Here is a list of all file members with links to the files they belong to:
- c -
- CA_ALL_ATTRIBUTES
: CADefines.hpp
- CA_ASSEMBLY_DATA
: CADefines.hpp
- CA_BODIES
: CADefines.hpp
- CA_COMPOSITE_VG
: CADefines.hpp
- CA_COORD_SYS
: CADefines.hpp
- CA_CURVE_CONTACT
: CADefines.hpp
- CA_CURVE_CONVECTION
: CADefines.hpp
- CA_CURVE_DISPLACEMENT
: CADefines.hpp
- CA_CURVE_FORCE
: CADefines.hpp
- CA_CURVE_HEATFLUX
: CADefines.hpp
- CA_CURVE_PRESSURE
: CADefines.hpp
- CA_CURVE_TEMPERATURE
: CADefines.hpp
- CA_DEFERRED_ATTRIB
: CADefines.hpp
- CA_ENTITY_COLOR
: CADefines.hpp
- CA_ENTITY_ID
: CADefines.hpp
- CA_ENTITY_NAME
: CADefines.hpp
- CA_ENTITY_SENSE
: CADefines.hpp
- CA_ENTITY_TOL
: CADefines.hpp
- CA_GENESIS_ENTITY
: CADefines.hpp
- CA_GRAPHICS_OPTS
: CADefines.hpp
- CA_GROUP
: CADefines.hpp
- CA_MATERIAL_BLOCK
: CADefines.hpp
- CA_MERGE_PARTNER
: CADefines.hpp
- CA_MERGE_STATUS
: CADefines.hpp
- CA_MESH_CONTAINER
: CADefines.hpp
- CA_MESH_INTERVAL
: CADefines.hpp
- CA_MESH_OUTPUT_GROUP
: CADefines.hpp
- CA_MESH_RELATIVE_LENGTH
: CADefines.hpp
- CA_MESH_SCHEME
: CADefines.hpp
- CA_PARTITION_VG
: CADefines.hpp
- CA_PROPERTY_BLOCK
: CADefines.hpp
- CA_SIZING_FUNCTION_SKELETON
: CADefines.hpp
- CA_SMOOTH_SCHEME
: CADefines.hpp
- CA_SOURCE_FEATURE
: CADefines.hpp
- CA_SURFACE_CONTACT
: CADefines.hpp
- CA_SURFACE_CONVECTION
: CADefines.hpp
- CA_SURFACE_DISPLACEMENT
: CADefines.hpp
- CA_SURFACE_FORCE
: CADefines.hpp
- CA_SURFACE_HEATFLUX
: CADefines.hpp
- CA_SURFACE_PRESSURE
: CADefines.hpp
- CA_SURFACE_TEMPERATURE
: CADefines.hpp
- CA_UNDEFINED
: CADefines.hpp
- CA_UNIQUE_ID
: CADefines.hpp
- CA_VERTEX_DISPLACEMENT
: CADefines.hpp
- CA_VERTEX_FORCE
: CADefines.hpp
- CA_VERTEX_TEMPERATURE
: CADefines.hpp
- CA_VERTEX_TYPE
: CADefines.hpp
- CA_VIRTUAL_VG
: CADefines.hpp
- CA_VOLUME_DISPLACEMENT
: CADefines.hpp
- CAAssemblyData_creator()
: InitCGMA.cpp
- CABodies_creator()
: CABodies.cpp
, CABodies.hpp
- CACompositeVG_creator()
: CACompositeVG.cpp
, CACompositeVG.hpp
- CACreateFunction
: CubitAttribManager.hpp
- CADeferredAttrib_creator()
: CADeferredAttrib.cpp
, CADeferredAttrib.hpp
- CAEntityColor_creator()
: CAEntityColor.cpp
, CAEntityColor.hpp
- CAEntityId_creator()
: CAEntityId.cpp
, CAEntityId.hpp
- CAEntityName_creator()
: CAEntityName.cpp
, CAEntityName.hpp
- CAEntitySense_creator()
: CAEntitySense.cpp
, CAEntitySense.hpp
- CAEntityTol_creator()
: CAEntityTol.cpp
, CAEntityTol.hpp
- CAGroup_creator()
: CAGroup.cpp
, CAGroup.hpp
- CALCULATED
: CubitDefines.h
- CAMergePartner_creator()
: CAMergePartner.cpp
, CAMergePartner.hpp
- CAMergeStatus_creator()
: CAMergeStatus.cpp
, CAMergeStatus.hpp
- CAPartitionVG_creator()
: CAPartitionVG.cpp
, CAPartitionVG.hpp
- CAPSULE_DIST
: CubitOctreeConstants.hpp
- CASourceFeature_creator()
: CASourceFeature.cpp
, CASourceFeature.hpp
- CAST_LIST
: CastTo.hpp
- CAST_LIST_TO_IDS
: CastTo.hpp
- CAST_LIST_TO_PARENT
: CastTo.hpp
- CAST_TO
: CastTo.hpp
- CAST_TO_VOID
: iGeom_CGMA.cc
- CATIA_IMPORT_DEFAULT_LOG
: GeometryQueryEngine.hpp
- CATIA_NCGM_TYPE
- CATIA_TYPE
- CATPART_TYPE
- CATPRODUCT_TYPE
- CAUniqueId_creator()
: CAUniqueId.cpp
, CAUniqueId.hpp
- CAVirtualVG_creator()
: CAVirtualVG.cpp
, CAVirtualVG.hpp
- cBit
: CubitDefines.h
- CELL_INDEX_ALLOC_SIZE
: AllocMemManagersList.cpp
- CGM_ENGINE_EXPORT_CREATE_GME
: CGMEngineDynamicLoader.hpp
, OCCModifyEngine.cpp
- CGM_ENGINE_EXPORT_CREATE_GQE
, OCCQueryEngine.cpp
- CGM_EXPORT_ENGINE_SYM
- CGM_F77_MAIN
: CGMConfig.h
- CGM_FC_FUNC
: CGMConfig.h
- CGM_FC_FUNC_
: CGMConfig.h
- CGM_FC_MAIN
: CGMConfig.h
- CGM_HAVE_DLFCN_H
: CGMConfig.h
- CGM_HAVE_INTTYPES_H
: CGMConfig.h
- CGM_HAVE_MEMORY_H
: CGMConfig.h
- CGM_HAVE_STDINT_H
: CGMConfig.h
- CGM_HAVE_STDLIB_H
: CGMConfig.h
- CGM_HAVE_STRING_H
: CGMConfig.h
- CGM_HAVE_STRINGS_H
: CGMConfig.h
- CGM_HAVE_SYS_STAT_H
: CGMConfig.h
- CGM_HAVE_SYS_TYPES_H
: CGMConfig.h
- CGM_HAVE_UNISTD_H
: CGMConfig.h
- CGM_iGeom_clearLastError()
: iGeomError.cc
, iGeomError.h
- CGM_iGeom_getLastErrorDesc()
: iGeomError.cc
, iGeomError.h
- CGM_iGeom_getLastErrorType()
: iGeomError.cc
, iGeomError.h
- CGM_iGeom_register()
: CGM_iGeom.h
- CGM_iGeom_setLastError()
: iGeomError.cc
, iGeomError.h
- CGM_LT_OBJDIR
: CGMConfig.h
- CGM_MAJOR_VERSION
: CGMConfig.h
- CGM_MINOR_VERSION
: CGMConfig.h
- CGM_PACKAGE
: CGMConfig.h
- CGM_PACKAGE_BUGREPORT
: CGMConfig.h
- CGM_PACKAGE_NAME
: CGMConfig.h
- CGM_PACKAGE_STRING
: CGMConfig.h
- CGM_PACKAGE_TARNAME
: CGMConfig.h
- CGM_PACKAGE_URL
: CGMConfig.h
- CGM_PACKAGE_VERSION
: CGMConfig.h
- CGM_read_parallel_debug
: CGMReadParallel.cpp
- CGM_STDC_HEADERS
: CGMConfig.h
- cgm_type_names
: iGeom_CGMA.cc
- CGM_VERSION
: CGMConfig.h
- CGM_VERSION_PATCH
: CGMConfig.h
- CGM_VERSION_STRING
: CGMConfig.h
- CGMA_IGEOM_EXPORT
: CGMIGeomConfigure.h
- CGMA_INIT_EXPORT
: CGMInitConfigure.h
- CGMA_opt_inhibit_intersect_errs
: mcnp2cad.cpp
- CGMEngineCreateModifyEngine
: CGMEngineDynamicLoader.cpp
- CGMEngineCreateQueryEngine
- CGMFOErrorCode
: CGMFileOptions.hpp
- CGMParallelActions
- CGMParallelActionsNames
- CGMPartitionActions
- CHECK
: copy_attrib.cpp
, mergetest.cc
, test_edge_orient.cc
, testgeom.cc
, fileoptions.cpp
- CHECK_BUF_SIZE
: volumes.hpp
- CHECK_IGEOM
: volumes.hpp
- CHECK_SIZE
: CATag.cpp
- check_valid_edge()
: brick.cpp
- check_valid_face()
: brick.cpp
- check_valid_loop()
: brick.cpp
- checkEdgeOrientation()
: test_edge_orient.cc
- checkMemoryAllocations()
: Cholla.cpp
- CHOLLA_FILE
: FacetQueryEngine.hpp
- circumsphere()
: TetFacetorTool.cpp
- classify_local_convexity_at_edge()
: Cholla.cpp
- cme_create_cosurf()
: CompositeEngine.cpp
- cme_hide_surface()
- cme_unhide_surface()
- COLLAPSE_TOLERANCE
: FacetDataUtil.cpp
- CommonDefine
: DLList.hpp
- CommonDefine2
: SDLList.hpp
- CommonSortedDefine
: SDLList.hpp
- compare_box()
: testgeom.cc
- CompLoopTool
- COMPOSITE
: GeometryDefines.h
- COMPOSITE_DATA_ATTRIB_NAME
: CompositeGeom.cpp
- COMPOSITE_LAYER
: VGDefines.h
- COMPSURF_KEEP_CPT_STATS
: GeometryUtil.cpp
- CONE_SURFACE_TYPE
: GeometryDefines.h
- CONST_CAST_LIST
: CastTo.hpp
- CONSTRAINT
: ElementType.h
- construct_test()
: testgeom.cc
- constructBezier()
: Cholla.h
, Cholla.cpp
- constructQuadNormals()
: Cholla.h
, Cholla.cpp
- constructQuadNormalsFromFile()
: Cholla.h
, Cholla.cpp
- constructQuadVerts()
: Cholla.cpp
- constructTriNormals()
: Cholla.h
, Cholla.cpp
- constructTriNormalsFromFile()
: Cholla.h
, Cholla.cpp
- constructTriVerts()
: Cholla.cpp
- CONTINUE
: ImprintBoundaryTool.hpp
- copy_ibase_type()
: iGeom_CGMA.cc
- copy_vec
: AnalyticGeometryTool.hpp
- COPYUIDMap
: TDUniqueId.hpp
- count_ibase_type()
: iGeom_CGMA.cc
- count_num_with_tag()
: testgeom.cc
- count_type()
: iGeom_CGMA.cc
- counter_id
: CubitFacetEdgeData.cpp
, CubitFacetData.cpp
, FaceterFacetData.cpp
- create_bbox_tets()
- CREATE_NEW_VERTEX
: ImprintPointData.hpp
- create_tri_facets()
: ChollaEngine.cpp
- CreateGeometry()
: CreateGeometry.cpp
- CROSS_INTERSECT
- CUBIT_ASSOC_BC_BLOCK
: CubitDefines.h
- CUBIT_ASSOC_BC_NSET
: CubitDefines.h
- CUBIT_ASSOC_BC_SSET
: CubitDefines.h
- CUBIT_ASSOC_GEOM_REFENTITY
: CubitDefines.h
- CUBIT_ASSOC_NULL
: CubitDefines.h
- CUBIT_BLACK
: CubitColor.hpp
, CubitColorConstants.hpp
- CUBIT_BLACK_INDEX
: CubitColor.hpp
- CUBIT_BLUE
: CubitColorConstants.hpp
, CubitColor.hpp
- CUBIT_BLUE_INDEX
: CubitColor.hpp
- cubit_box_identical()
: TestUtilities.cpp
, TestUtilities.hpp
- CUBIT_BROWN
: CubitColor.hpp
- CUBIT_BROWN_INDEX
: CubitColor.hpp
- CUBIT_CAMERA
: DrawingToolDefines.h
- CUBIT_CAMERA_MOVE_FLY
- CUBIT_CAMERA_MOVE_PAN
- CUBIT_CAMERA_MOVE_SPIN
- CUBIT_COMPAT_FT_ELIF
: CubitCompat.cpp
- CUBIT_CORAL
: CubitColor.hpp
- CUBIT_CORAL_INDEX
: CubitColor.hpp
- CUBIT_CYAN
, CubitColor.hpp
- CUBIT_CYAN_INDEX
: CubitColor.hpp
- CUBIT_DBL_MAX
: CubitDefines.h
- CUBIT_DBL_MIN
: CubitDefines.h
- CUBIT_DEBUG_1
: CubitMessage.hpp
- CUBIT_DEFAULT_COLOR
: CubitColor.hpp
- CUBIT_DEFAULT_COLOR_INDEX
: CubitColor.hpp
- CUBIT_DIAGNOSTIC
: CubitMessage.hpp
- CUBIT_ERROR
: CubitMessage.hpp
- CUBIT_ERROR_EXPECTED
: CubitMessage.hpp
- CUBIT_FACET_FILE
- CUBIT_FACET_POINT_DATA_EDGE
: OctreeFacetPointData.hpp
- CUBIT_FACET_POINT_DATA_FACET
- CUBIT_FACET_POINT_DATA_POINT
- CUBIT_FAILURE
: CubitDefines.h
- CUBIT_FALSE
: CubitDefines.h
- CUBIT_FB_INTERSECTION
: CubitDefines.h
- CUBIT_FB_SUBTRACTION
: CubitDefines.h
- CUBIT_FB_UNION
: CubitDefines.h
- CUBIT_FLAT_SHADING
- CUBIT_FORWARD
: CubitDefines.h
- CUBIT_GEOM_EXPORT
: CGMGeomConfigure.h
- CUBIT_GOLD
, CubitColor.hpp
- CUBIT_GOLD_INDEX
: CubitColor.hpp
- CUBIT_GRAPHICS_POINT_CIRCLED_DOT
- CUBIT_GRAPHICS_POINT_OPEN_CIRCLE
- CUBIT_GRAPHICS_POINT_PLUS
- CUBIT_GRAPHICS_POINT_SOLID_CIRCLE
- CUBIT_GRAPHICS_POINT_X
- CUBIT_GREEN
: CubitColor.hpp
- CUBIT_GREEN_INDEX
: CubitColor.hpp
- CUBIT_GREY
: CubitColor.hpp
- CUBIT_GREY_INDEX
: CubitColor.hpp
- CUBIT_HIDDEN_LINE
- CUBIT_INFO
: CubitMessage.hpp
- CUBIT_INT_MAX
: CubitDefines.h
- CUBIT_INT_MIN
: CubitDefines.h
- cubit_intr
: AppUtil.cpp
- CUBIT_INVALID_DRAW_MODE
- CUBIT_LABEL_ELEMENT_ID
- CUBIT_LABEL_FIRMNESS
- CUBIT_LABEL_ID
- CUBIT_LABEL_INTERVAL
- CUBIT_LABEL_IS_MERGED
- CUBIT_LABEL_MERGE
- CUBIT_LABEL_NAME
- CUBIT_LABEL_NAME_ID
- CUBIT_LABEL_NAME_ONLY
- CUBIT_LABEL_NONE
- CUBIT_LABEL_SCHEME
- CUBIT_LABEL_SIZE
- CUBIT_LABEL_SPHERE_ID
- CUBIT_LIGHTBLUE
, CubitColor.hpp
- CUBIT_LIGHTBLUE_INDEX
: CubitColor.hpp
- CUBIT_LIGHTGREEN
, CubitColor.hpp
- CUBIT_LIGHTGREEN_INDEX
: CubitColor.hpp
- CUBIT_MAGENTA
, CubitColor.hpp
- CUBIT_MAGENTA_INDEX
: CubitColor.hpp
- CUBIT_MAX
: CubitFacet.cpp
, CubitDefines.h
- CUBIT_MAX_3
: SurfaceOverlapFacet.hpp
- CUBIT_MAX_4
: CubitDefines.h
- CUBIT_MIN
: FaceterFacetData.cpp
, CubitDefines.h
, CubitFacet.cpp
- CUBIT_MIN_3
- CUBIT_MIN_4
: CubitDefines.h
- CUBIT_OCTREE_EDGE
- CUBIT_OCTREE_FACE
- CUBIT_OCTREE_VOLUME
- CUBIT_ORANGE
, CubitColor.hpp
- CUBIT_ORANGE_INDEX
: CubitColor.hpp
- CUBIT_PAINTERS
- CUBIT_PI
: CubitDefines.h
- CUBIT_PINK
: CubitColor.hpp
- CUBIT_PINK_INDEX
: CubitColor.hpp
- CUBIT_PNT_BOUNDARY
: CubitDefines.h
- CUBIT_PNT_INSIDE
: CubitDefines.h
- CUBIT_PNT_OFF
: CubitDefines.h
- CUBIT_PNT_ON
: CubitDefines.h
- CUBIT_PNT_OUTSIDE
: CubitDefines.h
- CUBIT_PNT_UNKNOWN
: CubitDefines.h
- CUBIT_POLYGON_FILL
- CUBIT_RED
: CubitColor.hpp
- CUBIT_RED_INDEX
: CubitColor.hpp
- CUBIT_RELATION_CHILD
: CubitDefines.h
- CUBIT_RELATION_NONE
: CubitDefines.h
- CUBIT_RELATION_PARENT
: CubitDefines.h
- CUBIT_RESABS
: GeometryDefines.h
- CUBIT_REVERSED
: CubitDefines.h
- CUBIT_SALMON
: CubitColor.hpp
- CUBIT_SALMON_INDEX
: CubitColor.hpp
- CUBIT_SCREEN
- CUBIT_SEARCH_CHILD
: ModelQueryEngine.hpp
- CUBIT_SEARCH_NO_DIRECTION
- CUBIT_SEARCH_PARENT
- CUBIT_SMOOTH_SHADING
- CUBIT_SMOOTH_TRANSPARENT
- CUBIT_STRING_PRINTF_FORMAT
: CubitString.hpp
- CUBIT_SUCCESS
: CubitDefines.h
- CUBIT_TRI
: ElementType.h
- CUBIT_TRUE
: CubitDefines.h
- CUBIT_TRUE_HIDDEN_LINE
- CUBIT_UNKNOWN
: CubitDefines.h
- cubit_update_terminal_size()
: AppUtil.cpp
- CUBIT_UTIL_EXPORT
: CGMUtilConfigure.h
- CUBIT_VERY_SMALL_NUMBER
: GeometryQueryTool.cpp
- CUBIT_WARNING
: CubitMessage.hpp
- CUBIT_WHITE
: CubitColor.hpp
- CUBIT_WHITE_INDEX
: CubitColor.hpp
- CUBIT_WIRE_FRAME
- CUBIT_WORLD
- CUBIT_YELLOW
: CubitColor.hpp
- CUBIT_YELLOW_INDEX
: CubitColor.hpp
- CUBIT_ZOOM_DOWN
- CUBIT_ZOOM_LEFT
- CUBIT_ZOOM_RIGHT
- CUBIT_ZOOM_UP
- CubitAssocDataType
: CubitDefines.h
- CubitAttributeType
: CADefines.hpp
- CubitBoolean
: CubitDefines.h
- CubitCompat_export_solid_model()
: CubitCompat.cpp
, CubitCompat.hpp
- CubitCompat_file_type()
: CubitCompat.cpp
- CubitCompat_import_solid_model()
: CubitCompat.hpp
, CubitCompat.cpp
- CubitEntityRelation
: CubitDefines.h
- CubitFacetboolOp
: CubitDefines.h
- CubitGraphicsPointStyle
- CubitLabelType
- CubitOctreeType
- CubitPointContainment
: CubitDefines.h
- CubitSearchDirection
- CubitSense
: CubitDefines.h
- CubitStatus
: CubitDefines.h
- CUTOFF_BBOX_RANGE_RATIO
- CUTOFF_NUM_NODES
- CUTOFF_OCTREE_DEPTH
- CYLINDER_SURFACE_TYPE
: GeometryDefines.h
