MeshKit
1.0
00001 // IPBend.hpp 00002 // Interval Assignment Data for Meshkit 00003 // 00004 // Data for defining an objective function that is piecewise linear and bends at integer points 00005 // 00006 00007 #ifndef MESHKIT_IA_IPBEND_HP 00008 #define MESHKIT_IA_IPBEND_HP 00009 00010 #include <vector> 00011 #include <limits> 00012 00013 namespace MeshKit 00014 { 00015 00016 class IPBend 00017 { 00018 public: 00019 // index of delta, magnitude of tilt = weight multiplier 00020 // note tilt is applied to that delta and all subsequent ones 00021 typedef std::pair<unsigned int, double> IPTilt; 00022 typedef std::vector< IPTilt > TiltVec; 00023 00025 IPBend() : 00026 deltaIStart(0), numDeltaPlus(1), numDeltaMinus(1), 00027 plusTilts(), minusTilts() // usually these vecs are empty 00028 {} 00029 00031 virtual ~IPBend() {} 00032 00033 // index i of x[i] or sum-even constraint i is implicitly defined by position in IPBendVec 00034 00035 int xl; // x value if all deltas are zero 00036 00037 int deltaIStart; // index of the first delta variables in the Nlp 00038 00039 // delta0 is always defined, one of them 00040 int numDeltaPlus; // number of plus deltas defined 00041 int numDeltaMinus; // number of minus deltas defined 00042 int num_deltas() const 00043 {return numDeltaPlus + numDeltaMinus; } 00044 00045 // x = xl + sum ( deltas_plus ) - sum (deltas_minus ); 00046 // delta_plus[k] for k < numDeltaPlus + 1 is in [0,1], last is [0,infinity] 00047 00048 static int num_deltas_max() 00049 { return std::numeric_limits<int>::max()/2 - 2; } 00050 00051 // sorted tilts, for x > g and x < g 00052 TiltVec plusTilts, minusTilts; 00053 00054 }; 00055 00056 typedef std::vector< IPBend > IPBendVec; 00057 00058 class IPBendData 00059 { 00060 public: 00061 IPBendVec bendVec; 00062 int numSumVars; 00063 int sumVarStart; 00064 double maxActiveVarWeight; 00065 }; 00066 00067 // default constructors for object and its members OK 00068 // inline IPData::IPData() {} 00069 00070 // default destructor OK 00071 00072 } // namespace MeshKit 00073 00074 #endif
