cgma
00001 /* 00002 * 00003 * 00004 * Copyright (C) 2004 Sandia Corporation. Under the terms of Contract DE-AC04-94AL85000 00005 * with Sandia Corporation, the U.S. Government retains certain rights in this software. 00006 * 00007 * This file is part of facetbool--contact via cubit@sandia.gov 00008 * 00009 * This library is free software; you can redistribute it and/or 00010 * modify it under the terms of the GNU Lesser General Public 00011 * License as published by the Free Software Foundation; either 00012 * version 2.1 of the License, or (at your option) any later version. 00013 * 00014 * This library is distributed in the hope that it will be useful, 00015 * but WITHOUT ANY WARRANTY; without even the implied warranty of 00016 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00017 * Lesser General Public License for more details. 00018 * 00019 * You should have received a copy of the GNU Lesser General Public 00020 * License along with this library; if not, write to the Free Software 00021 * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA 00022 * 00023 * 00024 * 00025 */ 00026 00027 #ifndef _FBSTRUCTS 00028 #define _FBSTRUCTS 00029 #include <vector> 00030 #include <list> 00031 #include "CubitDefines.h" 00032 #include "FBDefines.hpp" 00033 00034 class FSBoundingBox { 00035 public: 00036 FSBoundingBox() { } 00037 FSBoundingBox(float xmi, float ymi, float zmi, float xma, float yma, float zma) 00038 { 00039 xmin = xmi; xmax = xma; ymin = ymi; ymax = yma; zmin = zmi; zmax = zma; 00040 } 00041 ~FSBoundingBox() { } 00042 float xmin, xmax, ymin, ymax, zmin, zmax; 00043 }; 00044 00045 typedef std::vector<FSBoundingBox* > FSBOXVECTOR; 00046 00047 class FB_Coord { 00048 00049 public: 00050 FB_Coord(double x, double y, double z) { 00051 coord[0] = x; coord[1] = y; coord[2] = z; 00052 is_on_boundary = false; 00053 } 00054 ~FB_Coord() { } 00055 double coord[3]; 00056 bool is_on_boundary; 00057 00058 private: 00059 00060 }; 00061 00062 class FB_Edge { 00063 00064 public: 00065 FB_Edge(int vert0, int vert1, int vert0_type, int vert1_type, bool is_intersection) { 00066 v0 = vert0; v1 = vert1; 00067 v0_type = vert0_type; v1_type = vert1_type; 00068 mark = false; 00069 num_times = 0; 00070 slope = 0.0; 00071 quadrant = 0; 00072 if ( is_intersection == true ) 00073 edge_type = INTERSECTION_EDGE; 00074 else 00075 edge_type = UNKNOWN; 00076 is_intersection_edge = is_intersection; 00077 cubitedgeindex = 0; 00078 } 00079 FB_Edge(); 00080 ~FB_Edge() { } 00081 int v0, v1; 00082 int v0_type, v1_type; 00083 int edge_type; 00084 bool mark; 00085 bool is_intersection_edge; 00086 int num_times; 00087 double slope; 00088 unsigned int quadrant; 00089 int cubitedgeindex; 00090 00091 00092 00093 00094 00095 }; 00096 00097 class FB_Triangle { 00098 00099 public: 00100 FB_Triangle(int vert0, int vert1, int vert2, int myparent, int csvalue, 00101 int c0value, int c1value, int c2value) { 00102 v0 = vert0; v1 = vert1; v2 = vert2; 00103 dudded = false; 00104 parent = myparent; 00105 cubitsurfaceindex = csvalue; 00106 cubitedge0index = c0value; 00107 cubitedge1index = c1value; 00108 cubitedge2index = c2value; 00109 } 00110 FB_Triangle(); 00111 ~FB_Triangle() { 00112 for(size_t i = 0; i < edge_list.size(); i++) 00113 { 00114 delete edge_list[i]; 00115 } 00116 00117 } 00119 bool are_fb_coords_in_fb_triangle(int fb_vert_index_1, 00120 int fb_vert_index_2) 00121 { 00122 if((fb_vert_index_1 == v0 || fb_vert_index_1 == v1 || 00123 fb_vert_index_1 == v2) && (fb_vert_index_2== v0 || 00124 fb_vert_index_2 == v1 || fb_vert_index_2 == v2)){ 00125 return true; 00126 } 00127 return false; 00128 } 00129 00130 int v0, v1, v2; 00131 FSBoundingBox boundingbox; 00132 double a, b, c, d; // plane coefficients 00133 bool dudded; 00134 std::vector<FB_Edge*> edge_list; 00135 int parent; 00136 int cubitsurfaceindex; 00137 int cubitedge0index, cubitedge1index, cubitedge2index; 00138 }; 00139 00140 class VertexStuff { 00141 00142 public: 00143 VertexStuff(int vert, int vert_type, double p_coord, double s_coord) 00144 { v0 = vert; 00145 v0type = vert_type; 00146 p_dir_coord = p_coord; 00147 s_dir_coord = s_coord; 00148 } 00149 00150 ~VertexStuff() { 00151 edge_list.clear(); 00152 } 00153 00154 int v0; 00155 int v0type; 00156 double p_dir_coord, s_dir_coord; 00157 00158 std::vector<FB_Edge*> edge_list; 00159 }; 00160 00161 class vertstuffcompfn_less { 00162 00163 public: 00164 bool operator()(const VertexStuff* vfirst, const VertexStuff* vsecond) const 00165 { 00166 if ( vfirst->p_dir_coord < vsecond->p_dir_coord ) return true; 00167 else if ( vfirst->p_dir_coord > vsecond->p_dir_coord ) return false; 00168 else { 00169 if ( vfirst->s_dir_coord < vsecond->s_dir_coord ) return true; 00170 else return false; 00171 } 00172 } 00173 }; 00174 00175 class edgecompfn_less { 00176 00177 public: 00178 bool operator()(const FB_Edge* efirst, const FB_Edge* esecond) const 00179 { 00180 if ( efirst->quadrant < esecond->quadrant ) return true; 00181 if ( efirst->quadrant > esecond->quadrant ) return false; 00182 00183 if ( efirst->slope < esecond->slope ) return true; 00184 else return false; 00185 00186 } 00187 }; 00188 00189 class edgecompfn_more { 00190 00191 public: 00192 bool operator()(const FB_Edge* efirst, const FB_Edge* esecond) const 00193 { 00194 if ( efirst->quadrant > esecond->quadrant ) return true; 00195 if ( efirst->quadrant < esecond->quadrant ) return false; 00196 // if ( efirst->quadrant > esecond->quadrant ) return true; 00197 00198 if ( efirst->slope < esecond->slope ) return false; 00199 else return true; 00200 00201 } 00202 }; 00203 00204 #endif
