MeshKit
1.0
00001 /* 00002 * QslimOptions.cpp 00003 * 00004 * Created on: Mar 10, 2010 00005 * Author: iulian 00006 */ 00007 00008 #include "meshkit/QslimOptions.hpp" 00009 // for std:: 00010 #include <limits> 00011 00012 QslimOptions::QslimOptions() { 00013 // TODO Auto-generated constructor stub 00014 // default options: 00015 error_tolerance=0; 00016 face_target = 0; 00017 error_tolerance = std::numeric_limits<double>::max(); 00018 will_use_plane_constraint = true; 00019 will_use_vertex_constraint = false; 00020 00021 will_preserve_boundaries = false; 00022 will_preserve_mesh_quality = false; 00023 will_constrain_boundaries = false; 00024 boundary_constraint_weight = 1.0; 00025 00026 will_weight_by_area = false; 00027 height_fields = false; 00028 timingIntervals = 10; 00029 00030 useDelayedDeletion = true; 00031 00032 placement_policy = PLACE_OPTIMAL; 00033 00034 pair_selection_tolerance = 0.0; 00035 logfile = 0; 00036 selected_output = 0; 00037 plotCost = 0; 00038 create_range = false; 00039 topology = 0; 00040 00041 } 00042 00043 QslimOptions::~QslimOptions() { 00044 // TODO Auto-generated destructor stub 00045 }
