MeshKit
1.0
00001 #ifndef READPOLYLINE_H 00002 #define READPOLYLINE_H 00003 00004 // this should not be compiled separately, included only after some stuff 00005 /* 00006 #include <vector> 00007 #include <fstream> 00008 #include <iostream> 00009 */ 00010 // this is just a utility function used too many times in tests for 00011 // mesh-based geometry, so I put it separately 00012 00013 int ReadPolyLineFromFile(const char * filename, double direction[3], 00014 std::vector<double> & points) 00015 { 00016 // get the direction, and the polygon/ polyline points 00017 std::ifstream datafile(filename, std::ifstream::in); 00018 if (!datafile) { 00019 std::cout << "can't read polyline file\n"; 00020 return 1; 00021 } 00022 // 00023 char temp[100]; 00024 //double direction[3];// normalized 00025 double gridSize; 00026 datafile.getline(temp, 100);// first line 00027 00028 // get direction and mesh size along polygon segments, from file 00029 sscanf(temp, " %lf %lf %lf %lf ", direction, direction + 1, direction + 2, 00030 &gridSize); 00031 00032 //std::vector<double> xyz; 00033 while (!datafile.eof()) { 00034 datafile.getline(temp, 100); 00035 //int id = 0; 00036 double x, y, z; 00037 int nr = sscanf(temp, "%lf %lf %lf", &x, &y, &z); 00038 if (nr == 3) { 00039 points.push_back(x); 00040 points.push_back(y); 00041 points.push_back(z); 00042 } 00043 } 00044 return 0; 00045 } 00046 #endif // READPOLYLINE_H
