MOAB: Mesh Oriented datABase
(version 5.4.0)
#include "MeshImpl.hpp"
#include "MeshUtil.hpp"
#include "MsqTimer.hpp"
#include "Mesquite.hpp"
#include "MsqError.hpp"
#include "Vector3D.hpp"
#include "InstructionQueue.hpp"
#include "LaplaceWrapper.hpp"
#include "ShapeImprovementWrapper.hpp"
#include "UntangleWrapper.hpp"
#include "PatchData.hpp"
#include "TerminationCriterion.hpp"
#include "QualityAssessor.hpp"
#include "ParallelMeshImpl.hpp"
#include "ParallelHelper.hpp"
#include "MsqDebug.hpp"
#include "Settings.hpp"
#include "IdealWeightInverseMeanRatio.hpp"
#include "UntangleBetaQualityMetric.hpp"
#include "LPtoPTemplate.hpp"
#include "ConjugateGradient.hpp"
#include "SteepestDescent.hpp"
#include "Randomize.hpp"
#include "ConditionNumberQualityMetric.hpp"
#include "LInfTemplate.hpp"
#include "PlanarDomain.hpp"
#include "TestUtil.hpp"
#include <iostream>
#include <cstdlib>
#include <mpi.h>
#include <sstream>
Classes | |
class | ParShapeImprover |
class | ParShapeImprover::ParShapeImprovementWrapper |
Defines | |
#define | VTK_3D_DIR ( TestDir + "unittest/mesquite/3D/vtk/hexes/tangled/" ) |
#define | VTK_2D_DIR ( TestDir + "unittest/mesquite/2D/vtk/quads/tangled/" ) |
Functions | |
static int | test (std::string filename_prefix, std::string mesh_topology_name, MeshDomain *domain=0) |
int | main (int argc, char *argv[]) |
Variables | |
const double | DEF_UNT_BETA = 1e-8 |
const double | DEF_SUC_EPS = 1e-4 |
#define VTK_2D_DIR ( TestDir + "unittest/mesquite/2D/vtk/quads/tangled/" ) |
Definition at line 104 of file par_hex_untangle_shape.cpp.
Referenced by main().
#define VTK_3D_DIR ( TestDir + "unittest/mesquite/3D/vtk/hexes/tangled/" ) |
Definition at line 103 of file par_hex_untangle_shape.cpp.
int main | ( | int | argc, |
char * | argv[] | ||
Definition at line 527 of file par_hex_untangle_shape.cpp.
References test, VTK_2D_DIR, and VTK_3D_DIR.
{ /* init MPI */ if( MPI_SUCCESS != MPI_Init( &argc, &argv ) ) { cerr << "MPI_Init failed." << endl; return 2; } Vector3D pnt( 0, 0, 0 ); Vector3D s_norm( 0, 0, 1 ); PlanarDomain msq_geom( s_norm, pnt ); int t1 = test( VTK_2D_DIR, "quad", &msq_geom ); if( t1 ) return t1; t1 = test( VTK_3D_DIR, "hex" ); if( t1 ) return t1; MPI_Finalize(); return 0; }
static int test | ( | std::string | filename_prefix, |
std::string | mesh_topology_name, | ||
MeshDomain * | domain = 0 |
) | [static] |
Definition at line 426 of file par_hex_untangle_shape.cpp.
References mesh, MBMesquite::MeshUtil::meshes_are_different(), MPI_COMM_WORLD, MBMesquite::print_timing_diagnostics(), rank, MBMesquite::MeshImpl::read_vtk(), ParShapeImprover::run(), MBMesquite::ParallelHelperImpl::set_communicator(), MBMesquite::ParallelMesh::set_parallel_helper(), MBMesquite::ParallelHelperImpl::set_parallel_mesh(), and MBMesquite::MeshImpl::write_vtk().
{ int rank, nprocs; MPI_Comm_rank( MPI_COMM_WORLD, &rank ); MPI_Comm_size( MPI_COMM_WORLD, &nprocs ); if( nprocs > 2 ) { cerr << "parallel_untangle_shape::test(" << mesh_topology_name << " can only be run with 1 or 2 processors" << std::endl; return 0; } /* create processor-specific file names */ ostringstream in_name, out_name, gold_name; in_name << filename_prefix << "par_untangle_original_" << mesh_topology_name << "_mesh." << nprocs << "." << rank << ".vtk"; gold_name << filename_prefix << "par_untangle_smoothed_" << mesh_topology_name << "_mesh." << nprocs << "." << rank << ".vtk"; out_name << "par_untangle_smoothed_" << mesh_topology_name << "_mesh." << nprocs << "." << rank << ".vtk"; cout << "in_name= " << in_name.str() << " gold_name= " << gold_name.str() << " out_name= " << out_name.str() << std::endl; /* load different mesh files on each processor */ MsqError err; MeshImpl mesh; mesh.read_vtk( in_name.str().c_str(), err ); if( err ) { cerr << err << endl; return 1; } /* create parallel mesh instance, specifying tags * containing parallel data */ ParallelMeshImpl parallel_mesh( &mesh, "GLOBAL_ID", "PROCESSOR_ID" ); ParallelHelperImpl helper; helper.set_communicator( MPI_COMM_WORLD ); helper.set_parallel_mesh( ¶llel_mesh ); parallel_mesh.set_parallel_helper( &helper ); /* do Laplacian smooth */ // LaplaceWrapper optimizer; // optimizer.run_instructions(¶llel_mesh, err); int msq_debug = 0; // 1,2,3 for more debug info bool always_smooth = true; int innerIter = 100; double gradNorm = 1.e-9; ParShapeImprover si( innerIter, gradNorm ); // Mesh *pmesh = ¶llel_mesh; si.run( parallel_mesh, domain, err, always_smooth, msq_debug ); if( err ) { cerr << err << endl; return 1; } /* write mesh */ mesh.write_vtk( out_name.str().c_str(), err ); if( err ) { cerr << err << endl; return 1; } // std::cout << "P[ " << rank <<"] reading gold..." << std::endl; /* compare mesh with gold copy */ MeshImpl gold; gold.read_vtk( gold_name.str().c_str(), err ); if( err ) { cerr << err << endl; return 1; } // std::cout << "P[ " << rank <<"] read gold, checking mesh diff..." << std::endl; bool do_print = true; double tol = 1.e-4; bool diff = MeshUtil::meshes_are_different( mesh, gold, err, tol, do_print ); if( err ) { cerr << err << endl; return 1; } // std::cout << "P[ " << rank <<"] read gold, checking mesh diff...done" << std::endl; if( diff ) { cerr << "Error, computed mesh different from gold copy" << std::endl; return 1; } print_timing_diagnostics( cout ); return 0; }
const double DEF_SUC_EPS = 1e-4 |
Definition at line 109 of file par_hex_untangle_shape.cpp.
const double DEF_UNT_BETA = 1e-8 |
Definition at line 108 of file par_hex_untangle_shape.cpp.
