MOAB
4.9.3pre
Computes the generalized eigenvalues and eigenvectors of a pair of general matrices. More...
#include <GeneralizedEigenSolver.h>
Public Types | |
| enum | { RowsAtCompileTime = MatrixType::RowsAtCompileTime, ColsAtCompileTime = MatrixType::ColsAtCompileTime, Options = MatrixType::Options, MaxRowsAtCompileTime = MatrixType::MaxRowsAtCompileTime, MaxColsAtCompileTime = MatrixType::MaxColsAtCompileTime } |
| typedef _MatrixType | MatrixType |
Synonym for the template parameter _MatrixType. | |
| typedef MatrixType::Scalar | Scalar |
| Scalar type for matrices of type MatrixType. | |
| typedef NumTraits< Scalar >::Real | RealScalar |
| typedef Eigen::Index | Index |
| typedef std::complex< RealScalar > | ComplexScalar |
| Complex scalar type for MatrixType. | |
| typedef Matrix< Scalar, ColsAtCompileTime, 1, Options &~RowMajor, MaxColsAtCompileTime, 1 > | VectorType |
| Type for vector of real scalar values eigenvalues as returned by betas(). | |
| typedef Matrix< ComplexScalar, ColsAtCompileTime, 1, Options &~RowMajor, MaxColsAtCompileTime, 1 > | ComplexVectorType |
| Type for vector of complex scalar values eigenvalues as returned by betas(). | |
| typedef CwiseBinaryOp < internal::scalar_quotient_op < ComplexScalar, Scalar > , ComplexVectorType, VectorType > | EigenvalueType |
| Expression type for the eigenvalues as returned by eigenvalues(). | |
| typedef Matrix< ComplexScalar, RowsAtCompileTime, ColsAtCompileTime, Options, MaxRowsAtCompileTime, MaxColsAtCompileTime > | EigenvectorsType |
| Type for matrix of eigenvectors as returned by eigenvectors(). | |
Public Member Functions | |
| GeneralizedEigenSolver () | |
| Default constructor. | |
| GeneralizedEigenSolver (Index size) | |
| Default constructor with memory preallocation. | |
| GeneralizedEigenSolver (const MatrixType &A, const MatrixType &B, bool computeEigenvectors=true) | |
| Constructor; computes the generalized eigendecomposition of given matrix pair. | |
| EigenvalueType | eigenvalues () const |
| Returns an expression of the computed generalized eigenvalues. | |
| ComplexVectorType | alphas () const |
| VectorType | betas () const |
| GeneralizedEigenSolver & | compute (const MatrixType &A, const MatrixType &B, bool computeEigenvectors=true) |
| Computes generalized eigendecomposition of given matrix. | |
| ComputationInfo | info () const |
| GeneralizedEigenSolver & | setMaxIterations (Index maxIters) |
Protected Types | |
| typedef Matrix< Scalar, ColsAtCompileTime, 1, Options &~RowMajor, MaxColsAtCompileTime, 1 > | ColumnVectorType |
Static Protected Member Functions | |
| static void | check_template_parameters () |
Protected Attributes | |
| MatrixType | m_eivec |
| ComplexVectorType | m_alphas |
| VectorType | m_betas |
| bool | m_isInitialized |
| bool | m_eigenvectorsOk |
| RealQZ< MatrixType > | m_realQZ |
| MatrixType | m_matS |
| ColumnVectorType | m_tmp |
| _MatrixType | the type of the matrices of which we are computing the eigen-decomposition; this is expected to be an instantiation of the Matrix class template. Currently, only real matrices are supported. |
The generalized eigenvalues and eigenvectors of a matrix pair
and
are scalars
and vectors
such that
. If
is a diagonal matrix with the eigenvalues on the diagonal, and
is a matrix with the eigenvectors as its columns, then
. The matrix
is almost always invertible, in which case we have
. This is called the generalized eigen-decomposition.
The generalized eigenvalues and eigenvectors of a matrix pair may be complex, even when the matrices are real. Moreover, the generalized eigenvalue might be infinite if the matrix B is singular. To workaround this difficulty, the eigenvalues are provided as a pair of complex
and real
such that:
. If
is (nearly) zero, then one can consider the well defined left eigenvalue
such that:
, or even
where
is called the left eigenvector.
Call the function compute() to compute the generalized eigenvalues and eigenvectors of a given matrix pair. Alternatively, you can use the GeneralizedEigenSolver(const MatrixType&, const MatrixType&, bool) constructor which computes the eigenvalues and eigenvectors at construction time. Once the eigenvalue and eigenvectors are computed, they can be retrieved with the eigenvalues() and eigenvectors() functions.
Here is an usage example of this class: Example:
Output:
Definition at line 57 of file GeneralizedEigenSolver.h.
typedef Matrix<Scalar, ColsAtCompileTime, 1, Options & ~RowMajor, MaxColsAtCompileTime, 1> Eigen::GeneralizedEigenSolver< _MatrixType >::ColumnVectorType [protected] |
Definition at line 281 of file GeneralizedEigenSolver.h.
| typedef std::complex<RealScalar> Eigen::GeneralizedEigenSolver< _MatrixType >::ComplexScalar |
This is std::complex<Scalar> if Scalar is real (e.g., float or double) and just Scalar if Scalar is complex.
Definition at line 83 of file GeneralizedEigenSolver.h.
| typedef Matrix<ComplexScalar, ColsAtCompileTime, 1, Options & ~RowMajor, MaxColsAtCompileTime, 1> Eigen::GeneralizedEigenSolver< _MatrixType >::ComplexVectorType |
This is a column vector with entries of type ComplexScalar. The length of the vector is the size of MatrixType.
Definition at line 97 of file GeneralizedEigenSolver.h.
| typedef CwiseBinaryOp<internal::scalar_quotient_op<ComplexScalar,Scalar>,ComplexVectorType,VectorType> Eigen::GeneralizedEigenSolver< _MatrixType >::EigenvalueType |
Definition at line 101 of file GeneralizedEigenSolver.h.
| typedef Matrix<ComplexScalar, RowsAtCompileTime, ColsAtCompileTime, Options, MaxRowsAtCompileTime, MaxColsAtCompileTime> Eigen::GeneralizedEigenSolver< _MatrixType >::EigenvectorsType |
This is a square matrix with entries of type ComplexScalar. The size is the same as the size of MatrixType.
Definition at line 108 of file GeneralizedEigenSolver.h.
| typedef Eigen::Index Eigen::GeneralizedEigenSolver< _MatrixType >::Index |
Definition at line 75 of file GeneralizedEigenSolver.h.
| typedef _MatrixType Eigen::GeneralizedEigenSolver< _MatrixType >::MatrixType |
Definition at line 62 of file GeneralizedEigenSolver.h.
| typedef NumTraits<Scalar>::Real Eigen::GeneralizedEigenSolver< _MatrixType >::RealScalar |
Definition at line 74 of file GeneralizedEigenSolver.h.
| typedef MatrixType::Scalar Eigen::GeneralizedEigenSolver< _MatrixType >::Scalar |
Definition at line 73 of file GeneralizedEigenSolver.h.
| typedef Matrix<Scalar, ColsAtCompileTime, 1, Options & ~RowMajor, MaxColsAtCompileTime, 1> Eigen::GeneralizedEigenSolver< _MatrixType >::VectorType |
This is a column vector with entries of type Scalar. The length of the vector is the size of MatrixType.
Definition at line 90 of file GeneralizedEigenSolver.h.
| anonymous enum |
Definition at line 64 of file GeneralizedEigenSolver.h.
| Eigen::GeneralizedEigenSolver< _MatrixType >::GeneralizedEigenSolver | ( | ) | [inline] |
The default constructor is useful in cases in which the user intends to perform decompositions via EigenSolver::compute(const MatrixType&, bool).
Definition at line 117 of file GeneralizedEigenSolver.h.
| Eigen::GeneralizedEigenSolver< _MatrixType >::GeneralizedEigenSolver | ( | Index | size | ) | [inline, explicit] |
Like the default constructor but with preallocation of the internal data according to the specified problem size.
Definition at line 125 of file GeneralizedEigenSolver.h.
| Eigen::GeneralizedEigenSolver< _MatrixType >::GeneralizedEigenSolver | ( | const MatrixType & | A, |
| const MatrixType & | B, | ||
| bool | computeEigenvectors = true |
| ) | [inline] |
| [in] | A | Square matrix whose eigendecomposition is to be computed. |
| [in] | B | Square matrix whose eigendecomposition is to be computed. |
| [in] | computeEigenvectors | If true, both the eigenvectors and the eigenvalues are computed; if false, only the eigenvalues are computed. |
This constructor calls compute() to compute the generalized eigenvalues and eigenvectors.
Definition at line 148 of file GeneralizedEigenSolver.h.
: m_eivec(A.rows(), A.cols()), m_alphas(A.cols()), m_betas(A.cols()), m_isInitialized(false), m_eigenvectorsOk(false), m_realQZ(A.cols()), m_matS(A.rows(), A.cols()), m_tmp(A.cols()) { compute(A, B, computeEigenvectors); }
| ComplexVectorType Eigen::GeneralizedEigenSolver< _MatrixType >::alphas | ( | ) | const [inline] |
This vector permits to reconstruct the j-th eigenvalues as alphas(i)/betas(j).
Definition at line 209 of file GeneralizedEigenSolver.h.
eigen_assert(m_isInitialized && "GeneralizedEigenSolver is not initialized.");
return m_alphas;
| VectorType Eigen::GeneralizedEigenSolver< _MatrixType >::betas | ( | ) | const [inline] |
Definition at line 220 of file GeneralizedEigenSolver.h.
return m_betas;
| static void Eigen::GeneralizedEigenSolver< _MatrixType >::check_template_parameters | ( | ) | [inline, static, protected] |
Definition at line 267 of file GeneralizedEigenSolver.h.
EIGEN_STATIC_ASSERT_NON_INTEGER(Scalar);
EIGEN_STATIC_ASSERT(!NumTraits<Scalar>::IsComplex, NUMERIC_TYPE_MUST_BE_REAL);
| GeneralizedEigenSolver< MatrixType > & Eigen::GeneralizedEigenSolver< MatrixType >::compute | ( | const MatrixType & | A, |
*this This function computes the eigenvalues of the real matrix matrix. The eigenvalues() function can be used to retrieve them. If computeEigenvectors is true, then the eigenvectors are also computed and can be retrieved by calling eigenvectors().
The matrix is first reduced to real generalized Schur form using the RealQZ class. The generalized Schur decomposition is then used to compute the eigenvalues and eigenvectors.
The cost of the computation is dominated by the cost of the generalized Schur decomposition.
This method reuses of the allocated data in the GeneralizedEigenSolver object.
Definition at line 298 of file GeneralizedEigenSolver.h.
check_template_parameters();
using std::sqrt;
using std::abs;
eigen_assert(A.cols() == A.rows() && B.cols() == A.rows() && B.cols() == B.rows());
// Reduce to generalized real Schur form:
// A = Q S Z and B = Q T Z
m_realQZ.compute(A, B, computeEigenvectors);
if (m_realQZ.info() == Success)
m_matS = m_realQZ.matrixS();
if (computeEigenvectors)
m_eivec = m_realQZ.matrixZ().transpose();
// Compute eigenvalues from matS
m_alphas.resize(A.cols());
m_betas.resize(A.cols());
Index i = 0;
while (i < A.cols())
if (i == A.cols() - 1 || m_matS.coeff(i+1, i) == Scalar(0))
m_alphas.coeffRef(i) = m_matS.coeff(i, i);
m_betas.coeffRef(i) = m_realQZ.matrixT().coeff(i,i);
++i;
else
Scalar p = Scalar(0.5) * (m_matS.coeff(i, i) - m_matS.coeff(i+1, i+1));
Scalar z = sqrt(abs(p * p + m_matS.coeff(i+1, i) * m_matS.coeff(i, i+1)));
m_alphas.coeffRef(i) = ComplexScalar(m_matS.coeff(i+1, i+1) + p, z);
m_alphas.coeffRef(i+1) = ComplexScalar(m_matS.coeff(i+1, i+1) + p, -z);
m_betas.coeffRef(i+1) = m_realQZ.matrixT().coeff(i,i);
i += 2;
m_isInitialized = true;
m_eigenvectorsOk = false;//computeEigenvectors;
return *this;
| EigenvalueType Eigen::GeneralizedEigenSolver< _MatrixType >::eigenvalues | ( | ) | const [inline] |
It is a shortcut for
Not that betas might contain zeros. It is therefore not recommended to use this function, but rather directly deal with the alphas and betas vectors.
The eigenvalues are repeated according to their algebraic multiplicity, so there are as many eigenvalues as rows in the matrix. The eigenvalues are not sorted in any particular order.
Definition at line 198 of file GeneralizedEigenSolver.h.
return EigenvalueType(m_alphas,m_betas);
| ComputationInfo Eigen::GeneralizedEigenSolver< _MatrixType >::info | ( | ) | const [inline] |
Definition at line 251 of file GeneralizedEigenSolver.h.
eigen_assert(m_isInitialized && "EigenSolver is not initialized.");
return m_realQZ.info();
| GeneralizedEigenSolver& Eigen::GeneralizedEigenSolver< _MatrixType >::setMaxIterations | ( | Index | maxIters | ) | [inline] |
Sets the maximal number of iterations allowed.
Definition at line 259 of file GeneralizedEigenSolver.h.
m_realQZ.setMaxIterations(maxIters);
return *this;
ComplexVectorType Eigen::GeneralizedEigenSolver< _MatrixType >::m_alphas [protected] |
Definition at line 274 of file GeneralizedEigenSolver.h.
VectorType Eigen::GeneralizedEigenSolver< _MatrixType >::m_betas [protected] |
Definition at line 275 of file GeneralizedEigenSolver.h.
bool Eigen::GeneralizedEigenSolver< _MatrixType >::m_eigenvectorsOk [protected] |
Definition at line 277 of file GeneralizedEigenSolver.h.
MatrixType Eigen::GeneralizedEigenSolver< _MatrixType >::m_eivec [protected] |
Definition at line 273 of file GeneralizedEigenSolver.h.
bool Eigen::GeneralizedEigenSolver< _MatrixType >::m_isInitialized [protected] |
Definition at line 276 of file GeneralizedEigenSolver.h.
MatrixType Eigen::GeneralizedEigenSolver< _MatrixType >::m_matS [protected] |
Definition at line 279 of file GeneralizedEigenSolver.h.
RealQZ<MatrixType> Eigen::GeneralizedEigenSolver< _MatrixType >::m_realQZ [protected] |
Definition at line 278 of file GeneralizedEigenSolver.h.
ColumnVectorType Eigen::GeneralizedEigenSolver< _MatrixType >::m_tmp [protected] |
Definition at line 282 of file GeneralizedEigenSolver.h.
