MeshKit
1.0
00001 // IAMINnl.hpp 00002 // Interval Assignment for Meshkit 00003 // 00004 // ipopt mixed-integer solution 00005 // The idea is the optimal solution will be an integer one, if one exists 00006 // Define some region around the relaxed solution and search for an integer solution 00007 // 00008 00009 #ifndef MESHKIT_IA_IAMINLP_HP 00010 #define MESHKIT_IA_IAMINLP_HP 00011 00012 class IAData; 00013 class IPData; 00014 class IASolution; 00015 class IANlp; 00016 00017 #include "MKVersion.h" 00018 00019 #include "IpTNLP.hpp" 00020 00021 namespace MeshKit 00022 { 00023 00024 class IAMINlp : public TNLP 00025 { 00026 public: 00028 IAMINlp(const IAData *data_ptr, const IPData *ip_data_ptr, IASolution *solution_ptr); 00029 00031 virtual ~IAMINlp(); 00032 00036 virtual bool get_nlp_info(Index& n, Index& m, Index& nnz_jac_g, 00037 Index& nnz_h_lag, IndexStyleEnum& index_style); 00038 00040 virtual bool get_bounds_info(Index n, Number* x_l, Number* x_u, 00041 Index m, Number* g_l, Number* g_u); 00042 00044 virtual bool get_starting_point(Index n, bool init_x, Number* x_init, 00045 bool init_z, Number* z_L, Number* z_U, 00046 Index m, bool init_lambda, 00047 Number* lambda); 00048 00050 virtual bool eval_f(Index n, const Number* x, bool new_x, Number& obj_value); 00051 00053 virtual bool eval_grad_f(Index n, const Number* x, bool new_x, Number* grad_f); 00054 00056 virtual bool eval_g(Index n, const Number* x, bool new_x, Index m, Number* g); 00057 00062 virtual bool eval_jac_g(Index n, const Number* x, bool new_x, 00063 Index m, Index nele_jac, Index* iRow, Index *jCol, 00064 Number* values); 00065 00070 virtual bool eval_h(Index n, const Number* x, bool new_x, 00071 Number obj_factor, Index m, const Number* lambda, 00072 bool new_lambda, Index nele_hess, Index* iRow, 00073 Index* jCol, Number* values); 00074 00076 00080 virtual void finalize_solution(SolverReturn status, 00081 Index n, const Number* x, const Number* z_L, const Number* z_U, 00082 Index m, const Number* g, const Number* lambda, 00083 Number obj_value, 00084 const IpoptData* ip_data, 00085 IpoptCalculatedQuantities* ip_cq); 00087 00088 00089 private: 00090 // hide untrusted default methods 00092 // IA_NLP(); 00093 IAMINlp(); 00094 IAMINlp(const IAMINlp&); 00095 IAMINlp& operator=(const IAMINlp&); 00097 00098 // input data 00099 const IAData *data; 00100 const IPData *ip_data; 00101 // solution data 00102 IASolution *solution; 00103 00104 const bool debugging; 00105 const bool verbose; // verbose debugging 00106 00107 // internally used methods 00108 // contributions of one variable to the objective function and gradient 00109 // underlying function 00110 00111 00112 // r functions: if x>I then x-I / I else I-x / x 00113 Number eval_r_i(const Number& I_i, const Number& x_i); 00114 Number eval_grad_r_i(const Number& I_i, const Number& x_i); 00115 Number eval_hess_r_i(const Number& I_i, const Number& x_i); 00116 00117 // s functions: r weighted by x: r*x 00118 Number eval_s_i(const Number& I_i, const Number& x_i); 00119 Number eval_grad_s_i(const Number& I_i, const Number& x_i); 00120 Number eval_hess_s_i(const Number& I_i, const Number& x_i); 00121 00122 // Capital functions, l-p norms of the lowercase functions 00123 public: 00124 Number eval_R_i(const Number& I_i, const Number& x_i); 00125 private: 00126 Number eval_grad_R_i(const Number& I_i, const Number& x_i); 00127 Number eval_hess_R_i(const Number& I_i, const Number& x_i); 00128 00129 Number eval_S_i(const Number& I_i, const Number& x_i); 00130 Number eval_grad_S_i(const Number& I_i, const Number& x_i); 00131 Number eval_hess_S_i(const Number& I_i, const Number& x_i); 00132 00133 00134 }; 00135 00136 } // namespace MeshKit 00137 00138 #endif
