MeshKit
1.0
00001 #include <iostream> 00002 #include "std.h" 00003 #include "Heap.hpp" 00004 #include <string.h> /* for memcpy */ 00005 00006 00007 void Heap::swap(int i,int j) 00008 { 00009 heap_node tmp = ref(i); 00010 00011 ref(i) = ref(j); 00012 ref(j) = tmp; 00013 00014 ref(i).obj->setHeapPos(i); 00015 ref(j).obj->setHeapPos(j); 00016 } 00017 00018 void Heap::upheap(int i) 00019 { 00020 if( i==0 ) return; 00021 00022 if( ref(i).import > ref(parent(i)).import ) { 00023 swap(i,parent(i)); 00024 upheap(parent(i)); 00025 } 00026 } 00027 00028 void Heap::downheap(int i) 00029 { 00030 if (i>=size) return; // perhaps just extracted the last 00031 00032 int largest = i, 00033 l = left(i), 00034 r = right(i); 00035 00036 if( l<size && ref(l).import > ref(largest).import ) largest = l; 00037 if( r<size && ref(r).import > ref(largest).import ) largest = r; 00038 00039 if( largest != i ) { 00040 swap(i,largest); 00041 downheap(largest); 00042 } 00043 } 00044 00045 00046 00047 void Heap::insert(Heapable *t,double v) 00048 { 00049 if( size == maxLength() ) 00050 { 00051 std::cerr << "NOTE: Growing heap from " << size << " to " << 2*size << std::endl; 00052 resize(2*size); 00053 } 00054 00055 int i = size++; 00056 00057 ref(i).obj = t; 00058 ref(i).import = v; 00059 00060 ref(i).obj->setHeapPos(i); 00061 00062 upheap(i); 00063 } 00064 00065 void Heap::update(Heapable *t,double v) 00066 { 00067 int i = t->getHeapPos(); 00068 00069 if( i >= size ) 00070 { 00071 std::cerr << "WARNING: Attempting to update past end of heap!" << std::endl; 00072 return; 00073 } 00074 else if( i == NOT_IN_HEAP ) 00075 { 00076 std::cerr << "WARNING: Attempting to update object not in heap!" << std::endl; 00077 return; 00078 } 00079 00080 float old=ref(i).import; 00081 ref(i).import = v; 00082 00083 if( v<old ) 00084 downheap(i); 00085 else 00086 upheap(i); 00087 } 00088 00089 00090 00091 heap_node *Heap::extract() 00092 { 00093 if( size<1 ) return 0; 00094 00095 swap(0,size-1); 00096 size--; 00097 00098 downheap(0); 00099 00100 ref(size).obj->notInHeap(); 00101 00102 return &ref(size); 00103 } 00104 00105 heap_node *Heap::kill(int i) 00106 { 00107 if( i>=size ) 00108 std::cerr << "WARNING: Attempt to delete invalid heap node." << std::endl; 00109 00110 swap(i, size-1); 00111 size--; 00112 ref(size).obj->notInHeap(); 00113 00114 if( ref(i).import < ref(size).import ) 00115 downheap(i); 00116 else 00117 upheap(i); 00118 00119 00120 return &ref(size); 00121 }
