cgma
iGeomError.cc
00001 #include "iGeomError.h"
00002 #include "iGeom.h"
00003 #include <string>
00004 #include <assert.h>
00005
00006 #define iBase_SUCCESS_DESC "No Error"
00007
00008 std::string lastErrorDesc = iBase_SUCCESS_DESC;
00009 iBase_ErrorType lastErrorType = iBase_SUCCESS;
00010
00011 #ifdef __cplusplus
00012 extern "C" {
00013 #endif
00014
00015 void CGM_iGeom_clearLastError()
00016 {
00017   if (lastErrorType != iBase_SUCCESS) { // don't copy string not needed
00018     lastErrorType = iBase_SUCCESS;
00019     lastErrorDesc = iBase_SUCCESS_DESC;
00020   }
00021 }
00022
00023 void CGM_iGeom_setLastError( int error_type, const char* description )
00024 {
00025     // don't do string copies for non-errors
00026   if (error_type == iBase_SUCCESS && lastErrorType == iBase_SUCCESS)
00027     return;
00028
00029   lastErrorType = static_cast<iBase_ErrorType>(error_type);
00030   if (description) {
00031     lastErrorDesc = description;
00032     return;
00033   }
00034
00035 #define ERROR_DESC( A, B ) \
00036   case iBase_ ## A : lastErrorDesc = B ; break;
00037
00038   switch (error_type) {
00039     ERROR_DESC( SUCCESS                 , iBase_SUCCESS_DESC );
00040     ERROR_DESC( MESH_ALREADY_LOADED     , "Mesh already loaded" );
00041     ERROR_DESC( FILE_NOT_FOUND          , "Could not read file" );
00042     ERROR_DESC( FILE_WRITE_ERROR        , "File write failed" );
00043     ERROR_DESC( NIL_ARRAY               , "NULL or empty array" );
00044     ERROR_DESC( BAD_ARRAY_SIZE          , "Invalid array size" );
00045     ERROR_DESC( BAD_ARRAY_DIMENSION     , "Invalid array dimension" );
00046     ERROR_DESC( INVALID_ENTITY_HANDLE   , "Invalid entity handle" );
00047     ERROR_DESC( INVALID_ENTITY_COUNT    , "Invalid entity count" );
00048     ERROR_DESC( INVALID_ENTITY_TYPE     , "Invalid entity type" );
00049     ERROR_DESC( INVALID_ENTITY_TOPOLOGY , "Invalid entity topology" );
00050     ERROR_DESC( BAD_TYPE_AND_TOPO       , "Bad type and/or topology" );
00051     ERROR_DESC( ENTITY_CREATION_ERROR   , "Entity creation failed" );
00052     ERROR_DESC( INVALID_TAG_HANDLE      , "Invalid Tag" );
00053     ERROR_DESC( TAG_NOT_FOUND           , "Tag does not exist" );
00054     ERROR_DESC( TAG_ALREADY_EXISTS      , "Tag name conflict" );
00055     ERROR_DESC( TAG_IN_USE              , "Tag name conflict" );
00056     ERROR_DESC( INVALID_ENTITYSET_HANDLE, "Invalid entity set handle" );
00057     ERROR_DESC( INVALID_ITERATOR_HANDLE , "Invalid iterator handle" );
00058     ERROR_DESC( INVALID_ARGUMENT        , "Invalid argument" );
00059     ERROR_DESC( MEMORY_ALLOCATION_FAILED, "Out of memory" );
00060     ERROR_DESC( NOT_SUPPORTED           , "Feature not supported" );
00061     ERROR_DESC( FAILURE                 , "Unknown failure or internal error" );
00062     default:
00063       assert(false);
00064       lastErrorDesc = "IVALID OR UNKNOWN ERROR CODE";
00065   }
00066 }
00067
00068 int CGM_iGeom_getLastErrorType()
00069 {
00070   return lastErrorType;
00071 }
00072
00073 void CGM_iGeom_getLastErrorDesc(char* description_buffer,
00074                                 int description_buffer_length )
00075 {
00076   if (description_buffer && description_buffer_length > 0) {
00077     lastErrorDesc.copy( description_buffer, description_buffer_length );
00078     if (lastErrorDesc.length() < (unsigned)description_buffer_length)
00079       description_buffer[lastErrorDesc.length()] = '\0';
00080   }
00081 }
00082
00083 #ifdef __cplusplus
00084  } // extern "C"
00085 #endif
