cgma
CubitAttrib.cpp
00001 //- Class:          CubitAttrib
00002 //- Owner:          Greg Nielson
00003 //- Description:    implementation of the CubitAttrib class.
00004 //- Checked By:
00005 //- Version:
00006
00007 #include "CastTo.hpp"
00008 #include "CubitAttrib.hpp"
00009 #include "CubitAttribUser.hpp"
00010 #include "Body.hpp"
00011 #include "RefVolume.hpp"
00012 #include "RefFace.hpp"
00013 #include "RefEdge.hpp"
00014 #include "RefVertex.hpp"
00015 #include "CADeferredAttrib.hpp"
00016 #include "RefEntity.hpp"
00017 #include "DLIList.hpp"
00018 #include "RefEntityFactory.hpp"
00019 #include "MergeTool.hpp"
00020 #include "ModelQueryEngine.hpp"
00021 #include "GeometryQueryTool.hpp"
00022
00023
00024
00025
00026 CubitAttrib::CubitAttrib(RefEntity *attrib_owner)
00027 {
00028   attribOwnerEntity = attrib_owner;
00029   hasActuated = CUBIT_FALSE;
00030   hasUpdated = CUBIT_FALSE;
00031   hasWritten = CUBIT_FALSE;
00032   deleteAttrib = CUBIT_FALSE;
00033   nextAttrib = NULL;
00034
00035     // add this to the owner
00036   if (attrib_owner) attrib_owner->add_cubit_attrib(this);
00037 }
00038
00039 CubitAttrib::~CubitAttrib()
00040 {
00041   if( !hasActuated )
00042     CADeferredAttrib::remove_unactuated_ca( this );
00043 }
00044
00045 CubitStatus CubitAttrib::actuate_list(DLIList<RefEntity*> entity_list)
00046 {
00047   RefEntity * ref_ent;
00048   for(int i = entity_list.size(); i > 0; i--)
00049   {
00050     ref_ent = entity_list.get_and_step();
00051     ref_ent->actuate_cubit_attrib(CA_ENTITY_NAME);
00052     ref_ent->actuate_cubit_attrib ( CA_UNIQUE_ID );
00053     ref_ent->actuate_cubit_attrib(CA_SIZING_FUNCTION_SKELETON);
00054     ref_ent->actuate_cubit_attrib(CA_MESH_INTERVAL);
00055     ref_ent->actuate_cubit_attrib(CA_GROUP);
00056     ref_ent->actuate_cubit_attrib(CA_GENESIS_ENTITY);
00057 //    ref_ent->actuate_cubit_attrib ( CA_ENTITY_ID );
00058     ref_ent->actuate_cubit_attrib ( CA_MESH_SCHEME );
00059     ref_ent->actuate_cubit_attrib ( CA_SMOOTH_SCHEME );
00060     ref_ent->actuate_cubit_attrib ( CA_PARTITION_VG );
00061     ref_ent->actuate_cubit_attrib ( CA_COMPOSITE_VG );
00062     ref_ent->actuate_cubit_attrib ( CA_VIRTUAL_VG );
00063     ref_ent->actuate_cubit_attrib(CA_MERGE_PARTNER);
00064     ref_ent->actuate_cubit_attrib(CA_DEFERRED_ATTRIB);
00065     ref_ent->actuate_cubit_attrib(CA_MESH_CONTAINER);
00066     ref_ent->actuate_cubit_attrib(CA_BODIES);
00067     ref_ent->actuate_cubit_attrib ( CA_ENTITY_ID );
00068     ref_ent->actuate_cubit_attrib(CA_ENTITY_COLOR);
00069     ref_ent->actuate_cubit_attrib(CA_ENTITY_TOL);
00070 //#ifdef CAT
00071     ref_ent->actuate_cubit_attrib(CA_VERTEX_FORCE);
00072     ref_ent->actuate_cubit_attrib(CA_SURFACE_FORCE);
00073     ref_ent->actuate_cubit_attrib(CA_CURVE_FORCE);
00074     ref_ent->actuate_cubit_attrib(CA_VERTEX_DISPLACEMENT);
00075     ref_ent->actuate_cubit_attrib(CA_SURFACE_DISPLACEMENT);
00076     ref_ent->actuate_cubit_attrib(CA_CURVE_DISPLACEMENT);
00077     ref_ent->actuate_cubit_attrib(CA_VOLUME_DISPLACEMENT);
00078     ref_ent->actuate_cubit_attrib(CA_SURFACE_PRESSURE);
00079     ref_ent->actuate_cubit_attrib(CA_CURVE_PRESSURE);
00080     ref_ent->actuate_cubit_attrib(CA_SURFACE_TEMPERATURE);
00081     ref_ent->actuate_cubit_attrib(CA_CURVE_TEMPERATURE);
00082     ref_ent->actuate_cubit_attrib(CA_VERTEX_TEMPERATURE);
00083     ref_ent->actuate_cubit_attrib(CA_SURFACE_HEATFLUX);
00084     ref_ent->actuate_cubit_attrib(CA_CURVE_HEATFLUX);
00085     ref_ent->actuate_cubit_attrib(CA_SURFACE_CONVECTION);
00086     ref_ent->actuate_cubit_attrib(CA_CURVE_CONVECTION);
00087     ref_ent->actuate_cubit_attrib(CA_SURFACE_CONTACT);
00088     ref_ent->actuate_cubit_attrib(CA_CURVE_CONTACT);
00089     ref_ent->actuate_cubit_attrib(CA_COORD_SYS);
00090     ref_ent->actuate_cubit_attrib(CA_PROPERTY_BLOCK);
00091     ref_ent->actuate_cubit_attrib(CA_MATERIAL_BLOCK);
00092 //#endif
00093     ref_ent->actuate_cubit_attrib(CA_MERGE_STATUS);
00094   }
00095   return CUBIT_SUCCESS;
00096 }
00097
00098 void CubitAttrib::has_written(CubitBoolean set_has_written)
00099 {
00100   hasWritten = set_has_written;
00101
00102     // if the written flag is being set to true, reset the hasUpdated flag
00103   if (CUBIT_TRUE == hasWritten)
00104     hasUpdated = CUBIT_FALSE;
00105 }
00106
00107 CubitBoolean CubitAttrib::has_written() const
00108 {return hasWritten;}
00109
00110 void CubitAttrib::remove_attribute()
00111 {
00112   if (has_written())
00113     attribOwnerEntity->remove_attrib_geometry_entity(this);
00114 }
00115
00116 void CubitAttrib::add_attribute()
00117 {
00118   attribOwnerEntity->add_cubit_attrib(this);
00119 }
00120
00121 int CubitAttrib::equivalent(const CubitSimpleAttrib& csa_ptr)
00122 {
00123     //- return true if the csa and this are equivalent
00124    CubitSimpleAttrib this_csa_ptr = cubit_simple_attrib();
00125
00126    return this_csa_ptr == csa_ptr;
00127 }
00128
00129 void CubitAttrib::print()
00130 {
00131     // print some details about this attrib
00132   PRINT_INFO("Attrib type %s, Owner = %s %d, Actuated=%d, Updated=%d, "
00133              "Written=%d, Delete=%d\n",
00134              att_internal_name(),
00135              (attribOwnerEntity ? attribOwnerEntity->class_name() : "(none)"),
00136              (attribOwnerEntity ? attribOwnerEntity->id() : 0),
00137              hasActuated, hasUpdated,
00138              hasWritten, deleteAttrib);
00139
00140 }
00141
