cgma
PartitionPoint.cpp
00001 #include "PartitionPoint.hpp"
00002 #include "PartitionCurve.hpp"
00003 #include "VirtualQueryEngine.hpp"
00004 #include "PartitionEngine.hpp"
00005
00006 #include "CubitPointData.hpp"
00007 #include "TDVGFacetOwner.hpp"
00008 #include "CubitTransformMatrix.hpp"
00009 #include "Surface.hpp"
00010
00011 PartitionPoint::PartitionPoint( const CubitVector& position,
00012                                 PartitionEntity* owner )
00013   : firstCurve(0), curveCount(0), myPosition( position ), facetPoint(0)
00014 {
00015   owner->sub_entity_set().add_lower_order( this );
00016 }
00017
00018 PartitionPoint::PartitionPoint( TBPoint* real_point )
00019   : firstCurve(0), curveCount(0),
00020     myPosition( real_point->coordinates() ),
00021     facetPoint(0)
00022 {
00023   assert( dynamic_cast<SubEntitySet*>(real_point->owner()) == 0 );
00024   new SubEntitySet( real_point, this );
00025 }
00026
00027 PartitionPoint::PartitionPoint( const CubitSimpleAttrib& attrib,
00028                                 PartitionEntity* owner )
00029   : firstCurve(0), curveCount(0), facetPoint(0)
00030 {
00031   DLIList<int> junk;
00032   DLIList<CubitVector*> pt;
00033   owner->sub_entity_set().add_lower_order( this, attrib, 0, pt, junk, junk, junk);
00034   assert(pt.size() == 1);
00035   myPosition = *pt.get();
00036   delete pt.get();
00037 }
00038
00039
00040 PartitionPoint::~PartitionPoint()
00041 {
00042   while( firstCurve )
00043   {
00044     PartitionCurve* curve = firstCurve;
00045     if( curve->start_point() == this )
00046       curve->start_point(0);
00047     if( curve->end_point() == this )
00048       curve->end_point(0);
00049     assert( firstCurve != curve );
00050   }
00051   assert( curveCount == 0 );
00052   facet_point(0);
00053 }
00054
00055 CubitVector PartitionPoint::coordinates() const
00056   { return myPosition; }
00057 /*
00058 int PartitionPoint::num_curves() const
00059 {
00060   int count = 0;
00061   for( PartitionCurve* curve = firstCurve; curve; curve=curve->next_curve(this) )
00062     count++;
00063   return count;
00064 }
00065 */
00066 PartitionCurve* PartitionPoint::next_curve( PartitionCurve* prev ) const
00067   { return prev ? prev->next_curve(this) : firstCurve; }
00068
00069 PartitionCurve* PartitionPoint::common_curve( PartitionPoint* other ) const
00070 {
00071   PartitionCurve* curve = 0;
00072   if( other == this )
00073   {
00074     while( (curve = next_curve(curve)) )
00075       if( curve->start_point() == curve->end_point() )
00076         return curve;
00077   }
00078   else
00079   {
00080     while( (curve = next_curve(curve)) )
00081       if( curve->other_point(other) )
00082         return curve;
00083   }
00084   return 0;
00085 }
00086
00087 CubitStatus PartitionPoint::move( CubitVector& /*delta*/ )
00088 {
00089   //if( curveSet.size() )
00090     return CUBIT_FAILURE;
00091
00092   //myPosition += delta;
00093   //return CUBIT_SUCCESS;
00094 }
00095
00096 void PartitionPoint::get_parents_virt( DLIList<TopologyBridge*>& parents )
00097 {
00098   parents.clean_out();
00099   if( real_point() )
00100   {
00101       // Get all the real point's parent curves.
00102     sub_entity_set().get_entity()->get_parents_virt( parents );
00103
00104       // Remove all real parents hidden by partitions.  We will add
00105       // the partitions hiding these curves later.
00106     for( int i = parents.size(); i--; )
00107       if( dynamic_cast<SubEntitySet*>(parents.step_and_get()->owner() ) )
00108         parents.change_to(0);
00109     parents.remove_all_with_value(0);
00110   }
00111
00112     // Now add any parent partition curves
00113   for( PartitionCurve* curve = firstCurve; curve; curve = curve->next_curve(this) )
00114     parents.append( curve );
00115
00116 }
00117
00118 void PartitionPoint::get_children_virt( DLIList<TopologyBridge*>& )
00119 {
00120 }
00121
00122 TBPoint* PartitionPoint::real_point() const
00123 {
00124   return dynamic_cast<TBPoint*>(sub_entity_set().get_entity());
00125 }
00126
00127 GeometryQueryEngine* PartitionPoint::get_geometry_query_engine() const
00128 {
00129   return VirtualQueryEngine::instance();
00130 }
00131
00132 void PartitionPoint::print_debug_info( const char* prefix,
00133                                        bool ent_set ) const
00134 {
00135   if( !prefix ) prefix = "";
00136   char* new_prefix = new char[strlen(prefix)+3];
00137   strcpy( new_prefix, prefix );
00138   strcat( new_prefix, "  ");
00139   CubitVector p = coordinates();
00140   PRINT_INFO("%sPartitionPoint %p at (%f,%f,%f)\n",
00141     prefix, (void*)this, p.x(), p.y(), p.z() );
00142   DLIList<Curve*> curve_list;
00143   const_cast<PartitionPoint*>(this)->TopologyBridge::curves( curve_list );
00144   PRINT_INFO("%s  %d Curves (%d PartitionCurves).\n", prefix,
00145     curve_list.size(), num_curves() );
00146
00147   if ( facet_point() ) {
00148     p = facet_point()->coordinates();
00149     PRINT_INFO("%s  CubitPoint %p at [%f,%f,%f] (%f)\n", prefix,
00150             (void*)facet_point(), p.x(), p.y(), p.z(),
00151             (coordinates() - facet_point()->coordinates()).length());
00152   }
00153
00154   if( ent_set )
00155     sub_entity_set().print_debug_info( new_prefix );
00156   else
00157     print_partitioned_entity(new_prefix);
00158   delete [] new_prefix;
00159 }
00160
00161
00162 void PartitionPoint::append_simple_attribute_virt(const CubitSimpleAttrib& csa)
00163 { sub_entity_set().add_attribute( this, csa ); }
00164 void PartitionPoint::remove_simple_attribute_virt(const CubitSimpleAttrib& csa)
00165 { sub_entity_set().rem_attribute( this, csa ); }
00166 void PartitionPoint::remove_all_simple_attribute_virt()
00167 { sub_entity_set().rem_all_attrib( this ); }
00168 CubitStatus PartitionPoint::get_simple_attribute(DLIList<CubitSimpleAttrib>& list)
00169 {
00170   sub_entity_set().get_attributes( this, list );
00171   return CUBIT_SUCCESS;
00172 }
00173 CubitStatus PartitionPoint::get_simple_attribute(const CubitString& name,
00174                                        DLIList<CubitSimpleAttrib>& list)
00175 {
00176   sub_entity_set().get_attributes( this, name.c_str(), list );
00177   return CUBIT_SUCCESS;
00178 }
00179
00180 void PartitionPoint::reverse_sense()
00181   { }
00182
00183 void PartitionPoint::notify_split( FacetEntity* , FacetEntity* )
00184   { assert(0); }
00185
00186 void PartitionPoint::facet_point( CubitPointData* set )
00187 {
00188   if( facetPoint )
00189     TDVGFacetOwner::remove(facetPoint);
00190   facetPoint = set;
00191   if( set )
00192   {
00193     assert((set->coordinates() - coordinates()).length_squared()
00194                < GEOMETRY_RESABS*GEOMETRY_RESABS);
00195     TDVGFacetOwner::set(facetPoint,this);
00196   }
00197 }
00198
00199 CubitStatus PartitionPoint::save( CubitSimpleAttrib& attrib )
00200 {
00201   int id = sub_entity_set().get_id(this);
00202   if( id <= 0 )
00203     return CUBIT_FAILURE;
00204
00205   DLIList<CubitVector*> pt_list(1);
00206   pt_list.append( new CubitVector(coordinates()) );
00207
00208   return sub_entity_set().save_geometry( id, 0, &pt_list, 0, 0, 0, attrib );
00209 }
00210
00211 CubitBox PartitionPoint::bounding_box() const
00212   { return CubitBox(coordinates()); }
00213
00214 CubitStatus PartitionPoint::move_to_geometry( CubitVector& pos )
00215 {
00216   pos = coordinates();
00217   return CUBIT_SUCCESS;
00218 }
00219
00220 void PartitionPoint::transform( const CubitTransformMatrix& xform )
00221 {
00222   if( TBPoint* point = dynamic_cast<TBPoint*>(partitioned_entity()) )
00223     myPosition = point->coordinates();
00224   else
00225     myPosition = xform * myPosition;
00226
00227   if( facetPoint )
00228     facetPoint->set(myPosition);
00229 }
