cgma
CGMApp.cpp
00001 //-------------------------------------------------------------------------
00002 // Filename      : CGMApp.cpp
00003 //
00004 // Purpose       : Init and cleanup for CGM
00005 //
00006 // Special Notes :
00007 //
00008 // Creator       : Byron Hanks
00009 //
00010 // Date          : 01/09/2002
00011 //
00012 // Owner         :
00013 //-------------------------------------------------------------------------
00014
00015 #include "CGMApp.hpp"
00016 #include "AppUtil.hpp"
00017
00018 #include "GeometryQueryTool.hpp"
00019 #include "GeometryModifyTool.hpp"
00020 #include "GeometryFeatureTool.hpp"
00021 #include "GeometryHealerTool.hpp"
00022 #include "BoundingBoxTool.hpp"
00023 #include "RefEntityName.hpp"
00024 #include "SurfaceOverlapTool.hpp"
00025 #include "CubitSimpleAttrib.hpp"
00026 #include "TDUniqueId.hpp"
00027 #include "MergeTool.hpp"
00028 #include "OldUnmergeCode.hpp"
00029 #include "ModelQueryEngine.hpp"
00030
00031 // TODO - I'm not sure this is the place to include all the attributes
00032 #include "CADefines.hpp"
00033 #include "CAMergePartner.hpp"
00034 #include "CAEntityName.hpp"
00035 #include "CAGroup.hpp"
00036 #include "CAEntityId.hpp"
00037 #include "CAUniqueId.hpp"
00038 #include "CADeferredAttrib.hpp"
00039 #include "CAEntityColor.hpp"
00040 #include "CAEntityTol.hpp"
00041 #include "CAMergeStatus.hpp"
00042 #include "CASourceFeature.hpp"
00043 #include "CAEntitySense.hpp"
00044 #ifdef CAT
00045 #include "CAProWeld.hpp"
00046 #endif
00047
00048 CGMApp* CGMApp::instance_ = NULL;
00049
00050 // Returns the singleton instance of the app object.
00051 CGMApp* CGMApp::instance()
00052 {
00053    if (instance_ == NULL)
00054    {
00055       instance_ = new CGMApp();
00056       if (!instance_ )
00057       {
00058          PRINT_ERROR(" *** Unable to initialize application ***\n");
00059          exit(1);
00060       }
00061    }
00062    return instance_;
00063 }
00064
00065 CGMApp::CGMApp()
00066 {
00067     mAppStarted = CUBIT_FALSE;
00068
00069       // CGMApp depends on there being an AppUtil
00070     AppUtil::instance();
00071
00072       // initialize my settings
00073     initialize_settings();
00074
00075     caUpdateFlgs = NULL;
00076     caActuateFlgs = NULL;
00077     caWriteFlgs = NULL;
00078     caReadFlgs = NULL;
00079 }
00080
00081 CGMApp::~CGMApp()
00082 {
00083     instance_ = NULL;
00084 }
00085
00086 void CGMApp::startup(const std::vector<CubitString> &args)
00087 {
00088    if (mAppStarted)
00089        return;
00090
00091     // make sure apputil has started
00092   AppUtil::instance()->startup();
00093
00094      // register attributes
00095    register_attributes();
00096
00097    mAppStarted = CUBIT_TRUE;
00098 }
00099
00100 void CGMApp::shutdown()
00101 {
00102    GeometryHealerTool::delete_instance();
00103    GeometryModifyTool::delete_instance();
00104    GeometryQueryTool::delete_instance();
00105    GeometryFeatureTool::delete_instance();
00106    AnalyticGeometryTool::delete_instance();
00107    RefEntityName::delete_instance();
00108    MergeTool::delete_instance();
00109    ModelQueryEngine::delete_instance();
00110
00111    DAG::delete_instance();
00112    mAppStarted = CUBIT_FALSE;
00113 }
00114
00115 void CGMApp::initialize_settings()
00116 {
00117   GeometryQueryTool::instance()->initialize_settings();
00118   GeometryModifyTool::instance()->initialize_settings();
00119   BoundingBoxTool::initialize_settings();
00120   CubitSimpleAttrib::initialize_settings();
00121   RefEntityName::initialize_settings();
00122   SurfaceOverlapTool::initialize_settings();
00123   MergeTool::initialize_settings();
00124   OldUnmergeCode::initialize_settings();
00125
00126 }
00127
00128 void CGMApp::register_attributes()
00129 {
00130   CubitStatus result;
00131   result = mAttribManager.register_attrib_type(CA_MERGE_PARTNER, "merge", "MERGE_PARTNER",
00132                                                CAMergePartner_creator, CUBIT_FALSE,
00133                                                CUBIT_FALSE, CUBIT_TRUE, CUBIT_TRUE,
00134                                                CUBIT_FALSE, CUBIT_FALSE);
00135   if (CUBIT_SUCCESS != result) {
00136     PRINT_ERROR("Failed to register attribute type merge.\n");
00137     return;
00138   }
00139
00140   result = mAttribManager.register_attrib_type(CA_ENTITY_NAME, "name", "ENTITY_NAME",
00141                                                CAEntityName_creator, CUBIT_TRUE,
00142                                                CUBIT_TRUE, CUBIT_TRUE, CUBIT_TRUE,
00143                                                CUBIT_TRUE, CUBIT_FALSE);
00144   if (CUBIT_SUCCESS != result) {
00145     PRINT_ERROR("Failed to register attribute type name.\n");
00146     return;
00147   }
00148
00149   result = mAttribManager.register_attrib_type(CA_GROUP, "group", "GROUP",
00150                                                CAGroup_creator, CUBIT_FALSE,
00151                                                CUBIT_FALSE, CUBIT_TRUE, CUBIT_TRUE,
00152                                                CUBIT_FALSE, CUBIT_FALSE);
00153   if (CUBIT_SUCCESS != result) {
00154     PRINT_ERROR("Failed to register attribute type group.\n");
00155     return;
00156   }
00157
00158   result = mAttribManager.register_attrib_type(CA_ENTITY_ID, "id", "ENTITY_ID",
00159                                                CAEntityId_creator, CUBIT_FALSE,
00160                                                CUBIT_FALSE, CUBIT_TRUE, CUBIT_TRUE,
00161                                                CUBIT_TRUE, CUBIT_FALSE);
00162   if (CUBIT_SUCCESS != result) {
00163     PRINT_ERROR("Failed to register attribute type id.\n");
00164     return;
00165   }
00166
00167   result = mAttribManager.register_attrib_type(CA_ENTITY_TOL, "tolerance", "ENTITY_TOL",
00168                                                CAEntityTol_creator, CUBIT_FALSE,
00169                                                CUBIT_FALSE, CUBIT_TRUE, CUBIT_TRUE,
00170                                                CUBIT_FALSE, CUBIT_TRUE);
00171   if (CUBIT_SUCCESS != result) {
00172     PRINT_ERROR("Failed to register attribute type tolerance.\n");
00173     return;
00174   }
00175
00176   result = mAttribManager.register_attrib_type(CA_UNIQUE_ID, "unique id", "UNIQUE_ID",
00177                                                CAUniqueId_creator, CUBIT_FALSE,
00178                                                CUBIT_FALSE, CUBIT_TRUE, CUBIT_TRUE,
00179                                                CUBIT_TRUE, CUBIT_FALSE);
00180   if (CUBIT_SUCCESS != result) {
00181     PRINT_ERROR("Failed to register attribute type unique id.\n");
00182     return;
00183   }
00184
00185   result = mAttribManager.register_attrib_type(CA_DEFERRED_ATTRIB, "deferred attrib", "DEFERRED_ATTRIB",
00186                                                CADeferredAttrib_creator, CUBIT_FALSE,
00187                                                CUBIT_FALSE, CUBIT_TRUE, CUBIT_TRUE,
00188                                                CUBIT_FALSE, CUBIT_FALSE);
00189   if (CUBIT_SUCCESS != result) {
00190     PRINT_ERROR("Failed to register attribute type deferred attrib.\n");
00191     return;
00192   }
00193
00194   result = mAttribManager.register_attrib_type(CA_ENTITY_COLOR, "color", "ENTITY_COLOR",
00195                                                CAEntityColor_creator, CUBIT_FALSE,
00196                                                CUBIT_FALSE, CUBIT_TRUE, CUBIT_TRUE,
00197                                                CUBIT_FALSE, CUBIT_TRUE);
00198   if (CUBIT_SUCCESS != result) {
00199     PRINT_ERROR("Failed to register attribute type color.\n");
00200     return;
00201   }
00202
00203   result = mAttribManager.register_attrib_type(CA_MERGE_STATUS, "merge status", "MERGE_STATUS",
00204                                                CAMergeStatus_creator, CUBIT_FALSE,
00205                                                CUBIT_FALSE, CUBIT_TRUE, CUBIT_TRUE,
00206                                                CUBIT_FALSE, CUBIT_FALSE);
00207   if (CUBIT_SUCCESS != result) {
00208     PRINT_ERROR("Failed to register attribute type merge status.\n");
00209     return;
00210   }
00211
00212   result = mAttribManager.register_attrib_type(CA_SOURCE_FEATURE, "source feature", "SOURCE_FEATURE",
00213                                                CASourceFeature_creator, CUBIT_TRUE,
00214                                                CUBIT_TRUE, CUBIT_TRUE, CUBIT_TRUE,
00215                                                CUBIT_TRUE, CUBIT_FALSE);
00216   if (CUBIT_SUCCESS != result) {
00217     PRINT_ERROR("Failed to register attribute type source feature.\n");
00218     return;
00219   }
00220
00221   result = mAttribManager.register_attrib_type(CA_ENTITY_SENSE, "entity sense", "ENTITY_SENSE",
00222                                                CAEntitySense_creator, CUBIT_TRUE,
00223                                                CUBIT_TRUE, CUBIT_TRUE, CUBIT_TRUE,
00224                                                CUBIT_FALSE, CUBIT_FALSE);
00225   if (CUBIT_SUCCESS != result) {
00226     PRINT_ERROR("Failed to register attribute type entity sense.\n");
00227     return;
00228   }
00229
00230 #ifdef CAT
00231   result = mAttribManager.register_attrib_type(CA_PRO_WELD, "pro weld", "PRO_WELD",
00232                                                CAProWeld_creator, CUBIT_TRUE,
00233                                                CUBIT_TRUE, CUBIT_TRUE, CUBIT_TRUE,
00234                                                CUBIT_TRUE, CUBIT_FALSE);
00235   if (CUBIT_SUCCESS != result) {
00236     PRINT_ERROR("Failed to register attribute type pro weld.\n");
00237   }
00238 #endif
00239 }
00240
00241 CubitAttribManager* CGMApp::attrib_manager()
00242 {
00243   return &mAttribManager;
00244 }
00245
00246
00247 void CGMApp::save_current_attribute_states()
00248 {
00249   //all pointers must be NULL
00250   if( !!caUpdateFlgs && !!caActuateFlgs &&
00251       !!caWriteFlgs && !!caReadFlgs )
00252   {
00253     PRINT_ERROR("Problem setting attribute flags\n");
00254     return;
00255   }
00256
00257   DLIList<int> attrib_types;
00258   mAttribManager.get_registered_types(attrib_types);
00259
00260   caUpdateFlgs = new CubitBoolean[attrib_types.size()];
00261   caActuateFlgs = new CubitBoolean[attrib_types.size()];
00262   caWriteFlgs = new CubitBoolean[attrib_types.size()];
00263   caReadFlgs = new CubitBoolean[attrib_types.size()];
00264
00265   int num_att = attrib_types.size();
00266   attrib_types.reset();
00267   int i;
00268   for( i=0; i<num_att; i++ )
00269   {
00270     int att_type = attrib_types.get();
00271     caUpdateFlgs[i] = mAttribManager.auto_update_flag( att_type );
00272     caActuateFlgs[i] = mAttribManager.auto_actuate_flag( att_type );
00273     caWriteFlgs[i] = mAttribManager.auto_write_flag( att_type );
00274     caReadFlgs[i] = mAttribManager.auto_read_flag( att_type );
00275     attrib_types.step();
00276   }
00277 }
00278
00279 void CGMApp::restore_previous_attribute_states()
00280 {
00281   DLIList<int> attrib_types;
00282   mAttribManager.get_registered_types(attrib_types);
00283
00284   int num_att = attrib_types.size();
00285   attrib_types.reset();
00286   int i;
00287   for( i=0; i<num_att; i++ )
00288   {
00289     int att_type = attrib_types.get();
00290     mAttribManager.set_auto_update_flag( att_type, caUpdateFlgs[i] );
00291     mAttribManager.set_auto_actuate_flag( att_type, caActuateFlgs[i] );
00292     mAttribManager.set_auto_write_flag( att_type, caWriteFlgs[i] );
00293     mAttribManager.set_auto_read_flag( att_type, caReadFlgs[i] );
00294     attrib_types.step();
00295   }
00296
00297   delete [] caUpdateFlgs;
00298   delete [] caActuateFlgs;
00299   delete [] caWriteFlgs;
00300   delete [] caReadFlgs;
00301
00302   caUpdateFlgs = NULL;
00303   caActuateFlgs = NULL;
00304   caWriteFlgs = NULL;
00305   caReadFlgs = NULL;
00306 }
00307
