cgma
TDFacetBoundaryPoint.hpp
00001
00009 #ifndef TD_FACET_BOUNDARY_POINT_HPP
00010
00011
00012 #define TD_FACET_BOUNDARY_POINT_HPP
00013
00014 #include "CubitDefines.h"
00015 #include "ToolData.hpp"
00016 #include "MemoryManager.hpp"
00017 #include "DLIList.hpp"
00018 #include "CubitVector.hpp"
00019 #include "CastTo.hpp"
00020 class CubitPoint;
00021 class CubitFacet;
00022 class CubitQuadFacet;
00023 class CubitFacetEdge;
00024 class CubitTransformMatrix;
00028 typedef struct BoundaryPointData
00029 {
00030   DLIList<CubitFacet *> surfFacetList;
00031   CubitVector normal;
00032   double uVal, vVal, sizeVal;
00033   int surfID;
00034 } BoundaryPointData;
00035
00036 class TDFacetBoundaryPoint : public ToolData
00037 {
00038 private:
00039
00040   static MemoryManager memoryManager;
00041     //- memory management object
00042
00043   CubitPoint *pointPtr;
00044   DLIList <BoundaryPointData *> pointDataList;
00045
00046   void init_normal( BoundaryPointData *bpd_ptr );
00047     // initialize normals at point
00048   BoundaryPointData *get_bpd( CubitFacet *facet );
00049     // return a boundary point data
00050
00051 public:
00052
00053   TDFacetBoundaryPoint();
00054     //- constructor
00055
00056   ~TDFacetBoundaryPoint();
00057
00058   static int is_facet_boundary_point(const ToolData* td)
00059      {return (CAST_TO(const_cast<ToolData*>(td), TDFacetBoundaryPoint) != NULL);}
00060
00061   void add_surf(int new_id);
00062
00063   CubitPoint *get_point()
00064     { return pointPtr; }
00065
00066   void set_point( CubitPoint *point_ptr )
00067     { pointPtr = point_ptr; }
00068
00069   SetDynamicMemoryAllocation(memoryManager)
00070     //- class specific new and delete operators
00071
00072   static void set_memory_allocation_increment(int increment = 0)
00073     {memoryManager.set_memory_allocation_increment(increment);}
00074     //- set block memory size increment
00075
00076   static void destroy_memory()
00077     {memoryManager.destroy_memory();}
00078     //- destroy all memory allocted to this object
00079
00080   static CubitStatus add_facet_boundary_point(CubitPoint *point_ptr);
00081     // basic initializer
00082
00083   static CubitStatus add_facet_boundary_point( CubitPoint *point_ptr,
00084                                                CubitFacet *facet_ptr,
00085                                                CubitVector &normal );
00086   static CubitStatus add_facet_boundary_point( CubitPoint *point_ptr,
00087                                                CubitQuadFacet *qfacet_ptr,
00088                                                CubitVector &normal );
00089     // initializes with a single facet and normal
00090
00091   static TDFacetBoundaryPoint* get_facet_boundary_point(CubitPoint *point_ptr);
00092     // get the fbp from the point
00093
00094   CubitStatus get_normal( int surf_id, CubitVector &normal );
00095   CubitStatus get_normal( CubitFacet *adj_facet, CubitVector &normal );
00096   CubitStatus get_normal( CubitFacetEdge *edge_ptr, CubitVector &normal );
00097   CubitStatus set_normal( int surf_id, CubitVector &normal );
00098     //recalculate normals.  Call this if an attached facet changes in some way.
00099   CubitStatus reset_normals();
00100     //- get and set normals at a specific surface or facet
00101
00102   CubitStatus set_uv( CubitFacet *adj_facet, double u, double v );
00103   CubitStatus set_uvs( CubitFacet *adj_facet, double u, double v, double s );
00104   double u( CubitFacet *adj_facet );
00105   double v( CubitFacet *adj_facet );
00106   double s( CubitFacet *adj_facet );
00107   CubitStatus get_uv( CubitFacet *adj_facet, double &u, double &v );
00108     //- get and set the u-v values for this surface
00109   CubitStatus get_uvs( CubitFacet *adj_facet, double &u, double &v, double &s );
00110     //- get and set the u-v values and size for this surface
00111
00112
00113   void add_surf_facets( DLIList<CubitFacet *> adj_facet_list );
00114     //- add a group of facets that are adjacent to this point
00115     //- that are on the same surface
00116   void set_surf_id( CubitFacet *facet_ptr, int surf_id );
00117     //- set id of surface associated with facet
00118
00119   CubitStatus merge_normals( CubitFacet *facet0, CubitFacet *facet1);
00120     //- merge the normals from facets
00121
00122   CubitStatus rotate_normal( CubitTransformMatrix &rotmat );
00123     //- rotate the normals at the point
00124
00125   CubitStatus get_boundary_point_data_size( int &size_int_data,
00126                                             int &size_double_data );
00127   CubitStatus get_boundary_point_data(int *int_data, double *double_data,
00128                                       int &iidx, int &didx );
00129    //- retreive info for dumping to a CUB file
00130
00131   static CubitStatus new_facet_boundary_point(CubitPoint **points,
00132                     CubitFacet **facets,int &iidx,int &didx,
00133                     int *int_data,double *double_data);
00134   void initialize(CubitFacet **facets,
00135             int &iidx, int &didx, int *int_data,double *double_data);
00136     //- restore data from a CUB file
00137 };
00138
00139
00140 #endif // TD_FACET_BOUNDARY_EDGE_HPP
00141
00142
