MeshKit
1.0
00001 // IAIntWaveNlp.hpp 00002 // Interval Assignment for Meshkit 00003 // 00004 // ipopt mixed-integer solution 00005 // The idea is the optimal solution will be an integer one, if one exists 00006 // Define some region around the relaxed solution and search for an integer solution 00007 // 00008 // use some non-linear function as a constraint, so that the only feasible solutions are integer 00009 00010 #ifndef MESHKIT_IA_IAINTHESSNLP_HP 00011 #define MESHKIT_IA_IAINTHESSNLP_HP 00012 00013 #include "meshkit/IANlp.hpp" 00014 00015 // from Ipopt 00016 #include "IpTNLP.hpp" 00017 00018 #include <vector> 00019 #include <map> 00020 00021 namespace MeshKit 00022 { 00023 00024 class IAData; 00025 class IPData; 00026 class IASolution; 00027 00028 class IAIntWaveNlp : public TNLP 00029 { 00030 // first set of functions required by TNLP 00031 public: 00033 IAIntWaveNlp(const IAData *data_ptr, const IPData *ip_data_ptr, IASolution *solution_ptr, 00034 const bool set_silent = true); 00035 00037 virtual ~IAIntWaveNlp(); 00038 00042 virtual bool get_nlp_info(Index& n, Index& m, Index& nnz_jac_g, 00043 Index& nnz_h_lag, IndexStyleEnum& index_style); 00044 00046 virtual bool get_bounds_info(Index n, Number* x_l, Number* x_u, 00047 Index m, Number* g_l, Number* g_u); 00048 00050 virtual bool get_starting_point(Index n, bool init_x, Number* x_init, 00051 bool init_z, Number* z_L, Number* z_U, 00052 Index m, bool init_lambda, 00053 Number* lambda); 00054 00056 virtual bool eval_f(Index n, const Number* x, bool new_x, Number& obj_value); 00057 00059 virtual bool eval_grad_f(Index n, const Number* x, bool new_x, Number* grad_f); 00060 00062 virtual bool eval_g(Index n, const Number* x, bool new_x, Index m, Number* g); 00063 00068 virtual bool eval_jac_g(Index n, const Number* x, bool new_x, 00069 Index m, Index nele_jac, Index* iRow, Index *jCol, 00070 Number* values); 00071 00076 virtual bool eval_h(Index n, const Number* x, bool new_x, 00077 Number obj_factor, Index m, const Number* lambda, 00078 bool new_lambda, Index nele_hess, Index* iRow, 00079 Index* jCol, Number* values); 00080 00082 00086 virtual void finalize_solution(SolverReturn status, 00087 Index n, const Number* x, const Number* z_L, const Number* z_U, 00088 Index m, const Number* g, const Number* lambda, 00089 Number obj_value, 00090 const IpoptData* ip_data, 00091 IpoptCalculatedQuantities* ip_cq); 00093 00094 // extra stuff not required by TNLP 00095 00096 private: 00097 // hide untrusted default methods 00099 // IA_NLP(); 00100 IAIntWaveNlp(); 00101 IAIntWaveNlp(const IAIntWaveNlp&); 00102 IAIntWaveNlp& operator=(const IAIntWaveNlp&); 00104 00105 protected: 00106 // input data 00107 const IAData *data; 00108 const IPData *ipData; 00109 00110 // solution data 00111 IASolution *solution; 00112 00113 00114 // implemented using an overlay over an IANlp 00115 IANlp baseNlp; 00116 00117 const int base_n, base_m; 00118 const int problem_n, problem_m; 00119 const int wave_even_constraint_start; 00120 const int wave_int_constraint_start; 00121 00122 double f_x_value( double I_i, double x_i ); 00123 00124 const bool silent; 00125 const bool debugging; 00126 const bool verbose; // verbose debugging 00127 00128 struct SparseMatrixEntry 00129 { 00130 // position in matrix 00131 // column must be less than row, j <= i 00132 int i; // row 00133 int j; // col 00134 00135 // order in sequence for hessian values array, etc. 00136 int k; 00137 00138 static int n; // matrix is n x n 00139 int key() const { return i * n + j; } 00140 00141 SparseMatrixEntry(const int iset, const int jset, const int kset); 00142 SparseMatrixEntry() : i(-1), j(-1), k(-1) {} // bad values if unspecified 00143 }; 00144 00145 typedef std::map<int, SparseMatrixEntry> SparseMatrixMap; 00146 00147 SparseMatrixMap hessian_map; // sorted by key 00148 std::vector< SparseMatrixEntry > hessian_vector; // from 0..k 00149 00150 void add_hessian_entry( int i, int j, int &k ); 00151 void build_hessian(); 00152 int get_hessian_k( int i, int j ); 00153 void print_hessian(); // debug 00154 00155 // derived classes must define these 00156 // the first two should have a max of 1 for integer/even values, and be less than that elsewhere 00157 virtual double eval_g_int_x( const double x ) = 0; 00158 virtual double eval_g_int_s( const double s ) = 0; 00159 virtual double eval_jac_int_x( const double x ) = 0; 00160 virtual double eval_jac_int_s( const double s ) = 0; 00161 virtual double eval_hess_int_x( const double x ) = 0; 00162 virtual double eval_hess_int_s( const double s ) = 0; 00163 00164 }; 00165 00166 } // namespace MeshKit 00167 00168 #endif
