MeshKit
1.0
00001 // IAIntParabolaNlp.hpp 00002 // Interval Assignment for Meshkit 00003 // 00004 // use a cosine-"wave" function as a constraint, so that the only feasible solutions are integer 00005 // use a cosine-"wave" with twice the period to enforce the evenality constraints 00006 00007 #ifndef MESHKIT_IA_IAINTPARABOLANLP_HP 00008 #define MESHKIT_IA_IAINTPARABOLANLP_HP 00009 00010 #include "meshkit/IAIntWaveNlp.hpp" 00011 00012 #include <math.h> 00013 #include <limits.h> 00014 00015 namespace MeshKit 00016 { 00017 00018 class IAIntParabolaNlp : public IAIntWaveNlp 00019 { 00020 // first set of functions required by TNLP 00021 public: 00023 IAIntParabolaNlp(const IAData *data_ptr, const IPData *ip_data_ptr, IASolution *solution_ptr, 00024 const bool set_silent = true) : 00025 IAIntWaveNlp(data_ptr, ip_data_ptr, solution_ptr, set_silent) 00026 {} 00027 00029 virtual ~IAIntParabolaNlp() {} 00030 00031 protected: 00032 00033 // nearest integer 00034 const double nearest_int( const double x ) 00035 { 00036 const double xm = floor(x); 00037 const double xp = ceil(x); 00038 return (fabs(xm - x) < fabs(xp - x)) ? xm : xp; 00039 } 00040 const double nearest_even( const double s ) 00041 { 00042 return 2. * nearest_int( s / 2. ); 00043 } 00044 const double delta_x( const double x ) 00045 { 00046 return x - nearest_int(x); 00047 } 00048 const double delta_s( const double s ) 00049 { 00050 return s - nearest_even(s); 00051 } 00052 00053 virtual double eval_g_int_x( const double x ) 00054 { 00055 const double d = delta_x(x); 00056 return 1. - d * d; 00057 } 00058 virtual double eval_g_int_s( const double s ) 00059 { 00060 const double d = delta_s(s); 00061 return 1. - d * d; 00062 } 00063 virtual double eval_jac_int_x( const double x ) 00064 { 00065 const double d = delta_x( x ); 00066 return -2. * d; // d' is 1 00067 } 00068 virtual double eval_jac_int_s( const double s ) 00069 { 00070 double d = delta_s(s); 00071 return -2. * d; // d' is 1 00072 } 00073 virtual double eval_hess_int_x( const double x ) 00074 { 00075 return -2.; 00076 } 00077 virtual double eval_hess_int_s( const double s ) 00078 { 00079 return -2.; 00080 } 00081 00082 }; 00083 00084 00085 } // namespace MeshKit 00086 00087 #endif
