MeshKit
1.0
00001 #ifndef REFINE_H 00002 #define REFINE_H 00003 00004 #include <assert.h> 00005 #include <math.h> 00006 #include <string.h> 00007 #include <algorithm> 00008 00009 #include <iGeom.h> 00010 #include <iMesh.h> 00011 #include <iRel.h> 00012 00013 #include <vector> 00014 #include <bitset> 00015 00016 using namespace std; 00017 00018 #include "meshkit/SimpleArray.h" 00019 #include "meshkit/basic_math.hpp" 00020 00022 // MeshRefine2D: 00023 // LongestEdgeRefine2D: ConsistencyRefine2D 00024 // ObtuseRefine2D: ConsistencyRefine2D 00025 // GradeRefine2D: ConsistencyRefine2D 00026 // Refine2D14: ConsistencyRefine2D 00027 // CentroidRefine2D 00028 // DelaunayRefine2D 00029 // Square3SubDivision 00031 //Class Refine, refines an existing triangulation. This class works for 2D cases 00032 //or the parametric domain of 3D surface triangulation. The user need to provide 00033 //which cells need to be refined. There could be many criteria for deviding the 00034 //cell, so this is not part of the class. 00035 // 00036 //Input : Connection : Connectivity of the triangulation ( 1D array) 00037 // : ParamCoords: parametric coordinates of the vertices. 00038 // : markFace : Faces which are marked for refinement. 00039 // 00040 //Output: Connection : 00041 // ParamCoords: 00042 // 00043 //If the user is working with 3D triangulated surface, it is assumed that he 00044 //has some representation ( example NURBS ) from which he can calculate the 00045 //physical Coordinates from the paramCoords. Again this is not the responsiblity 00046 //of the class. 00047 // 00048 //------------------------------------------------------------------------------ 00049 //Number of Division : New Vertices : New Faces 00050 //------------------------------------------------------------------------------ 00051 // 2 : 1 : 1 00052 // 3 : 0 : 2 00053 // 4 : 3 : 3 00054 //------------------------------------------------------------------------------ 00055 // Default Number of Subdivisions is 2, which is conservative approach, but 00056 // good at equalizing the aspect ratio with respect to neighbouring triangles. 00057 // 00058 // Programmer : Chaman Singh Verma 00059 // Place : Argonne National Lab. 00060 // Argonne, IL, USA 00061 // 00062 // 00064 // 00071 enum RefinePolicy { CENTROID_PLACEMENT, CIRCUMCENTER_PLACEMENT, LONGEST_EDGE_BISECTION}; 00072 00073 enum RefineObjective {REFINE_AREA, REFINE_ASPECT_RATIO, REFINE_CURVATURE}; 00074 00076 00078 class MeshRefine2D 00079 { 00080 public: 00081 00082 MeshRefine2D() { 00083 boundary_split_flag = 0; 00084 } 00085 virtual ~MeshRefine2D() {} 00086 00087 void setMesh( iMesh_Instance &m ) { mesh = m; } 00088 void setGeometry( const iGeom_Instance &g ) { geom = g; } 00089 00090 void setBoundarySplitFlag( bool f ) { boundary_split_flag = f; } 00091 00092 vector<iBase_EntityHandle> getNewNodes() const { return insertedNodes; } 00093 vector<iBase_EntityHandle> getNewFaces() const { return insertedFaces; } 00094 00095 size_t getNumFacesRefined() const { return numfacesRefined; } 00096 00097 virtual int execute() = 0; 00098 00099 virtual int initialize(); 00100 00101 protected: 00102 int finalize(); 00103 00104 typedef iBase_EntityHandle EHandle; 00105 int numIterations; 00106 00107 iBase_TagHandle remove_tag, vertex_on_edge_tag, boundary_tag, globalID_tag; 00108 00109 iBase_EntitySetHandle rootSet, currSet; 00110 vector<iBase_EntitySetHandle> entitySets; 00111 00112 iMesh_Instance mesh; 00113 iGeom_Instance geom; 00114 00115 vector<EHandle> hangingVertex; 00116 vector<EHandle> insertedNodes; 00117 vector<EHandle> insertedFaces; 00118 00119 bool boundary_split_flag; 00120 size_t numfacesRefined; 00121 00122 int setVertexOnEdge(EHandle v1, EHandle v2, EHandle &vmid); 00123 int getVertexOnEdge(EHandle v1, EHandle v2, EHandle &vmid) const; 00124 00125 bool searchEdge( EHandle v1, EHandle v2, EHandle &edgehandle) const; 00126 bool allow_edge_refinement( EHandle &edgehandle ) const; 00127 00128 double edge_length( EHandle v1, EHandle v2) const; 00129 Point3D edge_centroid( EHandle v1, EHandle v2) const; 00130 00131 double face_aspect_ratio( EHandle v1 ) const; 00132 Point3D face_centroid( EHandle f) const; 00133 00134 int getVertexCoords(EHandle vHandle, Point3D &p3d) const 00135 { 00136 int err; 00137 double x, y, z; 00138 iMesh_getVtxCoord(mesh, vHandle, &x, &y, &z, &err); 00139 p3d[0] = x; 00140 p3d[1] = y; 00141 p3d[2] = z; 00142 return err; 00143 } 00144 00145 void setVertexCoords(EHandle f, const Point3D &p); 00146 00147 EHandle create_new_edge( EHandle v1, EHandle v2 ); 00148 00149 int prune_mesh(); 00150 00151 }; 00152 00154 00155 class Sqrt3Refine2D : public MeshRefine2D 00156 { 00157 public: 00158 int execute(); 00159 private: 00160 int create_tags(); 00161 }; 00162 00164 00165 class CentroidRefine2D : public MeshRefine2D 00166 { 00167 public: 00168 00169 int initialize(); 00170 int execute(); 00171 00172 private: 00173 int atomicOp( const iBase_EntityHandle &f); 00174 int refine_tri( const iBase_EntityHandle &f); 00175 int refine_quad( const iBase_EntityHandle &f); 00176 }; 00177 00179 00180 class ConsistencyRefine2D : public MeshRefine2D 00181 { 00182 public: 00183 ~ConsistencyRefine2D() {} 00184 00185 int initialize(); 00186 int execute(); 00187 00188 private: 00189 bitset<3> edge0, edge1, edge2, bitvec; 00190 typedef iBase_EntityHandle EHandle; 00191 00192 int create_tags(); 00193 00194 int atomicOp( const EHandle &f); 00195 void refineEdge0(const EHandle &f); 00196 void refineEdge1(const EHandle &f); 00197 void refineEdge2(const EHandle &f); 00198 void subDivideQuad2Tri( const vector<EHandle> &qnodes); 00199 00200 void checkFaceConsistency( const EHandle &f); 00201 00202 void makeConsistent(); 00203 void makeConsistent1( const EHandle &f ); 00204 void makeConsistent2( const EHandle &f ); 00205 void makeConsistent3( const EHandle &f ); 00206 }; 00207 00208 00210 00211 class LongestEdgeRefine2D : public MeshRefine2D 00212 { 00213 public: 00214 LongestEdgeRefine2D() 00215 { 00216 cutOffAspectRatio = 0.50; 00217 } 00218 00219 ~LongestEdgeRefine2D() {} 00220 00221 void setCutOffAspectRatio(double asp) { cutOffAspectRatio = asp;} 00222 00223 int initialize(); 00224 int execute(); 00225 00226 private: 00227 int create_tags(); 00228 double cutOffAspectRatio; 00229 int atomicOp( const iBase_EntityHandle &f); 00230 }; 00231 00233 00234 class Refine2D14 : public MeshRefine2D 00235 { 00236 public: 00237 00238 ~Refine2D14() {} 00239 00240 int initialize(); 00241 int execute(); 00242 00243 private: 00244 int atomicOp( const iBase_EntityHandle &f); 00245 int refine_tri(const iBase_EntityHandle &f); 00246 int refine_quad(const iBase_EntityHandle &f); 00247 }; 00248 00250 00251 struct DelaunayRefinement2D : public MeshRefine2D 00252 { 00253 ~DelaunayRefinement2D() {} 00254 00255 int initialize(); 00256 int finalize(); 00257 int execute() {} 00258 }; 00259 00261 00262 class ObtuseRefine2D : public MeshRefine2D 00263 { 00264 public: 00265 ObtuseRefine2D( ) { cutoffAngle = 90.0;} 00266 00267 void setCutOffAngle( double a ) { cutoffAngle = std::max(90.0, a); } 00268 00269 int initialize(); 00270 int execute(); 00271 00272 private: 00273 double cutoffAngle; 00274 int atomicOp(const iBase_EntityHandle &f); 00275 }; 00276 00278 00279 class GradeRefine2D : public MeshRefine2D 00280 { 00281 public: 00282 int initialize(); 00283 int finalize(); 00284 int execute(); 00285 00286 private: 00287 int atomicOp( const iBase_EntityHandle &v); 00288 }; 00289 00291 00292 #endif 00293
