MeshKit
1.0
00001 // IAMINlp.cpp 00002 // Interval Assignment for Meshkit 00003 // 00004 // Adapted from 00005 // Copyright (C) 2005, 2006 International Business Machines and others. 00006 // All Rights Reserved. 00007 // This code is published under the Eclipse Public License. 00008 // 00009 // $Id: hs071_nlp.cpp 1864 2010-12-22 19:21:02Z andreasw $ 00010 // 00011 // Authors: Carl Laird, Andreas Waechter IBM 2005-08-16 00012 00013 #include "meshkit/IAMINlp.hpp" 00014 #include "meshkit/IAData.hpp" 00015 #include "meshkit/IPData.hpp" 00016 #include "meshkit/IASolution.hpp" 00017 #include "meshkit/IANlp.hpp" 00018 00019 #include <math.h> 00020 00021 // for printf 00022 #ifdef HAVE_CSTDIO 00023 # include <cstdio> 00024 #else 00025 # ifdef HAVE_STDIO_H 00026 # include <stdio.h> 00027 # else 00028 # error "don't have header file for stdio" 00029 # endif 00030 #endif 00031 00032 namespace MeshKit 00033 { 00034 00035 double p_norm = 3; // remove this, we use linear objectives here 00036 00037 // constructor 00038 IAMINlp::IAMINlp(const IAData *data_ptr, const IPData *ip_data_ptr, IASolution *solution_ptr): 00039 data(data_ptr), ip_data(ip_data_ptr), solution(solution_ptr), 00040 debugging(true), verbose(true) // true 00041 { 00042 00043 printf("\nIAMINlp Problem size:\n"); 00044 printf(" number of variables: %lu\n", data->I.size()); 00045 printf(" number of constraints: %lu\n\n", data->constraints.size()); 00046 } 00047 00048 00049 // n = number of variables 00050 // m = number of constraints (not counting variable bounds) 00051 00052 // apparent Meshkit style conventions: 00053 // ClassFileName 00054 // ClassName 00055 // #ifndef MESHKIT_CLASSNAME_HPP 00056 // #define MESHKIT_CLASSNAME_HPP 00057 // namespace IAMeshKit 00058 // public class_member_function() 00059 // protected classMemberData 00060 00061 IAMINlp::~IAMINlp() {data = NULL;} 00062 00063 // returns the size of the problem 00064 bool IAMINlp::get_nlp_info(Index& n, Index& m, Index& nnz_jac_g, 00065 Index& nnz_h_lag, IndexStyleEnum& index_style) 00066 { 00067 // printf("A "); 00068 // number of variables 00069 n = data->num_variables(); 00070 00071 // number of constraints 00072 m = (int) data->constraints.size() + (int) data->sumEvenConstraints.size(); 00073 00074 // number of non-zeroes in the Jacobian of the constraints 00075 size_t num_entries=0; 00076 for (std::vector<IAData::constraintRow>::const_iterator i=data->constraints.begin(); i != data->constraints.end(); ++i) 00077 { 00078 num_entries += i->M.size(); 00079 } 00080 for (std::vector<IAData::sumEvenConstraintRow>::const_iterator i=data->sumEvenConstraints.begin(); i != data->sumEvenConstraints.end(); ++i) 00081 { 00082 num_entries += i->M.size(); 00083 } 00084 nnz_jac_g = (int) num_entries; 00085 00086 // number of non-zeroes in the Hessian 00087 // diagonal entries for the objective function + 00088 // none for the constraints, since they are all linear 00089 nnz_h_lag = data->num_variables(); 00090 00091 // C style indexing (0-based) 00092 index_style = TNLP::C_STYLE; 00093 00094 return true; 00095 } 00096 00097 // returns the variable bounds 00098 bool IAMINlp::get_bounds_info(Index n, Number* x_l, Number* x_u, 00099 Index m, Number* g_l, Number* g_u) 00100 { 00101 //printf("B "); 00102 00103 // The n and m we gave IPOPT in get_nlp_info are passed back to us. 00104 assert(n == data->num_variables()); 00105 assert(m == (int)(data->constraints.size() + data->sumEvenConstraints.size())); 00106 00107 // future interval upper and lower bounds: 00108 // for midpoint subdivision, the lower bound may be 2 instead 00109 // User may specify different bounds for some intervals 00110 // Implement this by having another vector of lower bounds and one of upper bounds 00111 00112 // relaxed problem 00113 if (ip_data->varIntegerBound.size() == 0) 00114 { 00115 // variables have lower bounds of 1 and no upper bounds 00116 for (Index i=0; i<n; ++i) 00117 { 00118 x_l[i] = 1.0; 00119 x_u[i] = MESHKIT_IA_upperUnbound; 00120 } 00121 } 00122 else 00123 { 00124 for (Index i=0; i<n; ++i) 00125 { 00126 const double b = ip_data->varIntegerBound[i]; 00127 if (b == 0) // unconstrained so far 00128 { 00129 x_l[i] = 1.0; 00130 x_u[i] = MESHKIT_IA_upperUnbound; 00131 } 00132 else 00133 { 00134 // b is a lower bound if it is bigger than the goal 00135 if (b > data->I[i]) 00136 { 00137 x_l[i] = b; 00138 x_u[i] = MESHKIT_IA_upperUnbound; 00139 } 00140 // otherwise b is an upper bound 00141 else 00142 { 00143 x_l[i] = 1.0; 00144 x_u[i] = b; 00145 } 00146 } 00147 } 00148 } 00149 00150 // constraint bounds 00151 for (unsigned int i = 0; i<data->constraints.size(); ++i) 00152 { 00153 g_l[i] = data->constraints[i].lowerBound; 00154 g_u[i] = data->constraints[i].upperBound; 00155 } 00156 for (unsigned int i = 0; i<data->sumEvenConstraints.size(); ++i) 00157 { 00158 const int j = i + (int) data->constraints.size(); 00159 g_l[j] = 4; 00160 g_u[j] = MESHKIT_IA_upperUnbound; 00161 } 00162 00163 //printf("b "); 00164 return true; //means what? 00165 } 00166 00167 // returns the initial point for the problem 00168 bool IAMINlp::get_starting_point(Index n, bool init_x, Number* x_init, 00169 bool init_z, Number* z_L, Number* z_U, 00170 Index m, bool init_lambda, 00171 Number* lambda) 00172 { 00173 //printf("C "); 00174 00175 // Minimal info is starting values for x, x_init 00176 // Improvement: we can provide starting values for the dual variables if we wish 00177 assert(init_x == true); 00178 assert(init_z == false); 00179 assert(init_lambda == false); 00180 00181 assert(n==(int)data->I.size()); 00182 assert(data->num_variables()==(int)data->I.size()); 00183 00184 // initialize x to the goals 00185 if (ip_data->varIntegerBound.size() == 0) 00186 for (unsigned int i = 0; i<data->I.size(); ++i) 00187 { 00188 x_init[i]=data->I[i]; 00189 } 00190 // initialize x to the prior solution 00191 else 00192 for (unsigned int i = 0; i<data->I.size(); ++i) 00193 { 00194 // todo: test if we need to modify this for x violating the variable bounds? 00195 x_init[i]= solution->x_solution[i]; 00196 } 00197 00198 return true; 00199 } 00200 00201 00202 // r 00203 inline Number IAMINlp::eval_r_i(const Number& I_i, const Number& x_i) 00204 { 00205 //return x_i / I_i + I_i / x_i; 00206 return x_i > I_i ? 00207 (x_i - I_i) / I_i : 00208 (I_i - x_i) / x_i; 00209 } 00210 00211 inline Number IAMINlp::eval_grad_r_i(const Number& I_i, const Number& x_i) 00212 { 00213 // return (1.0 / I_i) - I_i / (x_i * x_i); 00214 return x_i > I_i ? 00215 1. / I_i : 00216 -I_i / (x_i * x_i); 00217 } 00218 00219 inline Number IAMINlp::eval_hess_r_i(const Number& I_i, const Number& x_i) 00220 { 00221 // return 2.0 * I_i / (x_i * x_i * x_i); 00222 return x_i > I_i ? 00223 0 : 00224 2 * I_i / (x_i * x_i * x_i); 00225 } 00226 00227 inline Number IAMINlp::eval_R_i(const Number& I_i, const Number& x_i) 00228 { 00229 if (x_i <= 0.) 00230 return MESHKIT_IA_upperUnbound; 00231 00232 // old function, sum 00233 // return 2. + ( x_i / I_i ) * ( x_i / I_i ) + ( I_i / x_i ) * ( I_i / x_i ); 00234 // const register double r = (x_i - I_i) / I_i; 00235 // const register double r2 = r*r; 00236 // return 2. + r2 + 1./r2; 00237 00238 return pow( eval_r_i(I_i,x_i), p_norm ); 00239 } 00240 00241 00242 inline Number IAMINlp::eval_grad_R_i(const Number& I_i, const Number& x_i) 00243 { 00244 if (x_i <= 0.) 00245 return MESHKIT_IA_lowerUnbound; 00246 00247 return p_norm * pow( eval_r_i(I_i,x_i), p_norm-1) * eval_grad_r_i(I_i, x_i); 00248 } 00249 00250 inline Number IAMINlp::eval_hess_R_i(const Number& I_i, const Number& x_i) 00251 { 00252 if (x_i <= 0.) 00253 return MESHKIT_IA_upperUnbound; 00254 00255 // old function, sum 00256 // const register double I2 = I_i * I_i; 00257 // return 2. * ( 1. / I2 + 3. * I2 / (x_i * x_i * x_i * x_i) ); 00258 00259 if (p_norm == 2) 00260 return (x_i > I_i) ? 2 / (I_i * I_i) : ( I_i / (x_i * x_i * x_i) ) * ( 6. * I_i / x_i - 4. ); 00261 00262 if (x_i > I_i ) 00263 return p_norm * (p_norm - 1) * pow( (x_i - I_i) / I_i, p_norm -2) / (I_i * I_i); 00264 00265 // p (p-1) (I/x-1)^(p-2) I^2 / x^4 + p (I/x-1)^(p-1) 2 I / x^3 00266 const register double f = (I_i - x_i) / x_i; 00267 const register double fp2 = pow( f, p_norm - 2); 00268 const register double x3 = x_i * x_i * x_i; 00269 return p_norm * ( (p_norm - 1) * fp2 * I_i * I_i / ( x3 * x_i ) + f * fp2 * 2. * I_i / x3 ); 00270 00271 } 00272 00273 // s 00274 inline Number IAMINlp::eval_s_i(const Number& I_i, const Number& x_i) 00275 { 00276 return eval_r_i(x_i, I_i) * x_i; 00277 } 00278 00279 inline Number IAMINlp::eval_grad_s_i(const Number& I_i, const Number& x_i) 00280 { 00281 return eval_r_i(x_i, I_i) + x_i * eval_grad_r_i(I_i, x_i); 00282 } 00283 00284 inline Number IAMINlp::eval_hess_s_i(const Number& I_i, const Number& x_i) 00285 { 00286 return 2. * eval_grad_r_i(I_i, x_i) + x_i * eval_hess_r_i(I_i, x_i); 00287 } 00288 00289 inline Number IAMINlp::eval_S_i(const Number& I_i, const Number& x_i) 00290 { 00291 if (x_i <= 0.) 00292 return MESHKIT_IA_upperUnbound; 00293 const double s = eval_s_i(I_i,x_i); 00294 00295 if (p_norm == 1) 00296 return s; 00297 00298 if (p_norm == 2) 00299 return s*s; 00300 00301 assert(p_norm > 2); 00302 return pow(s, p_norm ); 00303 } 00304 00305 00306 inline Number IAMINlp::eval_grad_S_i(const Number& I_i, const Number& x_i) 00307 { 00308 if (x_i <= 0.) 00309 return MESHKIT_IA_lowerUnbound; 00310 00311 const double s = eval_s_i(I_i,x_i); 00312 const double sp = eval_grad_s_i(I_i, x_i); 00313 00314 if (p_norm == 1) 00315 return s; 00316 00317 assert(p_norm>1); 00318 if (p_norm == 2) 00319 return 2. * s * sp; 00320 00321 assert(p_norm > 2); 00322 return p_norm * pow( s, p_norm-1) * sp; 00323 } 00324 00325 inline Number IAMINlp::eval_hess_S_i(const Number& I_i, const Number& x_i) 00326 { 00327 if (x_i <= 0.) 00328 return MESHKIT_IA_upperUnbound; 00329 00330 const double spp = eval_hess_s_i(I_i, x_i); 00331 00332 if (p_norm == 1) 00333 return spp; 00334 00335 const double s = eval_s_i(I_i, x_i); 00336 const double sp = eval_grad_s_i(I_i, x_i); 00337 00338 if (p_norm==2) 00339 return 2. * ( sp * sp + s * spp ); 00340 00341 assert(p_norm>2); 00342 return p_norm * pow(s, p_norm - 2) * ( (p_norm - 1) * sp * sp + s * spp ); 00343 } 00344 00345 00346 // experimental results: 00347 // best so far is f=R and p_norm = 3 00348 // f=s doesn't work well for x < I, as it tends to push the x to 1 so the weight is small ! 00349 00350 // returns the value of the objective function 00351 bool IAMINlp::eval_f(Index n, const Number* x, bool new_x, Number& obj_value) 00352 { 00353 //printf("D "); 00354 00355 assert(n == data->num_variables()); 00356 00357 // future: perhaps try max of the f, infinity norm 00358 00359 double obj = 0.; 00360 for (Index i = 0; i<n; ++i) 00361 { 00362 obj += eval_R_i( data->I[i], x[i] ); 00363 } 00364 00365 obj_value = obj; 00366 00367 return true; 00368 } 00369 00370 // return the gradient of the objective function grad_{x} f(x) 00371 bool IAMINlp::eval_grad_f(Index n, const Number* x, bool new_x, Number* grad_f) 00372 { 00373 //printf("E "); 00374 00375 assert(n == data->num_variables()); 00376 00377 for (Index i = 0; i<n; ++i) 00378 { 00379 grad_f[i] = eval_grad_R_i( data->I[i], x[i] ); 00380 } 00381 00382 return true; 00383 } 00384 00385 // return the value of the constraints: g(x) 00386 bool IAMINlp::eval_g(Index n, const Number* x, bool new_x, Index m, Number* g) 00387 { 00388 //printf("F "); 00389 00390 assert(n == data->num_variables()); 00391 assert(m == (int)(data->constraints.size() + data->sumEvenConstraints.size())); 00392 00393 00394 for (Index i = 0; i<(int)data->constraints.size(); ++i) 00395 { 00396 //double g_i = constraints[i].rhs; 00397 double g_i = 0.; 00398 for (Index j = 0; j < (int)data->constraints[i].M.size(); ++j) 00399 { 00400 g_i += x[ data->constraints[i].M[j].col ] * data->constraints[i].M[j].val; 00401 } 00402 g[i] = g_i; 00403 } 00404 for (Index i = 0; i<(int)data->sumEvenConstraints.size(); ++i) 00405 { 00406 //double g_i = constraints[i].rhs; 00407 const int k = (int) data->constraints.size() + i; 00408 double g_k = 0.; 00409 for (Index j = 0; j < (int)data->sumEvenConstraints[i].M.size(); ++j) 00410 { 00411 g_k += x[ data->sumEvenConstraints[i].M[j].col ] * data->sumEvenConstraints[i].M[j].val; 00412 } 00413 g[k] = g_k; 00414 } 00415 00416 return true; 00417 } 00418 00419 // return the structure or values of the jacobian 00420 bool IAMINlp::eval_jac_g(Index n, const Number* x, bool new_x, 00421 Index m, Index nele_jac, Index* iRow, Index *jCol, 00422 Number* values) 00423 { 00424 //printf("G "); 00425 00426 assert(m == (int)(data->constraints.size() + data->sumEvenConstraints.size())); 00427 00428 if (values == NULL) { 00429 // return the structure of the jacobian 00430 Index k=0; 00431 for (Index i = 0; i<(int)data->constraints.size(); ++i) 00432 { 00433 for (Index j = 0; j < (int)data->constraints[i].M.size(); ++j) 00434 { 00435 iRow[k] = i; 00436 jCol[k] = data->constraints[i].M[j].col; 00437 ++k; 00438 } 00439 } 00440 for (Index i = 0; i< (int)data->sumEvenConstraints.size(); ++i) 00441 { 00442 for (Index j = 0; j < (int)data->sumEvenConstraints[i].M.size(); ++j) 00443 { 00444 iRow[k] = i + (int) data->constraints.size(); 00445 jCol[k] = data->sumEvenConstraints[i].M[j].col; 00446 ++k; 00447 } 00448 } 00449 00450 } 00451 else { 00452 // return the values of the jacobian of the constraints 00453 Index k=0; 00454 for (Index i = 0; i < (int)data->constraints.size(); ++i) 00455 { 00456 for (Index j = 0; j < (int)data->constraints[i].M.size(); ++j) 00457 { 00458 values[k++] = data->constraints[i].M[j].val; 00459 } 00460 } 00461 for (Index i = 0; i < (int)data->sumEvenConstraints.size(); ++i) 00462 { 00463 for (Index j = 0; j < (int)data->sumEvenConstraints[i].M.size(); ++j) 00464 { 00465 values[k++] = data->sumEvenConstraints[i].M[j].val; 00466 } 00467 } 00468 } 00469 00470 return true; 00471 } 00472 00473 //return the structure or values of the hessian 00474 bool IAMINlp::eval_h(Index n, const Number* x, bool new_x, 00475 Number obj_factor, Index m, const Number* lambda, 00476 bool new_lambda, Index nele_hess, Index* iRow, 00477 Index* jCol, Number* values) 00478 { 00479 //printf("H "); 00480 00481 // get_nlp_info specified the number of non-zeroes, should be 00482 assert(nele_hess == data->num_variables()); 00483 00484 if (values == NULL) { 00485 // return the structure. This is a symmetric matrix, fill the lower left 00486 // triangle only. 00487 00488 // because the constraints are linear 00489 // the hessian for this constraints are actually empty 00490 00491 // Since the objective function is separable, only the diagonal is non-zero 00492 for (Index idx=0; idx<data->num_variables(); ++idx) 00493 { 00494 iRow[idx] = idx; 00495 jCol[idx] = idx; 00496 } 00497 00498 } 00499 else { 00500 // return the values. This is a symmetric matrix, fill the lower left 00501 // triangle only 00502 00503 // because the constraints are linear 00504 // the hessian for this problem is actually empty 00505 00506 // fill the objective portion 00507 for (Index idx=0; idx<data->num_variables(); ++idx) 00508 { 00509 values[idx] = obj_factor * eval_hess_R_i(data->I[idx], x[idx]); 00510 } 00511 } 00512 00513 return true; 00514 } 00515 00516 void IAMINlp::finalize_solution(SolverReturn status, 00517 Index n, const Number* x, const Number* z_L, const Number* z_U, 00518 Index m, const Number* g, const Number* lambda, 00519 Number obj_value, 00520 const IpoptData* ip_data, 00521 IpoptCalculatedQuantities* ip_cq) 00522 { 00523 // here is where we would store the solution to variables, or write to a file, etc 00524 // so we could use the solution. 00525 //printf("I "); 00526 00527 // copy solution into local storage x_solution 00528 solution->x_solution.clear(); // clear contents 00529 std::vector<double>(solution->x_solution).swap(solution->x_solution); // zero capacity 00530 solution->x_solution.reserve(n); // space for new solution 00531 for (Index i=0; i<n; i++) 00532 { 00533 solution->x_solution.push_back( x[i] ); // values of new solution 00534 } 00535 assert( (int)solution->x_solution.size() == n ); 00536 solution->obj_value = obj_value; 00537 assert(obj_value >= 0.); 00538 00539 if (debugging) 00540 { 00541 printf("NLP solution:\n"); 00542 printf("x[%d] = %e\n", 0, x[0]); 00543 double rhs = 0., lhs = 0.; 00544 if (verbose) 00545 { 00546 printf("legend: coeff x_i (solution, goal, ratio; f(x), f'(x); F(x), F'(x) )\n"); 00547 for (unsigned int j = 0; j < data->constraints.size(); ++j) 00548 { 00549 printf("constraint %d: ", j); 00550 const IAData::constraintRow & c = data->constraints[j]; 00551 for (std::vector<IAData::sparseEntry>::const_iterator i = c.M.begin(); i < c.M.end(); ++i) 00552 { 00553 const double xv = x[i->col]; 00554 const double gv = data->I[i->col]; 00555 const double r = xv > gv ? (xv-gv) / gv : (gv - xv) / xv; 00556 printf(" %1.0f x_%d (%1.3f, %1.1f, %1.1f; %2.2g, %2.2g; %2.2g, %2.2g) ", 00557 i->val, i->col, xv, gv, 00558 r, eval_r_i(gv, xv), eval_grad_r_i(gv, xv), 00559 eval_R_i(gv,xv), eval_grad_R_i(gv,xv) ); 00560 if (i->val > 0) 00561 lhs += i->val * x[i->col]; 00562 else 00563 rhs += i->val * x[i->col]; 00564 } 00565 if (data->constraints.front().upperBound == data->constraints.front().lowerBound) 00566 printf(" = %1.1f", data->constraints.front().upperBound); 00567 else 00568 printf(" in [%1.1f,%1.1f]", data->constraints.front().upperBound, data->constraints.front().lowerBound ); 00569 printf(" <=> %f %f in ...\n", lhs, rhs ); 00570 } 00571 00572 printf("\n\nSolution of the primal variables, x\n"); 00573 for (Index i=0; i<n; i++) { 00574 printf("x[%d] = %e\n", i, x[i]); 00575 } 00576 00577 printf("\n\nSolution of the bound multipliers, z_L and z_U\n"); 00578 for (Index i=0; i<n; i++) { 00579 printf("z_L[%d] = %e\n", i, z_L[i]); 00580 } 00581 for (Index i=0; i<n; i++) { 00582 printf("z_U[%d] = %e\n", i, z_U[i]); 00583 } 00584 printf("\nFinal value of the constraints:\n"); 00585 for (Index i=0; i<m ;i++) { 00586 printf("g(%d) = %e\n", i, g[i]); 00587 } 00588 } 00589 00590 printf("\n\nObjective value\n"); 00591 printf("f(x*) = %e\n", obj_value); 00592 00593 } 00594 } 00595 00596 } // namespace MeshKit
