cgma
CubitOctreeGeneratorVolumes.cpp
00001 #include "CubitOctreeGeneratorVolumes.hpp"
00002 #include "CubitOctree.hpp"
00003 #include "RefFace.hpp"
00004 #include "TDOctreeRefFace.hpp"
00005 #include "CubitFacet.hpp"
00006 #include "CubitOctreeNode.hpp"
00007 #include "CubitOctreeCell.hpp"
00008 #include "CubitPoint.hpp"
00009 #include "CubitFacetEdge.hpp"
00010 #include "RefEdge.hpp"
00011 #include "CpuTimer.hpp"
00012 #include "FacetDataUtil.hpp"
00013 #include "RefEdge.hpp"
00014 #include "TDOctreeRefEdge.hpp"
00015 #include "GeometryQueryEngine.hpp"
00016 #include "FacetSurface.hpp"
00017 #include "CubitOctreeConstants.hpp"
00018 #include "ChollaEngine.hpp"
00019 #include "ProgressTool.hpp"
00020 #include "AppUtil.hpp"
00021 #include "OctreeFacetPointData.hpp"
00022 #include "Body.hpp"
00023
00024 // Constructor for CubitOctree
00025 CubitOctreeGeneratorVolumes::CubitOctreeGeneratorVolumes( DLIList<RefEntity*> &entity_list)
00026         :CubitOctreeGenerator( ), entityList(entity_list){
00027
00028   entityList = entity_list;
00029   cubitOctree = new CubitOctree( this);
00030 }
00031
00032 void CubitOctreeGeneratorVolumes::get_bounding_box( CubitVector &min, CubitVector &max ){
00033   RefEntity *volume;
00034   int index;
00035   CubitBox bound_box;
00036
00037   min.x( CUBIT_DBL_MAX );
00038   min.y( CUBIT_DBL_MAX );
00039   min.z( CUBIT_DBL_MAX );
00040
00041   max.x( -CUBIT_DBL_MAX );
00042   max.y( -CUBIT_DBL_MAX );
00043   max.z( -CUBIT_DBL_MAX );
00044
00045   for( index = 0; index < entityList.size(); index++ ){
00046     volume =   entityList.get_and_step();
00047
00048     bound_box =  volume->bounding_box();
00049
00050     if( bound_box.minimum().x() < min.x() )
00051       min.x( bound_box.minimum().x());
00052     if( bound_box.minimum().y() < min.y() )
00053       min.y( bound_box.minimum().y());
00054     if( bound_box.minimum().z() < min.z() )
00055       min.z( bound_box.minimum().z());
00056
00057     if( bound_box.maximum().x() > max.x() )
00058       max.x( bound_box.maximum().x());
00059     if( bound_box.maximum().y() > max.y() )
00060       max.y( bound_box.maximum().y());
00061     if( bound_box.maximum().z() > max.z() )
00062       max.z( bound_box.maximum().z());
00063   }
00064
00065 }
00066
00067 // CubitOctree is generated based on facets of the FACE.
00068 // Therefore small features are captured.
00069 // First the CubitOctree grid is generated without any intersection
00070 // calculation. The nodes are linked using 6 pointers to the adjacent nodes
00071 // The cells are stored using CubitOctree data structure.  As the boundary points are need
00072 // for MAT generation, intersection between the CubitOctree edges and facets are computed and
00073 // normals are also stored.
00074 CubitBoolean CubitOctreeGeneratorVolumes::generate_lattice( void ){
00075
00076     // initialize CubitOctree root
00077   cubitOctree->initialize_octree_generation();
00078
00079     // Builds the tree fully till the level min_depthibcbtghs.lib
00080   cubitOctree->build_octree_till_min_depth( cubitOctree->get_root() );
00081
00082     // Builds the tree based on facets' points, centroid, dimension ...
00083     // Note that the points on the curves belong to more than one face
00084     // Therefore the CubitOctree is subdivided till the maxDepth
00085   build_octree_till_skl_max_depth_based_on_facets();
00086
00087     // Adjacents cells can be found by visiting the adjacent cells of every node
00088     // Cells are split till the difference in the levels of adjacent cells is 1.
00089     // At every node find the maximum and minimum cell.  Split the maximum cell if
00090     // it deffers by 2 or more in depth.
00091
00092
00093     //PRINT_DEBUG_157(" Number of nodes = %d", gridNodeVector.size() );
00094   return CUBIT_TRUE;
00095 }
00096
00097
00098 CubitBoolean CubitOctreeGeneratorVolumes::build_octree_till_skl_max_depth_based_on_facets( void ){
00099
00100   DLIList< RefFace *> vol_ref_faces;
00101   DLIList<CubitFacet *> *facet_list;
00102   DLIList<CubitPoint*> *point_list;
00103   DLIList<CubitFacetEdge *> *ptr_facet_edge_list;
00104   DLIList<OctreeFacetPointData *> facet_point_data_list; //, vfacet_point_data_list;
00105   DLIList<CubitOctreeCell*> refine_cell_list;
00106
00107     // DLIList<CubitFacet*> global_facet_list;
00108
00109
00110   int index;
00111   int i, j, k, l;
00112   CubitPoint *ptr_point;
00113   CubitFacet *ptr_facet, *ptr_adj_facet0, *ptr_adj_facet1;
00114   CubitFacetEdge *ptr_edge;
00115   RefFace *ptr_ref_face;
00116   OctreeFacetPointData *facet_point_data;
00117   CubitVector normal0, normal1;
00118   double internal_angle;
00119   Body *volume;
00120   TDOctreeRefFace *td_ref_face;
00121
00122     // PR-CubitOctree has the property that the cell size depends on the density of the facet points
00123     // Higher the density the finer will be the facet cell size.
00124     // Step 1: The CubitOctree is built only till MaxDepth based on facet information
00125     //  1. Small features that have smaller curve length are detected using facet density
00126     //  2. Surface/Curve curvature are detected based on di-hedral angle between the adj facets.
00127     //     Also the aspect ratio of facets are used because it is found that when the surface has curvature on only one directio
00128     //     the facet aspect ratio will be very high.
00129   for( index = 0; index < entityList.size(); index++ ){
00130     volume =  CAST_TO( entityList.get_and_step(), Body );
00131     vol_ref_faces.clean_out();
00132     volume->ref_faces( vol_ref_faces );
00133     vol_ref_faces.reset();
00134
00135       // get volume facets and insert points from those facets
00136
00137     for( i = 0; i < vol_ref_faces.size(); i++ ){
00138       ptr_ref_face = vol_ref_faces.get_and_step();
00139       td_ref_face = TDOctreeRefFace::get_td( ptr_ref_face );
00140
00141       if( td_ref_face->get_visit() == CUBIT_FALSE ){
00142         td_ref_face->set_visit( CUBIT_TRUE );
00143
00144           // grab facets here if stitching
00145
00146           // add to global list for facet point insertion
00147
00148           /*int num_parents = CAST_TO(ptr_ref_face,RefFace)->num_parent_ref_entities();
00149             if (num_parents == 1)
00150             {
00151             global_facet_list += *facet_list;
00152             }
00153
00154             else
00155             {*/
00156
00157           // Generated OctreeFacetPointData based on facet vertices
00158         point_list = td_ref_face->get_ptr_cubit_point_list();
00159         for( j = 0; j < point_list->size(); j++ ){
00160           ptr_point = point_list->get_and_step();
00161           facet_point_data = new OctreeFacetPointData( ptr_point->coordinates(), ptr_point );
00162           facet_point_data_list.push( facet_point_data );
00163         }
00164 //        point_list.clean_out();
00165
00166           //}
00167
00168
00169           // Generate OctreeFacetPointData based on facet centroid
00170
00171         facet_list = td_ref_face->get_ptr_cubit_facet_list();
00172         for( j = 0; j < facet_list->size(); j++ ){
00173           ptr_facet = facet_list->get_and_step();
00174           facet_point_data = new OctreeFacetPointData( ptr_facet->center(), ptr_facet );
00175           facet_point_data_list.push( facet_point_data );
00176         }
00177
00178           /* Generate OctreeFacetPointData based on aspect ratio of facet
00179              for( j = 0; j < facet_list->size(); j++ ){
00180              ptr_facet = facet_list->get_and_step();
00181              OctreeFacetPointData::generate_facet_point_data_at_slender_facet( ptr_facet, facet_point_data_list );
00182              }
00183           */
00184
00185           // Generate OctreeFacetPointData based on surface curvature
00186         ptr_facet_edge_list = td_ref_face->get_ptr_cubit_facet_edge_list();
00187         for( j = 0; j < ptr_facet_edge_list->size(); j++ ){
00188           ptr_edge = ptr_facet_edge_list->get_and_step();
00189           if( ptr_edge->num_adj_facets() == 2 ){
00190               // mark adjacent facets
00191             ptr_adj_facet0 = ptr_edge->adj_facet(0);
00192             ptr_adj_facet1 = ptr_edge->adj_facet(1);
00193             normal0 = ptr_adj_facet0->normal();
00194             normal1 = ptr_adj_facet1->normal();
00195
00196             if (normal0.length_squared() > 0.0 && normal1.length_squared() > 0.0)
00197             {
00198               internal_angle = normal0.interior_angle(normal1);
00199             }
00200             else
00201             {
00202               internal_angle = 0.0;
00203             }
00204               //PRINT_INFO("%f ", internal_angle );
00205             if( internal_angle > ANGLE_BETWEEN_FACETS_NORMAL_FOR_OCTREE_BASED_ON_SURF_CURVATURE_FACTOR * ANG_FACET_EXTRACT[OCTREE_TIME_ACCURACY_LEVEL] ){
00206               OctreeFacetPointData::generate_facet_point_data_based_on_curvature( ptr_edge, /*internal_angle,*/ facet_point_data_list );
00207             }
00208           }
00209         }
00210
00211           // now check for pairs of adjacents with dihedral angles along their shared edge
00212           // the CubitOctree should be refined in these regions so we have enough grid nodes to generate 3dmat points
00213           // disabling for now :( because there is a problem in FacetDataUtil's facet stitching code
00214         if (0)
00215         {
00216           DLIList<DLIList<RefEdge*> > edge_loops;
00217           ptr_ref_face->ref_edge_loops(edge_loops);
00218           for (i=0; i < edge_loops.size(); ++i)
00219           {
00220             DLIList<RefEdge*>& edge_loop = edge_loops.get_and_step();
00221             for (j=0; j < edge_loop.size(); ++j)
00222             {
00223               DLIList<RefEntity*> parents;
00224               RefEdge *edge = edge_loop.get_and_step();
00225               TDOctreeRefEdge *td_ref_edge = TDOctreeRefEdge::get_td(edge);
00226
00227               if( td_ref_edge->get_visit() == CUBIT_FALSE )
00228               {
00229                 td_ref_edge->set_visit( CUBIT_TRUE );
00230                 edge->get_parent_ref_entities(parents);
00231
00232                   // check Refface's for bad facets in case it hasn't been done
00233                   // already
00234                 for (k=0; k < parents.size(); ++k)
00235                 {
00236                   RefFace *parent = CAST_TO(parents.get_and_step(), RefFace);
00237                   if (parent == NULL) {continue;}
00238                   TDOctreeRefFace *td_parent = TDOctreeRefFace::get_td(parent);
00239                   if (td_parent == NULL) {continue;}
00240                   if (td_parent->get_create_2dmat())
00241                   {
00242                     td_parent->check_valid_facets(CUBIT_TRUE);
00243                   }
00244                 }
00245
00246                 for (k=0; k < parents.size(); ++k)
00247                 {
00248                   for (l=k+1; l < parents.size(); ++l)
00249                   {
00250                       // SVDrawTool::clear_non_retained();
00251                     DLIList<CubitFacet*> crease_facets;
00252                     DLIList<CubitFacetEdge*> crease_edges;
00253                     cubitOctree->find_cells_based_on_surface_angle(refine_cell_list, crease_edges, crease_facets,
00254                                                               CAST_TO(parents[k],RefFace), CAST_TO(parents[l],RefFace),
00255                                                               CUBIT_FALSE, 2.0*CUBIT_PI/3.0);
00256                       // will need to store crease_edges and facets
00257
00258                       // SVDrawTool::mouse_xforms();
00259                   }
00260
00261                 }
00262               }
00263
00264             }
00265
00266           }
00267         }
00268
00269       }
00270     }
00271   }
00272
00273
00274     /*
00275       DLIList<DLIList<CubitFacet*>*> shells;
00276       shells.append(&global_facet_list);
00277       CubitBoolean dummy;
00278       FacetDataUtil::stitch_facets(shells, OCTREE_EPSILON, dummy);
00279       if (shells.size() == 1)
00280       {
00281       FacetDataUtil::get_points(global_facet_list, point_list);
00282       for( j = 0; j < point_list.size(); j++ )
00283       {
00284       ptr_point = point_list.get_and_step();
00285       facet_point_data = new OctreeFacetPointData( ptr_point->coordinates(), ptr_point );
00286       facet_point_data_list.push( facet_point_data );
00287       }
00288       }
00289       else
00290       {
00291       PRINT_INFO("Stitch resulted in multiple shells!!!!!!!!!!\n");
00292
00293       }
00294     */
00295
00296
00297
00298     // Reset the visit to CUBIT_FALSE
00299   reset_td_octree_ref_face_visit( CUBIT_FALSE );
00300   reset_td_octree_ref_edge_visit( CUBIT_FALSE );
00301
00302   facet_point_data_list.reset();
00303   for( i = 0; i < facet_point_data_list.size(); i++ ){
00304     facet_point_data =  facet_point_data_list.get_and_step();
00305       //SkeletonDebug::draw_point( facet_point_data->coordinates(), CUBIT_MAGENTA_INDEX );
00306     cubitOctree->subdivide_octree_based_on_facet_point( facet_point_data, cubitOctree->get_max_depth() );
00307   }
00308
00309     // refine the cells on edges with large enough dihedral angles
00310     // disabling for now
00311     //int target_depth = skeletonProxy->get_source_entity_max_depth();
00312     //cubitOctree->refine_cells_to_target_depth(refine_cell_list, target_depth);
00313
00314   return CUBIT_TRUE;
00315 }
00316
00317
00318
00319 CubitBoolean CubitOctreeGeneratorVolumes::find_intersection_between_octree_and_facets( DLIList<CubitOctreeNode *> &queue_for_mat_generation ){
00320   DLIList< RefFace *> vol_ref_faces;
00321   RefFace *ptr_ref_face;
00322   TDOctreeRefFace *td_ref_face;
00323   DLIList< CubitFacet *> *facet_list;
00324   CubitFacet *ptr_facet;
00325   DLIList<CubitOctreeCell *> CubitOctree_cell_list;
00326   DLIList< CubitOctreeNode *> CubitOctree_grid_node_list;
00327   DLIList<CubitOctreeNode*> all_grid_nodes;
00328
00329     //CubitVector facet_normal;
00330     //DLIList< CubitPoint *> *point_list;
00331   int i, j, k;
00332   int index;
00333   Body *volume;
00334
00335 //  CpuTimer total_idata_time;
00336
00337   for( index = 0; index < entityList.size(); index++ ){
00338     volume = CAST_TO( entityList.get_and_back(), Body );
00339     vol_ref_faces.clean_out();
00340     volume->ref_faces( vol_ref_faces );
00341       //vol_ref_faces.reset();
00342       //int cell_count = 0;
00343       //CubitBox facet_bbox;
00344       //PRINT_INFO(" \nRef Volume  = %d ", volume->id());
00345
00346     for( i = 0; i < vol_ref_faces.size(); i++ ){
00347       ptr_ref_face = vol_ref_faces.get_and_step();
00348       td_ref_face = TDOctreeRefFace::get_td( ptr_ref_face );
00349
00350       if(td_ref_face->get_visit() == CUBIT_FALSE){
00351         td_ref_face->set_visit( CUBIT_TRUE );
00352
00353           //PRINT_INFO(" \nRef Face = %d ", ptr_ref_face->id());
00354
00355         RefFace *current_ref_face = CAST_TO(ptr_ref_face, RefFace);
00356           /*if (current_ref_face->sense(CAST_TO(volume,Body)) == CUBIT_REVERSED)
00357             {
00358             temp_facet_normal *= -1.0;
00359             }*/
00360
00361 //        PRINT_INFO("Number of parent ref Entities for face %d: %d\n", current_ref_face->id(), current_ref_face->num_parent_ref_entities());
00362
00363           // get the sense so we know which way to propagate the 3DMAT front inwards
00364         CubitSense ref_face_sense = CUBIT_FORWARD; //current_ref_face->sense(volume);
00365
00366           // in the case of a merged face, figure out if two parent vols share the same
00367           // sizing function. If so, propagate in both directions
00368         if (current_ref_face->is_merged() /*&& current_ref_face->num_parent_ref_entities() == 2*/)
00369         {
00370           DLIList<RefEntity*> parent_ents;
00371           current_ref_face->get_parent_ref_entities(parent_ents);
00372           if (parent_ents.size() == 2)
00373           {
00374             Body *other_parent_vol = CAST_TO(parent_ents.get_and_step(),Body);
00375             if (other_parent_vol == volume) {other_parent_vol = CAST_TO(parent_ents.get(),Body);}
00376             if (other_parent_vol != NULL)
00377             {
00378
00379                       // if the other parent volume has the same sizing function,
00380                       // pass CUBIT_UNKNOWN to CubitOctreeCell::set_color_and_idatas
00381                       // It will then set up the front normals to propagate in both directions
00382                       ref_face_sense = CUBIT_UNKNOWN;
00383
00384             }
00385           }
00386         }
00387
00388         facet_list = td_ref_face->get_ptr_cubit_facet_list();
00389           //PRINT_INFO("Surface %d: facets: %d\n", ptr_ref_face->id(), facet_list->size());
00390
00391         for( j = 0; j < facet_list->size(); j++ ){
00392           ptr_facet = facet_list->get_and_step();
00393
00394             //CubitVector temp_facet_normal = ptr_facet->normal();
00395
00396
00397             //SVDrawTool::draw_vector(ptr_facet->center(), ptr_facet->center()+temp_facet_normal, (i%8)+1);
00398
00399
00400 //#ifndef NDEBUG
00401 //          SkeletonDebug::draw_facet( ptr_facet, CUBIT_BLUE_INDEX );
00402 //#endif
00403             //facet_bbox = ptr_facet->bounding_box();
00404             //draw_box( facet_bbox );
00405             //facet_normal = ptr_facet->normal();
00406             //if( ptr_facet->is_backwards() ){
00407             // facet_normal = facet_normal * -1;
00408             //}
00409             //GfxDebug::draw_line( ptr_facet->center().x(), ptr_facet->center().y(), ptr_facet->center().z(), ptr_facet->center().x()+facet_normal.x(), ptr_facet->center().y()+facet_normal.y(), ptr_facet->center().z()+facet_normal.z(), CUBIT_WHITE_INDEX );
00410           CubitOctree_cell_list.clean_out();
00411           CubitOctree_grid_node_list.clean_out();
00412             //PRINT_INFO(" Before find_octree_cells_contatined \n");
00413           cubitOctree->find_octree_cells_contained_inside_bbox( ptr_facet, CubitOctree_cell_list );
00414             //PRINT_INFO(" Before mark_positive_and_negative_grid_nodes \n");
00415           cubitOctree->mark_positive_and_negative_octree_grid_nodes( ptr_facet, CubitOctree_cell_list, CubitOctree_grid_node_list  );
00416             //PRINT_INFO(" Before find_intersection_between_grid_edge_facet \n");
00417
00418           if ( OCTREE_DEFAULT_INTERSECTION_METHOD[OCTREE_TIME_ACCURACY_LEVEL] == SAT_INTERSECT){
00419               //PRINT_INFO("%d cells in bbox\n", CubitOctree_cell_list.size());
00420
00421             for (k=0; k < CubitOctree_cell_list.size(); ++k)
00422             {
00423               CubitOctreeCell *current_cell = CubitOctree_cell_list.get_and_step();
00424                 // if (current_cell->get_mark() == CUBIT_FALSE) {continue;}
00425                 //current_cell->set_mark(CUBIT_FALSE);
00426
00427               if (current_cell->does_facet_intersect_octreecell(ptr_facet))
00428               {
00429                   /*  double corners[3];
00430                       double half_edge_length = current_cell->get_dimension()/2.0;
00431                       CubitVector center = current_cell->get_center();
00432                       center.get_xyz(corners);
00433                       float box[6] = {corners[0]-half_edge_length, corners[1]-half_edge_length, corners[2]-half_edge_length,
00434                       corners[0]+half_edge_length, corners[1]+half_edge_length, corners[2]+half_edge_length};
00435                       SVDrawTool::draw_cube(box, CUBIT_GREEN_INDEX, SVDrawTool::WIRE);*/
00436
00437                 current_cell->set_color_and_intersection_datas(ptr_facet, ptr_ref_face,
00438 #ifdef USE_octree_BGMESH
00439        cubitOctree->get_greycelllist(),
00440 #endif
00441        ref_face_sense);
00442
00443                   //cubitOctree->get_greycelllist()->append(current_cell);
00444               }
00445                 /*if (ref_face_sense) {
00446                   //  SVDrawTool::mouse_xforms();
00447                   }*/
00448
00449             }
00450
00451             for( k = 0; k < CubitOctree_grid_node_list.size(); k++ )
00452             {
00453               CubitOctreeNode *ptr_grid_node = CubitOctree_grid_node_list.get_and_step();
00454               if (ptr_grid_node->get_visit() == CUBIT_FALSE)
00455               {
00456                 all_grid_nodes.append(ptr_grid_node);
00457                 ptr_grid_node->set_visit(CUBIT_TRUE);
00458               }
00459
00460               ptr_grid_node->set_mark( CUBIT_FALSE );
00461               if( ptr_grid_node->get_halfspace_direction() == OCTREE_POSITIVE )
00462               {
00463                 ptr_grid_node->set_halfspace_direction( OCTREE_NEGATIVE );
00464               }
00465             }
00466           }
00467
00468           if (OCTREE_DEFAULT_INTERSECTION_METHOD[OCTREE_TIME_ACCURACY_LEVEL] == GRID_EDGE_INT)
00469           {
00470             cubitOctree->find_intersection_between_grid_edges_and_facet( CUBIT_OCTREE_VOLUME,  ptr_ref_face, ptr_facet, CubitOctree_grid_node_list );
00471           }
00472
00473
00474
00475         }
00476
00477       }
00478     }
00479   }
00480
00481     // Reset the visit to CUBIT_FALSE
00482   reset_td_octree_ref_face_visit( CUBIT_FALSE );
00483     //SVDrawTool::mouse_xforms();
00484     // PRINT_INFO("profiling: time for intersecting and making idatas: %f\n", total_idata_time.cpu_secs());
00485
00486   if (OCTREE_DEFAULT_INTERSECTION_METHOD[OCTREE_TIME_ACCURACY_LEVEL] == SAT_INTERSECT)
00487   {
00488       //CpuTimer front_color_time;
00489     for (i=0; i < all_grid_nodes.size(); ++i)
00490     {
00491       CubitOctreeNode *grid_node = all_grid_nodes.get_and_step();
00492       DLIList<OctreeIntersectionData*> *idata_list = grid_node->get_idata_list();
00493         //idata_list->uniquify_unordered();
00494
00495
00496       if (idata_list->size() > 0)
00497       {
00498         DLIList<OctreeIntersectionData*> closest_ones;
00499         //OctreeIntersectionData *closest = NULL;
00500         double min_list_dist = CUBIT_DBL_MAX;
00501         for (k=0; k < idata_list->size(); ++k)
00502         {
00503           if (idata_list->get()->is_merged()) {idata_list->step();}
00504
00505           double temp_dist = idata_list->get()->get_length();
00506           if (temp_dist < min_list_dist - OCTREE_EPSILON)
00507           {
00508             closest_ones.clean_out();
00509 //          closest = idata_list->get();
00510             closest_ones.append(idata_list->get());
00511             min_list_dist = temp_dist;
00512           }
00513           else if (fabs(temp_dist - min_list_dist) <= OCTREE_EPSILON)
00514           {
00515             closest_ones.append(idata_list->get());
00516           }
00517           idata_list->step();
00518         }
00519
00520         bool white = false;
00521
00522         for (j=0; j < closest_ones.size(); ++j)
00523         {
00524           if (closest_ones.get_and_step()->get_halfspace())
00525           {
00526             white = true;
00527             break;
00528           }
00529         }
00530
00531         //closest = closest_ones.get();
00532 //        if (!white) {SVDrawTool::draw_vector(grid_node->get_coord(), closest->get_int_point(), CUBIT_RED_INDEX);}
00533
00534           // this is the closest facet encountered by the current grid node so far
00535           // update color of node based on this facet
00536         if (white)
00537         {
00538           grid_node->set_color(CUBIT_WHITE_INDEX);
00539           cubitOctree->get_whitenodelist()->append(grid_node);
00540
00541         }
00542         else if (!white)
00543         {
00544 //           if ( (grid_node->get_coord()-closest->get_facet_ptr()->center()) % (closest->get_normal()) < 0)
00545 //           {
00546 //             PRINT_INFO("Adding a white node to queue !!!!!!!!!!!!\n");
00547 //           }
00548
00549             // uncomment this
00550             //             for (j=0; j < grid_node->get_idata_list()->size(); ++j)
00551 //           {
00552 //             OctreeIntersectionData *idata = grid_node->get_idata_list()->get_and_step();
00553 //             double proj_length = fabs((grid_node->get_coord() - idata->get_int_point())%idata->get_facet_normal());
00554 //             idata->set_length(proj_length);
00555 //             }
00556
00557 //           SVDrawTool::draw_vector(grid_node->get_coord(), closest->get_int_point(), CUBIT_RED_INDEX);
00558
00559           grid_node->set_color(CUBIT_BLACK_INDEX);
00560           queue_for_mat_generation.append(grid_node);
00561         }
00562         else
00563         {
00564             //PRINT_INFO("Couldn't pick halfspace to color node!\n");
00565         }
00566       }
00567       grid_node->set_visit(CUBIT_FALSE);
00568     }
00569
00570     for (i=0; i < cubitOctree->get_whitenodelist()->size(); ++i)
00571     {
00572       CubitOctreeNode *ptr_grid_node = cubitOctree->get_whitenodelist()->get_and_step();
00573       DLIList<OctreeIntersectionData*> *idata_list = ptr_grid_node->get_idata_list();
00574       for (k=0; k < idata_list->size(); ++k)
00575       {
00576         OctreeIntersectionData *idata = idata_list->get_and_step();
00577         if (idata != NULL) {delete idata;}
00578       }
00579       idata_list->clean_out();
00580       CubitOctreeNode *adj_node = NULL;
00581       for (k=0; k < 6; ++k)
00582       {
00583         adj_node = ptr_grid_node->get_adj_node(k);
00584         if (adj_node != NULL)
00585         {
00586           if (adj_node->get_color() != CUBIT_BLACK_INDEX && adj_node->get_color() != CUBIT_WHITE_INDEX)
00587           {
00588             adj_node->set_color(CUBIT_YELLOW_INDEX);
00589           }
00590             //SVDrawTool::draw_point(adj_node->get_coord(), adj_node->get_color());
00591         }
00592       }
00593     }
00594       // PRINT_INFO("profiling: time to color front nodes: %f\n", front_color_time.cpu_secs());
00595
00596   }
00597
00598
00599
00600
00601
00602     // PRINT_INFO("Testing: Cell Count = %d", cell_count );
00603   if (OCTREE_DEFAULT_INTERSECTION_METHOD[OCTREE_TIME_ACCURACY_LEVEL] == SAT_INTERSECT)
00604   {
00605
00606    //     CpuTimer front_init;
00607
00608     for( i = 0; i < queue_for_mat_generation.size(); i++ ){
00609       queue_for_mat_generation.get_and_step()->SAT_find_face_distance_average_normal( /*skeletonSizingFunction, queue_for_mat_generation*/ );
00610     }
00611       //PRINT_INFO("profiling: time to init front: %f\n", front_init.cpu_secs());
00612
00613   }
00614
00615
00616   return CUBIT_TRUE;
00617 }
00618
00619
00620
00621 void CubitOctreeGeneratorVolumes::find_optimal_min_and_max_depth( RefEntity*entity, int &local_min_depth, int &local_max_depth )
00622 {
00623   Body *volume = dynamic_cast<Body *> (entity);
00624   if( NULL == volume)
00625     return;
00626
00627   CubitBox bbox = volume->bounding_box();
00628
00629   // calculate min_depth by comparing min_range with max_range in log scale
00630   double max_range = std::max( std::max( bbox.x_range(), bbox.y_range()), bbox.z_range() );
00631   double min_range = std::min( std::min( bbox.x_range(), bbox.y_range()), bbox.z_range() );
00632   local_min_depth = (int)(log( max_range / min_range ) / log(2.0)) + 1;  // add plus 1 just to give enough one extra level of depth
00633
00634   if( local_min_depth < MIN_DEPTH_OCTREE[OCTREE_TIME_ACCURACY_LEVEL] )
00635     local_min_depth = MIN_DEPTH_OCTREE[OCTREE_TIME_ACCURACY_LEVEL];
00636   if( local_min_depth > MAX_DEPTH_OCTREE[OCTREE_TIME_ACCURACY_LEVEL] )
00637     local_min_depth = MAX_DEPTH_OCTREE[OCTREE_TIME_ACCURACY_LEVEL];
00638
00639   // calculate max_depth by comparing the min curve length with max_range in log scale
00640   DLIList< RefEdge *> list_edges;
00641   volume->ref_edges( list_edges );
00642
00643   int i;
00644   RefEdge *ptr_edge;
00645   double min_edge_len = DBL_MAX;
00646   double len;
00647   CubitVector start_pt, mid_pt, end_pt;
00648   for( i = 0; i < list_edges.size(); i++ )
00649   {
00650     ptr_edge = list_edges.get_and_step();
00651     //len = ptr_edge->length_from_u( ptr_edge->start_param(), ptr_edge->end_param() );
00652     start_pt = ptr_edge->start_coordinates();
00653     end_pt = ptr_edge->end_coordinates();
00654     ptr_edge->mid_point(mid_pt);
00655     len = (mid_pt - start_pt).length() + (end_pt - mid_pt).length();
00656     if( len < min_edge_len )
00657     {
00658       min_edge_len = len;
00659     }
00660   }
00661   local_max_depth = (int)(log( max_range / min_edge_len) / log(2.0) ) + 1;
00662
00663  /*
00664   // calculate max_depth by comparing the min mesh size with max_range in log scale
00665   double min_mesh_size = max_range;
00666   double mesh_size;
00667   for( i = 0; i < list_edges.size(); i++ )
00668   {
00669     ptr_edge = list_edges.get_and_step();
00670
00671     mesh_size = max_range;
00672     MeshToolProxy* mesh_tool_ptr = MeshToolProxy::mesh_tool(ptr_edge);
00673     SizeIntervalType hardness;
00674     double tmp_size = mesh_tool_ptr->requested_interval_size(hardness);
00675     if (hardness > CALCULATED)
00676     {
00677       mesh_size = tmp_size/ 2.0;
00678     }
00679     if( mesh_size < min_mesh_size )
00680     {
00681       min_mesh_size = mesh_size;
00682     }
00683   }
00684   local_max_depth = std::max( local_max_depth, (int)(log( max_range / min_mesh_size) / log(2.0) ) + 1 );
00685 */
00686 /*
00687    // calculate max_depth by comparing the min mesh size with max_range in log scale
00688   DLIList< RefFace *> list_faces;
00689   volume->ref_faces( list_faces );
00690   min_mesh_size = max_range;
00691   RefFace *ptr_face;
00692   for( i = 0; i < list_faces.size(); i++ )
00693   {
00694     ptr_face = list_faces.get_and_step();
00695
00696     mesh_size = max_range;
00697     MeshToolProxy* mesh_tool_ptr = MeshToolProxy::mesh_tool(ptr_face);
00698     SizeIntervalType hardness;
00699     double tmp_size = mesh_tool_ptr->requested_interval_size(hardness);
00700     if (hardness > CALCULATED)
00701     {
00702       mesh_size = tmp_size/2.0;
00703     }
00704     if( mesh_size < min_mesh_size )
00705     {
00706       min_mesh_size = mesh_size;
00707     }
00708   }
00709   local_max_depth = std::max( local_max_depth, (int)(log( max_range / min_mesh_size) / log(2.0) ) + 1 );
00710 */
00711
00712   if( local_max_depth > MAX_DEPTH_OCTREE[OCTREE_TIME_ACCURACY_LEVEL] )
00713     local_max_depth = MAX_DEPTH_OCTREE[OCTREE_TIME_ACCURACY_LEVEL];
00714
00715   // make sure local_max_depth is atleast one depth higher than local_min_depth
00716   if( local_max_depth <= local_min_depth )
00717     local_max_depth = local_min_depth + 1;
00718
00719
00720
00721 }
00722
00723 // finds the optimal min and max depths of CubitOctree
00724 void CubitOctreeGeneratorVolumes::find_optimal_min_and_max_octree_depths( DLIList< RefEntity *> &entity_list, int &min_depth, int &max_depth )
00725 {
00726   DLIList< int > list_min_depth;
00727   DLIList< int > list_max_depth;
00728
00729   // traverse through the list of volumes and find optimal depth
00730   Body*volume;
00731   int index;
00732   int local_min_depth, local_max_depth;
00733   for( index = 0; index < entity_list.size(); index++ )
00734   {
00735     volume =  CAST_TO( entity_list.get_and_step(), Body );
00736     if( volume )
00737     {
00738       CubitOctreeGeneratorVolumes::find_optimal_min_and_max_depth( volume, local_min_depth, local_max_depth );
00739       list_min_depth.append( local_min_depth );
00740       list_max_depth.append( local_max_depth );
00741     }
00742   }
00743
00744   // find resultant min_depth and max_depth
00745   // for now let us take the floor of the average depth
00746   int avg_min_depth = 0;
00747   int avg_max_depth = 0;
00748   for( index = 0; index < list_min_depth.size(); index++ )
00749   {
00750     avg_min_depth += list_min_depth[index];
00751     avg_max_depth += list_max_depth[index];
00752   }
00753   avg_min_depth /= list_min_depth.size();
00754   avg_max_depth /= list_max_depth.size();
00755
00756   // assign min of initial value and avg depths as final answer
00757   min_depth = std::min( min_depth, avg_min_depth );
00758   max_depth = std::min( max_depth, avg_max_depth );
00759
00760 }
00761
00762 void CubitOctreeGeneratorVolumes::reset_td_octree_ref_face_visit( const CubitBoolean type ){
00763   int index, i;
00764   Body *volume;
00765   DLIList<RefFace *> vol_ref_faces;
00766
00767   for( index = 0; index < entityList.size(); index++ ){
00768     volume = CAST_TO( entityList.get_and_step(), Body );
00769     vol_ref_faces.clean_out();
00770     volume->ref_faces( vol_ref_faces );
00771     for( i = 0; i < vol_ref_faces.size(); i++ ){
00772       TDOctreeRefFace::get_td( vol_ref_faces.get_and_step() )->set_visit( type );
00773     }
00774   }
00775
00776   return;
00777 }
00778
00779
00780 void CubitOctreeGeneratorVolumes::reset_td_octree_ref_edge_visit( const CubitBoolean type ){
00781   int index, i;
00782   Body *volume;
00783   DLIList<RefEdge *> vol_ref_edges;
00784
00785   for( index = 0; index < entityList.size(); index++ ){
00786     volume = CAST_TO( entityList.get_and_step(), Body );
00787     vol_ref_edges.clean_out();
00788     volume->ref_edges( vol_ref_edges );
00789     for( i = 0; i < vol_ref_edges.size(); i++ ){
00790       TDOctreeRefEdge::get_td( vol_ref_edges.get_and_step() )->set_visit( type );
00791     }
00792   }
00793
00794   return;
00795 }
00796
00797 CubitBoolean CubitOctreeGeneratorVolumes::build_td_mref_faces( void ){
00798   DLIList< RefFace *> vol_ref_faces;
00799   RefFace *ptr_ref_face;
00800   TDOctreeRefFace *td_mref_face;
00801   DLIList<CubitFacet *> *facet_list;
00802   DLIList<CubitFacetEdge *> *facet_edge_list;
00803   DLIList<CubitPoint*> *point_list;
00804   int i;
00805   int index;
00806   Body *volume;
00807
00808   CubitBoolean identified_engine = CUBIT_FALSE;
00809   CubitBoolean is_facet_geom = CUBIT_FALSE;
00810
00811   for( index = 0; index < entityList.size(); index++ ){
00812     volume = CAST_TO( entityList.get_and_step(), Body );
00813     vol_ref_faces.clean_out();
00814     volume->ref_faces( vol_ref_faces );
00815     identified_engine = CUBIT_FALSE;
00816     for( i = 0; i < vol_ref_faces.size(); i++ ){
00817       ptr_ref_face = vol_ref_faces.get_and_step();
00818       if( ptr_ref_face->marked() == CUBIT_FALSE ){
00819         if (identified_engine == CUBIT_FALSE)
00820         {
00821           if (ptr_ref_face->get_geometry_query_engine()->get_engine_version_string().find("Facet") != CubitString::npos)
00822           {
00823             is_facet_geom = CUBIT_TRUE;
00824           }
00825           identified_engine = CUBIT_TRUE;
00826         }
00827
00828
00829         ptr_ref_face->marked( CUBIT_TRUE );
00830
00831         // Add TD for MRefFace
00832         TDOctreeRefFace::add_td(ptr_ref_face);
00833         facet_list = new DLIList<CubitFacet *>;
00834         facet_edge_list = new DLIList<CubitFacetEdge *>;
00835         point_list  = new DLIList<CubitPoint*>;
00836
00837         //PRINT_DEBUG_157(" \n\nRef Face = %d \n ", ptr_ref_face->id());
00838         //facet_list->clean_out();
00839         //point_list->clean_out();
00840         //facet_edge_list->clean_out();
00841
00842         if (is_facet_geom)
00843         {
00844           DLIList<CubitFacet*> facets;
00845           DLIList<CubitPoint*> points;
00846
00847           FacetSurface *facet_surf_ptr = CAST_TO(ptr_ref_face->get_surface_ptr(),FacetSurface);
00848           if (facet_surf_ptr != NULL)
00849           {
00850             facet_surf_ptr->get_my_facets(facets,points);
00851           }
00852           FacetDataUtil::copy_facets(facets,*facet_list,*point_list,*facet_edge_list);
00853           /*PRINT_INFO("Grabbed %d facets from surface %d\n", facet_list->size(),ptr_ref_face);
00854            PRINT_INFO("Grabbed %d facet edges from surface %d\n", facet_edge_list->size(),ptr_ref_face);
00855            PRINT_INFO("Grabbed %d facet points from surface %d\n", point_list->size(),ptr_ref_face);*/
00856         }
00857         else
00858         {
00859           GMem gmem;
00860           //Surface* surf_ptr = ptr_ref_face->get_surface_ptr();
00861           //surf_ptr->get_geometry_query_engine()->get_graphics(surf_ptr, &gmem);
00862           int angle = 15;
00863           float distance = 0;
00864           //SVDrawTool::get_facet_tolerance(angle, distance);
00865           angle = static_cast<int>(ANG_FACET_EXTRACT[OCTREE_TIME_ACCURACY_LEVEL]);
00866           //PRINT_INFO("\n Facets extracted with angle %d and distance %f \n", angle, distance );
00867           ptr_ref_face->get_graphics( gmem, angle, distance, 0 );
00868           ChollaEngine::get_facets(gmem, *facet_list, *point_list);
00869
00870           /*
00871            // delete point_list;
00872            // point_list = new DLIList<CubitPoint*>;
00873            point_list->clean_out();
00874
00875            DLIList<DLIList<CubitFacet *> *> shell_list;
00876
00877            CubitBoolean dummy2;
00878            double tol = SKL_EPSILON;
00879            DLIList <CubitQuadFacet *> qfacet_list;
00880            FacetDataUtil::split_into_shells(*facet_list, qfacet_list,shell_list, dummy2);
00881
00882            FacetDataUtil::stitch_facets(shell_list,tol,dummy2,false);
00883            //int nv,ne;
00884            //DLIList<CubitPoint*> un;
00885
00886            //FacetDataUtil::merge_coincident_vertices(shell_list,tol,nv,ne,un);
00887            facet_list = shell_list.get();
00888            PRINT_INFO("skl: number of shells = %d\n", shell_list.size());
00889
00890            FacetDataUtil::get_edges( *facet_list, *facet_edge_list );
00891            FacetDataUtil::get_points(*facet_list,*point_list);
00892            SVDrawTool::draw_facets(*facet_list,CUBIT_GREEN_INDEX);
00893            */
00894
00895           FacetDataUtil::get_edges( *facet_list, *facet_edge_list );
00896           /*
00897            // checks for problems with gfx facets
00898            // debug use only
00899            int v;
00900            for (v=0; v < facet_edge_list->size(); ++v)
00901            {
00902            CubitFacetEdge *temp_edge = facet_edge_list->get_and_step();
00903            if (temp_edge->num_adj_facets() != 2 && temp_edge->num_adj_facets() != 1)
00904            {
00905            PRINT_INFO("Skeleton sizing function, copying gfx facets: edge has %d adj facets!\n", temp_edge->num_adj_facets());
00906            SVDrawTool::draw_vector(temp_edge->point(0)->coordinates(), temp_edge->point(1)->coordinates(), CUBIT_RED_INDEX);
00907            SVDrawTool::mouse_xforms();
00908            }
00909            }
00910            int w;
00911            for (v=0; v < facet_list->size(); ++v)
00912            {
00913            CubitFacet *first = (*facet_list)[v];
00914            for (w=v+1; w < facet_list->size(); ++w)
00915            {
00916            CubitFacet *second = (*facet_list)[w];
00917            if (first == second)
00918            {
00919            PRINT_INFO("Skeleton Sizing Function: gfx facet list contains a duplicate, ids are %d,%d\n", first->id(), second->id());
00920            }
00921            }
00922            }
00923            */
00924         }
00925
00926         td_mref_face = TDOctreeRefFace::get_td(ptr_ref_face);
00927
00928         /*
00929          td_mref_face->set_ptr_cubit_facet_list(facet_list);
00930          td_mref_face->set_ptr_cubit_facet_edge_list(facet_edge_list);
00931          td_mref_face->set_ptr_cubit_point_list(point_list);
00932          */
00933         if( td_mref_face->get_ptr_cubit_facet_list() )
00934         {
00935           delete td_mref_face->get_ptr_cubit_facet_list();
00936           td_mref_face->set_ptr_cubit_facet_list(facet_list);
00937
00938         }
00939         else
00940         {
00941           td_mref_face->set_ptr_cubit_facet_list(facet_list);
00942         }
00943
00944         if( td_mref_face->get_ptr_cubit_facet_edge_list() )
00945         {
00946           delete td_mref_face->get_ptr_cubit_facet_edge_list();
00947           td_mref_face->set_ptr_cubit_facet_edge_list(facet_edge_list);
00948
00949         }
00950         else
00951         {
00952           td_mref_face->set_ptr_cubit_facet_edge_list(facet_edge_list);
00953         }
00954
00955         if( td_mref_face->get_ptr_cubit_point_list() )
00956         {
00957           delete td_mref_face->get_ptr_cubit_point_list();
00958           td_mref_face->set_ptr_cubit_point_list(point_list);
00959         }
00960         else
00961         {
00962           td_mref_face->set_ptr_cubit_point_list(point_list);
00963         }
00964
00965         // check for bad facets and disable 2dmat if necessary
00966         td_mref_face->check_valid_facets(CUBIT_TRUE);
00967         //if (!create_2dmat) {td_mref_face->set_create_2dmat(CUBIT_FALSE);}
00968       }
00969     }
00970   }
00971
00972   // Reset the marker of faces
00973   for( index = 0; index < entityList.size(); index++ ){
00974     volume = CAST_TO( entityList.get_and_step(), Body );
00975     vol_ref_faces.clean_out();
00976     volume->ref_faces( vol_ref_faces );
00977     for( i = 0; i < vol_ref_faces.size(); i++ ){
00978       vol_ref_faces.get_and_step()->marked( CUBIT_FALSE );
00979     }
00980   }
00981
00982   return CUBIT_TRUE;
00983 }
00984
00985
00986 CubitBoolean CubitOctreeGeneratorVolumes::build_td_mref_edges( void )
00987 {
00988   DLIList< RefEdge *> vol_mref_edges;
00989   RefEdge *ptr_mref_edge;
00990   TDOctreeRefEdge *td_mref_edge;
00991   int i;
00992   int index;
00993   Body *volume;
00994
00995   // Reset the marker of edges
00996   for( index = 0; index < entityList.size(); index++ ){
00997     volume = CAST_TO( entityList.get_and_step(), Body );
00998     vol_mref_edges.clean_out();
00999     volume->ref_edges( vol_mref_edges );
01000     for( i = 0; i < vol_mref_edges.size(); i++ ){
01001       ptr_mref_edge = vol_mref_edges.get_and_step();
01002       if( ptr_mref_edge->marked() == CUBIT_FALSE ){
01003         ptr_mref_edge->marked( CUBIT_TRUE );
01004         // Add TD for MRefEdge
01005         TDOctreeRefEdge::add_td(ptr_mref_edge);
01006         td_mref_edge = TDOctreeRefEdge::get_td(ptr_mref_edge);
01007         td_mref_edge->generate_gpoint_list(ANG_FACET_EXTRACT[OCTREE_TIME_ACCURACY_LEVEL] * OCTREE_TOLERANCE_FOR_CURVE_DECIMATION_FACTOR );
01008       }
01009     }
01010   }
01011
01012   // Reset the marker of edges
01013   for( index = 0; index < entityList.size(); index++ ){
01014     volume = CAST_TO( entityList.get_and_step(), Body );
01015     vol_mref_edges.clean_out();
01016     volume->ref_edges( vol_mref_edges );
01017     for( i = 0; i < vol_mref_edges.size();i++ ){
01018       vol_mref_edges.get_and_step()->marked( CUBIT_FALSE );
01019     }
01020   }
01021
01022   return CUBIT_TRUE;
01023 }
01024
01025
01026
01027 void CubitOctreeGeneratorVolumes::color_octreenode_via_grassfire( DLIList<CubitOctreeNode *> &queue_for_mat_generation )
01028 {
01029
01030   PriorityQueue<CubitOctreeNode *> heap( CubitOctreeNode::compare_function);
01031   CubitOctreeNode *ptr_grid_node;
01032
01033   // ************************* For Testing Purpose ***************************
01034   // int i;
01035   //for( i = 0; i < queue_for_mat_generation.size(); i++ ){
01036   //ptr_grid_node = queue_for_mat_generation.get_and_step();
01037
01038   //PRINT_DEBUG_157(" boundary node distance = %f \n",ptr_grid_node->get_distance() );
01039   //PRINT_DEBUG_157(" boundary node visit = %d \n",ptr_grid_node->get_visit() );
01040
01041   //PRINT_DEBUG_157(" mat initial grid = %f %f %f %f \n", ptr_grid_node->get_distance(), ptr_grid_node->get_coord().x(), ptr_grid_node->get_coord().y(), ptr_grid_node->get_coord().z() );
01042   //GfxDebug::draw_point( ptr_grid_node->get_coord().x(), ptr_grid_node->get_coord().y(), ptr_grid_node->get_coord().z(), CUBIT_YELLOW_INDEX );
01043   //ptr_grid_node->display( this, DISTANCE );
01044   //}
01045   // ************************* For Testing Purpose ***************************
01046
01047   //PRINT_DEBUG_157(" Num of initial points for mat generation = %d \n", queue_for_mat_generation.size() );
01048
01049   // Initialize the heap
01050   while( queue_for_mat_generation.size() > 0 ){
01051     heap.push( queue_for_mat_generation.pop() );
01052   }
01053
01054   // distance by default is CUBIT_DBL_MAX, and the white boundary nodes's distance is set to -1.
01055   //PRINT_DEBUG_157(" heap size = %d", heap.size() );
01056   //int draw_count = 1;
01057
01058
01059   while( heap.size() > 0 ){
01060     //        PRINT_INFO( " manhattan in process before opo() = %d \n",queue.size() );
01061     ptr_grid_node = heap.top();
01062     heap.pop();
01063
01064
01065     ptr_grid_node->find_distance_at_adj_node( &heap );
01066
01067        //       PRINT_INFO( " manhattan in process after NumberAdjNode() = %d \n", queue.size() );
01068   }
01069
01070 }
01071
01072 CubitStatus CubitOctreeGeneratorVolumes::generate_full_octree( void )
01073 {
01074   // all the functions of skeleton sizing function are called here
01075   CpuTimer octgentime;
01076   double time_octree_generation;
01077
01078   //ProgressTool *progressToolPtr = AppUtil::instance()->progress_tool();
01079   //assert(progressToolPtr != NULL );
01080   //char title[42]="Octree Generation in Progress ...";
01081   //progressToolPtr->start(0, 100, title, NULL, CUBIT_TRUE, CUBIT_TRUE);
01082
01083   //PRINT_DEBUG_157("\nENTER: Octree Generation \n");
01084
01085
01086   CpuTimer preproctime;
01087
01088     build_td_mref_faces();
01089     build_td_mref_edges();
01090
01091
01092   // this is used to store size and also used in 3D MAT generation
01093   CpuTimer gen_latt;
01094
01095   int min_depth = MIN_DEPTH_OCTREE[OCTREE_TIME_ACCURACY_LEVEL];
01096   int max_depth = MAX_DEPTH_OCTREE[OCTREE_TIME_ACCURACY_LEVEL];
01097   CubitOctreeGeneratorVolumes::find_optimal_min_and_max_octree_depths( entityList, min_depth, max_depth );
01098   get_octree_lattice()->set_max_depth(std::min( get_octree_lattice()->get_max_depth(), max_depth) );
01099   get_octree_lattice()->set_min_depth(std::max( get_octree_lattice()->get_min_depth(), min_depth) );
01100   //PRINT_INFO("\nOctree min_depth = %d, max_depth = %d\n", min_depth, max_depth);
01101
01102   generate_lattice();
01103   //PRINT_INFO("profiling: time in generate_lattice: %f\n", gen_latt.cpu_secs());
01104
01105  // PRINT_DEBUG_157("AFTER: octree lattice generation\n");
01106
01107
01108   //PRINT_DEBUG_157("BEFORE smooth transiton number of nodes = %d\n",gridNodeVector.size() );
01109   CpuTimer time_to_balance;
01110   get_octree_lattice()->establish_smooth_transition_of_cells( max_depth ); //OCTREE_MAX_DEPTH_OCTREE[OCTREE_TIME_ACCURACY_LEVEL] );
01111  // PRINT_INFO("profiling: time to balance octree: %f\n", time_to_balance.cpu_secs());
01112
01113 //  PRINT_DEBUG_157("AFTER smooth transiton \n" );
01114
01115   // Finds the intersection between the facets and the octree
01116   CpuTimer intersection_time;
01117   DLIList<CubitOctreeNode *> queue_for_3Dmat_generation;
01118  find_intersection_between_octree_and_facets( queue_for_3Dmat_generation );
01119   //PRINT_INFO("profiling: intersection time: %f\n", intersection_time.cpu_secs());
01120
01121   //PRINT_DEBUG_157("AFTER intersection between facets and octree \n" );
01122
01123
01124   //PRINT_DEBUG_157("\nDONE: Octree Generation \n" );
01125   //progressToolPtr->percent(1.0);
01126
01127   if( AppUtil::instance()->interrupt() ){
01128     //CubitBoolean interruptStatus;
01129     PRINT_WARNING("\n Killed  octree generation...\n");
01130     //interruptStatus = CUBIT_TRUE;
01131     //progressToolPtr->end();
01132     return CUBIT_FAILURE;
01133   }
01134
01135   color_octreenode_via_grassfire( queue_for_3Dmat_generation );
01136
01137   color_lattice_cell();
01138
01139
01140   time_octree_generation = octgentime.cpu_secs();
01141
01142
01143
01144
01145   PRINT_INFO("Total time for octree generation: %f\n", time_octree_generation);
01146
01147   return CUBIT_SUCCESS;
01148 }
01149
01150
01151 // OPTIMIZE: priorityqueue -> dlist/queue
01152 // EOF
01153
