cgma
00001 00002 #include <cassert> 00003 #include <cstdio> 00004 #include <cstring> 00005 00006 #include <iostream> 00007 00008 #include "SettingHandler.hpp" 00009 #include "CubitDefines.h" 00010 #include "CubitString.hpp" 00011 #include "CubitUtil.hpp" 00012 #include "CubitMessage.hpp" 00013 #include "AppUtil.hpp" 00014 #include "CubitFile.hpp" 00015 00016 00017 SettingHandler* SettingHandler::instance_ = NULL; 00018 00019 SettingHandler* SettingHandler::instance() 00020 { 00021 if (!instance_) 00022 { 00023 instance_ = new SettingHandler; 00024 if (!instance_) 00025 { 00026 std::cerr << " *** Unable to instantiate setting_handler object ***" << std::endl; 00027 exit(1); 00028 } 00029 } 00030 return instance_; 00031 } 00032 00033 //Default Constructor 00034 SettingHandler::SettingHandler() 00035 { 00036 debug_flags_added = CUBIT_FALSE; 00037 } 00038 00039 void SettingHandler::delete_instance() 00040 { 00041 if (instance_) 00042 { 00043 delete instance_; 00044 instance_ = 0; 00045 } 00046 } 00047 00048 SettingHandler::~SettingHandler() 00049 { 00050 std::map<CubitString, SettingHolder*>::iterator iter = mSettingsList.begin(); 00051 std::map<CubitString, SettingHolder*>::iterator end = mSettingsList.end(); 00052 00053 for( ; iter != end; ++iter) 00054 delete (*iter).second; 00055 mSettingsList.clear(); 00056 } 00057 00058 void SettingHandler::add_setting(const char* name, void (*setFn) (int), 00059 int (*getFn)()) 00060 { 00061 CubitString cs = name; 00062 //Check to see if a setting with the same name already exists 00063 if (mSettingsList.find(cs) != mSettingsList.end()) { 00064 std::cerr << "The " << name << " setting has the same name as another setting.\n" 00065 << "This is a bug. Please report!\n"; 00066 exit(-1); 00067 } 00068 SettingHolder* setting = new SettingHolder(cs, setFn, getFn); 00069 mSettingsList[cs] = setting; 00070 } 00071 00072 00073 void SettingHandler::add_setting(const char* name, void (*setFn) (double), 00074 double (*getFn)()) 00075 { 00076 CubitString cs = name; 00077 //Check to see if a setting with the same name already exists 00078 if (mSettingsList.find(cs) != mSettingsList.end()) { 00079 std::cerr << "The " << name << " setting has the same name as another setting.\n" 00080 << "This is a bug. Please report!\n"; 00081 exit(-1); 00082 00083 } 00084 SettingHolder* setting = new SettingHolder(cs, setFn, getFn); 00085 mSettingsList[cs] = setting; 00086 } 00087 00088 00089 void SettingHandler::add_setting(const char* name, void (*setFn) (CubitBoolean), 00090 CubitBoolean (*getFn)()) 00091 { 00092 CubitString cs = name; 00093 //Check to see if a setting with the same name already exists 00094 if (mSettingsList.find(cs) != mSettingsList.end()) { 00095 std::cerr << "The " << name << " setting has the same name as another setting.\n" 00096 << "This is a bug. Please report!\n"; 00097 exit(-1); 00098 00099 } 00100 SettingHolder* setting = new SettingHolder(cs, setFn, getFn); 00101 mSettingsList[cs] = setting; 00102 } 00103 00104 00105 void SettingHandler::add_setting(const char* name, void (*setFn) (CubitString), 00106 CubitString (*getFn)()) 00107 { 00108 CubitString cs = name; 00109 //Check to see if a setting with the same name already exists 00110 if (mSettingsList.find(cs) != mSettingsList.end()) { 00111 std::cerr << "The " << name << " setting has the same name as another setting.\n" 00112 << "This is a bug. Please report!\n"; 00113 exit(-1); 00114 00115 } 00116 SettingHolder* setting = new SettingHolder(cs, setFn, getFn); 00117 mSettingsList[cs] = setting; 00118 } 00119 00120 void SettingHandler::save_settings(const char *filename) 00121 { 00122 CubitFile file(filename, "w"); 00123 00124 if (!file) { 00125 std::cerr << "File " << filename << " could not be opened. Settings not saved." << std::endl; 00126 return; 00127 } 00128 00129 //Put a header at the top of the file 00130 fprintf(file.file(), "#Setting Name Setting Value\n"); 00131 fprintf(file.file(), "#------------------------------------------------------------\n"); 00132 00133 // Get starting and ending iterators from the map 00134 std::map<CubitString, SettingHolder*>::iterator start = mSettingsList.begin(); 00135 std::map<CubitString, SettingHolder*>::iterator end = mSettingsList.end(); 00136 00137 // Step through the map and build a file to hold the settings 00138 while(start != end) { 00139 SettingHolder* setting = (*start).second; 00140 00141 //Integer settings 00142 if (setting->setting_type == 0) { 00143 fprintf(file.file(), "%-50.50s%d \n", setting->name.c_str(), (setting->get_int_function)()); 00144 } 00145 00146 //Double settings 00147 else if (setting->setting_type == 1) { 00148 fprintf(file.file(), "%-50.50s%f \n", setting->name.c_str(), (setting->get_double_function)()); 00149 } 00150 00151 //Boolean settings 00152 else if (setting->setting_type == 2) { 00153 fprintf(file.file(), "%-50.50s%d \n", setting->name.c_str(), (setting->get_bool_function)()); 00154 } 00155 00156 //String settings 00157 else if (setting->setting_type == 3) { 00158 fprintf(file.file(), "%-50.50s%s \n", setting->name.c_str(), (setting->get_string_function)().c_str()); 00159 } 00160 00161 else 00162 { 00163 assert(false); 00164 PRINT_ERROR("Error with SettingHolder type! Please report."); 00165 } 00166 00167 ++start; 00168 } 00169 } 00170 00171 void SettingHandler::print_settings() 00172 { 00173 int rows, cols; 00174 if (!AppUtil::instance()->get_terminal_size(rows, cols)) 00175 cols = 71; 00176 --cols; 00177 00178 // Get starting and ending iterators from the map 00179 std::map<CubitString, SettingHolder*>::iterator iter = mSettingsList.begin(); 00180 const std::map<CubitString, SettingHolder*>::iterator end = mSettingsList.end(); 00181 00182 // Step through the map and build a file to hold the settings 00183 for ( ; iter != end; ++iter ) 00184 { 00185 SettingHolder* setting = iter->second; 00186 int vallen = cols - setting->name.length() - 1; 00187 if (vallen < 1) vallen = 1; 00188 switch( setting->setting_type ) 00189 { 00190 case 0: 00191 PRINT_INFO("%s %*d\n", setting->name.c_str(), vallen, 00192 (setting->get_int_function)()); 00193 break; 00194 case 1: 00195 PRINT_INFO("%s %*f\n", setting->name.c_str(), vallen, 00196 (setting->get_double_function)()); 00197 break; 00198 case 2: 00199 PRINT_INFO("%s %*s\n", setting->name.c_str(), vallen, 00200 (setting->get_bool_function)() ? "true" : "false"); 00201 break; 00202 case 3: 00203 PRINT_INFO("%s %*s\n", setting->name.c_str(), vallen, 00204 (setting->get_string_function)().c_str()); 00205 break; 00206 default: 00207 PRINT_INFO("%s %*s\n", setting->name.c_str(), vallen, 00208 "ERROR : UNKNOWN SETTING TYPE"); 00209 } 00210 } 00211 } 00212 00213 void SettingHandler::save_settings() 00214 { 00215 00216 const char* default_filename = "cubit.settings"; 00217 00218 CubitFile file(default_filename, "w"); 00219 00220 if (!file) { 00221 std::cerr << "File " << default_filename << " could not be opened. Settings not saved." << std::endl; 00222 return; 00223 } 00224 00225 //Put a header at the top of the file 00226 fprintf(file.file(), "#Setting Name Setting Value\n"); 00227 fprintf(file.file(), "#------------------------------------------------------------\n"); 00228 00229 // Get starting and ending iterators from the map 00230 std::map<CubitString, SettingHolder*>::iterator start = mSettingsList.begin(); 00231 std::map<CubitString, SettingHolder*>::iterator end = mSettingsList.end(); 00232 00233 // Step through the map and build a file to hold the settings 00234 while(start != end) { 00235 SettingHolder* setting = (*start).second; 00236 00237 //Integer settings 00238 if (setting->setting_type == 0) { 00239 fprintf(file.file(), "%-50.50s%d \n", setting->name.c_str(), (setting->get_int_function)()); 00240 } 00241 00242 //Double settings 00243 else if (setting->setting_type == 1) { 00244 fprintf(file.file(), "%-50.50s%f \n", setting->name.c_str(), (setting->get_double_function)()); 00245 } 00246 00247 //Boolean settings 00248 else if (setting->setting_type == 2) { 00249 fprintf(file.file(), "%-50.50s%d \n", setting->name.c_str(), (setting->get_bool_function)()); 00250 } 00251 00252 //String settings 00253 else if (setting->setting_type == 3) { 00254 fprintf(file.file(), "%-50.50s%s \n", setting->name.c_str(), (setting->get_string_function)().c_str()); 00255 } 00256 00257 else 00258 { 00259 assert(false); 00260 PRINT_ERROR("Error with SettingHolder type! Please report."); 00261 } 00262 00263 ++start; 00264 } 00265 } 00266 00267 00268 void SettingHandler::restore_settings(const char* filename) 00269 { 00270 00271 //Open the file for reading 00272 CubitFile file(filename, "r"); 00273 00274 if (file) { 00275 std::cerr << "File " << filename << " could not be opened. Settings not restored." << std::endl; 00276 return; 00277 } 00278 00279 //Read the first 2 lines of the file, we know they are not settings 00280 //so just get rid of them 00281 char junk[100]; 00282 fgets(junk, 100, file.file()); 00283 fgets(junk, 100, file.file()); 00284 00285 char name[51]; //Allocate 50 bytes for the characters and 1 for a null termination 00286 CubitString cubit_name; //A CubitString that will be used for checking if the setting 00287 //is in the map. 00288 char value[120]; //This will be used when getting the value of a setting 00289 SettingHolder* setting; 00290 int int_value = -1; 00291 double double_value = 0.0; 00292 CubitBoolean bool_value = CUBIT_FALSE; 00293 CubitString string_value = ""; 00294 00295 while (!feof(file.file())) { 00296 00297 //Get the setting name. This will be in the first 50 characters of a line 00298 fgets(name, 51, file.file()); 00299 00300 cubit_name = name; 00301 cubit_name.trim(); 00302 00303 //Find the setting in the map 00304 std::map<CubitString, SettingHolder*>::iterator temp; 00305 00306 temp = mSettingsList.find(cubit_name); 00307 00308 //Read in the rest of the line no matter what 00309 fgets(value, 120, file.file()); 00310 00311 if (temp == mSettingsList.end()) { 00312 std::cerr << "Setting " << cubit_name.c_str() << " was not found." << std::endl; 00313 } 00314 else { 00315 setting = (*temp).second; 00316 //Integer Settings 00317 if (setting->setting_type == 0) { 00318 int_value = atoi(value); 00319 (setting->set_int_function)(int_value); 00320 } 00321 00322 //Double Settings 00323 if (setting->setting_type == 1) { 00324 double_value = atof(value); 00325 (setting->set_double_function)(double_value); 00326 } 00327 00328 //Boolean Settings 00329 if (setting->setting_type == 2) { 00330 // bool_value = (CubitBoolean)(atoi(value)); 00331 bool_value = (atoi(value)) ? true : false; 00332 (setting->set_bool_function)(bool_value); 00333 } 00334 00335 //CubitString Settings 00336 if (setting->setting_type == 3) { 00337 string_value = value; 00338 (setting->set_string_function)(string_value); 00339 } 00340 00341 } 00342 00343 } //End while 00344 00345 } 00346 00347 SettingHolder* SettingHandler::get_setting_holder(CubitString name) 00348 { 00349 std::map<CubitString, SettingHolder*>::iterator it = mSettingsList.find(name); 00350 return it == mSettingsList.end() ? NULL : it->second; 00351 } 00352 00353 void SettingHandler::get_settings_list(std::vector< std::pair<CubitString, SettingHolder*> > &list) 00354 { 00355 // return a list of the settings 00356 std::map<CubitString, SettingHolder*>::iterator iter = mSettingsList.begin(); 00357 while(iter != mSettingsList.end()) 00358 { 00359 std::pair<CubitString, SettingHolder*> tmp_pair; 00360 CubitString key = (*iter).first; 00361 tmp_pair.first = key; 00362 tmp_pair.second = (*iter).second; 00363 list.push_back( (tmp_pair) ); 00364 iter++; 00365 } 00366 } 00367 00368 00369 00370 00371 00372 00373
