MBMesquite::AddQualityMetric Class Reference
#include <AddQualityMetric.hpp>
+ Inheritance diagram for MBMesquite::AddQualityMetric:
+ Collaboration diagram for MBMesquite::AddQualityMetric:
Public Member Functions
 AddQualityMetric (QualityMetric *qm1, QualityMetric *qm2, MsqError &err)
 ~AddQualityMetric ()
MetricType get_metric_type () const
std::string get_name () const
int get_negate_flag () const
 1 if metric should be minimized, -1 if metric should be maximized.
QualityMetricget_first_metric () const
QualityMetricget_second_metric () const
virtual void get_evaluations (PatchData &pd, std::vector< size_t > &handles, bool free_vertices_only, MsqError &err)
 Get locations at which metric can be evaluated.
virtual bool evaluate (PatchData &pd, size_t handle, double &value, MsqError &err)
 Get metric value at a logical location in the patch.
virtual bool evaluate_with_indices (PatchData &pd, size_t handle, double &value, std::vector< size_t > &indices, MsqError &err)
virtual bool evaluate_with_gradient (PatchData &pd, size_t handle, double &value, std::vector< size_t > &indices, std::vector< Vector3D > &gradient, MsqError &err)
 Get metric value and gradient at a logical location in the patch.
virtual bool evaluate_with_Hessian (PatchData &pd, size_t handle, double &value, std::vector< size_t > &indices, std::vector< Vector3D > &gradient, std::vector< Matrix3D > &Hessian, MsqError &err)
 Get metric value and deravitives at a logical location in the patch.
Private Attributes
QualityMetricmetric1
QualityMetricmetric2
std::vector< size_t > mHandles
std::vector< size_t > indices1
std::vector< size_t > indices2
std::vector< Vector3Dgrad1
std::vector< Vector3Dgrad2
std::vector< Matrix3DHess1
std::vector< Matrix3DHess2
Detailed Description
Definition at line 41 of file AddQualityMetric.hpp.
Definition at line 41 of file AddQualityMetric.cpp.
References MBMesquite::QualityMetric::get_metric_type(), MBMesquite::QualityMetric::get_negate_flag(), MBMesquite::MsqError::INVALID_ARG, and MSQ_SETERR.
    : metric1( *qm1 ), metric2( *qm2 )
    if( qm1->get_metric_type() != qm2->get_metric_type() || qm1->get_negate_flag() != qm2->get_negate_flag() )
        MSQ_SETERR( err )( "Incompatible metrics", MsqError::INVALID_ARG );
Member Function Documentation
bool MBMesquite::AddQualityMetric::evaluate ( PatchData pd,
size_t  handle,
double &  value,
MsqError err
) [virtual]
Evaluate the metric at one location in the PatchData.
Parameters:
pdThe patch.
handleThe location in the patch (as passed back from get_evaluations).
valueThe output metric value.
Implements MBMesquite::QualityMetric.
Definition at line 77 of file AddQualityMetric.cpp.
References MBMesquite::QualityMetric::evaluate(), metric1, metric2, and MSQ_ERRZERO.
    double val1, val2;
    bool rval1, rval2;
    rval1 = metric1.evaluate( pd, handle, val1, err );
    MSQ_ERRZERO( err );
    rval2 = metric2.evaluate( pd, handle, val2, err );
    MSQ_ERRZERO( err );
    value = val1 + val2;
    return rval1 && rval2;
bool MBMesquite::AddQualityMetric::evaluate_with_gradient ( PatchData pd,
size_t  handle,
double &  value,
std::vector< size_t > &  indices,
std::vector< Vector3D > &  gradient,
MsqError err
) [virtual]
Parameters:
pdThe patch.
indicesThe free vertices that the evaluation is a function of, specified as vertex indices in the PatchData.
gradientThe gradient of the metric as a function of the coordinates of the free vertices passed back in the indices list.
Reimplemented from MBMesquite::QualityMetric.
Definition at line 111 of file AddQualityMetric.cpp.
References MBMesquite::QualityMetric::evaluate_with_gradient(), grad1, grad2, indices1, indices2, metric1, metric2, and MSQ_ERRZERO.
    std::vector< size_t >::iterator i;
    size_t j;
    double val1, val2;
    bool rval1, rval2;
    rval1 = metric1.evaluate_with_gradient( pd, handle, val1, indices1, grad1, err );
    MSQ_ERRZERO( err );
    rval2 = metric2.evaluate_with_gradient( pd, handle, val2, indices2, grad2, err );
    MSQ_ERRZERO( err );
    indices.resize( indices1.size() + indices2.size() );
    i = std::copy( indices1.begin(), indices1.end(), indices.begin() );
    std::copy( indices2.begin(), indices2.end(), i );
    std::sort( indices.begin(), indices.end() );
    indices.erase( std::unique( indices.begin(), indices.end() ), indices.end() );
    gradient.clear();
    gradient.resize( indices.size(), Vector3D( 0.0 ) );
    for( j = 0; j < indices1.size(); ++j )
        i        = std::lower_bound( indices.begin(), indices.end(), indices1[j] );
        size_t k = i - indices.begin();
        gradient[k] += grad1[j];
    for( j = 0; j < indices2.size(); ++j )
        i        = std::lower_bound( indices.begin(), indices.end(), indices2[j] );
        gradient[k] += grad2[j];
bool MBMesquite::AddQualityMetric::evaluate_with_Hessian ( PatchData pd,
size_t  handle,
double &  value,
std::vector< Matrix3D > &  Hessian,
MsqError err
) [virtual]
Parameters:
pdThe patch.
HessianThe Hessian of the metric as a function of the coordinates. The Hessian is passed back as the upper-triangular portion of the matrix in row-major order, where each Matrix3D is the portion of the Hessian with respect to the vertices at the corresponding positions in the indices list.
Definition at line 152 of file AddQualityMetric.cpp.
References MBMesquite::QualityMetric::evaluate_with_Hessian(), grad1, grad2, Hess1, Hess2, indices1, indices2, metric1, metric2, MSQ_ERRZERO, n, N, and nr.
    size_t j, r, c, n, h;
    double val1, val2;
    bool rval1, rval2;
    rval1 = metric1.evaluate_with_Hessian( pd, handle, val1, indices1, grad1, Hess1, err );
    MSQ_ERRZERO( err );
    rval2 = metric2.evaluate_with_Hessian( pd, handle, val2, indices2, grad2, Hess2, err );
    MSQ_ERRZERO( err );
    gradient.clear();
        indices1[j] = i - indices.begin();
        gradient[indices1[j]] += grad1[j];
        indices2[j] = i - indices.begin();
        gradient[indices2[j]] += grad2[j];
    const size_t N = indices.size();
    Hessian.clear();
    Hessian.resize( N * ( N + 1 ) / 2, Matrix3D( 0.0 ) );
    n = indices1.size();
    h = 0;
    for( r = 0; r < n; ++r )
        const size_t nr = indices1[r];
        for( c = r; c < n; ++c )
            const size_t nc = indices1[c];
            if( nr <= nc )
                Hessian[N * nr - nr * ( nr + 1 ) / 2 + nc] += Hess1[h++];
            else
                Hessian[N * nc - nc * ( nc + 1 ) / 2 + nr].plus_transpose_equal( Hess1[h++] );
    n = indices2.size();
    h = 0;
        const size_t nr = indices2[r];
            const size_t nc = indices2[c];
            if( nr <= nc )
                Hessian[N * nr - nr * ( nr + 1 ) / 2 + nc] += Hess2[h++];
            else
                Hessian[N * nc - nc * ( nc + 1 ) / 2 + nr].plus_transpose_equal( Hess2[h++] );
bool MBMesquite::AddQualityMetric::evaluate_with_indices ( PatchData pd,
size_t  handle,
double &  value,
MsqError err
) [virtual]
Parameters:
pdThe patch.
Definition at line 89 of file AddQualityMetric.cpp.
References MBMesquite::QualityMetric::evaluate_with_indices(), indices1, indices2, metric1, metric2, and MSQ_ERRZERO.
    double val1, val2;
    bool rval1, rval2;
    rval1 = metric1.evaluate_with_indices( pd, handle, val1, indices1, err );
    MSQ_ERRZERO( err );
    rval2 = metric2.evaluate_with_indices( pd, handle, val2, indices2, err );
    MSQ_ERRZERO( err );
    indices.clear();
    std::sort( indices1.begin(), indices1.end() );
    std::sort( indices2.begin(), indices2.end() );
    std::set_union( indices1.begin(), indices1.end(), indices2.begin(), indices2.end(), std::back_inserter( indices ) );
void MBMesquite::AddQualityMetric::get_evaluations ( PatchData pd,
std::vector< size_t > &  handles,
MsqError err
) [virtual]
Different metrics are evaluated for different things within a patch. For example, an element-based metric will be evaluated once for each element in patch, a vertex-based metric once for each veretx, and a target/sample-point based metric will be evaluated once for each samle point in each element. This method returns a list of handles, one for each location in the patch at which the metric can be evaluated. The handle values are used as input to the evaluate methods.
Parameters:
pdThe patch
handlesOutput list of handles
free_vertices_onlyIf true, only pass back evaluation points that depend on at least one free vertex.
Definition at line 67 of file AddQualityMetric.cpp.
References MBMesquite::QualityMetric::get_evaluations(), MBMesquite::MsqError::INVALID_STATE, metric1, metric2, mHandles, MSQ_ERRRTN, and MSQ_SETERR.
    metric1.get_evaluations( pd, handles, free_only, err );MSQ_ERRRTN( err );
    metric2.get_evaluations( pd, mHandles, free_only, err );MSQ_ERRRTN( err );
    if( handles != mHandles )
        MSQ_SETERR( err )( "Incompatible metrics", MsqError::INVALID_STATE );
Definition at line 54 of file AddQualityMetric.hpp.
References metric1.
        return &metric1;
std::string MBMesquite::AddQualityMetric::get_name ( ) const [virtual]
Definition at line 57 of file AddQualityMetric.cpp.
References MBMesquite::QualityMetric::get_name(), metric1, and metric2.
    return std::string( "Sum(" ) + metric1.get_name() + ", " + metric2.get_name() + ")";
Definition at line 62 of file AddQualityMetric.cpp.
References MBMesquite::QualityMetric::get_negate_flag(), and metric1.
    return metric1.get_negate_flag();
Definition at line 58 of file AddQualityMetric.hpp.
References metric2.
        return &metric2;
Member Data Documentation
std::vector< Vector3D > MBMesquite::AddQualityMetric::grad1 [mutable, private]
Definition at line 95 of file AddQualityMetric.hpp.
Referenced by evaluate_with_gradient(), and evaluate_with_Hessian().
std::vector< Vector3D > MBMesquite::AddQualityMetric::grad2 [mutable, private]
std::vector< Matrix3D > MBMesquite::AddQualityMetric::Hess1 [mutable, private]
Definition at line 96 of file AddQualityMetric.hpp.
Referenced by evaluate_with_Hessian().
std::vector< Matrix3D > MBMesquite::AddQualityMetric::Hess2 [mutable, private]
std::vector< size_t > MBMesquite::AddQualityMetric::indices1 [mutable, private]
std::vector< size_t > MBMesquite::AddQualityMetric::indices2 [mutable, private]
std::vector< size_t > MBMesquite::AddQualityMetric::mHandles [mutable, private]
Definition at line 93 of file AddQualityMetric.hpp.
Referenced by get_evaluations().
List of all members.
