cgma
OctTreeCell.hpp
00001 //-------------------------------------------------------------------------
00002 // Filename      : OctTreeCell.hpp
00003 //
00004 // Purpose       : Oct-tree node used by OctTree
00005 //
00006 // Special Notes : OctTree handles all memory allocation for this
00007 //                 class.
00008 //
00009 // Creator       : Jason Kraftcheck
00010 //
00011 // Creation Date : 01/30/02
00012 //-------------------------------------------------------------------------
00013
00014 #ifndef OCT_TREE_CELL_HPP
00015 #define OCT_TREE_CELL_HPP
00016
00017 template <class X, class E> class OctTreeCell;
00018 class CubitVector;
00019 template <class X> class DLIList;
00020
00021 // Linked-list node used to hold CubitNodes in each box.
00022 template <class X, class E> struct OctTreeEntry
00023 {
00024   X* node;
00025   OctTreeEntry<X,E>* next;
00026 };
00027
00028 // A node in the oct-tree.
00029 template <class X, class E> class OctTreeCell
00030 {
00031   private:
00032
00033     union {
00034       OctTreeEntry<X,E>* head_;     // head of linked-list of CubitNodes
00035       OctTreeCell<X,E>* children_; // array of 8 child boxes
00036     };
00037       // union of both the head pointer for the linked-list
00038       // of CubitNodes in a leaf node and a pointer to the
00039       // array of child boxes.
00040       //
00041       // This node is a leaf node iff node_count_ is non-zero
00042       // or both values in the data union are null.
00043
00044     int node_count_;
00045       // Number of nodes contained in a leaf node.  If zero,
00046       // need to check if data.children is null to determine
00047       // if this is a leaf node.
00048
00049     void add_nodes( OctTreeEntry<X,E>* node );
00050       // Join the passed linked-list to the data list.
00051       // asserts if not a leaf node.
00052
00053   public:
00054
00055     OctTreeCell( OctTreeEntry<X,E> array[], int size );
00056       // create a root node
00057       // calling code provides storage for linked-list
00058       // nodes by providing 'array'.  Do not delete
00059       // 'array' until this OctTreeCell and all its
00060       // children are destroyed.
00061
00062     inline OctTreeCell( ) : children_(0), node_count_(0) {}
00063       // Construct unused child node.  This is provieded
00064       // for the cexternal memory allocator.
00065
00066     bool leaf() const { return node_count_ || !children_; }
00067       // Is this box a leaf in the tree?
00068
00069     bool split( const CubitVector& my_center, OctTreeCell<X,E>* memory );
00070       // Change from leaf box to non-leaf.  Splits nodes amongst 8 new
00071       // child boxes using the value of 'my_center'.  May fail (return
00072       // false) if two few nodes are contained for a split to be sensible.
00073       //
00074       // Calling application provides memory for use in holding child
00075       // nodes.  memory must be freed by the caller AFTER the destruction
00076       // of this object.
00077
00078     void append_nodes( DLIList<X*>& list );
00079       // If this node is a leaf node, append all contained CubitNodes
00080
00081     void append_all_nodes( DLIList<X*>& list );
00082       // If this node is a leaf node, append all contained CubitNodes.
00083       // Otherwise descend oct-tree getting CubitNodes contained in
00084       // all child leaf nodes.
00085
00086     enum {
00087       X_MIN = 0,
00088       Y_MIN = 0,
00089       Z_MIN = 0,
00090       X_MAX = 1,
00091       Y_MAX = 2,
00092       Z_MAX = 4
00093     };
00094       // Constants for selecting one of 8 child boxes.
00095       // Can be either bitwise-or'ed (|) or added (+).
00096       // MAX values take precedence over MIN values
00097       // if both are specified.  (MIN is just the
00098       // absense of MAX).
00099
00100     OctTreeCell<X,E>* child( int quadrant );
00101       // quadrant should be a bitwise OR (or sum) of
00102       // the constants above.  If both a MIN and MAX
00103       // value is specified for a given principal
00104       // direction, the M  : children_(0),
00105
00106     void node_locations( CubitVector& box_min,
00107                          CubitVector& box_max,
00108                          CubitVector& average,
00109                          CubitVector* std_dev = 0 );
00110       // Get information about CubitNodes contained in
00111       // this box.  Method does nothing when called on
00112       // non-leaf boxes.
00113
00114     int node_count() { return node_count_; }
00115       // CubitNodes contained in this box.
00116       // Always zero for non-leaf boxes.
00117
00118 };
00119
00120 #include "OctTreeCell.cpp"
00121
00122 #endif
00123
