cgma
FacetBody.cpp
00001 //-------------------------------------------------------------------------
00002 // Filename      : FacetBody.cpp
00003 //
00004 // Purpose       :
00005 //
00006 // Special Notes :
00007 //
00008 // Creator       : David White
00009 //
00010 // Creation Date : 7/18/00
00011 //
00012 //-------------------------------------------------------------------------
00013
00014 // ********** BEGIN STANDARD INCLUDES      **********
00015 #include <assert.h>
00016 // ********** END STANDARD INCLUDES        **********
00017
00018
00019 // ********** BEGIN CUBIT INCLUDES         **********
00020 #include "CubitDefines.h"
00021 #include "CubitString.hpp"
00022 #include "CubitPoint.hpp"
00023 #include "CastTo.hpp"
00024 #include "BodySM.hpp"
00025 #include "Body.hpp"
00026 #include "FacetBody.hpp"
00027 #include "CubitSimpleAttrib.hpp"
00028 #include "FacetQueryEngine.hpp"
00029 #include "DLIList.hpp"
00030 #include "FacetEvalTool.hpp"
00031 #include "CurveFacetEvalTool.hpp"
00032 #include "Surface.hpp"
00033 #include "FacetSurface.hpp"
00034 #include "CubitTransformMatrix.hpp"
00035 #include "FacetPoint.hpp"
00036 #include "FacetCurve.hpp"
00037 #include "FacetCoEdge.hpp"
00038 #include "FacetLoop.hpp"
00039 #include "FacetShell.hpp"
00040 #include "FacetLump.hpp"
00041 #include "CubitFacetEdge.hpp"
00042 #include "FacetModifyEngine.hpp"
00043 #include "FacetAttrib.hpp"
00044 #include "GfxDebug.hpp"
00045 #include "CubitSimpleAttrib.hpp"
00046 #include "CubitPointData.hpp"
00047
00048 //-------------------------------------------------------------------------
00049 // Purpose       : A constructor with a list of lumps that are attached.
00050 //
00051 // Special Notes :
00052 //
00053 //-------------------------------------------------------------------------
00054 FacetBody::FacetBody(DLIList<Lump*>& my_lumps)
00055 {
00056   myLumps += my_lumps;
00057 }
00058 FacetBody::~FacetBody()
00059 {
00060     //Not sure what to do..
00061 }
00062
00063 GeometryQueryEngine* FacetBody::get_geometry_query_engine() const
00064 {
00065   return FacetQueryEngine::instance();
00066 }
00067
00068 void FacetBody::append_simple_attribute_virt(const CubitSimpleAttrib &csa)
00069   { attribSet.append_attribute(csa); }
00070
00071 void FacetBody::remove_simple_attribute_virt(const CubitSimpleAttrib &csa)
00072   { attribSet.remove_attribute(csa); }
00073
00074 void FacetBody::remove_all_simple_attribute_virt()
00075   { attribSet.remove_all_attributes(); }
00076
00077 CubitStatus FacetBody::get_simple_attribute(DLIList<CubitSimpleAttrib>& csa_list)
00078   { return attribSet.get_attributes(csa_list); }
00079
00080 CubitStatus FacetBody::get_simple_attribute( const CubitString& name,
00081                                           DLIList<CubitSimpleAttrib>& csa_list )
00082   { return attribSet.get_attributes( name, csa_list ); }
00083
00084 CubitStatus FacetBody::save_attribs( FILE *file_ptr )
00085   { return attribSet.save_attributes( file_ptr); }
00086
00087 CubitStatus FacetBody::restore_attribs( FILE *file_ptr, unsigned int endian )
00088   { return attribSet.restore_attributes( file_ptr, endian ); }
00089
00090
00091
00092 //----------------------------------------------------------------
00093 // Function: copy
00094 // Description: create a new copy of the body.
00095 // Author: sjowen
00096 //----------------------------------------------------------------
00097 BodySM* FacetBody::copy()
00098 {
00099   CubitStatus rv;
00100
00101   // ----------Copy the points on the body------------------------
00102
00103   std::map<TopologyBridge*, TopologyBridge*> old_to_new_map;
00104
00105   std::map<CubitPoint*, CubitPoint*> old_to_new_cubit_pts;
00106
00107   int ii;
00108   DLIList<FacetPoint*> point_list;
00109   get_points(point_list);
00110   DLIList<TBPoint*> copy_points;
00111   point_list.reset();
00112   TBPoint *point_ptr;
00113   TBPoint *point_copy;
00114   for(ii=0; ii<point_list.size(); ii++)
00115   {
00116     point_ptr = point_list.get_and_step();
00117     CubitVector temp_vector = point_ptr->coordinates();
00118
00119     CubitPoint *new_cubit_point = new CubitPointData( temp_vector );
00120
00121     rv = FacetModifyEngine::instance()->make_facet_point( new_cubit_point,
00122                                                            point_copy);
00123
00124     if(rv != CUBIT_SUCCESS)
00125     {
00126       PRINT_ERROR("Couldn't copy points");
00127       return (BodySM *)NULL;
00128     }
00129     copy_points.append( point_copy );
00130
00131     FacetPoint *old_fp = static_cast<FacetPoint*>(point_ptr);
00132
00133     old_to_new_cubit_pts.insert(
00134       std::make_pair(old_fp->get_cubit_point(), new_cubit_point ) );
00135
00136     old_to_new_map.insert(
00137       std::make_pair( point_ptr, point_copy ) );
00138   }
00139
00140   // ------------------Copy the curves-------------------------
00141
00142   int jj;
00143   std::map<FacetCurve*, FacetCurve*> hard_line_curve_map;
00144   DLIList<FacetCurve*> curve_list;
00145   get_curves( curve_list );
00146   DLIList<Curve*> copy_curves;
00147   curve_list.reset();
00148   Curve *curve_ptr, *curve_copy;
00149   FacetCurve *fcurve;
00150   TBPoint *ptsm_ptr;
00151   TBPoint *start_ptr, *end_ptr, *copy_start = NULL, *copy_end = NULL;
00152   for (ii=0; ii<curve_list.size(); ii++)
00153   {
00154     curve_ptr = curve_list.get_and_step();
00155     fcurve = CAST_TO( curve_ptr, FacetCurve );
00156     start_ptr = fcurve->start_point();
00157     end_ptr = fcurve->end_point();
00158     int found0 = 0;
00159     int found1 = 0;
00160
00161     // find the end points
00162
00163     point_list.reset();
00164     copy_points.reset();
00165     for (jj=0; jj<point_list.size() && (!found0 || !found1); jj++)
00166     {
00167       point_ptr = point_list.get_and_step();
00168       ptsm_ptr = CAST_TO(point_ptr, TBPoint);
00169       point_copy = copy_points.get_and_step();
00170       if (ptsm_ptr == start_ptr)
00171       {
00172         copy_start = point_copy;
00173         found0 = 1;
00174       }
00175       if (ptsm_ptr == end_ptr)
00176       {
00177         copy_end = point_copy;
00178         found1 = 1;
00179       }
00180     }
00181
00182     // create the new curve and update the points
00183
00184     rv = FacetModifyEngine::instance()->make_facet_curve(copy_start,
00185                                                            copy_end,
00186                                                            curve_copy);
00187     if(rv != CUBIT_SUCCESS)
00188     {
00189       PRINT_ERROR("Couldn't copy curves");
00190       return (BodySM *)NULL;
00191     }
00192
00193
00194     CurveFacetEvalTool *eval_tool = fcurve->get_eval_tool();
00195     DLIList<CubitFacetEdge*> facet_edges;
00196     eval_tool->get_facets( facet_edges );
00197     CubitFacetEdge *tmp_facet_edge = facet_edges.get();
00198     DLIList<CubitFacet*> adj_facets;
00199     tmp_facet_edge->facets( adj_facets );
00200     CubitFacet *tmp_facet = adj_facets.get_and_step();
00201     tmp_facet->tool_id();
00202
00203     for( int k=adj_facets.size(); k--; )
00204     {
00205       if( tmp_facet_edge->num_adj_facets_on_surf( adj_facets.get_and_step()->tool_id() ) > 1 )
00206       {
00207         hard_line_curve_map.insert(
00208           std::map<FacetCurve*, FacetCurve*>::value_type( static_cast<FacetCurve*>( CAST_TO( curve_copy, FacetCurve )),fcurve ));
00209         break;
00210       }
00211     }
00212
00213     old_to_new_map.insert(
00214       std::make_pair( curve_ptr, curve_copy ) );
00215
00216     copy_curves.append( curve_copy );
00217   }
00218
00219   // ------------------copy coedges-----------------------
00220
00221   DLIList<FacetCoEdge*> coedge_list;
00222   get_coedges( coedge_list );
00223   DLIList<CoEdgeSM*> copy_coedges;
00224   coedge_list.reset();
00225   Curve *curvsm_ptr;
00226   Curve *curvsm_copy = NULL;
00227   CoEdgeSM *coedge_ptr, *coedge_copy;
00228   FacetCoEdge *fcoedge;
00229   for (ii=0; ii<coedge_list.size(); ii++)
00230   {
00231     coedge_ptr = coedge_list.get_and_step();
00232     fcoedge = CAST_TO( coedge_ptr, FacetCoEdge );
00233     Curve *curve_at_coedge = fcoedge->curve();
00234     int found = 0;
00235
00236     // find the associated curve
00237
00238     curve_list.reset();
00239     copy_curves.reset();
00240     for (jj=0; jj<curve_list.size() && !found; jj++)
00241     {
00242       curve_ptr = curve_list.get_and_step();
00243       curvsm_ptr = CAST_TO(curve_ptr, Curve);
00244       curvsm_copy = copy_curves.get_and_step();
00245       if (curve_at_coedge == curvsm_ptr)
00246       {
00247         found = 1;
00248       }
00249     }
00250
00251     // create the new coedge
00252
00253     CubitSense sense = fcoedge->sense();
00254     rv = FacetModifyEngine::instance()->make_facet_coedge(curvsm_copy,
00255                                                     sense, coedge_copy);
00256     if(rv != CUBIT_SUCCESS)
00257     {
00258       PRINT_ERROR("Couldn't copy coedge");
00259       return (BodySM *)NULL;
00260     }
00261     copy_coedges.append( coedge_copy );
00262   }
00263
00264   // ----------------------copy loops--------------------------
00265
00266   int kk;
00267   DLIList<FacetLoop*> loop_list;
00268   get_loops( loop_list );
00269   DLIList<LoopSM*> copy_loops;
00270   loop_list.reset();
00271   LoopSM *loop_ptr, *loop_copy;
00272   FacetLoop *floop;
00273   for (ii=0; ii<loop_list.size(); ii++)
00274   {
00275     floop = loop_list.get_and_step();
00276     DLIList<FacetCoEdge *>coedges_on_loop;
00277     floop->get_coedges(coedges_on_loop);
00278     DLIList<CoEdgeSM *>copy_coedges_on_loop;
00279
00280     // find all associated coedges on the loop
00281
00282     for(kk=0; kk<coedges_on_loop.size(); kk++)
00283     {
00284       int found = 0;
00285       coedge_list.reset();
00286       copy_coedges.reset();
00287       CoEdgeSM *coedge_on_loop = coedges_on_loop.get_and_step();
00288       for (jj=0; jj<coedge_list.size() && !found; jj++)
00289       {
00290         coedge_ptr = coedge_list.get_and_step();
00291         coedge_copy = copy_coedges.get_and_step();
00292         if (coedge_on_loop == coedge_ptr)
00293         {
00294           found = 1;
00295           copy_coedges_on_loop.append(coedge_copy);
00296         }
00297       }
00298     }
00299
00300     // create the new loop
00301
00302     rv = FacetModifyEngine::instance()->make_facet_loop(copy_coedges_on_loop,
00303                                                           loop_copy);
00304     if(rv != CUBIT_SUCCESS)
00305     {
00306       PRINT_ERROR("Couldn't copy loops");
00307       return (BodySM *)NULL;
00308     }
00309     copy_loops.append( loop_copy );
00310   }
00311
00312   // ----------------------copy surfaces--------------------------
00313   DLIList<FacetSurface*> surface_list;
00314   get_surfaces(surface_list);
00315   DLIList<Surface*> copy_surfaces;
00316   surface_list.reset();
00317   Surface *surface_ptr, *surface_copy;
00318   FacetSurface *fsurface;
00319   for (ii=0; ii<surface_list.size(); ii++)
00320   {
00321     fsurface = surface_list.get_and_step();
00322     DLIList<FacetLoop *>loops_on_surface;
00323     fsurface->get_loops(loops_on_surface);
00324     DLIList<LoopSM *>copy_loops_on_surface;
00325
00326     // find all associated loops on the surface
00327
00328     for(kk=0; kk<loops_on_surface.size(); kk++)
00329     {
00330       int found = 0;
00331       loop_list.reset();
00332       copy_loops.reset();
00333       LoopSM *loop_on_surface = loops_on_surface.get_and_step();
00334       for (jj=0; jj<loop_list.size() && !found; jj++)
00335       {
00336         loop_ptr = loop_list.get_and_step();
00337         loop_copy = copy_loops.get_and_step();
00338         if (loop_on_surface == loop_ptr)
00339         {
00340           found = 1;
00341           copy_loops_on_surface.append(loop_copy);
00342         }
00343       }
00344     }
00345
00346     // create the new surface
00347
00348     DLIList<CubitFacet*>facet_list;
00349     DLIList<CubitPoint*>cpoint_list;
00350     rv = fsurface->copy_facets( facet_list, cpoint_list, old_to_new_cubit_pts );
00351     if (rv != CUBIT_SUCCESS)
00352     {
00353       return (BodySM *)NULL;
00354     }
00355     int interp_order = fsurface->interp_order();
00356     double min_dot = fsurface->min_dot();
00357     const CubitEvaluatorData *eval_data = fsurface->evaluator_data();
00358     CubitBoolean use_point_addresses = CUBIT_FALSE;
00359     rv = FacetModifyEngine::instance()->make_facet_surface(eval_data,
00360                                                            facet_list,
00361                                                            cpoint_list,
00362                                                            copy_loops_on_surface,
00363                                                            interp_order,
00364                                                            min_dot,
00365                                                            surface_copy,
00366                                                            use_point_addresses,
00367                                                            NULL,
00368                                                            &hard_line_curve_map);
00369     if(rv != CUBIT_SUCCESS)
00370     {
00371       PRINT_ERROR("Couldn't copy surfaces");
00372       return (BodySM *)NULL;
00373     }
00374
00375     old_to_new_map.insert(
00376       std::make_pair( fsurface, surface_copy ) );
00377
00378     copy_surfaces.append( surface_copy );
00379   }
00380
00381   // ----------------------copy shells--------------------------
00382
00383   DLIList<FacetShell*> shell_list;
00384   get_shells(shell_list);
00385   DLIList<ShellSM*> copy_shells;
00386   shell_list.reset();
00387   ShellSM *shell_ptr, *shell_copy;
00388   FacetShell *fshell;
00389   for (ii=0; ii<shell_list.size(); ii++)
00390   {
00391     fshell = shell_list.get_and_step();
00392     DLIList<FacetSurface *>surfaces_on_shell;
00393     fshell->get_surfaces(surfaces_on_shell);
00394     DLIList<Surface *>copy_surfaces_on_shell;
00395
00396     // find all associated loops on the surface
00397
00398     for(kk=0; kk<surfaces_on_shell.size(); kk++)
00399     {
00400       int found = 0;
00401       surface_list.reset();
00402       copy_surfaces.reset();
00403       Surface *surface_on_shell = surfaces_on_shell.get_and_step();
00404       for (jj=0; jj<surface_list.size() && !found; jj++)
00405       {
00406         surface_ptr = surface_list.get_and_step();
00407         surface_copy = copy_surfaces.get_and_step();
00408         if (surface_on_shell == surface_ptr)
00409         {
00410           found = 1;
00411           copy_surfaces_on_shell.append(surface_copy);
00412         }
00413       }
00414     }
00415
00416     // create the new shell
00417
00418     rv = FacetModifyEngine::instance()->make_facet_shell(copy_surfaces_on_shell,
00419                                                            shell_copy);
00420     if(rv != CUBIT_SUCCESS)
00421     {
00422       PRINT_ERROR("Couldn't copy shell");
00423       return (BodySM *)NULL;
00424     }
00425
00426     // set the sense of the surfaces on the shell - copy from the old shell
00427
00428     FacetShell *fshell_copy = CAST_TO(shell_copy, FacetShell);
00429     surfaces_on_shell.reset();
00430     copy_surfaces_on_shell.reset();
00431     for (kk=0; kk<surfaces_on_shell.size(); kk++)
00432     {
00433       Surface *surface_on_shell = surfaces_on_shell.get_and_step();
00434       Surface *copy_surface_on_shell = copy_surfaces_on_shell.get_and_step();
00435       fsurface = CAST_TO( surface_on_shell, FacetSurface );
00436       CubitSense sense = fsurface->get_shell_sense(fshell);
00437       FacetSurface *copy_fsurface = CAST_TO( copy_surface_on_shell, FacetSurface );
00438       copy_fsurface->set_shell_sense( fshell_copy, sense );
00439     }
00440     copy_shells.append( shell_copy );
00441   }
00442
00443   // ----------------------copy lumps--------------------------
00444
00445   DLIList<FacetLump*> lump_list;
00446   get_lumps(lump_list);
00447   DLIList<Lump*> copy_lumps;
00448   lump_list.reset();
00449   Lump *lump_copy;
00450   FacetLump *flump;
00451   for (ii=0; ii<lump_list.size(); ii++)
00452   {
00453     flump = lump_list.get_and_step();
00454     DLIList<FacetShell *>shells_on_lump;
00455     flump->get_shells(shells_on_lump);
00456     DLIList<ShellSM *>copy_shells_on_lump;
00457
00458     // find all associated loops on the surface
00459
00460     for(kk=0; kk<shells_on_lump.size(); kk++)
00461     {
00462       int found = 0;
00463       shell_list.reset();
00464       copy_shells.reset();
00465       ShellSM *shell_on_lump = shells_on_lump.get_and_step();
00466       for (jj=0; jj<shell_list.size() && !found; jj++)
00467       {
00468         shell_ptr = shell_list.get_and_step();
00469         shell_copy = copy_shells.get_and_step();
00470         if (shell_on_lump == shell_ptr)
00471         {
00472           found = 1;
00473           copy_shells_on_lump.append(shell_copy);
00474         }
00475       }
00476     }
00477
00478     // create the new lump
00479
00480     rv = FacetModifyEngine::instance()->make_facet_lump(copy_shells_on_lump,
00481                                                           lump_copy);
00482     if(rv != CUBIT_SUCCESS)
00483     {
00484       PRINT_ERROR("Couldn't copy lump");
00485       return (BodySM *)NULL;
00486     }
00487
00488     old_to_new_map.insert(
00489       std::make_pair( flump, lump_copy ) );
00490
00491     copy_lumps.append( lump_copy );
00492   }
00493
00494   // ----------------------copy body--------------------------
00495
00496   BodySM *body_copy;
00497   rv = FacetModifyEngine::instance()->make_facet_body(copy_lumps,
00498                                                         body_copy);
00499   if(rv != CUBIT_SUCCESS)
00500   {
00501     PRINT_ERROR("Couldn't copy lump");
00502     return (BodySM *)NULL;
00503   }
00504
00505   //copy the attributes from old to new
00506   std::map<TopologyBridge*, TopologyBridge*>::iterator iter;
00507   for( iter= old_to_new_map.begin(); iter != old_to_new_map.end(); iter++ )
00508   {
00509     TopologyBridge *old_tb = iter->first;
00510     TopologyBridge *new_tb = iter->second;
00511
00512     DLIList<CubitSimpleAttrib> old_attribs;
00513     old_tb->get_simple_attribute( old_attribs );
00514
00515     for( int i=old_attribs.size(); i--; )
00516     {
00517       const CubitSimpleAttrib& copy = old_attribs.get_and_step();
00518       new_tb->append_simple_attribute_virt( copy );
00519     }
00520   }
00521
00522   return (BodySM*)body_copy;
00523 }
00524 //----------------------------------------------------------------
00525 // Function: can_be_deleted
00526 // Description: determine if the body can be deleted
00527 //
00528 // Author: sjowen
00529 //----------------------------------------------------------------
00530 CubitBoolean FacetBody::can_be_deleted( DLIList <Body*> &body_list )
00531 {
00532   CubitBoolean delete_ok = CUBIT_TRUE;
00533   DLIList<FacetSurface *>surf_list;
00534   get_surfaces(surf_list);
00535   int ii;
00536   for (ii=0; ii<surf_list.size() && delete_ok; ii++)
00537   {
00538     FacetSurface *surf_ptr = surf_list.get_and_step();
00539     DLIList<FacetBody*>my_body_list;
00540     surf_ptr->get_bodies(my_body_list);
00541     int jj;
00542     if (my_body_list.size() >= 2)
00543     {
00544       for (jj=0; jj<my_body_list.size() && delete_ok; jj++)
00545       {
00546         BodySM *my_body_ptr = my_body_list.get_and_step();
00547         if (my_body_ptr != this)
00548         {
00549           int kk;
00550           int found = 0;
00551           for (kk=0; kk<body_list.size() && !found; kk++)
00552           {
00553             Body *body_ptr = body_list.get_and_step();
00554             FacetBody* fbody_ptr = CAST_TO(body_ptr->get_body_sm_ptr(), FacetBody);
00555             if (fbody_ptr)
00556             {
00557               if (my_body_ptr == fbody_ptr)
00558                 found = 1;
00559             }
00560           }
00561           if (!found)
00562           {
00563             delete_ok = CUBIT_FALSE;
00564             PRINT_ERROR("Body cannot be deleted because it is merged with adjacent Body\n");
00565             PRINT_INFO("    Mesh Based Geometry entities cannot be unmerged.\n"
00566               "    Try using the no_merge option when importing the mesh\n");
00567           }
00568         }
00569       }
00570     }
00571   }
00572   return delete_ok;
00573 }
00574
00575 //----------------------------------------------------------------
00576 // Function: move
00577 // Description: translate the body and its child entities
00578 //
00579 // Author: sjowen
00580 //----------------------------------------------------------------
00581 CubitStatus FacetBody::move(double dx, double dy, double dz)
00582 {
00583   CubitTransformMatrix tfmat;
00584   tfmat.translate( dx, dy, dz );
00585
00586   CubitStatus stat = transform( tfmat, CUBIT_FALSE );
00587
00588   if (stat == CUBIT_SUCCESS)
00589     myTransforms.translate( dx, dy, dz );
00590
00591   return stat;
00592 }
00593
00594
00595 //----------------------------------------------------------------
00596 // Function: rotate
00597 // Description: rotate the body and its child entities
00598 //
00599 // Author: sjowen
00600 //----------------------------------------------------------------
00601 CubitStatus FacetBody::rotate( double x, double y, double z,
00602                                double angle_in_degrees )
00603 {
00604
00605   CubitTransformMatrix rotmat;
00606   CubitVector axis( x, y, z );
00607   rotmat.rotate( angle_in_degrees, axis );
00608
00609   CubitStatus stat = transform( rotmat, CUBIT_TRUE );
00610
00611   if (stat == CUBIT_SUCCESS)
00612     myTransforms.rotate( angle_in_degrees, axis );
00613
00614   return stat;
00615 }
00616
00617 //----------------------------------------------------------------
00618 // Function: scale
00619 // Description: scale the body and its child entities
00620 //              use a constant scale factor
00621 //
00622 // Author: sjowen
00623 //----------------------------------------------------------------
00624 CubitStatus FacetBody::scale(double scale_factor )
00625 {
00626   return scale(scale_factor,scale_factor,scale_factor);
00627 }
00628
00629 //----------------------------------------------------------------
00630 // Function: scale
00631 // Description: scale the body and its child entities
00632 //
00633 // Author: sjowen
00634 //----------------------------------------------------------------
00635 CubitStatus FacetBody::scale(double scale_factor_x,
00636                              double scale_factor_y,
00637                              double scale_factor_z )
00638 {
00639   CubitTransformMatrix scalemat;
00640   scalemat.scale_about_origin( scale_factor_x,
00641                                scale_factor_y,
00642                                scale_factor_z );
00643
00644   CubitStatus stat = transform( scalemat, CUBIT_FALSE );
00645
00646   if (stat == CUBIT_SUCCESS)
00647     myTransforms.scale_about_origin( scale_factor_x,
00648                                      scale_factor_y,
00649                                      scale_factor_z );
00650
00651   // scale the facetcurve
00652
00653   DLIList<FacetCurve *> curve_list;
00654   get_curves(curve_list);
00655   Curve *curv_ptr;
00656   for (int ii=0; ii<curve_list.size(); ii++)
00657   {
00658     curv_ptr = curve_list.get_and_step();
00659     FacetCurve *fcurve = CAST_TO( curv_ptr, FacetCurve );
00660     if (fcurve)
00661     {
00662       fcurve->reset_length();
00663     }
00664   }
00665
00666   return stat;
00667 }
00668
00669 //----------------------------------------------------------------
00670 // Function: restore
00671 // Description: restore the body and its child entities
00672 //              to its original coordinates using the inverse
00673 //              transformation matrix
00674 //
00675 // Author: sjowen
00676 //----------------------------------------------------------------
00677 CubitStatus FacetBody::restore()
00678 {
00679   // invert the transformation matrix and apply to entities
00680   // (assumes an orthogonal matrix (ie. no shear or non-uniform scaling)
00681
00682   CubitTransformMatrix inverse_mat;
00683   inverse_mat = myTransforms.inverse();
00684
00685   CubitStatus stat = transform( inverse_mat, CUBIT_TRUE );
00686
00687   if (stat == CUBIT_SUCCESS)
00688     myTransforms.set_to_identity();
00689
00690   return stat;
00691 }
00692
00693 //----------------------------------------------------------------
00694 // Function: reflect
00695 // Description: reflect the body about a exis
00696 //
00697 // Author: sjowen
00698 //----------------------------------------------------------------
00699 CubitStatus FacetBody::reflect( double reflect_axis_x,
00700                                 double reflect_axis_y,
00701                                 double reflect_axis_z )
00702 {
00703   CubitTransformMatrix reflectmat;
00704   CubitVector reflect_vector( reflect_axis_x,
00705                               reflect_axis_y,
00706                               reflect_axis_z );
00707   reflectmat.reflect( reflect_vector );
00708
00709   CubitStatus stat = transform( reflectmat, CUBIT_TRUE );
00710
00711   if (stat == CUBIT_SUCCESS)
00712     myTransforms.reflect( reflect_vector );
00713
00714   return stat;
00715 }
00716
00717 //----------------------------------------------------------------
00718 // Function: transform
00719 // Description: transform the body based on a transformation matrix
00720 //              main function for applying transformations to
00721 //              facet-based bodies
00722 //
00723 // Author: sjowen
00724 //----------------------------------------------------------------
00725 CubitStatus FacetBody::transform( CubitTransformMatrix &tfmat,
00726                                   CubitBoolean is_rotation )
00727 {
00728   int ii;
00729
00730   // get the list of surfaces on the body
00731
00732   DLIList<FacetSurface *>surf_list;
00733   get_surfaces( surf_list );
00734   Surface *surf;
00735   FacetSurface *fsurf;
00736   FacetEvalTool *ftool;
00737   //CubitVector min, max;
00738
00739   // go through all the surfaces and collect the list of all points.
00740   // (some may be listed on multiple surfaces)
00741
00742   DLIList<CubitPoint *>point_list;
00743   for (ii=0; ii<surf_list.size(); ii++)
00744   {
00745     surf = surf_list.get_and_step();
00746     fsurf = CAST_TO( surf, FacetSurface );
00747     fsurf->get_my_points( point_list );
00748   }
00749
00750   // unmark all the points so we can keep track of the ones that have
00751   // already been transformed
00752
00753   CubitPoint *cp;
00754   for (ii=0; ii<point_list.size(); ii++)
00755   {
00756     cp = point_list.get_and_step();
00757     cp->marked( 0 );
00758   }
00759
00760   // transform the points
00761
00762   //CubitVector norm, du, dv;
00763   for (ii=0; ii<point_list.size(); ii++)
00764   {
00765     cp = point_list.get_and_step();
00766     if (!cp->marked())
00767     {
00768       cp->transform( tfmat );
00769       if (is_rotation)
00770         cp->rotate_normal( tfmat );
00771       cp->marked( 1 );
00772     }
00773   }
00774
00775   // check the vertices - make sure they are transformed
00776
00777   FacetPoint *fpt;
00778   TBPoint *pt;
00779   DLIList<FacetPoint*>gpoint_list;
00780   get_points(gpoint_list);
00781   for (ii=0; ii<gpoint_list.size(); ii++)
00782   {
00783     pt = gpoint_list.get_and_step();
00784     fpt = CAST_TO( pt, FacetPoint );
00785
00786     // only transform the point if it isn't already part of the facets
00787     // (they could be points by themselves)
00788
00789     cp = fpt->get_cubit_point();
00790     if (cp->num_adj_facets() == 0)
00791     {
00792       cp->transform( tfmat );
00793       if (is_rotation)
00794         cp->rotate_normal( tfmat );
00795     }
00796   }
00797
00798   // reset the bounding box and update the facet normal and plane
00799
00800   // init flags on edges to 0
00801   DLIList<Surface*> tmp_surf_list( surf_list.size() );
00802   CAST_LIST_TO_PARENT( surf_list, tmp_surf_list );
00803   init_edge_flags( tmp_surf_list, 0 );
00804   for (ii=0; ii<surf_list.size(); ii++)
00805   {
00806     surf = surf_list.get_and_step();
00807     fsurf = CAST_TO( surf, FacetSurface );
00808
00809     // if we are using a bspline representation, then we also need to
00810     // transform the control points on the edges and facets
00811
00812     ftool = fsurf->get_eval_tool();
00813     if (ftool->interp_order() == 4)
00814     {
00815       ftool->transform_control_points( tfmat );
00816     }
00817
00818     DLIList<CubitFacet *>flist;
00819     DLIList<CubitPoint *>plist;
00820     fsurf->get_my_facets( flist, plist);
00821     int jj;
00822     CubitFacet *facet_ptr;
00823     for (jj=0; jj<flist.size(); jj++)
00824     {
00825       facet_ptr = flist.get_and_step();
00826       facet_ptr->update_plane();
00827       facet_ptr->reset_bounding_box();
00828     }
00829       //must be done after facet's are reset...
00830     ftool->reset_bounding_box();
00831     // if this facet surface has a primitive evaluator, then we need
00832     // to tell it about the transformation also.
00833     fsurf->add_transformation( tfmat );
00834
00835       //re-calculate the area of the surface in case it changed
00836     fsurf->update_measurement();
00837   }
00838   init_edge_flags( tmp_surf_list, 0 );
00839
00840     // Some transforms (those incorporating reflections)
00841     // invert the geometry.  Correct for it.
00842     // -- jason k.
00843   if ( tfmat.sub_matrix(3,3).determinant() < 0.0 )
00844   {
00845       // Flip CoFace senses
00846     DLIList<FacetShell*> shells;
00847     get_shells( shells );
00848     //modified.  mbrewer.  doing both a reverse and a
00849     //reverse_surfaces.  the latter actually changes the
00850     // underlying surfaces so that the normals can all
00851     // still be outward pointing.  It automatically changes
00852     // the sense, therefore we also still need excplicity
00853     // call reverse so that sense is corrected.
00854     while (shells.size()){
00855       shells.get()->reverse_surfaces();
00856       shells.pop()->reverse();
00857     }
00858   }
00859
00860   return CUBIT_SUCCESS;
00861 }
00862
00863 //----------------------------------------------------------------
00864 // Function: init_edge_flags
00865 // Description: set the flags on the facet edges
00866 // Note:  Only done for facet eval tool with order 4 interpolation
00867 // Author: sjowen
00868 //----------------------------------------------------------------
00869 void FacetBody::init_edge_flags( DLIList<Surface *>&surf_list,
00870                                  int )
00871 {
00872   int ii, jj;
00873   Surface *surf;
00874   FacetSurface *fsurf;
00875   FacetEvalTool *ftool;
00876   CubitFacetEdge *edge_ptr;
00877
00878   for (ii=0; ii<surf_list.size(); ii++)
00879   {
00880     DLIList<CubitFacetEdge*>edge_list;
00881     surf = surf_list.get_and_step();
00882     fsurf = CAST_TO( surf, FacetSurface );
00883     ftool = fsurf->get_eval_tool();
00884     if (ftool->interp_order() == 4)
00885     {
00886       ftool->get_edges( edge_list );
00887       for (jj=0; jj<edge_list.size(); jj++)
00888       {
00889         edge_ptr = edge_list.get_and_step();
00890         edge_ptr->set_flag( 0 );
00891       }
00892     }
00893   }
00894 }
00895
00896 CubitStatus FacetBody::get_transforms( CubitTransformMatrix &tfm )
00897 {
00898   tfm = myTransforms;
00899   return CUBIT_SUCCESS;
00900 }
00901
00902 CubitStatus FacetBody::set_transforms( CubitTransformMatrix tfm )
00903 {
00904   myTransforms = tfm;
00905   return CUBIT_SUCCESS;
00906 }
00907
00908 int FacetBody::validate(const CubitString &, DLIList <TopologyEntity*>&)
00909 {
00910   PRINT_ERROR("This option is not available for mesh defined geometry.\n");
00911   return 0;
00912 }
00913
00914 void FacetBody::get_parents_virt( DLIList<TopologyBridge*>& )
00915   {}
00916
00917 void FacetBody::get_children_virt( DLIList<TopologyBridge*>& lumps )
00918   { CAST_LIST_TO_PARENT( myLumps, lumps ); }
00919
00920 void FacetBody::get_lumps( DLIList<FacetLump*>& result_list )
00921 {
00922   myLumps.reset();
00923   for ( int i = 0; i < myLumps.size(); i++ )
00924     if ( FacetLump* lump = dynamic_cast<FacetLump*>(myLumps.next(i)) )
00925       result_list.append(lump);
00926 }
00927
00928 void FacetBody::get_shells( DLIList<FacetShell*>& result_list )
00929 {
00930   DLIList<FacetLump*> lump_list;
00931   get_lumps( lump_list );
00932   lump_list.reset();
00933   for ( int i = 0; i < lump_list.size(); i++ )
00934     lump_list.next(i)->get_shells( result_list );
00935 }
00936
00937 void FacetBody::get_surfaces( DLIList<FacetSurface*>& result_list )
00938 {
00939   DLIList<FacetShell*> shell_list;
00940   DLIList<FacetSurface*> tmp_list;
00941   get_shells(shell_list);
00942   shell_list.reset();
00943   for ( int i = 0; i < shell_list.size(); i++ )
00944   {
00945     tmp_list.clean_out();
00946     shell_list.next(i)->get_surfaces( tmp_list );
00947     result_list.merge_unique( tmp_list );
00948   }
00949 }
00950
00951 void FacetBody::get_loops( DLIList<FacetLoop*>& result_list )
00952 {
00953   DLIList<FacetSurface*> surface_list;
00954   get_surfaces( surface_list );
00955   surface_list.reset();
00956   for ( int i = 0; i < surface_list.size(); i++ )
00957     surface_list.next(i)->get_loops( result_list );
00958 }
00959
00960 void FacetBody::get_coedges( DLIList<FacetCoEdge*>& result_list )
00961 {
00962   DLIList<FacetSurface*> surface_list;
00963   get_surfaces( surface_list );
00964   surface_list.reset();
00965   for ( int i = 0; i < surface_list.size(); i++ )
00966     surface_list.next(i)->get_coedges( result_list );
00967 }
00968
00969 void FacetBody::get_curves( DLIList<FacetCurve*>& result_list )
00970 {
00971   DLIList<FacetCoEdge*> coedge_list;
00972   get_coedges( coedge_list );
00973   coedge_list.reset();
00974   for ( int i = coedge_list.size(); i--; )
00975   {
00976     FacetCoEdge* coedge = coedge_list.get_and_step();
00977     FacetCurve* curve = dynamic_cast<FacetCurve*>(coedge->curve());
00978     if (curve)
00979       result_list.append_unique(curve);
00980   }
00981 }
00982
00983 void FacetBody::get_points( DLIList<FacetPoint*>& result_list )
00984 {
00985   DLIList<FacetCurve*> curve_list;
00986   get_curves( curve_list );
00987   curve_list.reset();
00988   for ( int i = curve_list.size(); i--; )
00989   {
00990     FacetCurve* curve = curve_list.get_and_step();
00991     FacetPoint* point = dynamic_cast<FacetPoint*>(curve->start_point());
00992     if (point)
00993       result_list.append_unique(point);
00994     point = dynamic_cast<FacetPoint*>(curve->end_point());
00995     if (point)
00996       result_list.append_unique(point);
00997   }
00998 }
00999
01000 void FacetBody::add_lump( FacetLump *lump_to_add )
01001 {
01002   Lump* lump = dynamic_cast<Lump*>(lump_to_add);
01003   if (lump)
01004   {
01005     lump_to_add->add_body(this);
01006     myLumps.append( lump );
01007   }
01008 }
01009
01010 void FacetBody::remove_lump( FacetLump *lump_to_remove )
01011 {
01012   FacetLump* lump = dynamic_cast<FacetLump*>(lump_to_remove);
01013   if (lump)
01014   {
01015     assert(lump_to_remove->get_body() == this);
01016     lump_to_remove->remove_body();
01017     myLumps.remove( lump );
01018   }
01019 }
01020
01021
01022 //-------------------------------------------------------------------------
01023 // Purpose       : Tear down topology
01024 //
01025 // Special Notes :
01026 //
01027 // Creator       : Jason Kraftcheck
01028 //
01029 // Creation Date : 09/29/03
01030 //-------------------------------------------------------------------------
01031 void FacetBody::disconnect_all_lumps()
01032 {
01033   myLumps.reset();
01034   for (int i = myLumps.size(); i--; )
01035   {
01036     Lump* sm_ptr = myLumps.get_and_step();
01037     FacetLump* lump = dynamic_cast<FacetLump*>(sm_ptr);
01038     if (lump)
01039     {
01040       assert(lump->get_body() == this);
01041       lump->remove_body();
01042     }
01043   }
01044   myLumps.clean_out();
01045 }
01046
01047 //-------------------------------------------------------------------------
01048 // Purpose       : Find centroid
01049 //
01050 // Special Notes :
01051 //
01052 // Creator       : Jason Kraftcheck
01053 //
01054 // Creation Date : 05/10/04
01055 //-------------------------------------------------------------------------
01056 CubitStatus FacetBody::mass_properties( CubitVector& centroid,
01057                                         double& volume )
01058 {
01059   centroid.set( 0.0, 0.0, 0.0 );
01060   volume = 0.0;
01061
01062   DLIList<FacetLump*> lumps (myLumps.size());
01063   CAST_LIST( myLumps, lumps, FacetLump );
01064   assert( myLumps.size() == lumps.size() );
01065   for (int i = lumps.size(); i--; )
01066   {
01067     CubitVector cent;
01068     double vol;
01069     if (CUBIT_SUCCESS != lumps.get_and_step()->mass_properties(cent,vol))
01070       return CUBIT_FAILURE;
01071     centroid += vol*cent;
01072     volume += vol;
01073   }
01074   if (volume > CUBIT_RESABS)
01075   {
01076     centroid /= volume;
01077   }
01078   else
01079   {
01080     centroid.set( 0.0, 0.0, 0.0 );
01081     volume = 0.0;
01082   }
01083
01084   return CUBIT_SUCCESS;
01085 }
01086
01087 //-------------------------------------------------------------------------
01088 // Purpose       : Used to be FacetQueryEngine::is_point_in_body
01089 //
01090 // Special Notes :
01091 //
01092 // Creator       : Jason Kraftcheck
01093 //
01094 // Creation Date : 05/10/04
01095 //-------------------------------------------------------------------------
01096 CubitPointContainment FacetBody::point_containment( const CubitVector &point, double tolerance )
01097 {
01098   CubitPointContainment pc_value;
01099   FacetLump *facet_lump;
01100
01101   int i;
01102   for(i=myLumps.size(); i--;)
01103   {
01104     facet_lump = dynamic_cast<FacetLump*>(myLumps.get_and_step());
01105     pc_value = facet_lump->point_containment( point, tolerance );
01106     if( pc_value == CUBIT_PNT_INSIDE )
01107       return CUBIT_PNT_INSIDE;
01108     else if( pc_value == CUBIT_PNT_BOUNDARY )
01109       return CUBIT_PNT_BOUNDARY;
01110   }
01111
01112   return CUBIT_PNT_OUTSIDE;
01113 }
01114
01115
