cgma
FaceterFacetData.hpp
00001 #ifndef FACETERFACETDATA_HPP
00002 #define FACETERFACETDATA_HPP
00003
00004 // Include for CubitBoolean
00005 #include "CubitDefines.h"
00006 #include "MemoryManager.hpp"
00007 #include "CubitPoint.hpp"
00008 #include "DLIList.hpp"
00009 #include "CubitBox.hpp"
00010 #include "CubitFacet.hpp"
00011 class CubitVector;
00012 class CubitBox;
00013 class CubitPlane;
00014 class CubitFacetEdge;
00015 class RefEntity;
00016
00017 class FaceterFacetData : public CubitFacet
00018 {
00019 private:
00020   CubitPoint *pointArray[3];
00021   CubitFacetEdge *edgeArray[3];
00022   int edgeUse[3];
00023   static MemoryManager memoryManager;
00024     //- memory management object
00025   int entityId;
00026   RefEntity *myOwner;
00027
00028     //- for debug tracking...
00029
00030 public:
00031   FaceterFacetData(CubitPoint *p1, CubitPoint *p2, CubitPoint *p3);
00032   ~FaceterFacetData();
00033   virtual int id(){return entityId;}
00034   virtual void set_id(int ii){entityId = ii;}
00035
00036   void owner(RefEntity *owner)
00037     {myOwner = owner;}
00038   RefEntity* owner()
00039     {return myOwner;}
00040   SetDynamicMemoryAllocation(memoryManager)
00041     //- class specific new and delete operators
00042   CubitStatus closest_point( const CubitVector &point,
00043                                      CubitVector &closest_point);
00044     //- Sets the closest point on the plane defined by
00045     //- this facet to the point in space.
00046     //- If the normal length to the facet is 0, it will return CUBIT_FAILURE.
00047
00048   CubitPoint* point( int index );
00049     //Get the point at the specified index.
00050     //asserts that the index is in range, for a
00051     //triangle, 0 <= index <= 2.
00052
00053
00054   void set_point( CubitPoint *the_point, int index ) { pointArray[index] = the_point; }
00055     //- sets the point into the facet.
00056
00057   CubitFacetEdge *edge( int index );
00058   void edge( CubitFacetEdge *the_edge, int index )
00059     { edgeArray[index] = the_edge; };
00060     //- get and set edge pointers
00061
00062   void edge_use( int direction, int index ) { edgeUse[index] = direction; };
00063   int edge_use( int index );
00064     //- get and set the edge uses
00065
00066   CubitPoint* split_edge( CubitPoint* edge_pt1,
00067                           CubitPoint* edge_pt2,
00068                           const CubitVector& position );
00069     //R CubitPoint
00070     //R- The new CubitPoint created.
00071     //I edge_pt1, edge_pt2
00072     //I- The end points of an edge of this triangle.
00073     //I position
00074     //I- The position at which to split the edge.
00075     //O new_facet1
00076     //O- The new facet resulting from splitting the edge on
00077     //O- this triangle.
00078     //O new_facet2
00079     //O- The new facet resulting from splitting the same edge
00080     //O- on the ajacent triangle.  If there is no other
00081     //O- triangle sharing the edge, NULL will be passed back.
00082     //- Split an edge on this triangle and the other triangle
00083     //- sharing the edge, if it exists.
00084     //-
00085     //- Note:  No check is done on the location of the split
00086     //-        position.
00087
00088   CubitPoint* insert_point( const CubitVector& position,
00089                             CubitFacet*& new_tri1,
00090                             CubitFacet*& new_tri2 );
00091     //R CubitPoint
00092     //R- The new CubitPoint created.
00093     //I position
00094     //I- The position at which to insert a point in the triangle.
00095     //O new_facet1, new_facet2
00096     //O- The two new facets created.
00097     //- Insert a point in the interior of this triangle.
00098     //-
00099     //- Note:  No check is done on the location of the split
00100     //-        position.
00101
00102   void flip();
00103     //- reorient the facet
00104 };
00105
00106 inline CubitPoint* FaceterFacetData::point( int index )
00107 {
00108   assert( (index >= 0) && (index < 3) );
00109   if (!is_backwards())
00110     return pointArray[index];
00111   else
00112   {
00113     switch(index)
00114     {
00115     case 0: return pointArray[0];
00116     case 1: return pointArray[2];
00117     case 2: return pointArray[1];
00118     }
00119   }
00120   return NULL;
00121 }
00122
00123 inline CubitFacetEdge* FaceterFacetData::edge( int index )
00124 {
00125   assert( (index >= 0) && (index < 3) );
00126   if (!is_backwards())
00127     return edgeArray[index];
00128   else
00129   {
00130     switch(index)
00131     {
00132     case 0: return edgeArray[0];
00133     case 1: return edgeArray[2];
00134     case 2: return edgeArray[1];
00135     }
00136   }
00137   return NULL;
00138 }
00139
00140 inline int FaceterFacetData::edge_use( int index )
00141 {
00142   assert( (index >= 0) && (index < 3) );
00143   if (!is_backwards())
00144     return edgeUse[index];
00145   else
00146   {
00147     switch(index)
00148     {
00149     case 0: return -edgeUse[0];
00150     case 1: return -edgeUse[2];
00151     case 2: return -edgeUse[1];
00152     }
00153   }
00154   return 0;
00155 }
00156
00157
00158 #endif
