cgma
FacetLump.hpp
00001 //-------------------------------------------------------------------------
00002 // Filename      : FacetLump.hpp
00003 //
00004 // Purpose       :
00005 //
00006 // Special Notes :
00007 //
00008 // Creator       : David White
00009 //
00010 // Creation Date : 7/18/2000
00011 //-------------------------------------------------------------------------
00012
00013 #ifndef FACET_LUMP_HPP
00014 #define FACET_LUMP_HPP
00015
00016 // ********** BEGIN STANDARD INCLUDES      **********
00017 // ********** END STANDARD INCLUDES        **********
00018
00019 // ********** BEGIN CUBIT INCLUDES         **********
00020 #include "CubitDefines.h"
00021 #include "Lump.hpp"
00022 #include "FacetAttribSet.hpp"
00023 // ********** END CUBIT INCLUDES           **********
00024
00025 // ********** BEGIN FORWARD DECLARATIONS   **********
00026 class TopologyEntity;
00027 class BodySM;
00028 class FacetAttrib;
00029
00030 class FacetBody;
00031 class FacetShell;
00032 class FacetSurface;
00033 class FacetLoop;
00034 class FacetCoEdge;
00035 class FacetCurve;
00036 class FacetPoint;
00037
00038 // ********** END FORWARD DECLARATIONS     **********
00039
00040 class FacetLump : public Lump
00041 {
00042 public:
00043
00044   FacetLump(DLIList<ShellSM*> &my_shells,
00045             BodySM *body_sm_ptr = NULL);
00046     //Pass in a list of shells attached to this lump if you have them.
00047     //Also pass in the body that this lump belongs to.
00048   virtual ~FacetLump();
00049     //- The destructor
00050
00051   void add_body(BodySM* new_body)
00052     {myBodyPtr = new_body;}
00053
00054   virtual void append_simple_attribute_virt(const CubitSimpleAttrib&);
00055     //R void
00056     //I
00057     //I-
00058     //I- that is to be appended to this OSME object.
00059     //- The purpose of this function is to append a
00060     //- attribute to the OSME. The  is attached to each of the
00061     //- underlying solid model entities this one points to.
00062
00063   virtual void remove_simple_attribute_virt(const CubitSimpleAttrib&);
00064     //R void
00065     //I CubitSimpleAttrib*
00066     //I- A reference to a CubitSimpleAttrib object which is the object
00067     //I- that is to be removed to this OSME object.
00068     //- The purpose of this function is to remove a simple
00069     //- attribute from the OSME. The attribute is attached to each of the
00070     //- underlying solid model entities this one points to.
00071
00072   virtual void remove_all_simple_attribute_virt();
00073     //R void
00074     //I-
00075     //- The purpose of this function is to remove all simple
00076     //- attributes from the OSME.
00077
00078   virtual CubitStatus get_simple_attribute(DLIList<CubitSimpleAttrib>&);
00079   virtual CubitStatus get_simple_attribute(const CubitString& name,
00080                                            DLIList<CubitSimpleAttrib>&);
00081     //R CubitSimpleAttrib*
00082     //R- the returned cubit simple attribute.
00083     //- The purpose of this function is to get the attributes
00084     //- of the geometry entity. The name is attached to the underlying solid
00085     //- model entity(ies) this one points to.
00086     //- MJP Note:
00087     //- This is the code that implements the requirement that names
00088     //- of VGI Entities propagate across solid model boolean
00089     //- operations.  The success of this relies, of course, on the underlying
00090     //- solid modeler being able to propagate attributes across
00091     //- such operations on its entities. If it cannot, then "names"
00092     //- of VGI entities will not propagate.
00093
00094   virtual CubitBox bounding_box() const ;
00095
00096   virtual GeometryQueryEngine*
00097   get_geometry_query_engine() const;
00098     //R GeometryQueryEngine*
00099     //R- A pointer to the geometric modeling engine associated with
00100     //R- the object.
00101     //- This function returns a pointer to the geometric modeling engine
00102     //- associated with the object.
00103
00104   virtual CubitStatus merge( GeometryEntity* /*GEPtr*/)
00105     {
00106       PRINT_ERROR("BUG: In FacetLump::merge\n"
00107                   "     This function should not be called at all\n"
00108                   "  This is a Bug -- please report it!\n");
00109       return CUBIT_FAILURE;
00110     }
00111
00112   virtual TopologyEntity* unmerge(DLIList<RefVolume*>)
00113     {
00114       PRINT_ERROR( "BUG: In FacetLump::unmerge\n"
00115                    "     This function should not be called\n"
00116                    "  This is a Bug -- please report it!\n" );
00117       return (TopologyEntity*)NULL;
00118     }
00119
00120   virtual double measure();
00121     //R double
00122     //R- The numeric value of the measure (its units depend on the dimension
00123     //R- of the RefEntity being "measured")
00124     //- A generic geometric extent function.
00125     //- Returns volume for Lump, area for Surface, length for Curve and
00126     //- 1.0 for Point
00127
00128   CubitStatus save_attribs( FILE* file_ptr );
00129     // Write FactAttribs out to file
00130
00131   CubitStatus restore_attribs( FILE* file_ptr, unsigned int endian );
00132     // Read FactAttribs from file
00133
00134   void get_bodies  ( DLIList<FacetBody   *>& bodies   );
00135   void get_shells  ( DLIList<FacetShell  *>& shells   );
00136   void get_surfaces( DLIList<FacetSurface*>& surfaces );
00137   void get_coedges ( DLIList<FacetCoEdge *>& coedges  );
00138   void get_curves  ( DLIList<FacetCurve  *>& curves   );
00139
00140   void get_parents_virt( DLIList<TopologyBridge*>& parents );
00141   void get_children_virt( DLIList<TopologyBridge*>& children );
00142
00143   inline BodySM* get_body() const { return myBodyPtr; }
00144
00145   inline void remove_body() {myBodyPtr = 0;}
00146
00147   void add_shell( FacetShell *shell );
00148   void remove_shell( FacetShell *shell );
00149
00150   void disconnect_all_shells();
00151
00152   CubitStatus mass_properties( CubitVector& centroid, double& volume );
00153
00154   CubitPointContainment point_containment( const CubitVector &point, double tolerance );
00155
00156     //is this lump a sheet
00157   CubitBoolean is_sheet( );
00158
00159 protected:
00160
00161 private:
00162   DLIList<ShellSM*> myShells;
00163   BodySM *myBodyPtr;
00164
00165   FacetAttribSet attribSet;
00166     //List of FacetAttrib*'s instead of CubitSimpleAttribs
00167 } ;
00168
00169
00170 // ********** BEGIN INLINE FUNCTIONS       **********
00171 // ********** END INLINE FUNCTIONS         **********
00172
00173 // ********** BEGIN FRIEND FUNCTIONS       **********
00174 // ********** END FRIEND FUNCTIONS         **********
00175
00176 // ********** BEGIN EXTERN FUNCTIONS       **********
00177 // ********** END EXTERN FUNCTIONS         **********
00178
00179 #endif
00180
