MOAB: Mesh Oriented datABase
(version 5.4.0)
#include "Randomize.hpp"
#include "InstructionQueue.hpp"
#include "QualityAssessor.hpp"
#include "MeshImpl.hpp"
#include "PatchData.hpp"
#include "MsqVertex.hpp"
#include "IdealWeightInverseMeanRatio.hpp"
#include "PMeanPTemplate.hpp"
#include "TerminationCriterion.hpp"
#include <cassert>
#include "domain.hpp"
#include <iostream>
#include <iomanip>
#include <memory>
#include <cstdio>
#include <cstring>
#include <cctype>
#include <cstdlib>
Classes | |
class | UnOptimizer |
Functions | |
int | main (int argc, char *argv[]) |
Variables | |
const char | INVALID_FLAG = 'i' |
const char | PERCENT_FLAG = 'p' |
const char | UNOPTIMIZE_FLAG = 'u' |
int main | ( | int | argc, |
char * | argv[] | ||
Definition at line 102 of file randomize.cpp.
References add_domain_args(), MBMesquite::TerminationCriterion::add_iteration_limit(), MBMesquite::InstructionQueue::add_preconditioner(), MBMesquite::InstructionQueue::add_quality_assessor(), CLArgs::add_required_arg(), args, CLArgs::double_flag(), MBMesquite::QualityAssessor::get_inverted_element_count(), input_file, CLArgs::int_flag(), INVALID_FLAG, mesh, CLArgs::parse_options(), PERCENT_FLAG, CLArgs::print_usage(), process_domain_args(), MBMesquite::MeshImpl::read_vtk(), MBMesquite::IQInterface::run_instructions(), CLArgs::ArgIBase::seen(), MBMesquite::InstructionQueue::set_master_quality_improver(), MBMesquite::QualityImprover::set_outer_termination_criterion(), CLArgs::toggle_flag(), UNOPTIMIZE_FLAG, CLArgs::ArgTemplate< T >::value(), CLArgs::IntRangeArg::value(), CLArgs::DoubleRangeArg::value(), and MBMesquite::MeshImpl::write_vtk().
{ const double default_fraction = 0.05; const double zero = 0.0; int one = 1; CLArgs::ToggleArg allow_invalid( false ); CLArgs::DoubleRangeArg rand_percent( default_fraction, &zero, 0 ); CLArgs::IntRangeArg unoptimize( 0, &one, 0 ); CLArgs args( "vtkrandom", "Randomize mesh vertex locations.", "Read VTK file, randomize locations of containded vertices, and re-write file." ); args.toggle_flag( INVALID_FLAG, "Allow inverted elements in output", &allow_invalid ); args.double_flag( PERCENT_FLAG, "fract", "Randomize fraction", &rand_percent ); args.int_flag( UNOPTIMIZE_FLAG, "N", "Use UnOptimizer with N passes rather than Randomize", &unoptimize ); add_domain_args( args ); args.add_required_arg( "input_file" ); args.add_required_arg( "output_file" ); std::vector< std::string > files; if( !args.parse_options( argc, argv, files, std::cerr ) ) { args.print_usage( std::cerr ); exit( 1 ); } std::string input_file = files[0]; std::string output_file = files[1]; MsqError err; MeshImpl mesh; mesh.read_vtk( input_file.c_str(), err ); if( err ) { std::cerr << "ERROR READING FILE: " << input_file << std::endl << err << std::endl; return 2; } MeshDomain* domain = process_domain_args( &mesh ); TerminationCriterion tc; QualityAssessor qa( false ); InstructionQueue q; Randomize op( rand_percent.value() ); IdealWeightInverseMeanRatio metric; PMeanPTemplate of( 1, &metric ); UnOptimizer op2( &of ); if( unoptimize.seen() ) { tc.add_iteration_limit( unoptimize.value() ); op2.set_outer_termination_criterion( &tc ); q.add_preconditioner( &op, err ); q.set_master_quality_improver( &op2, err ); } else { q.set_master_quality_improver( &op, err ); } q.add_quality_assessor( &qa, err ); MeshDomainAssoc mesh_and_domain = MeshDomainAssoc( &mesh, domain ); q.run_instructions( &mesh_and_domain, err ); if( err ) { std::cerr << err << std::endl; return 3; } int inverted, junk; if( qa.get_inverted_element_count( inverted, junk, err ) && inverted ) { if( allow_invalid.value() ) std::cerr << "Warning: output mesh contains " << inverted << " inverted elements" << std::endl; else { std::cerr << "Error: output mesh contains " << inverted << " inverted elements" << std::endl; return 4; } } mesh.write_vtk( output_file.c_str(), err ); if( err ) { std::cerr << "ERROR WRITING FILE: " << output_file << std::endl << err << std::endl; return 2; } return 0; }
const char INVALID_FLAG = 'i' |
Definition at line 25 of file randomize.cpp.
Referenced by main().
const char PERCENT_FLAG = 'p' |
Definition at line 26 of file randomize.cpp.
const char UNOPTIMIZE_FLAG = 'u' |
Definition at line 27 of file randomize.cpp.
