cgma
OctreeFacetPointData.cpp
00001 #include "OctreeFacetPointData.hpp"
00002
00003 #include "CubitPoint.hpp"
00004 #include "CubitFacet.hpp"
00005 #include "CubitFacetEdge.hpp"
00006 //#include "SVDrawTool.hpp"
00007 #include "CubitColor.hpp"
00008
00009 /* -------------------- Methods of OctreeFacetPointData ----------------- */
00010 int OctreeFacetPointData::calculate_id( void ){
00011   static int count = -1;
00012   count++;
00013   return count;
00014 }
00015
00016 OctreeFacetPointData::OctreeFacetPointData( CubitVector coord, CubitFacet *ptr_facet ){
00017   xyz = coord;
00018   type = CUBIT_FACET_POINT_DATA_FACET;
00019   facetPtr = ptr_facet;
00020   num = calculate_id();
00021 }
00022
00023 OctreeFacetPointData::OctreeFacetPointData( CubitVector coord, CubitFacetEdge *ptr_facet_edge ){
00024   xyz = coord;
00025   type = CUBIT_FACET_POINT_DATA_EDGE;
00026   facetEdgePtr = ptr_facet_edge;
00027   num = calculate_id();
00028 }
00029
00030 OctreeFacetPointData::OctreeFacetPointData( CubitVector coord, CubitPoint *ptr_point ){
00031   xyz = coord;
00032   type = CUBIT_FACET_POINT_DATA_POINT;
00033   facetPointPtr = ptr_point;
00034   num = calculate_id();
00035 }
00036
00037 CubitBoolean OctreeFacetPointData::generate_facet_point_data_based_on_curvature( CubitFacetEdge *ptr_facet_edge, /*double angle,*/ DLIList< OctreeFacetPointData *> &facet_point_data_list ){
00038
00039   CubitFacet *ptr_adj_facet0 = ptr_facet_edge->adj_facet(0);
00040   CubitFacet *ptr_adj_facet1 = ptr_facet_edge->adj_facet(1);
00041
00042     // Find minimum edge length
00043   int i;
00044   double edge_len, min_edge_len = CUBIT_DBL_MAX;
00045   for( i = 0; i < 3; i++ ){
00046     edge_len = ptr_adj_facet0->edge(i)->length();
00047     if( edge_len < min_edge_len ){
00048       min_edge_len = edge_len;
00049     }
00050   }
00051   for( i = 0; i < 3; i++ ){
00052     edge_len = ptr_adj_facet1->edge(i)->length();
00053     if( edge_len < min_edge_len ){
00054       min_edge_len = edge_len;
00055     }
00056   }
00057
00058   int num_seg = (int)(ptr_facet_edge->length() / min_edge_len) + 1;
00059
00060   // For triangles with high aspect ratio the number of segments can be enormous.  Limit
00061   // the number of segments.
00062   if(num_seg > 100)
00063     num_seg = 100;
00064
00065   OctreeFacetPointData *facet_point_data;
00066   for( i = 1; i < num_seg; i++ ){
00067     facet_point_data = new OctreeFacetPointData( (ptr_facet_edge->point(0)->coordinates() * (num_seg - i) + ptr_facet_edge->point(1)->coordinates()  * (i)) / num_seg , ptr_facet_edge );
00068     facet_point_data_list.push( facet_point_data );
00069   }
00070
00071   return CUBIT_TRUE;
00072 }
00073
00074 void OctreeFacetPointData::display( void ){
00075
00076   switch( type  ){
00077     case CUBIT_FACET_POINT_DATA_POINT:
00078         //SVDrawTool::draw_point( xyz, CUBIT_BLUE_INDEX );
00079         break;
00080
00081     case CUBIT_FACET_POINT_DATA_EDGE:
00082         //SVDrawTool::draw_point( xyz, CUBIT_YELLOW_INDEX );
00083         break;
00084
00085     case CUBIT_FACET_POINT_DATA_FACET:
00086         //SVDrawTool::draw_point( xyz, CUBIT_GREEN_INDEX );
00087         break;
00088
00089     default:
00090         break;
00091   }
00092
00093 }
00094
00095
00096
00097 //EOF
00098
