MOAB: Mesh Oriented datABase
(version 5.3.1)
#include "Mesquite.hpp"
#include "MeshImpl.hpp"
#include "MsqError.hpp"
#include "InstructionQueue.hpp"
#include "TerminationCriterion.hpp"
#include "QualityAssessor.hpp"
#include "PlanarDomain.hpp"
#include "XYPlanarDomain.hpp"
#include "MeshInterface.hpp"
#include "TShapeNB1.hpp"
#include "TShapeB1.hpp"
#include "TQualityMetric.hpp"
#include "IdealShapeTarget.hpp"
#include "MaxTemplate.hpp"
#include "PMeanPTemplate.hpp"
#include "ElementMaxQM.hpp"
#include "ElementAvgQM.hpp"
#include "ElementPMeanP.hpp"
#include "ElemSampleQM.hpp"
#include "TargetCalculator.hpp"
#include "LPtoPTemplate.hpp"
#include "NonGradient.hpp"
#include "TestUtil.hpp"
Defines | |
#define | FILE_NAME1 "bad_circle_tri.vtk" |
#define | FILE_NAME2 "tangled_tri.vtk" |
Functions | |
int | main () |
#define FILE_NAME1 "bad_circle_tri.vtk" |
Referenced by main().
#define FILE_NAME2 "tangled_tri.vtk" |
int main | ( | ) |
Definition at line 61 of file nongradient_test.cpp.
References MBMesquite::TerminationCriterion::add_iteration_limit(), MBMesquite::InstructionQueue::add_quality_assessor(), MBMesquite::MsqError::BARRIER_VIOLATED, MBMesquite::MsqError::clear(), MBMesquite::MsqError::error_code(), FILE_NAME1, FILE_NAME2, MBMesquite::MeshImpl::read_vtk(), MBMesquite::IQInterface::run_instructions(), MBMesquite::NonGradient::set_debugging_level(), MBMesquite::QualityImprover::set_inner_termination_criterion(), MBMesquite::InstructionQueue::set_master_quality_improver(), MBMesquite::QualityImprover::set_outer_termination_criterion(), MBMesquite::NonGradient::setExactPenaltyFunction(), MBMesquite::NonGradient::setSimplexDiameterScale(), MBMesquite::PatchSetUser::use_element_on_vertex_patch(), and MBMesquite::PlanarDomain::XY.
{ MsqPrintError err( std::cout ); PlanarDomain xyPlane( PlanarDomain::XY, -5 ); #define FILE_NAME1 "bad_circle_tri.vtk" #define FILE_NAME2 "tangled_tri.vtk" std::string file_name1 = TestDir + "unittest/mesquite/2D/vtk/tris/untangled/" FILE_NAME1; std::string file_name2 = TestDir + "unittest/mesquite/2D/vtk/tris/tangled/" FILE_NAME2; // Barrier / Max Objective Function Test MBMesquite::MeshImpl mesh_max; mesh_max.read_vtk( file_name1.c_str(), err ); if( err ) { std::cerr << "NonGradient Barrier test: failed to read file." << std::endl; return 1; } IdealShapeTarget target_max; TShapeB1 mu; TQualityMetric tqMetric_max( &target_max, &mu ); ElemSampleQM* sampleMetric( &tqMetric_max ); ElementMaxQM maxMetric( &tqMetric_max ); ElementPMeanP meanpMetric( 1.0, sampleMetric ); MaxTemplate maxObjFunction( &maxMetric ); // max(max) NonGradient max_opt( &maxObjFunction ); // optimization procedure PMeanPTemplate pmeanpObjFunction( 1.0, sampleMetric ); NonGradient pmeanp_opt( &pmeanpObjFunction ); LPtoPTemplate PtoPObjMaxfunction( &maxMetric, (short int)1.0, err ); // max(max) // Processing for Max Objective Function max_opt.setSimplexDiameterScale( 0 ); max_opt.use_element_on_vertex_patch(); // local patch max_opt.set_debugging_level( 0 ); // Construct and register the Quality Assessor instances QualityAssessor max_initial_qa = QualityAssessor( &maxMetric, 10 ); QualityAssessor maxObj_max_optimal_qa = QualityAssessor( &maxMetric, 10 ); //**************Set stopping criterion**************** TerminationCriterion innerTC, outerTC; outerTC.add_iteration_limit( 40 ); innerTC.add_iteration_limit( 20 ); max_opt.set_outer_termination_criterion( &outerTC ); max_opt.set_inner_termination_criterion( &innerTC ); // test for barrier violation PlanarDomain xyPlane2( PlanarDomain::XY, 5 ); MBMesquite::MeshImpl mesh_bv; mesh_bv.read_vtk( file_name2.c_str(), err ); if( err ) { std::cerr << "NonGradient Barrier Violation test: failed to read file." << std::endl; return 1; } InstructionQueue queue1; queue1.add_quality_assessor( &max_initial_qa, err ); if( err ) return 1; queue1.set_master_quality_improver( &max_opt, err ); // max if( err ) return 1; queue1.add_quality_assessor( &maxObj_max_optimal_qa, err ); if( err ) return 1; MBMesquite::MeshDomainAssoc mesh_and_domain = MeshDomainAssoc( &mesh_max, &xyPlane ); queue1.run_instructions( &mesh_and_domain, err ); if( err ) return 1; // Non-Barrier / Ave Objective Function Test MBMesquite::MeshImpl mesh_mean; mesh_mean.read_vtk( file_name1.c_str(), err ); if( err ) { std::cerr << "NonGradient Non-barrier test: failed to read file." << std::endl; return 1; } TShapeNB1 nonBarrier; TargetCalculator* target; IdealShapeTarget ident_target; target = &ident_target; TQualityMetric tqMetric( target, &nonBarrier ); ElementPMeanP mean_metric( 1.0, &tqMetric ); PMeanPTemplate meanObjfunction( 1.0, &mean_metric ); // ave(ave) // Processing for Mean Objective Function NonGradient mean_opt( &meanObjfunction ); // optimization procedure mean_opt.setExactPenaltyFunction( false ); // allow infeasible mean_opt.use_element_on_vertex_patch(); // local patch // Set Termination Criteria TerminationCriterion innerTC_mean, outerTC_mean; outerTC_mean.add_iteration_limit( 10 ); innerTC_mean.add_iteration_limit( 30 ); mean_opt.set_outer_termination_criterion( &outerTC_mean ); mean_opt.set_inner_termination_criterion( &innerTC_mean ); mean_opt.set_debugging_level( 0 ); // Construct and register the meanObj Quality Assessor instance QualityAssessor mean_qa = QualityAssessor( &mean_metric, 10 ); InstructionQueue queue2; queue2.add_quality_assessor( &mean_qa, err ); if( err ) return 1; queue2.set_master_quality_improver( &mean_opt, err ); if( err ) return 1; queue2.add_quality_assessor( &mean_qa, err ); if( err ) return 1; queue2.run_instructions( &mesh_and_domain, err ); if( err ) return 1; // Test barrier target metric using objective function MaxTemplate with inverted mesh InstructionQueue queue3; queue3.add_quality_assessor( &max_initial_qa, err ); if( err ) return 1; queue3.set_master_quality_improver( &max_opt, err ); if( err ) return 1; MBMesquite::MeshDomainAssoc mesh_and_domain2 = MeshDomainAssoc( &mesh_bv, &xyPlane2 ); queue3.run_instructions( &mesh_and_domain2, err ); if( err.error_code() == err.BARRIER_VIOLATED ) { std::cerr << std::endl << "MaxTemplate OF with inverted mesh test passed" << std::endl; err.clear(); } else return 1; // Test barrier target metric using objective function PMeanPTemplate with inverted mesh InstructionQueue queue4; queue4.set_master_quality_improver( &pmeanp_opt, err ); if( err ) return 1; queue4.run_instructions( &mesh_and_domain2, err ); if( err.error_code() == err.BARRIER_VIOLATED ) { std::cerr << std::endl << "PMeanPTemplate OF with inverted mesh test passed" << std::endl << std::endl; err.clear(); } else return 1; return 0; }
