MOAB: Mesh Oriented datABase
(version 5.4.1)
test geometrize method from GeomTopoTool More...
#include "moab/Core.hpp"
#include <iostream>
#include <cassert>
#include <cstring>
#include <cstdio>
#include "TestUtil.hpp"
#include "moab/GeomTopoTool.hpp"
#include "MBTagConventions.hpp"
Functions | |
ErrorCode | geometrize_test (Interface *mb, EntityHandle inputSet) |
ErrorCode | create_shell_test (Interface *mb) |
ErrorCode | duplicate_model_test (Interface *mb) |
ErrorCode | check_model_test (Interface *mb) |
ErrorCode | test_root_sets_resize (Interface *mb) |
ErrorCode | test_delete_obb_tree (Interface *mb) |
ErrorCode | test_restore_obb_trees (Interface *mb, Interface *mb2, Interface *mb3) |
void | handle_error_code (ErrorCode rv, int &number_failed, int &number_successful) |
int | main (int argc, char *argv[]) |
Variables | |
std::string | filename |
std::string | filename2 |
std::string | ofile |
std::string | ofile2 |
std::string | ofile3 |
std::string | ofile4 |
std::string | ofile5 |
const char | OBB_ROOT_TAG_NAME [] = "OBB_ROOT" |
Tag | obbRootTag |
bool | remove_output_file |
This library is free software; you can redistribute it and/or modify it under the terms of the GNU Lesser General Public License as published by the Free Software Foundation; either version 2.1 of the License, or (at your option) any later version.
Definition in file gttool_test.cpp.
ErrorCode check_model_test | ( | Interface * | mb | ) |
Definition at line 424 of file gttool_test.cpp.
References moab::GeomTopoTool::check_model(), moab::Interface::delete_mesh(), ErrorCode, moab::Interface::load_file(), MB_CHK_ERR, MB_CHK_SET_ERR, MB_SUCCESS, ofile3, and remove_output_file.
Referenced by main().
{ ErrorCode rval = mb->delete_mesh();MB_CHK_SET_ERR( rval, "Can't delete existing mesh\n" ); rval = mb->load_file( ofile3.c_str() );MB_CHK_ERR( rval ); // do some tests on geometry // it would be good to have a method on updating the geom topo tool // so we do not have to create another one if( remove_output_file ) { remove( ofile3.c_str() ); } moab::GeomTopoTool gTopoTool( mb, true ); if( !gTopoTool.check_model() ) return MB_FAILURE; return MB_SUCCESS; }
ErrorCode create_shell_test | ( | Interface * | mb | ) |
Definition at line 196 of file gttool_test.cpp.
References moab::Interface::add_entities(), moab::GeomTopoTool::add_geo_set(), moab::Interface::add_parent_child(), moab::Interface::create_element(), moab::Interface::create_meshset(), moab::Interface::create_vertices(), moab::Interface::delete_mesh(), edges, ErrorCode, MBMesquite::faces, moab::GeomTopoTool::find_geomsets(), moab::Interface::load_file(), MB_CHK_ERR, MB_CHK_SET_ERR, MB_SUCCESS, MBEDGE, MBTRI, MESHSET_SET, ofile2, remove_output_file, SENSE_FORWARD, SENSE_REVERSE, moab::GeomTopoTool::set_senses(), size, and moab::Interface::write_mesh().
{ // we should be able to delete mesh and create a model from scratch ErrorCode rval = mb->delete_mesh();MB_CHK_SET_ERR( rval, "Can't delete existing mesh\n" ); // create some vertices double coords[] = { 0, 0, 0, 1, 0, 0.1, 2, 0, 0, 3, 0, -0.1, 0, 1, 0, 1, 1, 0, 2, 1, 0, 3, 1, -0.1, 0, 2, 0, 1, 2, -0.1, 2, 2, -0.1, 3, 2, -0.2, 0, 0, 1, 1, 0, 0.9, 2, 0.1, 0.85, 3, 0.2, 0.8, 0, 0.1, 2, 1, 0.1, 2, 2.1, 0.2, 2.1, 3.1, 0.2, 2.1 }; int nvert = 20; Range verts; rval = mb->create_vertices( coords, nvert, verts );MB_CHK_SET_ERR( rval, "Can't create vertices\n" ); EntityHandle connec[] = { 1, 2, 5, 5, 2, 6, 2, 3, 6, 6, 3, 7, 3, 4, 7, 7, 4, 8, 5, 6, 9, 9, 6, 10, 6, 7, 10, 10, 7, 11, 7, 8, 11, 11, 8, 12, // first face, 1-12 13, 14, 1, 1, 14, 2, 14, 15, 2, 2, 15, 3, 15, 16, 3, 3, 16, 4, 17, 18, 13, 13, 18, 14, 18, 19, 14, 14, 19, 15, 19, 20, 15, 15, 20, 16 // second face, 13-24 }; EntityHandle elem; int nbTri = sizeof( connec ) / 3 / sizeof( EntityHandle ); int i = 0; std::vector< EntityHandle > tris; for( i = 0; i < nbTri; i++ ) { mb->create_element( MBTRI, &connec[3 * i], 3, elem ); tris.push_back( elem ); } // create some edges too EntityHandle edges[] = { 1, 2, 2, 3, 3, 4, // geo edge 1 1:3 4, 8, 8, 12, // geo 2 4:5 12, 11, 11, 10, 10, 9, // geo 3 6:8 9, 5, 5, 1, // geo 4 9:10 1, 13, 13, 17, // geo 5 11:12 17, 18, 18, 19, 19, 20, // geo 6 13:15 20, 16, 16, 4 // geo 7 16:17 }; int nbEdges = sizeof( edges ) / 2 / sizeof( EntityHandle ); std::vector< EntityHandle > edgs; for( i = 0; i < nbEdges; i++ ) { mb->create_element( MBEDGE, &edges[2 * i], 2, elem ); edgs.push_back( elem ); } // create some sets, and create some ordered sets for edges EntityHandle face1, face2; rval = mb->create_meshset( MESHSET_SET, face1 );MB_CHK_ERR( rval ); rval = mb->add_entities( face1, &tris[0], 12 );MB_CHK_ERR( rval ); rval = mb->create_meshset( MESHSET_SET, face2 );MB_CHK_ERR( rval ); // next 12 triangles rval = mb->add_entities( face2, &tris[12], 12 );MB_CHK_ERR( rval ); // the orientation and senses need to be set for face edges moab::GeomTopoTool gTopoTool( mb, false ); rval = gTopoTool.add_geo_set( face1, 2 );MB_CHK_ERR( rval ); rval = gTopoTool.add_geo_set( face2, 2 );MB_CHK_ERR( rval ); // create some edges EntityHandle edge[7]; // edge[0] has EH 1... ; for( i = 0; i < 7; i++ ) { rval = mb->create_meshset( MESHSET_ORDERED, edge[i] );MB_CHK_ERR( rval ); rval = gTopoTool.add_geo_set( edge[i], 1 );MB_CHK_ERR( rval ); } // first 3 mesh edges... rval = mb->add_entities( edge[0], &edgs[0], 3 );MB_CHK_ERR( rval ); rval = mb->add_entities( edge[1], &edgs[3], 2 );MB_CHK_ERR( rval ); rval = mb->add_entities( edge[2], &edgs[5], 3 );MB_CHK_ERR( rval ); rval = mb->add_entities( edge[3], &edgs[8], 2 );MB_CHK_ERR( rval ); rval = mb->add_entities( edge[4], &edgs[10], 2 );MB_CHK_ERR( rval ); rval = mb->add_entities( edge[5], &edgs[12], 3 );MB_CHK_ERR( rval ); rval = mb->add_entities( edge[6], &edgs[15], 2 );MB_CHK_ERR( rval ); // create some sets for vertices; also need to create some for parent/child relationships EntityHandle vertSets[6]; // start from 0 for( i = 0; i < 6; i++ ) { rval = mb->create_meshset( MESHSET_SET, vertSets[i] );MB_CHK_ERR( rval ); rval = gTopoTool.add_geo_set( vertSets[i], 0 );MB_CHK_ERR( rval ); } EntityHandle v( 1 ); // first vertex; rval = mb->add_entities( vertSets[0], &v, 1 );MB_CHK_ERR( rval ); v = EntityHandle( 4 ); rval = mb->add_entities( vertSets[1], &v, 1 );MB_CHK_ERR( rval ); v = EntityHandle( 9 ); rval = mb->add_entities( vertSets[2], &v, 1 );MB_CHK_ERR( rval ); v = EntityHandle( 12 ); rval = mb->add_entities( vertSets[3], &v, 1 );MB_CHK_ERR( rval ); v = EntityHandle( 17 ); rval = mb->add_entities( vertSets[4], &v, 1 );MB_CHK_ERR( rval ); v = EntityHandle( 20 ); rval = mb->add_entities( vertSets[5], &v, 1 );MB_CHK_ERR( rval ); // need to add parent-child relations between sets // edge 1 : 1-2 rval = mb->add_parent_child( edge[0], vertSets[0] );MB_CHK_ERR( rval ); rval = mb->add_parent_child( edge[0], vertSets[1] );MB_CHK_ERR( rval ); // edge 2 : 2-4 rval = mb->add_parent_child( edge[1], vertSets[1] );MB_CHK_ERR( rval ); rval = mb->add_parent_child( edge[1], vertSets[3] );MB_CHK_ERR( rval ); // edge 3 : 4-3 rval = mb->add_parent_child( edge[2], vertSets[3] );MB_CHK_ERR( rval ); rval = mb->add_parent_child( edge[2], vertSets[2] );MB_CHK_ERR( rval ); // edge 4 : 4-1 rval = mb->add_parent_child( edge[3], vertSets[2] );MB_CHK_ERR( rval ); rval = mb->add_parent_child( edge[3], vertSets[0] );MB_CHK_ERR( rval ); // edge 5 : 1-5 rval = mb->add_parent_child( edge[4], vertSets[0] );MB_CHK_ERR( rval ); rval = mb->add_parent_child( edge[4], vertSets[4] );MB_CHK_ERR( rval ); // edge 6 : 5-6 rval = mb->add_parent_child( edge[5], vertSets[4] );MB_CHK_ERR( rval ); rval = mb->add_parent_child( edge[5], vertSets[5] );MB_CHK_ERR( rval ); // edge 7 : 6-2 rval = mb->add_parent_child( edge[6], vertSets[5] );MB_CHK_ERR( rval ); rval = mb->add_parent_child( edge[6], vertSets[1] );MB_CHK_ERR( rval ); // face 1: edges 1, 2, 3, 4 rval = mb->add_parent_child( face1, edge[0] );MB_CHK_ERR( rval ); rval = mb->add_parent_child( face1, edge[1] );MB_CHK_ERR( rval ); rval = mb->add_parent_child( face1, edge[2] );MB_CHK_ERR( rval ); rval = mb->add_parent_child( face1, edge[3] );MB_CHK_ERR( rval ); // face 2: edges 1, 5, 6, 7 rval = mb->add_parent_child( face2, edge[0] );MB_CHK_ERR( rval ); rval = mb->add_parent_child( face2, edge[4] );MB_CHK_ERR( rval ); rval = mb->add_parent_child( face2, edge[5] );MB_CHK_ERR( rval ); rval = mb->add_parent_child( face2, edge[6] );MB_CHK_ERR( rval ); // set senses !! std::vector< EntityHandle > faces; faces.push_back( face1 ); // the face1 has all edges oriented positively std::vector< int > senses; senses.push_back( moab::SENSE_FORWARD ); // // faces.push_back(face1); // faces.push_back(face2); gTopoTool.set_senses( edge[1], faces, senses ); gTopoTool.set_senses( edge[2], faces, senses ); gTopoTool.set_senses( edge[3], faces, senses ); faces[0] = face2; // set senses for edges for face2 gTopoTool.set_senses( edge[4], faces, senses ); gTopoTool.set_senses( edge[5], faces, senses ); gTopoTool.set_senses( edge[6], faces, senses ); // the only complication is edge1 (edge[0]), that has face1 forward and face 2 reverse faces[0] = face1; faces.push_back( face2 ); senses.push_back( moab::SENSE_REVERSE ); // -1 is reverse; face 2 is reverse for edge1 (0) // forward == 0, reverse ==1 gTopoTool.set_senses( edge[0], faces, senses ); rval = mb->write_mesh( ofile2.c_str() );MB_CHK_ERR( rval ); rval = mb->delete_mesh();MB_CHK_ERR( rval ); // now test loading it up rval = mb->load_file( ofile2.c_str() );MB_CHK_ERR( rval ); if( remove_output_file ) { remove( ofile2.c_str() ); } // do some tests on geometry // it would be good to have a method on updating the geom topo tool // so we do not have to create another one moab::GeomTopoTool gTopoTool2( mb, true ); // to find the geomsets Range ranges[5]; rval = gTopoTool2.find_geomsets( ranges ); assert( MB_SUCCESS == rval ); assert( ranges[0].size() == 6 ); assert( ranges[1].size() == 7 ); assert( ranges[2].size() == 2 ); assert( ranges[3].size() == 0 ); assert( ranges[4].size() == 0 ); return MB_SUCCESS; }
ErrorCode duplicate_model_test | ( | Interface * | mb | ) |
Definition at line 393 of file gttool_test.cpp.
References moab::GeomTopoTool::duplicate_model(), ErrorCode, moab::GeomTopoTool::find_geomsets(), moab::GeomTopoTool::get_root_model_set(), MB_CHK_ERR, MB_CHK_SET_ERR, MB_SUCCESS, ofile3, size, and moab::Interface::write_file().
{ moab::GeomTopoTool gTopoTool2( mb, true ); // to find the geomsets GeomTopoTool* newModel = NULL; ErrorCode rval = gTopoTool2.duplicate_model( newModel ); if( NULL == newModel || rval != MB_SUCCESS ) return MB_FAILURE; Range ranges[5]; rval = newModel->find_geomsets( ranges );MB_CHK_ERR( rval ); assert( ranges[0].size() == 6 ); assert( ranges[1].size() == 7 ); assert( ranges[2].size() == 2 ); assert( ranges[3].size() == 0 ); // write the model to a test file EntityHandle rootModelSet = newModel->get_root_model_set(); std::cout << "writing duplicated model file: " << ofile3.c_str() << " "; rval = mb->write_file( ofile3.c_str(), 0, 0, &rootModelSet, 1 );MB_CHK_SET_ERR( rval, "Can't write output files\n" ); delete newModel; // we are done with the new geom topo tool // do not delete yet the output file, delay after the next test /*if (remove_output_file) { remove(ofile3.c_str()); }*/ return MB_SUCCESS; }
ErrorCode geometrize_test | ( | Interface * | mb, |
EntityHandle | inputSet | ||
Definition at line 181 of file gttool_test.cpp.
References ErrorCode, moab::GeomTopoTool::geometrize_surface_set(), MB_CHK_SET_ERR, MB_SUCCESS, ofile, remove_output_file, and moab::Interface::write_file().
{ GeomTopoTool gtt( mb ); EntityHandle outSet; ErrorCode rval = gtt.geometrize_surface_set( inputSet, outSet );MB_CHK_SET_ERR( rval, "Can't geometrize the set\n" ); std::cout << "writing output file: " << ofile.c_str() << " "; rval = mb->write_file( ofile.c_str(), 0, 0, &outSet, 1 );MB_CHK_SET_ERR( rval, "Can't write output file\n" ); if( remove_output_file ) { remove( ofile.c_str() ); } return MB_SUCCESS; }
void handle_error_code | ( | ErrorCode | rv, |
int & | number_failed, | ||
int & | number_successful | ||
Definition at line 53 of file gttool_test.cpp.
References MB_SUCCESS.
{ if( rv == MB_SUCCESS ) { std::cout << "Success"; number_successful++; } else { std::cout << "Failure"; number_failed++; } }
int main | ( | int | argc, |
char * | argv[] | ||
Definition at line 67 of file gttool_test.cpp.
References check_model_test(), create_shell_test(), duplicate_model_test(), ErrorCode, filename, filename2, geometrize_test(), handle_error_code(), moab::Interface::load_file(), mb, MB_SUCCESS, mbcore, number_tests_failed, number_tests_successful, ofile, ofile2, ofile3, ofile4, ofile5, remove_output_file, test_delete_obb_tree(), test_restore_obb_trees(), and test_root_sets_resize().
{ filename = TestDir + "unittest/partBed.smf"; filename2 = TestDir + "unittest/test_geom.h5m"; ofile = "output.h5m"; ofile2 = "shell.h5m"; ofile3 = "shellCopy.h5m"; ofile4 = "geom_w_obbs.h5m"; ofile5 = "geom_missing_obb.h5m"; remove_output_file = true; bool only_check = false; bool only_geometrize = false; if( argc == 1 ) { std::cout << "Using default input file and output files " << filename << " " << ofile << " " << ofile2 << " " << ofile3 << std::endl; } else if( argc == 5 ) { filename = argv[1]; ofile = argv[2]; ofile2 = argv[3]; ofile3 = argv[4]; remove_output_file = false; } else if( argc == 2 ) { ofile3 = argv[1]; // check model only from file only_check = true; remove_output_file = false; // this is input now, do not delete it } else if( argc == 3 ) { filename = argv[1]; ofile = argv[2]; only_geometrize = true; remove_output_file = false; } else { std::cerr << "Usage: " << argv[0] << " [surface_mesh] [mbgeo_file] [shellfile] [copyshellfile] " << std::endl; return 1; } int number_tests_successful = 0; int number_tests_failed = 0; Core mbcore; Interface* mb = &mbcore; // use this as a tool to check a model if( only_check ) { if( MB_SUCCESS == check_model_test( mb ) ) std::cout << ofile3 << " passed gtt check\n"; return 0; } mb->load_file( filename.c_str() ); // FBEngine * pFacet = new FBEngine(mb, NULL, true);// smooth facetting, no OBB tree passed std::cout << "geometrize test: "; ErrorCode rval = geometrize_test( mb, 0 ); // just pass the root set handle_error_code( rval, number_tests_failed, number_tests_successful ); std::cout << "\n"; if( only_geometrize ) { return number_tests_failed; } std::cout << "create shell test: "; rval = create_shell_test( mb ); handle_error_code( rval, number_tests_failed, number_tests_successful ); std::cout << "\n"; std::cout << "duplicate model test: "; rval = duplicate_model_test( mb ); handle_error_code( rval, number_tests_failed, number_tests_successful ); std::cout << "\n"; std::cout << "check_model test: "; rval = check_model_test( mb ); handle_error_code( rval, number_tests_failed, number_tests_successful ); std::cout << "\n"; std::cout << "test_rootsets_resize: "; Interface* mb2 = new Core(); rval = test_root_sets_resize( mb2 ); handle_error_code( rval, number_tests_failed, number_tests_successful ); delete mb2; std::cout << "\n"; std::cout << "test_delete_obb_tree: "; Interface* mb3 = new Core(); rval = test_delete_obb_tree( mb3 ); handle_error_code( rval, number_tests_failed, number_tests_successful ); delete mb3; std::cout << "\n"; std::cout << "test_restore_obb_trees: "; Interface* mb4 = new Core(); Interface* mb5 = new Core(); Interface* mb6 = new Core(); rval = test_restore_obb_trees( mb4, mb5, mb6 ); handle_error_code( rval, number_tests_failed, number_tests_successful ); delete mb4; delete mb5; delete mb6; std::cout << "\n"; return number_tests_failed; }
ErrorCode test_delete_obb_tree | ( | Interface * | mb | ) |
Definition at line 512 of file gttool_test.cpp.
References moab::Range::begin(), moab::GeomTopoTool::construct_obb_tree(), moab::GeomTopoTool::delete_obb_tree(), moab::Range::end(), ErrorCode, filename2, moab::Range::front(), moab::GeomTopoTool::get_gsets_by_dimension(), moab::GeomTopoTool::get_root(), moab::Interface::load_file(), MB_CHK_SET_ERR, MB_CHK_SET_ERR_CONT, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_SPARSE, MB_TYPE_HANDLE, moab::OBB_ROOT_TAG_NAME, obbRootTag, moab::Interface::tag_get_data(), and moab::Interface::tag_get_handle().
{ // Load the test file ErrorCode rval = mb->load_file( filename2.c_str() );MB_CHK_SET_ERR( rval, "Failed to load input file" ); // Create a GTT with all default settings moab::GeomTopoTool* gTopoTool = new GeomTopoTool( mb ); // Get all volumes and surfaces Range vols, surfs; rval = gTopoTool->get_gsets_by_dimension( 3, vols );MB_CHK_SET_ERR( rval, "Failed to get volume gsets" ); rval = gTopoTool->get_gsets_by_dimension( 2, surfs );MB_CHK_SET_ERR( rval, "Failed to get surface gsets" ); // Build obb tree for volume EntityHandle test_vol = vols.front(); rval = gTopoTool->construct_obb_tree( test_vol );MB_CHK_SET_ERR( rval, "Error constructing all trees." ); // Get the obbRootTag for vol rval = mb->tag_get_handle( OBB_ROOT_TAG_NAME, 1, MB_TYPE_HANDLE, obbRootTag, MB_TAG_CREAT | MB_TAG_SPARSE );MB_CHK_SET_ERR_CONT( rval, "Error: Failed to create obb root tag" ); EntityHandle gbroot; rval = mb->tag_get_data( obbRootTag, &test_vol, 1, &gbroot );MB_CHK_SET_ERR( rval, "Failed to get the obb root tag" ); // Test if obb tree in ModelSet EntityHandle test_vol_root; rval = gTopoTool->get_root( test_vol, test_vol_root );MB_CHK_SET_ERR( rval, "Obb root not in ModelSet" ); // CASE 1: Delete vol obb tree including all child surface trees rval = gTopoTool->delete_obb_tree( test_vol, false );MB_CHK_SET_ERR( rval, "Error deleting volume tree." ); // Make sure vol tree is gone EntityHandle newroot; rval = mb->tag_get_data( obbRootTag, &test_vol, 1, &newroot ); if( MB_SUCCESS == rval ) { return MB_FAILURE; } // Make sure its child surf trees also gone Range::iterator surf_it; for( surf_it = surfs.begin(); surf_it != surfs.end(); ++surf_it ) { EntityHandle test_surf_root_gone; rval = mb->tag_get_data( obbRootTag, &( *surf_it ), 1, &test_surf_root_gone ); if( MB_SUCCESS == rval ) { return MB_FAILURE; } } // Rebuild vol tree rval = gTopoTool->construct_obb_tree( test_vol );MB_CHK_SET_ERR( rval, "Error constructing all trees." ); // CASE 2: Delete just vol, not surf trees rval = gTopoTool->delete_obb_tree( test_vol, true );MB_CHK_SET_ERR( rval, "Error deleting volume tree." ); // Make sure vol tree is gone rval = mb->tag_get_data( obbRootTag, &test_vol, 1, &gbroot ); if( MB_SUCCESS == rval ) { return MB_FAILURE; } // Make sure its child surf trees remain for( surf_it = surfs.begin(); surf_it != surfs.end(); ++surf_it ) { EntityHandle test_surf_root; rval = mb->tag_get_data( obbRootTag, &( *surf_it ), 1, &test_surf_root );MB_CHK_SET_ERR( rval, "Problem getting obb root of surface." ); } // CASE 3: Delete surf tree EntityHandle test_surf = surfs.front(); rval = gTopoTool->delete_obb_tree( test_surf, false );MB_CHK_SET_ERR( rval, "Error deleting surface tree." ); // Make sure surf tree is gone rval = mb->tag_get_data( obbRootTag, &test_surf, 1, &gbroot ); if( MB_SUCCESS == rval ) { return MB_FAILURE; } delete gTopoTool; return MB_SUCCESS; }
ErrorCode test_restore_obb_trees | ( | Interface * | mb, |
Interface * | mb2, | ||
Interface * | mb3 | ||
Definition at line 598 of file gttool_test.cpp.
References moab::Range::begin(), CHECK, moab::Range::clear(), moab::GeomTopoTool::construct_obb_trees(), moab::GeomTopoTool::delete_obb_tree(), moab::Range::end(), ErrorCode, filename2, moab::Range::front(), moab::GeomTopoTool::get_gsets_by_dimension(), moab::GeomTopoTool::get_root(), moab::Range::insert_list(), moab::Interface::load_file(), MB_CHK_SET_ERR, MB_CHK_SET_ERR_CONT, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_SPARSE, MB_TYPE_HANDLE, moab::OBB_ROOT_TAG_NAME, obbRootTag, ofile4, ofile5, moab::Interface::tag_get_data(), moab::Interface::tag_get_handle(), and moab::Interface::write_file().
{ // Load the test file ErrorCode rval = mb->load_file( filename2.c_str() );MB_CHK_SET_ERR( rval, "Failed to load input file" ); // Create a GTT with all default settings moab::GeomTopoTool* gTopoTool = new GeomTopoTool( mb ); // Build all obb trees rval = gTopoTool->construct_obb_trees();MB_CHK_SET_ERR( rval, "Error constructing all trees" ); // Write the file with all obbs rval = mb->write_file( ofile4.c_str() );MB_CHK_SET_ERR( rval, "Can't write output file" ); // Delete a vol obb tree Range vols; rval = gTopoTool->get_gsets_by_dimension( 3, vols );MB_CHK_SET_ERR( rval, "Failed to get volume gsets" ); EntityHandle test_vol = vols.front(); rval = gTopoTool->delete_obb_tree( test_vol, false );MB_CHK_SET_ERR( rval, "Error deleting volume tree" ); // Write the file missing an obb rval = mb->write_file( ofile5.c_str() );MB_CHK_SET_ERR( rval, "Can't write output file" ); // Load file containing obbs rval = mb2->load_file( ofile4.c_str() );MB_CHK_SET_ERR( rval, "Failed to load file containing obbs" ); // 1) Check that roots are NOT restored by default GTT settings // GeomTopoTool(Interface *impl, bool find_geoments = false, EntityHandle modelRootSet = 0, // bool p_rootSets_vector = true, bool restore_rootSets = true); moab::GeomTopoTool* gTopoTool2 = new GeomTopoTool( mb2, false, 0, true, true ); vols.clear(); Range surfs; rval = gTopoTool2->get_gsets_by_dimension( 3, vols );MB_CHK_SET_ERR( rval, "Failed to get volume gsets" ); rval = gTopoTool2->get_gsets_by_dimension( 2, surfs );MB_CHK_SET_ERR( rval, "Failed to get volume gsets" ); Range gsets; gsets.insert_list( surfs.begin(), surfs.end() ); gsets.insert_list( vols.begin(), vols.end() ); EntityHandle test_root2; for( Range::iterator rit = gsets.begin(); rit != gsets.end(); ++rit ) { rval = gTopoTool2->get_root( *rit, test_root2 ); if( MB_SUCCESS == rval ) { return MB_FAILURE; } } // 2) Check that roots ARE restored by setting find_geoments and restore_rootSets to true moab::GeomTopoTool* gTopoTool3 = new GeomTopoTool( mb2, true, 0, true, true ); vols.clear(); rval = gTopoTool3->get_gsets_by_dimension( 3, vols );MB_CHK_SET_ERR( rval, "Failed to get volume gsets" ); surfs.clear(); rval = gTopoTool3->get_gsets_by_dimension( 2, surfs );MB_CHK_SET_ERR( rval, "Failed to get volume gsets" ); gsets.clear(); gsets.insert_list( surfs.begin(), surfs.end() ); gsets.insert_list( vols.begin(), vols.end() ); EntityHandle test_root3; for( Range::iterator rit = gsets.begin(); rit != gsets.end(); ++rit ) { rval = gTopoTool3->get_root( *rit, test_root3 );MB_CHK_SET_ERR( rval, "Failed to get obb tree root from GTT" ); CHECK( test_root3 ); } // 3) Check that roots are deleted and then rebuilt if an obb tree is missing // Load file missing obb rval = mb3->load_file( ofile5.c_str() );MB_CHK_SET_ERR( rval, "Failed to load file containing obbs" ); // Create GTT and try to restore OBBs moab::GeomTopoTool* gTopoTool4 = new GeomTopoTool( mb3, true, 0, true, true ); // Check that roots still exist vols.clear(); rval = gTopoTool4->get_gsets_by_dimension( 3, vols );MB_CHK_SET_ERR( rval, "Failed to get volume gsets" ); surfs.clear(); rval = gTopoTool4->get_gsets_by_dimension( 2, surfs );MB_CHK_SET_ERR( rval, "Failed to get volume gsets" ); gsets.clear(); gsets.insert_list( surfs.begin(), surfs.end() ); gsets.insert_list( vols.begin(), vols.end() ); EntityHandle test_root4; for( Range::iterator rit = gsets.begin(); rit != gsets.end(); ++rit ) { rval = gTopoTool4->get_root( *rit, test_root4 );MB_CHK_SET_ERR( rval, "Failed to get obb tree root from GTT" ); CHECK( test_root4 ); } // 4) Check that roots exist but rootSets is NOT repopulated when find_geoments = true and // restore_rootSets = false moab::GeomTopoTool* gTopoTool5 = new GeomTopoTool( mb2, true, 0, true, false ); // Get the obbRootTag for vol rval = mb2->tag_get_handle( OBB_ROOT_TAG_NAME, 1, MB_TYPE_HANDLE, obbRootTag, MB_TAG_CREAT | MB_TAG_SPARSE );MB_CHK_SET_ERR_CONT( rval, "Error: Failed to create obb root tag" ); vols.clear(); rval = gTopoTool5->get_gsets_by_dimension( 3, vols );MB_CHK_SET_ERR( rval, "Failed to get volume gsets" ); surfs.clear(); rval = gTopoTool5->get_gsets_by_dimension( 2, surfs );MB_CHK_SET_ERR( rval, "Failed to get volume gsets" ); gsets.clear(); gsets.insert_list( surfs.begin(), surfs.end() ); gsets.insert_list( vols.begin(), vols.end() ); EntityHandle test_root5, tagged_root; for( Range::iterator rit = gsets.begin(); rit != gsets.end(); ++rit ) { // Check that root still exits, but not in rootSet rval = mb2->tag_get_data( obbRootTag, &( *rit ), 1, &tagged_root );MB_CHK_SET_ERR( rval, "Failed to get root from tag" ); CHECK( tagged_root ); rval = gTopoTool5->get_root( *rit, test_root5 ); if( MB_SUCCESS == rval ) return MB_FAILURE; } delete gTopoTool; delete gTopoTool2; delete gTopoTool3; delete gTopoTool4; delete gTopoTool5; return MB_SUCCESS; }
ErrorCode test_root_sets_resize | ( | Interface * | mb | ) |
Definition at line 444 of file gttool_test.cpp.
References moab::GeomTopoTool::add_geo_set(), moab::Range::begin(), CHECK, moab::GeomTopoTool::construct_obb_tree(), moab::Interface::delete_mesh(), dim, moab::Range::end(), ErrorCode, filename2, GEOM_DIMENSION_TAG_NAME, geomTag, moab::Interface::get_entities_by_type_and_tag(), moab::GeomTopoTool::get_root(), moab::Interface::load_file(), MB_CHK_SET_ERR, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_SPARSE, MB_TYPE_INTEGER, MBENTITYSET, moab::Range::rbegin(), moab::Range::rend(), and moab::Interface::tag_get_handle().
{ // load the test file ErrorCode rval = mb->load_file( filename2.c_str() );MB_CHK_SET_ERR( rval, "Failed to load input file" ); // create a GTT with all default settings moab::GeomTopoTool* gTopoTool = new GeomTopoTool( mb ); Tag geomTag; rval = mb->tag_get_handle( GEOM_DIMENSION_TAG_NAME, 1, MB_TYPE_INTEGER, geomTag, MB_TAG_CREAT | MB_TAG_SPARSE );MB_CHK_SET_ERR( rval, "Error: Failed to create geometry dimension tag" ); Range surfs; const int dim = 2; const void* const dim_val[] = { &dim }; rval = mb->get_entities_by_type_and_tag( 0, MBENTITYSET, &geomTag, dim_val, 1, surfs );MB_CHK_SET_ERR( rval, "Failed to get entity sets by type and tag" ); // in reverse order, add surfaces and construct their trees for( Range::reverse_iterator rit = surfs.rbegin(); rit != surfs.rend(); rit++ ) { rval = gTopoTool->add_geo_set( *rit, 2 );MB_CHK_SET_ERR( rval, "Failed to add geometry set to GTT" ); rval = gTopoTool->construct_obb_tree( *rit );MB_CHK_SET_ERR( rval, "Failed to construct obb tree for surf " << *rit ); } for( Range::iterator it = surfs.begin(); it != surfs.end(); it++ ) { EntityHandle obb_root_set; rval = gTopoTool->get_root( *it, obb_root_set );MB_CHK_SET_ERR( rval, "Failed to get obb tree root from GTT" ); // make sure the returned root is valid CHECK( obb_root_set ); } // clean up GTT delete gTopoTool; // create a GTT with all default settings gTopoTool = new moab::GeomTopoTool( mb, false, 0, false ); // in reverse order, add surfaces and construct their trees for( Range::reverse_iterator rit = surfs.rbegin(); rit != surfs.rend(); rit++ ) { rval = gTopoTool->add_geo_set( *rit, 2 );MB_CHK_SET_ERR( rval, "Failed to add geometry set to GTT" ); rval = gTopoTool->construct_obb_tree( *rit );MB_CHK_SET_ERR( rval, "Failed to construct obb tree for surf " << *rit ); } for( Range::iterator it = surfs.begin(); it != surfs.end(); it++ ) { EntityHandle obb_root_set; rval = gTopoTool->get_root( *it, obb_root_set );MB_CHK_SET_ERR( rval, "Failed to get obb tree root from GTT" ); // make sure the returned root is valid CHECK( obb_root_set ); } delete gTopoTool; rval = mb->delete_mesh();MB_CHK_SET_ERR( rval, "Failed to delete mesh in MOAB instance." ); return MB_SUCCESS; }
std::string filename |
Definition at line 27 of file gttool_test.cpp.
std::string filename2 |
Definition at line 28 of file gttool_test.cpp.
Referenced by main(), test_delete_obb_tree(), test_restore_obb_trees(), test_root_sets_resize(), and test_set_flags().
const char OBB_ROOT_TAG_NAME[] = "OBB_ROOT" |
Definition at line 35 of file gttool_test.cpp.
Definition at line 36 of file gttool_test.cpp.
Referenced by test_delete_obb_tree(), and test_restore_obb_trees().
std::string ofile |
Definition at line 29 of file gttool_test.cpp.
Referenced by geometrize_test(), moab::WriteGMV::local_write_mesh(), and main().
std::string ofile2 |
Definition at line 30 of file gttool_test.cpp.
Referenced by create_shell_test(), and main().
std::string ofile3 |
Definition at line 31 of file gttool_test.cpp.
Referenced by check_model_test(), duplicate_model_test(), and main().
std::string ofile4 |
Definition at line 32 of file gttool_test.cpp.
Referenced by main(), and test_restore_obb_trees().
std::string ofile5 |
Definition at line 33 of file gttool_test.cpp.
bool remove_output_file |
Definition at line 38 of file gttool_test.cpp.
Referenced by check_model_test(), create_shell_test(), geometrize_test(), and main().
