cgma
multifaceted.cpp
00001 #include "AppUtil.hpp"
00002 #include "CGMApp.hpp"
00003 #include "GeometryQueryTool.hpp"
00004 #include "FacetModifyEngine.hpp"
00005 #include "FacetQueryEngine.hpp"
00006 #include "CubitFacetData.hpp"
00007 #include "CubitPointData.hpp"
00008 #include "CubitQuadFacetData.hpp"
00009 #include "DLIList.hpp"
00010 #include "Surface.hpp"
00011 #include "ShellSM.hpp"
00012 #include "Lump.hpp"
00013 #include "Body.hpp"
00014 #include "BodySM.hpp"
00015 #include "RefFace.hpp"
00016 #include "RefVertex.hpp"
00017
00018 #include <iostream>
00019
00020 // forward declare some functions used and defined later
00021 bool generateFacetModel(DLIList<TopologyBridge*>& model);
00022
00023 int main(int argc, char* argv[])
00024 {
00025   // Initialize CGM
00026   FacetQueryEngine* fqe = FacetQueryEngine::instance();
00027
00028   DLIList<TopologyBridge*> model;
00029   const char *arg = "multifaceted.stl";
00030   if (generateFacetModel(model))
00031     {
00032     ModelExportOptions opts;
00033     fqe->export_solid_model(
00034       model, arg, FACET_TYPE,
00035       CubitString(), opts);
00036     std::cout << "Wrote \"" << arg << "\"\n";
00037     }
00038
00039   return 0;
00040 }
00041
00042 bool generateFacetModel(
00043   DLIList<TopologyBridge*>& model)
00044 {
00045   FacetModifyEngine* fme = FacetModifyEngine::instance();
00046
00047   CubitStatus stat;
00048   int i;
00049
00050   DLIList <CubitPoint*> plist;
00051   double pts[4][3] = {
00052       { 0., 0., 0. },
00053       { 1., 0., 0. },
00054       { 1., 1., 0. },
00055       { 0., 1., 1. },
00056   };
00057   for (i = 0; i < (int)(sizeof(pts)/sizeof(pts[0])); ++i)
00058     {
00059     plist.append(new CubitPointData(pts[i][0], pts[i][1], pts[i][2]));
00060     }
00061
00062   // Build a tetrahedron, with 1 triangular facet per faceted-surface:
00063   int tconn[4][3] = {
00064       {0, 2, 1},
00065       {0, 3, 2},
00066       {0, 1, 3},
00067       {1, 2, 3}
00068   };
00069   DLIList<Surface*> all_surfs;
00070   DLIList<CubitFacet*> tflist;
00071   DLIList<CubitQuadFacet*> qflist;
00072   DLIList<CubitPoint*> facet_plist;
00073   for (i = 0; i < (int)(sizeof(tconn)/sizeof(tconn[0])); ++i)
00074     {
00075     std::cout << "Build faceted surface " << i << "\n";
00076     //DLIList<CubitFacet*> tflist;
00077     //DLIList<CubitQuadFacet*> qflist;
00078     //DLIList<CubitPoint*> facet_plist;
00079     // Fails with or without the next 3 lines:
00080     //facet_plist.append(plist[tconn[i][0]]);
00081     //facet_plist.append(plist[tconn[i][1]]);
00082     //facet_plist.append(plist[tconn[i][2]]);
00083     // Create a single facet for our faceted surface:
00084     tflist.append(
00085       new CubitFacetData(
00086         plist[tconn[i][0]], plist[tconn[i][1]], plist[tconn[i][2]]));
00087     }
00088   DLIList<Surface*> slist;
00089   // Attempt to build a faceted surface:
00090   stat = fme->build_facet_surface(
00091     qflist, tflist, facet_plist, -1., 0, false, false, slist);
00092   if (slist.size() <= 0 || stat != CUBIT_SUCCESS)
00093   {
00094     PRINT_ERROR("Make surface failed. \n");
00095     return false;
00096   }
00097   all_surfs += slist;
00098
00099   ShellSM* shell;
00100   stat = fme->make_facet_shell(all_surfs, shell);
00101   if (!shell || stat != CUBIT_SUCCESS)
00102   {
00103     PRINT_ERROR("Make shell failed. \n");
00104     return false;
00105   }
00106
00107   DLIList<ShellSM*> shlist;
00108   shlist.append(shell);
00109   Lump* lump;
00110   stat = fme->make_facet_lump(shlist, lump);
00111   if (!lump || stat != CUBIT_SUCCESS) return false;
00112
00113   DLIList<Lump*> llist;
00114   BodySM* bodySM;
00115   Body* body;
00116   llist.append(lump);
00117   stat = fme->make_facet_body(llist, bodySM);
00118   body = GeometryQueryTool::instance()->make_Body(bodySM);
00119   if (!body || stat != CUBIT_SUCCESS) return false;
00120
00121   model.append(bodySM);
00122   return true;
00123 }
00124
