cgma
OrderedMap.hpp
00001 //-------------------------------------------------------------------------
00002 // Filename      : OrderedMap.hpp
00003 //
00004 // Purpose       : An std::map that keeps order that things were inserted
00005 //                 into it.
00006 //
00007 // Creator       : Matt Staten
00008 //
00009 // Creation Date : 01/27/2006
00010 //
00011 // Owner         : Matt Staten
00012 //-------------------------------------------------------------------------
00013
00014 #ifndef OrderedMap_HPP
00015 #define OrderedMap_HPP
00016
00017 #include <map>
00018 #include "DLIList.hpp"
00019
00020 template<class X, class Y> class OrderedMap
00021 {
00022 private:
00023     DLIList<X> mList1;
00024     std::map<X,Y> mMap;
00025
00026 public:
00027
00028     OrderedMap( void ) {};
00029
00030     bool find( X key, Y *data = NULL ) const
00031     {
00032         typename std::map<X,Y>::const_iterator iter = mMap.find( key );
00033         if ( iter == mMap.end() )
00034         {
00035             return CUBIT_FALSE;
00036         }
00037         if ( data )
00038         {
00039             *data = iter->second;
00040         }
00041         return CUBIT_TRUE;
00042     };
00043
00044     // Return true if the new pair was inserted.
00045     // Return false if this key is already being used.
00046     bool insert( X new_key, Y new_data )
00047     {
00048         if ( !find( new_key ) )
00049         {
00050             mList1.append( new_key );
00051             mMap.insert( std::pair<X,Y>( new_key, new_data ) );
00052             return CUBIT_TRUE;
00053         }
00054         return CUBIT_FALSE;
00055     };
00056
00057     // This can be inefficient
00058     void erase( X key_to_erase )
00059     {
00060         typename std::map<X,Y>::iterator iter = mMap.find( key_to_erase );
00061         if ( iter != mMap.end() )
00062         {
00063             mMap.erase( iter );
00064             mList1.remove_all_with_value( key_to_erase );
00065         }
00066     };
00067
00068     void erase_iter( int iter_to_erase )
00069     {
00070         X key_to_erase = mList1[iter_to_erase];
00071         typename std::map<X,Y>::iterator iter = mMap.find( key_to_erase );
00072         if ( iter != mMap.end() )
00073         {
00074             mMap.erase( iter );
00075             mList1.remove_all_with_value( key_to_erase );
00076         }
00077     };
00078
00079     X first( int iter ) const
00080     {
00081         return mList1[iter];
00082     }
00083     Y second( int iter ) const
00084     {
00085         Y data;
00086         bool stat = find( mList1[iter], &data );
00087         assert(stat);
00088         return data;
00089     }
00090
00091     bool empty( void ) const { return ( mList1.size() == 0 ? CUBIT_TRUE : CUBIT_FALSE ); };
00092     int size( void ) const { return mList1.size(); };
00093
00094     void clean_out( void )
00095     {
00096         mList1.clean_out();
00097         mMap.clear();
00098     };
00099
00100     OrderedMap<X,Y>& operator=(const OrderedMap<X,Y>&from)
00101     {
00102         clean_out();
00103         for ( int i = 0; i < from.size(); i++ )
00104         {
00105             X key = from.first( i );
00106             Y data = from.second( i );
00107             this->insert( key, data );
00108         }
00109         return *this;
00110     };
00111
00112     Y operator[]( X key ) const
00113     {
00114         Y data;
00115         bool stat = find( key, &data );
00116         //assert(stat);
00117         if(!stat)
00118           throw std::invalid_argument("The key specified was not found");
00119         return data;
00120     };
00121 };
00122
00123 #endif // OrderedMap_HPP
