read_gcrm_nc.cpp File Reference
#include "TestUtil.hpp"
#include "moab/Core.hpp"
#include "moab/ReadUtilIface.hpp"
#include "MBTagConventions.hpp"
+ Include dependency graph for read_gcrm_nc.cpp:
Functions
void test_read_all ()
void test_read_onevar ()
void test_read_onetimestep ()
void test_read_nomesh ()
void test_read_novars ()
void test_read_no_edges ()
void test_gather_onevar ()
void get_options (std::string &opts)
int main (int argc, char *argv[])
Variables
std::string example = "unittest/io/gcrm_r3.nc"
const double eps = 1e-6
const int layers = 3
const int interfaces = 3
Function Documentation
int main ( int  argc,
char *  argv[]
Definition at line 29 of file read_gcrm_nc.cpp.
References moab::fail(), RUN_TEST, test_gather_onevar(), test_read_all(), test_read_no_edges(), test_read_nomesh(), test_read_novars(), test_read_onetimestep(), and test_read_onevar().
    int result = 0;
#ifdef MOAB_HAVE_MPI
    int fail = MPI_Init( &argc, &argv );
    if( fail ) return 1;
#else
    argv[0]   = argv[argc - argc];  // To remove the warnings in serial mode about unused variables
#endif
    result += RUN_TEST( test_read_all );
    result += RUN_TEST( test_read_onevar );
    result += RUN_TEST( test_read_onetimestep );
    result += RUN_TEST( test_read_nomesh );
    result += RUN_TEST( test_read_novars );
    result += RUN_TEST( test_read_no_edges );
    result += RUN_TEST( test_gather_onevar );
    fail = MPI_Finalize();
#endif
    return result;
Definition at line 450 of file read_gcrm_nc.cpp.
References CHECK_EQUAL, CHECK_ERR, CHECK_REAL_EQUAL, moab::Interface::create_meshset(), eps, ErrorCode, example, moab::ParallelComm::filter_pstatus(), moab::ParallelComm::gather_data(), moab::Interface::get_entities_by_type(), moab::ReadUtilIface::get_gather_set(), get_options(), moab::ParallelComm::get_pcomm(), moab::Interface::globalId_tag(), layers, moab::Interface::load_file(), mb, MB_TAG_DENSE, MB_TYPE_DOUBLE, MBPOLYGON, MESHSET_SET, moab::ParallelComm::proc_config(), moab::ProcConfig::proc_rank(), moab::Range::psize(), PSTATUS_NOT, PSTATUS_NOT_OWNED, moab::Interface::query_interface(), rank, moab::Range::size(), moab::Interface::tag_get_data(), and moab::Interface::tag_get_handle().
Referenced by main().
    Core moab;
    Interface& mb = moab;
    EntityHandle file_set;
    ErrorCode rval = mb.create_meshset( MESHSET_SET, file_set );CHECK_ERR( rval );
    std::string opts;
    get_options( opts );
    // Read cell variable vorticity and create gather set on processor 0
    opts += ";VARIABLE=vorticity;GATHER_SET=0";
    rval = mb.load_file( example.c_str(), &file_set, opts.c_str() );CHECK_ERR( rval );
    ParallelComm* pcomm = ParallelComm::get_pcomm( &mb, 0 );
    int rank            = pcomm->proc_config().proc_rank();
    Range cells, cells_owned;
    rval = mb.get_entities_by_type( file_set, MBPOLYGON, cells );CHECK_ERR( rval );
    // Get local owned cells
    rval = pcomm->filter_pstatus( cells, PSTATUS_NOT_OWNED, PSTATUS_NOT, -1, &cells_owned );CHECK_ERR( rval );
    EntityHandle gather_set = 0;
    if( 0 == rank )
        // Get gather set
        ReadUtilIface* readUtilIface;
        mb.query_interface( readUtilIface );
        rval = readUtilIface->get_gather_set( gather_set );CHECK_ERR( rval );
        assert( gather_set != 0 );
    Tag vorticity_tag0, gid_tag;
    rval = mb.tag_get_handle( "vorticity0", layers, MB_TYPE_DOUBLE, vorticity_tag0, MB_TAG_DENSE );CHECK_ERR( rval );
    gid_tag = mb.globalId_tag();
    pcomm->gather_data( cells_owned, vorticity_tag0, gid_tag, gather_set, 0 );
    if( 0 == rank )
        // Get gather set cells
        Range gather_set_cells;
        rval = mb.get_entities_by_type( gather_set, MBPOLYGON, gather_set_cells );CHECK_ERR( rval );
        CHECK_EQUAL( (size_t)642, gather_set_cells.size() );
        CHECK_EQUAL( (size_t)1, gather_set_cells.psize() );
        // Check vorticity0 tag values on 4 gather set cells: first cell, two median cells, and last
        // cell
        EntityHandle cell_ents[] = { gather_set_cells[0], gather_set_cells[320], gather_set_cells[321],
                                     gather_set_cells[641] };
        double vorticity0_val[4 * layers];
        rval = mb.tag_get_data( vorticity_tag0, cell_ents, 4, vorticity0_val );CHECK_ERR( rval );
        // Only check first two layers
        // Layer 0
        CHECK_REAL_EQUAL( 3.629994, vorticity0_val[0 * layers], eps );
        CHECK_REAL_EQUAL( 0.131688, vorticity0_val[1 * layers], eps );
        CHECK_REAL_EQUAL( -0.554888, vorticity0_val[2 * layers], eps );
        CHECK_REAL_EQUAL( -0.554888, vorticity0_val[3 * layers], eps );
        // Layer 1
        CHECK_REAL_EQUAL( 3.629944, vorticity0_val[0 * layers + 1], eps );
        CHECK_REAL_EQUAL( 0.131686, vorticity0_val[1 * layers + 1], eps );
        CHECK_REAL_EQUAL( -0.554881, vorticity0_val[2 * layers + 1], eps );
        CHECK_REAL_EQUAL( -0.554881, vorticity0_val[3 * layers + 1], eps );
#endif
void test_read_all ( )
Definition at line 56 of file read_gcrm_nc.cpp.
References CHECK_EQUAL, CHECK_ERR, CHECK_REAL_EQUAL, edges, eps, ErrorCode, example, moab::Interface::get_entities_by_type(), get_options(), moab::ParallelComm::get_pcomm(), interfaces, layers, moab::Interface::load_file(), mb, MB_TYPE_DOUBLE, MBEDGE, MBPOLYGON, MBVERTEX, moab::ParallelComm::proc_config(), moab::ProcConfig::proc_size(), moab::Range::psize(), moab::Range::size(), moab::Interface::tag_get_data(), and moab::Interface::tag_get_handle().
    Core moab;
    std::string opts;
    // Read mesh and read all variables at all timesteps
    ErrorCode rval = mb.load_file( example.c_str(), 0, opts.c_str() );CHECK_ERR( rval );
    int procs           = pcomm->proc_config().proc_size();
#else
    int procs = 1;
#endif
    // Make check runs this test on one processor
    if( 1 == procs )
        // For u, wind and vorticity, check tag values on two entities
        double val[2 * layers];
        // Check tags for vertex variable u
        Tag u_tag0, u_tag1;
        rval = mb.tag_get_handle( "u0", layers, MB_TYPE_DOUBLE, u_tag0 );CHECK_ERR( rval );
        rval = mb.tag_get_handle( "u1", layers, MB_TYPE_DOUBLE, u_tag1 );CHECK_ERR( rval );
        // Get vertices (1280 vertices)
        Range verts;
        rval = mb.get_entities_by_type( 0, MBVERTEX, verts );CHECK_ERR( rval );
        CHECK_EQUAL( (size_t)1280, verts.size() );
        CHECK_EQUAL( (size_t)1, verts.psize() );
        // Check u tag values on first and last vertices
        EntityHandle vert_ents[] = { verts[0], verts[1279] };
        // Timestep 0
        rval = mb.tag_get_data( u_tag0, vert_ents, 2, val );CHECK_ERR( rval );
        // Layer 0
        CHECK_REAL_EQUAL( -4.839992, val[0 * layers], eps );
        CHECK_REAL_EQUAL( -3.699257, val[1 * layers], eps );
        // Layer 1
        CHECK_REAL_EQUAL( -4.839925, val[0 * layers + 1], eps );
        CHECK_REAL_EQUAL( -3.699206, val[1 * layers + 1], eps );
        // Timestep 1
        rval = mb.tag_get_data( u_tag1, vert_ents, 2, val );CHECK_ERR( rval );
        // Layer 0
        CHECK_REAL_EQUAL( -4.712473, val[0 * layers], eps );
        CHECK_REAL_EQUAL( -3.601793, val[1 * layers], eps );
        // Layer 1
        CHECK_REAL_EQUAL( -4.712409, val[0 * layers + 1], eps );
        CHECK_REAL_EQUAL( -3.601743, val[1 * layers + 1], eps );
        // Check tags for edge variable wind
        Tag wind_tag0, wind_tag1;
        rval = mb.tag_get_handle( "wind0", layers, MB_TYPE_DOUBLE, wind_tag0 );CHECK_ERR( rval );
        rval = mb.tag_get_handle( "wind1", layers, MB_TYPE_DOUBLE, wind_tag1 );CHECK_ERR( rval );
        // Get edges (1920 edges)
        Range edges;
        rval = mb.get_entities_by_type( 0, MBEDGE, edges );CHECK_ERR( rval );
        CHECK_EQUAL( (size_t)1920, edges.size() );
        CHECK_EQUAL( (size_t)1, edges.psize() );
        // Check wind tag values on first and last edges
        EntityHandle edge_ents[] = { edges[0], edges[1919] };
        // Timestep 0
        rval = mb.tag_get_data( wind_tag0, edge_ents, 2, val );CHECK_ERR( rval );
        // Layer 0
        CHECK_REAL_EQUAL( -5.081991, val[0 * layers], eps );
        CHECK_REAL_EQUAL( -6.420274, val[1 * layers], eps );
        // Layer 1
        CHECK_REAL_EQUAL( -5.081781, val[0 * layers + 1], eps );
        CHECK_REAL_EQUAL( -6.419831, val[1 * layers + 1], eps );
        // Timestep 1
        rval = mb.tag_get_data( wind_tag1, edge_ents, 2, val );CHECK_ERR( rval );
        // Layer 0
        CHECK_REAL_EQUAL( -4.948097, val[0 * layers], eps );
        CHECK_REAL_EQUAL( -6.251121, val[1 * layers], eps );
        // Layer 1
        CHECK_REAL_EQUAL( -4.947892, val[0 * layers + 1], eps );
        CHECK_REAL_EQUAL( -6.250690, val[1 * layers + 1], eps );
        // Check tags for cell variable vorticity
        Tag vorticity_tag0, vorticity_tag1;
        rval = mb.tag_get_handle( "vorticity0", layers, MB_TYPE_DOUBLE, vorticity_tag0 );CHECK_ERR( rval );
        rval = mb.tag_get_handle( "vorticity1", layers, MB_TYPE_DOUBLE, vorticity_tag1 );CHECK_ERR( rval );
        // Get cells (12 pentagons and 630 hexagons)
        Range cells;
        rval = mb.get_entities_by_type( 0, MBPOLYGON, cells );CHECK_ERR( rval );
        CHECK_EQUAL( (size_t)642, cells.size() );
        // GCRM pentagons are always padded to hexagons
        CHECK_EQUAL( (size_t)1, cells.psize() );
        // Check vorticity tag values on first and last cells
        EntityHandle cell_ents[] = { cells[0], cells[641] };
        // Timestep 0
        rval = mb.tag_get_data( vorticity_tag0, cell_ents, 2, val );CHECK_ERR( rval );
        // Layer 0
        CHECK_REAL_EQUAL( 3.629994, val[0 * layers], eps );
        CHECK_REAL_EQUAL( -0.554888, val[1 * layers], eps );
        // Layer 1
        CHECK_REAL_EQUAL( 3.629944, val[0 * layers + 1], eps );
        CHECK_REAL_EQUAL( -0.554881, val[1 * layers + 1], eps );
        // Timestep 1
        rval = mb.tag_get_data( vorticity_tag1, cell_ents, 2, val );CHECK_ERR( rval );
        // Layer 0
        CHECK_REAL_EQUAL( 3.534355, val[0 * layers], eps );
        CHECK_REAL_EQUAL( -0.540269, val[1 * layers], eps );
        // Layer 1
        CHECK_REAL_EQUAL( 3.534306, val[0 * layers + 1], eps );
        CHECK_REAL_EQUAL( -0.540262, val[1 * layers + 1], eps );
        // Check tags for cell variable pressure
        Tag pressure_tag0, pressure_tag1;
        rval = mb.tag_get_handle( "pressure0", interfaces, MB_TYPE_DOUBLE, pressure_tag0 );CHECK_ERR( rval );
        rval = mb.tag_get_handle( "pressure1", interfaces, MB_TYPE_DOUBLE, pressure_tag1 );CHECK_ERR( rval );
        // For pressure, check tag values on two cells
        double pressure_val[2 * interfaces];
        // Check pressure tag values on first and last cells
        // Only check first two interfaces
        // Timestep 0
        rval = mb.tag_get_data( pressure_tag0, cell_ents, 2, pressure_val );CHECK_ERR( rval );
        // Interface 0
        CHECK_REAL_EQUAL( 4.44234e-06, pressure_val[0 * interfaces], 1e-11 );
        CHECK_REAL_EQUAL( 0.2486804, pressure_val[1 * interfaces], 1e-7 );
        // Interface 1
        CHECK_REAL_EQUAL( 4.44234e-06, pressure_val[0 * interfaces + 1], 1e-11 );
        CHECK_REAL_EQUAL( 0.2486804, pressure_val[1 * interfaces + 1], 1e-7 );
        // Timestep 1
        rval = mb.tag_get_data( pressure_tag1, cell_ents, 2, pressure_val );CHECK_ERR( rval );
        // Interface 0
        CHECK_REAL_EQUAL( 2.365176e-07, pressure_val[0 * interfaces], 1e-13 );
        CHECK_REAL_EQUAL( 0.02234409, pressure_val[1 * interfaces], 1e-8 );
        // Interface 1
        CHECK_REAL_EQUAL( 2.365176e-07, pressure_val[0 * interfaces + 1], 1e-13 );
        CHECK_REAL_EQUAL( 0.02234409, pressure_val[1 * interfaces + 1], 1e-8 );
Definition at line 433 of file read_gcrm_nc.cpp.
References CHECK_EQUAL, CHECK_ERR, edges, ErrorCode, example, moab::Interface::get_entities_by_type(), get_options(), moab::Interface::load_file(), mb, MBEDGE, and moab::Range::size().
    Core moab;
    std::string opts;
    opts += ";NO_EDGES;VARIABLE=";
    ErrorCode rval = mb.load_file( example.c_str(), NULL, opts.c_str() );CHECK_ERR( rval );
    // Get edges
    Range edges;
    CHECK_EQUAL( (size_t)0, edges.size() );
void test_read_nomesh ( )
Definition at line 299 of file read_gcrm_nc.cpp.
References CHECK_EQUAL, CHECK_ERR, moab::Interface::create_meshset(), ErrorCode, example, get_options(), layers, moab::Interface::load_file(), mb, MB_TAG_NOT_FOUND, MB_TYPE_DOUBLE, MESHSET_SET, and moab::Interface::tag_get_handle().
    Core moab;
    // Need a file set for nomesh to work right
    std::string orig, opts;
    get_options( orig );
    // Read mesh and read all variables at 1st timestep
    opts = orig + ";TIMESTEP=0";
    // Check u tags
    Tag u_tag0, u_tag1;
    // Tag u1 should not exist
    CHECK_EQUAL( rval, MB_TAG_NOT_FOUND );
    // Read all variables at 2nd timestep 0, no need to read mesh
    opts = orig + ";TIMESTEP=1;NOMESH";
    // Check tag u1 again
    // Tag u1 should exist at this time
    CHECK_ERR( rval );
void test_read_novars ( )
Definition at line 332 of file read_gcrm_nc.cpp.
References CHECK_EQUAL, CHECK_ERR, CHECK_REAL_EQUAL, moab::Interface::create_meshset(), eps, ErrorCode, example, moab::Interface::get_entities_by_type(), get_options(), moab::ParallelComm::get_pcomm(), layers, moab::Interface::load_file(), mb, MB_TAG_NOT_FOUND, MB_TYPE_DOUBLE, MBPOLYGON, MESHSET_SET, moab::ParallelComm::proc_config(), moab::ProcConfig::proc_size(), moab::Range::psize(), moab::Range::size(), moab::Interface::tag_get_data(), and moab::Interface::tag_get_handle().
    Core moab;
    get_options( orig );CHECK_ERR( rval );
    // Read header info only, no mesh, no variables
    opts = orig + ";NOMESH;VARIABLE=";
    // Read mesh, but still no variables
    opts = orig + ";VARIABLE=";
    // Check vorticity tags
    // Tag vorticity0 should not exist
    // Tag vorticity1 should not exist
    // Read vorticity at 1st timestep, no need to read mesh
    opts = orig + ";VARIABLE=vorticity;TIMESTEP=0;NOMESH";
    // Check vorticity tags again
    // Tag vorticity0 should exist at this time
    CHECK_ERR( rval );
    // Tag vorticity1 should still not exist
    // Read vorticity at 2nd timestep, no need to read mesh
    opts = orig + ";VARIABLE=vorticity;TIMESTEP=1;NOMESH";
    // Check tag vorticity1 again
    // Tag vorticity1 should exist at this time
    CHECK_ERR( rval );
#else
    int procs = 1;
#endif
    if( 1 == procs )
        Range cells;
        // Check vorticity tag values on 4 cells: first cell, two median cells, and last cell
        EntityHandle cell_ents[] = { cells[0], cells[320], cells[321], cells[641] };
        double vorticity_val[4 * layers];
        // Timestep 0
        rval = mb.tag_get_data( vorticity_tag0, cell_ents, 4, vorticity_val );CHECK_ERR( rval );
        // Layer 0
        CHECK_REAL_EQUAL( 3.629994, vorticity_val[0 * layers], eps );
        CHECK_REAL_EQUAL( 0.131688, vorticity_val[1 * layers], eps );
        CHECK_REAL_EQUAL( -0.554888, vorticity_val[2 * layers], eps );
        CHECK_REAL_EQUAL( -0.554888, vorticity_val[3 * layers], eps );
        // Layer 1
        CHECK_REAL_EQUAL( 3.629944, vorticity_val[0 * layers + 1], eps );
        CHECK_REAL_EQUAL( 0.131686, vorticity_val[1 * layers + 1], eps );
        CHECK_REAL_EQUAL( -0.554881, vorticity_val[2 * layers + 1], eps );
        CHECK_REAL_EQUAL( -0.554881, vorticity_val[3 * layers + 1], eps );
        // Timestep 1
        rval = mb.tag_get_data( vorticity_tag1, cell_ents, 4, vorticity_val );CHECK_ERR( rval );
        // Layer 0
        CHECK_REAL_EQUAL( 3.534355, vorticity_val[0 * layers], eps );
        CHECK_REAL_EQUAL( 0.128218, vorticity_val[1 * layers], eps );
        CHECK_REAL_EQUAL( -0.540269, vorticity_val[2 * layers], eps );
        CHECK_REAL_EQUAL( -0.540269, vorticity_val[3 * layers], eps );
        // Layer 1
        CHECK_REAL_EQUAL( 3.534306, vorticity_val[0 * layers + 1], eps );
        CHECK_REAL_EQUAL( 0.128216, vorticity_val[1 * layers + 1], eps );
        CHECK_REAL_EQUAL( -0.540262, vorticity_val[2 * layers + 1], eps );
        CHECK_REAL_EQUAL( -0.540262, vorticity_val[3 * layers + 1], eps );
Definition at line 279 of file read_gcrm_nc.cpp.
References CHECK_EQUAL, CHECK_ERR, ErrorCode, example, get_options(), layers, moab::Interface::load_file(), mb, MB_TAG_NOT_FOUND, MB_TYPE_DOUBLE, and moab::Interface::tag_get_handle().
    Core moab;
    std::string opts;
    // Read mesh and read all variables at 2nd timestep
    opts += ";TIMESTEP=1";
void test_read_onevar ( )
Definition at line 211 of file read_gcrm_nc.cpp.
References CHECK_EQUAL, CHECK_ERR, CHECK_REAL_EQUAL, eps, ErrorCode, example, moab::Interface::get_entities_by_type(), get_options(), moab::ParallelComm::get_pcomm(), layers, moab::Interface::load_file(), mb, MB_TYPE_DOUBLE, MBPOLYGON, moab::ParallelComm::proc_config(), moab::ProcConfig::proc_size(), moab::Range::psize(), moab::Range::size(), moab::Interface::tag_get_data(), and moab::Interface::tag_get_handle().
    Core moab;
    std::string opts;
    // Read mesh and read cell variable vorticity at all timesteps
    opts += ";VARIABLE=vorticity";
#else
    int procs = 1;
#endif
    if( 1 == procs )
        Range cells;
        // Timestep 0
        // Layer 0
        // Layer 1
        // Timestep 1
        // Layer 0
        // Layer 1
Variable Documentation
Definition at line 25 of file read_gcrm_nc.cpp.
Definition at line 8 of file read_gcrm_nc.cpp.
Definition at line 27 of file read_gcrm_nc.cpp.
Referenced by test_read_all().
