MeshKit
1.0
00001 /* 00002 * FastArea.c++ 00003 * 00004 * From the paper: 00005 * 00006 * Daniel Sunday 00007 * "Fast Polygon Area and Newell Normal Computation" 00008 * journal of graphics tools, 7(2):9-13, 2002 00009 * 00010 */ 00011 00012 // assume vertex coordinates are in arrays x[], y[], and z[] 00013 00014 // with room to duplicate the first two vertices at the end 00015 00016 00017 // return the signed area of a 2D polygon 00018 00019 #include <math.h> 00020 #include <iostream> 00021 00022 using namespace std; 00023 00024 inline double 00025 PolygonArea(int n, double *x, double *y) // 2D polygon 00026 00027 { 00028 // guarantee the first two vertices are also at array end 00029 00030 x[n] = x[0]; y[n] = y[0]; 00031 x[n+1] = x[1]; y[n+1] = y[1]; 00032 00033 double sum = 0.0; 00034 double *xptr = x+1, *ylow = y, *yhigh = y+2; 00035 for (int i=1; i <= n; i++) { 00036 sum += (*xptr++) * ( (*yhigh++) - (*ylow++) ); 00037 } 00038 00039 return 0.5*sum ; 00040 } 00041 00042 // return the signed area of a 3D planar polygon (given normal vector) 00043 00044 inline double 00045 PolygonArea3D(int n, double *x, double *y, double *z, // 3D planar polygon 00046 00047 double nx, double ny, double nz) // and plane normal 00048 00049 { 00050 // select largest normal coordinate to ignore for projection 00051 // CSV: Original Code seeems to have bug: Need to verify it. 00052 00053 double ax = (nx>0 ? nx : -nx); // abs nx 00054 00055 double ay = (ny>0 ? ny : -ny); // abs ny 00056 00057 double az = (nz>0 ? nz : -nz); // abs nz 00058 00059 double len = sqrt(nx*nx + ny*ny + nz*nz); // length of normal 00060 00061 00062 if (ax > ay) { 00063 if (ax > az) // ignore x-coord 00064 00065 // CSV return PolygonArea(n, y, z) * (len / nx); 00066 return PolygonArea(n, y, z) * (len / ax); 00067 } 00068 else if (ay > az) // ignore y-coord 00069 00070 // CSV return PolygonArea(n, z, x) * (len / ny); 00071 return PolygonArea(n, z, x) * (len / ay); 00072 00073 //CSV return PolygonArea(n, x, y) * (len / nz); // ignore z-coord 00074 return PolygonArea(n, x, y) * (len / az); // ignore z-coord 00075 00076 } 00077 00078 // output the approximate unit normal of a 3D nearly planar polygon 00079 // return the area of the polygon 00080 00081 inline double 00082 PolygonNormal3D(int n, double *x, double *y, double *z, // 3D polygon 00083 double *nx, double *ny, double *nz) // output unit normal 00084 00085 { 00086 // get the Newell normal 00087 00088 double nwx = PolygonArea(n, y, z); 00089 double nwy = PolygonArea(n, z, x); 00090 double nwz = PolygonArea(n, x, y); 00091 00092 // get length of the Newell normal 00093 00094 double nlen = sqrt( nwx*nwx + nwy*nwy + nwz*nwz ); 00095 // compute the unit normal 00096 00097 double multby = 1.0/( double)nlen; 00098 00099 *nx = multby*nwx; 00100 *ny = multby*nwy; 00101 *nz = multby*nwz; 00102 00103 return nlen; // area of polygon = length of Newell normal 00104 } 00105 00106 inline 00107 double PolygonArea3D( int n, double *x, double *y, double *z) 00108 { 00109 double nx, ny, nz; 00110 PolygonNormal3D( n, x, y, z, &nx, &ny, &nz ); 00111 00112 return PolygonArea3D( n, x, y, z, nx, ny, nz ); 00113 } 00114
