MOAB: Mesh Oriented datABase
(version 5.2.1)
#include "MeshImpl.hpp"
#include "MsqTimer.hpp"
#include "Mesquite.hpp"
#include "MsqError.hpp"
#include "Vector3D.hpp"
#include "InstructionQueue.hpp"
#include "PatchData.hpp"
#include "TerminationCriterion.hpp"
#include "QualityAssessor.hpp"
#include "TestUtil.hpp"
#include "Randomize.hpp"
#include "ConditionNumberQualityMetric.hpp"
#include "UntangleBetaQualityMetric.hpp"
#include "LPtoPTemplate.hpp"
#include "LInfTemplate.hpp"
#include "SteepestDescent.hpp"
#include "ConjugateGradient.hpp"
#include "PlanarDomain.hpp"
#include <iostream>
#include <cstdlib>
Functions | |
int | main () |
Variables | |
std::string | DEFAULT_MESH = "/2D/vtk/quads/tangled/tangled_quad.vtk" |
const bool | brief_output = true |
const bool | write_output = false |
int main | ( | ) |
Definition at line 80 of file untangle_test.cpp.
References MBMesquite::TerminationCriterion::add_iteration_limit(), MBMesquite::QualityAssessor::add_quality_assessment(), MBMesquite::InstructionQueue::add_quality_assessor(), MBMesquite::TerminationCriterion::add_relative_quality_improvement(), brief_output, DEFAULT_MESH, MBMesquite::QualityAssessor::disable_printing_results(), mesh, MBMesquite::print_timing_diagnostics(), MBMesquite::MeshImpl::read_vtk(), MBMesquite::IQInterface::run_instructions(), MBMesquite::QualityImprover::set_inner_termination_criterion(), MBMesquite::InstructionQueue::set_master_quality_improver(), MBMesquite::QualityImprover::set_outer_termination_criterion(), MBMesquite::PatchSetUser::use_element_on_vertex_patch(), MBMesquite::PatchSetUser::use_global_patch(), write_output, and MBMesquite::MeshImpl::write_vtk().
{ MBMesquite::MeshImpl mesh; MsqPrintError err( cout ); mesh.read_vtk( DEFAULT_MESH.c_str(), err ); if( err ) return 1; // Set Domain Constraint Vector3D pnt( 0, 0, 5 ); Vector3D s_norm( 0, 0, 1 ); PlanarDomain msq_geom( s_norm, pnt ); // creates an intruction queue InstructionQueue queue1; // creates a mean ratio quality metric ... ConditionNumberQualityMetric shape_metric; UntangleBetaQualityMetric untangle( 2 ); Randomize pass0( .05 ); // ... and builds an objective function with it // LInfTemplate* obj_func = new LInfTemplate(shape_metric); LInfTemplate obj_func( &untangle ); LPtoPTemplate obj_func2( &shape_metric, 2, err ); if( err ) return 1; // creates the steepest descent optimization procedures ConjugateGradient pass1( &obj_func, err ); if( err ) return 1; // SteepestDescent* pass2 = new SteepestDescent( obj_func2 ); ConjugateGradient pass2( &obj_func2, err ); if( err ) return 1; pass2.use_element_on_vertex_patch(); if( err ) return 1; pass2.use_global_patch(); if( err ) return 1; QualityAssessor stop_qa = QualityAssessor( &shape_metric ); QualityAssessor stop_qa2 = QualityAssessor( &shape_metric ); if( brief_output ) { stop_qa.disable_printing_results(); stop_qa2.disable_printing_results(); } stop_qa.add_quality_assessment( &untangle ); // **************Set stopping criterion************** // untangle beta should be 0 when untangled TerminationCriterion sc1; sc1.add_relative_quality_improvement( 0.000001 ); TerminationCriterion sc3; sc3.add_iteration_limit( 10 ); TerminationCriterion sc_rand; sc_rand.add_iteration_limit( 1 ); // StoppingCriterion sc1(&stop_qa,-1.0,.0000001); // StoppingCriterion sc3(&stop_qa2,.9,1.00000001); // StoppingCriterion sc2(StoppingCriterion::NUMBER_OF_PASSES,10); // StoppingCriterion sc_rand(StoppingCriterion::NUMBER_OF_PASSES,1); // either until untangled or 10 iterations pass0.set_outer_termination_criterion( &sc_rand ); pass1.set_outer_termination_criterion( &sc1 ); pass2.set_inner_termination_criterion( &sc3 ); // adds 1 pass of pass1 to mesh_set1 queue1.add_quality_assessor( &stop_qa, err ); if( err ) return 1; // queue1.add_preconditioner(pass0,err);MSQ_CHKERR(err); // queue1.add_preconditioner(pass1,err);MSQ_CHKERR(err); // queue1.set_master_quality_improver(pass2, err); MSQ_CHKERR(err); queue1.set_master_quality_improver( &pass1, err ); if( err ) return 1; queue1.add_quality_assessor( &stop_qa2, err ); if( err ) return 1; if( write_output ) mesh.write_vtk( "original_mesh.vtk", err ); if( err ) return 1; // launches optimization on mesh_set1 MeshDomainAssoc mesh_and_domain = MeshDomainAssoc( &mesh, &msq_geom ); queue1.run_instructions( &mesh_and_domain, err ); if( err ) return 1; if( write_output ) mesh.write_vtk( "smoothed_mesh.vtk", err ); if( err ) return 1; if( !brief_output ) print_timing_diagnostics( cout ); return 0; }
const bool brief_output = true |
Definition at line 77 of file untangle_test.cpp.
std::string DEFAULT_MESH = "/2D/vtk/quads/tangled/tangled_quad.vtk" |
Definition at line 75 of file untangle_test.cpp.
Referenced by main().
const bool write_output = false |
Definition at line 78 of file untangle_test.cpp.
