- r -
- rand_excluded_middle()
: IAWeights
- randomize_weights_of_non_int()
: IARoundingNlp
, IASolverToolInt
- RapidSorting()
: EdgeMesher
- raw()
: Vec4
, Vec3
, Vec4
- raw_weight()
: IASolverBend
- rdtsc()
: RegisterCounter
- reactivate()
: Mesh
- Read()
: CMatrix< T >
- read_inputs_phase1()
: CoreGen
- read_inputs_phase2()
: CoreGen
- ReadAndCreate()
: AssyGen
- ReadCommonInp()
: AssyGen
- readFromFile()
: Mesh
- ReadInputPhase1()
: AssyGen
- ReadNextLine()
: CParser
- ReadPinCellData()
: AssyGen
, AssyMesher
- readTriEdges()
: MeshImporter
- readTriFaces()
: MeshImporter
- readTriNodes()
: MeshImporter
- reduce_boundary_vertex_degree()
: QuadCleanUp
- reduce_degree()
: QuadCleanUp
- reduce_internal_vertex_degree()
: QuadCleanUp
- ref()
: array< T >
- refine()
: CentroidRefine2D
- refine_3434_pattern()
: QuadCleanUp
- refine_3444_pattern()
: QuadCleanUp
- refine_3454_pattern()
: QuadCleanUp
- refine_boundary_triangle()
: Tri2Quads
- refine_bridges_face()
: QuadCleanUp
- refine_concave_quad15()
: Face
- refine_convex_quad15()
: Face
- refine_coremodel()
: CoreGen
- refine_degree3_faces()
: QuadCleanUp
- refine_quad()
: CentroidRefine2D
, Refine2D14
, CentroidRefine2D
, Refine2D14
- refine_quad14()
: Face
, Mesh
- refine_quad15()
: Face
, Mesh
- refine_quads14()
: Mesh
- refine_quads15()
: Mesh
- refine_restricted_node()
: QuadCleanUp
- refine_tri()
: CentroidRefine2D
, Refine2D14
, CentroidRefine2D
, Refine2D14
- refine_tri_edge()
: Mesh
- refineEdge0()
: ConsistencyRefine2D
- refineEdge1()
- refineEdge2()
- reflectEnt()
: FBiGeom
, iGeom
- register_mesh_op()
: MeshOpSet
- register_meshop()
: MKCore
- RegisterCounter()
: RegisterCounter
- RegisterMeshOp()
: RegisterMeshOp< TYPE >
- Release()
: CMatrix< T >
, CVector< T >
- release()
: AF2Algorithm
, AF2Binding
, ObjectPool< T >
- relinkAll()
: BinaryNode
, BinaryTree
- relinkChild()
: BinaryNode
- remesh()
: OneDefectPatch
, QuadRemeshTemplate
, TriRemeshTemplate
, PentaRemeshTemplate
, CircleRemeshTemplate
- remesh_3_sided_patch()
: OneDefectPatch
- remesh_4_sided_patch()
: OneDefectPatch
- remesh_5_sided_patch()
: OneDefectPatch
- remesh_defective_patches()
: QuadCleanUp
- remove()
: buffer< T >
, Mesh
, FaceClose
, Diamond
, Doublet
, Singlet
- remove_boundary_singlet_type1()
: QuadCleanUp
- remove_boundary_singlet_type2()
: QuadCleanUp
- remove_boundary_singlets()
: QuadCleanUp
- remove_boundary_singlets_once()
: QuadCleanUp
- remove_bridges()
: QuadCleanUp
- remove_bridges_in_layer()
: QuadCleanUp
- remove_bridges_once()
: QuadCleanUp
- remove_by_refinement()
: Singlet
- remove_by_swapping()
: Singlet
- remove_diamonds()
: QuadCleanUp
- remove_diamonds_in_layer()
: QuadCleanUp
- remove_diamonds_once()
: QuadCleanUp
- remove_doublets_once()
: QuadCleanUp
- remove_edges_attribute()
: Mesh
- remove_faces_attribute()
: Mesh
- remove_interior_doublet()
: QuadCleanUp
- remove_interior_doublets()
: QuadCleanUp
- remove_interior_doublets_once()
: QuadCleanUp
- remove_intersection_duplicates()
: EBMesher
- remove_it()
: MeshRefine2D
- remove_mesh_based_geometry()
: MKCore
- remove_meshop()
: ModelEnt
- remove_modelent()
: MeshOp
- remove_nodes_attribute()
: Mesh
- remove_pair()
: iRel
- remove_sizing_function()
: MKCore
- remove_tunnels()
: QuadCleanUp
- remove_unreferenced_nodes()
: Mesh
- removeAll()
: AttribRep
- removeAttribute()
: MeshEntity
, AttribRep
- removeChild()
: BinaryNode
- removeDuplicates()
: buffer< T >
- removeNode()
: BinaryTree
- removeRelation()
: MeshEntity
, RelationRep
, MeshEntity
- RemoveToken()
: CParser
- reorient_4_sided_loop()
: OneDefectPatch
, SurfPatch
- replaceNode()
: Face
- report()
: QuadCleanUp
- report_many_non_integer()
: IASolverEven
- report_one_constraint()
: IASolverEven
- report_one_non_integer()
: IASolverEven
- reserve()
: Mesh
, ObjectPool< T >
- reset()
: iMesh::EntArrIter
, iGeom::EntArrIter
, Bounds
, FBiGeom::FBEntIter
, buffer< T >
, iMesh::EntIter
, iGeom::EntIter
, RegisterCounter
, StopWatch
, FBiGeom::FBEntArrIter
- reset_sets()
: CopyMesh
, ExtrudeMesh
- resize()
: array< T >
, SimpleArray< T >
- reverse()
: Face
, Mesh
- right()
: Heap
- rmvArrTag()
: iGeom
, FBiGeom
- rmvEntArrFromSet()
: iGeom
, FBiGeom
- rmvEntFromSet()
: iGeom
, FBiGeom
- rmvEntSet()
: iGeom
, FBiGeom
- rmvEntSetTag()
: iGeom
, FBiGeom
- rmvPrntChld()
: iGeom
, FBiGeom
- rmvTag()
: FBiGeom
, iGeom
- rollback()
: SwapQuadEdge
, FaceClose
, OneDefectPatch
- root_node()
: MKGraph
- Rotate()
: Rotate
- Rotate_Assm()
: AssyGen
- rotate_chain()
: Mesh
- rotateEnt()
: FBiGeom
, iGeom
- round_solution()
: IASolverToolInt
, IASolverBend
- row()
: Matrix< R, C >
- run_wrapper()
: SmartLaplaceWrapper
, SweepWrapper
