cgma
SphereEvaluator.hpp
00001 //-------------------------------------------------------------------------
00002 // Filename      : SphereEvaluator.hpp
00003 //
00004 // Purpose       : Provide evaluators for a spherical surface.  Since a sphere
00005 //                 is an analytic primitive, its evaluators can be overwritten
00006 //                 rather than using the OCC, or Facet based evaluators.
00007 //
00008 // Special Notes :
00009 //
00010 // Creator       : Matthew Staten
00011 //
00012 // Creation Date : 09/14/04
00013 //
00014 // Owner         : Matthew Staten
00015 //-------------------------------------------------------------------------
00016
00017 #ifndef SPHERE_EVALUATOR_HPP
00018 #define SPHERE_EVALUATOR_HPP
00019
00020 #include "CubitEvaluator.hpp"
00021 #include "CubitDefines.h"
00022 #include "CubitVector.hpp"
00023 #include "GeometryDefines.h"
00024
00025 class CUBIT_GEOM_EXPORT SphereEvaluatorData : public CubitEvaluatorData
00026 {
00027 public:
00028     double radius;
00029     CubitVector center;
00030
00031     virtual GeometryType ask_type() const { return SPHERE_SURFACE_TYPE; }
00032 };
00033
00034 class CUBIT_GEOM_EXPORT SphereEvaluator: public CubitEvaluator
00035 {
00036
00037 private:
00038
00039     SphereEvaluatorData mEvalData;
00040
00041 protected:
00042
00043 public :
00044
00045
00046     SphereEvaluator( const SphereEvaluatorData *data ) { mEvalData = *data; }
00047
00048   virtual ~SphereEvaluator()
00049     {}
00050
00051     virtual GeometryType ask_type() { return SPHERE_SURFACE_TYPE; }
00052     virtual CubitBoolean is_parametric() const { return CUBIT_TRUE; }
00053     virtual CubitBoolean is_periodic() const { return CUBIT_TRUE; }
00054     virtual CubitBoolean is_periodic_in_U( double &period ) const { period = 2*CUBIT_PI;
00055        return CUBIT_TRUE; }
00056     virtual CubitBoolean is_periodic_in_V( double &period ) const { period = 2*CUBIT_PI;
00057        return CUBIT_FALSE; }
00058     virtual CubitBoolean is_singular_in_U() const { return CUBIT_FALSE; }
00059     virtual CubitBoolean is_singular_in_V() const { return CUBIT_TRUE; }
00060     virtual CubitBoolean is_closed_in_U() const { return CUBIT_TRUE; }
00061     virtual CubitBoolean is_closed_in_V() const { return CUBIT_FALSE; }
00062     virtual CubitBoolean get_param_range_U( double& lower_bound,
00063                                             double& upper_bound ) const;
00064     virtual CubitBoolean get_param_range_V( double& lower_bound,
00065                                             double& upper_bound ) const;
00066
00067     virtual const CubitEvaluatorData* evaluator_data() const;
00068     virtual CubitVector position_from_u_v( double u, double v ) const;
00069     virtual CubitStatus u_v_from_position( CubitVector const& location,
00070                                            double& u,
00071                                            double& v,
00072                                            CubitVector* closest_location ) const;
00073
00074     virtual CubitBox bounding_box() const;
00075     //- Return the bounding obox of this sphere.
00076
00077     virtual CubitStatus principal_curvatures( CubitVector const& location,
00078                                               double& curvature_1,
00079                                               double& curvature_2,
00080                                               CubitVector* closest_location = NULL );
00081     //R CubitStatus
00082     //R- CUBIT_SUCCESS/FAILURE
00083     //I location
00084     //I- The point at which the curvatures are being requested -- it is also
00085     //I- the point to which the closest point on the surface is returned.
00086     //I- curvatures.
00087     //O closest_location
00088     //O- The point on the surface, closest to the input location (this
00089     //O- might not be on the surface).  This is input as a reference
00090     //O- so that the function can modify its contents.
00091     //O curvature_1/2
00092     //O- Returned principal curvature magnitudes.
00093     //- This functions computes the point on the surface that is closest
00094     //- to the input location and then calculates the magnitudes of the
00095     //- principal curvatures at this (possibly, new) point on the surface.
00096
00097     virtual CubitStatus closest_point( CubitVector const& location,
00098                                        CubitVector* closest_location = NULL,
00099                                        CubitVector* unit_normal_ptr = NULL,
00100                                        CubitVector* curvature1_ptr = NULL,
00101                                        CubitVector* curvature2_ptr = NULL ) const;
00102     //R CubitStatus
00103     //R- CUBIT_SUCCESS/FAILURE
00104     //I location
00105     //I- The point to which the closest point on the surface is desired.
00106     //O closest_location
00107     //O- The point on the Surface, closest to the
00108     //O- input location (which might not be on the Surface).  This is
00109     //O- input as a reference so that the function can modify its
00110     //O- contents.
00111     //O unit_normal_ptr
00112     //O- The normal (represented as a unit vector) at the closest_location.
00113     //O- If this pointer is NULL, the normal is not returned.
00114     //O curvature1_ptr
00115     //O- The first principal curvature of the surface at closest_location.
00116     //O- If this pointer is NULL, this curvature is not returned.
00117     //O curvature2_ptr
00118     //O- The second principal curvature of the surface at closest_location.
00119     //O- If this pointer is NULL, this curvature is not returned.
00120     //- This function computes the point on the surface closest to the input
00121     //- location -- i.e., closest_location.
00122     //- The first Facet FACE in the list
00123     //- is queried.
00124     //-
00125     //- If the input pointer values of unit_normal, curvature1 and
00126     //- curvature2
00127     //- are non-NULL, the normal and principal curvatures, too, are
00128     //- returned.  These are computed at closest_location, not at the
00129     //- input location.
00130     //-
00131     //- NOTE:
00132     //- It is assumed that if the calling code needs the normal or the
00133     //- principal curvatures, it will *allocate* space for the CubitVectors
00134     //- before sending in the pointers.
00135
00136 };
00137
00138
00139 // ********** BEGIN INLINE FUNCTIONS       **********
00140 // ********** END INLINE FUNCTIONS         **********
00141
00142 // ********** BEGIN FRIEND FUNCTIONS       **********
00143 // ********** END FRIEND FUNCTIONS         **********
00144
00145 // ********** BEGIN EXTERN FUNCTIONS       **********
00146 // ********** END EXTERN FUNCTIONS         **********
00147
00148 #endif
00149
