cgma
point_project.cpp
00001
00010 #undef NDEBUG
00011 #include <cassert>
00012
00013 #include "GeometryModifyEngine.hpp"
00014 #include "GeometryModifyTool.hpp"
00015 #include "GeometryQueryTool.hpp"
00016 #include "CubitMessage.hpp"
00017 #include "Body.hpp"
00018 #include "RefVolume.hpp"
00019 #include "RefFace.hpp"
00020 #include "RefEdge.hpp"
00021 #include "RefVertex.hpp"
00022 #include "InitCGMA.hpp"
00023 #include "OCCBody.hpp"
00024 #include "OCCSurface.hpp"
00025 #include "OCCCurve.hpp"
00026 #include "OCCDrawTool.hpp"
00027 #include "CubitCompat.hpp"
00028
00029 #ifndef SRCDIR
00030 # define SRCDIR .
00031 #endif
00032
00033 #define STRINGIFY_(X) #X
00034 #define STRINGIFY(X) STRINGIFY_(X)
00035 #define SRCPATH STRINGIFY(SRCDIR) "/"
00036
00037 // forward declare some functions used and defined later
00038 CubitStatus read_geometry(int, const char **, bool local = false);
00039 CubitStatus point_project();
00040 // macro for printing a separator line
00041 #define PRINT_SEPARATOR   PRINT_INFO("=======================================\n");
00042
00043 // main program - initialize, then send to proper function
00044 int main (int argc, char **argv)
00045 {
00046   CubitStatus status = InitCGMA::initialize_cgma("OCC");
00047   if (CUBIT_SUCCESS != status) return 1;
00048
00049   //Do make point.
00050   status = point_project();
00051   if (status == CUBIT_FAILURE)
00052      PRINT_INFO("Operation Failed");
00053
00054   int ret_val = ( CubitMessage::instance()->error_count() );
00055   if ( ret_val > 0 )
00056   {
00057     PRINT_ERROR("Errors found during Mergechk session.\n");
00058   }
00059   return ret_val;
00060
00061 }
00062
00067 CubitStatus read_geometry(int num_files, const char **argv, bool local)
00068 {
00069   CubitStatus status = CUBIT_SUCCESS;
00070   GeometryQueryTool *gti = GeometryQueryTool::instance();
00071   assert(gti);
00072   int i;
00073
00074   PRINT_SEPARATOR;
00075
00076   for (i = 0; i < num_files; i++) {
00077     std::string filename( local ? "./" : SRCPATH );
00078     filename += argv[i];
00079     status = CubitCompat_import_solid_model(filename.c_str(), "OCC");
00080     if (status != CUBIT_SUCCESS) {
00081       PRINT_ERROR("Problems reading geometry file %s.\n", filename.c_str());
00082     }
00083   }
00084   PRINT_SEPARATOR;
00085
00086   return CUBIT_SUCCESS;
00087 }
00088
00089 CubitStatus point_project()
00090 {
00091   GeometryQueryTool *gti = GeometryQueryTool::instance();
00092
00093   const char *argv = "box-w-hole.brep";
00094   CubitStatus status = read_geometry(1, &argv);
00095   if (status == CUBIT_FAILURE) exit(1);
00096
00097   DLIList<Body*> test_bodies;
00098   gti->bodies(test_bodies);
00099   DLIList<Surface*> surfaces;
00100   BodySM* body = test_bodies.get()->get_body_sm_ptr();
00101   body->surfaces(surfaces);
00102   Surface* surf = NULL;
00103   for (int i = 0 ; i <  surfaces.size(); i++)
00104   {
00105     surf = surfaces.get_and_step();
00106     double d = surf->measure();
00107     if (d < 82.1 && d > 81.9)
00108       break;
00109   }
00110   CubitVector point(1,1,-5);
00111   CubitVector on_surf;
00112   surf->closest_point_trimmed(point, on_surf);
00113   std::cout << "Point on surface closest to (1, 1, -5) is (" << on_surf.x()
00114       << ", " << on_surf.y() << ", " << on_surf.z() << ")" << std::endl;
00115   assert (fabs(on_surf.z() + 5) < 0.0001);
00116   if (on_surf.y() < on_surf.x())
00117   {
00118     assert (on_surf.y() < 1.001 && on_surf.y() > 0.999);
00119     assert (on_surf.x() < 2.122 && on_surf.x() > 2.121 );
00120   }
00121   else
00122   {
00123     assert (on_surf.y() < 2.122 && on_surf.y() > 2.121 );
00124     assert (on_surf.x() < 1.001 && on_surf.x() > 0.999);
00125   }
00126
00127   CubitVector p1(0, 1.5, -6 );
00128   surf->closest_point_trimmed(p1, on_surf);
00129   std::cout << "Point on surface closest to (0, 1.5, -6) is (" << on_surf.x()
00130       << ", " << on_surf.y() << ", " << on_surf.z() << ")" << std::endl;
00131   assert (fabs(on_surf.z() + 5) < 0.0001);
00132   assert (on_surf.y() < 2.122 && on_surf.y() > 2.121);
00133   assert (on_surf.x() < 0.0001 && on_surf.x() > -0.0001 );
00134   return CUBIT_SUCCESS;
00135 }
