MeshKit
1.0
00001 00002 #include "meshkit/circumcenter.hpp" 00003 00004 #include <stdlib.h> 00005 #include <stdio.h> 00006 00007 #include <iostream> 00008 using namespace std; 00009 00010 // 00011 //Let a, b, c, d, and m be vectors in R^3. Let ax, ay, and az be the components 00012 //of a, and likewise for b, c, and d. Let |a| denote the Euclidean norm of a, 00013 //and let a x b denote the cross product of a and b. Then 00014 // 00015 // | | 00016 // | |d-a|^2 [(b-a)x(c-a)] + |c-a|^2 [(d-a)x(b-a)] + |b-a|^2 [(c-a)x(d-a)] | 00017 // | | 00018 //r = -------------------------------------------------------------------------, 00019 // | bx-ax by-ay bz-az | 00020 // 2 | cx-ax cy-ay cz-az | 00021 // | dx-ax dy-ay dz-az | 00022 // 00023 //and 00024 // 00025 // |d-a|^2 [(b-a)x(c-a)] + |c-a|^2 [(d-a)x(b-a)] + |b-a|^2 [(c-a)x(d-a)] 00026 //m = a + ---------------------------------------------------------------------. 00027 // | bx-ax by-ay bz-az | 00028 // 2 | cx-ax cy-ay cz-az | 00029 // | dx-ax dy-ay dz-az | 00030 // 00031 //Some notes on stability: 00032 // 00033 //- Note that the expression for r is purely a function of differences between 00034 // coordinates. The advantage is that the relative error incurred in the 00035 // computation of r is also a function of the _differences_ between the 00036 // vertices, and is not influenced by the _absolute_ coordinates of the 00037 // vertices. In most applications, vertices are usually nearer to each other 00038 // than to the origin, so this property is advantageous. If someone gives you 00039 // a formula that doesn't have this property, be wary. 00040 // 00041 // Similarly, the formula for m incurs roundoff error proportional to the 00042 // differences between vertices, but does not incur roundoff error proportional 00043 // to the absolute coordinates of the vertices until the final addition. 00044 00045 //- These expressions are unstable in only one case: if the denominator is 00046 // close to zero. This instability, which arises if the tetrahedron is nearly 00047 // degenerate, is unavoidable. Depending on your application, you may want 00048 // to use exact arithmetic to compute the value of the determinant. 00049 // Fortunately, this determinant is the basis of the well-studied 3D orientation 00050 // test, and several fast algorithms for providing accurate approximations to 00051 // the determinant are available. Some resources are available from the 00052 // "Numerical and algebraic computation" page of Nina Amenta's Directory of 00053 // Computational Geometry Software: 00054 00055 // http://www.geom.umn.edu/software/cglist/alg.html 00056 00057 // If you're using floating-point inputs (as opposed to integers), one 00058 // package that can estimate this determinant somewhat accurately is my own: 00059 00060 // http://www.cs.cmu.edu/~quake/robust.html 00061 00062 //- If you want to be even more aggressive about stability, you might reorder 00063 // the vertices of the tetrahedron so that the vertex `a' (which is subtracted 00064 // from the other vertices) is, roughly speaking, the vertex at the center of 00065 // the minimum spanning tree of the tetrahedron's four vertices. For more 00066 // information about this idea, see Steven Fortune, "Numerical Stability of 00067 // Algorithms for 2D Delaunay Triangulations," International Journal of 00068 // Computational Geometry & Applications 5(1-2):193-213, March-June 1995. 00069 00070 //For completeness, here are stable expressions for the circumradius and 00071 //circumcenter of a triangle, in R^2 and in R^3. Incidentally, the expressions 00072 //given here for R^2 are better behaved in terms of relative error than the 00073 //suggestions currently given in the Geometry Junkyard 00074 //(http://www.ics.uci.edu/~eppstein/junkyard/triangulation.html). 00075 00076 //Triangle in R^2: 00077 // 00078 // |b-a| |c-a| |b-c| < Note: You only want to compute one sqrt, so 00079 //r = ------------------, use sqrt{ |b-a|^2 |c-a|^2 |b-c|^2 } 00080 // | bx-ax by-ay | 00081 // 2 | cx-ax cy-ay | 00082 // 00083 // | by-ay |b-a|^2 | 00084 // | cy-ay |c-a|^2 | 00085 //mx = ax - ------------------, 00086 // | bx-ax by-ay | 00087 // 2 | cx-ax cy-ay | 00088 // 00089 // | bx-ax |b-a|^2 | 00090 // | cx-ax |c-a|^2 | 00091 //my = ay + ------------------. 00092 // | bx-ax by-ay | 00093 // 2 | cx-ax cy-ay | 00094 // 00095 //Triangle in R^3: 00096 // 00097 // | | 00098 // | |c-a|^2 [(b-a)x(c-a)]x(b-a) + |b-a|^2 (c-a)x[(b-a)x(c-a)] | 00099 // | | 00100 //r = -------------------------------------------------------------, 00101 // 2 | (b-a)x(c-a) |^2 00102 // 00103 // |c-a|^2 [(b-a)x(c-a)]x(b-a) + |b-a|^2 (c-a)x[(b-a)x(c-a)] 00104 //m = a + ---------------------------------------------------------. 00105 // 2 | (b-a)x(c-a) |^2 00106 // 00107 //Finally, here's some C code that computes the vector m-a (whose norm is r) in 00108 //each of these three cases. Notice the #ifdef statements, which allow you to 00109 //choose whether or not to use my aforementioned package to approximate the 00110 //determinant. (No attempt is made here to reorder the vertices to improve 00111 //stability.) 00112 00113 /*****************************************************************************/ 00114 /* */ 00115 /* tetcircumcenter() Find the circumcenter of a tetrahedron. */ 00116 /* */ 00117 /* The result is returned both in terms of xyz coordinates and xi-eta-zeta */ 00118 /* coordinates, relative to the tetrahedron's point `a' (that is, `a' is */ 00119 /* the origin of both coordinate systems). Hence, the xyz coordinates */ 00120 /* returned are NOT absolute; one must add the coordinates of `a' to */ 00121 /* find the absolute coordinates of the circumcircle. However, this means */ 00122 /* that the result is frequently more accurate than would be possible if */ 00123 /* absolute coordinates were returned, due to limited floating-point */ 00124 /* precision. In general, the circumradius can be computed much more */ 00125 /* accurately. */ 00126 /* */ 00127 /* The xi-eta-zeta coordinate system is defined in terms of the */ 00128 /* tetrahedron. Point `a' is the origin of the coordinate system. */ 00129 /* The edge `ab' extends one unit along the xi axis. The edge `ac' */ 00130 /* extends one unit along the eta axis. The edge `ad' extends one unit */ 00131 /* along the zeta axis. These coordinate values are useful for linear */ 00132 /* interpolation. */ 00133 /* */ 00134 /* If `xi' is NULL on input, the xi-eta-zeta coordinates will not be */ 00135 /* computed. */ 00136 /* */ 00137 /*****************************************************************************/ 00138 00139 /*****************************************************************************/ 00140 00141 void tetcircumcenter(double a[3], double b[3], double c[3], double d[3], 00142 double circumcenter[3], double *xi, double *eta, double *zeta) 00143 { 00144 double xba, yba, zba, xca, yca, zca, xda, yda, zda; 00145 double balength, calength, dalength; 00146 double xcrosscd, ycrosscd, zcrosscd; 00147 double xcrossdb, ycrossdb, zcrossdb; 00148 double xcrossbc, ycrossbc, zcrossbc; 00149 double denominator; 00150 double xcirca, ycirca, zcirca; 00151 00152 /* Use coordinates relative to point `a' of the tetrahedron. */ 00153 xba = b[0] - a[0]; 00154 yba = b[1] - a[1]; 00155 zba = b[2] - a[2]; 00156 xca = c[0] - a[0]; 00157 yca = c[1] - a[1]; 00158 zca = c[2] - a[2]; 00159 xda = d[0] - a[0]; 00160 yda = d[1] - a[1]; 00161 zda = d[2] - a[2]; 00162 /* Squares of lengths of the edges incident to `a'. */ 00163 balength = xba * xba + yba * yba + zba * zba; 00164 calength = xca * xca + yca * yca + zca * zca; 00165 dalength = xda * xda + yda * yda + zda * zda; 00166 /* Cross products of these edges. */ 00167 xcrosscd = yca * zda - yda * zca; 00168 ycrosscd = zca * xda - zda * xca; 00169 zcrosscd = xca * yda - xda * yca; 00170 xcrossdb = yda * zba - yba * zda; 00171 ycrossdb = zda * xba - zba * xda; 00172 zcrossdb = xda * yba - xba * yda; 00173 xcrossbc = yba * zca - yca * zba; 00174 ycrossbc = zba * xca - zca * xba; 00175 zcrossbc = xba * yca - xca * yba; 00176 00177 /* Calculate the denominator of the formulae. */ 00178 #ifdef EXACT 00179 /* Use orient3d() from http://www.cs.cmu.edu/~quake/robust.html */ 00180 /* to ensure a correctly signed (and reasonably accurate) result, */ 00181 /* avoiding any possibility of division by zero. */ 00182 denominator = 0.5 / orient3d(b, c, d, a); 00183 #else 00184 /* Take your chances with floating-point roundoff. */ 00185 printf( " Warning: IEEE floating points used: Define -DEXACT in makefile \n"); 00186 denominator = 0.5 / (xba * xcrosscd + yba * ycrosscd + zba * zcrosscd); 00187 #endif 00188 00189 /* Calculate offset (from `a') of circumcenter. */ 00190 xcirca = (balength * xcrosscd + calength * xcrossdb + dalength * xcrossbc) * 00191 denominator; 00192 ycirca = (balength * ycrosscd + calength * ycrossdb + dalength * ycrossbc) * 00193 denominator; 00194 zcirca = (balength * zcrosscd + calength * zcrossdb + dalength * zcrossbc) * 00195 denominator; 00196 circumcenter[0] = xcirca; 00197 circumcenter[1] = ycirca; 00198 circumcenter[2] = zcirca; 00199 00200 if (xi != (double *) NULL) { 00201 /* To interpolate a linear function at the circumcenter, define a */ 00202 /* coordinate system with a xi-axis directed from `a' to `b', */ 00203 /* an eta-axis directed from `a' to `c', and a zeta-axis directed */ 00204 /* from `a' to `d'. The values for xi, eta, and zeta are computed */ 00205 /* by Cramer's Rule for solving systems of linear equations. */ 00206 *xi = (xcirca * xcrosscd + ycirca * ycrosscd + zcirca * zcrosscd) * 00207 (2.0 * denominator); 00208 *eta = (xcirca * xcrossdb + ycirca * ycrossdb + zcirca * zcrossdb) * 00209 (2.0 * denominator); 00210 *zeta = (xcirca * xcrossbc + ycirca * ycrossbc + zcirca * zcrossbc) * 00211 (2.0 * denominator); 00212 } 00213 } 00214 00215 /*****************************************************************************/ 00216 /*****************************************************************************/ 00217 /* */ 00218 /* tricircumcenter() Find the circumcenter of a triangle. */ 00219 /* */ 00220 /* The result is returned both in terms of x-y coordinates and xi-eta */ 00221 /* coordinates, relative to the triangle's point `a' (that is, `a' is */ 00222 /* the origin of both coordinate systems). Hence, the x-y coordinates */ 00223 /* returned are NOT absolute; one must add the coordinates of `a' to */ 00224 /* find the absolute coordinates of the circumcircle. However, this means */ 00225 /* that the result is frequently more accurate than would be possible if */ 00226 /* absolute coordinates were returned, due to limited floating-point */ 00227 /* precision. In general, the circumradius can be computed much more */ 00228 /* accurately. */ 00229 /* */ 00230 /* The xi-eta coordinate system is defined in terms of the triangle. */ 00231 /* Point `a' is the origin of the coordinate system. The edge `ab' extends */ 00232 /* one unit along the xi axis. The edge `ac' extends one unit along the */ 00233 /* eta axis. These coordinate values are useful for linear interpolation. */ 00234 /* */ 00235 /* If `xi' is NULL on input, the xi-eta coordinates will not be computed. */ 00236 /* */ 00237 /*****************************************************************************/ 00238 00239 00240 /*****************************************************************************/ 00241 void tricircumcenter(double a[2], double b[2], double c[2], double circumcenter[2], 00242 double *xi, double *eta) 00243 { 00244 double xba, yba, xca, yca; 00245 double balength, calength; 00246 double denominator; 00247 double xcirca, ycirca; 00248 00249 /* Use coordinates relative to point `a' of the triangle. */ 00250 xba = b[0] - a[0]; 00251 yba = b[1] - a[1]; 00252 xca = c[0] - a[0]; 00253 yca = c[1] - a[1]; 00254 /* Squares of lengths of the edges incident to `a'. */ 00255 balength = xba * xba + yba * yba; 00256 calength = xca * xca + yca * yca; 00257 00258 /* Calculate the denominator of the formulae. */ 00259 #ifdef EXACT 00260 /* Use orient2d() from http://www.cs.cmu.edu/~quake/robust.html */ 00261 /* to ensure a correctly signed (and reasonably accurate) result, */ 00262 /* avoiding any possibility of division by zero. */ 00263 denominator = 0.5 / orient2d(b, c, a); 00264 #else 00265 /* Take your chances with floating-point roundoff. */ 00266 denominator = 0.5 / (xba * yca - yba * xca); 00267 #endif 00268 00269 /* Calculate offset (from `a') of circumcenter. */ 00270 xcirca = (yca * balength - yba * calength) * denominator; 00271 ycirca = (xba * calength - xca * balength) * denominator; 00272 circumcenter[0] = xcirca; 00273 circumcenter[1] = ycirca; 00274 00275 if (xi != (double *) NULL) { 00276 /* To interpolate a linear function at the circumcenter, define a */ 00277 /* coordinate system with a xi-axis directed from `a' to `b' and */ 00278 /* an eta-axis directed from `a' to `c'. The values for xi and eta */ 00279 /* are computed by Cramer's Rule for solving systems of linear */ 00280 /* equations. */ 00281 *xi = (xcirca * yca - ycirca * xca) * (2.0 * denominator); 00282 *eta = (ycirca * xba - xcirca * yba) * (2.0 * denominator); 00283 } 00284 } 00285 00286 /****************************************************************************/ 00287 00288 /*****************************************************************************/ 00289 /* */ 00290 /* tricircumcenter3d() Find the circumcenter of a triangle in 3D. */ 00291 /* */ 00292 /* The result is returned both in terms of xyz coordinates and xi-eta */ 00293 /* coordinates, relative to the triangle's point `a' (that is, `a' is */ 00294 /* the origin of both coordinate systems). Hence, the xyz coordinates */ 00295 /* returned are NOT absolute; one must add the coordinates of `a' to */ 00296 /* find the absolute coordinates of the circumcircle. However, this means */ 00297 /* that the result is frequently more accurate than would be possible if */ 00298 /* absolute coordinates were returned, due to limited floating-point */ 00299 /* precision. In general, the circumradius can be computed much more */ 00300 /* accurately. */ 00301 /* */ 00302 /* The xi-eta coordinate system is defined in terms of the triangle. */ 00303 /* Point `a' is the origin of the coordinate system. The edge `ab' extends */ 00304 /* one unit along the xi axis. The edge `ac' extends one unit along the */ 00305 /* eta axis. These coordinate values are useful for linear interpolation. */ 00306 /* */ 00307 /* If `xi' is NULL on input, the xi-eta coordinates will not be computed. */ 00308 /* */ 00309 /*****************************************************************************/ 00310 /*****************************************************************************/ 00311 void tricircumcenter3d(double a[3], double b[3], double c[3], double circumcenter[3], 00312 double *xi, double *eta) 00313 { 00314 double xba, yba, zba, xca, yca, zca; 00315 double balength, calength; 00316 double xcrossbc, ycrossbc, zcrossbc; 00317 double denominator; 00318 double xcirca, ycirca, zcirca; 00319 00320 /* Use coordinates relative to point `a' of the triangle. */ 00321 xba = b[0] - a[0]; 00322 yba = b[1] - a[1]; 00323 zba = b[2] - a[2]; 00324 xca = c[0] - a[0]; 00325 yca = c[1] - a[1]; 00326 zca = c[2] - a[2]; 00327 /* Squares of lengths of the edges incident to `a'. */ 00328 balength = xba * xba + yba * yba + zba * zba; 00329 calength = xca * xca + yca * yca + zca * zca; 00330 00331 /* Cross product of these edges. */ 00332 #ifdef EXACT 00333 /* Use orient2d() from http://www.cs.cmu.edu/~quake/robust.html */ 00334 /* to ensure a correctly signed (and reasonably accurate) result, */ 00335 /* avoiding any possibility of division by zero. */ 00336 00337 A[0] = b[1]; A[1] = b[2]; 00338 B[0] = c[1]; B[1] = c[2]; 00339 C[0] = a[1]; C[1] = a[2]; 00340 xcrossbc = orient2d(A, B, C); 00341 00342 A[0] = c[0]; A[1] = c[2]; 00343 B[0] = b[0]; B[1] = b[2]; 00344 C[0] = a[0]; C[1] = a[2]; 00345 ycrossbc = orient2d(A, B, C); 00346 00347 A[0] = b[0]; A[1] = b[1]; 00348 B[0] = c[0]; B[1] = c[1]; 00349 C[0] = a[0]; C[1] = a[1]; 00350 zcrossbc = orient2d(A, B, C); 00351 00352 /* 00353 xcrossbc = orient2d(b[1], b[2], c[1], c[2], a[1], a[2]); 00354 ycrossbc = orient2d(b[2], b[0], c[2], c[0], a[2], a[0]); 00355 zcrossbc = orient2d(b[0], b[1], c[0], c[1], a[0], a[1]); 00356 */ 00357 #else 00358 printf( " Warning: IEEE floating points used: Define -DEXACT in makefile \n"); 00359 /* Take your chances with floating-point roundoff. */ 00360 xcrossbc = yba * zca - yca * zba; 00361 ycrossbc = zba * xca - zca * xba; 00362 zcrossbc = xba * yca - xca * yba; 00363 #endif 00364 00365 /* Calculate the denominator of the formulae. */ 00366 denominator = 0.5 / (xcrossbc * xcrossbc + ycrossbc * ycrossbc + 00367 zcrossbc * zcrossbc); 00368 00369 /* Calculate offset (from `a') of circumcenter. */ 00370 xcirca = ((balength * yca - calength * yba) * zcrossbc - 00371 (balength * zca - calength * zba) * ycrossbc) * denominator; 00372 ycirca = ((balength * zca - calength * zba) * xcrossbc - 00373 (balength * xca - calength * xba) * zcrossbc) * denominator; 00374 zcirca = ((balength * xca - calength * xba) * ycrossbc - 00375 (balength * yca - calength * yba) * xcrossbc) * denominator; 00376 circumcenter[0] = xcirca; 00377 circumcenter[1] = ycirca; 00378 circumcenter[2] = zcirca; 00379 00380 if (xi != (double *) NULL) { 00381 /* To interpolate a linear function at the circumcenter, define a */ 00382 /* coordinate system with a xi-axis directed from `a' to `b' and */ 00383 /* an eta-axis directed from `a' to `c'. The values for xi and eta */ 00384 /* are computed by Cramer's Rule for solving systems of linear */ 00385 /* equations. */ 00386 00387 /* There are three ways to do this calculation - using xcrossbc, */ 00388 /* ycrossbc, or zcrossbc. Choose whichever has the largest */ 00389 /* magnitude, to improve stability and avoid division by zero. */ 00390 if (((xcrossbc >= ycrossbc) ^ (-xcrossbc > ycrossbc)) && 00391 ((xcrossbc >= zcrossbc) ^ (-xcrossbc > zcrossbc))) { 00392 *xi = (ycirca * zca - zcirca * yca) / xcrossbc; 00393 *eta = (zcirca * yba - ycirca * zba) / xcrossbc; 00394 } else if ((ycrossbc >= zcrossbc) ^ (-ycrossbc > zcrossbc)) { 00395 *xi = (zcirca * xca - xcirca * zca) / ycrossbc; 00396 *eta = (xcirca * zba - zcirca * xba) / ycrossbc; 00397 } else { 00398 *xi = (xcirca * yca - ycirca * xca) / zcrossbc; 00399 *eta = (ycirca * xba - xcirca * yba) / zcrossbc; 00400 } 00401 } 00402 } 00403 /****************************************************************************/ 00404 void TriCircumCenter2D( double *a, double *b, double *c, double *result, 00405 double *param) 00406 { 00407 tricircumcenter(a, b, c, result, ¶m[0], ¶m[1]); 00408 00409 result[0] += a[0]; 00410 result[1] += a[1]; 00411 } 00412 /****************************************************************************/ 00413 void TriCircumCenter3D( double *a, double *b, double *c, double *result, 00414 double *param) 00415 { 00416 tricircumcenter3d(a, b, c, result, ¶m[0], ¶m[1]); 00417 result[0] += a[0]; 00418 result[1] += a[1]; 00419 result[2] += a[2]; 00420 } 00421 00422 /****************************************************************************/ 00423 void TriCircumCenter3D( double *a, double *b, double *c, double *result) 00424 { 00425 double xi, eta; 00426 tricircumcenter3d(a, b, c, result, &xi, & eta); 00427 result[0] += a[0]; 00428 result[1] += a[1]; 00429 result[2] += a[2]; 00430 } 00431 /****************************************************************************/ 00432 void TetCircumCenter( double *a, double *b, double *c, double *d, double *result, 00433 double *param) 00434 { 00435 double orient = orient3d(a, b, c, d); 00436 00437 if(orient < 0.0) 00438 tetcircumcenter(a, c, b, d, result, ¶m[0], ¶m[1], ¶m[2]); 00439 else 00440 tetcircumcenter(a, b, c, d, result, ¶m[0], ¶m[1], ¶m[2]); 00441 00442 result[0] += a[0]; 00443 result[1] += a[1]; 00444 result[2] += a[2]; 00445 } 00446 /****************************************************************************/ 00447 int UnitTest:: test_tet_circumcenter() 00448 { 00449 Point3D a, b, c, d; 00450 Point3D result, param; 00451 Array4D dist; 00452 00453 exactinit(); 00454 for( int i = 0; i < 100; i++) { 00455 a[0] = -5.0 + 10*drand48(); 00456 a[1] = -5.0 + 10*drand48(); 00457 a[2] = -5.0 + 10*drand48(); 00458 00459 b[0] = -5.0 + 10*drand48(); 00460 b[1] = -5.0 + 10*drand48(); 00461 b[2] = -5.0 + 10*drand48(); 00462 00463 c[0] = -5.0 + 10*drand48(); 00464 c[1] = -5.0 + 10*drand48(); 00465 c[2] = -5.0 + 10*drand48(); 00466 00467 d[0] = -5.0 + 10*drand48(); 00468 d[1] = -5.0 + 10*drand48(); 00469 d[2] = -5.0 + 10*drand48(); 00470 00471 TetCircumCenter( &a[0], &b[0], &c[0], &d[0], &result[0], ¶m[0]); 00472 00473 dist[0] = Math::length(a, result); 00474 dist[1] = Math::length(b, result); 00475 dist[2] = Math::length(c, result); 00476 dist[3] = Math::length(d, result); 00477 00478 if( fabs(dist[1]-dist[0]) > 1.0E-05) { 00479 cout << "Info: Tet CircumCenter failed " << endl; 00480 return 1; 00481 } 00482 if( fabs(dist[2]-dist[0]) > 1.0E-05) { 00483 cout << "Info: Tet CircumCenter failed " << endl; 00484 return 1; 00485 } 00486 if( fabs(dist[3]-dist[0]) > 1.0E-05) { 00487 cout << "Info: Tet CircumCenter failed " << endl; 00488 return 1; 00489 } 00490 } 00491 00492 cout << "Info: Tetrahedra Circumcenter tests passed " << endl; 00493 00494 return 0; 00495 } 00496 00497 int UnitTest:: test_tri3d_circumcenter() 00498 { 00499 Point3D a, b, c; 00500 Point3D result, param; 00501 Array4D dist; 00502 00503 exactinit(); 00504 for( int i = 0; i < 100; i++) { 00505 a[0] = -5.0 + 10*drand48(); 00506 a[1] = -5.0 + 10*drand48(); 00507 a[2] = -5.0 + 10*drand48(); 00508 00509 b[0] = -5.0 + 10*drand48(); 00510 b[1] = -5.0 + 10*drand48(); 00511 b[2] = -5.0 + 10*drand48(); 00512 00513 c[0] = -5.0 + 10*drand48(); 00514 c[1] = -5.0 + 10*drand48(); 00515 c[2] = -5.0 + 10*drand48(); 00516 00517 TriCircumCenter3D( &a[0], &b[0], &c[0], &result[0], ¶m[0]); 00518 00519 dist[0] = Math::length(a, result); 00520 dist[1] = Math::length(b, result); 00521 dist[2] = Math::length(c, result); 00522 00523 if( fabs(dist[1]-dist[0]) > 1.0E-05) { 00524 cout << "Info: Tet CircumCenter failed " << endl; 00525 return 1; 00526 } 00527 00528 if( fabs(dist[2]-dist[0]) > 1.0E-05) { 00529 cout << "Info: Tet CircumCenter failed " << endl; 00530 return 1; 00531 } 00532 00533 } 00534 00535 cout << "Info: 3D Triangle Circumcenter tests passed " << endl; 00536 00537 return 0; 00538 }
