MeshKit
1.0
00001 /*****************************************************************************/ 00002 /* */ 00003 /* Routines for Arbitrary Precision Floating-point Arithmetic */ 00004 /* and Fast Robust Geometric Predicates */ 00005 /* (predicates.c) */ 00006 /* */ 00007 /* May 18, 1996 */ 00008 /* */ 00009 /* Placed in the public domain by */ 00010 /* Jonathan Richard Shewchuk */ 00011 /* School of Computer Science */ 00012 /* Carnegie Mellon University */ 00013 /* 5000 Forbes Avenue */ 00014 /* Pittsburgh, Pennsylvania 15213-3891 */ 00015 /* [email protected] */ 00016 /* */ 00017 /* This file contains C implementation of algorithms for exact addition */ 00018 /* and multiplication of floating-point numbers, and predicates for */ 00019 /* robustly performing the orientation and incircle tests used in */ 00020 /* computational geometry. The algorithms and underlying theory are */ 00021 /* described in Jonathan Richard Shewchuk. "Adaptive Precision Floating- */ 00022 /* Point Arithmetic and Fast Robust Geometric Predicates." Technical */ 00023 /* Report CMU-CS-96-140, School of Computer Science, Carnegie Mellon */ 00024 /* University, Pittsburgh, Pennsylvania, May 1996. (Submitted to */ 00025 /* Discrete & Computational Geometry.) */ 00026 /* */ 00027 /* This file, the paper listed above, and other information are available */ 00028 /* from the Web page http://www.cs.cmu.edu/~quake/robust.html . */ 00029 /* */ 00030 /*****************************************************************************/ 00031 00032 /*****************************************************************************/ 00033 /* */ 00034 /* Using this code: */ 00035 /* */ 00036 /* First, read the short or long version of the paper (from the Web page */ 00037 /* above). */ 00038 /* */ 00039 /* Be sure to call exactinit() once, before calling any of the arithmetic */ 00040 /* functions or geometric predicates. Also be sure to turn on the */ 00041 /* optimizer when compiling this file. */ 00042 /* */ 00043 /* */ 00044 /* Several geometric predicates are defined. Their parameters are all */ 00045 /* points. Each point is an array of two or three floating-point */ 00046 /* numbers. The geometric predicates, described in the papers, are */ 00047 /* */ 00048 /* orient2d(pa, pb, pc) */ 00049 /* orient2dfast(pa, pb, pc) */ 00050 /* orient3d(pa, pb, pc, pd) */ 00051 /* orient3dfast(pa, pb, pc, pd) */ 00052 /* incircle(pa, pb, pc, pd) */ 00053 /* incirclefast(pa, pb, pc, pd) */ 00054 /* insphere(pa, pb, pc, pd, pe) */ 00055 /* inspherefast(pa, pb, pc, pd, pe) */ 00056 /* */ 00057 /* Those with suffix "fast" are approximate, non-robust versions. Those */ 00058 /* without the suffix are adaptive precision, robust versions. There */ 00059 /* are also versions with the suffices "exact" and "slow", which are */ 00060 /* non-adaptive, exact arithmetic versions, which I use only for timings */ 00061 /* in my arithmetic papers. */ 00062 /* */ 00063 /* */ 00064 /* An expansion is represented by an array of floating-point numbers, */ 00065 /* sorted from smallest to largest magnitude (possibly with interspersed */ 00066 /* zeros). The length of each expansion is stored as a separate integer, */ 00067 /* and each arithmetic function returns an integer which is the length */ 00068 /* of the expansion it created. */ 00069 /* */ 00070 /* Several arithmetic functions are defined. Their parameters are */ 00071 /* */ 00072 /* e, f Input expansions */ 00073 /* elen, flen Lengths of input expansions (must be >= 1) */ 00074 /* h Output expansion */ 00075 /* b Input scalar */ 00076 /* */ 00077 /* The arithmetic functions are */ 00078 /* */ 00079 /* grow_expansion(elen, e, b, h) */ 00080 /* grow_expansion_zeroelim(elen, e, b, h) */ 00081 /* expansion_sum(elen, e, flen, f, h) */ 00082 /* expansion_sum_zeroelim1(elen, e, flen, f, h) */ 00083 /* expansion_sum_zeroelim2(elen, e, flen, f, h) */ 00084 /* fast_expansion_sum(elen, e, flen, f, h) */ 00085 /* fast_expansion_sum_zeroelim(elen, e, flen, f, h) */ 00086 /* linear_expansion_sum(elen, e, flen, f, h) */ 00087 /* linear_expansion_sum_zeroelim(elen, e, flen, f, h) */ 00088 /* scale_expansion(elen, e, b, h) */ 00089 /* scale_expansion_zeroelim(elen, e, b, h) */ 00090 /* compress(elen, e, h) */ 00091 /* */ 00092 /* All of these are described in the long version of the paper; some are */ 00093 /* described in the short version. All return an integer that is the */ 00094 /* length of h. Those with suffix _zeroelim perform zero elimination, */ 00095 /* and are recommended over their counterparts. The procedure */ 00096 /* fast_expansion_sum_zeroelim() (or linear_expansion_sum_zeroelim() on */ 00097 /* processors that do not use the round-to-even tiebreaking rule) is */ 00098 /* recommended over expansion_sum_zeroelim(). Each procedure has a */ 00099 /* little note next to it (in the code below) that tells you whether or */ 00100 /* not the output expansion may be the same array as one of the input */ 00101 /* expansions. */ 00102 /* */ 00103 /* */ 00104 /* If you look around below, you'll also find macros for a bunch of */ 00105 /* simple unrolled arithmetic operations, and procedures for printing */ 00106 /* expansions (commented out because they don't work with all C */ 00107 /* compilers) and for generating random floating-point numbers whose */ 00108 /* significand bits are all random. Most of the macros have undocumented */ 00109 /* requirements that certain of their parameters should not be the same */ 00110 /* variable; for safety, better to make sure all the parameters are */ 00111 /* distinct variables. Feel free to send email to [email protected] if you */ 00112 /* have questions. */ 00113 /* */ 00114 /*****************************************************************************/ 00115 00116 #include <stdio.h> 00117 #include <stdlib.h> 00118 #include <math.h> 00119 #include <sys/time.h> 00120 00121 /* On some machines, the exact arithmetic routines might be defeated by the */ 00122 /* use of internal extended precision floating-point registers. Sometimes */ 00123 /* this problem can be fixed by defining certain values to be volatile, */ 00124 /* thus forcing them to be stored to memory and rounded off. This isn't */ 00125 /* a great solution, though, as it slows the arithmetic down. */ 00126 /* */ 00127 /* To try this out, write "#define INEXACT volatile" below. Normally, */ 00128 /* however, INEXACT should be defined to be nothing. ("#define INEXACT".) */ 00129 00130 /* #define INEXACT */ /* Nothing */ 00131 namespace QM{ 00132 #define INEXACT volatile 00133 00134 #define REAL double /* float or double */ 00135 #define REALPRINT doubleprint 00136 #define REALRAND doublerand 00137 #define NARROWRAND narrowdoublerand 00138 #define UNIFORMRAND uniformdoublerand 00139 00140 /* Which of the following two methods of finding the absolute values is */ 00141 /* fastest is compiler-dependent. A few compilers can inline and optimize */ 00142 /* the fabs() call; but most will incur the overhead of a function call, */ 00143 /* which is disastrously slow. A faster way on IEEE machines might be to */ 00144 /* mask the appropriate bit, but that's difficult to do in C. */ 00145 00146 #define Absolute(a) ((a) >= 0.0 ? (a) : -(a)) 00147 /* #define Absolute(a) fabs(a) */ 00148 00149 /* Many of the operations are broken up into two pieces, a main part that */ 00150 /* performs an approximate operation, and a "tail" that computes the */ 00151 /* roundoff error of that operation. */ 00152 /* */ 00153 /* The operations Fast_Two_Sum(), Fast_Two_Diff(), Two_Sum(), Two_Diff(), */ 00154 /* Split(), and Two_Product() are all implemented as described in the */ 00155 /* reference. Each of these macros requires certain variables to be */ 00156 /* defined in the calling routine. The variables `bvirt', `c', `abig', */ 00157 /* `_i', `_j', `_k', `_l', `_m', and `_n' are declared `INEXACT' because */ 00158 /* they store the result of an operation that may incur roundoff error. */ 00159 /* The input parameter `x' (or the highest numbered `x_' parameter) must */ 00160 /* also be declared `INEXACT'. */ 00161 00162 #define Fast_Two_Sum_Tail(a, b, x, y) \ 00163 bvirt = x - a; \ 00164 y = b - bvirt 00165 00166 #define Fast_Two_Sum(a, b, x, y) \ 00167 x = (REAL) (a + b); \ 00168 Fast_Two_Sum_Tail(a, b, x, y) 00169 00170 #define Fast_Two_Diff_Tail(a, b, x, y) \ 00171 bvirt = a - x; \ 00172 y = bvirt - b 00173 00174 #define Fast_Two_Diff(a, b, x, y) \ 00175 x = (REAL) (a - b); \ 00176 Fast_Two_Diff_Tail(a, b, x, y) 00177 00178 #define Two_Sum_Tail(a, b, x, y) \ 00179 bvirt = (REAL) (x - a); \ 00180 avirt = x - bvirt; \ 00181 bround = b - bvirt; \ 00182 around = a - avirt; \ 00183 y = around + bround 00184 00185 #define Two_Sum(a, b, x, y) \ 00186 x = (REAL) (a + b); \ 00187 Two_Sum_Tail(a, b, x, y) 00188 00189 #define Two_Diff_Tail(a, b, x, y) \ 00190 bvirt = (REAL) (a - x); \ 00191 avirt = x + bvirt; \ 00192 bround = bvirt - b; \ 00193 around = a - avirt; \ 00194 y = around + bround 00195 00196 #define Two_Diff(a, b, x, y) \ 00197 x = (REAL) (a - b); \ 00198 Two_Diff_Tail(a, b, x, y) 00199 00200 #define Split(a, ahi, alo) \ 00201 c = (REAL) (splitter * a); \ 00202 abig = (REAL) (c - a); \ 00203 ahi = c - abig; \ 00204 alo = a - ahi 00205 00206 #define Two_Product_Tail(a, b, x, y) \ 00207 Split(a, ahi, alo); \ 00208 Split(b, bhi, blo); \ 00209 err1 = x - (ahi * bhi); \ 00210 err2 = err1 - (alo * bhi); \ 00211 err3 = err2 - (ahi * blo); \ 00212 y = (alo * blo) - err3 00213 00214 #define Two_Product(a, b, x, y) \ 00215 x = (REAL) (a * b); \ 00216 Two_Product_Tail(a, b, x, y) 00217 00218 /* Two_Product_Presplit() is Two_Product() where one of the inputs has */ 00219 /* already been split. Avoids redundant splitting. */ 00220 00221 #define Two_Product_Presplit(a, b, bhi, blo, x, y) \ 00222 x = (REAL) (a * b); \ 00223 Split(a, ahi, alo); \ 00224 err1 = x - (ahi * bhi); \ 00225 err2 = err1 - (alo * bhi); \ 00226 err3 = err2 - (ahi * blo); \ 00227 y = (alo * blo) - err3 00228 00229 /* Two_Product_2Presplit() is Two_Product() where both of the inputs have */ 00230 /* already been split. Avoids redundant splitting. */ 00231 00232 #define Two_Product_2Presplit(a, ahi, alo, b, bhi, blo, x, y) \ 00233 x = (REAL) (a * b); \ 00234 err1 = x - (ahi * bhi); \ 00235 err2 = err1 - (alo * bhi); \ 00236 err3 = err2 - (ahi * blo); \ 00237 y = (alo * blo) - err3 00238 00239 /* Square() can be done more quickly than Two_Product(). */ 00240 00241 #define Square_Tail(a, x, y) \ 00242 Split(a, ahi, alo); \ 00243 err1 = x - (ahi * ahi); \ 00244 err3 = err1 - ((ahi + ahi) * alo); \ 00245 y = (alo * alo) - err3 00246 00247 #define Square(a, x, y) \ 00248 x = (REAL) (a * a); \ 00249 Square_Tail(a, x, y) 00250 00251 /* Macros for summing expansions of various fixed lengths. These are all */ 00252 /* unrolled versions of Expansion_Sum(). */ 00253 00254 #define Two_One_Sum(a1, a0, b, x2, x1, x0) \ 00255 Two_Sum(a0, b , _i, x0); \ 00256 Two_Sum(a1, _i, x2, x1) 00257 00258 #define Two_One_Diff(a1, a0, b, x2, x1, x0) \ 00259 Two_Diff(a0, b , _i, x0); \ 00260 Two_Sum( a1, _i, x2, x1) 00261 00262 #define Two_Two_Sum(a1, a0, b1, b0, x3, x2, x1, x0) \ 00263 Two_One_Sum(a1, a0, b0, _j, _0, x0); \ 00264 Two_One_Sum(_j, _0, b1, x3, x2, x1) 00265 00266 #define Two_Two_Diff(a1, a0, b1, b0, x3, x2, x1, x0) \ 00267 Two_One_Diff(a1, a0, b0, _j, _0, x0); \ 00268 Two_One_Diff(_j, _0, b1, x3, x2, x1) 00269 00270 #define Four_One_Sum(a3, a2, a1, a0, b, x4, x3, x2, x1, x0) \ 00271 Two_One_Sum(a1, a0, b , _j, x1, x0); \ 00272 Two_One_Sum(a3, a2, _j, x4, x3, x2) 00273 00274 #define Four_Two_Sum(a3, a2, a1, a0, b1, b0, x5, x4, x3, x2, x1, x0) \ 00275 Four_One_Sum(a3, a2, a1, a0, b0, _k, _2, _1, _0, x0); \ 00276 Four_One_Sum(_k, _2, _1, _0, b1, x5, x4, x3, x2, x1) 00277 00278 #define Four_Four_Sum(a3, a2, a1, a0, b4, b3, b1, b0, x7, x6, x5, x4, x3, x2, \ 00279 x1, x0) \ 00280 Four_Two_Sum(a3, a2, a1, a0, b1, b0, _l, _2, _1, _0, x1, x0); \ 00281 Four_Two_Sum(_l, _2, _1, _0, b4, b3, x7, x6, x5, x4, x3, x2) 00282 00283 #define Eight_One_Sum(a7, a6, a5, a4, a3, a2, a1, a0, b, x8, x7, x6, x5, x4, \ 00284 x3, x2, x1, x0) \ 00285 Four_One_Sum(a3, a2, a1, a0, b , _j, x3, x2, x1, x0); \ 00286 Four_One_Sum(a7, a6, a5, a4, _j, x8, x7, x6, x5, x4) 00287 00288 #define Eight_Two_Sum(a7, a6, a5, a4, a3, a2, a1, a0, b1, b0, x9, x8, x7, \ 00289 x6, x5, x4, x3, x2, x1, x0) \ 00290 Eight_One_Sum(a7, a6, a5, a4, a3, a2, a1, a0, b0, _k, _6, _5, _4, _3, _2, \ 00291 _1, _0, x0); \ 00292 Eight_One_Sum(_k, _6, _5, _4, _3, _2, _1, _0, b1, x9, x8, x7, x6, x5, x4, \ 00293 x3, x2, x1) 00294 00295 #define Eight_Four_Sum(a7, a6, a5, a4, a3, a2, a1, a0, b4, b3, b1, b0, x11, \ 00296 x10, x9, x8, x7, x6, x5, x4, x3, x2, x1, x0) \ 00297 Eight_Two_Sum(a7, a6, a5, a4, a3, a2, a1, a0, b1, b0, _l, _6, _5, _4, _3, \ 00298 _2, _1, _0, x1, x0); \ 00299 Eight_Two_Sum(_l, _6, _5, _4, _3, _2, _1, _0, b4, b3, x11, x10, x9, x8, \ 00300 x7, x6, x5, x4, x3, x2) 00301 00302 /* Macros for multiplying expansions of various fixed lengths. */ 00303 00304 #define Two_One_Product(a1, a0, b, x3, x2, x1, x0) \ 00305 Split(b, bhi, blo); \ 00306 Two_Product_Presplit(a0, b, bhi, blo, _i, x0); \ 00307 Two_Product_Presplit(a1, b, bhi, blo, _j, _0); \ 00308 Two_Sum(_i, _0, _k, x1); \ 00309 Fast_Two_Sum(_j, _k, x3, x2) 00310 00311 #define Four_One_Product(a3, a2, a1, a0, b, x7, x6, x5, x4, x3, x2, x1, x0) \ 00312 Split(b, bhi, blo); \ 00313 Two_Product_Presplit(a0, b, bhi, blo, _i, x0); \ 00314 Two_Product_Presplit(a1, b, bhi, blo, _j, _0); \ 00315 Two_Sum(_i, _0, _k, x1); \ 00316 Fast_Two_Sum(_j, _k, _i, x2); \ 00317 Two_Product_Presplit(a2, b, bhi, blo, _j, _0); \ 00318 Two_Sum(_i, _0, _k, x3); \ 00319 Fast_Two_Sum(_j, _k, _i, x4); \ 00320 Two_Product_Presplit(a3, b, bhi, blo, _j, _0); \ 00321 Two_Sum(_i, _0, _k, x5); \ 00322 Fast_Two_Sum(_j, _k, x7, x6) 00323 00324 #define Two_Two_Product(a1, a0, b1, b0, x7, x6, x5, x4, x3, x2, x1, x0) \ 00325 Split(a0, a0hi, a0lo); \ 00326 Split(b0, bhi, blo); \ 00327 Two_Product_2Presplit(a0, a0hi, a0lo, b0, bhi, blo, _i, x0); \ 00328 Split(a1, a1hi, a1lo); \ 00329 Two_Product_2Presplit(a1, a1hi, a1lo, b0, bhi, blo, _j, _0); \ 00330 Two_Sum(_i, _0, _k, _1); \ 00331 Fast_Two_Sum(_j, _k, _l, _2); \ 00332 Split(b1, bhi, blo); \ 00333 Two_Product_2Presplit(a0, a0hi, a0lo, b1, bhi, blo, _i, _0); \ 00334 Two_Sum(_1, _0, _k, x1); \ 00335 Two_Sum(_2, _k, _j, _1); \ 00336 Two_Sum(_l, _j, _m, _2); \ 00337 Two_Product_2Presplit(a1, a1hi, a1lo, b1, bhi, blo, _j, _0); \ 00338 Two_Sum(_i, _0, _n, _0); \ 00339 Two_Sum(_1, _0, _i, x2); \ 00340 Two_Sum(_2, _i, _k, _1); \ 00341 Two_Sum(_m, _k, _l, _2); \ 00342 Two_Sum(_j, _n, _k, _0); \ 00343 Two_Sum(_1, _0, _j, x3); \ 00344 Two_Sum(_2, _j, _i, _1); \ 00345 Two_Sum(_l, _i, _m, _2); \ 00346 Two_Sum(_1, _k, _i, x4); \ 00347 Two_Sum(_2, _i, _k, x5); \ 00348 Two_Sum(_m, _k, x7, x6) 00349 00350 /* An expansion of length two can be squared more quickly than finding the */ 00351 /* product of two different expansions of length two, and the result is */ 00352 /* guaranteed to have no more than six (rather than eight) components. */ 00353 00354 #define Two_Square(a1, a0, x5, x4, x3, x2, x1, x0) \ 00355 Square(a0, _j, x0); \ 00356 _0 = a0 + a0; \ 00357 Two_Product(a1, _0, _k, _1); \ 00358 Two_One_Sum(_k, _1, _j, _l, _2, x1); \ 00359 Square(a1, _j, _1); \ 00360 Two_Two_Sum(_j, _1, _l, _2, x5, x4, x3, x2) 00361 00362 REAL splitter; /* = 2^ceiling(p / 2) + 1. Used to split floats in half. */ 00363 REAL epsilon; /* = 2^(-p). Used to estimate roundoff errors. */ 00364 /* A set of coefficients used to calculate maximum roundoff errors. */ 00365 REAL resulterrbound; 00366 REAL ccwerrboundA, ccwerrboundB, ccwerrboundC; 00367 REAL o3derrboundA, o3derrboundB, o3derrboundC; 00368 REAL iccerrboundA, iccerrboundB, iccerrboundC; 00369 REAL isperrboundA, isperrboundB, isperrboundC; 00370 00371 /*****************************************************************************/ 00372 /* */ 00373 /* doubleprint() Print the bit representation of a double. */ 00374 /* */ 00375 /* Useful for debugging exact arithmetic routines. */ 00376 /* */ 00377 /*****************************************************************************/ 00378 00379 /* 00380 void doubleprint(number) 00381 double number; 00382 { 00383 unsigned long long no; 00384 unsigned long long sign, expo; 00385 int exponent; 00386 int i, bottomi; 00387 00388 no = *(unsigned long long *) &number; 00389 sign = no & 0x8000000000000000ll; 00390 expo = (no >> 52) & 0x7ffll; 00391 exponent = (int) expo; 00392 exponent = exponent - 1023; 00393 if (sign) { 00394 printf("-"); 00395 } else { 00396 printf(" "); 00397 } 00398 if (exponent == -1023) { 00399 printf( 00400 "0.0000000000000000000000000000000000000000000000000000_ ( )"); 00401 } else { 00402 printf("1."); 00403 bottomi = -1; 00404 for (i = 0; i < 52; i++) { 00405 if (no & 0x0008000000000000ll) { 00406 printf("1"); 00407 bottomi = i; 00408 } else { 00409 printf("0"); 00410 } 00411 no <<= 1; 00412 } 00413 printf("_%d (%d)", exponent, exponent - 1 - bottomi); 00414 } 00415 } 00416 */ 00417 00418 /*****************************************************************************/ 00419 /* */ 00420 /* floatprint() Print the bit representation of a float. */ 00421 /* */ 00422 /* Useful for debugging exact arithmetic routines. */ 00423 /* */ 00424 /*****************************************************************************/ 00425 00426 /* 00427 void floatprint(number) 00428 float number; 00429 { 00430 unsigned no; 00431 unsigned sign, expo; 00432 int exponent; 00433 int i, bottomi; 00434 00435 no = *(unsigned *) &number; 00436 sign = no & 0x80000000; 00437 expo = (no >> 23) & 0xff; 00438 exponent = (int) expo; 00439 exponent = exponent - 127; 00440 if (sign) { 00441 printf("-"); 00442 } else { 00443 printf(" "); 00444 } 00445 if (exponent == -127) { 00446 printf("0.00000000000000000000000_ ( )"); 00447 } else { 00448 printf("1."); 00449 bottomi = -1; 00450 for (i = 0; i < 23; i++) { 00451 if (no & 0x00400000) { 00452 printf("1"); 00453 bottomi = i; 00454 } else { 00455 printf("0"); 00456 } 00457 no <<= 1; 00458 } 00459 printf("_%3d (%3d)", exponent, exponent - 1 - bottomi); 00460 } 00461 } 00462 */ 00463 00464 /*****************************************************************************/ 00465 /* */ 00466 /* expansion_print() Print the bit representation of an expansion. */ 00467 /* */ 00468 /* Useful for debugging exact arithmetic routines. */ 00469 /* */ 00470 /*****************************************************************************/ 00471 00472 /* 00473 void expansion_print(elen, e) 00474 int elen; 00475 REAL *e; 00476 { 00477 int i; 00478 00479 for (i = elen - 1; i >= 0; i--) { 00480 REALPRINT(e[i]); 00481 if (i > 0) { 00482 printf(" +\n"); 00483 } else { 00484 printf("\n"); 00485 } 00486 } 00487 } 00488 */ 00489 00490 /*****************************************************************************/ 00491 /* */ 00492 /* doublerand() Generate a double with random 53-bit significand and a */ 00493 /* random exponent in [0, 511]. */ 00494 /* */ 00495 /*****************************************************************************/ 00496 00497 double doublerand() 00498 { 00499 double result; 00500 double expo; 00501 long a, b, c; 00502 long i; 00503 00504 a = random(); 00505 b = random(); 00506 c = random(); 00507 result = (double) (a - 1073741824) * 8388608.0 + (double) (b >> 8); 00508 for (i = 512, expo = 2; i <= 131072; i *= 2, expo = expo * expo) { 00509 if (c & i) { 00510 result *= expo; 00511 } 00512 } 00513 return result; 00514 } 00515 00516 /*****************************************************************************/ 00517 /* */ 00518 /* narrowdoublerand() Generate a double with random 53-bit significand */ 00519 /* and a random exponent in [0, 7]. */ 00520 /* */ 00521 /*****************************************************************************/ 00522 00523 double narrowdoublerand() 00524 { 00525 double result; 00526 double expo; 00527 long a, b, c; 00528 long i; 00529 00530 a = random(); 00531 b = random(); 00532 c = random(); 00533 result = (double) (a - 1073741824) * 8388608.0 + (double) (b >> 8); 00534 for (i = 512, expo = 2; i <= 2048; i *= 2, expo = expo * expo) { 00535 if (c & i) { 00536 result *= expo; 00537 } 00538 } 00539 return result; 00540 } 00541 00542 /*****************************************************************************/ 00543 /* */ 00544 /* uniformdoublerand() Generate a double with random 53-bit significand. */ 00545 /* */ 00546 /*****************************************************************************/ 00547 00548 double uniformdoublerand() 00549 { 00550 double result; 00551 long a, b; 00552 00553 a = random(); 00554 b = random(); 00555 result = (double) (a - 1073741824) * 8388608.0 + (double) (b >> 8); 00556 return result; 00557 } 00558 00559 /*****************************************************************************/ 00560 /* */ 00561 /* floatrand() Generate a float with random 24-bit significand and a */ 00562 /* random exponent in [0, 63]. */ 00563 /* */ 00564 /*****************************************************************************/ 00565 00566 float floatrand() 00567 { 00568 float result; 00569 float expo; 00570 long a, c; 00571 long i; 00572 00573 a = random(); 00574 c = random(); 00575 result = (float) ((a - 1073741824) >> 6); 00576 for (i = 512, expo = 2; i <= 16384; i *= 2, expo = expo * expo) { 00577 if (c & i) { 00578 result *= expo; 00579 } 00580 } 00581 return result; 00582 } 00583 00584 /*****************************************************************************/ 00585 /* */ 00586 /* narrowfloatrand() Generate a float with random 24-bit significand and */ 00587 /* a random exponent in [0, 7]. */ 00588 /* */ 00589 /*****************************************************************************/ 00590 00591 float narrowfloatrand() 00592 { 00593 float result; 00594 float expo; 00595 long a, c; 00596 long i; 00597 00598 a = random(); 00599 c = random(); 00600 result = (float) ((a - 1073741824) >> 6); 00601 for (i = 512, expo = 2; i <= 2048; i *= 2, expo = expo * expo) { 00602 if (c & i) { 00603 result *= expo; 00604 } 00605 } 00606 return result; 00607 } 00608 00609 /*****************************************************************************/ 00610 /* */ 00611 /* uniformfloatrand() Generate a float with random 24-bit significand. */ 00612 /* */ 00613 /*****************************************************************************/ 00614 00615 float uniformfloatrand() 00616 { 00617 float result; 00618 long a; 00619 00620 a = random(); 00621 result = (float) ((a - 1073741824) >> 6); 00622 return result; 00623 } 00624 00625 /*****************************************************************************/ 00626 /* */ 00627 /* exactinit() Initialize the variables used for exact arithmetic. */ 00628 /* */ 00629 /* `epsilon' is the largest power of two such that 1.0 + epsilon = 1.0 in */ 00630 /* floating-point arithmetic. `epsilon' bounds the relative roundoff */ 00631 /* error. It is used for floating-point error analysis. */ 00632 /* */ 00633 /* `splitter' is used to split floating-point numbers into two half- */ 00634 /* length significands for exact multiplication. */ 00635 /* */ 00636 /* I imagine that a highly optimizing compiler might be too smart for its */ 00637 /* own good, and somehow cause this routine to fail, if it pretends that */ 00638 /* floating-point arithmetic is too much like real arithmetic. */ 00639 /* */ 00640 /* Don't change this routine unless you fully understand it. */ 00641 /* */ 00642 /*****************************************************************************/ 00643 00644 void exactinit() 00645 { 00646 REAL half; 00647 REAL check, lastcheck; 00648 int every_other; 00649 00650 every_other = 1; 00651 half = 0.5; 00652 epsilon = 1.0; 00653 splitter = 1.0; 00654 check = 1.0; 00655 /* Repeatedly divide `epsilon' by two until it is too small to add to */ 00656 /* one without causing roundoff. (Also check if the sum is equal to */ 00657 /* the previous sum, for machines that round up instead of using exact */ 00658 /* rounding. Not that this library will work on such machines anyway. */ 00659 do { 00660 lastcheck = check; 00661 epsilon *= half; 00662 if (every_other) { 00663 splitter *= 2.0; 00664 } 00665 every_other = !every_other; 00666 check = 1.0 + epsilon; 00667 } while ((check != 1.0) && (check != lastcheck)); 00668 splitter += 1.0; 00669 00670 /* Error bounds for orientation and incircle tests. */ 00671 resulterrbound = (3.0 + 8.0 * epsilon) * epsilon; 00672 ccwerrboundA = (3.0 + 16.0 * epsilon) * epsilon; 00673 ccwerrboundB = (2.0 + 12.0 * epsilon) * epsilon; 00674 ccwerrboundC = (9.0 + 64.0 * epsilon) * epsilon * epsilon; 00675 o3derrboundA = (7.0 + 56.0 * epsilon) * epsilon; 00676 o3derrboundB = (3.0 + 28.0 * epsilon) * epsilon; 00677 o3derrboundC = (26.0 + 288.0 * epsilon) * epsilon * epsilon; 00678 iccerrboundA = (10.0 + 96.0 * epsilon) * epsilon; 00679 iccerrboundB = (4.0 + 48.0 * epsilon) * epsilon; 00680 iccerrboundC = (44.0 + 576.0 * epsilon) * epsilon * epsilon; 00681 isperrboundA = (16.0 + 224.0 * epsilon) * epsilon; 00682 isperrboundB = (5.0 + 72.0 * epsilon) * epsilon; 00683 isperrboundC = (71.0 + 1408.0 * epsilon) * epsilon * epsilon; 00684 } 00685 00686 /*****************************************************************************/ 00687 /* */ 00688 /* grow_expansion() Add a scalar to an expansion. */ 00689 /* */ 00690 /* Sets h = e + b. See the long version of my paper for details. */ 00691 /* */ 00692 /* Maintains the nonoverlapping property. If round-to-even is used (as */ 00693 /* with IEEE 754), maintains the strongly nonoverlapping and nonadjacent */ 00694 /* properties as well. (That is, if e has one of these properties, so */ 00695 /* will h.) */ 00696 /* */ 00697 /*****************************************************************************/ 00698 00699 int grow_expansion(int elen, REAL *e, REAL b, REAL *h) /* e and h can be the same. */ 00700 { 00701 REAL Q; 00702 INEXACT REAL Qnew; 00703 int eindex; 00704 REAL enow; 00705 INEXACT REAL bvirt; 00706 REAL avirt, bround, around; 00707 00708 Q = b; 00709 for (eindex = 0; eindex < elen; eindex++) { 00710 enow = e[eindex]; 00711 Two_Sum(Q, enow, Qnew, h[eindex]); 00712 Q = Qnew; 00713 } 00714 h[eindex] = Q; 00715 return eindex + 1; 00716 } 00717 00718 /*****************************************************************************/ 00719 /* */ 00720 /* grow_expansion_zeroelim() Add a scalar to an expansion, eliminating */ 00721 /* zero components from the output expansion. */ 00722 /* */ 00723 /* Sets h = e + b. See the long version of my paper for details. */ 00724 /* */ 00725 /* Maintains the nonoverlapping property. If round-to-even is used (as */ 00726 /* with IEEE 754), maintains the strongly nonoverlapping and nonadjacent */ 00727 /* properties as well. (That is, if e has one of these properties, so */ 00728 /* will h.) */ 00729 /* */ 00730 /*****************************************************************************/ 00731 00732 int grow_expansion_zeroelim(int elen, REAL *e, REAL b, REAL *h) /* e and h can be the same. */ 00733 { 00734 REAL Q, hh; 00735 INEXACT REAL Qnew; 00736 int eindex, hindex; 00737 REAL enow; 00738 INEXACT REAL bvirt; 00739 REAL avirt, bround, around; 00740 00741 hindex = 0; 00742 Q = b; 00743 for (eindex = 0; eindex < elen; eindex++) { 00744 enow = e[eindex]; 00745 Two_Sum(Q, enow, Qnew, hh); 00746 Q = Qnew; 00747 if (hh != 0.0) { 00748 h[hindex++] = hh; 00749 } 00750 } 00751 if ((Q != 0.0) || (hindex == 0)) { 00752 h[hindex++] = Q; 00753 } 00754 return hindex; 00755 } 00756 00757 /*****************************************************************************/ 00758 /* */ 00759 /* expansion_sum() Sum two expansions. */ 00760 /* */ 00761 /* Sets h = e + f. See the long version of my paper for details. */ 00762 /* */ 00763 /* Maintains the nonoverlapping property. If round-to-even is used (as */ 00764 /* with IEEE 754), maintains the nonadjacent property as well. (That is, */ 00765 /* if e has one of these properties, so will h.) Does NOT maintain the */ 00766 /* strongly nonoverlapping property. */ 00767 /* */ 00768 /*****************************************************************************/ 00769 00770 int expansion_sum(int elen, REAL *e, int flen, REAL *f, REAL *h) 00771 /* e and h can be the same, but f and h cannot. */ 00772 { 00773 REAL Q; 00774 INEXACT REAL Qnew; 00775 int findex, hindex, hlast; 00776 REAL hnow; 00777 INEXACT REAL bvirt; 00778 REAL avirt, bround, around; 00779 00780 Q = f[0]; 00781 for (hindex = 0; hindex < elen; hindex++) { 00782 hnow = e[hindex]; 00783 Two_Sum(Q, hnow, Qnew, h[hindex]); 00784 Q = Qnew; 00785 } 00786 h[hindex] = Q; 00787 hlast = hindex; 00788 for (findex = 1; findex < flen; findex++) { 00789 Q = f[findex]; 00790 for (hindex = findex; hindex <= hlast; hindex++) { 00791 hnow = h[hindex]; 00792 Two_Sum(Q, hnow, Qnew, h[hindex]); 00793 Q = Qnew; 00794 } 00795 h[++hlast] = Q; 00796 } 00797 return hlast + 1; 00798 } 00799 00800 /*****************************************************************************/ 00801 /* */ 00802 /* expansion_sum_zeroelim1() Sum two expansions, eliminating zero */ 00803 /* components from the output expansion. */ 00804 /* */ 00805 /* Sets h = e + f. See the long version of my paper for details. */ 00806 /* */ 00807 /* Maintains the nonoverlapping property. If round-to-even is used (as */ 00808 /* with IEEE 754), maintains the nonadjacent property as well. (That is, */ 00809 /* if e has one of these properties, so will h.) Does NOT maintain the */ 00810 /* strongly nonoverlapping property. */ 00811 /* */ 00812 /*****************************************************************************/ 00813 00814 int expansion_sum_zeroelim1(int elen, REAL *e, int flen, REAL *f, REAL *h) 00815 /* e and h can be the same, but f and h cannot. */ 00816 { 00817 REAL Q; 00818 INEXACT REAL Qnew; 00819 int index, findex, hindex, hlast; 00820 REAL hnow; 00821 INEXACT REAL bvirt; 00822 REAL avirt, bround, around; 00823 00824 Q = f[0]; 00825 for (hindex = 0; hindex < elen; hindex++) { 00826 hnow = e[hindex]; 00827 Two_Sum(Q, hnow, Qnew, h[hindex]); 00828 Q = Qnew; 00829 } 00830 h[hindex] = Q; 00831 hlast = hindex; 00832 for (findex = 1; findex < flen; findex++) { 00833 Q = f[findex]; 00834 for (hindex = findex; hindex <= hlast; hindex++) { 00835 hnow = h[hindex]; 00836 Two_Sum(Q, hnow, Qnew, h[hindex]); 00837 Q = Qnew; 00838 } 00839 h[++hlast] = Q; 00840 } 00841 hindex = -1; 00842 for (index = 0; index <= hlast; index++) { 00843 hnow = h[index]; 00844 if (hnow != 0.0) { 00845 h[++hindex] = hnow; 00846 } 00847 } 00848 if (hindex == -1) { 00849 return 1; 00850 } else { 00851 return hindex + 1; 00852 } 00853 } 00854 00855 /*****************************************************************************/ 00856 /* */ 00857 /* expansion_sum_zeroelim2() Sum two expansions, eliminating zero */ 00858 /* components from the output expansion. */ 00859 /* */ 00860 /* Sets h = e + f. See the long version of my paper for details. */ 00861 /* */ 00862 /* Maintains the nonoverlapping property. If round-to-even is used (as */ 00863 /* with IEEE 754), maintains the nonadjacent property as well. (That is, */ 00864 /* if e has one of these properties, so will h.) Does NOT maintain the */ 00865 /* strongly nonoverlapping property. */ 00866 /* */ 00867 /*****************************************************************************/ 00868 00869 int expansion_sum_zeroelim2(int elen, REAL *e, int flen, REAL *f, REAL *h) 00870 /* e and h can be the same, but f and h cannot. */ 00871 { 00872 REAL Q, hh; 00873 INEXACT REAL Qnew; 00874 int eindex, findex, hindex, hlast; 00875 REAL enow; 00876 INEXACT REAL bvirt; 00877 REAL avirt, bround, around; 00878 00879 hindex = 0; 00880 Q = f[0]; 00881 for (eindex = 0; eindex < elen; eindex++) { 00882 enow = e[eindex]; 00883 Two_Sum(Q, enow, Qnew, hh); 00884 Q = Qnew; 00885 if (hh != 0.0) { 00886 h[hindex++] = hh; 00887 } 00888 } 00889 h[hindex] = Q; 00890 hlast = hindex; 00891 for (findex = 1; findex < flen; findex++) { 00892 hindex = 0; 00893 Q = f[findex]; 00894 for (eindex = 0; eindex <= hlast; eindex++) { 00895 enow = h[eindex]; 00896 Two_Sum(Q, enow, Qnew, hh); 00897 Q = Qnew; 00898 if (hh != 0) { 00899 h[hindex++] = hh; 00900 } 00901 } 00902 h[hindex] = Q; 00903 hlast = hindex; 00904 } 00905 return hlast + 1; 00906 } 00907 00908 /*****************************************************************************/ 00909 /* */ 00910 /* fast_expansion_sum() Sum two expansions. */ 00911 /* */ 00912 /* Sets h = e + f. See the long version of my paper for details. */ 00913 /* */ 00914 /* If round-to-even is used (as with IEEE 754), maintains the strongly */ 00915 /* nonoverlapping property. (That is, if e is strongly nonoverlapping, h */ 00916 /* will be also.) Does NOT maintain the nonoverlapping or nonadjacent */ 00917 /* properties. */ 00918 /* */ 00919 /*****************************************************************************/ 00920 00921 int fast_expansion_sum(int elen, REAL *e, int flen, REAL *f, REAL *h) /* h cannot be e or f. */ 00922 { 00923 REAL Q; 00924 INEXACT REAL Qnew; 00925 INEXACT REAL bvirt; 00926 REAL avirt, bround, around; 00927 int eindex, findex, hindex; 00928 REAL enow, fnow; 00929 00930 enow = e[0]; 00931 fnow = f[0]; 00932 eindex = findex = 0; 00933 if ((fnow > enow) == (fnow > -enow)) { 00934 Q = enow; 00935 enow = e[++eindex]; 00936 } else { 00937 Q = fnow; 00938 fnow = f[++findex]; 00939 } 00940 hindex = 0; 00941 if ((eindex < elen) && (findex < flen)) { 00942 if ((fnow > enow) == (fnow > -enow)) { 00943 Fast_Two_Sum(enow, Q, Qnew, h[0]); 00944 enow = e[++eindex]; 00945 } else { 00946 Fast_Two_Sum(fnow, Q, Qnew, h[0]); 00947 fnow = f[++findex]; 00948 } 00949 Q = Qnew; 00950 hindex = 1; 00951 while ((eindex < elen) && (findex < flen)) { 00952 if ((fnow > enow) == (fnow > -enow)) { 00953 Two_Sum(Q, enow, Qnew, h[hindex]); 00954 enow = e[++eindex]; 00955 } else { 00956 Two_Sum(Q, fnow, Qnew, h[hindex]); 00957 fnow = f[++findex]; 00958 } 00959 Q = Qnew; 00960 hindex++; 00961 } 00962 } 00963 while (eindex < elen) { 00964 Two_Sum(Q, enow, Qnew, h[hindex]); 00965 enow = e[++eindex]; 00966 Q = Qnew; 00967 hindex++; 00968 } 00969 while (findex < flen) { 00970 Two_Sum(Q, fnow, Qnew, h[hindex]); 00971 fnow = f[++findex]; 00972 Q = Qnew; 00973 hindex++; 00974 } 00975 h[hindex] = Q; 00976 return hindex + 1; 00977 } 00978 00979 /*****************************************************************************/ 00980 /* */ 00981 /* fast_expansion_sum_zeroelim() Sum two expansions, eliminating zero */ 00982 /* components from the output expansion. */ 00983 /* */ 00984 /* Sets h = e + f. See the long version of my paper for details. */ 00985 /* */ 00986 /* If round-to-even is used (as with IEEE 754), maintains the strongly */ 00987 /* nonoverlapping property. (That is, if e is strongly nonoverlapping, h */ 00988 /* will be also.) Does NOT maintain the nonoverlapping or nonadjacent */ 00989 /* properties. */ 00990 /* */ 00991 /*****************************************************************************/ 00992 00993 int fast_expansion_sum_zeroelim(int elen, REAL *e, int flen, REAL *f, REAL *h) /* h cannot be e or f. */ 00994 { 00995 REAL Q; 00996 INEXACT REAL Qnew; 00997 INEXACT REAL hh; 00998 INEXACT REAL bvirt; 00999 REAL avirt, bround, around; 01000 int eindex, findex, hindex; 01001 REAL enow, fnow; 01002 01003 enow = e[0]; 01004 fnow = f[0]; 01005 eindex = findex = 0; 01006 if ((fnow > enow) == (fnow > -enow)) { 01007 Q = enow; 01008 enow = e[++eindex]; 01009 } else { 01010 Q = fnow; 01011 fnow = f[++findex]; 01012 } 01013 hindex = 0; 01014 if ((eindex < elen) && (findex < flen)) { 01015 if ((fnow > enow) == (fnow > -enow)) { 01016 Fast_Two_Sum(enow, Q, Qnew, hh); 01017 enow = e[++eindex]; 01018 } else { 01019 Fast_Two_Sum(fnow, Q, Qnew, hh); 01020 fnow = f[++findex]; 01021 } 01022 Q = Qnew; 01023 if (hh != 0.0) { 01024 h[hindex++] = hh; 01025 } 01026 while ((eindex < elen) && (findex < flen)) { 01027 if ((fnow > enow) == (fnow > -enow)) { 01028 Two_Sum(Q, enow, Qnew, hh); 01029 enow = e[++eindex]; 01030 } else { 01031 Two_Sum(Q, fnow, Qnew, hh); 01032 fnow = f[++findex]; 01033 } 01034 Q = Qnew; 01035 if (hh != 0.0) { 01036 h[hindex++] = hh; 01037 } 01038 } 01039 } 01040 while (eindex < elen) { 01041 Two_Sum(Q, enow, Qnew, hh); 01042 enow = e[++eindex]; 01043 Q = Qnew; 01044 if (hh != 0.0) { 01045 h[hindex++] = hh; 01046 } 01047 } 01048 while (findex < flen) { 01049 Two_Sum(Q, fnow, Qnew, hh); 01050 fnow = f[++findex]; 01051 Q = Qnew; 01052 if (hh != 0.0) { 01053 h[hindex++] = hh; 01054 } 01055 } 01056 if ((Q != 0.0) || (hindex == 0)) { 01057 h[hindex++] = Q; 01058 } 01059 return hindex; 01060 } 01061 01062 /*****************************************************************************/ 01063 /* */ 01064 /* linear_expansion_sum() Sum two expansions. */ 01065 /* */ 01066 /* Sets h = e + f. See either version of my paper for details. */ 01067 /* */ 01068 /* Maintains the nonoverlapping property. (That is, if e is */ 01069 /* nonoverlapping, h will be also.) */ 01070 /* */ 01071 /*****************************************************************************/ 01072 01073 int linear_expansion_sum(int elen, REAL *e, int flen, REAL *f, REAL *h) /* h cannot be e or f. */ 01074 { 01075 REAL Q, q; 01076 INEXACT REAL Qnew; 01077 INEXACT REAL R; 01078 INEXACT REAL bvirt; 01079 REAL avirt, bround, around; 01080 int eindex, findex, hindex; 01081 REAL enow, fnow; 01082 REAL g0; 01083 01084 enow = e[0]; 01085 fnow = f[0]; 01086 eindex = findex = 0; 01087 if ((fnow > enow) == (fnow > -enow)) { 01088 g0 = enow; 01089 enow = e[++eindex]; 01090 } else { 01091 g0 = fnow; 01092 fnow = f[++findex]; 01093 } 01094 if ((eindex < elen) && ((findex >= flen) 01095 || ((fnow > enow) == (fnow > -enow)))) { 01096 Fast_Two_Sum(enow, g0, Qnew, q); 01097 enow = e[++eindex]; 01098 } else { 01099 Fast_Two_Sum(fnow, g0, Qnew, q); 01100 fnow = f[++findex]; 01101 } 01102 Q = Qnew; 01103 for (hindex = 0; hindex < elen + flen - 2; hindex++) { 01104 if ((eindex < elen) && ((findex >= flen) 01105 || ((fnow > enow) == (fnow > -enow)))) { 01106 Fast_Two_Sum(enow, q, R, h[hindex]); 01107 enow = e[++eindex]; 01108 } else { 01109 Fast_Two_Sum(fnow, q, R, h[hindex]); 01110 fnow = f[++findex]; 01111 } 01112 Two_Sum(Q, R, Qnew, q); 01113 Q = Qnew; 01114 } 01115 h[hindex] = q; 01116 h[hindex + 1] = Q; 01117 return hindex + 2; 01118 } 01119 01120 /*****************************************************************************/ 01121 /* */ 01122 /* linear_expansion_sum_zeroelim() Sum two expansions, eliminating zero */ 01123 /* components from the output expansion. */ 01124 /* */ 01125 /* Sets h = e + f. See either version of my paper for details. */ 01126 /* */ 01127 /* Maintains the nonoverlapping property. (That is, if e is */ 01128 /* nonoverlapping, h will be also.) */ 01129 /* */ 01130 /*****************************************************************************/ 01131 01132 int linear_expansion_sum_zeroelim(int elen, REAL *e, int flen, REAL *f, REAL *h)/* h cannot be e or f. */ 01133 { 01134 REAL Q, q, hh; 01135 INEXACT REAL Qnew; 01136 INEXACT REAL R; 01137 INEXACT REAL bvirt; 01138 REAL avirt, bround, around; 01139 int eindex, findex, hindex; 01140 int count; 01141 REAL enow, fnow; 01142 REAL g0; 01143 01144 enow = e[0]; 01145 fnow = f[0]; 01146 eindex = findex = 0; 01147 hindex = 0; 01148 if ((fnow > enow) == (fnow > -enow)) { 01149 g0 = enow; 01150 enow = e[++eindex]; 01151 } else { 01152 g0 = fnow; 01153 fnow = f[++findex]; 01154 } 01155 if ((eindex < elen) && ((findex >= flen) 01156 || ((fnow > enow) == (fnow > -enow)))) { 01157 Fast_Two_Sum(enow, g0, Qnew, q); 01158 enow = e[++eindex]; 01159 } else { 01160 Fast_Two_Sum(fnow, g0, Qnew, q); 01161 fnow = f[++findex]; 01162 } 01163 Q = Qnew; 01164 for (count = 2; count < elen + flen; count++) { 01165 if ((eindex < elen) && ((findex >= flen) 01166 || ((fnow > enow) == (fnow > -enow)))) { 01167 Fast_Two_Sum(enow, q, R, hh); 01168 enow = e[++eindex]; 01169 } else { 01170 Fast_Two_Sum(fnow, q, R, hh); 01171 fnow = f[++findex]; 01172 } 01173 Two_Sum(Q, R, Qnew, q); 01174 Q = Qnew; 01175 if (hh != 0) { 01176 h[hindex++] = hh; 01177 } 01178 } 01179 if (q != 0) { 01180 h[hindex++] = q; 01181 } 01182 if ((Q != 0.0) || (hindex == 0)) { 01183 h[hindex++] = Q; 01184 } 01185 return hindex; 01186 } 01187 01188 /*****************************************************************************/ 01189 /* */ 01190 /* scale_expansion() Multiply an expansion by a scalar. */ 01191 /* */ 01192 /* Sets h = be. See either version of my paper for details. */ 01193 /* */ 01194 /* Maintains the nonoverlapping property. If round-to-even is used (as */ 01195 /* with IEEE 754), maintains the strongly nonoverlapping and nonadjacent */ 01196 /* properties as well. (That is, if e has one of these properties, so */ 01197 /* will h.) */ 01198 /* */ 01199 /*****************************************************************************/ 01200 01201 int scale_expansion(int elen, REAL *e, REAL b, REAL *h) /* e and h cannot be the same. */ 01202 { 01203 INEXACT REAL Q; 01204 INEXACT REAL sum; 01205 INEXACT REAL product1; 01206 REAL product0; 01207 int eindex, hindex; 01208 REAL enow; 01209 INEXACT REAL bvirt; 01210 REAL avirt, bround, around; 01211 INEXACT REAL c; 01212 INEXACT REAL abig; 01213 REAL ahi, alo, bhi, blo; 01214 REAL err1, err2, err3; 01215 01216 Split(b, bhi, blo); 01217 Two_Product_Presplit(e[0], b, bhi, blo, Q, h[0]); 01218 hindex = 1; 01219 for (eindex = 1; eindex < elen; eindex++) { 01220 enow = e[eindex]; 01221 Two_Product_Presplit(enow, b, bhi, blo, product1, product0); 01222 Two_Sum(Q, product0, sum, h[hindex]); 01223 hindex++; 01224 Two_Sum(product1, sum, Q, h[hindex]); 01225 hindex++; 01226 } 01227 h[hindex] = Q; 01228 return elen + elen; 01229 } 01230 01231 /*****************************************************************************/ 01232 /* */ 01233 /* scale_expansion_zeroelim() Multiply an expansion by a scalar, */ 01234 /* eliminating zero components from the */ 01235 /* output expansion. */ 01236 /* */ 01237 /* Sets h = be. See either version of my paper for details. */ 01238 /* */ 01239 /* Maintains the nonoverlapping property. If round-to-even is used (as */ 01240 /* with IEEE 754), maintains the strongly nonoverlapping and nonadjacent */ 01241 /* properties as well. (That is, if e has one of these properties, so */ 01242 /* will h.) */ 01243 /* */ 01244 /*****************************************************************************/ 01245 01246 int scale_expansion_zeroelim(int elen, REAL *e, REAL b, REAL *h) /* e and h cannot be the same. */ 01247 { 01248 INEXACT REAL Q, sum; 01249 REAL hh; 01250 INEXACT REAL product1; 01251 REAL product0; 01252 int eindex, hindex; 01253 REAL enow; 01254 INEXACT REAL bvirt; 01255 REAL avirt, bround, around; 01256 INEXACT REAL c; 01257 INEXACT REAL abig; 01258 REAL ahi, alo, bhi, blo; 01259 REAL err1, err2, err3; 01260 01261 Split(b, bhi, blo); 01262 Two_Product_Presplit(e[0], b, bhi, blo, Q, hh); 01263 hindex = 0; 01264 if (hh != 0) { 01265 h[hindex++] = hh; 01266 } 01267 for (eindex = 1; eindex < elen; eindex++) { 01268 enow = e[eindex]; 01269 Two_Product_Presplit(enow, b, bhi, blo, product1, product0); 01270 Two_Sum(Q, product0, sum, hh); 01271 if (hh != 0) { 01272 h[hindex++] = hh; 01273 } 01274 Fast_Two_Sum(product1, sum, Q, hh); 01275 if (hh != 0) { 01276 h[hindex++] = hh; 01277 } 01278 } 01279 if ((Q != 0.0) || (hindex == 0)) { 01280 h[hindex++] = Q; 01281 } 01282 return hindex; 01283 } 01284 01285 /*****************************************************************************/ 01286 /* */ 01287 /* compress() Compress an expansion. */ 01288 /* */ 01289 /* See the long version of my paper for details. */ 01290 /* */ 01291 /* Maintains the nonoverlapping property. If round-to-even is used (as */ 01292 /* with IEEE 754), then any nonoverlapping expansion is converted to a */ 01293 /* nonadjacent expansion. */ 01294 /* */ 01295 /*****************************************************************************/ 01296 01297 int compress(int elen, REAL *e, REAL *h) /* e and h may be the same. */ 01298 { 01299 REAL Q, q; 01300 INEXACT REAL Qnew; 01301 int eindex, hindex; 01302 INEXACT REAL bvirt; 01303 REAL enow, hnow; 01304 int top, bottom; 01305 01306 bottom = elen - 1; 01307 Q = e[bottom]; 01308 for (eindex = elen - 2; eindex >= 0; eindex--) { 01309 enow = e[eindex]; 01310 Fast_Two_Sum(Q, enow, Qnew, q); 01311 if (q != 0) { 01312 h[bottom--] = Qnew; 01313 Q = q; 01314 } else { 01315 Q = Qnew; 01316 } 01317 } 01318 top = 0; 01319 for (hindex = bottom + 1; hindex < elen; hindex++) { 01320 hnow = h[hindex]; 01321 Fast_Two_Sum(hnow, Q, Qnew, q); 01322 if (q != 0) { 01323 h[top++] = q; 01324 } 01325 Q = Qnew; 01326 } 01327 h[top] = Q; 01328 return top + 1; 01329 } 01330 01331 /*****************************************************************************/ 01332 /* */ 01333 /* estimate() Produce a one-word estimate of an expansion's value. */ 01334 /* */ 01335 /* See either version of my paper for details. */ 01336 /* */ 01337 /*****************************************************************************/ 01338 01339 REAL estimate(int elen, REAL *e) 01340 { 01341 REAL Q; 01342 int eindex; 01343 01344 Q = e[0]; 01345 for (eindex = 1; eindex < elen; eindex++) { 01346 Q += e[eindex]; 01347 } 01348 return Q; 01349 } 01350 01351 /*****************************************************************************/ 01352 /* */ 01353 /* orient2dfast() Approximate 2D orientation test. Nonrobust. */ 01354 /* orient2dexact() Exact 2D orientation test. Robust. */ 01355 /* orient2dslow() Another exact 2D orientation test. Robust. */ 01356 /* orient2d() Adaptive exact 2D orientation test. Robust. */ 01357 /* */ 01358 /* Return a positive value if the points pa, pb, and pc occur */ 01359 /* in counterclockwise order; a negative value if they occur */ 01360 /* in clockwise order; and zero if they are collinear. The */ 01361 /* result is also a rough approximation of twice the signed */ 01362 /* area of the triangle defined by the three points. */ 01363 /* */ 01364 /* Only the first and last routine should be used; the middle two are for */ 01365 /* timings. */ 01366 /* */ 01367 /* The last three use exact arithmetic to ensure a correct answer. The */ 01368 /* result returned is the determinant of a matrix. In orient2d() only, */ 01369 /* this determinant is computed adaptively, in the sense that exact */ 01370 /* arithmetic is used only to the degree it is needed to ensure that the */ 01371 /* returned value has the correct sign. Hence, orient2d() is usually quite */ 01372 /* fast, but will run more slowly when the input points are collinear or */ 01373 /* nearly so. */ 01374 /* */ 01375 /*****************************************************************************/ 01376 01377 REAL orient2dfast(REAL *pa, REAL *pb, REAL *pc) 01378 { 01379 REAL acx, bcx, acy, bcy; 01380 01381 acx = pa[0] - pc[0]; 01382 bcx = pb[0] - pc[0]; 01383 acy = pa[1] - pc[1]; 01384 bcy = pb[1] - pc[1]; 01385 return acx * bcy - acy * bcx; 01386 } 01387 01388 REAL orient2dexact(REAL *pa, REAL *pb, REAL *pc) 01389 { 01390 INEXACT REAL axby1, axcy1, bxcy1, bxay1, cxay1, cxby1; 01391 REAL axby0, axcy0, bxcy0, bxay0, cxay0, cxby0; 01392 REAL aterms[4], bterms[4], cterms[4]; 01393 INEXACT REAL aterms3, bterms3, cterms3; 01394 REAL v[8], w[12]; 01395 int vlength, wlength; 01396 01397 INEXACT REAL bvirt; 01398 REAL avirt, bround, around; 01399 INEXACT REAL c; 01400 INEXACT REAL abig; 01401 REAL ahi, alo, bhi, blo; 01402 REAL err1, err2, err3; 01403 INEXACT REAL _i, _j; 01404 REAL _0; 01405 01406 Two_Product(pa[0], pb[1], axby1, axby0); 01407 Two_Product(pa[0], pc[1], axcy1, axcy0); 01408 Two_Two_Diff(axby1, axby0, axcy1, axcy0, 01409 aterms3, aterms[2], aterms[1], aterms[0]); 01410 aterms[3] = aterms3; 01411 01412 Two_Product(pb[0], pc[1], bxcy1, bxcy0); 01413 Two_Product(pb[0], pa[1], bxay1, bxay0); 01414 Two_Two_Diff(bxcy1, bxcy0, bxay1, bxay0, 01415 bterms3, bterms[2], bterms[1], bterms[0]); 01416 bterms[3] = bterms3; 01417 01418 Two_Product(pc[0], pa[1], cxay1, cxay0); 01419 Two_Product(pc[0], pb[1], cxby1, cxby0); 01420 Two_Two_Diff(cxay1, cxay0, cxby1, cxby0, 01421 cterms3, cterms[2], cterms[1], cterms[0]); 01422 cterms[3] = cterms3; 01423 01424 vlength = fast_expansion_sum_zeroelim(4, aterms, 4, bterms, v); 01425 wlength = fast_expansion_sum_zeroelim(vlength, v, 4, cterms, w); 01426 01427 return w[wlength - 1]; 01428 } 01429 01430 REAL orient2dslow(REAL *pa, REAL *pb, REAL *pc) 01431 { 01432 INEXACT REAL acx, acy, bcx, bcy; 01433 REAL acxtail, acytail; 01434 REAL bcxtail, bcytail; 01435 REAL negate, negatetail; 01436 REAL axby[8], bxay[8]; 01437 INEXACT REAL axby7, bxay7; 01438 REAL deter[16]; 01439 int deterlen; 01440 01441 INEXACT REAL bvirt; 01442 REAL avirt, bround, around; 01443 INEXACT REAL c; 01444 INEXACT REAL abig; 01445 REAL a0hi, a0lo, a1hi, a1lo, bhi, blo; 01446 REAL err1, err2, err3; 01447 INEXACT REAL _i, _j, _k, _l, _m, _n; 01448 REAL _0, _1, _2; 01449 01450 Two_Diff(pa[0], pc[0], acx, acxtail); 01451 Two_Diff(pa[1], pc[1], acy, acytail); 01452 Two_Diff(pb[0], pc[0], bcx, bcxtail); 01453 Two_Diff(pb[1], pc[1], bcy, bcytail); 01454 01455 Two_Two_Product(acx, acxtail, bcy, bcytail, 01456 axby7, axby[6], axby[5], axby[4], 01457 axby[3], axby[2], axby[1], axby[0]); 01458 axby[7] = axby7; 01459 negate = -acy; 01460 negatetail = -acytail; 01461 Two_Two_Product(bcx, bcxtail, negate, negatetail, 01462 bxay7, bxay[6], bxay[5], bxay[4], 01463 bxay[3], bxay[2], bxay[1], bxay[0]); 01464 bxay[7] = bxay7; 01465 01466 deterlen = fast_expansion_sum_zeroelim(8, axby, 8, bxay, deter); 01467 01468 return deter[deterlen - 1]; 01469 } 01470 01471 REAL orient2dadapt(REAL *pa, REAL *pb, REAL *pc, REAL detsum) 01472 { 01473 INEXACT REAL acx, acy, bcx, bcy; 01474 REAL acxtail, acytail, bcxtail, bcytail; 01475 INEXACT REAL detleft, detright; 01476 REAL detlefttail, detrighttail; 01477 REAL det, errbound; 01478 REAL B[4], C1[8], C2[12], D[16]; 01479 INEXACT REAL B3; 01480 int C1length, C2length, Dlength; 01481 REAL u[4]; 01482 INEXACT REAL u3; 01483 INEXACT REAL s1, t1; 01484 REAL s0, t0; 01485 01486 INEXACT REAL bvirt; 01487 REAL avirt, bround, around; 01488 INEXACT REAL c; 01489 INEXACT REAL abig; 01490 REAL ahi, alo, bhi, blo; 01491 REAL err1, err2, err3; 01492 INEXACT REAL _i, _j; 01493 REAL _0; 01494 01495 acx = (REAL) (pa[0] - pc[0]); 01496 bcx = (REAL) (pb[0] - pc[0]); 01497 acy = (REAL) (pa[1] - pc[1]); 01498 bcy = (REAL) (pb[1] - pc[1]); 01499 01500 Two_Product(acx, bcy, detleft, detlefttail); 01501 Two_Product(acy, bcx, detright, detrighttail); 01502 01503 Two_Two_Diff(detleft, detlefttail, detright, detrighttail, 01504 B3, B[2], B[1], B[0]); 01505 B[3] = B3; 01506 01507 det = estimate(4, B); 01508 errbound = ccwerrboundB * detsum; 01509 if ((det >= errbound) || (-det >= errbound)) { 01510 return det; 01511 } 01512 01513 Two_Diff_Tail(pa[0], pc[0], acx, acxtail); 01514 Two_Diff_Tail(pb[0], pc[0], bcx, bcxtail); 01515 Two_Diff_Tail(pa[1], pc[1], acy, acytail); 01516 Two_Diff_Tail(pb[1], pc[1], bcy, bcytail); 01517 01518 if ((acxtail == 0.0) && (acytail == 0.0) 01519 && (bcxtail == 0.0) && (bcytail == 0.0)) { 01520 return det; 01521 } 01522 01523 errbound = ccwerrboundC * detsum + resulterrbound * Absolute(det); 01524 det += (acx * bcytail + bcy * acxtail) 01525 - (acy * bcxtail + bcx * acytail); 01526 if ((det >= errbound) || (-det >= errbound)) { 01527 return det; 01528 } 01529 01530 Two_Product(acxtail, bcy, s1, s0); 01531 Two_Product(acytail, bcx, t1, t0); 01532 Two_Two_Diff(s1, s0, t1, t0, u3, u[2], u[1], u[0]); 01533 u[3] = u3; 01534 C1length = fast_expansion_sum_zeroelim(4, B, 4, u, C1); 01535 01536 Two_Product(acx, bcytail, s1, s0); 01537 Two_Product(acy, bcxtail, t1, t0); 01538 Two_Two_Diff(s1, s0, t1, t0, u3, u[2], u[1], u[0]); 01539 u[3] = u3; 01540 C2length = fast_expansion_sum_zeroelim(C1length, C1, 4, u, C2); 01541 01542 Two_Product(acxtail, bcytail, s1, s0); 01543 Two_Product(acytail, bcxtail, t1, t0); 01544 Two_Two_Diff(s1, s0, t1, t0, u3, u[2], u[1], u[0]); 01545 u[3] = u3; 01546 Dlength = fast_expansion_sum_zeroelim(C2length, C2, 4, u, D); 01547 01548 return(D[Dlength - 1]); 01549 } 01550 01551 REAL orient2d(REAL *pa, REAL *pb, REAL *pc) 01552 { 01553 REAL detleft, detright, det; 01554 REAL detsum, errbound; 01555 01556 detleft = (pa[0] - pc[0]) * (pb[1] - pc[1]); 01557 detright = (pa[1] - pc[1]) * (pb[0] - pc[0]); 01558 det = detleft - detright; 01559 01560 if (detleft > 0.0) { 01561 if (detright <= 0.0) { 01562 return det; 01563 } else { 01564 detsum = detleft + detright; 01565 } 01566 } else if (detleft < 0.0) { 01567 if (detright >= 0.0) { 01568 return det; 01569 } else { 01570 detsum = -detleft - detright; 01571 } 01572 } else { 01573 return det; 01574 } 01575 01576 errbound = ccwerrboundA * detsum; 01577 if ((det >= errbound) || (-det >= errbound)) { 01578 return det; 01579 } 01580 01581 return orient2dadapt(pa, pb, pc, detsum); 01582 } 01583 01584 /*****************************************************************************/ 01585 /* */ 01586 /* orient3dfast() Approximate 3D orientation test. Nonrobust. */ 01587 /* orient3dexact() Exact 3D orientation test. Robust. */ 01588 /* orient3dslow() Another exact 3D orientation test. Robust. */ 01589 /* orient3d() Adaptive exact 3D orientation test. Robust. */ 01590 /* */ 01591 /* Return a positive value if the point pd lies below the */ 01592 /* plane passing through pa, pb, and pc; "below" is defined so */ 01593 /* that pa, pb, and pc appear in counterclockwise order when */ 01594 /* viewed from above the plane. Returns a negative value if */ 01595 /* pd lies above the plane. Returns zero if the points are */ 01596 /* coplanar. The result is also a rough approximation of six */ 01597 /* times the signed volume of the tetrahedron defined by the */ 01598 /* four points. */ 01599 /* */ 01600 /* Only the first and last routine should be used; the middle two are for */ 01601 /* timings. */ 01602 /* */ 01603 /* The last three use exact arithmetic to ensure a correct answer. The */ 01604 /* result returned is the determinant of a matrix. In orient3d() only, */ 01605 /* this determinant is computed adaptively, in the sense that exact */ 01606 /* arithmetic is used only to the degree it is needed to ensure that the */ 01607 /* returned value has the correct sign. Hence, orient3d() is usually quite */ 01608 /* fast, but will run more slowly when the input points are coplanar or */ 01609 /* nearly so. */ 01610 /* */ 01611 /*****************************************************************************/ 01612 01613 REAL orient3dfast(REAL *pa, REAL *pb, REAL *pc, REAL *pd) 01614 { 01615 REAL adx, bdx, cdx; 01616 REAL ady, bdy, cdy; 01617 REAL adz, bdz, cdz; 01618 01619 adx = pa[0] - pd[0]; 01620 bdx = pb[0] - pd[0]; 01621 cdx = pc[0] - pd[0]; 01622 ady = pa[1] - pd[1]; 01623 bdy = pb[1] - pd[1]; 01624 cdy = pc[1] - pd[1]; 01625 adz = pa[2] - pd[2]; 01626 bdz = pb[2] - pd[2]; 01627 cdz = pc[2] - pd[2]; 01628 01629 return adx * (bdy * cdz - bdz * cdy) 01630 + bdx * (cdy * adz - cdz * ady) 01631 + cdx * (ady * bdz - adz * bdy); 01632 } 01633 01634 REAL orient3dexact(REAL *pa, REAL *pb, REAL *pc, REAL *pd) 01635 { 01636 INEXACT REAL axby1, bxcy1, cxdy1, dxay1, axcy1, bxdy1; 01637 INEXACT REAL bxay1, cxby1, dxcy1, axdy1, cxay1, dxby1; 01638 REAL axby0, bxcy0, cxdy0, dxay0, axcy0, bxdy0; 01639 REAL bxay0, cxby0, dxcy0, axdy0, cxay0, dxby0; 01640 REAL ab[4], bc[4], cd[4], da[4], ac[4], bd[4]; 01641 REAL temp8[8]; 01642 int templen; 01643 REAL abc[12], bcd[12], cda[12], dab[12]; 01644 int abclen, bcdlen, cdalen, dablen; 01645 REAL adet[24], bdet[24], cdet[24], ddet[24]; 01646 int alen, blen, clen, dlen; 01647 REAL abdet[48], cddet[48]; 01648 int ablen, cdlen; 01649 REAL deter[96]; 01650 int deterlen; 01651 int i; 01652 01653 INEXACT REAL bvirt; 01654 REAL avirt, bround, around; 01655 INEXACT REAL c; 01656 INEXACT REAL abig; 01657 REAL ahi, alo, bhi, blo; 01658 REAL err1, err2, err3; 01659 INEXACT REAL _i, _j; 01660 REAL _0; 01661 01662 Two_Product(pa[0], pb[1], axby1, axby0); 01663 Two_Product(pb[0], pa[1], bxay1, bxay0); 01664 Two_Two_Diff(axby1, axby0, bxay1, bxay0, ab[3], ab[2], ab[1], ab[0]); 01665 01666 Two_Product(pb[0], pc[1], bxcy1, bxcy0); 01667 Two_Product(pc[0], pb[1], cxby1, cxby0); 01668 Two_Two_Diff(bxcy1, bxcy0, cxby1, cxby0, bc[3], bc[2], bc[1], bc[0]); 01669 01670 Two_Product(pc[0], pd[1], cxdy1, cxdy0); 01671 Two_Product(pd[0], pc[1], dxcy1, dxcy0); 01672 Two_Two_Diff(cxdy1, cxdy0, dxcy1, dxcy0, cd[3], cd[2], cd[1], cd[0]); 01673 01674 Two_Product(pd[0], pa[1], dxay1, dxay0); 01675 Two_Product(pa[0], pd[1], axdy1, axdy0); 01676 Two_Two_Diff(dxay1, dxay0, axdy1, axdy0, da[3], da[2], da[1], da[0]); 01677 01678 Two_Product(pa[0], pc[1], axcy1, axcy0); 01679 Two_Product(pc[0], pa[1], cxay1, cxay0); 01680 Two_Two_Diff(axcy1, axcy0, cxay1, cxay0, ac[3], ac[2], ac[1], ac[0]); 01681 01682 Two_Product(pb[0], pd[1], bxdy1, bxdy0); 01683 Two_Product(pd[0], pb[1], dxby1, dxby0); 01684 Two_Two_Diff(bxdy1, bxdy0, dxby1, dxby0, bd[3], bd[2], bd[1], bd[0]); 01685 01686 templen = fast_expansion_sum_zeroelim(4, cd, 4, da, temp8); 01687 cdalen = fast_expansion_sum_zeroelim(templen, temp8, 4, ac, cda); 01688 templen = fast_expansion_sum_zeroelim(4, da, 4, ab, temp8); 01689 dablen = fast_expansion_sum_zeroelim(templen, temp8, 4, bd, dab); 01690 for (i = 0; i < 4; i++) { 01691 bd[i] = -bd[i]; 01692 ac[i] = -ac[i]; 01693 } 01694 templen = fast_expansion_sum_zeroelim(4, ab, 4, bc, temp8); 01695 abclen = fast_expansion_sum_zeroelim(templen, temp8, 4, ac, abc); 01696 templen = fast_expansion_sum_zeroelim(4, bc, 4, cd, temp8); 01697 bcdlen = fast_expansion_sum_zeroelim(templen, temp8, 4, bd, bcd); 01698 01699 alen = scale_expansion_zeroelim(bcdlen, bcd, pa[2], adet); 01700 blen = scale_expansion_zeroelim(cdalen, cda, -pb[2], bdet); 01701 clen = scale_expansion_zeroelim(dablen, dab, pc[2], cdet); 01702 dlen = scale_expansion_zeroelim(abclen, abc, -pd[2], ddet); 01703 01704 ablen = fast_expansion_sum_zeroelim(alen, adet, blen, bdet, abdet); 01705 cdlen = fast_expansion_sum_zeroelim(clen, cdet, dlen, ddet, cddet); 01706 deterlen = fast_expansion_sum_zeroelim(ablen, abdet, cdlen, cddet, deter); 01707 01708 return deter[deterlen - 1]; 01709 } 01710 01711 REAL orient3dslow(REAL *pa, REAL *pb, REAL *pc, REAL *pd) 01712 { 01713 INEXACT REAL adx, ady, adz, bdx, bdy, bdz, cdx, cdy, cdz; 01714 REAL adxtail, adytail, adztail; 01715 REAL bdxtail, bdytail, bdztail; 01716 REAL cdxtail, cdytail, cdztail; 01717 REAL negate, negatetail; 01718 INEXACT REAL axby7, bxcy7, axcy7, bxay7, cxby7, cxay7; 01719 REAL axby[8], bxcy[8], axcy[8], bxay[8], cxby[8], cxay[8]; 01720 REAL temp16[16], temp32[32], temp32t[32]; 01721 int temp16len, temp32len, temp32tlen; 01722 REAL adet[64], bdet[64], cdet[64]; 01723 int alen, blen, clen; 01724 REAL abdet[128]; 01725 int ablen; 01726 REAL deter[192]; 01727 int deterlen; 01728 01729 INEXACT REAL bvirt; 01730 REAL avirt, bround, around; 01731 INEXACT REAL c; 01732 INEXACT REAL abig; 01733 REAL a0hi, a0lo, a1hi, a1lo, bhi, blo; 01734 REAL err1, err2, err3; 01735 INEXACT REAL _i, _j, _k, _l, _m, _n; 01736 REAL _0, _1, _2; 01737 01738 Two_Diff(pa[0], pd[0], adx, adxtail); 01739 Two_Diff(pa[1], pd[1], ady, adytail); 01740 Two_Diff(pa[2], pd[2], adz, adztail); 01741 Two_Diff(pb[0], pd[0], bdx, bdxtail); 01742 Two_Diff(pb[1], pd[1], bdy, bdytail); 01743 Two_Diff(pb[2], pd[2], bdz, bdztail); 01744 Two_Diff(pc[0], pd[0], cdx, cdxtail); 01745 Two_Diff(pc[1], pd[1], cdy, cdytail); 01746 Two_Diff(pc[2], pd[2], cdz, cdztail); 01747 01748 Two_Two_Product(adx, adxtail, bdy, bdytail, 01749 axby7, axby[6], axby[5], axby[4], 01750 axby[3], axby[2], axby[1], axby[0]); 01751 axby[7] = axby7; 01752 negate = -ady; 01753 negatetail = -adytail; 01754 Two_Two_Product(bdx, bdxtail, negate, negatetail, 01755 bxay7, bxay[6], bxay[5], bxay[4], 01756 bxay[3], bxay[2], bxay[1], bxay[0]); 01757 bxay[7] = bxay7; 01758 Two_Two_Product(bdx, bdxtail, cdy, cdytail, 01759 bxcy7, bxcy[6], bxcy[5], bxcy[4], 01760 bxcy[3], bxcy[2], bxcy[1], bxcy[0]); 01761 bxcy[7] = bxcy7; 01762 negate = -bdy; 01763 negatetail = -bdytail; 01764 Two_Two_Product(cdx, cdxtail, negate, negatetail, 01765 cxby7, cxby[6], cxby[5], cxby[4], 01766 cxby[3], cxby[2], cxby[1], cxby[0]); 01767 cxby[7] = cxby7; 01768 Two_Two_Product(cdx, cdxtail, ady, adytail, 01769 cxay7, cxay[6], cxay[5], cxay[4], 01770 cxay[3], cxay[2], cxay[1], cxay[0]); 01771 cxay[7] = cxay7; 01772 negate = -cdy; 01773 negatetail = -cdytail; 01774 Two_Two_Product(adx, adxtail, negate, negatetail, 01775 axcy7, axcy[6], axcy[5], axcy[4], 01776 axcy[3], axcy[2], axcy[1], axcy[0]); 01777 axcy[7] = axcy7; 01778 01779 temp16len = fast_expansion_sum_zeroelim(8, bxcy, 8, cxby, temp16); 01780 temp32len = scale_expansion_zeroelim(temp16len, temp16, adz, temp32); 01781 temp32tlen = scale_expansion_zeroelim(temp16len, temp16, adztail, temp32t); 01782 alen = fast_expansion_sum_zeroelim(temp32len, temp32, temp32tlen, temp32t, 01783 adet); 01784 01785 temp16len = fast_expansion_sum_zeroelim(8, cxay, 8, axcy, temp16); 01786 temp32len = scale_expansion_zeroelim(temp16len, temp16, bdz, temp32); 01787 temp32tlen = scale_expansion_zeroelim(temp16len, temp16, bdztail, temp32t); 01788 blen = fast_expansion_sum_zeroelim(temp32len, temp32, temp32tlen, temp32t, 01789 bdet); 01790 01791 temp16len = fast_expansion_sum_zeroelim(8, axby, 8, bxay, temp16); 01792 temp32len = scale_expansion_zeroelim(temp16len, temp16, cdz, temp32); 01793 temp32tlen = scale_expansion_zeroelim(temp16len, temp16, cdztail, temp32t); 01794 clen = fast_expansion_sum_zeroelim(temp32len, temp32, temp32tlen, temp32t, 01795 cdet); 01796 01797 ablen = fast_expansion_sum_zeroelim(alen, adet, blen, bdet, abdet); 01798 deterlen = fast_expansion_sum_zeroelim(ablen, abdet, clen, cdet, deter); 01799 01800 return deter[deterlen - 1]; 01801 } 01802 01803 REAL orient3dadapt(REAL *pa, REAL *pb, REAL *pc, REAL *pd, REAL permanent) 01804 { 01805 INEXACT REAL adx, bdx, cdx, ady, bdy, cdy, adz, bdz, cdz; 01806 REAL det, errbound; 01807 01808 INEXACT REAL bdxcdy1, cdxbdy1, cdxady1, adxcdy1, adxbdy1, bdxady1; 01809 REAL bdxcdy0, cdxbdy0, cdxady0, adxcdy0, adxbdy0, bdxady0; 01810 REAL bc[4], ca[4], ab[4]; 01811 INEXACT REAL bc3, ca3, ab3; 01812 REAL adet[8], bdet[8], cdet[8]; 01813 int alen, blen, clen; 01814 REAL abdet[16]; 01815 int ablen; 01816 REAL *finnow, *finother, *finswap; 01817 REAL fin1[192], fin2[192]; 01818 int finlength; 01819 01820 REAL adxtail, bdxtail, cdxtail; 01821 REAL adytail, bdytail, cdytail; 01822 REAL adztail, bdztail, cdztail; 01823 INEXACT REAL at_blarge, at_clarge; 01824 INEXACT REAL bt_clarge, bt_alarge; 01825 INEXACT REAL ct_alarge, ct_blarge; 01826 REAL at_b[4], at_c[4], bt_c[4], bt_a[4], ct_a[4], ct_b[4]; 01827 int at_blen, at_clen, bt_clen, bt_alen, ct_alen, ct_blen; 01828 INEXACT REAL bdxt_cdy1, cdxt_bdy1, cdxt_ady1; 01829 INEXACT REAL adxt_cdy1, adxt_bdy1, bdxt_ady1; 01830 REAL bdxt_cdy0, cdxt_bdy0, cdxt_ady0; 01831 REAL adxt_cdy0, adxt_bdy0, bdxt_ady0; 01832 INEXACT REAL bdyt_cdx1, cdyt_bdx1, cdyt_adx1; 01833 INEXACT REAL adyt_cdx1, adyt_bdx1, bdyt_adx1; 01834 REAL bdyt_cdx0, cdyt_bdx0, cdyt_adx0; 01835 REAL adyt_cdx0, adyt_bdx0, bdyt_adx0; 01836 REAL bct[8], cat[8], abt[8]; 01837 int bctlen, catlen, abtlen; 01838 INEXACT REAL bdxt_cdyt1, cdxt_bdyt1, cdxt_adyt1; 01839 INEXACT REAL adxt_cdyt1, adxt_bdyt1, bdxt_adyt1; 01840 REAL bdxt_cdyt0, cdxt_bdyt0, cdxt_adyt0; 01841 REAL adxt_cdyt0, adxt_bdyt0, bdxt_adyt0; 01842 REAL u[4], v[12], w[16]; 01843 INEXACT REAL u3; 01844 int vlength, wlength; 01845 REAL negate; 01846 01847 INEXACT REAL bvirt; 01848 REAL avirt, bround, around; 01849 INEXACT REAL c; 01850 INEXACT REAL abig; 01851 REAL ahi, alo, bhi, blo; 01852 REAL err1, err2, err3; 01853 INEXACT REAL _i, _j, _k; 01854 REAL _0; 01855 01856 adx = (REAL) (pa[0] - pd[0]); 01857 bdx = (REAL) (pb[0] - pd[0]); 01858 cdx = (REAL) (pc[0] - pd[0]); 01859 ady = (REAL) (pa[1] - pd[1]); 01860 bdy = (REAL) (pb[1] - pd[1]); 01861 cdy = (REAL) (pc[1] - pd[1]); 01862 adz = (REAL) (pa[2] - pd[2]); 01863 bdz = (REAL) (pb[2] - pd[2]); 01864 cdz = (REAL) (pc[2] - pd[2]); 01865 01866 Two_Product(bdx, cdy, bdxcdy1, bdxcdy0); 01867 Two_Product(cdx, bdy, cdxbdy1, cdxbdy0); 01868 Two_Two_Diff(bdxcdy1, bdxcdy0, cdxbdy1, cdxbdy0, bc3, bc[2], bc[1], bc[0]); 01869 bc[3] = bc3; 01870 alen = scale_expansion_zeroelim(4, bc, adz, adet); 01871 01872 Two_Product(cdx, ady, cdxady1, cdxady0); 01873 Two_Product(adx, cdy, adxcdy1, adxcdy0); 01874 Two_Two_Diff(cdxady1, cdxady0, adxcdy1, adxcdy0, ca3, ca[2], ca[1], ca[0]); 01875 ca[3] = ca3; 01876 blen = scale_expansion_zeroelim(4, ca, bdz, bdet); 01877 01878 Two_Product(adx, bdy, adxbdy1, adxbdy0); 01879 Two_Product(bdx, ady, bdxady1, bdxady0); 01880 Two_Two_Diff(adxbdy1, adxbdy0, bdxady1, bdxady0, ab3, ab[2], ab[1], ab[0]); 01881 ab[3] = ab3; 01882 clen = scale_expansion_zeroelim(4, ab, cdz, cdet); 01883 01884 ablen = fast_expansion_sum_zeroelim(alen, adet, blen, bdet, abdet); 01885 finlength = fast_expansion_sum_zeroelim(ablen, abdet, clen, cdet, fin1); 01886 01887 det = estimate(finlength, fin1); 01888 errbound = o3derrboundB * permanent; 01889 if ((det >= errbound) || (-det >= errbound)) { 01890 return det; 01891 } 01892 01893 Two_Diff_Tail(pa[0], pd[0], adx, adxtail); 01894 Two_Diff_Tail(pb[0], pd[0], bdx, bdxtail); 01895 Two_Diff_Tail(pc[0], pd[0], cdx, cdxtail); 01896 Two_Diff_Tail(pa[1], pd[1], ady, adytail); 01897 Two_Diff_Tail(pb[1], pd[1], bdy, bdytail); 01898 Two_Diff_Tail(pc[1], pd[1], cdy, cdytail); 01899 Two_Diff_Tail(pa[2], pd[2], adz, adztail); 01900 Two_Diff_Tail(pb[2], pd[2], bdz, bdztail); 01901 Two_Diff_Tail(pc[2], pd[2], cdz, cdztail); 01902 01903 if ((adxtail == 0.0) && (bdxtail == 0.0) && (cdxtail == 0.0) 01904 && (adytail == 0.0) && (bdytail == 0.0) && (cdytail == 0.0) 01905 && (adztail == 0.0) && (bdztail == 0.0) && (cdztail == 0.0)) { 01906 return det; 01907 } 01908 01909 errbound = o3derrboundC * permanent + resulterrbound * Absolute(det); 01910 det += (adz * ((bdx * cdytail + cdy * bdxtail) 01911 - (bdy * cdxtail + cdx * bdytail)) 01912 + adztail * (bdx * cdy - bdy * cdx)) 01913 + (bdz * ((cdx * adytail + ady * cdxtail) 01914 - (cdy * adxtail + adx * cdytail)) 01915 + bdztail * (cdx * ady - cdy * adx)) 01916 + (cdz * ((adx * bdytail + bdy * adxtail) 01917 - (ady * bdxtail + bdx * adytail)) 01918 + cdztail * (adx * bdy - ady * bdx)); 01919 if ((det >= errbound) || (-det >= errbound)) { 01920 return det; 01921 } 01922 01923 finnow = fin1; 01924 finother = fin2; 01925 01926 if (adxtail == 0.0) { 01927 if (adytail == 0.0) { 01928 at_b[0] = 0.0; 01929 at_blen = 1; 01930 at_c[0] = 0.0; 01931 at_clen = 1; 01932 } else { 01933 negate = -adytail; 01934 Two_Product(negate, bdx, at_blarge, at_b[0]); 01935 at_b[1] = at_blarge; 01936 at_blen = 2; 01937 Two_Product(adytail, cdx, at_clarge, at_c[0]); 01938 at_c[1] = at_clarge; 01939 at_clen = 2; 01940 } 01941 } else { 01942 if (adytail == 0.0) { 01943 Two_Product(adxtail, bdy, at_blarge, at_b[0]); 01944 at_b[1] = at_blarge; 01945 at_blen = 2; 01946 negate = -adxtail; 01947 Two_Product(negate, cdy, at_clarge, at_c[0]); 01948 at_c[1] = at_clarge; 01949 at_clen = 2; 01950 } else { 01951 Two_Product(adxtail, bdy, adxt_bdy1, adxt_bdy0); 01952 Two_Product(adytail, bdx, adyt_bdx1, adyt_bdx0); 01953 Two_Two_Diff(adxt_bdy1, adxt_bdy0, adyt_bdx1, adyt_bdx0, 01954 at_blarge, at_b[2], at_b[1], at_b[0]); 01955 at_b[3] = at_blarge; 01956 at_blen = 4; 01957 Two_Product(adytail, cdx, adyt_cdx1, adyt_cdx0); 01958 Two_Product(adxtail, cdy, adxt_cdy1, adxt_cdy0); 01959 Two_Two_Diff(adyt_cdx1, adyt_cdx0, adxt_cdy1, adxt_cdy0, 01960 at_clarge, at_c[2], at_c[1], at_c[0]); 01961 at_c[3] = at_clarge; 01962 at_clen = 4; 01963 } 01964 } 01965 if (bdxtail == 0.0) { 01966 if (bdytail == 0.0) { 01967 bt_c[0] = 0.0; 01968 bt_clen = 1; 01969 bt_a[0] = 0.0; 01970 bt_alen = 1; 01971 } else { 01972 negate = -bdytail; 01973 Two_Product(negate, cdx, bt_clarge, bt_c[0]); 01974 bt_c[1] = bt_clarge; 01975 bt_clen = 2; 01976 Two_Product(bdytail, adx, bt_alarge, bt_a[0]); 01977 bt_a[1] = bt_alarge; 01978 bt_alen = 2; 01979 } 01980 } else { 01981 if (bdytail == 0.0) { 01982 Two_Product(bdxtail, cdy, bt_clarge, bt_c[0]); 01983 bt_c[1] = bt_clarge; 01984 bt_clen = 2; 01985 negate = -bdxtail; 01986 Two_Product(negate, ady, bt_alarge, bt_a[0]); 01987 bt_a[1] = bt_alarge; 01988 bt_alen = 2; 01989 } else { 01990 Two_Product(bdxtail, cdy, bdxt_cdy1, bdxt_cdy0); 01991 Two_Product(bdytail, cdx, bdyt_cdx1, bdyt_cdx0); 01992 Two_Two_Diff(bdxt_cdy1, bdxt_cdy0, bdyt_cdx1, bdyt_cdx0, 01993 bt_clarge, bt_c[2], bt_c[1], bt_c[0]); 01994 bt_c[3] = bt_clarge; 01995 bt_clen = 4; 01996 Two_Product(bdytail, adx, bdyt_adx1, bdyt_adx0); 01997 Two_Product(bdxtail, ady, bdxt_ady1, bdxt_ady0); 01998 Two_Two_Diff(bdyt_adx1, bdyt_adx0, bdxt_ady1, bdxt_ady0, 01999 bt_alarge, bt_a[2], bt_a[1], bt_a[0]); 02000 bt_a[3] = bt_alarge; 02001 bt_alen = 4; 02002 } 02003 } 02004 if (cdxtail == 0.0) { 02005 if (cdytail == 0.0) { 02006 ct_a[0] = 0.0; 02007 ct_alen = 1; 02008 ct_b[0] = 0.0; 02009 ct_blen = 1; 02010 } else { 02011 negate = -cdytail; 02012 Two_Product(negate, adx, ct_alarge, ct_a[0]); 02013 ct_a[1] = ct_alarge; 02014 ct_alen = 2; 02015 Two_Product(cdytail, bdx, ct_blarge, ct_b[0]); 02016 ct_b[1] = ct_blarge; 02017 ct_blen = 2; 02018 } 02019 } else { 02020 if (cdytail == 0.0) { 02021 Two_Product(cdxtail, ady, ct_alarge, ct_a[0]); 02022 ct_a[1] = ct_alarge; 02023 ct_alen = 2; 02024 negate = -cdxtail; 02025 Two_Product(negate, bdy, ct_blarge, ct_b[0]); 02026 ct_b[1] = ct_blarge; 02027 ct_blen = 2; 02028 } else { 02029 Two_Product(cdxtail, ady, cdxt_ady1, cdxt_ady0); 02030 Two_Product(cdytail, adx, cdyt_adx1, cdyt_adx0); 02031 Two_Two_Diff(cdxt_ady1, cdxt_ady0, cdyt_adx1, cdyt_adx0, 02032 ct_alarge, ct_a[2], ct_a[1], ct_a[0]); 02033 ct_a[3] = ct_alarge; 02034 ct_alen = 4; 02035 Two_Product(cdytail, bdx, cdyt_bdx1, cdyt_bdx0); 02036 Two_Product(cdxtail, bdy, cdxt_bdy1, cdxt_bdy0); 02037 Two_Two_Diff(cdyt_bdx1, cdyt_bdx0, cdxt_bdy1, cdxt_bdy0, 02038 ct_blarge, ct_b[2], ct_b[1], ct_b[0]); 02039 ct_b[3] = ct_blarge; 02040 ct_blen = 4; 02041 } 02042 } 02043 02044 bctlen = fast_expansion_sum_zeroelim(bt_clen, bt_c, ct_blen, ct_b, bct); 02045 wlength = scale_expansion_zeroelim(bctlen, bct, adz, w); 02046 finlength = fast_expansion_sum_zeroelim(finlength, finnow, wlength, w, 02047 finother); 02048 finswap = finnow; finnow = finother; finother = finswap; 02049 02050 catlen = fast_expansion_sum_zeroelim(ct_alen, ct_a, at_clen, at_c, cat); 02051 wlength = scale_expansion_zeroelim(catlen, cat, bdz, w); 02052 finlength = fast_expansion_sum_zeroelim(finlength, finnow, wlength, w, 02053 finother); 02054 finswap = finnow; finnow = finother; finother = finswap; 02055 02056 abtlen = fast_expansion_sum_zeroelim(at_blen, at_b, bt_alen, bt_a, abt); 02057 wlength = scale_expansion_zeroelim(abtlen, abt, cdz, w); 02058 finlength = fast_expansion_sum_zeroelim(finlength, finnow, wlength, w, 02059 finother); 02060 finswap = finnow; finnow = finother; finother = finswap; 02061 02062 if (adztail != 0.0) { 02063 vlength = scale_expansion_zeroelim(4, bc, adztail, v); 02064 finlength = fast_expansion_sum_zeroelim(finlength, finnow, vlength, v, 02065 finother); 02066 finswap = finnow; finnow = finother; finother = finswap; 02067 } 02068 if (bdztail != 0.0) { 02069 vlength = scale_expansion_zeroelim(4, ca, bdztail, v); 02070 finlength = fast_expansion_sum_zeroelim(finlength, finnow, vlength, v, 02071 finother); 02072 finswap = finnow; finnow = finother; finother = finswap; 02073 } 02074 if (cdztail != 0.0) { 02075 vlength = scale_expansion_zeroelim(4, ab, cdztail, v); 02076 finlength = fast_expansion_sum_zeroelim(finlength, finnow, vlength, v, 02077 finother); 02078 finswap = finnow; finnow = finother; finother = finswap; 02079 } 02080 02081 if (adxtail != 0.0) { 02082 if (bdytail != 0.0) { 02083 Two_Product(adxtail, bdytail, adxt_bdyt1, adxt_bdyt0); 02084 Two_One_Product(adxt_bdyt1, adxt_bdyt0, cdz, u3, u[2], u[1], u[0]); 02085 u[3] = u3; 02086 finlength = fast_expansion_sum_zeroelim(finlength, finnow, 4, u, 02087 finother); 02088 finswap = finnow; finnow = finother; finother = finswap; 02089 if (cdztail != 0.0) { 02090 Two_One_Product(adxt_bdyt1, adxt_bdyt0, cdztail, u3, u[2], u[1], u[0]); 02091 u[3] = u3; 02092 finlength = fast_expansion_sum_zeroelim(finlength, finnow, 4, u, 02093 finother); 02094 finswap = finnow; finnow = finother; finother = finswap; 02095 } 02096 } 02097 if (cdytail != 0.0) { 02098 negate = -adxtail; 02099 Two_Product(negate, cdytail, adxt_cdyt1, adxt_cdyt0); 02100 Two_One_Product(adxt_cdyt1, adxt_cdyt0, bdz, u3, u[2], u[1], u[0]); 02101 u[3] = u3; 02102 finlength = fast_expansion_sum_zeroelim(finlength, finnow, 4, u, 02103 finother); 02104 finswap = finnow; finnow = finother; finother = finswap; 02105 if (bdztail != 0.0) { 02106 Two_One_Product(adxt_cdyt1, adxt_cdyt0, bdztail, u3, u[2], u[1], u[0]); 02107 u[3] = u3; 02108 finlength = fast_expansion_sum_zeroelim(finlength, finnow, 4, u, 02109 finother); 02110 finswap = finnow; finnow = finother; finother = finswap; 02111 } 02112 } 02113 } 02114 if (bdxtail != 0.0) { 02115 if (cdytail != 0.0) { 02116 Two_Product(bdxtail, cdytail, bdxt_cdyt1, bdxt_cdyt0); 02117 Two_One_Product(bdxt_cdyt1, bdxt_cdyt0, adz, u3, u[2], u[1], u[0]); 02118 u[3] = u3; 02119 finlength = fast_expansion_sum_zeroelim(finlength, finnow, 4, u, 02120 finother); 02121 finswap = finnow; finnow = finother; finother = finswap; 02122 if (adztail != 0.0) { 02123 Two_One_Product(bdxt_cdyt1, bdxt_cdyt0, adztail, u3, u[2], u[1], u[0]); 02124 u[3] = u3; 02125 finlength = fast_expansion_sum_zeroelim(finlength, finnow, 4, u, 02126 finother); 02127 finswap = finnow; finnow = finother; finother = finswap; 02128 } 02129 } 02130 if (adytail != 0.0) { 02131 negate = -bdxtail; 02132 Two_Product(negate, adytail, bdxt_adyt1, bdxt_adyt0); 02133 Two_One_Product(bdxt_adyt1, bdxt_adyt0, cdz, u3, u[2], u[1], u[0]); 02134 u[3] = u3; 02135 finlength = fast_expansion_sum_zeroelim(finlength, finnow, 4, u, 02136 finother); 02137 finswap = finnow; finnow = finother; finother = finswap; 02138 if (cdztail != 0.0) { 02139 Two_One_Product(bdxt_adyt1, bdxt_adyt0, cdztail, u3, u[2], u[1], u[0]); 02140 u[3] = u3; 02141 finlength = fast_expansion_sum_zeroelim(finlength, finnow, 4, u, 02142 finother); 02143 finswap = finnow; finnow = finother; finother = finswap; 02144 } 02145 } 02146 } 02147 if (cdxtail != 0.0) { 02148 if (adytail != 0.0) { 02149 Two_Product(cdxtail, adytail, cdxt_adyt1, cdxt_adyt0); 02150 Two_One_Product(cdxt_adyt1, cdxt_adyt0, bdz, u3, u[2], u[1], u[0]); 02151 u[3] = u3; 02152 finlength = fast_expansion_sum_zeroelim(finlength, finnow, 4, u, 02153 finother); 02154 finswap = finnow; finnow = finother; finother = finswap; 02155 if (bdztail != 0.0) { 02156 Two_One_Product(cdxt_adyt1, cdxt_adyt0, bdztail, u3, u[2], u[1], u[0]); 02157 u[3] = u3; 02158 finlength = fast_expansion_sum_zeroelim(finlength, finnow, 4, u, 02159 finother); 02160 finswap = finnow; finnow = finother; finother = finswap; 02161 } 02162 } 02163 if (bdytail != 0.0) { 02164 negate = -cdxtail; 02165 Two_Product(negate, bdytail, cdxt_bdyt1, cdxt_bdyt0); 02166 Two_One_Product(cdxt_bdyt1, cdxt_bdyt0, adz, u3, u[2], u[1], u[0]); 02167 u[3] = u3; 02168 finlength = fast_expansion_sum_zeroelim(finlength, finnow, 4, u, 02169 finother); 02170 finswap = finnow; finnow = finother; finother = finswap; 02171 if (adztail != 0.0) { 02172 Two_One_Product(cdxt_bdyt1, cdxt_bdyt0, adztail, u3, u[2], u[1], u[0]); 02173 u[3] = u3; 02174 finlength = fast_expansion_sum_zeroelim(finlength, finnow, 4, u, 02175 finother); 02176 finswap = finnow; finnow = finother; finother = finswap; 02177 } 02178 } 02179 } 02180 02181 if (adztail != 0.0) { 02182 wlength = scale_expansion_zeroelim(bctlen, bct, adztail, w); 02183 finlength = fast_expansion_sum_zeroelim(finlength, finnow, wlength, w, 02184 finother); 02185 finswap = finnow; finnow = finother; finother = finswap; 02186 } 02187 if (bdztail != 0.0) { 02188 wlength = scale_expansion_zeroelim(catlen, cat, bdztail, w); 02189 finlength = fast_expansion_sum_zeroelim(finlength, finnow, wlength, w, 02190 finother); 02191 finswap = finnow; finnow = finother; finother = finswap; 02192 } 02193 if (cdztail != 0.0) { 02194 wlength = scale_expansion_zeroelim(abtlen, abt, cdztail, w); 02195 finlength = fast_expansion_sum_zeroelim(finlength, finnow, wlength, w, 02196 finother); 02197 finswap = finnow; finnow = finother; finother = finswap; 02198 } 02199 02200 return finnow[finlength - 1]; 02201 } 02202 02203 REAL orient3d(REAL *pa, REAL *pb, REAL *pc, REAL *pd) 02204 { 02205 REAL adx, bdx, cdx, ady, bdy, cdy, adz, bdz, cdz; 02206 REAL bdxcdy, cdxbdy, cdxady, adxcdy, adxbdy, bdxady; 02207 REAL det; 02208 REAL permanent, errbound; 02209 02210 adx = pa[0] - pd[0]; 02211 bdx = pb[0] - pd[0]; 02212 cdx = pc[0] - pd[0]; 02213 ady = pa[1] - pd[1]; 02214 bdy = pb[1] - pd[1]; 02215 cdy = pc[1] - pd[1]; 02216 adz = pa[2] - pd[2]; 02217 bdz = pb[2] - pd[2]; 02218 cdz = pc[2] - pd[2]; 02219 02220 bdxcdy = bdx * cdy; 02221 cdxbdy = cdx * bdy; 02222 02223 cdxady = cdx * ady; 02224 adxcdy = adx * cdy; 02225 02226 adxbdy = adx * bdy; 02227 bdxady = bdx * ady; 02228 02229 det = adz * (bdxcdy - cdxbdy) 02230 + bdz * (cdxady - adxcdy) 02231 + cdz * (adxbdy - bdxady); 02232 02233 permanent = (Absolute(bdxcdy) + Absolute(cdxbdy)) * Absolute(adz) 02234 + (Absolute(cdxady) + Absolute(adxcdy)) * Absolute(bdz) 02235 + (Absolute(adxbdy) + Absolute(bdxady)) * Absolute(cdz); 02236 errbound = o3derrboundA * permanent; 02237 if ((det > errbound) || (-det > errbound)) { 02238 return det; 02239 } 02240 02241 return orient3dadapt(pa, pb, pc, pd, permanent); 02242 } 02243 02244 /*****************************************************************************/ 02245 /* */ 02246 /* incirclefast() Approximate 2D incircle test. Nonrobust. */ 02247 /* incircleexact() Exact 2D incircle test. Robust. */ 02248 /* incircleslow() Another exact 2D incircle test. Robust. */ 02249 /* incircle() Adaptive exact 2D incircle test. Robust. */ 02250 /* */ 02251 /* Return a positive value if the point pd lies inside the */ 02252 /* circle passing through pa, pb, and pc; a negative value if */ 02253 /* it lies outside; and zero if the four points are cocircular.*/ 02254 /* The points pa, pb, and pc must be in counterclockwise */ 02255 /* order, or the sign of the result will be reversed. */ 02256 /* */ 02257 /* Only the first and last routine should be used; the middle two are for */ 02258 /* timings. */ 02259 /* */ 02260 /* The last three use exact arithmetic to ensure a correct answer. The */ 02261 /* result returned is the determinant of a matrix. In incircle() only, */ 02262 /* this determinant is computed adaptively, in the sense that exact */ 02263 /* arithmetic is used only to the degree it is needed to ensure that the */ 02264 /* returned value has the correct sign. Hence, incircle() is usually quite */ 02265 /* fast, but will run more slowly when the input points are cocircular or */ 02266 /* nearly so. */ 02267 /* */ 02268 /*****************************************************************************/ 02269 02270 REAL incirclefast(REAL *pa, REAL *pb, REAL *pc, REAL *pd) 02271 { 02272 REAL adx, ady, bdx, bdy, cdx, cdy; 02273 REAL abdet, bcdet, cadet; 02274 REAL alift, blift, clift; 02275 02276 adx = pa[0] - pd[0]; 02277 ady = pa[1] - pd[1]; 02278 bdx = pb[0] - pd[0]; 02279 bdy = pb[1] - pd[1]; 02280 cdx = pc[0] - pd[0]; 02281 cdy = pc[1] - pd[1]; 02282 02283 abdet = adx * bdy - bdx * ady; 02284 bcdet = bdx * cdy - cdx * bdy; 02285 cadet = cdx * ady - adx * cdy; 02286 alift = adx * adx + ady * ady; 02287 blift = bdx * bdx + bdy * bdy; 02288 clift = cdx * cdx + cdy * cdy; 02289 02290 return alift * bcdet + blift * cadet + clift * abdet; 02291 } 02292 02293 REAL incircleexact(REAL *pa, REAL *pb, REAL *pc, REAL *pd) 02294 { 02295 INEXACT REAL axby1, bxcy1, cxdy1, dxay1, axcy1, bxdy1; 02296 INEXACT REAL bxay1, cxby1, dxcy1, axdy1, cxay1, dxby1; 02297 REAL axby0, bxcy0, cxdy0, dxay0, axcy0, bxdy0; 02298 REAL bxay0, cxby0, dxcy0, axdy0, cxay0, dxby0; 02299 REAL ab[4], bc[4], cd[4], da[4], ac[4], bd[4]; 02300 REAL temp8[8]; 02301 int templen; 02302 REAL abc[12], bcd[12], cda[12], dab[12]; 02303 int abclen, bcdlen, cdalen, dablen; 02304 REAL det24x[24], det24y[24], det48x[48], det48y[48]; 02305 int xlen, ylen; 02306 REAL adet[96], bdet[96], cdet[96], ddet[96]; 02307 int alen, blen, clen, dlen; 02308 REAL abdet[192], cddet[192]; 02309 int ablen, cdlen; 02310 REAL deter[384]; 02311 int deterlen; 02312 int i; 02313 02314 INEXACT REAL bvirt; 02315 REAL avirt, bround, around; 02316 INEXACT REAL c; 02317 INEXACT REAL abig; 02318 REAL ahi, alo, bhi, blo; 02319 REAL err1, err2, err3; 02320 INEXACT REAL _i, _j; 02321 REAL _0; 02322 02323 Two_Product(pa[0], pb[1], axby1, axby0); 02324 Two_Product(pb[0], pa[1], bxay1, bxay0); 02325 Two_Two_Diff(axby1, axby0, bxay1, bxay0, ab[3], ab[2], ab[1], ab[0]); 02326 02327 Two_Product(pb[0], pc[1], bxcy1, bxcy0); 02328 Two_Product(pc[0], pb[1], cxby1, cxby0); 02329 Two_Two_Diff(bxcy1, bxcy0, cxby1, cxby0, bc[3], bc[2], bc[1], bc[0]); 02330 02331 Two_Product(pc[0], pd[1], cxdy1, cxdy0); 02332 Two_Product(pd[0], pc[1], dxcy1, dxcy0); 02333 Two_Two_Diff(cxdy1, cxdy0, dxcy1, dxcy0, cd[3], cd[2], cd[1], cd[0]); 02334 02335 Two_Product(pd[0], pa[1], dxay1, dxay0); 02336 Two_Product(pa[0], pd[1], axdy1, axdy0); 02337 Two_Two_Diff(dxay1, dxay0, axdy1, axdy0, da[3], da[2], da[1], da[0]); 02338 02339 Two_Product(pa[0], pc[1], axcy1, axcy0); 02340 Two_Product(pc[0], pa[1], cxay1, cxay0); 02341 Two_Two_Diff(axcy1, axcy0, cxay1, cxay0, ac[3], ac[2], ac[1], ac[0]); 02342 02343 Two_Product(pb[0], pd[1], bxdy1, bxdy0); 02344 Two_Product(pd[0], pb[1], dxby1, dxby0); 02345 Two_Two_Diff(bxdy1, bxdy0, dxby1, dxby0, bd[3], bd[2], bd[1], bd[0]); 02346 02347 templen = fast_expansion_sum_zeroelim(4, cd, 4, da, temp8); 02348 cdalen = fast_expansion_sum_zeroelim(templen, temp8, 4, ac, cda); 02349 templen = fast_expansion_sum_zeroelim(4, da, 4, ab, temp8); 02350 dablen = fast_expansion_sum_zeroelim(templen, temp8, 4, bd, dab); 02351 for (i = 0; i < 4; i++) { 02352 bd[i] = -bd[i]; 02353 ac[i] = -ac[i]; 02354 } 02355 templen = fast_expansion_sum_zeroelim(4, ab, 4, bc, temp8); 02356 abclen = fast_expansion_sum_zeroelim(templen, temp8, 4, ac, abc); 02357 templen = fast_expansion_sum_zeroelim(4, bc, 4, cd, temp8); 02358 bcdlen = fast_expansion_sum_zeroelim(templen, temp8, 4, bd, bcd); 02359 02360 xlen = scale_expansion_zeroelim(bcdlen, bcd, pa[0], det24x); 02361 xlen = scale_expansion_zeroelim(xlen, det24x, pa[0], det48x); 02362 ylen = scale_expansion_zeroelim(bcdlen, bcd, pa[1], det24y); 02363 ylen = scale_expansion_zeroelim(ylen, det24y, pa[1], det48y); 02364 alen = fast_expansion_sum_zeroelim(xlen, det48x, ylen, det48y, adet); 02365 02366 xlen = scale_expansion_zeroelim(cdalen, cda, pb[0], det24x); 02367 xlen = scale_expansion_zeroelim(xlen, det24x, -pb[0], det48x); 02368 ylen = scale_expansion_zeroelim(cdalen, cda, pb[1], det24y); 02369 ylen = scale_expansion_zeroelim(ylen, det24y, -pb[1], det48y); 02370 blen = fast_expansion_sum_zeroelim(xlen, det48x, ylen, det48y, bdet); 02371 02372 xlen = scale_expansion_zeroelim(dablen, dab, pc[0], det24x); 02373 xlen = scale_expansion_zeroelim(xlen, det24x, pc[0], det48x); 02374 ylen = scale_expansion_zeroelim(dablen, dab, pc[1], det24y); 02375 ylen = scale_expansion_zeroelim(ylen, det24y, pc[1], det48y); 02376 clen = fast_expansion_sum_zeroelim(xlen, det48x, ylen, det48y, cdet); 02377 02378 xlen = scale_expansion_zeroelim(abclen, abc, pd[0], det24x); 02379 xlen = scale_expansion_zeroelim(xlen, det24x, -pd[0], det48x); 02380 ylen = scale_expansion_zeroelim(abclen, abc, pd[1], det24y); 02381 ylen = scale_expansion_zeroelim(ylen, det24y, -pd[1], det48y); 02382 dlen = fast_expansion_sum_zeroelim(xlen, det48x, ylen, det48y, ddet); 02383 02384 ablen = fast_expansion_sum_zeroelim(alen, adet, blen, bdet, abdet); 02385 cdlen = fast_expansion_sum_zeroelim(clen, cdet, dlen, ddet, cddet); 02386 deterlen = fast_expansion_sum_zeroelim(ablen, abdet, cdlen, cddet, deter); 02387 02388 return deter[deterlen - 1]; 02389 } 02390 02391 REAL incircleslow(REAL *pa, REAL *pb, REAL *pc, REAL *pd) 02392 { 02393 INEXACT REAL adx, bdx, cdx, ady, bdy, cdy; 02394 REAL adxtail, bdxtail, cdxtail; 02395 REAL adytail, bdytail, cdytail; 02396 REAL negate, negatetail; 02397 INEXACT REAL axby7, bxcy7, axcy7, bxay7, cxby7, cxay7; 02398 REAL axby[8], bxcy[8], axcy[8], bxay[8], cxby[8], cxay[8]; 02399 REAL temp16[16]; 02400 int temp16len; 02401 REAL detx[32], detxx[64], detxt[32], detxxt[64], detxtxt[64]; 02402 int xlen, xxlen, xtlen, xxtlen, xtxtlen; 02403 REAL x1[128], x2[192]; 02404 int x1len, x2len; 02405 REAL dety[32], detyy[64], detyt[32], detyyt[64], detytyt[64]; 02406 int ylen, yylen, ytlen, yytlen, ytytlen; 02407 REAL y1[128], y2[192]; 02408 int y1len, y2len; 02409 REAL adet[384], bdet[384], cdet[384], abdet[768], deter[1152]; 02410 int alen, blen, clen, ablen, deterlen; 02411 int i; 02412 02413 INEXACT REAL bvirt; 02414 REAL avirt, bround, around; 02415 INEXACT REAL c; 02416 INEXACT REAL abig; 02417 REAL a0hi, a0lo, a1hi, a1lo, bhi, blo; 02418 REAL err1, err2, err3; 02419 INEXACT REAL _i, _j, _k, _l, _m, _n; 02420 REAL _0, _1, _2; 02421 02422 Two_Diff(pa[0], pd[0], adx, adxtail); 02423 Two_Diff(pa[1], pd[1], ady, adytail); 02424 Two_Diff(pb[0], pd[0], bdx, bdxtail); 02425 Two_Diff(pb[1], pd[1], bdy, bdytail); 02426 Two_Diff(pc[0], pd[0], cdx, cdxtail); 02427 Two_Diff(pc[1], pd[1], cdy, cdytail); 02428 02429 Two_Two_Product(adx, adxtail, bdy, bdytail, 02430 axby7, axby[6], axby[5], axby[4], 02431 axby[3], axby[2], axby[1], axby[0]); 02432 axby[7] = axby7; 02433 negate = -ady; 02434 negatetail = -adytail; 02435 Two_Two_Product(bdx, bdxtail, negate, negatetail, 02436 bxay7, bxay[6], bxay[5], bxay[4], 02437 bxay[3], bxay[2], bxay[1], bxay[0]); 02438 bxay[7] = bxay7; 02439 Two_Two_Product(bdx, bdxtail, cdy, cdytail, 02440 bxcy7, bxcy[6], bxcy[5], bxcy[4], 02441 bxcy[3], bxcy[2], bxcy[1], bxcy[0]); 02442 bxcy[7] = bxcy7; 02443 negate = -bdy; 02444 negatetail = -bdytail; 02445 Two_Two_Product(cdx, cdxtail, negate, negatetail, 02446 cxby7, cxby[6], cxby[5], cxby[4], 02447 cxby[3], cxby[2], cxby[1], cxby[0]); 02448 cxby[7] = cxby7; 02449 Two_Two_Product(cdx, cdxtail, ady, adytail, 02450 cxay7, cxay[6], cxay[5], cxay[4], 02451 cxay[3], cxay[2], cxay[1], cxay[0]); 02452 cxay[7] = cxay7; 02453 negate = -cdy; 02454 negatetail = -cdytail; 02455 Two_Two_Product(adx, adxtail, negate, negatetail, 02456 axcy7, axcy[6], axcy[5], axcy[4], 02457 axcy[3], axcy[2], axcy[1], axcy[0]); 02458 axcy[7] = axcy7; 02459 02460 02461 temp16len = fast_expansion_sum_zeroelim(8, bxcy, 8, cxby, temp16); 02462 02463 xlen = scale_expansion_zeroelim(temp16len, temp16, adx, detx); 02464 xxlen = scale_expansion_zeroelim(xlen, detx, adx, detxx); 02465 xtlen = scale_expansion_zeroelim(temp16len, temp16, adxtail, detxt); 02466 xxtlen = scale_expansion_zeroelim(xtlen, detxt, adx, detxxt); 02467 for (i = 0; i < xxtlen; i++) { 02468 detxxt[i] *= 2.0; 02469 } 02470 xtxtlen = scale_expansion_zeroelim(xtlen, detxt, adxtail, detxtxt); 02471 x1len = fast_expansion_sum_zeroelim(xxlen, detxx, xxtlen, detxxt, x1); 02472 x2len = fast_expansion_sum_zeroelim(x1len, x1, xtxtlen, detxtxt, x2); 02473 02474 ylen = scale_expansion_zeroelim(temp16len, temp16, ady, dety); 02475 yylen = scale_expansion_zeroelim(ylen, dety, ady, detyy); 02476 ytlen = scale_expansion_zeroelim(temp16len, temp16, adytail, detyt); 02477 yytlen = scale_expansion_zeroelim(ytlen, detyt, ady, detyyt); 02478 for (i = 0; i < yytlen; i++) { 02479 detyyt[i] *= 2.0; 02480 } 02481 ytytlen = scale_expansion_zeroelim(ytlen, detyt, adytail, detytyt); 02482 y1len = fast_expansion_sum_zeroelim(yylen, detyy, yytlen, detyyt, y1); 02483 y2len = fast_expansion_sum_zeroelim(y1len, y1, ytytlen, detytyt, y2); 02484 02485 alen = fast_expansion_sum_zeroelim(x2len, x2, y2len, y2, adet); 02486 02487 02488 temp16len = fast_expansion_sum_zeroelim(8, cxay, 8, axcy, temp16); 02489 02490 xlen = scale_expansion_zeroelim(temp16len, temp16, bdx, detx); 02491 xxlen = scale_expansion_zeroelim(xlen, detx, bdx, detxx); 02492 xtlen = scale_expansion_zeroelim(temp16len, temp16, bdxtail, detxt); 02493 xxtlen = scale_expansion_zeroelim(xtlen, detxt, bdx, detxxt); 02494 for (i = 0; i < xxtlen; i++) { 02495 detxxt[i] *= 2.0; 02496 } 02497 xtxtlen = scale_expansion_zeroelim(xtlen, detxt, bdxtail, detxtxt); 02498 x1len = fast_expansion_sum_zeroelim(xxlen, detxx, xxtlen, detxxt, x1); 02499 x2len = fast_expansion_sum_zeroelim(x1len, x1, xtxtlen, detxtxt, x2); 02500 02501 ylen = scale_expansion_zeroelim(temp16len, temp16, bdy, dety); 02502 yylen = scale_expansion_zeroelim(ylen, dety, bdy, detyy); 02503 ytlen = scale_expansion_zeroelim(temp16len, temp16, bdytail, detyt); 02504 yytlen = scale_expansion_zeroelim(ytlen, detyt, bdy, detyyt); 02505 for (i = 0; i < yytlen; i++) { 02506 detyyt[i] *= 2.0; 02507 } 02508 ytytlen = scale_expansion_zeroelim(ytlen, detyt, bdytail, detytyt); 02509 y1len = fast_expansion_sum_zeroelim(yylen, detyy, yytlen, detyyt, y1); 02510 y2len = fast_expansion_sum_zeroelim(y1len, y1, ytytlen, detytyt, y2); 02511 02512 blen = fast_expansion_sum_zeroelim(x2len, x2, y2len, y2, bdet); 02513 02514 02515 temp16len = fast_expansion_sum_zeroelim(8, axby, 8, bxay, temp16); 02516 02517 xlen = scale_expansion_zeroelim(temp16len, temp16, cdx, detx); 02518 xxlen = scale_expansion_zeroelim(xlen, detx, cdx, detxx); 02519 xtlen = scale_expansion_zeroelim(temp16len, temp16, cdxtail, detxt); 02520 xxtlen = scale_expansion_zeroelim(xtlen, detxt, cdx, detxxt); 02521 for (i = 0; i < xxtlen; i++) { 02522 detxxt[i] *= 2.0; 02523 } 02524 xtxtlen = scale_expansion_zeroelim(xtlen, detxt, cdxtail, detxtxt); 02525 x1len = fast_expansion_sum_zeroelim(xxlen, detxx, xxtlen, detxxt, x1); 02526 x2len = fast_expansion_sum_zeroelim(x1len, x1, xtxtlen, detxtxt, x2); 02527 02528 ylen = scale_expansion_zeroelim(temp16len, temp16, cdy, dety); 02529 yylen = scale_expansion_zeroelim(ylen, dety, cdy, detyy); 02530 ytlen = scale_expansion_zeroelim(temp16len, temp16, cdytail, detyt); 02531 yytlen = scale_expansion_zeroelim(ytlen, detyt, cdy, detyyt); 02532 for (i = 0; i < yytlen; i++) { 02533 detyyt[i] *= 2.0; 02534 } 02535 ytytlen = scale_expansion_zeroelim(ytlen, detyt, cdytail, detytyt); 02536 y1len = fast_expansion_sum_zeroelim(yylen, detyy, yytlen, detyyt, y1); 02537 y2len = fast_expansion_sum_zeroelim(y1len, y1, ytytlen, detytyt, y2); 02538 02539 clen = fast_expansion_sum_zeroelim(x2len, x2, y2len, y2, cdet); 02540 02541 ablen = fast_expansion_sum_zeroelim(alen, adet, blen, bdet, abdet); 02542 deterlen = fast_expansion_sum_zeroelim(ablen, abdet, clen, cdet, deter); 02543 02544 return deter[deterlen - 1]; 02545 } 02546 02547 REAL incircleadapt(REAL *pa, REAL *pb, REAL *pc, REAL *pd, REAL permanent) 02548 { 02549 INEXACT REAL adx, bdx, cdx, ady, bdy, cdy; 02550 REAL det, errbound; 02551 02552 INEXACT REAL bdxcdy1, cdxbdy1, cdxady1, adxcdy1, adxbdy1, bdxady1; 02553 REAL bdxcdy0, cdxbdy0, cdxady0, adxcdy0, adxbdy0, bdxady0; 02554 REAL bc[4], ca[4], ab[4]; 02555 INEXACT REAL bc3, ca3, ab3; 02556 REAL axbc[8], axxbc[16], aybc[8], ayybc[16], adet[32]; 02557 int axbclen, axxbclen, aybclen, ayybclen, alen; 02558 REAL bxca[8], bxxca[16], byca[8], byyca[16], bdet[32]; 02559 int bxcalen, bxxcalen, bycalen, byycalen, blen; 02560 REAL cxab[8], cxxab[16], cyab[8], cyyab[16], cdet[32]; 02561 int cxablen, cxxablen, cyablen, cyyablen, clen; 02562 REAL abdet[64]; 02563 int ablen; 02564 REAL fin1[1152], fin2[1152]; 02565 REAL *finnow, *finother, *finswap; 02566 int finlength; 02567 02568 REAL adxtail, bdxtail, cdxtail, adytail, bdytail, cdytail; 02569 INEXACT REAL adxadx1, adyady1, bdxbdx1, bdybdy1, cdxcdx1, cdycdy1; 02570 REAL adxadx0, adyady0, bdxbdx0, bdybdy0, cdxcdx0, cdycdy0; 02571 REAL aa[4], bb[4], cc[4]; 02572 INEXACT REAL aa3, bb3, cc3; 02573 INEXACT REAL ti1, tj1; 02574 REAL ti0, tj0; 02575 REAL u[4], v[4]; 02576 INEXACT REAL u3, v3; 02577 REAL temp8[8], temp16a[16], temp16b[16], temp16c[16]; 02578 REAL temp32a[32], temp32b[32], temp48[48], temp64[64]; 02579 int temp8len, temp16alen, temp16blen, temp16clen; 02580 int temp32alen, temp32blen, temp48len, temp64len; 02581 REAL axtbb[8], axtcc[8], aytbb[8], aytcc[8]; 02582 int axtbblen, axtcclen, aytbblen, aytcclen; 02583 REAL bxtaa[8], bxtcc[8], bytaa[8], bytcc[8]; 02584 int bxtaalen, bxtcclen, bytaalen, bytcclen; 02585 REAL cxtaa[8], cxtbb[8], cytaa[8], cytbb[8]; 02586 int cxtaalen, cxtbblen, cytaalen, cytbblen; 02587 REAL axtbc[8], aytbc[8], bxtca[8], bytca[8], cxtab[8], cytab[8]; 02588 int axtbclen = 0, aytbclen = 0, bxtcalen = 0, bytcalen = 0, cxtablen = 0, cytablen = 0; 02589 REAL axtbct[16], aytbct[16], bxtcat[16], bytcat[16], cxtabt[16], cytabt[16]; 02590 int axtbctlen, aytbctlen, bxtcatlen, bytcatlen, cxtabtlen, cytabtlen; 02591 REAL axtbctt[8], aytbctt[8], bxtcatt[8]; 02592 REAL bytcatt[8], cxtabtt[8], cytabtt[8]; 02593 int axtbcttlen, aytbcttlen, bxtcattlen, bytcattlen, cxtabttlen, cytabttlen; 02594 REAL abt[8], bct[8], cat[8]; 02595 int abtlen, bctlen, catlen; 02596 REAL abtt[4], bctt[4], catt[4]; 02597 int abttlen, bcttlen, cattlen; 02598 INEXACT REAL abtt3, bctt3, catt3; 02599 REAL negate; 02600 02601 INEXACT REAL bvirt; 02602 REAL avirt, bround, around; 02603 INEXACT REAL c; 02604 INEXACT REAL abig; 02605 REAL ahi, alo, bhi, blo; 02606 REAL err1, err2, err3; 02607 INEXACT REAL _i, _j; 02608 REAL _0; 02609 02610 adx = (REAL) (pa[0] - pd[0]); 02611 bdx = (REAL) (pb[0] - pd[0]); 02612 cdx = (REAL) (pc[0] - pd[0]); 02613 ady = (REAL) (pa[1] - pd[1]); 02614 bdy = (REAL) (pb[1] - pd[1]); 02615 cdy = (REAL) (pc[1] - pd[1]); 02616 02617 Two_Product(bdx, cdy, bdxcdy1, bdxcdy0); 02618 Two_Product(cdx, bdy, cdxbdy1, cdxbdy0); 02619 Two_Two_Diff(bdxcdy1, bdxcdy0, cdxbdy1, cdxbdy0, bc3, bc[2], bc[1], bc[0]); 02620 bc[3] = bc3; 02621 axbclen = scale_expansion_zeroelim(4, bc, adx, axbc); 02622 axxbclen = scale_expansion_zeroelim(axbclen, axbc, adx, axxbc); 02623 aybclen = scale_expansion_zeroelim(4, bc, ady, aybc); 02624 ayybclen = scale_expansion_zeroelim(aybclen, aybc, ady, ayybc); 02625 alen = fast_expansion_sum_zeroelim(axxbclen, axxbc, ayybclen, ayybc, adet); 02626 02627 Two_Product(cdx, ady, cdxady1, cdxady0); 02628 Two_Product(adx, cdy, adxcdy1, adxcdy0); 02629 Two_Two_Diff(cdxady1, cdxady0, adxcdy1, adxcdy0, ca3, ca[2], ca[1], ca[0]); 02630 ca[3] = ca3; 02631 bxcalen = scale_expansion_zeroelim(4, ca, bdx, bxca); 02632 bxxcalen = scale_expansion_zeroelim(bxcalen, bxca, bdx, bxxca); 02633 bycalen = scale_expansion_zeroelim(4, ca, bdy, byca); 02634 byycalen = scale_expansion_zeroelim(bycalen, byca, bdy, byyca); 02635 blen = fast_expansion_sum_zeroelim(bxxcalen, bxxca, byycalen, byyca, bdet); 02636 02637 Two_Product(adx, bdy, adxbdy1, adxbdy0); 02638 Two_Product(bdx, ady, bdxady1, bdxady0); 02639 Two_Two_Diff(adxbdy1, adxbdy0, bdxady1, bdxady0, ab3, ab[2], ab[1], ab[0]); 02640 ab[3] = ab3; 02641 cxablen = scale_expansion_zeroelim(4, ab, cdx, cxab); 02642 cxxablen = scale_expansion_zeroelim(cxablen, cxab, cdx, cxxab); 02643 cyablen = scale_expansion_zeroelim(4, ab, cdy, cyab); 02644 cyyablen = scale_expansion_zeroelim(cyablen, cyab, cdy, cyyab); 02645 clen = fast_expansion_sum_zeroelim(cxxablen, cxxab, cyyablen, cyyab, cdet); 02646 02647 ablen = fast_expansion_sum_zeroelim(alen, adet, blen, bdet, abdet); 02648 finlength = fast_expansion_sum_zeroelim(ablen, abdet, clen, cdet, fin1); 02649 02650 det = estimate(finlength, fin1); 02651 errbound = iccerrboundB * permanent; 02652 if ((det >= errbound) || (-det >= errbound)) { 02653 return det; 02654 } 02655 02656 Two_Diff_Tail(pa[0], pd[0], adx, adxtail); 02657 Two_Diff_Tail(pa[1], pd[1], ady, adytail); 02658 Two_Diff_Tail(pb[0], pd[0], bdx, bdxtail); 02659 Two_Diff_Tail(pb[1], pd[1], bdy, bdytail); 02660 Two_Diff_Tail(pc[0], pd[0], cdx, cdxtail); 02661 Two_Diff_Tail(pc[1], pd[1], cdy, cdytail); 02662 if ((adxtail == 0.0) && (bdxtail == 0.0) && (cdxtail == 0.0) 02663 && (adytail == 0.0) && (bdytail == 0.0) && (cdytail == 0.0)) { 02664 return det; 02665 } 02666 02667 errbound = iccerrboundC * permanent + resulterrbound * Absolute(det); 02668 det += ((adx * adx + ady * ady) * ((bdx * cdytail + cdy * bdxtail) 02669 - (bdy * cdxtail + cdx * bdytail)) 02670 + 2.0 * (adx * adxtail + ady * adytail) * (bdx * cdy - bdy * cdx)) 02671 + ((bdx * bdx + bdy * bdy) * ((cdx * adytail + ady * cdxtail) 02672 - (cdy * adxtail + adx * cdytail)) 02673 + 2.0 * (bdx * bdxtail + bdy * bdytail) * (cdx * ady - cdy * adx)) 02674 + ((cdx * cdx + cdy * cdy) * ((adx * bdytail + bdy * adxtail) 02675 - (ady * bdxtail + bdx * adytail)) 02676 + 2.0 * (cdx * cdxtail + cdy * cdytail) * (adx * bdy - ady * bdx)); 02677 if ((det >= errbound) || (-det >= errbound)) { 02678 return det; 02679 } 02680 02681 finnow = fin1; 02682 finother = fin2; 02683 02684 if ((bdxtail != 0.0) || (bdytail != 0.0) 02685 || (cdxtail != 0.0) || (cdytail != 0.0)) { 02686 Square(adx, adxadx1, adxadx0); 02687 Square(ady, adyady1, adyady0); 02688 Two_Two_Sum(adxadx1, adxadx0, adyady1, adyady0, aa3, aa[2], aa[1], aa[0]); 02689 aa[3] = aa3; 02690 } 02691 if ((cdxtail != 0.0) || (cdytail != 0.0) 02692 || (adxtail != 0.0) || (adytail != 0.0)) { 02693 Square(bdx, bdxbdx1, bdxbdx0); 02694 Square(bdy, bdybdy1, bdybdy0); 02695 Two_Two_Sum(bdxbdx1, bdxbdx0, bdybdy1, bdybdy0, bb3, bb[2], bb[1], bb[0]); 02696 bb[3] = bb3; 02697 } 02698 if ((adxtail != 0.0) || (adytail != 0.0) 02699 || (bdxtail != 0.0) || (bdytail != 0.0)) { 02700 Square(cdx, cdxcdx1, cdxcdx0); 02701 Square(cdy, cdycdy1, cdycdy0); 02702 Two_Two_Sum(cdxcdx1, cdxcdx0, cdycdy1, cdycdy0, cc3, cc[2], cc[1], cc[0]); 02703 cc[3] = cc3; 02704 } 02705 02706 if (adxtail != 0.0) { 02707 axtbclen = scale_expansion_zeroelim(4, bc, adxtail, axtbc); 02708 temp16alen = scale_expansion_zeroelim(axtbclen, axtbc, 2.0 * adx, 02709 temp16a); 02710 02711 axtcclen = scale_expansion_zeroelim(4, cc, adxtail, axtcc); 02712 temp16blen = scale_expansion_zeroelim(axtcclen, axtcc, bdy, temp16b); 02713 02714 axtbblen = scale_expansion_zeroelim(4, bb, adxtail, axtbb); 02715 temp16clen = scale_expansion_zeroelim(axtbblen, axtbb, -cdy, temp16c); 02716 02717 temp32alen = fast_expansion_sum_zeroelim(temp16alen, temp16a, 02718 temp16blen, temp16b, temp32a); 02719 temp48len = fast_expansion_sum_zeroelim(temp16clen, temp16c, 02720 temp32alen, temp32a, temp48); 02721 finlength = fast_expansion_sum_zeroelim(finlength, finnow, temp48len, 02722 temp48, finother); 02723 finswap = finnow; finnow = finother; finother = finswap; 02724 } 02725 if (adytail != 0.0) { 02726 aytbclen = scale_expansion_zeroelim(4, bc, adytail, aytbc); 02727 temp16alen = scale_expansion_zeroelim(aytbclen, aytbc, 2.0 * ady, 02728 temp16a); 02729 02730 aytbblen = scale_expansion_zeroelim(4, bb, adytail, aytbb); 02731 temp16blen = scale_expansion_zeroelim(aytbblen, aytbb, cdx, temp16b); 02732 02733 aytcclen = scale_expansion_zeroelim(4, cc, adytail, aytcc); 02734 temp16clen = scale_expansion_zeroelim(aytcclen, aytcc, -bdx, temp16c); 02735 02736 temp32alen = fast_expansion_sum_zeroelim(temp16alen, temp16a, 02737 temp16blen, temp16b, temp32a); 02738 temp48len = fast_expansion_sum_zeroelim(temp16clen, temp16c, 02739 temp32alen, temp32a, temp48); 02740 finlength = fast_expansion_sum_zeroelim(finlength, finnow, temp48len, 02741 temp48, finother); 02742 finswap = finnow; finnow = finother; finother = finswap; 02743 } 02744 if (bdxtail != 0.0) { 02745 bxtcalen = scale_expansion_zeroelim(4, ca, bdxtail, bxtca); 02746 temp16alen = scale_expansion_zeroelim(bxtcalen, bxtca, 2.0 * bdx, 02747 temp16a); 02748 02749 bxtaalen = scale_expansion_zeroelim(4, aa, bdxtail, bxtaa); 02750 temp16blen = scale_expansion_zeroelim(bxtaalen, bxtaa, cdy, temp16b); 02751 02752 bxtcclen = scale_expansion_zeroelim(4, cc, bdxtail, bxtcc); 02753 temp16clen = scale_expansion_zeroelim(bxtcclen, bxtcc, -ady, temp16c); 02754 02755 temp32alen = fast_expansion_sum_zeroelim(temp16alen, temp16a, 02756 temp16blen, temp16b, temp32a); 02757 temp48len = fast_expansion_sum_zeroelim(temp16clen, temp16c, 02758 temp32alen, temp32a, temp48); 02759 finlength = fast_expansion_sum_zeroelim(finlength, finnow, temp48len, 02760 temp48, finother); 02761 finswap = finnow; finnow = finother; finother = finswap; 02762 } 02763 if (bdytail != 0.0) { 02764 bytcalen = scale_expansion_zeroelim(4, ca, bdytail, bytca); 02765 temp16alen = scale_expansion_zeroelim(bytcalen, bytca, 2.0 * bdy, 02766 temp16a); 02767 02768 bytcclen = scale_expansion_zeroelim(4, cc, bdytail, bytcc); 02769 temp16blen = scale_expansion_zeroelim(bytcclen, bytcc, adx, temp16b); 02770 02771 bytaalen = scale_expansion_zeroelim(4, aa, bdytail, bytaa); 02772 temp16clen = scale_expansion_zeroelim(bytaalen, bytaa, -cdx, temp16c); 02773 02774 temp32alen = fast_expansion_sum_zeroelim(temp16alen, temp16a, 02775 temp16blen, temp16b, temp32a); 02776 temp48len = fast_expansion_sum_zeroelim(temp16clen, temp16c, 02777 temp32alen, temp32a, temp48); 02778 finlength = fast_expansion_sum_zeroelim(finlength, finnow, temp48len, 02779 temp48, finother); 02780 finswap = finnow; finnow = finother; finother = finswap; 02781 } 02782 if (cdxtail != 0.0) { 02783 cxtablen = scale_expansion_zeroelim(4, ab, cdxtail, cxtab); 02784 temp16alen = scale_expansion_zeroelim(cxtablen, cxtab, 2.0 * cdx, 02785 temp16a); 02786 02787 cxtbblen = scale_expansion_zeroelim(4, bb, cdxtail, cxtbb); 02788 temp16blen = scale_expansion_zeroelim(cxtbblen, cxtbb, ady, temp16b); 02789 02790 cxtaalen = scale_expansion_zeroelim(4, aa, cdxtail, cxtaa); 02791 temp16clen = scale_expansion_zeroelim(cxtaalen, cxtaa, -bdy, temp16c); 02792 02793 temp32alen = fast_expansion_sum_zeroelim(temp16alen, temp16a, 02794 temp16blen, temp16b, temp32a); 02795 temp48len = fast_expansion_sum_zeroelim(temp16clen, temp16c, 02796 temp32alen, temp32a, temp48); 02797 finlength = fast_expansion_sum_zeroelim(finlength, finnow, temp48len, 02798 temp48, finother); 02799 finswap = finnow; finnow = finother; finother = finswap; 02800 } 02801 if (cdytail != 0.0) { 02802 cytablen = scale_expansion_zeroelim(4, ab, cdytail, cytab); 02803 temp16alen = scale_expansion_zeroelim(cytablen, cytab, 2.0 * cdy, 02804 temp16a); 02805 02806 cytaalen = scale_expansion_zeroelim(4, aa, cdytail, cytaa); 02807 temp16blen = scale_expansion_zeroelim(cytaalen, cytaa, bdx, temp16b); 02808 02809 cytbblen = scale_expansion_zeroelim(4, bb, cdytail, cytbb); 02810 temp16clen = scale_expansion_zeroelim(cytbblen, cytbb, -adx, temp16c); 02811 02812 temp32alen = fast_expansion_sum_zeroelim(temp16alen, temp16a, 02813 temp16blen, temp16b, temp32a); 02814 temp48len = fast_expansion_sum_zeroelim(temp16clen, temp16c, 02815 temp32alen, temp32a, temp48); 02816 finlength = fast_expansion_sum_zeroelim(finlength, finnow, temp48len, 02817 temp48, finother); 02818 finswap = finnow; finnow = finother; finother = finswap; 02819 } 02820 02821 if ((adxtail != 0.0) || (adytail != 0.0)) { 02822 if ((bdxtail != 0.0) || (bdytail != 0.0) 02823 || (cdxtail != 0.0) || (cdytail != 0.0)) { 02824 Two_Product(bdxtail, cdy, ti1, ti0); 02825 Two_Product(bdx, cdytail, tj1, tj0); 02826 Two_Two_Sum(ti1, ti0, tj1, tj0, u3, u[2], u[1], u[0]); 02827 u[3] = u3; 02828 negate = -bdy; 02829 Two_Product(cdxtail, negate, ti1, ti0); 02830 negate = -bdytail; 02831 Two_Product(cdx, negate, tj1, tj0); 02832 Two_Two_Sum(ti1, ti0, tj1, tj0, v3, v[2], v[1], v[0]); 02833 v[3] = v3; 02834 bctlen = fast_expansion_sum_zeroelim(4, u, 4, v, bct); 02835 02836 Two_Product(bdxtail, cdytail, ti1, ti0); 02837 Two_Product(cdxtail, bdytail, tj1, tj0); 02838 Two_Two_Diff(ti1, ti0, tj1, tj0, bctt3, bctt[2], bctt[1], bctt[0]); 02839 bctt[3] = bctt3; 02840 bcttlen = 4; 02841 } else { 02842 bct[0] = 0.0; 02843 bctlen = 1; 02844 bctt[0] = 0.0; 02845 bcttlen = 1; 02846 } 02847 02848 if (adxtail != 0.0) { 02849 temp16alen = scale_expansion_zeroelim(axtbclen, axtbc, adxtail, temp16a); 02850 axtbctlen = scale_expansion_zeroelim(bctlen, bct, adxtail, axtbct); 02851 temp32alen = scale_expansion_zeroelim(axtbctlen, axtbct, 2.0 * adx, 02852 temp32a); 02853 temp48len = fast_expansion_sum_zeroelim(temp16alen, temp16a, 02854 temp32alen, temp32a, temp48); 02855 finlength = fast_expansion_sum_zeroelim(finlength, finnow, temp48len, 02856 temp48, finother); 02857 finswap = finnow; finnow = finother; finother = finswap; 02858 if (bdytail != 0.0) { 02859 temp8len = scale_expansion_zeroelim(4, cc, adxtail, temp8); 02860 temp16alen = scale_expansion_zeroelim(temp8len, temp8, bdytail, 02861 temp16a); 02862 finlength = fast_expansion_sum_zeroelim(finlength, finnow, temp16alen, 02863 temp16a, finother); 02864 finswap = finnow; finnow = finother; finother = finswap; 02865 } 02866 if (cdytail != 0.0) { 02867 temp8len = scale_expansion_zeroelim(4, bb, -adxtail, temp8); 02868 temp16alen = scale_expansion_zeroelim(temp8len, temp8, cdytail, 02869 temp16a); 02870 finlength = fast_expansion_sum_zeroelim(finlength, finnow, temp16alen, 02871 temp16a, finother); 02872 finswap = finnow; finnow = finother; finother = finswap; 02873 } 02874 02875 temp32alen = scale_expansion_zeroelim(axtbctlen, axtbct, adxtail, 02876 temp32a); 02877 axtbcttlen = scale_expansion_zeroelim(bcttlen, bctt, adxtail, axtbctt); 02878 temp16alen = scale_expansion_zeroelim(axtbcttlen, axtbctt, 2.0 * adx, 02879 temp16a); 02880 temp16blen = scale_expansion_zeroelim(axtbcttlen, axtbctt, adxtail, 02881 temp16b); 02882 temp32blen = fast_expansion_sum_zeroelim(temp16alen, temp16a, 02883 temp16blen, temp16b, temp32b); 02884 temp64len = fast_expansion_sum_zeroelim(temp32alen, temp32a, 02885 temp32blen, temp32b, temp64); 02886 finlength = fast_expansion_sum_zeroelim(finlength, finnow, temp64len, 02887 temp64, finother); 02888 finswap = finnow; finnow = finother; finother = finswap; 02889 } 02890 if (adytail != 0.0) { 02891 temp16alen = scale_expansion_zeroelim(aytbclen, aytbc, adytail, temp16a); 02892 aytbctlen = scale_expansion_zeroelim(bctlen, bct, adytail, aytbct); 02893 temp32alen = scale_expansion_zeroelim(aytbctlen, aytbct, 2.0 * ady, 02894 temp32a); 02895 temp48len = fast_expansion_sum_zeroelim(temp16alen, temp16a, 02896 temp32alen, temp32a, temp48); 02897 finlength = fast_expansion_sum_zeroelim(finlength, finnow, temp48len, 02898 temp48, finother); 02899 finswap = finnow; finnow = finother; finother = finswap; 02900 02901 02902 temp32alen = scale_expansion_zeroelim(aytbctlen, aytbct, adytail, 02903 temp32a); 02904 aytbcttlen = scale_expansion_zeroelim(bcttlen, bctt, adytail, aytbctt); 02905 temp16alen = scale_expansion_zeroelim(aytbcttlen, aytbctt, 2.0 * ady, 02906 temp16a); 02907 temp16blen = scale_expansion_zeroelim(aytbcttlen, aytbctt, adytail, 02908 temp16b); 02909 temp32blen = fast_expansion_sum_zeroelim(temp16alen, temp16a, 02910 temp16blen, temp16b, temp32b); 02911 temp64len = fast_expansion_sum_zeroelim(temp32alen, temp32a, 02912 temp32blen, temp32b, temp64); 02913 finlength = fast_expansion_sum_zeroelim(finlength, finnow, temp64len, 02914 temp64, finother); 02915 finswap = finnow; finnow = finother; finother = finswap; 02916 } 02917 } 02918 if ((bdxtail != 0.0) || (bdytail != 0.0)) { 02919 if ((cdxtail != 0.0) || (cdytail != 0.0) 02920 || (adxtail != 0.0) || (adytail != 0.0)) { 02921 Two_Product(cdxtail, ady, ti1, ti0); 02922 Two_Product(cdx, adytail, tj1, tj0); 02923 Two_Two_Sum(ti1, ti0, tj1, tj0, u3, u[2], u[1], u[0]); 02924 u[3] = u3; 02925 negate = -cdy; 02926 Two_Product(adxtail, negate, ti1, ti0); 02927 negate = -cdytail; 02928 Two_Product(adx, negate, tj1, tj0); 02929 Two_Two_Sum(ti1, ti0, tj1, tj0, v3, v[2], v[1], v[0]); 02930 v[3] = v3; 02931 catlen = fast_expansion_sum_zeroelim(4, u, 4, v, cat); 02932 02933 Two_Product(cdxtail, adytail, ti1, ti0); 02934 Two_Product(adxtail, cdytail, tj1, tj0); 02935 Two_Two_Diff(ti1, ti0, tj1, tj0, catt3, catt[2], catt[1], catt[0]); 02936 catt[3] = catt3; 02937 cattlen = 4; 02938 } else { 02939 cat[0] = 0.0; 02940 catlen = 1; 02941 catt[0] = 0.0; 02942 cattlen = 1; 02943 } 02944 02945 if (bdxtail != 0.0) { 02946 temp16alen = scale_expansion_zeroelim(bxtcalen, bxtca, bdxtail, temp16a); 02947 bxtcatlen = scale_expansion_zeroelim(catlen, cat, bdxtail, bxtcat); 02948 temp32alen = scale_expansion_zeroelim(bxtcatlen, bxtcat, 2.0 * bdx, 02949 temp32a); 02950 temp48len = fast_expansion_sum_zeroelim(temp16alen, temp16a, 02951 temp32alen, temp32a, temp48); 02952 finlength = fast_expansion_sum_zeroelim(finlength, finnow, temp48len, 02953 temp48, finother); 02954 finswap = finnow; finnow = finother; finother = finswap; 02955 if (cdytail != 0.0) { 02956 temp8len = scale_expansion_zeroelim(4, aa, bdxtail, temp8); 02957 temp16alen = scale_expansion_zeroelim(temp8len, temp8, cdytail, 02958 temp16a); 02959 finlength = fast_expansion_sum_zeroelim(finlength, finnow, temp16alen, 02960 temp16a, finother); 02961 finswap = finnow; finnow = finother; finother = finswap; 02962 } 02963 if (adytail != 0.0) { 02964 temp8len = scale_expansion_zeroelim(4, cc, -bdxtail, temp8); 02965 temp16alen = scale_expansion_zeroelim(temp8len, temp8, adytail, 02966 temp16a); 02967 finlength = fast_expansion_sum_zeroelim(finlength, finnow, temp16alen, 02968 temp16a, finother); 02969 finswap = finnow; finnow = finother; finother = finswap; 02970 } 02971 02972 temp32alen = scale_expansion_zeroelim(bxtcatlen, bxtcat, bdxtail, 02973 temp32a); 02974 bxtcattlen = scale_expansion_zeroelim(cattlen, catt, bdxtail, bxtcatt); 02975 temp16alen = scale_expansion_zeroelim(bxtcattlen, bxtcatt, 2.0 * bdx, 02976 temp16a); 02977 temp16blen = scale_expansion_zeroelim(bxtcattlen, bxtcatt, bdxtail, 02978 temp16b); 02979 temp32blen = fast_expansion_sum_zeroelim(temp16alen, temp16a, 02980 temp16blen, temp16b, temp32b); 02981 temp64len = fast_expansion_sum_zeroelim(temp32alen, temp32a, 02982 temp32blen, temp32b, temp64); 02983 finlength = fast_expansion_sum_zeroelim(finlength, finnow, temp64len, 02984 temp64, finother); 02985 finswap = finnow; finnow = finother; finother = finswap; 02986 } 02987 if (bdytail != 0.0) { 02988 temp16alen = scale_expansion_zeroelim(bytcalen, bytca, bdytail, temp16a); 02989 bytcatlen = scale_expansion_zeroelim(catlen, cat, bdytail, bytcat); 02990 temp32alen = scale_expansion_zeroelim(bytcatlen, bytcat, 2.0 * bdy, 02991 temp32a); 02992 temp48len = fast_expansion_sum_zeroelim(temp16alen, temp16a, 02993 temp32alen, temp32a, temp48); 02994 finlength = fast_expansion_sum_zeroelim(finlength, finnow, temp48len, 02995 temp48, finother); 02996 finswap = finnow; finnow = finother; finother = finswap; 02997 02998 02999 temp32alen = scale_expansion_zeroelim(bytcatlen, bytcat, bdytail, 03000 temp32a); 03001 bytcattlen = scale_expansion_zeroelim(cattlen, catt, bdytail, bytcatt); 03002 temp16alen = scale_expansion_zeroelim(bytcattlen, bytcatt, 2.0 * bdy, 03003 temp16a); 03004 temp16blen = scale_expansion_zeroelim(bytcattlen, bytcatt, bdytail, 03005 temp16b); 03006 temp32blen = fast_expansion_sum_zeroelim(temp16alen, temp16a, 03007 temp16blen, temp16b, temp32b); 03008 temp64len = fast_expansion_sum_zeroelim(temp32alen, temp32a, 03009 temp32blen, temp32b, temp64); 03010 finlength = fast_expansion_sum_zeroelim(finlength, finnow, temp64len, 03011 temp64, finother); 03012 finswap = finnow; finnow = finother; finother = finswap; 03013 } 03014 } 03015 if ((cdxtail != 0.0) || (cdytail != 0.0)) { 03016 if ((adxtail != 0.0) || (adytail != 0.0) 03017 || (bdxtail != 0.0) || (bdytail != 0.0)) { 03018 Two_Product(adxtail, bdy, ti1, ti0); 03019 Two_Product(adx, bdytail, tj1, tj0); 03020 Two_Two_Sum(ti1, ti0, tj1, tj0, u3, u[2], u[1], u[0]); 03021 u[3] = u3; 03022 negate = -ady; 03023 Two_Product(bdxtail, negate, ti1, ti0); 03024 negate = -adytail; 03025 Two_Product(bdx, negate, tj1, tj0); 03026 Two_Two_Sum(ti1, ti0, tj1, tj0, v3, v[2], v[1], v[0]); 03027 v[3] = v3; 03028 abtlen = fast_expansion_sum_zeroelim(4, u, 4, v, abt); 03029 03030 Two_Product(adxtail, bdytail, ti1, ti0); 03031 Two_Product(bdxtail, adytail, tj1, tj0); 03032 Two_Two_Diff(ti1, ti0, tj1, tj0, abtt3, abtt[2], abtt[1], abtt[0]); 03033 abtt[3] = abtt3; 03034 abttlen = 4; 03035 } else { 03036 abt[0] = 0.0; 03037 abtlen = 1; 03038 abtt[0] = 0.0; 03039 abttlen = 1; 03040 } 03041 03042 if (cdxtail != 0.0) { 03043 temp16alen = scale_expansion_zeroelim(cxtablen, cxtab, cdxtail, temp16a); 03044 cxtabtlen = scale_expansion_zeroelim(abtlen, abt, cdxtail, cxtabt); 03045 temp32alen = scale_expansion_zeroelim(cxtabtlen, cxtabt, 2.0 * cdx, 03046 temp32a); 03047 temp48len = fast_expansion_sum_zeroelim(temp16alen, temp16a, 03048 temp32alen, temp32a, temp48); 03049 finlength = fast_expansion_sum_zeroelim(finlength, finnow, temp48len, 03050 temp48, finother); 03051 finswap = finnow; finnow = finother; finother = finswap; 03052 if (adytail != 0.0) { 03053 temp8len = scale_expansion_zeroelim(4, bb, cdxtail, temp8); 03054 temp16alen = scale_expansion_zeroelim(temp8len, temp8, adytail, 03055 temp16a); 03056 finlength = fast_expansion_sum_zeroelim(finlength, finnow, temp16alen, 03057 temp16a, finother); 03058 finswap = finnow; finnow = finother; finother = finswap; 03059 } 03060 if (bdytail != 0.0) { 03061 temp8len = scale_expansion_zeroelim(4, aa, -cdxtail, temp8); 03062 temp16alen = scale_expansion_zeroelim(temp8len, temp8, bdytail, 03063 temp16a); 03064 finlength = fast_expansion_sum_zeroelim(finlength, finnow, temp16alen, 03065 temp16a, finother); 03066 finswap = finnow; finnow = finother; finother = finswap; 03067 } 03068 03069 temp32alen = scale_expansion_zeroelim(cxtabtlen, cxtabt, cdxtail, 03070 temp32a); 03071 cxtabttlen = scale_expansion_zeroelim(abttlen, abtt, cdxtail, cxtabtt); 03072 temp16alen = scale_expansion_zeroelim(cxtabttlen, cxtabtt, 2.0 * cdx, 03073 temp16a); 03074 temp16blen = scale_expansion_zeroelim(cxtabttlen, cxtabtt, cdxtail, 03075 temp16b); 03076 temp32blen = fast_expansion_sum_zeroelim(temp16alen, temp16a, 03077 temp16blen, temp16b, temp32b); 03078 temp64len = fast_expansion_sum_zeroelim(temp32alen, temp32a, 03079 temp32blen, temp32b, temp64); 03080 finlength = fast_expansion_sum_zeroelim(finlength, finnow, temp64len, 03081 temp64, finother); 03082 finswap = finnow; finnow = finother; finother = finswap; 03083 } 03084 if (cdytail != 0.0) { 03085 temp16alen = scale_expansion_zeroelim(cytablen, cytab, cdytail, temp16a); 03086 cytabtlen = scale_expansion_zeroelim(abtlen, abt, cdytail, cytabt); 03087 temp32alen = scale_expansion_zeroelim(cytabtlen, cytabt, 2.0 * cdy, 03088 temp32a); 03089 temp48len = fast_expansion_sum_zeroelim(temp16alen, temp16a, 03090 temp32alen, temp32a, temp48); 03091 finlength = fast_expansion_sum_zeroelim(finlength, finnow, temp48len, 03092 temp48, finother); 03093 finswap = finnow; finnow = finother; finother = finswap; 03094 03095 03096 temp32alen = scale_expansion_zeroelim(cytabtlen, cytabt, cdytail, 03097 temp32a); 03098 cytabttlen = scale_expansion_zeroelim(abttlen, abtt, cdytail, cytabtt); 03099 temp16alen = scale_expansion_zeroelim(cytabttlen, cytabtt, 2.0 * cdy, 03100 temp16a); 03101 temp16blen = scale_expansion_zeroelim(cytabttlen, cytabtt, cdytail, 03102 temp16b); 03103 temp32blen = fast_expansion_sum_zeroelim(temp16alen, temp16a, 03104 temp16blen, temp16b, temp32b); 03105 temp64len = fast_expansion_sum_zeroelim(temp32alen, temp32a, 03106 temp32blen, temp32b, temp64); 03107 finlength = fast_expansion_sum_zeroelim(finlength, finnow, temp64len, 03108 temp64, finother); 03109 finswap = finnow; finnow = finother; finother = finswap; 03110 } 03111 } 03112 03113 return finnow[finlength - 1]; 03114 } 03115 03116 REAL incircle(REAL *pa, REAL *pb, REAL *pc, REAL *pd) 03117 { 03118 REAL adx, bdx, cdx, ady, bdy, cdy; 03119 REAL bdxcdy, cdxbdy, cdxady, adxcdy, adxbdy, bdxady; 03120 REAL alift, blift, clift; 03121 REAL det; 03122 REAL permanent, errbound; 03123 03124 adx = pa[0] - pd[0]; 03125 bdx = pb[0] - pd[0]; 03126 cdx = pc[0] - pd[0]; 03127 ady = pa[1] - pd[1]; 03128 bdy = pb[1] - pd[1]; 03129 cdy = pc[1] - pd[1]; 03130 03131 bdxcdy = bdx * cdy; 03132 cdxbdy = cdx * bdy; 03133 alift = adx * adx + ady * ady; 03134 03135 cdxady = cdx * ady; 03136 adxcdy = adx * cdy; 03137 blift = bdx * bdx + bdy * bdy; 03138 03139 adxbdy = adx * bdy; 03140 bdxady = bdx * ady; 03141 clift = cdx * cdx + cdy * cdy; 03142 03143 det = alift * (bdxcdy - cdxbdy) 03144 + blift * (cdxady - adxcdy) 03145 + clift * (adxbdy - bdxady); 03146 03147 permanent = (Absolute(bdxcdy) + Absolute(cdxbdy)) * alift 03148 + (Absolute(cdxady) + Absolute(adxcdy)) * blift 03149 + (Absolute(adxbdy) + Absolute(bdxady)) * clift; 03150 errbound = iccerrboundA * permanent; 03151 if ((det > errbound) || (-det > errbound)) { 03152 return det; 03153 } 03154 03155 return incircleadapt(pa, pb, pc, pd, permanent); 03156 } 03157 03158 /*****************************************************************************/ 03159 /* */ 03160 /* inspherefast() Approximate 3D insphere test. Nonrobust. */ 03161 /* insphereexact() Exact 3D insphere test. Robust. */ 03162 /* insphereslow() Another exact 3D insphere test. Robust. */ 03163 /* insphere() Adaptive exact 3D insphere test. Robust. */ 03164 /* */ 03165 /* Return a positive value if the point pe lies inside the */ 03166 /* sphere passing through pa, pb, pc, and pd; a negative value */ 03167 /* if it lies outside; and zero if the five points are */ 03168 /* cospherical. The points pa, pb, pc, and pd must be ordered */ 03169 /* so that they have a positive orientation (as defined by */ 03170 /* orient3d()), or the sign of the result will be reversed. */ 03171 /* */ 03172 /* Only the first and last routine should be used; the middle two are for */ 03173 /* timings. */ 03174 /* */ 03175 /* The last three use exact arithmetic to ensure a correct answer. The */ 03176 /* result returned is the determinant of a matrix. In insphere() only, */ 03177 /* this determinant is computed adaptively, in the sense that exact */ 03178 /* arithmetic is used only to the degree it is needed to ensure that the */ 03179 /* returned value has the correct sign. Hence, insphere() is usually quite */ 03180 /* fast, but will run more slowly when the input points are cospherical or */ 03181 /* nearly so. */ 03182 /* */ 03183 /*****************************************************************************/ 03184 03185 REAL inspherefast(REAL *pa, REAL *pb, REAL *pc, REAL *pd, REAL *pe) 03186 { 03187 REAL aex, bex, cex, dex; 03188 REAL aey, bey, cey, dey; 03189 REAL aez, bez, cez, dez; 03190 REAL alift, blift, clift, dlift; 03191 REAL ab, bc, cd, da, ac, bd; 03192 REAL abc, bcd, cda, dab; 03193 03194 aex = pa[0] - pe[0]; 03195 bex = pb[0] - pe[0]; 03196 cex = pc[0] - pe[0]; 03197 dex = pd[0] - pe[0]; 03198 aey = pa[1] - pe[1]; 03199 bey = pb[1] - pe[1]; 03200 cey = pc[1] - pe[1]; 03201 dey = pd[1] - pe[1]; 03202 aez = pa[2] - pe[2]; 03203 bez = pb[2] - pe[2]; 03204 cez = pc[2] - pe[2]; 03205 dez = pd[2] - pe[2]; 03206 03207 ab = aex * bey - bex * aey; 03208 bc = bex * cey - cex * bey; 03209 cd = cex * dey - dex * cey; 03210 da = dex * aey - aex * dey; 03211 03212 ac = aex * cey - cex * aey; 03213 bd = bex * dey - dex * bey; 03214 03215 abc = aez * bc - bez * ac + cez * ab; 03216 bcd = bez * cd - cez * bd + dez * bc; 03217 cda = cez * da + dez * ac + aez * cd; 03218 dab = dez * ab + aez * bd + bez * da; 03219 03220 alift = aex * aex + aey * aey + aez * aez; 03221 blift = bex * bex + bey * bey + bez * bez; 03222 clift = cex * cex + cey * cey + cez * cez; 03223 dlift = dex * dex + dey * dey + dez * dez; 03224 03225 return (dlift * abc - clift * dab) + (blift * cda - alift * bcd); 03226 } 03227 03228 REAL insphereexact(REAL *pa, REAL *pb, REAL *pc, REAL *pd, REAL *pe) 03229 { 03230 INEXACT REAL axby1, bxcy1, cxdy1, dxey1, exay1; 03231 INEXACT REAL bxay1, cxby1, dxcy1, exdy1, axey1; 03232 INEXACT REAL axcy1, bxdy1, cxey1, dxay1, exby1; 03233 INEXACT REAL cxay1, dxby1, excy1, axdy1, bxey1; 03234 REAL axby0, bxcy0, cxdy0, dxey0, exay0; 03235 REAL bxay0, cxby0, dxcy0, exdy0, axey0; 03236 REAL axcy0, bxdy0, cxey0, dxay0, exby0; 03237 REAL cxay0, dxby0, excy0, axdy0, bxey0; 03238 REAL ab[4], bc[4], cd[4], de[4], ea[4]; 03239 REAL ac[4], bd[4], ce[4], da[4], eb[4]; 03240 REAL temp8a[8], temp8b[8], temp16[16]; 03241 int temp8alen, temp8blen, temp16len; 03242 REAL abc[24], bcd[24], cde[24], dea[24], eab[24]; 03243 REAL abd[24], bce[24], cda[24], deb[24], eac[24]; 03244 int abclen, bcdlen, cdelen, dealen, eablen; 03245 int abdlen, bcelen, cdalen, deblen, eaclen; 03246 REAL temp48a[48], temp48b[48]; 03247 int temp48alen, temp48blen; 03248 REAL abcd[96], bcde[96], cdea[96], deab[96], eabc[96]; 03249 int abcdlen, bcdelen, cdealen, deablen, eabclen; 03250 REAL temp192[192]; 03251 REAL det384x[384], det384y[384], det384z[384]; 03252 int xlen, ylen, zlen; 03253 REAL detxy[768]; 03254 int xylen; 03255 REAL adet[1152], bdet[1152], cdet[1152], ddet[1152], edet[1152]; 03256 int alen, blen, clen, dlen, elen; 03257 REAL abdet[2304], cddet[2304], cdedet[3456]; 03258 int ablen, cdlen; 03259 REAL deter[5760]; 03260 int deterlen; 03261 int i; 03262 03263 INEXACT REAL bvirt; 03264 REAL avirt, bround, around; 03265 INEXACT REAL c; 03266 INEXACT REAL abig; 03267 REAL ahi, alo, bhi, blo; 03268 REAL err1, err2, err3; 03269 INEXACT REAL _i, _j; 03270 REAL _0; 03271 03272 Two_Product(pa[0], pb[1], axby1, axby0); 03273 Two_Product(pb[0], pa[1], bxay1, bxay0); 03274 Two_Two_Diff(axby1, axby0, bxay1, bxay0, ab[3], ab[2], ab[1], ab[0]); 03275 03276 Two_Product(pb[0], pc[1], bxcy1, bxcy0); 03277 Two_Product(pc[0], pb[1], cxby1, cxby0); 03278 Two_Two_Diff(bxcy1, bxcy0, cxby1, cxby0, bc[3], bc[2], bc[1], bc[0]); 03279 03280 Two_Product(pc[0], pd[1], cxdy1, cxdy0); 03281 Two_Product(pd[0], pc[1], dxcy1, dxcy0); 03282 Two_Two_Diff(cxdy1, cxdy0, dxcy1, dxcy0, cd[3], cd[2], cd[1], cd[0]); 03283 03284 Two_Product(pd[0], pe[1], dxey1, dxey0); 03285 Two_Product(pe[0], pd[1], exdy1, exdy0); 03286 Two_Two_Diff(dxey1, dxey0, exdy1, exdy0, de[3], de[2], de[1], de[0]); 03287 03288 Two_Product(pe[0], pa[1], exay1, exay0); 03289 Two_Product(pa[0], pe[1], axey1, axey0); 03290 Two_Two_Diff(exay1, exay0, axey1, axey0, ea[3], ea[2], ea[1], ea[0]); 03291 03292 Two_Product(pa[0], pc[1], axcy1, axcy0); 03293 Two_Product(pc[0], pa[1], cxay1, cxay0); 03294 Two_Two_Diff(axcy1, axcy0, cxay1, cxay0, ac[3], ac[2], ac[1], ac[0]); 03295 03296 Two_Product(pb[0], pd[1], bxdy1, bxdy0); 03297 Two_Product(pd[0], pb[1], dxby1, dxby0); 03298 Two_Two_Diff(bxdy1, bxdy0, dxby1, dxby0, bd[3], bd[2], bd[1], bd[0]); 03299 03300 Two_Product(pc[0], pe[1], cxey1, cxey0); 03301 Two_Product(pe[0], pc[1], excy1, excy0); 03302 Two_Two_Diff(cxey1, cxey0, excy1, excy0, ce[3], ce[2], ce[1], ce[0]); 03303 03304 Two_Product(pd[0], pa[1], dxay1, dxay0); 03305 Two_Product(pa[0], pd[1], axdy1, axdy0); 03306 Two_Two_Diff(dxay1, dxay0, axdy1, axdy0, da[3], da[2], da[1], da[0]); 03307 03308 Two_Product(pe[0], pb[1], exby1, exby0); 03309 Two_Product(pb[0], pe[1], bxey1, bxey0); 03310 Two_Two_Diff(exby1, exby0, bxey1, bxey0, eb[3], eb[2], eb[1], eb[0]); 03311 03312 temp8alen = scale_expansion_zeroelim(4, bc, pa[2], temp8a); 03313 temp8blen = scale_expansion_zeroelim(4, ac, -pb[2], temp8b); 03314 temp16len = fast_expansion_sum_zeroelim(temp8alen, temp8a, temp8blen, temp8b, 03315 temp16); 03316 temp8alen = scale_expansion_zeroelim(4, ab, pc[2], temp8a); 03317 abclen = fast_expansion_sum_zeroelim(temp8alen, temp8a, temp16len, temp16, 03318 abc); 03319 03320 temp8alen = scale_expansion_zeroelim(4, cd, pb[2], temp8a); 03321 temp8blen = scale_expansion_zeroelim(4, bd, -pc[2], temp8b); 03322 temp16len = fast_expansion_sum_zeroelim(temp8alen, temp8a, temp8blen, temp8b, 03323 temp16); 03324 temp8alen = scale_expansion_zeroelim(4, bc, pd[2], temp8a); 03325 bcdlen = fast_expansion_sum_zeroelim(temp8alen, temp8a, temp16len, temp16, 03326 bcd); 03327 03328 temp8alen = scale_expansion_zeroelim(4, de, pc[2], temp8a); 03329 temp8blen = scale_expansion_zeroelim(4, ce, -pd[2], temp8b); 03330 temp16len = fast_expansion_sum_zeroelim(temp8alen, temp8a, temp8blen, temp8b, 03331 temp16); 03332 temp8alen = scale_expansion_zeroelim(4, cd, pe[2], temp8a); 03333 cdelen = fast_expansion_sum_zeroelim(temp8alen, temp8a, temp16len, temp16, 03334 cde); 03335 03336 temp8alen = scale_expansion_zeroelim(4, ea, pd[2], temp8a); 03337 temp8blen = scale_expansion_zeroelim(4, da, -pe[2], temp8b); 03338 temp16len = fast_expansion_sum_zeroelim(temp8alen, temp8a, temp8blen, temp8b, 03339 temp16); 03340 temp8alen = scale_expansion_zeroelim(4, de, pa[2], temp8a); 03341 dealen = fast_expansion_sum_zeroelim(temp8alen, temp8a, temp16len, temp16, 03342 dea); 03343 03344 temp8alen = scale_expansion_zeroelim(4, ab, pe[2], temp8a); 03345 temp8blen = scale_expansion_zeroelim(4, eb, -pa[2], temp8b); 03346 temp16len = fast_expansion_sum_zeroelim(temp8alen, temp8a, temp8blen, temp8b, 03347 temp16); 03348 temp8alen = scale_expansion_zeroelim(4, ea, pb[2], temp8a); 03349 eablen = fast_expansion_sum_zeroelim(temp8alen, temp8a, temp16len, temp16, 03350 eab); 03351 03352 temp8alen = scale_expansion_zeroelim(4, bd, pa[2], temp8a); 03353 temp8blen = scale_expansion_zeroelim(4, da, pb[2], temp8b); 03354 temp16len = fast_expansion_sum_zeroelim(temp8alen, temp8a, temp8blen, temp8b, 03355 temp16); 03356 temp8alen = scale_expansion_zeroelim(4, ab, pd[2], temp8a); 03357 abdlen = fast_expansion_sum_zeroelim(temp8alen, temp8a, temp16len, temp16, 03358 abd); 03359 03360 temp8alen = scale_expansion_zeroelim(4, ce, pb[2], temp8a); 03361 temp8blen = scale_expansion_zeroelim(4, eb, pc[2], temp8b); 03362 temp16len = fast_expansion_sum_zeroelim(temp8alen, temp8a, temp8blen, temp8b, 03363 temp16); 03364 temp8alen = scale_expansion_zeroelim(4, bc, pe[2], temp8a); 03365 bcelen = fast_expansion_sum_zeroelim(temp8alen, temp8a, temp16len, temp16, 03366 bce); 03367 03368 temp8alen = scale_expansion_zeroelim(4, da, pc[2], temp8a); 03369 temp8blen = scale_expansion_zeroelim(4, ac, pd[2], temp8b); 03370 temp16len = fast_expansion_sum_zeroelim(temp8alen, temp8a, temp8blen, temp8b, 03371 temp16); 03372 temp8alen = scale_expansion_zeroelim(4, cd, pa[2], temp8a); 03373 cdalen = fast_expansion_sum_zeroelim(temp8alen, temp8a, temp16len, temp16, 03374 cda); 03375 03376 temp8alen = scale_expansion_zeroelim(4, eb, pd[2], temp8a); 03377 temp8blen = scale_expansion_zeroelim(4, bd, pe[2], temp8b); 03378 temp16len = fast_expansion_sum_zeroelim(temp8alen, temp8a, temp8blen, temp8b, 03379 temp16); 03380 temp8alen = scale_expansion_zeroelim(4, de, pb[2], temp8a); 03381 deblen = fast_expansion_sum_zeroelim(temp8alen, temp8a, temp16len, temp16, 03382 deb); 03383 03384 temp8alen = scale_expansion_zeroelim(4, ac, pe[2], temp8a); 03385 temp8blen = scale_expansion_zeroelim(4, ce, pa[2], temp8b); 03386 temp16len = fast_expansion_sum_zeroelim(temp8alen, temp8a, temp8blen, temp8b, 03387 temp16); 03388 temp8alen = scale_expansion_zeroelim(4, ea, pc[2], temp8a); 03389 eaclen = fast_expansion_sum_zeroelim(temp8alen, temp8a, temp16len, temp16, 03390 eac); 03391 03392 temp48alen = fast_expansion_sum_zeroelim(cdelen, cde, bcelen, bce, temp48a); 03393 temp48blen = fast_expansion_sum_zeroelim(deblen, deb, bcdlen, bcd, temp48b); 03394 for (i = 0; i < temp48blen; i++) { 03395 temp48b[i] = -temp48b[i]; 03396 } 03397 bcdelen = fast_expansion_sum_zeroelim(temp48alen, temp48a, 03398 temp48blen, temp48b, bcde); 03399 xlen = scale_expansion_zeroelim(bcdelen, bcde, pa[0], temp192); 03400 xlen = scale_expansion_zeroelim(xlen, temp192, pa[0], det384x); 03401 ylen = scale_expansion_zeroelim(bcdelen, bcde, pa[1], temp192); 03402 ylen = scale_expansion_zeroelim(ylen, temp192, pa[1], det384y); 03403 zlen = scale_expansion_zeroelim(bcdelen, bcde, pa[2], temp192); 03404 zlen = scale_expansion_zeroelim(zlen, temp192, pa[2], det384z); 03405 xylen = fast_expansion_sum_zeroelim(xlen, det384x, ylen, det384y, detxy); 03406 alen = fast_expansion_sum_zeroelim(xylen, detxy, zlen, det384z, adet); 03407 03408 temp48alen = fast_expansion_sum_zeroelim(dealen, dea, cdalen, cda, temp48a); 03409 temp48blen = fast_expansion_sum_zeroelim(eaclen, eac, cdelen, cde, temp48b); 03410 for (i = 0; i < temp48blen; i++) { 03411 temp48b[i] = -temp48b[i]; 03412 } 03413 cdealen = fast_expansion_sum_zeroelim(temp48alen, temp48a, 03414 temp48blen, temp48b, cdea); 03415 xlen = scale_expansion_zeroelim(cdealen, cdea, pb[0], temp192); 03416 xlen = scale_expansion_zeroelim(xlen, temp192, pb[0], det384x); 03417 ylen = scale_expansion_zeroelim(cdealen, cdea, pb[1], temp192); 03418 ylen = scale_expansion_zeroelim(ylen, temp192, pb[1], det384y); 03419 zlen = scale_expansion_zeroelim(cdealen, cdea, pb[2], temp192); 03420 zlen = scale_expansion_zeroelim(zlen, temp192, pb[2], det384z); 03421 xylen = fast_expansion_sum_zeroelim(xlen, det384x, ylen, det384y, detxy); 03422 blen = fast_expansion_sum_zeroelim(xylen, detxy, zlen, det384z, bdet); 03423 03424 temp48alen = fast_expansion_sum_zeroelim(eablen, eab, deblen, deb, temp48a); 03425 temp48blen = fast_expansion_sum_zeroelim(abdlen, abd, dealen, dea, temp48b); 03426 for (i = 0; i < temp48blen; i++) { 03427 temp48b[i] = -temp48b[i]; 03428 } 03429 deablen = fast_expansion_sum_zeroelim(temp48alen, temp48a, 03430 temp48blen, temp48b, deab); 03431 xlen = scale_expansion_zeroelim(deablen, deab, pc[0], temp192); 03432 xlen = scale_expansion_zeroelim(xlen, temp192, pc[0], det384x); 03433 ylen = scale_expansion_zeroelim(deablen, deab, pc[1], temp192); 03434 ylen = scale_expansion_zeroelim(ylen, temp192, pc[1], det384y); 03435 zlen = scale_expansion_zeroelim(deablen, deab, pc[2], temp192); 03436 zlen = scale_expansion_zeroelim(zlen, temp192, pc[2], det384z); 03437 xylen = fast_expansion_sum_zeroelim(xlen, det384x, ylen, det384y, detxy); 03438 clen = fast_expansion_sum_zeroelim(xylen, detxy, zlen, det384z, cdet); 03439 03440 temp48alen = fast_expansion_sum_zeroelim(abclen, abc, eaclen, eac, temp48a); 03441 temp48blen = fast_expansion_sum_zeroelim(bcelen, bce, eablen, eab, temp48b); 03442 for (i = 0; i < temp48blen; i++) { 03443 temp48b[i] = -temp48b[i]; 03444 } 03445 eabclen = fast_expansion_sum_zeroelim(temp48alen, temp48a, 03446 temp48blen, temp48b, eabc); 03447 xlen = scale_expansion_zeroelim(eabclen, eabc, pd[0], temp192); 03448 xlen = scale_expansion_zeroelim(xlen, temp192, pd[0], det384x); 03449 ylen = scale_expansion_zeroelim(eabclen, eabc, pd[1], temp192); 03450 ylen = scale_expansion_zeroelim(ylen, temp192, pd[1], det384y); 03451 zlen = scale_expansion_zeroelim(eabclen, eabc, pd[2], temp192); 03452 zlen = scale_expansion_zeroelim(zlen, temp192, pd[2], det384z); 03453 xylen = fast_expansion_sum_zeroelim(xlen, det384x, ylen, det384y, detxy); 03454 dlen = fast_expansion_sum_zeroelim(xylen, detxy, zlen, det384z, ddet); 03455 03456 temp48alen = fast_expansion_sum_zeroelim(bcdlen, bcd, abdlen, abd, temp48a); 03457 temp48blen = fast_expansion_sum_zeroelim(cdalen, cda, abclen, abc, temp48b); 03458 for (i = 0; i < temp48blen; i++) { 03459 temp48b[i] = -temp48b[i]; 03460 } 03461 abcdlen = fast_expansion_sum_zeroelim(temp48alen, temp48a, 03462 temp48blen, temp48b, abcd); 03463 xlen = scale_expansion_zeroelim(abcdlen, abcd, pe[0], temp192); 03464 xlen = scale_expansion_zeroelim(xlen, temp192, pe[0], det384x); 03465 ylen = scale_expansion_zeroelim(abcdlen, abcd, pe[1], temp192); 03466 ylen = scale_expansion_zeroelim(ylen, temp192, pe[1], det384y); 03467 zlen = scale_expansion_zeroelim(abcdlen, abcd, pe[2], temp192); 03468 zlen = scale_expansion_zeroelim(zlen, temp192, pe[2], det384z); 03469 xylen = fast_expansion_sum_zeroelim(xlen, det384x, ylen, det384y, detxy); 03470 elen = fast_expansion_sum_zeroelim(xylen, detxy, zlen, det384z, edet); 03471 03472 ablen = fast_expansion_sum_zeroelim(alen, adet, blen, bdet, abdet); 03473 cdlen = fast_expansion_sum_zeroelim(clen, cdet, dlen, ddet, cddet); 03474 cdelen = fast_expansion_sum_zeroelim(cdlen, cddet, elen, edet, cdedet); 03475 deterlen = fast_expansion_sum_zeroelim(ablen, abdet, cdelen, cdedet, deter); 03476 03477 return deter[deterlen - 1]; 03478 } 03479 03480 REAL insphereslow(REAL *pa, REAL *pb, REAL *pc, REAL *pd, REAL *pe) 03481 { 03482 INEXACT REAL aex, bex, cex, dex, aey, bey, cey, dey, aez, bez, cez, dez; 03483 REAL aextail, bextail, cextail, dextail; 03484 REAL aeytail, beytail, ceytail, deytail; 03485 REAL aeztail, beztail, ceztail, deztail; 03486 REAL negate, negatetail; 03487 INEXACT REAL axby7, bxcy7, cxdy7, dxay7, axcy7, bxdy7; 03488 INEXACT REAL bxay7, cxby7, dxcy7, axdy7, cxay7, dxby7; 03489 REAL axby[8], bxcy[8], cxdy[8], dxay[8], axcy[8], bxdy[8]; 03490 REAL bxay[8], cxby[8], dxcy[8], axdy[8], cxay[8], dxby[8]; 03491 REAL ab[16], bc[16], cd[16], da[16], ac[16], bd[16]; 03492 int ablen, bclen, cdlen, dalen, aclen, bdlen; 03493 REAL temp32a[32], temp32b[32], temp64a[64], temp64b[64], temp64c[64]; 03494 int temp32alen, temp32blen, temp64alen, temp64blen, temp64clen; 03495 REAL temp128[128], temp192[192]; 03496 int temp128len, temp192len; 03497 REAL detx[384], detxx[768], detxt[384], detxxt[768], detxtxt[768]; 03498 int xlen, xxlen, xtlen, xxtlen, xtxtlen; 03499 REAL x1[1536], x2[2304]; 03500 int x1len, x2len; 03501 REAL dety[384], detyy[768], detyt[384], detyyt[768], detytyt[768]; 03502 int ylen, yylen, ytlen, yytlen, ytytlen; 03503 REAL y1[1536], y2[2304]; 03504 int y1len, y2len; 03505 REAL detz[384], detzz[768], detzt[384], detzzt[768], detztzt[768]; 03506 int zlen, zzlen, ztlen, zztlen, ztztlen; 03507 REAL z1[1536], z2[2304]; 03508 int z1len, z2len; 03509 REAL detxy[4608]; 03510 int xylen; 03511 REAL adet[6912], bdet[6912], cdet[6912], ddet[6912]; 03512 int alen, blen, clen, dlen; 03513 REAL abdet[13824], cddet[13824], deter[27648]; 03514 int deterlen; 03515 int i; 03516 03517 INEXACT REAL bvirt; 03518 REAL avirt, bround, around; 03519 INEXACT REAL c; 03520 INEXACT REAL abig; 03521 REAL a0hi, a0lo, a1hi, a1lo, bhi, blo; 03522 REAL err1, err2, err3; 03523 INEXACT REAL _i, _j, _k, _l, _m, _n; 03524 REAL _0, _1, _2; 03525 03526 Two_Diff(pa[0], pe[0], aex, aextail); 03527 Two_Diff(pa[1], pe[1], aey, aeytail); 03528 Two_Diff(pa[2], pe[2], aez, aeztail); 03529 Two_Diff(pb[0], pe[0], bex, bextail); 03530 Two_Diff(pb[1], pe[1], bey, beytail); 03531 Two_Diff(pb[2], pe[2], bez, beztail); 03532 Two_Diff(pc[0], pe[0], cex, cextail); 03533 Two_Diff(pc[1], pe[1], cey, ceytail); 03534 Two_Diff(pc[2], pe[2], cez, ceztail); 03535 Two_Diff(pd[0], pe[0], dex, dextail); 03536 Two_Diff(pd[1], pe[1], dey, deytail); 03537 Two_Diff(pd[2], pe[2], dez, deztail); 03538 03539 Two_Two_Product(aex, aextail, bey, beytail, 03540 axby7, axby[6], axby[5], axby[4], 03541 axby[3], axby[2], axby[1], axby[0]); 03542 axby[7] = axby7; 03543 negate = -aey; 03544 negatetail = -aeytail; 03545 Two_Two_Product(bex, bextail, negate, negatetail, 03546 bxay7, bxay[6], bxay[5], bxay[4], 03547 bxay[3], bxay[2], bxay[1], bxay[0]); 03548 bxay[7] = bxay7; 03549 ablen = fast_expansion_sum_zeroelim(8, axby, 8, bxay, ab); 03550 Two_Two_Product(bex, bextail, cey, ceytail, 03551 bxcy7, bxcy[6], bxcy[5], bxcy[4], 03552 bxcy[3], bxcy[2], bxcy[1], bxcy[0]); 03553 bxcy[7] = bxcy7; 03554 negate = -bey; 03555 negatetail = -beytail; 03556 Two_Two_Product(cex, cextail, negate, negatetail, 03557 cxby7, cxby[6], cxby[5], cxby[4], 03558 cxby[3], cxby[2], cxby[1], cxby[0]); 03559 cxby[7] = cxby7; 03560 bclen = fast_expansion_sum_zeroelim(8, bxcy, 8, cxby, bc); 03561 Two_Two_Product(cex, cextail, dey, deytail, 03562 cxdy7, cxdy[6], cxdy[5], cxdy[4], 03563 cxdy[3], cxdy[2], cxdy[1], cxdy[0]); 03564 cxdy[7] = cxdy7; 03565 negate = -cey; 03566 negatetail = -ceytail; 03567 Two_Two_Product(dex, dextail, negate, negatetail, 03568 dxcy7, dxcy[6], dxcy[5], dxcy[4], 03569 dxcy[3], dxcy[2], dxcy[1], dxcy[0]); 03570 dxcy[7] = dxcy7; 03571 cdlen = fast_expansion_sum_zeroelim(8, cxdy, 8, dxcy, cd); 03572 Two_Two_Product(dex, dextail, aey, aeytail, 03573 dxay7, dxay[6], dxay[5], dxay[4], 03574 dxay[3], dxay[2], dxay[1], dxay[0]); 03575 dxay[7] = dxay7; 03576 negate = -dey; 03577 negatetail = -deytail; 03578 Two_Two_Product(aex, aextail, negate, negatetail, 03579 axdy7, axdy[6], axdy[5], axdy[4], 03580 axdy[3], axdy[2], axdy[1], axdy[0]); 03581 axdy[7] = axdy7; 03582 dalen = fast_expansion_sum_zeroelim(8, dxay, 8, axdy, da); 03583 Two_Two_Product(aex, aextail, cey, ceytail, 03584 axcy7, axcy[6], axcy[5], axcy[4], 03585 axcy[3], axcy[2], axcy[1], axcy[0]); 03586 axcy[7] = axcy7; 03587 negate = -aey; 03588 negatetail = -aeytail; 03589 Two_Two_Product(cex, cextail, negate, negatetail, 03590 cxay7, cxay[6], cxay[5], cxay[4], 03591 cxay[3], cxay[2], cxay[1], cxay[0]); 03592 cxay[7] = cxay7; 03593 aclen = fast_expansion_sum_zeroelim(8, axcy, 8, cxay, ac); 03594 Two_Two_Product(bex, bextail, dey, deytail, 03595 bxdy7, bxdy[6], bxdy[5], bxdy[4], 03596 bxdy[3], bxdy[2], bxdy[1], bxdy[0]); 03597 bxdy[7] = bxdy7; 03598 negate = -bey; 03599 negatetail = -beytail; 03600 Two_Two_Product(dex, dextail, negate, negatetail, 03601 dxby7, dxby[6], dxby[5], dxby[4], 03602 dxby[3], dxby[2], dxby[1], dxby[0]); 03603 dxby[7] = dxby7; 03604 bdlen = fast_expansion_sum_zeroelim(8, bxdy, 8, dxby, bd); 03605 03606 temp32alen = scale_expansion_zeroelim(cdlen, cd, -bez, temp32a); 03607 temp32blen = scale_expansion_zeroelim(cdlen, cd, -beztail, temp32b); 03608 temp64alen = fast_expansion_sum_zeroelim(temp32alen, temp32a, 03609 temp32blen, temp32b, temp64a); 03610 temp32alen = scale_expansion_zeroelim(bdlen, bd, cez, temp32a); 03611 temp32blen = scale_expansion_zeroelim(bdlen, bd, ceztail, temp32b); 03612 temp64blen = fast_expansion_sum_zeroelim(temp32alen, temp32a, 03613 temp32blen, temp32b, temp64b); 03614 temp32alen = scale_expansion_zeroelim(bclen, bc, -dez, temp32a); 03615 temp32blen = scale_expansion_zeroelim(bclen, bc, -deztail, temp32b); 03616 temp64clen = fast_expansion_sum_zeroelim(temp32alen, temp32a, 03617 temp32blen, temp32b, temp64c); 03618 temp128len = fast_expansion_sum_zeroelim(temp64alen, temp64a, 03619 temp64blen, temp64b, temp128); 03620 temp192len = fast_expansion_sum_zeroelim(temp64clen, temp64c, 03621 temp128len, temp128, temp192); 03622 xlen = scale_expansion_zeroelim(temp192len, temp192, aex, detx); 03623 xxlen = scale_expansion_zeroelim(xlen, detx, aex, detxx); 03624 xtlen = scale_expansion_zeroelim(temp192len, temp192, aextail, detxt); 03625 xxtlen = scale_expansion_zeroelim(xtlen, detxt, aex, detxxt); 03626 for (i = 0; i < xxtlen; i++) { 03627 detxxt[i] *= 2.0; 03628 } 03629 xtxtlen = scale_expansion_zeroelim(xtlen, detxt, aextail, detxtxt); 03630 x1len = fast_expansion_sum_zeroelim(xxlen, detxx, xxtlen, detxxt, x1); 03631 x2len = fast_expansion_sum_zeroelim(x1len, x1, xtxtlen, detxtxt, x2); 03632 ylen = scale_expansion_zeroelim(temp192len, temp192, aey, dety); 03633 yylen = scale_expansion_zeroelim(ylen, dety, aey, detyy); 03634 ytlen = scale_expansion_zeroelim(temp192len, temp192, aeytail, detyt); 03635 yytlen = scale_expansion_zeroelim(ytlen, detyt, aey, detyyt); 03636 for (i = 0; i < yytlen; i++) { 03637 detyyt[i] *= 2.0; 03638 } 03639 ytytlen = scale_expansion_zeroelim(ytlen, detyt, aeytail, detytyt); 03640 y1len = fast_expansion_sum_zeroelim(yylen, detyy, yytlen, detyyt, y1); 03641 y2len = fast_expansion_sum_zeroelim(y1len, y1, ytytlen, detytyt, y2); 03642 zlen = scale_expansion_zeroelim(temp192len, temp192, aez, detz); 03643 zzlen = scale_expansion_zeroelim(zlen, detz, aez, detzz); 03644 ztlen = scale_expansion_zeroelim(temp192len, temp192, aeztail, detzt); 03645 zztlen = scale_expansion_zeroelim(ztlen, detzt, aez, detzzt); 03646 for (i = 0; i < zztlen; i++) { 03647 detzzt[i] *= 2.0; 03648 } 03649 ztztlen = scale_expansion_zeroelim(ztlen, detzt, aeztail, detztzt); 03650 z1len = fast_expansion_sum_zeroelim(zzlen, detzz, zztlen, detzzt, z1); 03651 z2len = fast_expansion_sum_zeroelim(z1len, z1, ztztlen, detztzt, z2); 03652 xylen = fast_expansion_sum_zeroelim(x2len, x2, y2len, y2, detxy); 03653 alen = fast_expansion_sum_zeroelim(z2len, z2, xylen, detxy, adet); 03654 03655 temp32alen = scale_expansion_zeroelim(dalen, da, cez, temp32a); 03656 temp32blen = scale_expansion_zeroelim(dalen, da, ceztail, temp32b); 03657 temp64alen = fast_expansion_sum_zeroelim(temp32alen, temp32a, 03658 temp32blen, temp32b, temp64a); 03659 temp32alen = scale_expansion_zeroelim(aclen, ac, dez, temp32a); 03660 temp32blen = scale_expansion_zeroelim(aclen, ac, deztail, temp32b); 03661 temp64blen = fast_expansion_sum_zeroelim(temp32alen, temp32a, 03662 temp32blen, temp32b, temp64b); 03663 temp32alen = scale_expansion_zeroelim(cdlen, cd, aez, temp32a); 03664 temp32blen = scale_expansion_zeroelim(cdlen, cd, aeztail, temp32b); 03665 temp64clen = fast_expansion_sum_zeroelim(temp32alen, temp32a, 03666 temp32blen, temp32b, temp64c); 03667 temp128len = fast_expansion_sum_zeroelim(temp64alen, temp64a, 03668 temp64blen, temp64b, temp128); 03669 temp192len = fast_expansion_sum_zeroelim(temp64clen, temp64c, 03670 temp128len, temp128, temp192); 03671 xlen = scale_expansion_zeroelim(temp192len, temp192, bex, detx); 03672 xxlen = scale_expansion_zeroelim(xlen, detx, bex, detxx); 03673 xtlen = scale_expansion_zeroelim(temp192len, temp192, bextail, detxt); 03674 xxtlen = scale_expansion_zeroelim(xtlen, detxt, bex, detxxt); 03675 for (i = 0; i < xxtlen; i++) { 03676 detxxt[i] *= 2.0; 03677 } 03678 xtxtlen = scale_expansion_zeroelim(xtlen, detxt, bextail, detxtxt); 03679 x1len = fast_expansion_sum_zeroelim(xxlen, detxx, xxtlen, detxxt, x1); 03680 x2len = fast_expansion_sum_zeroelim(x1len, x1, xtxtlen, detxtxt, x2); 03681 ylen = scale_expansion_zeroelim(temp192len, temp192, bey, dety); 03682 yylen = scale_expansion_zeroelim(ylen, dety, bey, detyy); 03683 ytlen = scale_expansion_zeroelim(temp192len, temp192, beytail, detyt); 03684 yytlen = scale_expansion_zeroelim(ytlen, detyt, bey, detyyt); 03685 for (i = 0; i < yytlen; i++) { 03686 detyyt[i] *= 2.0; 03687 } 03688 ytytlen = scale_expansion_zeroelim(ytlen, detyt, beytail, detytyt); 03689 y1len = fast_expansion_sum_zeroelim(yylen, detyy, yytlen, detyyt, y1); 03690 y2len = fast_expansion_sum_zeroelim(y1len, y1, ytytlen, detytyt, y2); 03691 zlen = scale_expansion_zeroelim(temp192len, temp192, bez, detz); 03692 zzlen = scale_expansion_zeroelim(zlen, detz, bez, detzz); 03693 ztlen = scale_expansion_zeroelim(temp192len, temp192, beztail, detzt); 03694 zztlen = scale_expansion_zeroelim(ztlen, detzt, bez, detzzt); 03695 for (i = 0; i < zztlen; i++) { 03696 detzzt[i] *= 2.0; 03697 } 03698 ztztlen = scale_expansion_zeroelim(ztlen, detzt, beztail, detztzt); 03699 z1len = fast_expansion_sum_zeroelim(zzlen, detzz, zztlen, detzzt, z1); 03700 z2len = fast_expansion_sum_zeroelim(z1len, z1, ztztlen, detztzt, z2); 03701 xylen = fast_expansion_sum_zeroelim(x2len, x2, y2len, y2, detxy); 03702 blen = fast_expansion_sum_zeroelim(z2len, z2, xylen, detxy, bdet); 03703 03704 temp32alen = scale_expansion_zeroelim(ablen, ab, -dez, temp32a); 03705 temp32blen = scale_expansion_zeroelim(ablen, ab, -deztail, temp32b); 03706 temp64alen = fast_expansion_sum_zeroelim(temp32alen, temp32a, 03707 temp32blen, temp32b, temp64a); 03708 temp32alen = scale_expansion_zeroelim(bdlen, bd, -aez, temp32a); 03709 temp32blen = scale_expansion_zeroelim(bdlen, bd, -aeztail, temp32b); 03710 temp64blen = fast_expansion_sum_zeroelim(temp32alen, temp32a, 03711 temp32blen, temp32b, temp64b); 03712 temp32alen = scale_expansion_zeroelim(dalen, da, -bez, temp32a); 03713 temp32blen = scale_expansion_zeroelim(dalen, da, -beztail, temp32b); 03714 temp64clen = fast_expansion_sum_zeroelim(temp32alen, temp32a, 03715 temp32blen, temp32b, temp64c); 03716 temp128len = fast_expansion_sum_zeroelim(temp64alen, temp64a, 03717 temp64blen, temp64b, temp128); 03718 temp192len = fast_expansion_sum_zeroelim(temp64clen, temp64c, 03719 temp128len, temp128, temp192); 03720 xlen = scale_expansion_zeroelim(temp192len, temp192, cex, detx); 03721 xxlen = scale_expansion_zeroelim(xlen, detx, cex, detxx); 03722 xtlen = scale_expansion_zeroelim(temp192len, temp192, cextail, detxt); 03723 xxtlen = scale_expansion_zeroelim(xtlen, detxt, cex, detxxt); 03724 for (i = 0; i < xxtlen; i++) { 03725 detxxt[i] *= 2.0; 03726 } 03727 xtxtlen = scale_expansion_zeroelim(xtlen, detxt, cextail, detxtxt); 03728 x1len = fast_expansion_sum_zeroelim(xxlen, detxx, xxtlen, detxxt, x1); 03729 x2len = fast_expansion_sum_zeroelim(x1len, x1, xtxtlen, detxtxt, x2); 03730 ylen = scale_expansion_zeroelim(temp192len, temp192, cey, dety); 03731 yylen = scale_expansion_zeroelim(ylen, dety, cey, detyy); 03732 ytlen = scale_expansion_zeroelim(temp192len, temp192, ceytail, detyt); 03733 yytlen = scale_expansion_zeroelim(ytlen, detyt, cey, detyyt); 03734 for (i = 0; i < yytlen; i++) { 03735 detyyt[i] *= 2.0; 03736 } 03737 ytytlen = scale_expansion_zeroelim(ytlen, detyt, ceytail, detytyt); 03738 y1len = fast_expansion_sum_zeroelim(yylen, detyy, yytlen, detyyt, y1); 03739 y2len = fast_expansion_sum_zeroelim(y1len, y1, ytytlen, detytyt, y2); 03740 zlen = scale_expansion_zeroelim(temp192len, temp192, cez, detz); 03741 zzlen = scale_expansion_zeroelim(zlen, detz, cez, detzz); 03742 ztlen = scale_expansion_zeroelim(temp192len, temp192, ceztail, detzt); 03743 zztlen = scale_expansion_zeroelim(ztlen, detzt, cez, detzzt); 03744 for (i = 0; i < zztlen; i++) { 03745 detzzt[i] *= 2.0; 03746 } 03747 ztztlen = scale_expansion_zeroelim(ztlen, detzt, ceztail, detztzt); 03748 z1len = fast_expansion_sum_zeroelim(zzlen, detzz, zztlen, detzzt, z1); 03749 z2len = fast_expansion_sum_zeroelim(z1len, z1, ztztlen, detztzt, z2); 03750 xylen = fast_expansion_sum_zeroelim(x2len, x2, y2len, y2, detxy); 03751 clen = fast_expansion_sum_zeroelim(z2len, z2, xylen, detxy, cdet); 03752 03753 temp32alen = scale_expansion_zeroelim(bclen, bc, aez, temp32a); 03754 temp32blen = scale_expansion_zeroelim(bclen, bc, aeztail, temp32b); 03755 temp64alen = fast_expansion_sum_zeroelim(temp32alen, temp32a, 03756 temp32blen, temp32b, temp64a); 03757 temp32alen = scale_expansion_zeroelim(aclen, ac, -bez, temp32a); 03758 temp32blen = scale_expansion_zeroelim(aclen, ac, -beztail, temp32b); 03759 temp64blen = fast_expansion_sum_zeroelim(temp32alen, temp32a, 03760 temp32blen, temp32b, temp64b); 03761 temp32alen = scale_expansion_zeroelim(ablen, ab, cez, temp32a); 03762 temp32blen = scale_expansion_zeroelim(ablen, ab, ceztail, temp32b); 03763 temp64clen = fast_expansion_sum_zeroelim(temp32alen, temp32a, 03764 temp32blen, temp32b, temp64c); 03765 temp128len = fast_expansion_sum_zeroelim(temp64alen, temp64a, 03766 temp64blen, temp64b, temp128); 03767 temp192len = fast_expansion_sum_zeroelim(temp64clen, temp64c, 03768 temp128len, temp128, temp192); 03769 xlen = scale_expansion_zeroelim(temp192len, temp192, dex, detx); 03770 xxlen = scale_expansion_zeroelim(xlen, detx, dex, detxx); 03771 xtlen = scale_expansion_zeroelim(temp192len, temp192, dextail, detxt); 03772 xxtlen = scale_expansion_zeroelim(xtlen, detxt, dex, detxxt); 03773 for (i = 0; i < xxtlen; i++) { 03774 detxxt[i] *= 2.0; 03775 } 03776 xtxtlen = scale_expansion_zeroelim(xtlen, detxt, dextail, detxtxt); 03777 x1len = fast_expansion_sum_zeroelim(xxlen, detxx, xxtlen, detxxt, x1); 03778 x2len = fast_expansion_sum_zeroelim(x1len, x1, xtxtlen, detxtxt, x2); 03779 ylen = scale_expansion_zeroelim(temp192len, temp192, dey, dety); 03780 yylen = scale_expansion_zeroelim(ylen, dety, dey, detyy); 03781 ytlen = scale_expansion_zeroelim(temp192len, temp192, deytail, detyt); 03782 yytlen = scale_expansion_zeroelim(ytlen, detyt, dey, detyyt); 03783 for (i = 0; i < yytlen; i++) { 03784 detyyt[i] *= 2.0; 03785 } 03786 ytytlen = scale_expansion_zeroelim(ytlen, detyt, deytail, detytyt); 03787 y1len = fast_expansion_sum_zeroelim(yylen, detyy, yytlen, detyyt, y1); 03788 y2len = fast_expansion_sum_zeroelim(y1len, y1, ytytlen, detytyt, y2); 03789 zlen = scale_expansion_zeroelim(temp192len, temp192, dez, detz); 03790 zzlen = scale_expansion_zeroelim(zlen, detz, dez, detzz); 03791 ztlen = scale_expansion_zeroelim(temp192len, temp192, deztail, detzt); 03792 zztlen = scale_expansion_zeroelim(ztlen, detzt, dez, detzzt); 03793 for (i = 0; i < zztlen; i++) { 03794 detzzt[i] *= 2.0; 03795 } 03796 ztztlen = scale_expansion_zeroelim(ztlen, detzt, deztail, detztzt); 03797 z1len = fast_expansion_sum_zeroelim(zzlen, detzz, zztlen, detzzt, z1); 03798 z2len = fast_expansion_sum_zeroelim(z1len, z1, ztztlen, detztzt, z2); 03799 xylen = fast_expansion_sum_zeroelim(x2len, x2, y2len, y2, detxy); 03800 dlen = fast_expansion_sum_zeroelim(z2len, z2, xylen, detxy, ddet); 03801 03802 ablen = fast_expansion_sum_zeroelim(alen, adet, blen, bdet, abdet); 03803 cdlen = fast_expansion_sum_zeroelim(clen, cdet, dlen, ddet, cddet); 03804 deterlen = fast_expansion_sum_zeroelim(ablen, abdet, cdlen, cddet, deter); 03805 03806 return deter[deterlen - 1]; 03807 } 03808 03809 REAL insphereadapt(REAL *pa, REAL *pb, REAL *pc, REAL *pd, REAL *pe, REAL permanent) 03810 { 03811 INEXACT REAL aex, bex, cex, dex, aey, bey, cey, dey, aez, bez, cez, dez; 03812 REAL det, errbound; 03813 03814 INEXACT REAL aexbey1, bexaey1, bexcey1, cexbey1; 03815 INEXACT REAL cexdey1, dexcey1, dexaey1, aexdey1; 03816 INEXACT REAL aexcey1, cexaey1, bexdey1, dexbey1; 03817 REAL aexbey0, bexaey0, bexcey0, cexbey0; 03818 REAL cexdey0, dexcey0, dexaey0, aexdey0; 03819 REAL aexcey0, cexaey0, bexdey0, dexbey0; 03820 REAL ab[4], bc[4], cd[4], da[4], ac[4], bd[4]; 03821 INEXACT REAL ab3, bc3, cd3, da3, ac3, bd3; 03822 REAL abeps, bceps, cdeps, daeps, aceps, bdeps; 03823 REAL temp8a[8], temp8b[8], temp8c[8], temp16[16], temp24[24], temp48[48]; 03824 int temp8alen, temp8blen, temp8clen, temp16len, temp24len, temp48len; 03825 REAL xdet[96], ydet[96], zdet[96], xydet[192]; 03826 int xlen, ylen, zlen, xylen; 03827 REAL adet[288], bdet[288], cdet[288], ddet[288]; 03828 int alen, blen, clen, dlen; 03829 REAL abdet[576], cddet[576]; 03830 int ablen, cdlen; 03831 REAL fin1[1152]; 03832 int finlength; 03833 03834 REAL aextail, bextail, cextail, dextail; 03835 REAL aeytail, beytail, ceytail, deytail; 03836 REAL aeztail, beztail, ceztail, deztail; 03837 03838 INEXACT REAL bvirt; 03839 REAL avirt, bround, around; 03840 INEXACT REAL c; 03841 INEXACT REAL abig; 03842 REAL ahi, alo, bhi, blo; 03843 REAL err1, err2, err3; 03844 INEXACT REAL _i, _j; 03845 REAL _0; 03846 03847 aex = (REAL) (pa[0] - pe[0]); 03848 bex = (REAL) (pb[0] - pe[0]); 03849 cex = (REAL) (pc[0] - pe[0]); 03850 dex = (REAL) (pd[0] - pe[0]); 03851 aey = (REAL) (pa[1] - pe[1]); 03852 bey = (REAL) (pb[1] - pe[1]); 03853 cey = (REAL) (pc[1] - pe[1]); 03854 dey = (REAL) (pd[1] - pe[1]); 03855 aez = (REAL) (pa[2] - pe[2]); 03856 bez = (REAL) (pb[2] - pe[2]); 03857 cez = (REAL) (pc[2] - pe[2]); 03858 dez = (REAL) (pd[2] - pe[2]); 03859 03860 Two_Product(aex, bey, aexbey1, aexbey0); 03861 Two_Product(bex, aey, bexaey1, bexaey0); 03862 Two_Two_Diff(aexbey1, aexbey0, bexaey1, bexaey0, ab3, ab[2], ab[1], ab[0]); 03863 ab[3] = ab3; 03864 03865 Two_Product(bex, cey, bexcey1, bexcey0); 03866 Two_Product(cex, bey, cexbey1, cexbey0); 03867 Two_Two_Diff(bexcey1, bexcey0, cexbey1, cexbey0, bc3, bc[2], bc[1], bc[0]); 03868 bc[3] = bc3; 03869 03870 Two_Product(cex, dey, cexdey1, cexdey0); 03871 Two_Product(dex, cey, dexcey1, dexcey0); 03872 Two_Two_Diff(cexdey1, cexdey0, dexcey1, dexcey0, cd3, cd[2], cd[1], cd[0]); 03873 cd[3] = cd3; 03874 03875 Two_Product(dex, aey, dexaey1, dexaey0); 03876 Two_Product(aex, dey, aexdey1, aexdey0); 03877 Two_Two_Diff(dexaey1, dexaey0, aexdey1, aexdey0, da3, da[2], da[1], da[0]); 03878 da[3] = da3; 03879 03880 Two_Product(aex, cey, aexcey1, aexcey0); 03881 Two_Product(cex, aey, cexaey1, cexaey0); 03882 Two_Two_Diff(aexcey1, aexcey0, cexaey1, cexaey0, ac3, ac[2], ac[1], ac[0]); 03883 ac[3] = ac3; 03884 03885 Two_Product(bex, dey, bexdey1, bexdey0); 03886 Two_Product(dex, bey, dexbey1, dexbey0); 03887 Two_Two_Diff(bexdey1, bexdey0, dexbey1, dexbey0, bd3, bd[2], bd[1], bd[0]); 03888 bd[3] = bd3; 03889 03890 temp8alen = scale_expansion_zeroelim(4, cd, bez, temp8a); 03891 temp8blen = scale_expansion_zeroelim(4, bd, -cez, temp8b); 03892 temp8clen = scale_expansion_zeroelim(4, bc, dez, temp8c); 03893 temp16len = fast_expansion_sum_zeroelim(temp8alen, temp8a, 03894 temp8blen, temp8b, temp16); 03895 temp24len = fast_expansion_sum_zeroelim(temp8clen, temp8c, 03896 temp16len, temp16, temp24); 03897 temp48len = scale_expansion_zeroelim(temp24len, temp24, aex, temp48); 03898 xlen = scale_expansion_zeroelim(temp48len, temp48, -aex, xdet); 03899 temp48len = scale_expansion_zeroelim(temp24len, temp24, aey, temp48); 03900 ylen = scale_expansion_zeroelim(temp48len, temp48, -aey, ydet); 03901 temp48len = scale_expansion_zeroelim(temp24len, temp24, aez, temp48); 03902 zlen = scale_expansion_zeroelim(temp48len, temp48, -aez, zdet); 03903 xylen = fast_expansion_sum_zeroelim(xlen, xdet, ylen, ydet, xydet); 03904 alen = fast_expansion_sum_zeroelim(xylen, xydet, zlen, zdet, adet); 03905 03906 temp8alen = scale_expansion_zeroelim(4, da, cez, temp8a); 03907 temp8blen = scale_expansion_zeroelim(4, ac, dez, temp8b); 03908 temp8clen = scale_expansion_zeroelim(4, cd, aez, temp8c); 03909 temp16len = fast_expansion_sum_zeroelim(temp8alen, temp8a, 03910 temp8blen, temp8b, temp16); 03911 temp24len = fast_expansion_sum_zeroelim(temp8clen, temp8c, 03912 temp16len, temp16, temp24); 03913 temp48len = scale_expansion_zeroelim(temp24len, temp24, bex, temp48); 03914 xlen = scale_expansion_zeroelim(temp48len, temp48, bex, xdet); 03915 temp48len = scale_expansion_zeroelim(temp24len, temp24, bey, temp48); 03916 ylen = scale_expansion_zeroelim(temp48len, temp48, bey, ydet); 03917 temp48len = scale_expansion_zeroelim(temp24len, temp24, bez, temp48); 03918 zlen = scale_expansion_zeroelim(temp48len, temp48, bez, zdet); 03919 xylen = fast_expansion_sum_zeroelim(xlen, xdet, ylen, ydet, xydet); 03920 blen = fast_expansion_sum_zeroelim(xylen, xydet, zlen, zdet, bdet); 03921 03922 temp8alen = scale_expansion_zeroelim(4, ab, dez, temp8a); 03923 temp8blen = scale_expansion_zeroelim(4, bd, aez, temp8b); 03924 temp8clen = scale_expansion_zeroelim(4, da, bez, temp8c); 03925 temp16len = fast_expansion_sum_zeroelim(temp8alen, temp8a, 03926 temp8blen, temp8b, temp16); 03927 temp24len = fast_expansion_sum_zeroelim(temp8clen, temp8c, 03928 temp16len, temp16, temp24); 03929 temp48len = scale_expansion_zeroelim(temp24len, temp24, cex, temp48); 03930 xlen = scale_expansion_zeroelim(temp48len, temp48, -cex, xdet); 03931 temp48len = scale_expansion_zeroelim(temp24len, temp24, cey, temp48); 03932 ylen = scale_expansion_zeroelim(temp48len, temp48, -cey, ydet); 03933 temp48len = scale_expansion_zeroelim(temp24len, temp24, cez, temp48); 03934 zlen = scale_expansion_zeroelim(temp48len, temp48, -cez, zdet); 03935 xylen = fast_expansion_sum_zeroelim(xlen, xdet, ylen, ydet, xydet); 03936 clen = fast_expansion_sum_zeroelim(xylen, xydet, zlen, zdet, cdet); 03937 03938 temp8alen = scale_expansion_zeroelim(4, bc, aez, temp8a); 03939 temp8blen = scale_expansion_zeroelim(4, ac, -bez, temp8b); 03940 temp8clen = scale_expansion_zeroelim(4, ab, cez, temp8c); 03941 temp16len = fast_expansion_sum_zeroelim(temp8alen, temp8a, 03942 temp8blen, temp8b, temp16); 03943 temp24len = fast_expansion_sum_zeroelim(temp8clen, temp8c, 03944 temp16len, temp16, temp24); 03945 temp48len = scale_expansion_zeroelim(temp24len, temp24, dex, temp48); 03946 xlen = scale_expansion_zeroelim(temp48len, temp48, dex, xdet); 03947 temp48len = scale_expansion_zeroelim(temp24len, temp24, dey, temp48); 03948 ylen = scale_expansion_zeroelim(temp48len, temp48, dey, ydet); 03949 temp48len = scale_expansion_zeroelim(temp24len, temp24, dez, temp48); 03950 zlen = scale_expansion_zeroelim(temp48len, temp48, dez, zdet); 03951 xylen = fast_expansion_sum_zeroelim(xlen, xdet, ylen, ydet, xydet); 03952 dlen = fast_expansion_sum_zeroelim(xylen, xydet, zlen, zdet, ddet); 03953 03954 ablen = fast_expansion_sum_zeroelim(alen, adet, blen, bdet, abdet); 03955 cdlen = fast_expansion_sum_zeroelim(clen, cdet, dlen, ddet, cddet); 03956 finlength = fast_expansion_sum_zeroelim(ablen, abdet, cdlen, cddet, fin1); 03957 03958 det = estimate(finlength, fin1); 03959 errbound = isperrboundB * permanent; 03960 if ((det >= errbound) || (-det >= errbound)) { 03961 return det; 03962 } 03963 03964 Two_Diff_Tail(pa[0], pe[0], aex, aextail); 03965 Two_Diff_Tail(pa[1], pe[1], aey, aeytail); 03966 Two_Diff_Tail(pa[2], pe[2], aez, aeztail); 03967 Two_Diff_Tail(pb[0], pe[0], bex, bextail); 03968 Two_Diff_Tail(pb[1], pe[1], bey, beytail); 03969 Two_Diff_Tail(pb[2], pe[2], bez, beztail); 03970 Two_Diff_Tail(pc[0], pe[0], cex, cextail); 03971 Two_Diff_Tail(pc[1], pe[1], cey, ceytail); 03972 Two_Diff_Tail(pc[2], pe[2], cez, ceztail); 03973 Two_Diff_Tail(pd[0], pe[0], dex, dextail); 03974 Two_Diff_Tail(pd[1], pe[1], dey, deytail); 03975 Two_Diff_Tail(pd[2], pe[2], dez, deztail); 03976 if ((aextail == 0.0) && (aeytail == 0.0) && (aeztail == 0.0) 03977 && (bextail == 0.0) && (beytail == 0.0) && (beztail == 0.0) 03978 && (cextail == 0.0) && (ceytail == 0.0) && (ceztail == 0.0) 03979 && (dextail == 0.0) && (deytail == 0.0) && (deztail == 0.0)) { 03980 return det; 03981 } 03982 03983 errbound = isperrboundC * permanent + resulterrbound * Absolute(det); 03984 abeps = (aex * beytail + bey * aextail) 03985 - (aey * bextail + bex * aeytail); 03986 bceps = (bex * ceytail + cey * bextail) 03987 - (bey * cextail + cex * beytail); 03988 cdeps = (cex * deytail + dey * cextail) 03989 - (cey * dextail + dex * ceytail); 03990 daeps = (dex * aeytail + aey * dextail) 03991 - (dey * aextail + aex * deytail); 03992 aceps = (aex * ceytail + cey * aextail) 03993 - (aey * cextail + cex * aeytail); 03994 bdeps = (bex * deytail + dey * bextail) 03995 - (bey * dextail + dex * beytail); 03996 det += (((bex * bex + bey * bey + bez * bez) 03997 * ((cez * daeps + dez * aceps + aez * cdeps) 03998 + (ceztail * da3 + deztail * ac3 + aeztail * cd3)) 03999 + (dex * dex + dey * dey + dez * dez) 04000 * ((aez * bceps - bez * aceps + cez * abeps) 04001 + (aeztail * bc3 - beztail * ac3 + ceztail * ab3))) 04002 - ((aex * aex + aey * aey + aez * aez) 04003 * ((bez * cdeps - cez * bdeps + dez * bceps) 04004 + (beztail * cd3 - ceztail * bd3 + deztail * bc3)) 04005 + (cex * cex + cey * cey + cez * cez) 04006 * ((dez * abeps + aez * bdeps + bez * daeps) 04007 + (deztail * ab3 + aeztail * bd3 + beztail * da3)))) 04008 + 2.0 * (((bex * bextail + bey * beytail + bez * beztail) 04009 * (cez * da3 + dez * ac3 + aez * cd3) 04010 + (dex * dextail + dey * deytail + dez * deztail) 04011 * (aez * bc3 - bez * ac3 + cez * ab3)) 04012 - ((aex * aextail + aey * aeytail + aez * aeztail) 04013 * (bez * cd3 - cez * bd3 + dez * bc3) 04014 + (cex * cextail + cey * ceytail + cez * ceztail) 04015 * (dez * ab3 + aez * bd3 + bez * da3))); 04016 if ((det >= errbound) || (-det >= errbound)) { 04017 return det; 04018 } 04019 04020 return insphereexact(pa, pb, pc, pd, pe); 04021 } 04022 04023 REAL insphere(REAL *pa, REAL *pb, REAL *pc, REAL *pd, REAL *pe) 04024 { 04025 REAL aex, bex, cex, dex; 04026 REAL aey, bey, cey, dey; 04027 REAL aez, bez, cez, dez; 04028 REAL aexbey, bexaey, bexcey, cexbey, cexdey, dexcey, dexaey, aexdey; 04029 REAL aexcey, cexaey, bexdey, dexbey; 04030 REAL alift, blift, clift, dlift; 04031 REAL ab, bc, cd, da, ac, bd; 04032 REAL abc, bcd, cda, dab; 04033 REAL aezplus, bezplus, cezplus, dezplus; 04034 REAL aexbeyplus, bexaeyplus, bexceyplus, cexbeyplus; 04035 REAL cexdeyplus, dexceyplus, dexaeyplus, aexdeyplus; 04036 REAL aexceyplus, cexaeyplus, bexdeyplus, dexbeyplus; 04037 REAL det; 04038 REAL permanent, errbound; 04039 04040 aex = pa[0] - pe[0]; 04041 bex = pb[0] - pe[0]; 04042 cex = pc[0] - pe[0]; 04043 dex = pd[0] - pe[0]; 04044 aey = pa[1] - pe[1]; 04045 bey = pb[1] - pe[1]; 04046 cey = pc[1] - pe[1]; 04047 dey = pd[1] - pe[1]; 04048 aez = pa[2] - pe[2]; 04049 bez = pb[2] - pe[2]; 04050 cez = pc[2] - pe[2]; 04051 dez = pd[2] - pe[2]; 04052 04053 aexbey = aex * bey; 04054 bexaey = bex * aey; 04055 ab = aexbey - bexaey; 04056 bexcey = bex * cey; 04057 cexbey = cex * bey; 04058 bc = bexcey - cexbey; 04059 cexdey = cex * dey; 04060 dexcey = dex * cey; 04061 cd = cexdey - dexcey; 04062 dexaey = dex * aey; 04063 aexdey = aex * dey; 04064 da = dexaey - aexdey; 04065 04066 aexcey = aex * cey; 04067 cexaey = cex * aey; 04068 ac = aexcey - cexaey; 04069 bexdey = bex * dey; 04070 dexbey = dex * bey; 04071 bd = bexdey - dexbey; 04072 04073 abc = aez * bc - bez * ac + cez * ab; 04074 bcd = bez * cd - cez * bd + dez * bc; 04075 cda = cez * da + dez * ac + aez * cd; 04076 dab = dez * ab + aez * bd + bez * da; 04077 04078 alift = aex * aex + aey * aey + aez * aez; 04079 blift = bex * bex + bey * bey + bez * bez; 04080 clift = cex * cex + cey * cey + cez * cez; 04081 dlift = dex * dex + dey * dey + dez * dez; 04082 04083 det = (dlift * abc - clift * dab) + (blift * cda - alift * bcd); 04084 04085 aezplus = Absolute(aez); 04086 bezplus = Absolute(bez); 04087 cezplus = Absolute(cez); 04088 dezplus = Absolute(dez); 04089 aexbeyplus = Absolute(aexbey); 04090 bexaeyplus = Absolute(bexaey); 04091 bexceyplus = Absolute(bexcey); 04092 cexbeyplus = Absolute(cexbey); 04093 cexdeyplus = Absolute(cexdey); 04094 dexceyplus = Absolute(dexcey); 04095 dexaeyplus = Absolute(dexaey); 04096 aexdeyplus = Absolute(aexdey); 04097 aexceyplus = Absolute(aexcey); 04098 cexaeyplus = Absolute(cexaey); 04099 bexdeyplus = Absolute(bexdey); 04100 dexbeyplus = Absolute(dexbey); 04101 permanent = ((cexdeyplus + dexceyplus) * bezplus 04102 + (dexbeyplus + bexdeyplus) * cezplus 04103 + (bexceyplus + cexbeyplus) * dezplus) 04104 * alift 04105 + ((dexaeyplus + aexdeyplus) * cezplus 04106 + (aexceyplus + cexaeyplus) * dezplus 04107 + (cexdeyplus + dexceyplus) * aezplus) 04108 * blift 04109 + ((aexbeyplus + bexaeyplus) * dezplus 04110 + (bexdeyplus + dexbeyplus) * aezplus 04111 + (dexaeyplus + aexdeyplus) * bezplus) 04112 * clift 04113 + ((bexceyplus + cexbeyplus) * aezplus 04114 + (cexaeyplus + aexceyplus) * bezplus 04115 + (aexbeyplus + bexaeyplus) * cezplus) 04116 * dlift; 04117 errbound = isperrboundA * permanent; 04118 if ((det > errbound) || (-det > errbound)) { 04119 return det; 04120 } 04121 04122 return insphereadapt(pa, pb, pc, pd, pe, permanent); 04123 } 04124 }//end namespace QM 04125
