MOAB: Mesh Oriented datABase
(version 5.4.0)
#include "moab/Core.hpp"
#include "moab/Range.hpp"
#include <cstring>
#include <cstdio>
#include <cstdlib>
#include <cassert>
#include <map>
#include <vector>
#include <algorithm>
#include <sstream>
#include "TestUtil.hpp"
Classes | |
struct | test_data |
Defines | |
#define | DECLARE_TEST(A) |
#define | CHECK(A) if( is_error( ( A ) ) ) return do_error( #A, __LINE__ ) |
Typedefs | |
typedef bool(* | test_ptr )() |
Functions | |
int | register_test (test_ptr test, const char *name) |
int | main (int argc, char *argv[]) |
static bool | do_error (const char *string, int line) |
static bool | is_error (bool b) |
static bool | is_error (ErrorCode b) |
bool | read_file (Interface *iface, const char *file) |
bool | write_and_read (Interface *iface1, Interface *iface2) |
bool | test_read_write_element (const double *coords, unsigned num_coords, const int *vtk_conn, const int *moab_conn, unsigned num_conn, unsigned num_elem, unsigned vtk_type, EntityType moab_type) |
bool | test_edge2 () |
bool | test_edge3 () |
bool | test_tri3 () |
bool | test_tri6 () |
bool | test_quad4 () |
bool | test_quad8 () |
bool | test_quad9 () |
bool | test_polygon () |
bool | test_polygon_mix () |
bool | test_polyhedra () |
bool | test_tet4 () |
bool | test_tet10 () |
bool | test_hex8 () |
bool | test_hex20 () |
bool | test_hex27 () |
bool | test_wedge () |
bool | test_wedge15 () |
bool | test_pyramid () |
bool | test_pyramid13 () |
bool | test_structured_2d (const char *file) |
bool | test_structured_3d (const char *file) |
bool | test_structured_points_2d () |
bool | test_free_vertices (const char *file) |
bool | test_free_nodes () |
bool | test_structured_grid_2d () |
bool | test_rectilinear_grid_2d () |
bool | test_structured_points_3d () |
bool | test_structured_grid_3d () |
bool | test_rectilinear_grid_3d () |
bool | test_scalar_attrib (const char *vtk_type, DataType mb_type, int count) |
bool | test_vector_attrib (const char *vtk_type, DataType mb_type) |
bool | test_tensor_attrib (const char *vtk_type, DataType mb_type) |
bool | test_scalar_attrib_1_bit () |
bool | test_scalar_attrib_1_uchar () |
bool | test_scalar_attrib_1_char () |
bool | test_scalar_attrib_1_ushort () |
bool | test_scalar_attrib_1_short () |
bool | test_scalar_attrib_1_uint () |
bool | test_scalar_attrib_1_int () |
bool | test_scalar_attrib_1_ulong () |
bool | test_scalar_attrib_1_long () |
bool | test_scalar_attrib_1_float () |
bool | test_scalar_attrib_1_double () |
bool | test_scalar_attrib_4_bit () |
bool | test_scalar_attrib_4_uchar () |
bool | test_scalar_attrib_4_char () |
bool | test_scalar_attrib_4_ushort () |
bool | test_scalar_attrib_4_short () |
bool | test_scalar_attrib_4_uint () |
bool | test_scalar_attrib_4_int () |
bool | test_scalar_attrib_4_ulong () |
bool | test_scalar_attrib_4_long () |
bool | test_scalar_attrib_4_float () |
bool | test_scalar_attrib_4_double () |
bool | test_vector_attrib_bit () |
bool | test_vector_attrib_uchar () |
bool | test_vector_attrib_char () |
bool | test_vector_attrib_ushort () |
bool | test_vector_attrib_short () |
bool | test_vector_attrib_uint () |
bool | test_vector_attrib_int () |
bool | test_vector_attrib_ulong () |
bool | test_vector_attrib_long () |
bool | test_vector_attrib_float () |
bool | test_vector_attrib_double () |
bool | test_tensor_attrib_uchar () |
bool | test_tensor_attrib_char () |
bool | test_tensor_attrib_ushort () |
bool | test_tensor_attrib_short () |
bool | test_tensor_attrib_uint () |
bool | test_tensor_attrib_int () |
bool | test_tensor_attrib_ulong () |
bool | test_tensor_attrib_long () |
bool | test_tensor_attrib_float () |
bool | test_tensor_attrib_double () |
bool | compare_connectivity (EntityType, const int *conn1, const int *conn2, unsigned len) |
bool | match_vertices_and_elements (Interface *iface, EntityType moab_type, unsigned num_vert, unsigned num_elem, unsigned vert_per_elem, const double *coords, const int *connectivity, EntityHandle *vert_handles, EntityHandle *elem_handles) |
bool | check_elements (Interface *iface, EntityType moab_type, unsigned num_elem, unsigned vert_per_elem, const double *coords, unsigned num_vert, const int *connectivity) |
void | write_data (char *file, size_t &len, DataType type, unsigned count, const int *vals) |
bool | check_tag_values (Interface *iface, DataType tag_type, int tag_length, int num_entities, const EntityHandle *entities, const int *values) |
bool | check_tag_values (Interface *iface, DataType type, int vals_per_ent) |
bool | check_tag_data (const char *file, DataType type, int vals_per_ent) |
bool | test_subset () |
bool | test_write_free_nodes () |
bool | test_unstructured_field () |
Variables | |
std::string | poly_example = "unittest/io/poly8-10.vtk" |
std::string | polyhedra_example = "unittest/io/polyhedra.vtk" |
size_t | num_tests = 0 |
test_data * | test_array = 0 |
const double | grid_3x3 [] |
const int | quad_structured_conn [] |
const double | grid_2x2x2 [] |
const int | hex_structured_conn [] |
const char | two_quad_mesh [] = "9 9\n" |
const double | two_quad_mesh_coords [] = { -1, 0, 0, 0, 0, 0, 1, 0, 0, -1, 1, 0, 0, 1, 0, 1, 1, 0 } |
const int | two_quad_mesh_conn [] = { 0, 1, 4, 3, 1, 2, 5, 4 } |
const int | vertex_values [] |
const int | element_values [] |
Definition at line 189 of file io/VtkTest.cpp.
Referenced by check_elements(), check_tag_data(), check_tag_values(), match_vertices_and_elements(), test_free_vertices(), test_hex8(), test_read_write_element(), test_structured_2d(), test_structured_3d(), test_subset(), test_unstructured_field(), test_write_free_nodes(), and write_and_read().
#define DECLARE_TEST | ( | A | ) |
bool test_##A(); \ int A##_reg_var = register_test( &test_##A, #A );
Definition at line 20 of file io/VtkTest.cpp.
typedef bool( * test_ptr)() |
Definition at line 24 of file io/VtkTest.cpp.
bool check_elements | ( | Interface * | iface, |
EntityType | moab_type, | ||
unsigned | num_elem, | ||
unsigned | vert_per_elem, | ||
const double * | coords, | ||
unsigned | num_vert, | ||
const int * | connectivity | ||
Definition at line 926 of file io/VtkTest.cpp.
References CHECK, and match_vertices_and_elements().
Referenced by test_read_write_element(), test_structured_2d(), and test_structured_3d().
{ std::vector< EntityHandle > junk1( num_vert ), junk2( num_elem ); bool rval = match_vertices_and_elements( iface, moab_type, num_vert, num_elem, vert_per_elem, coords, connectivity, &junk1[0], &junk2[0] ); CHECK( rval ); return true; }
bool check_tag_data | ( | const char * | file, |
DataType | type, | ||
int | vals_per_ent | ||
Definition at line 1151 of file io/VtkTest.cpp.
References CHECK, check_tag_values(), read_file(), and write_and_read().
Referenced by test_scalar_attrib(), test_tensor_attrib(), and test_vector_attrib().
{ bool bval; Core instance1, instance2; bval = read_file( &instance1, file ); CHECK( bval ); bval = check_tag_values( &instance1, type, vals_per_ent ); CHECK( bval ); bval = write_and_read( &instance1, &instance2 ); CHECK( bval ); bval = check_tag_values( &instance2, type, vals_per_ent ); CHECK( bval ); return true; }
bool check_tag_values | ( | Interface * | iface, |
DataType | tag_type, | ||
int | tag_length, | ||
int | num_entities, | ||
const EntityHandle * | entities, | ||
const int * | values | ||
Definition at line 1067 of file io/VtkTest.cpp.
References CHECK, ErrorCode, MB_TYPE_BIT, MB_TYPE_DOUBLE, MB_TYPE_INTEGER, MB_TYPE_OPAQUE, size, moab::Interface::tag_get_bytes(), moab::Interface::tag_get_data(), moab::Interface::tag_get_handle(), and moab::Interface::tag_get_length().
Referenced by check_tag_data(), and check_tag_values().
{ Tag tag; ErrorCode rval = iface->tag_get_handle( "data", tag_length, tag_type, tag ); CHECK( rval ); int size, *intptr; double* dblptr; rval = iface->tag_get_bytes( tag, size ); CHECK( rval ); std::vector< unsigned char > data( size * num_entities ); switch( tag_type ) { case MB_TYPE_BIT: rval = iface->tag_get_length( tag, size ); CHECK( rval ); CHECK( tag_length == size ); for( int i = 0; i < num_entities; ++i ) { unsigned char val; rval = iface->tag_get_data( tag, entities + i, 1, &val ); CHECK( rval ); for( int j = 0; j < tag_length; ++j ) { int bitval = !!( val & ( 1 << j ) ); int expval = abs( *values ) % 2; CHECK( bitval == expval ); ++values; } } break; case MB_TYPE_OPAQUE: rval = iface->tag_get_data( tag, entities, num_entities, &data[0] ); CHECK( rval ); CHECK( tag_length == size ); for( int i = 0; i < num_entities; ++i ) for( int j = 0; j < tag_length; ++j, ++values ) CHECK( (unsigned)( *values % 256 ) == data[i * tag_length + j] ); break; case MB_TYPE_INTEGER: rval = iface->tag_get_data( tag, entities, num_entities, &data[0] ); CHECK( rval ); CHECK( tag_length * sizeof( int ) == (unsigned)size ); intptr = reinterpret_cast< int* >( &data[0] ); for( int i = 0; i < num_entities; ++i ) for( int j = 0; j < tag_length; ++j, ++values ) CHECK( *values == intptr[i * tag_length + j] ); break; case MB_TYPE_DOUBLE: rval = iface->tag_get_data( tag, entities, num_entities, &data[0] ); CHECK( rval ); CHECK( tag_length * sizeof( double ) == (unsigned)size ); dblptr = reinterpret_cast< double* >( &data[0] ); for( int i = 0; i < num_entities; ++i ) for( int j = 0; j < tag_length; ++j, ++values ) CHECK( *values == dblptr[i * tag_length + j] ); break; default: assert( false ); return false; } return true; }
Definition at line 1137 of file io/VtkTest.cpp.
References CHECK, check_tag_values(), element_values, match_vertices_and_elements(), MBQUAD, two_quad_mesh_conn, two_quad_mesh_coords, and vertex_values.
{ EntityHandle vert_handles[6], elem_handles[2]; bool rval = match_vertices_and_elements( iface, MBQUAD, 6, 2, 4, two_quad_mesh_coords, two_quad_mesh_conn, vert_handles, elem_handles ); CHECK( rval ); rval = check_tag_values( iface, type, vals_per_ent, 6, vert_handles, vertex_values ); CHECK( rval ); rval = check_tag_values( iface, type, vals_per_ent, 2, elem_handles, element_values ); CHECK( rval ); return rval; }
bool compare_connectivity | ( | EntityType | , |
const int * | conn1, | ||
const int * | conn2, | ||
unsigned | len | ||
Definition at line 818 of file io/VtkTest.cpp.
Referenced by match_vertices_and_elements().
{ for( unsigned i = 0; i < len; ++i ) if( conn1[i] != conn2[i] ) return false; return true; }
static bool do_error | ( | const char * | string, |
int | line | ||
) | [static] |
Definition at line 191 of file io/VtkTest.cpp.
{ fprintf( stderr, "Check failed at line %d: %s\n", line, string ); return false; }
static bool is_error | ( | bool | b | ) | [inline, static] |
Definition at line 208 of file io/VtkTest.cpp.
References b, and MB_SUCCESS.
{ return MB_SUCCESS != b; }
int main | ( | int | argc, |
char * | argv[] | ||
Definition at line 135 of file io/VtkTest.cpp.
References test_data::name, num_tests, test_data::result, test, test_data::test, and test_array.
{ int* test_indices = (int*)malloc( sizeof( int ) * num_tests ); int test_count; // if no arguments, do all tests if( argc == 1 ) { for( unsigned i = 0; i < num_tests; ++i ) test_indices[i] = i; test_count = num_tests; } // otherwise run only specified tests else { test_count = 0; for( int i = 1; i < argc; ++i ) for( unsigned j = 0; j < num_tests; ++j ) if( !strcmp( test_array[j].name, argv[i] ) ) test_indices[test_count++] = j; } int fail_count = 0; for( int i = 0; i < test_count; ++i ) { test_data& test = test_array[test_indices[i]]; printf( "Testing %s...\n", test.name ); if( !( test.result = test.test() ) ) ++fail_count; } printf( "\n\n" ); if( fail_count ) { printf( "FAILED TESTS:\n" ); for( int i = 0; i < test_count; ++i ) { test_data& test = test_array[test_indices[i]]; if( !test.result ) printf( "\t%s\n", test.name ); } } if( test_count == 0 ) printf( "0 VTK tests run\n" ); else if( fail_count == 0 ) printf( "%d tests passed\n", test_count ); else printf( "%d of %d tests failed\n", fail_count, test_count ); printf( "\n" ); free( test_indices ); free( test_array ); return fail_count; }
bool match_vertices_and_elements | ( | Interface * | iface, |
const int * | connectivity, | ||
EntityHandle * | vert_handles, | ||
EntityHandle * | elem_handles | ||
Definition at line 825 of file io/VtkTest.cpp.
References moab::Range::begin(), CHECK, compare_connectivity(), moab::Range::end(), ErrorCode, moab::Interface::get_connectivity(), moab::Interface::get_coords(), moab::Interface::get_entities_by_type(), MBVERTEX, and moab::Range::size().
Referenced by check_elements(), check_tag_values(), and test_unstructured_field().
{ ErrorCode rval; // get vertices and check count Range verts; rval = iface->get_entities_by_type( 0, MBVERTEX, verts ); CHECK( rval ); CHECK( verts.size() == num_vert ); // get elements and check count Range elems; rval = iface->get_entities_by_type( 0, moab_type, elems ); CHECK( rval ); CHECK( elems.size() == num_elem ); // get vertex coordinates std::vector< EntityHandle > vert_array( num_vert ); std::copy( verts.begin(), verts.end(), vert_array.begin() ); std::vector< double > mb_coords( 3 * num_vert ); rval = iface->get_coords( &vert_array[0], num_vert, &mb_coords[0] ); CHECK( rval ); // compare vertex coordinates to construct map from // EntityHandle to index in input coordinate list std::map< EntityHandle, int > vert_map; std::vector< bool > seen( num_vert, false ); for( unsigned i = 0; i < num_vert; ++i ) { double* vert_coords = &mb_coords[3 * i]; bool found = false; for( unsigned j = 0; j < num_vert; ++j ) { const double* file_coords = &coords[3 * j]; double dsqr = 0; for( unsigned k = 0; k < 3; ++k ) { double diff = vert_coords[k] - file_coords[k]; dsqr += diff * diff; } if( dsqr < 1e-6 ) { CHECK( !seen[j] ); // duplicate vertex seen[j] = found = true; vert_map[vert_array[i]] = j; vert_handles[j] = vert_array[i]; break; } } CHECK( found ); // not found? } // check element connectivity seen.clear(); seen.resize( num_elem, false ); Range::iterator iter = elems.begin(); for( unsigned i = 0; i < num_elem; ++i ) { // get element connectivity EntityHandle elem = *iter; ++iter; std::vector< EntityHandle > elem_conn; rval = iface->get_connectivity( &elem, 1, elem_conn ); CHECK( rval ); CHECK( elem_conn.size() == vert_per_elem ); // convert to input vertex ordering std::vector< int > elem_conn2( vert_per_elem ); for( unsigned j = 0; j < vert_per_elem; ++j ) { std::map< EntityHandle, int >::iterator k = vert_map.find( elem_conn[j] ); CHECK( k != vert_map.end() ); elem_conn2[j] = k->second; } // search input list for matching element bool found = false; for( unsigned j = 0; j < num_elem; ++j ) { const int* conn_arr = connectivity + j * vert_per_elem; if( !seen[j] && compare_connectivity( moab_type, conn_arr, &elem_conn2[0], vert_per_elem ) ) { seen[j] = found = true; elem_handles[j] = elem; break; } } CHECK( found ); } return true; }
Definition at line 57 of file read_cgm_basic_test.cpp.
References CHECK_ERR, ErrorCode, and moab::Interface::load_file().
{ InitCGMA::initialize_cgma(); GeometryQueryTool::instance()->delete_geometry(); ErrorCode rval = moab->load_file( input_file );CHECK_ERR( rval ); }
int register_test | ( | test_ptr | test, |
const char * | name | ||
Definition at line 33 of file io/VtkTest.cpp.
{ test_data* new_test_array = (test_data*)realloc( test_array, sizeof( test_data ) * ( num_tests + 1 ) ); if( !new_test_array ) { fprintf( stderr, "VtkTest.cpp::regeister_test(): reallocation of test array failed\n" ); free( test_array ); test_array = NULL; num_tests = 0; return -1; } else test_array = new_test_array; test_array[num_tests].test = test; test_array[num_tests].name = name; test_array[num_tests].result = true; ++num_tests; return 0; }
bool test_edge2 | ( | ) |
Definition at line 225 of file io/VtkTest.cpp.
References conn, MBEDGE, and test_read_write_element().
{ const double coords[] = { 0, 0, 0, 1, 0, 0, 1, 1, 0, 0, 1, 0, 0, 0, 1 }; const int conn[] = { 0, 1, 1, 2, 2, 3, 3, 4, 0, 4 }; return test_read_write_element( coords, 5, conn, conn, 10, 5, 3, MBEDGE ); }
bool test_edge3 | ( | ) |
Definition at line 233 of file io/VtkTest.cpp.
{ const double coords[] = { -1, -1, 2, 1, -1, 2, 1, 1, 2, -1, 1, 2, 0.000, -0.707, 2, 0.707, 0.000, 2, 0.000, 0.707, 2, -0.707, 0.000, 2 }; const int conn[] = { 0, 1, 4, 1, 2, 5, 2, 3, 6, 3, 0, 7 }; return test_read_write_element( coords, 8, conn, conn, 12, 4, 21, MBEDGE ); }
bool test_free_nodes | ( | ) |
Definition at line 464 of file io/VtkTest.cpp.
References test_free_vertices().
{ const char file1[] = "# vtk DataFile Version 3.0\n" "MOAB Version 1.00\n" "ASCII\n" "DATASET UNSTRUCTURED_GRID\n" "POINTS 2 double\n" "10.0 0 0\n" "-10.0 0 0\n" "CELLS 2 4\n" "1 0\n" "1 1\n" "CELL_TYPES 2\n" "1\n" "1\n"; bool rval1 = test_free_vertices( file1 ); const char file2[] = "# vtk DataFile Version 3.0\n" "MOAB Version 1.00\n" "ASCII\n" "DATASET UNSTRUCTURED_GRID\n" "POINTS 5 double\n" "10.0 0 0\n" "-10.0 0 0\n" "-5 2. 2.\n" "-5 2. 0.\n" "-5 4. 2.\n" "CELLS 3 8\n" "1 0\n" "1 1\n" "3 2 3 4\n" "CELL_TYPES 3\n" "1\n" "1\n" "5\n"; bool rval2 = test_free_vertices( file2 ); return rval1 && rval2; }
bool test_free_vertices | ( | const char * | file | ) |
Definition at line 455 of file io/VtkTest.cpp.
References CHECK, and read_file().
Referenced by test_free_nodes().
bool test_hex20 | ( | ) |
Definition at line 373 of file io/VtkTest.cpp.
References grid_2x2x2, MBHEX, and test_read_write_element().
{ const int vtk_conn[] = { 0, 2, 8, 6, 18, 20, 26, 24, 1, 5, 7, 3, 19, 23, 25, 21, 9, 11, 17, 15 }; const int exo_conn[] = { 0, 2, 8, 6, 18, 20, 26, 24, 1, 5, 7, 3, 9, 11, 17, 15, 19, 23, 25, 21 }; return test_read_write_element( grid_2x2x2, 27, vtk_conn, exo_conn, 20, 1, 25, MBHEX ); }
bool test_hex27 | ( | ) |
Definition at line 381 of file io/VtkTest.cpp.
{ const int vtk_conn[] = { 0, 2, 8, 6, 18, 20, 26, 24, 1, 5, 7, 3, 19, 23, 25, 21, 9, 11, 17, 15, 10, 16, 14, 12, 4, 22, 13 }; const int moab_conn[] = { 0, 2, 8, 6, 18, 20, 26, 24, 1, 5, 7, 3, 9, 11, 17, 15, 19, 23, 25, 21, 14, 16, 12, 10, 4, 22, 13 }; return test_read_write_element( grid_2x2x2, 27, vtk_conn, moab_conn, 27, 1, 29, MBHEX ); }
bool test_hex8 | ( | ) |
Definition at line 356 of file io/VtkTest.cpp.
References CHECK, grid_2x2x2, hex_structured_conn, MBHEX, and test_read_write_element().
{ // check vtk hexes bool rval1 = test_read_write_element( grid_2x2x2, 27, hex_structured_conn, hex_structured_conn, 64, 8, 12, MBHEX ); CHECK( rval1 ); const int conn2[] = { 0, 1, 3, 4, 9, 10, 12, 13, 1, 2, 4, 5, 10, 11, 13, 14, 3, 4, 6, 7, 12, 13, 15, 16, 4, 5, 7, 8, 13, 14, 16, 17, 9, 10, 12, 13, 18, 19, 21, 22, 10, 11, 13, 14, 19, 20, 22, 23, 12, 13, 15, 16, 21, 22, 24, 25, 13, 14, 16, 17, 22, 23, 25, 26 }; // check with vtk voxels bool rval2 = test_read_write_element( grid_2x2x2, 27, conn2, hex_structured_conn, 64, 8, 11, MBHEX ); CHECK( rval2 ); return true; }
bool test_polygon | ( | ) |
Definition at line 295 of file io/VtkTest.cpp.
References conn, MBPOLYGON, and test_read_write_element().
{ const double coords[] = { 0, 0, 0, 0, 2, 0, 0, 4, 0, 0, 0, 4, 0, 2, 4, 0, 4, 4, 4, 0, 0, 4, 2, 0, 4, 4, 0, 2, 0, 0, 2, 4, 0, 0, 0, 2, 0, 4, 2 }; const int conn[] = { 0, 1, 2, 12, 5, 4, 3, 11, 2, 1, 0, 9, 6, 7, 8, 10 }; return test_read_write_element( coords, 13, conn, conn, 16, 2, 7, MBPOLYGON ); }
bool test_polygon_mix | ( | ) |
Definition at line 304 of file io/VtkTest.cpp.
References ErrorCode, moab::Interface::load_file(), mb, MB_SUCCESS, and poly_example.
{ // just read the polygon file with mixed sequences Core moab; Interface& mb = moab; ErrorCode rval = mb.load_file( poly_example.c_str() ); if( MB_SUCCESS != rval ) return false; return true; }
bool test_polyhedra | ( | ) |
Definition at line 315 of file io/VtkTest.cpp.
References ErrorCode, moab::Interface::get_entities_by_type(), moab::Interface::load_file(), mb, MB_SUCCESS, MBPOLYHEDRON, polyhedra_example, and moab::Range::size().
{ // just read the polyhedra file Core moab; Interface& mb = moab; ErrorCode rval = mb.load_file( polyhedra_example.c_str() ); if( MB_SUCCESS != rval ) return false; Range polyhedras; rval = mb.get_entities_by_type( 0, MBPOLYHEDRON, polyhedras ); if( MB_SUCCESS != rval ) return false; if( 10 != polyhedras.size() ) return false; return true; }
bool test_pyramid | ( | ) |
Definition at line 411 of file io/VtkTest.cpp.
References conn, MBPYRAMID, and test_read_write_element().
{ const double coords[] = { 1, -1, 0, 1, 1, 0, -1, 1, 0, -1, -1, 0, 0, 0, -1, 0, 0, 1 }; const int conn[] = { 0, 1, 2, 3, 5, 3, 2, 1, 0, 4 }; return test_read_write_element( coords, 6, conn, conn, 10, 2, 14, MBPYRAMID ); }
bool test_pyramid13 | ( | ) |
Definition at line 419 of file io/VtkTest.cpp.
{ const double coords[] = { 2, -2, 0, 2, 2, 0, -2, 2, 0, -2, -2, 0, 0, 0, -2, 0, 0, 2, 2, 0, 0, 0, 2, 0, -2, 0, 0, 0, -2, 0, 1, -1, -1, 1, 1, -1, -1, 1, -1, -1, -1, -1, 1, -1, 1, 1, 1, 1, -1, 1, 1, -1, -1, 1 }; const int conn[] = { 0, 1, 2, 3, 5, 6, 7, 8, 9, 14, 15, 16, 17, 3, 2, 1, 0, 4, 8, 7, 6, 9, 13, 12, 11, 10 }; return test_read_write_element( coords, 18, conn, conn, 26, 2, 27, MBPYRAMID ); }
bool test_quad4 | ( | ) |
Definition at line 264 of file io/VtkTest.cpp.
References grid_3x3, MBQUAD, quad_structured_conn, and test_read_write_element().
{ // test read as quads bool rval1 = test_read_write_element( grid_3x3, 16, quad_structured_conn, quad_structured_conn, 36, 9, 9, MBQUAD ); // test read as pixels const int conn2[] = { 0, 1, 4, 5, 1, 2, 5, 6, 2, 3, 6, 7, 4, 5, 8, 9, 5, 6, 9, 10, 6, 7, 10, 11, 8, 9, 12, 13, 9, 10, 13, 14, 10, 11, 14, 15 }; bool rval2 = test_read_write_element( grid_3x3, 16, conn2, quad_structured_conn, 36, 9, 8, MBQUAD ); return rval1 && rval2; }
bool test_quad8 | ( | ) |
Definition at line 277 of file io/VtkTest.cpp.
References conn, MBQUAD, and test_read_write_element().
{ const double coords[] = { 0, 0, 0, 0, 2, 0, 0, 4, 0, 0, 0, 4, 0, 2, 4, 0, 4, 4, 4, 0, 0, 4, 2, 0, 4, 4, 0, 2, 0, 0, 2, 4, 0, 0, 0, 2, 0, 4, 2 }; const int conn[] = { 0, 2, 5, 3, 1, 12, 4, 11, 2, 0, 6, 8, 1, 9, 7, 10 }; return test_read_write_element( coords, 13, conn, conn, 16, 2, 23, MBQUAD ); }
bool test_quad9 | ( | ) |
Definition at line 286 of file io/VtkTest.cpp.
{ const double coords[] = { 0, 0, 0, 0, 2, 0, 0, 4, 0, 0, 0, 4, 0, 2, 4, 0, 4, 4, 4, 0, 0, 4, 2, 0, 4, 4, 0, 2, 0, 0, 2, 2, 0, 2, 4, 0, 0, 0, 2, 0, 2, 2, 0, 4, 2 }; const int conn[] = { 0, 2, 5, 3, 1, 14, 4, 12, 12, 2, 0, 6, 8, 1, 9, 7, 11, 10 }; return test_read_write_element( coords, 15, conn, conn, 18, 2, 28, MBQUAD ); }
bool test_read_write_element | ( | const double * | coords, |
unsigned | num_coords, | ||
const int * | vtk_conn, | ||
const int * | moab_conn, | ||
unsigned | num_conn, | ||
unsigned | vtk_type, | ||
EntityType | moab_type | ||
Definition at line 941 of file io/VtkTest.cpp.
References CHECK, check_elements(), read_file(), and write_and_read().
Referenced by test_edge2(), test_edge3(), test_hex20(), test_hex27(), test_hex8(), test_polygon(), test_pyramid(), test_pyramid13(), test_quad4(), test_quad8(), test_quad9(), test_tet10(), test_tet4(), test_tri3(), test_tri6(), test_wedge(), and test_wedge15().
{ // construct VTK file char file[4096] = "# vtk DataFile Version 3.0\n" "MOAB Version 1.00\n" "ASCII\n" "DATASET UNSTRUCTURED_GRID\n"; size_t len = strlen( file ); len += sprintf( file + len, "POINTS %u double\n", num_verts ); for( unsigned i = 0; i < num_verts; ++i ) len += sprintf( file + len, "%f %f %f\n", coords[3 * i], coords[3 * i + 1], coords[3 * i + 2] ); len += sprintf( file + len, "CELLS %u %u\n", num_elem, num_conn + num_elem ); assert( num_conn % num_elem == 0 ); unsigned conn_len = num_conn / num_elem; for( unsigned i = 0; i < num_elem; ++i ) { len += sprintf( file + len, "%u", conn_len ); for( unsigned j = 0; j < conn_len; ++j ) len += sprintf( file + len, " %u", vtk_conn[conn_len * i + j] ); len += sprintf( file + len, "\n" ); } len += sprintf( file + len, "CELL_TYPES %u\n", num_elem ); for( unsigned i = 0; i < num_elem; ++i ) len += sprintf( file + len, "%u\n", vtk_type ); // read VTK file and check results Core instance1, instance2; bool bval = read_file( &instance1, file ); CHECK( bval ); bval = check_elements( &instance1, moab_type, num_elem, conn_len, coords, num_verts, moab_conn ); CHECK( bval ); // write, re-read, and check results bval = write_and_read( &instance1, &instance2 ); CHECK( bval ); bval = check_elements( &instance2, moab_type, num_elem, conn_len, coords, num_verts, moab_conn ); CHECK( bval ); return true; }
bool test_rectilinear_grid_2d | ( | ) |
Definition at line 519 of file io/VtkTest.cpp.
References test_structured_2d().
{ const char file[] = "# vtk DataFile Version 3.0\n" "MOAB Version 1.00\n" "ASCII\n" "DATASET RECTILINEAR_GRID\n" "DIMENSIONS 4 4 1\n" "X_COORDINATES 4 float 0 1 2 3\n" "Y_COORDINATES 4 float 0 1 2 3\n" "Z_COORDINATES 1 float 0\n"; return test_structured_2d( file ); }
bool test_rectilinear_grid_3d | ( | ) |
Definition at line 561 of file io/VtkTest.cpp.
References test_structured_3d().
{ const char file[] = "# vtk DataFile Version 3.0\n" "MOAB Version 1.00\n" "ASCII\n" "DATASET RECTILINEAR_GRID\n" "DIMENSIONS 3 3 3\n" "X_COORDINATES 3 float 0 1 2\n" "Y_COORDINATES 3 float 0 1 2\n" "Z_COORDINATES 3 float 0 1 2\n"; return test_structured_3d( file ); }
bool test_scalar_attrib | ( | const char * | vtk_type, |
DataType | mb_type, | ||
int | count | ||
Definition at line 1167 of file io/VtkTest.cpp.
References check_tag_data(), element_values, two_quad_mesh, vertex_values, and write_data().
Referenced by test_scalar_attrib_1_bit(), test_scalar_attrib_1_char(), test_scalar_attrib_1_double(), test_scalar_attrib_1_float(), test_scalar_attrib_1_int(), test_scalar_attrib_1_long(), test_scalar_attrib_1_short(), test_scalar_attrib_1_uchar(), test_scalar_attrib_1_uint(), test_scalar_attrib_1_ulong(), test_scalar_attrib_1_ushort(), test_scalar_attrib_4_bit(), test_scalar_attrib_4_char(), test_scalar_attrib_4_double(), test_scalar_attrib_4_float(), test_scalar_attrib_4_int(), test_scalar_attrib_4_long(), test_scalar_attrib_4_short(), test_scalar_attrib_4_uchar(), test_scalar_attrib_4_uint(), test_scalar_attrib_4_ulong(), and test_scalar_attrib_4_ushort().
{ char file[4096]; strcpy( file, two_quad_mesh ); size_t len = strlen( file ); len += sprintf( file + len, "POINT_DATA 6\n" ); len += sprintf( file + len, "SCALARS data %s %d\n", vtk_type, count ); len += sprintf( file + len, "LOOKUP_TABLE default\n" ); write_data( file, len, mb_type, 6 * count, vertex_values ); len += sprintf( file + len, "CELL_DATA 2\n" ); len += sprintf( file + len, "SCALARS data %s %d\n", vtk_type, count ); len += sprintf( file + len, "LOOKUP_TABLE default\n" ); write_data( file, len, mb_type, 2 * count, element_values ); return check_tag_data( file, mb_type, count ); }
bool test_scalar_attrib_1_bit | ( | ) |
Definition at line 579 of file io/VtkTest.cpp.
References MB_TYPE_BIT, and test_scalar_attrib().
{ return test_scalar_attrib( "bit", MB_TYPE_BIT, 1 ); }
bool test_scalar_attrib_1_char | ( | ) |
Definition at line 589 of file io/VtkTest.cpp.
References MB_TYPE_INTEGER, and test_scalar_attrib().
{ return test_scalar_attrib( "char", MB_TYPE_INTEGER, 1 ); }
bool test_scalar_attrib_1_double | ( | ) |
Definition at line 629 of file io/VtkTest.cpp.
References MB_TYPE_DOUBLE, and test_scalar_attrib().
{ return test_scalar_attrib( "double", MB_TYPE_DOUBLE, 1 ); }
bool test_scalar_attrib_1_float | ( | ) |
Definition at line 624 of file io/VtkTest.cpp.
{ return test_scalar_attrib( "float", MB_TYPE_DOUBLE, 1 ); }
bool test_scalar_attrib_1_int | ( | ) |
Definition at line 609 of file io/VtkTest.cpp.
{ return test_scalar_attrib( "int", MB_TYPE_INTEGER, 1 ); }
bool test_scalar_attrib_1_long | ( | ) |
Definition at line 619 of file io/VtkTest.cpp.
{ return test_scalar_attrib( "long", MB_TYPE_INTEGER, 1 ); }
bool test_scalar_attrib_1_short | ( | ) |
Definition at line 599 of file io/VtkTest.cpp.
{ return test_scalar_attrib( "short", MB_TYPE_INTEGER, 1 ); }
bool test_scalar_attrib_1_uchar | ( | ) |
Definition at line 584 of file io/VtkTest.cpp.
{ return test_scalar_attrib( "unsigned_char", MB_TYPE_INTEGER, 1 ); }
bool test_scalar_attrib_1_uint | ( | ) |
Definition at line 604 of file io/VtkTest.cpp.
{ return test_scalar_attrib( "unsigned_int", MB_TYPE_INTEGER, 1 ); }
bool test_scalar_attrib_1_ulong | ( | ) |
Definition at line 614 of file io/VtkTest.cpp.
{ return test_scalar_attrib( "unsigned_long", MB_TYPE_INTEGER, 1 ); }
bool test_scalar_attrib_1_ushort | ( | ) |
Definition at line 594 of file io/VtkTest.cpp.
{ return test_scalar_attrib( "unsigned_short", MB_TYPE_INTEGER, 1 ); }
bool test_scalar_attrib_4_bit | ( | ) |
Definition at line 634 of file io/VtkTest.cpp.
{ return test_scalar_attrib( "bit", MB_TYPE_BIT, 4 ); }
bool test_scalar_attrib_4_char | ( | ) |
Definition at line 644 of file io/VtkTest.cpp.
{ return test_scalar_attrib( "char", MB_TYPE_INTEGER, 4 ); }
bool test_scalar_attrib_4_double | ( | ) |
Definition at line 684 of file io/VtkTest.cpp.
{ return test_scalar_attrib( "double", MB_TYPE_DOUBLE, 4 ); }
bool test_scalar_attrib_4_float | ( | ) |
Definition at line 679 of file io/VtkTest.cpp.
{ return test_scalar_attrib( "float", MB_TYPE_DOUBLE, 4 ); }
bool test_scalar_attrib_4_int | ( | ) |
Definition at line 664 of file io/VtkTest.cpp.
{ return test_scalar_attrib( "int", MB_TYPE_INTEGER, 4 ); }
bool test_scalar_attrib_4_long | ( | ) |
Definition at line 674 of file io/VtkTest.cpp.
{ return test_scalar_attrib( "long", MB_TYPE_INTEGER, 4 ); }
bool test_scalar_attrib_4_short | ( | ) |
Definition at line 654 of file io/VtkTest.cpp.
{ return test_scalar_attrib( "short", MB_TYPE_INTEGER, 4 ); }
bool test_scalar_attrib_4_uchar | ( | ) |
Definition at line 639 of file io/VtkTest.cpp.
{ return test_scalar_attrib( "unsigned_char", MB_TYPE_INTEGER, 4 ); }
bool test_scalar_attrib_4_uint | ( | ) |
Definition at line 659 of file io/VtkTest.cpp.
{ return test_scalar_attrib( "unsigned_int", MB_TYPE_INTEGER, 4 ); }
bool test_scalar_attrib_4_ulong | ( | ) |
Definition at line 669 of file io/VtkTest.cpp.
{ return test_scalar_attrib( "unsigned_long", MB_TYPE_INTEGER, 4 ); }
bool test_scalar_attrib_4_ushort | ( | ) |
Definition at line 649 of file io/VtkTest.cpp.
{ return test_scalar_attrib( "unsigned_short", MB_TYPE_INTEGER, 4 ); }
bool test_structured_2d | ( | const char * | file | ) |
Definition at line 993 of file io/VtkTest.cpp.
References CHECK, check_elements(), grid_3x3, MBQUAD, quad_structured_conn, and read_file().
Referenced by test_rectilinear_grid_2d(), test_structured_grid_2d(), and test_structured_points_2d().
{ // read VTK file and check results Core instance; bool bval = read_file( &instance, file ); CHECK( bval ); bval = check_elements( &instance, MBQUAD, 9, 4, grid_3x3, 16, quad_structured_conn ); CHECK( bval ); return true; }
bool test_structured_3d | ( | const char * | file | ) |
Definition at line 1005 of file io/VtkTest.cpp.
References CHECK, check_elements(), grid_2x2x2, hex_structured_conn, MBHEX, and read_file().
Referenced by test_rectilinear_grid_3d(), test_structured_grid_3d(), and test_structured_points_3d().
{ // read VTK file and check results Core instance; bool bval = read_file( &instance, file ); CHECK( bval ); bval = check_elements( &instance, MBHEX, 8, 8, grid_2x2x2, 27, hex_structured_conn ); CHECK( bval ); return true; }
bool test_structured_grid_2d | ( | ) |
Definition at line 504 of file io/VtkTest.cpp.
References grid_3x3, and test_structured_2d().
{ char file[4096] = "# vtk DataFile Version 3.0\n" "MOAB Version 1.00\n" "ASCII\n" "DATASET STRUCTURED_GRID\n" "DIMENSIONS 4 4 1\n" "POINTS 16 double\n"; int len = strlen( file ); for( unsigned i = 0; i < 16; ++i ) len += sprintf( file + len, "%f %f %f\n", grid_3x3[3 * i], grid_3x3[3 * i + 1], grid_3x3[3 * i + 2] ); return test_structured_2d( file ); }
bool test_structured_grid_3d | ( | ) |
Definition at line 545 of file io/VtkTest.cpp.
References grid_2x2x2, and test_structured_3d().
{ char file[4096] = "# vtk DataFile Version 3.0\n" "MOAB Version 1.00\n" "ASCII\n" "DATASET STRUCTURED_GRID\n" "DIMENSIONS 3 3 3\n" "POINTS 27 double\n"; int len = strlen( file ); for( unsigned i = 0; i < 27; ++i ) len += sprintf( file + len, "%f %f %f\n", grid_2x2x2[3 * i], grid_2x2x2[3 * i + 1], grid_2x2x2[3 * i + 2] ); return test_structured_3d( file ); }
bool test_structured_points_2d | ( | ) |
Definition at line 432 of file io/VtkTest.cpp.
{ const char file[] = "# vtk DataFile Version 3.0\n" "MOAB Version 1.00\n" "ASCII\n" "DATASET STRUCTURED_POINTS\n" "DIMENSIONS 4 4 1\n" "ORIGIN 0 0 0\n" "SPACING 1 1 1\n"; bool rval1 = test_structured_2d( file ); // test again w/ old 1.0 ASPECT_RATIO keyword const char file2[] = "# vtk DataFile Version 3.0\n" "MOAB Version 1.00\n" "ASCII\n" "DATASET STRUCTURED_POINTS\n" "DIMENSIONS 4 4 1\n" "ORIGIN 0 0 0\n" "ASPECT_RATIO 1 1 1\n"; bool rval2 = test_structured_2d( file2 ); return rval1 && rval2; }
bool test_structured_points_3d | ( | ) |
Definition at line 533 of file io/VtkTest.cpp.
{ const char file[] = "# vtk DataFile Version 3.0\n" "MOAB Version 1.00\n" "ASCII\n" "DATASET STRUCTURED_POINTS\n" "DIMENSIONS 3 3 3\n" "ORIGIN 0 0 0\n" "SPACING 1 1 1\n"; return test_structured_3d( file ); }
bool test_subset | ( | ) |
Definition at line 1214 of file io/VtkTest.cpp.
References moab::Interface::add_child_meshset(), moab::Interface::add_entities(), CHECK, conn, moab::Interface::create_element(), moab::Interface::create_meshset(), moab::Interface::create_vertex(), moab::Interface::delete_mesh(), ErrorCode, moab::Interface::get_adjacencies(), moab::Interface::get_coords(), moab::Interface::get_entities_by_type(), moab::Interface::load_mesh(), MB_SUCCESS, MBQUAD, MBVERTEX, moab::Range::size(), moab::subtract(), moab::Interface::UNION, and moab::Interface::write_mesh().
{ Core moab_inst; Interface& moab = moab_inst; ErrorCode rval; // create 9 nodes in grid pattern EntityHandle verts[9]; const double coords[][3] = { { 0, 0, 0 }, { 1, 0, 0 }, { 2, 0, 0 }, { 0, 1, 0 }, { 1, 1, 0 }, { 2, 1, 0 }, { 0, 2, 0 }, { 1, 2, 0 }, { 2, 2, 0 } }; for( unsigned i = 0; i < 9; ++i ) { rval = moab.create_vertex( coords[i], verts[i] ); assert( MB_SUCCESS == rval ); } // create 4 quad elements in grid pattern const int conn[][4] = { { 0, 1, 4, 3 }, { 1, 2, 5, 4 }, { 3, 4, 7, 6 }, { 4, 5, 8, 7 } }; EntityHandle econn[4], elems[4]; for( unsigned i = 0; i < 4; ++i ) { for( unsigned j = 0; j < 4; ++j ) econn[j] = verts[conn[i][j]]; rval = moab.create_element( MBQUAD, econn, 4, elems[i] ); assert( MB_SUCCESS == rval ); } // create 3 meshsets EntityHandle sets[3]; for( unsigned i = 0; i < 3; ++i ) { rval = moab.create_meshset( 0, sets[i] ); assert( MB_SUCCESS == rval ); } // add element 3 to set 0 rval = moab.add_entities( sets[0], elems + 3, 1 ); assert( MB_SUCCESS == rval ); // add node 2 to set 1 rval = moab.add_entities( sets[1], verts + 2, 1 ); assert( MB_SUCCESS == rval ); // add element 2 and 3 to set 2 rval = moab.add_entities( sets[2], elems + 2, 2 ); assert( MB_SUCCESS == rval ); // make set 2 a child of set 1 rval = moab.add_child_meshset( sets[1], sets[2] ); assert( MB_SUCCESS == rval ); // put set 1 in set 0 rval = moab.add_entities( sets[0], sets + 1, 1 ); assert( MB_SUCCESS == rval ); // write sets[0] to vtk file rval = moab.write_mesh( "tmp_file.vtk", sets, 1 ); CHECK( rval ); // read data back in moab.delete_mesh(); rval = moab.load_mesh( "tmp_file.vtk" ); remove( "tmp_file.vtk" ); CHECK( rval ); // writer should have written all three sets, // so the resulting mesh should be elems[2], elems[3], // and verts[2] Range new_elems, new_verts; rval = moab.get_entities_by_type( 0, MBQUAD, new_elems ); CHECK( rval ); CHECK( new_elems.size() == 2 ); rval = moab.get_entities_by_type( 0, MBVERTEX, new_verts ); CHECK( rval ); CHECK( new_verts.size() == 7 ); // vertex not in element closure should have coords of 2,0,0 Range elem_verts; rval = moab.get_adjacencies( new_elems, 0, false, elem_verts, Interface::UNION ); CHECK( rval ); CHECK( elem_verts.size() == 6 ); Range free_verts( subtract( new_verts, elem_verts ) ); CHECK( free_verts.size() == 1 ); double vcoords[3]; rval = moab.get_coords( free_verts, vcoords ); CHECK( vcoords[0] == 2 ); CHECK( vcoords[1] == 0 ); CHECK( vcoords[2] == 0 ); return true; }
bool test_tensor_attrib | ( | const char * | vtk_type, |
DataType | mb_type | ||
Definition at line 1199 of file io/VtkTest.cpp.
Referenced by test_tensor_attrib_char(), test_tensor_attrib_double(), test_tensor_attrib_float(), test_tensor_attrib_int(), test_tensor_attrib_long(), test_tensor_attrib_short(), test_tensor_attrib_uchar(), test_tensor_attrib_uint(), test_tensor_attrib_ulong(), and test_tensor_attrib_ushort().
{ char file[4096]; strcpy( file, two_quad_mesh ); size_t len = strlen( file ); len += sprintf( file + len, "POINT_DATA 6\n" ); len += sprintf( file + len, "TENSORS data %s\n", vtk_type ); write_data( file, len, mb_type, 6 * 9, vertex_values ); len += sprintf( file + len, "CELL_DATA 2\n" ); len += sprintf( file + len, "TENSORS data %s\n", vtk_type ); write_data( file, len, mb_type, 2 * 9, element_values ); return check_tag_data( file, mb_type, 9 ); }
bool test_tensor_attrib_char | ( | ) |
Definition at line 749 of file io/VtkTest.cpp.
References MB_TYPE_INTEGER, and test_tensor_attrib().
{ return test_tensor_attrib( "char", MB_TYPE_INTEGER ); }
bool test_tensor_attrib_double | ( | ) |
Definition at line 789 of file io/VtkTest.cpp.
References MB_TYPE_DOUBLE, and test_tensor_attrib().
{ return test_tensor_attrib( "double", MB_TYPE_DOUBLE ); }
bool test_tensor_attrib_float | ( | ) |
Definition at line 784 of file io/VtkTest.cpp.
{ return test_tensor_attrib( "float", MB_TYPE_DOUBLE ); }
bool test_tensor_attrib_int | ( | ) |
Definition at line 769 of file io/VtkTest.cpp.
{ return test_tensor_attrib( "int", MB_TYPE_INTEGER ); }
bool test_tensor_attrib_long | ( | ) |
Definition at line 779 of file io/VtkTest.cpp.
{ return test_tensor_attrib( "long", MB_TYPE_INTEGER ); }
bool test_tensor_attrib_short | ( | ) |
Definition at line 759 of file io/VtkTest.cpp.
{ return test_tensor_attrib( "short", MB_TYPE_INTEGER ); }
bool test_tensor_attrib_uchar | ( | ) |
Definition at line 744 of file io/VtkTest.cpp.
{ return test_tensor_attrib( "unsigned_char", MB_TYPE_INTEGER ); }
bool test_tensor_attrib_uint | ( | ) |
Definition at line 764 of file io/VtkTest.cpp.
{ return test_tensor_attrib( "unsigned_int", MB_TYPE_INTEGER ); }
bool test_tensor_attrib_ulong | ( | ) |
Definition at line 774 of file io/VtkTest.cpp.
{ return test_tensor_attrib( "unsigned_long", MB_TYPE_INTEGER ); }
bool test_tensor_attrib_ushort | ( | ) |
Definition at line 754 of file io/VtkTest.cpp.
{ return test_tensor_attrib( "unsigned_short", MB_TYPE_INTEGER ); }
bool test_tet10 | ( | ) |
Definition at line 338 of file io/VtkTest.cpp.
References conn, MBTET, and test_read_write_element().
{ const double coords[] = { 4, 0, 0, 0, 2, 0, 0, -2, 0, 0, 0, -2, 0, 0, 2, 0, 1, 1, 2, 0, 1, 0, -1, 1, 0, 0, 0, 2, 1, 0, 2, -1, 0, 2, 0, -1, 0, -1, -1, 0, 1, -1 }; const int conn[] = { 0, 1, 2, 4, 9, 8, 10, 6, 5, 7, 2, 1, 0, 3, 8, 9, 10, 12, 13, 11 }; return test_read_write_element( coords, 14, conn, conn, 20, 2, 24, MBTET ); }
bool test_tet4 | ( | ) |
Definition at line 330 of file io/VtkTest.cpp.
{ const double coords[] = { 1, -1, 0, 1, 1, 0, -1, 1, 0, -1, -1, 0, 0, 0, -1, 0, 0, 1 }; const int conn[] = { 0, 1, 3, 5, 1, 2, 3, 5, 0, 1, 4, 3, 1, 2, 4, 3 }; return test_read_write_element( coords, 6, conn, conn, 16, 4, 10, MBTET ); }
bool test_tri3 | ( | ) |
Definition at line 242 of file io/VtkTest.cpp.
References conn, MBTRI, and test_read_write_element().
{ const double coords[] = { 0, 0, 0, 5, 0, 0, 0, 5, 0, -5, 0, 0, 0, -5, 0 }; const int conn[] = { 0, 1, 2, 0, 2, 3, 0, 3, 4, 0, 4, 1 }; return test_read_write_element( coords, 5, conn, conn, 12, 4, 5, MBTRI ); }
bool test_tri6 | ( | ) |
Definition at line 250 of file io/VtkTest.cpp.
{ const double coords[] = { 0, 2, 0, 0, 0, 2, 0, -2, 0, 0, 0, -2, 0, 1, 1, 0, -1, 1, 0, -1, -1, 0, 1, -1, 0, 0, 0 }; const int conn[] = { 0, 1, 3, 4, 5, 8, 1, 2, 3, 6, 7, 8 }; return test_read_write_element( coords, 9, conn, conn, 12, 2, 22, MBTRI ); }
bool test_unstructured_field | ( | ) |
Definition at line 1355 of file io/VtkTest.cpp.
References CHECK, match_vertices_and_elements(), mb, MBQUAD, read_file(), two_quad_mesh, two_quad_mesh_conn, and two_quad_mesh_coords.
{ // Use existing file defined in 'two_quad_mesh', but // insert a few field data blocks std::istringstream base_data( two_quad_mesh ); std::ostringstream file_data; std::string line; while( getline( base_data, line ) ) { if( 0 == line.find( "POINTS" ) ) { file_data << "FIELD FieldData 2" << std::endl << "avtOriginalBounds 1 6 float" << std::endl << "-10 10 -10 10 -10 10 " << std::endl << "TIME 1 1 double" << std::endl << "10.543" << std::endl; } else if( 0 == line.find( "CELLS" ) ) { file_data << "FIELD more_data 2" << std::endl << "first_array 3 2 int" << std::endl << "0 1 2" << std::endl << "3 4 5" << std::endl << "second_array 4 3 bit" << std::endl << "0 0 0 0" << std::endl << "1 1 1 1" << std::endl << "1 0 1 0" << std::endl; } file_data << line << std::endl; } Core core; Interface& mb = core; bool rval = read_file( &mb, file_data.str().c_str() ); CHECK( rval ); EntityHandle vert_handles[6], elem_handles[2]; rval = match_vertices_and_elements( &mb, MBQUAD, 6, 2, 4, two_quad_mesh_coords, two_quad_mesh_conn, vert_handles, elem_handles ); CHECK( rval ); return true; }
bool test_vector_attrib | ( | const char * | vtk_type, |
Definition at line 1184 of file io/VtkTest.cpp.
Referenced by test_vector_attrib_bit(), test_vector_attrib_char(), test_vector_attrib_double(), test_vector_attrib_float(), test_vector_attrib_int(), test_vector_attrib_long(), test_vector_attrib_short(), test_vector_attrib_uchar(), test_vector_attrib_uint(), test_vector_attrib_ulong(), and test_vector_attrib_ushort().
{ char file[4096]; strcpy( file, two_quad_mesh ); size_t len = strlen( file ); len += sprintf( file + len, "POINT_DATA 6\n" ); len += sprintf( file + len, "VECTORS data %s\n", vtk_type ); write_data( file, len, mb_type, 6 * 3, vertex_values ); len += sprintf( file + len, "CELL_DATA 2\n" ); len += sprintf( file + len, "VECTORS data %s\n", vtk_type ); write_data( file, len, mb_type, 2 * 3, element_values ); return check_tag_data( file, mb_type, 3 ); }
bool test_vector_attrib_bit | ( | ) |
Definition at line 689 of file io/VtkTest.cpp.
References MB_TYPE_BIT, and test_vector_attrib().
{ return test_vector_attrib( "bit", MB_TYPE_BIT ); }
bool test_vector_attrib_char | ( | ) |
Definition at line 699 of file io/VtkTest.cpp.
References MB_TYPE_INTEGER, and test_vector_attrib().
{ return test_vector_attrib( "char", MB_TYPE_INTEGER ); }
bool test_vector_attrib_double | ( | ) |
Definition at line 739 of file io/VtkTest.cpp.
References MB_TYPE_DOUBLE, and test_vector_attrib().
{ return test_vector_attrib( "double", MB_TYPE_DOUBLE ); }
bool test_vector_attrib_float | ( | ) |
Definition at line 734 of file io/VtkTest.cpp.
{ return test_vector_attrib( "float", MB_TYPE_DOUBLE ); }
bool test_vector_attrib_int | ( | ) |
Definition at line 719 of file io/VtkTest.cpp.
{ return test_vector_attrib( "int", MB_TYPE_INTEGER ); }
bool test_vector_attrib_long | ( | ) |
Definition at line 729 of file io/VtkTest.cpp.
{ return test_vector_attrib( "long", MB_TYPE_INTEGER ); }
bool test_vector_attrib_short | ( | ) |
Definition at line 709 of file io/VtkTest.cpp.
{ return test_vector_attrib( "short", MB_TYPE_INTEGER ); }
bool test_vector_attrib_uchar | ( | ) |
Definition at line 694 of file io/VtkTest.cpp.
{ return test_vector_attrib( "unsigned_char", MB_TYPE_INTEGER ); }
bool test_vector_attrib_uint | ( | ) |
Definition at line 714 of file io/VtkTest.cpp.
{ return test_vector_attrib( "unsigned_int", MB_TYPE_INTEGER ); }
bool test_vector_attrib_ulong | ( | ) |
Definition at line 724 of file io/VtkTest.cpp.
{ return test_vector_attrib( "unsigned_long", MB_TYPE_INTEGER ); }
bool test_vector_attrib_ushort | ( | ) |
Definition at line 704 of file io/VtkTest.cpp.
{ return test_vector_attrib( "unsigned_short", MB_TYPE_INTEGER ); }
bool test_wedge | ( | ) |
Definition at line 391 of file io/VtkTest.cpp.
References MBPRISM, and test_read_write_element().
{ const double coords[] = { 1, 0, 0, 1, 1, 0, 0, 1, 0, 0, 0, 0, 1, 0, 1, 1, 1, 1, 0, 1, 1, 0, 0, 1 }; const int exo_conn[] = { 0, 1, 3, 4, 5, 7, 1, 2, 3, 5, 6, 7 }; const int vtk_conn[] = { 0, 3, 1, 4, 7, 5, 1, 3, 2, 5, 7, 6 }; return test_read_write_element( coords, 8, vtk_conn, exo_conn, 12, 2, 13, MBPRISM ); }
bool test_wedge15 | ( | ) |
Definition at line 399 of file io/VtkTest.cpp.
{ const double coords[] = { 2, 0, 0, 2, 2, 0, 0, 2, 0, 0, 0, 0, 2, 0, 2, 2, 2, 2, 0, 2, 2, 0, 0, 2, 2, 1, 0, 1, 2, 0, 0, 1, 0, 1, 0, 0, 1, 1, 0, 2, 1, 2, 1, 2, 2, 0, 1, 2, 1, 0, 2, 1, 1, 2, 2, 0, 1, 2, 2, 1, 0, 2, 1, 0, 0, 1 }; const int exo_conn[] = { 0, 1, 3, 4, 5, 7, 8, 12, 11, 18, 19, 21, 13, 17, 16, 1, 2, 3, 5, 6, 7, 9, 10, 12, 19, 20, 21, 14, 15, 17 }; const int vtk_conn[] = { 0, 3, 1, 4, 7, 5, 11, 12, 8, 16, 17, 13, 18, 21, 19, 1, 3, 2, 5, 7, 6, 12, 10, 9, 17, 15, 14, 19, 21, 20 }; return test_read_write_element( coords, 22, vtk_conn, exo_conn, 30, 2, 26, MBPRISM ); }
bool test_write_free_nodes | ( | ) |
Definition at line 1303 of file io/VtkTest.cpp.
References CHECK, conn, moab::Interface::create_element(), moab::Interface::create_vertex(), moab::Interface::delete_mesh(), ErrorCode, moab::Interface::load_file(), MB_SUCCESS, MB_TYPE_INTEGER, MBQUAD, moab::Interface::tag_get_handle(), moab::Interface::tag_set_data(), and moab::Interface::write_file().
{ Core moab_inst; Interface& moab = moab_inst; ErrorCode rval; // create 9 nodes in grid pattern EntityHandle verts[9]; const double coords[][3] = { { 0, 0, 0 }, { 1, 0, 0 }, { 2, 0, 0 }, { 0, 1, 0 }, { 1, 1, 0 }, { 2, 1, 0 }, { 0, 2, 0 }, { 1, 2, 0 }, { 2, 2, 0 } }; for( unsigned i = 0; i < 9; ++i ) { rval = moab.create_vertex( coords[i], verts[i] ); assert( MB_SUCCESS == rval ); } // create 3 quad elements, one node (8) not used const int conn[][4] = { { 0, 1, 4, 3 }, { 1, 2, 5, 4 }, { 3, 4, 7, 6 } }; Tag gid; rval = moab.tag_get_handle( "GLOBAL_ID", 1, moab::MB_TYPE_INTEGER, gid ); assert( MB_SUCCESS == rval ); EntityHandle econn[4], elems[3]; for( unsigned i = 0; i < 3; ++i ) { for( unsigned j = 0; j < 4; ++j ) econn[j] = verts[conn[i][j]]; rval = moab.create_element( MBQUAD, econn, 4, elems[i] ); assert( MB_SUCCESS == rval ); int id = i + 1; rval = moab.tag_set_data( gid, &elems[i], 1, &id ); assert( MB_SUCCESS == rval ); } rval = moab.write_file( "tmp_file.vtk" ); CHECK( rval ); rval = moab.write_file( "tmp_file2.vtk", 0, "CREATE_ONE_NODE_CELLS;" ); CHECK( rval ); // read data back in moab.delete_mesh(); rval = moab.load_file( "tmp_file.vtk" ); remove( "tmp_file.vtk" ); remove( "tmp_file2.vtk" ); CHECK( rval ); return true; }
bool write_and_read | ( | Interface * | iface1, |
Interface * | iface2 | ||
Definition at line 807 of file io/VtkTest.cpp.
References CHECK, ErrorCode, fname, moab::Interface::load_mesh(), and moab::Interface::write_mesh().
void write_data | ( | char * | file, |
size_t & | len, | ||
unsigned | count, | ||
const int * | vals | ||
Definition at line 1042 of file io/VtkTest.cpp.
References MB_TYPE_BIT, MB_TYPE_DOUBLE, MB_TYPE_INTEGER, and MB_TYPE_OPAQUE.
{ switch( type ) { case MB_TYPE_BIT: for( unsigned i = 0; i < count; ++i ) len += sprintf( file + len, "%d\n", abs( vals[i] ) % 2 ); break; case MB_TYPE_INTEGER: for( unsigned i = 0; i < count; ++i ) len += sprintf( file + len, "%d\n", vals[i] ); break; case MB_TYPE_DOUBLE: for( unsigned i = 0; i < count; ++i ) len += sprintf( file + len, "%f\n", (double)vals[i] ); break; case MB_TYPE_OPAQUE: for( unsigned i = 0; i < count; ++i ) len += sprintf( file + len, "%d\n", abs( vals[i] % 256 ) ); break; default: assert( false /* VTK files cannot handle this type */ ); } }
const int element_values[] |
{ 1001, 1002, 1004, 1003, 50, 60, 51, 61, 1, 2, 3, 4, 5, 6, 7, 8, 9, 0, 0, 9, 8, 7, 6, 5, 4, 3, 2, 1 }
Definition at line 1039 of file io/VtkTest.cpp.
Referenced by check_tag_values(), test_scalar_attrib(), test_tensor_attrib(), and test_vector_attrib().
const double grid_2x2x2[] |
{ 0, 0, 0, 1, 0, 0, 2, 0, 0, 0, 1, 0, 1, 1, 0, 2, 1, 0, 0, 2, 0, 1, 2, 0, 2, 2, 0, 0, 0, 1, 1, 0, 1, 2, 0, 1, 0, 1, 1, 1, 1, 1, 2, 1, 1, 0, 2, 1, 1, 2, 1, 2, 2, 1, 0, 0, 2, 1, 0, 2, 2, 0, 2, 0, 1, 2, 1, 1, 2, 2, 1, 2, 0, 2, 2, 1, 2, 2, 2, 2, 2 }
Definition at line 347 of file io/VtkTest.cpp.
Referenced by test_hex20(), test_hex27(), test_hex8(), test_structured_3d(), and test_structured_grid_3d().
const double grid_3x3[] |
{ 0, 0, 0, 1, 0, 0, 2, 0, 0, 3, 0, 0, 0, 1, 0, 1, 1, 0, 2, 1, 0, 3, 1, 0, 0, 2, 0, 1, 2, 0, 2, 2, 0, 3, 2, 0, 0, 3, 0, 1, 3, 0, 2, 3, 0, 3, 3, 0 }
Definition at line 258 of file io/VtkTest.cpp.
Referenced by test_quad4(), test_structured_2d(), and test_structured_grid_2d().
const int hex_structured_conn[] |
{ 0, 1, 4, 3, 9, 10, 13, 12, 1, 2, 5, 4, 10, 11, 14, 13, 3, 4, 7, 6, 12, 13, 16, 15, 4, 5, 8, 7, 13, 14, 17, 16, 9, 10, 13, 12, 18, 19, 22, 21, 10, 11, 14, 13, 19, 20, 23, 22, 12, 13, 16, 15, 21, 22, 25, 24, 13, 14, 17, 16, 22, 23, 26, 25 }
Definition at line 351 of file io/VtkTest.cpp.
Referenced by test_hex8(), and test_structured_3d().
size_t num_tests = 0 |
Definition at line 31 of file io/VtkTest.cpp.
Referenced by find_volume_tests(), initialize_default_files(), main(), and register_test().
std::string poly_example = "unittest/io/poly8-10.vtk" |
Definition at line 17 of file io/VtkTest.cpp.
Referenced by test_polygon_mix().
std::string polyhedra_example = "unittest/io/polyhedra.vtk" |
Definition at line 18 of file io/VtkTest.cpp.
Referenced by test_polyhedra().
const int quad_structured_conn[] |
{ 0, 1, 5, 4, 1, 2, 6, 5, 2, 3, 7, 6, 4, 5, 9, 8, 5, 6, 10, 9, 6, 7, 11, 10, 8, 9, 13, 12, 9, 10, 14, 13, 10, 11, 15, 14 }
Definition at line 261 of file io/VtkTest.cpp.
Referenced by test_quad4(), and test_structured_2d().
test_data* test_array = 0 |
Definition at line 32 of file io/VtkTest.cpp.
Referenced by main(), and register_test().
const char two_quad_mesh[] = "9 9\n" |
Definition at line 1017 of file io/VtkTest.cpp.
Referenced by test_scalar_attrib(), test_tensor_attrib(), test_unstructured_field(), and test_vector_attrib().
const int two_quad_mesh_conn[] = { 0, 1, 4, 3, 1, 2, 5, 4 } |
Definition at line 1035 of file io/VtkTest.cpp.
Referenced by check_tag_values(), and test_unstructured_field().
const double two_quad_mesh_coords[] = { -1, 0, 0, 0, 0, 0, 1, 0, 0, -1, 1, 0, 0, 1, 0, 1, 1, 0 } |
Definition at line 1034 of file io/VtkTest.cpp.
const int vertex_values[] |
{ 9, 3, 8, 2, 0, 6, 4, 1, 4, 1, 0, 3, 8, 6, 6, 4, 0, 2, 1, 2, 3, 4, 5, 6, 6, 5, 4, 3, 2, 1, 0, 6, 1, 5, 2, 4, 3, 6, 9, 2, 5, 8, 1, 3, 5, 7, 1, 3, 5, 8, 1, 9, 7, 4 }
Definition at line 1037 of file io/VtkTest.cpp.
