MeshKit
1.0
00001 /* 00002 * AF2Polygon3D.hpp 00003 * 00004 * \brief An immutable not-necessarily flat polygon whose vertices are 00005 * AF2Point3D points. 00006 * 00007 * Perhaps a better name would be a closed wire rather than a polygon, 00008 * for the way it is represented here, but the object is defined in 00009 * terms of its vertices and is intended to correspond to a 00010 * two-dimensional element of a mesh. This is also a close analog 00011 * of the AF2Polygon2D, except that it has three-dimensional vertices. 00012 * 00013 * The vertices are numbered 0 through n - 1, where n is the number of 00014 * polygon vertices. As the numbers increase, the polygon is traversed 00015 * counterclockwise. Thus the interior of the polygon is to the left 00016 * of the edge from vertex i to vertex i + 1 modulo n. 00017 * 00018 * This class holds on to its vertices with pointers, but it does not 00019 * manage the memory for its vertices. It is the reponsibility of the 00020 * context that uses AF2Polygon3D to ensure that pointers to vertices 00021 * remain valid as long as they may be referenced by an AF2Polygon3D instance. 00022 */ 00023 #ifndef AF2POLYGON3D_HPP 00024 #define AF2POLYGON3D_HPP 00025 00026 // C++ 00027 #include <list> 00028 00029 // MeshKit 00030 #include "meshkit/AF2Point3D.hpp" 00031 00032 class AF2Polygon3D 00033 { 00034 private: 00035 00036 unsigned int numVertices; 00037 const AF2Point3D** vertices; 00038 00039 public: 00040 00059 AF2Polygon3D(std::list<const AF2Point3D*> const & polygonVertices); 00060 00064 ~AF2Polygon3D(); 00065 00074 AF2Polygon3D(const AF2Polygon3D & toCopy); 00075 00084 AF2Polygon3D& operator=(const AF2Polygon3D & rhs); 00085 00091 unsigned int getNumVertices() const; 00092 00103 const AF2Point3D* getVertex(unsigned int vtxNum) const; 00104 }; 00105 00106 #endif
