MeshKit
1.0
00001 00002 #include "meshkit/AssyGen.hpp" 00003 00004 namespace MeshKit 00005 { 00006 void AssyGen::CreateCubitJournal() 00007 //--------------------------------------------------------------------------- 00008 //Function: Create Cubit Journal File for generating mesh 00009 //Input: none 00010 //Output: none 00011 //--------------------------------------------------------------------------- 00012 { 00013 #ifdef HAVE_RGG16 00014 m_FileOutput << "#RGG16 enabled for AssyGen" << std::endl; 00015 #else 00016 m_FileOutput << "#<15.1 version enabled for AssyGen" << std::endl; 00017 #endif 00018 if(m_szMeshScheme == "hole") 00019 m_FileOutput << "surf in group hole_surfaces scheme hole" << std::endl; 00020 00021 if (m_nBLAssemblyMat !=0){ 00022 // Also look for material name in BL material list 00023 for (int ll=1; ll<= m_nBLAssemblyMat; ll++){ 00024 //if(szVCylMat(m) == m_szBLAssmMat(ll)) { 00025 #ifdef HAVE_RGG16 00026 m_FileOutput << "group 'tmpgrp' equals surf with name '" << m_szBLAssmMat(ll) << "_top*'" << std::endl; 00027 #else 00028 m_FileOutput << "group 'tmpgrp' equals surf with name '" << m_szBLAssmMat(ll) << "_top'" << std::endl; 00029 #endif 00030 00031 m_FileOutput << "surf in tmpgrp size {RADIAL_MESH_SIZE}" << std::endl; 00032 m_FileOutput << "group '" << m_szBLAssmMat(ll) << "_hole_surfaces' equals surf in tmpgrp"<< std::endl; 00033 m_FileOutput << "surface in group " << m_szBLAssmMat(ll) << "_hole_surfaces scheme hole rad_interval " << m_nBLMatIntervals(ll) << " bias " << m_dBLMatBias(ll) << std::endl; 00034 if(strcmp(m_szSmooth.c_str(),"on") == 0) 00035 m_FileOutput << "surf in group " << m_szBLAssmMat(ll) << "_hole_surfaces" << " smooth scheme condition number beta 2.0 cpu 10" << std::endl; 00036 // m_FileOutput << "mesh surf in group " << m_szBLAssmMat(ll) << "_hole_surfaces" << std::endl; 00037 // } 00038 m_FileOutput << "group 'bl_surfaces' add surf in tmpgrp" << std::endl; 00039 } 00040 } 00041 // variables 00042 int nColor; 00043 std::string color[21] = {" ", "thistle", "grey", "deepskyblue", "red", "purple", "green", 00044 "yellow", "royalblue", "magenta", "cyan", "lightsalmon", "springgreen", 00045 "gold", "orange", "brown", "pink", "khaki", "black", "aquamarine", "mediumslateblue"}; 00046 00047 // if creating only journal file load the geometry file to compute bounding box for automatic size specification 00048 if(m_nJouFlag == 1){ 00049 #if defined (HAVE_ACIS) || defined (HAVE_OCC) 00050 iGeom_load(igeomImpl->instance(), m_szGeomFile.c_str(), NULL, &err, m_szGeomFile.length() , 0); 00051 #endif 00052 } 00053 00054 // get the max and min coordinates of the geometry 00055 #if defined (HAVE_ACIS) || defined (HAVE_OCC) 00056 double x1, y1, z1, x2, y2, z2; 00057 iGeom_getBoundBox( igeomImpl->instance(), &x1, &y1, &z1, &x2, &y2, &z2, &err ); 00058 #endif 00059 00060 int nSideset=m_nNeumannSetId; 00061 00062 m_SchemesFile << "group \"gall\" add vol all\n#{gtempid = Id(\"group\")}\n" << std::endl; 00063 m_SchemesFile << "#{Zmax = BBox_ZMax(\"group\", gtempid)}" << std::endl; 00064 m_SchemesFile << "#{Zmin = BBox_ZMin(\"group\", gtempid)}" << std::endl; 00065 00066 std::string szGrp, szBlock, szSurfTop, szSurfBot, szSize, szSurfSide; 00067 double dHeight = 0.0, dMid = 0.0; 00068 int nTemp = 1; 00069 #if defined (HAVE_ACIS) || defined (HAVE_OCC) 00070 if(m_nDimensions > 0){ 00071 dHeight= fabs(z2 - z1); 00072 dMid = z2 - dHeight/2.0; 00073 } 00074 #endif 00075 00076 // writing to template.jou 00077 m_SchemesFile << "## This file is created by rgg program in MeshKit ##\n"; 00078 m_SchemesFile << "##Schemes " << std::endl ; 00079 m_SchemesFile << "#{CIRCLE =\"circle interval 1 fraction 0.8\"}" << std::endl; 00080 m_SchemesFile << "#{HOLE = \"hole rad_interval 2 bias 0.0\"}" << std::endl; 00081 m_SchemesFile << "#{PAVE = \"pave\"}" << std::endl; 00082 m_SchemesFile << "#{MAP = \"map\"}" << std::endl; 00083 m_SchemesFile << "#{SWEEP = \"sweep\"}" << std::endl; 00084 m_SchemesFile << "#{TET = \"tetmesh\"}" << std::endl; 00085 m_SchemesFile << "#{TOP_EDGE_INTERVAL = " << m_edgeInterval << " }" << std::endl; 00086 m_SchemesFile << "## Dimensions" << std::endl; 00087 if(m_szGeomType == "hexagonal"){ 00088 if(m_nDimensions > 0){ 00089 m_SchemesFile << "#{PITCH =" << m_dMAssmPitch(nTemp, m_nDimensions) << "}" << std::endl; 00090 } 00091 } 00092 else if(m_szGeomType == "rectangular"){ 00093 if(m_nDimensions > 0){ 00094 m_SchemesFile << "#{PITCHX =" << m_dMAssmPitchX(nTemp, m_nDimensions)<< "}" << std::endl; 00095 m_SchemesFile << "#{PITCHY =" << m_dMAssmPitchY(nTemp, m_nDimensions) << "}" << std::endl; 00096 } 00097 } 00098 if( m_nPlanar ==0){ 00099 m_SchemesFile << "#{Z_HEIGHT = Zmax - Zmin}" << std::endl; 00100 m_SchemesFile << "#{Z_MID = (Zmax + Zmin)/2.0}" << std::endl; 00101 } 00102 m_SchemesFile << "##Set Mesh Sizes" << std::endl; 00103 00104 if (m_szMeshType == "hex"){ 00105 // volume only 00106 if(m_nPlanar == 0 ){ 00107 if (m_dAxialSize.GetSize() == 0){ 00108 m_SchemesFile << "#{AXIAL_MESH_SIZE = 0.1*Z_HEIGHT}" << std::endl; 00109 } 00110 else { 00111 m_SchemesFile << "#{AXIAL_MESH_SIZE = " << m_dAxialSize(1) << "}" << std::endl; 00112 } 00113 00114 // create templates for specifying block z intervals 00115 if (m_nDuct > 1){ 00116 m_SchemesFile << "## Set interval along Z direction ## " << std::endl; 00117 00118 for( int p=1; p<= m_nDuct; p++){ 00119 if (m_dAxialSize.GetSize() != 0) 00120 m_SchemesFile << "#{AXIAL_MESH_SIZE" << p << "=" << m_dAxialSize(p) << "}" << std::endl; 00121 else 00122 m_SchemesFile << "#{AXIAL_MESH_SIZE" << p << "= 0.1*Z_HEIGHT}" << std::endl; 00123 m_SchemesFile << "#{BLOCK" << p << "_Z_INTERVAL = AXIAL_MESH_SIZE" << p << "}" << std::endl; 00124 m_SchemesFile << "#{BLOCK" << p << "_ZBOT = " << m_dMZAssm(p, 1) << "}" << std::endl; 00125 m_SchemesFile << "#{BLOCK" << p << "_ZTOP = " << m_dMZAssm(p, 2) << "}" << std::endl; 00126 } 00127 m_SchemesFile << "##" << std::endl; 00128 } 00129 } 00130 if (-1.0 == m_dRadialSize) { 00131 if (m_szGeomType == "hexagonal") 00132 m_SchemesFile << "#{RADIAL_MESH_SIZE = 0.1*PITCH}" << std::endl; 00133 else 00134 m_SchemesFile << "#{RADIAL_MESH_SIZE = 0.02*0.5*(PITCHX+PITCHY)}" << std::endl; 00135 } 00136 else 00137 m_SchemesFile << "#{RADIAL_MESH_SIZE = " << m_dRadialSize << "}" << std::endl; 00138 } 00139 else if (m_szMeshType == "tet"){ 00140 if (-1.0 == m_dTetMeshSize) { 00141 if (m_szGeomType == "hexagonal") 00142 m_SchemesFile << "#{TET_MESH_SIZE = 0.1*PITCH}" << std::endl; 00143 else 00144 m_SchemesFile << "#{TET_MESH_SIZE = 0.02*0.5*(PITCHX+PITCHY)}" << std::endl; 00145 } 00146 else { 00147 m_SchemesFile << "#{TET_MESH_SIZE = " << m_dTetMeshSize << "}" << std::endl; 00148 } 00149 } 00150 00151 if(m_nHblock == -1){ // if more blocks are needed axially, create'em using hexes and the end 00152 // block creation dumps 00153 m_FileOutput << "#Creating blocks, Note: you might need to combine some blocks" << std::endl; 00154 // group creation dumps. each material has a group 00155 m_FileOutput << "#Creating groups" << std::endl; 00156 for(int p=1;p<=(m_szAssmMatAlias.GetSize() - m_nBLAssemblyMat);p++){ 00157 szGrp = "g_"+ m_szAssmMat(p); 00158 m_szAssmMat(p); 00159 if(m_nPlanar ==1){ 00160 #ifdef HAVE_RGG16 00161 m_FileOutput << "group \"" << szGrp << "\" add surface with name \"" << m_szAssmMat(p) <<"*\"" << std::endl; 00162 #else 00163 m_FileOutput << "group \"" << szGrp << "\" add surface with name \"" << m_szAssmMat(p) <<"\"" << std::endl; 00164 #endif 00165 } 00166 else{ 00167 #ifdef HAVE_RGG16 00168 m_FileOutput << "group \"" << szGrp << "\" add body with name \"" << m_szAssmMat(p) <<"*\"" << std::endl; 00169 #else 00170 m_FileOutput << "group \"" << szGrp << "\" add body with name \"" << m_szAssmMat(p) <<"\"" << std::endl; 00171 #endif 00172 } 00173 } 00174 for(int p = 1; p <= (m_szAssmMatAlias.GetSize() - m_nBLAssemblyMat);p++){ 00175 szBlock = "b_"+ m_szAssmMat(p); 00176 szGrp = "g_"+ m_szAssmMat(p); 00177 m_FileOutput << "#{nb" << p << " =NumInGrp('" << szGrp << "')}" << std::endl; 00178 m_FileOutput << "#{Ifndef(nb" << p << ")}" << "\n" << "#{else}" << std::endl; 00179 if(m_nPlanar ==1){ 00180 m_FileOutput << "block " << m_nMaterialSetId + p -1 << " surface in " << szGrp << std::endl; 00181 m_FileOutput << "block " << m_nMaterialSetId + p -1 << " name \"" << szBlock <<"\""<< std::endl; 00182 } 00183 else{ 00184 m_FileOutput << "block " << m_nMaterialSetId + p -1 << " body in " << szGrp << std::endl; 00185 m_FileOutput << "block " << m_nMaterialSetId + p -1 << " name \"" << szBlock <<"\""<< std::endl; 00186 } 00187 m_FileOutput << "#{endif}" << std::endl; 00188 } 00189 m_FileOutput << "#" << std::endl; 00190 } 00191 if(m_szMeshType == "hex"){ 00192 // imprint 00193 m_FileOutput << "#Imprint geometry" << std::endl; 00194 m_FileOutput << "imprint all" << std::endl; 00195 m_FileOutput << "#" << std::endl; 00196 // merge 00197 00198 m_FileOutput << "Merge Tolerance " << m_dMergeTol << std::endl; 00199 m_FileOutput << "#" << std::endl; 00200 00201 m_FileOutput << "#Merge geometry" << std::endl; 00202 m_FileOutput << "merge all" << std::endl; 00203 m_FileOutput << "#" << std::endl; 00204 } 00205 00206 // for info keyword 00207 if(strcmp(m_szInfo.c_str(),"on") == 0){ 00208 int temp = 9700; 00209 m_FileOutput << "# stuff for info keyword, remove if not desired " << std::endl; 00210 m_FileOutput << "# putting pins in seperate blocks " << std::endl; 00211 m_FileOutput << "#" << std::endl; 00212 for (int i=0; i<m_nTotalPincells; i++){ 00213 m_FileOutput << "#You might have to use:\n#set duplicate block elements on\n#This is required for creating blocks with pin materials only" << std::endl; 00214 #ifdef HAVE_RGG16 00215 m_FileOutput << "group 'g"<< i+m_nStartpinid << "' add body with name '*_xp" << i+m_nStartpinid << "_*'" << std::endl; 00216 #else 00217 m_FileOutput << "group 'g"<< i+m_nStartpinid << "' add body with name '_xp" << i+m_nStartpinid << "_'" << std::endl; 00218 #endif 00219 m_FileOutput << "#{nbody" << i+1 << " =NumInGrp('g" <<i+m_nStartpinid << "')}" << std::endl; 00220 m_FileOutput << "#{Ifndef(nbody" << i+1 << ")}" << "\n" << "#{else}" << std::endl; 00221 m_FileOutput << "block " << temp+i << " body in group g" << i+m_nStartpinid << std::endl; 00222 m_FileOutput << "block " << temp+i << " name '_xp" << i+m_nStartpinid << "'" << std::endl; 00223 m_FileOutput << "#{endif}" << std::endl; 00224 } 00225 } 00226 00227 //surface only 00228 if(m_nPlanar ==1){ 00229 m_FileOutput << "# Pointing surface normals to 0.0, 0.0, -1.0 or -ve Z or correct STARCCM+ cell-face orientation" << std::endl; 00230 m_FileOutput << "surface all normal opposite" << std::endl; 00231 m_FileOutput << "#" << std::endl; 00232 } 00233 // volume only 00234 else{ 00235 if(m_szSideset == "yes"){ 00236 00237 // rename the skin surfaces, so that they don't appear as sidesets 00238 for (int p=1; p<=m_nDuct; p++){ 00239 for(int q=1;q<=m_nSides; q++){ 00240 #ifdef HAVE_RGG16 00241 m_FileOutput << "group 'edge" << (m_nSides*(p-1) + q ) <<"' equals curve with name 'side_edge" 00242 << (m_nSides*(p-1) + q ) << "*'" << std::endl; 00243 #else 00244 m_FileOutput << "group 'edge" << (m_nSides*(p-1) + q ) <<"' equals curve with name 'side_edge" 00245 << (m_nSides*(p-1) + q ) << "@'" << std::endl; 00246 #endif 00247 00248 00249 m_FileOutput << "group 'vt" << (m_nSides*(p-1) + q ) <<"' equals vertex with z_max == z_min in curve in edge" 00250 << (m_nSides*(p-1) + q ) << std::endl; 00251 00252 } 00253 } 00254 00255 // creating groups for vertices on the top surface of the duct 00256 for (int p=1; p<=m_nDuct; p++){ 00257 for(int q=1;q<=m_nSides; q++){ 00258 00259 if(q != m_nSides){ 00260 m_FileOutput << "group 'v" << (m_nSides*(p-1) + q ) <<"' intersect group vt" << (m_nSides*(p-1) + q ) 00261 << " with group vt" << (m_nSides*(p-1) + q + 1 ) << std::endl; 00262 } 00263 else { 00264 m_FileOutput << "group 'v" << (m_nSides*(p-1) + q ) <<"' intersect group vt" << (m_nSides*(p-1) + q ) 00265 << " with group vt" << (m_nSides*(p-1) + 1 ) << std::endl; 00266 } 00267 } 00268 } 00269 // creating temp surfaces groups 00270 for (int p=1; p<=m_nDuct; p++){ 00271 for(int q=1;q<=m_nSides; q++){ 00272 m_FileOutput << "group 'st" << (m_nSides*(p-1) + q ) <<"' equals surface with z_max <> z_min in vert in v" 00273 << (m_nSides*(p-1) + q ) << "'" << std::endl; 00274 } 00275 } 00276 00277 // creating surface groups for obtaining surfaces 00278 for (int p=1; p<=m_nDuct; p++){ 00279 for(int q=1;q<=m_nSides; q++){ 00280 if(q != 1){ 00281 m_FileOutput << "group 's" << (m_nSides*(p-1) + q ) <<"' intersect group st" << (m_nSides*(p-1) + q ) 00282 << " with group st" << (m_nSides*(p-1) + q - 1 ) << std::endl; 00283 } 00284 else { 00285 m_FileOutput << "group 's" << (m_nSides*(p-1) + q ) <<"' intersect group st" << (m_nSides*(p-1) + q ) 00286 << " with group st" << (m_nSides*(p-1) + m_nSides ) << std::endl; 00287 } 00288 } 00289 } 00290 00291 // renaming the skin side surfaces 00292 for (int p=1; p<=m_nDuct; p++){ 00293 for(int q=1;q<=m_nSides; q++){ 00294 m_FileOutput << "surface in group s" << (m_nSides*(p-1) + q ) << " rename 'side_surface" 00295 << (m_nSides*(p-1) + q ) << "'" << std::endl; 00296 00297 } 00298 } 00299 } 00300 00301 if(m_szMeshType == "hex"){ 00302 00303 //now set the sizes 00304 m_FileOutput << "#Set Meshing Scheme and Sizes, use template.jou to specify sizes" << std::endl; 00305 00306 for(int p=1;p<=(m_szAssmMatAlias.GetSize() - m_nBLAssemblyMat);p++){ 00307 szGrp = "g_"+ m_szAssmMat(p); 00308 szSize = m_szAssmMat(p) + "_size"; 00309 szSurfBot = m_szAssmMat(p) + "_bot"; 00310 szSize = m_szAssmMat(p) + "_surf_size"; 00311 #ifdef HAVE_RGG16 00312 m_FileOutput << "group 'tmpgrp' equals surface with name \"" << szSurfBot << "*\"" << std::endl; 00313 #else 00314 m_FileOutput << "group 'tmpgrp' equals surface with name \"" << szSurfBot << "\"" << std::endl; 00315 #endif 00316 m_FileOutput << "surface in tmpgrp size {" << szSize <<"}" << std::endl; 00317 } 00318 m_FileOutput << "#" << std::endl; 00319 } 00320 } 00321 if(m_szMeshType == "hex"){ 00322 // some more common stuff meshing top surfaces set the sizes and mesh 00323 m_FileOutput << "#Surfaces mesh, use template.jou to specify sizes" << std::endl; 00324 for(int p=1;p<=(m_szAssmMatAlias.GetSize() - m_nBLAssemblyMat);p++){ 00325 szSurfTop = m_szAssmMat(p) + "_top"; 00326 szGrp = "g_"+ m_szAssmMat(p); 00327 szSize = m_szAssmMat(p) + "_surf_size"; 00328 if(m_szMeshScheme == "hole" && m_nBLAssemblyMat == 0){ 00329 #ifdef HAVE_RGG16 00330 m_FileOutput << "group 'tmpgrp' equals surface with name \"" << szSurfTop << "*\"" << std::endl; 00331 #else 00332 m_FileOutput << "group 'tmpgrp' equals surface with name \"" << szSurfTop << "\"" << std::endl; 00333 #endif 00334 m_FileOutput << "group 'remove_hole' intersect group tmpgrp with group hole_surfaces" << std::endl; 00335 m_FileOutput << "#{nIntersect=NumInGrp('remove_hole')}" << std::endl; 00336 m_FileOutput << "#{If(nIntersect==0)}" << std::endl; 00337 m_FileOutput << "surface in tmpgrp size {" << szSize <<"}" << std::endl; 00338 m_FileOutput << "surface in tmpgrp scheme {" << "PAVE" << "}" << std::endl; 00339 m_FileOutput << "#{endif}" << std::endl; 00340 } 00341 else{ 00342 #ifdef HAVE_RGG16 00343 m_FileOutput << "group 'tmpgrp' equals surface with name \"" << szSurfTop << "*\"" << std::endl; 00344 #else 00345 m_FileOutput << "group 'tmpgrp' equals surface with name \"" << szSurfTop << "\"" << std::endl; 00346 #endif 00347 m_FileOutput << "surface in tmpgrp size {" << szSize <<"}" << std::endl; 00348 m_FileOutput << "surface in tmpgrp scheme {" << "PAVE" << "}" << std::endl; 00349 } 00350 00351 if (p==1 && m_edgeInterval != 99){ 00352 #ifdef HAVE_RGG16 00353 m_FileOutput << "group 'sz_edges" <<"' equals curve with name 'side_edge*'"<< std::endl; 00354 #else 00355 m_FileOutput << "group 'sz_edges" <<"' equals curve with name 'side_edge'"<< std::endl; 00356 #endif 00357 m_FileOutput << "curve in sz_edges interval {TOP_EDGE_INTERVAL}" << std::endl; 00358 } 00359 00360 // m_FileOutput << "mesh surface in " << szGrp << "\n#" << std::endl; 00361 00362 // dumping these sizes schemes.jou also 00363 m_SchemesFile << "#{" << szSize <<" = RADIAL_MESH_SIZE}" << std::endl; 00364 } 00365 m_FileOutput << "#" << std::endl; 00366 00367 // mesh all command after meshing surface 00368 if (m_nDuct <= 1 ){ 00369 #ifdef HAVE_RGG16 00370 m_FileOutput << "group 'tmpgrp' add surface with name '*_top*'" << std::endl; 00371 #else 00372 m_FileOutput << "group 'tmpgrp' add surface with name '_top'" << std::endl; 00373 #endif 00374 if (m_nBLAssemblyMat !=0){ // only if boundary layers are specified 00375 m_FileOutput << "group 'tmpgrp1' subtract innerduct from tmpgrp" << std::endl; 00376 m_FileOutput << "group 'tmpgrp2' subtract bl_surfaces from tmpgrp1" << std::endl; 00377 m_FileOutput << "mesh tmpgrp2" << std::endl; 00378 } 00379 else 00380 { 00381 m_FileOutput << "mesh tmpgrp" << std::endl; 00382 } 00383 } 00384 else { 00385 m_FileOutput << "#Meshing top surface" << std::endl; 00386 //m_FileOutput << "mesh surface with z_coord = " << z2 << std::endl; 00387 if(m_szMeshScheme == "hole" && m_nBLAssemblyMat == 0){ 00388 #ifdef HAVE_RGG16 00389 m_FileOutput << "group 'tmpgrp' equals surface with name \"" << szSurfTop << "*\"" << std::endl; 00390 #else 00391 m_FileOutput << "group 'tmpgrp' equals surface with name \"" << szSurfTop << "\"" << std::endl; 00392 #endif 00393 m_FileOutput << "group 'remove_hole' intersect group tmpgrp with group hole_surfaces" << std::endl; 00394 m_FileOutput << "#{nIntersect=NumInGrp('remove_hole')}" << std::endl; 00395 m_FileOutput << "#{If(nIntersect==0)}" << std::endl; 00396 m_FileOutput << "surface in tmpgrp size {" << szSize <<"}" << std::endl; 00397 m_FileOutput << "surface in tmpgrp scheme {" << "PAVE" << "}" << std::endl; 00398 m_FileOutput << "#{endif}" << std::endl; 00399 m_FileOutput << "mesh surface with z_coord = {Zmax}" << std::endl; 00400 } 00401 else if (m_nBLAssemblyMat != 0){ // mesh by spefifying boundary layers or mesh partially 00402 #ifdef HAVE_RGG16 00403 m_FileOutput << "group 'tmpgrp' equals surface with name '*_top*'" << std::endl; 00404 #else 00405 m_FileOutput << "group 'tmpgrp' equals surface with name '_top'" << std::endl; 00406 #endif 00407 m_FileOutput << "group 'tmpgrp1' subtract innerduct from tmpgrp" << std::endl; 00408 m_FileOutput << "group 'tmpgrp2' subtract bl_surfaces from tmpgrp1" << std::endl; 00409 m_FileOutput << "group 'tmpgrp3' equals surface in tmpgrp2 with z_coord = {Zmax}" << std::endl; 00410 00411 m_FileOutput << "surface in tmpgrp3 size {" << szSize <<"}" << std::endl; 00412 m_FileOutput << "surface in tmpgrp3 scheme {" << "PAVE" << "}" << std::endl; 00413 m_FileOutput << "mesh tmpgrp3" << std::endl; 00414 00415 } 00416 else { 00417 #ifdef HAVE_RGG16 00418 m_FileOutput << "group 'tmpgrp' equals surface with name \"" << szSurfTop << "*\"" << std::endl; 00419 #else 00420 m_FileOutput << "group 'tmpgrp' equals surface with name \"" << szSurfTop << "\"" << std::endl; 00421 #endif 00422 m_FileOutput << "surface in tmpgrp size {" << szSize <<"}" << std::endl; 00423 m_FileOutput << "surface in tmpgrp scheme {" << "PAVE" << "}" << std::endl; 00424 m_FileOutput << "mesh surface with z_coord = {Zmax}" << std::endl; 00425 } 00426 } 00427 // This part is for mesh top surfaces only when boundary layer surfaces are specified 00428 if (m_nBLAssemblyMat !=0){ 00429 // Also look for material name in BL material list 00430 for (int ll=1; ll<= m_nBLAssemblyMat; ll++){ 00431 bool duct = false; 00432 for (int n = 0; n < (int) m_szDuctMats.size(); n++){ 00433 if (strcmp(m_szDuctMats[n].c_str(), m_szBLAssmMat(ll).c_str()) == 0) 00434 duct = true; 00435 else 00436 duct = false; 00437 } 00438 if (duct){ //We want to use this part with pair node only for ducts and not cylinderical pins so check if this material is duct or not 00439 if (m_edgeInterval != 99) 00440 m_FileOutput << "curve in surf in " << m_szBLAssmMat(ll) << "_hole_surfaces interval {TOP_EDGE_INTERVAL}"<< std::endl; 00441 m_FileOutput << "mesh vertex in surf in " << m_szBLAssmMat(ll) << "_hole_surfaces with z_coord = {Zmax}" << std::endl; 00442 m_FileOutput << "#{corner1 = Id('node')} " << std::endl; 00443 m_FileOutput << "group 'gcurves' equals curve in surface in " << m_szBLAssmMat(ll) << "_hole_surfaces'" << std::endl; 00444 m_FileOutput << "#{_cntr=0} " << "\n" << 00445 "#{_tmp_dis=0} " << "\n" << 00446 "#{_min_dis=0} " << "\n" << 00447 "#{_closest_node=11} " << "\n" << 00448 00449 "group 'v_node' equals node in volume in surface in " << m_szBLAssmMat(ll) << "_hole_surfaces" << "\n" << 00450 "group v_node remove node {corner1} " << "\n" << 00451 "#{xc1 = Nx(corner1)} " << "\n" << 00452 "#{yc1 = Ny(corner1)} " << "\n" << 00453 "#{_num_nodes = NumInGrp('v_node')} " << "\n" << 00454 "#{_min_dis = 1.e10} " << "\n" << 00455 "#{Loop(20)} " << "\n" << 00456 "#{_node_id = GroupMemberId('v_node', 'node', _cntr)} " << "\n" << 00457 "#{_xni = Nx(_node_id)} " << "\n" << 00458 "#{_yni = Ny(_node_id)} " << "\n" << 00459 "#{_tmp_dis = (xc1 - _xni)*(xc1 -_xni) + (yc1 -_yni)*(yc1 - _yni)} " << "\n" << 00460 "#{if(_tmp_dis < _min_dis)} " << "\n" << 00461 "#{ _closest_node = _node_id} " << "\n" << 00462 "# {_min_dis=_tmp_dis} " << "\n" << 00463 "#{endif} " << "\n" << 00464 "#{_cntr++} " << "\n" << 00465 "#{if (_cntr >_num_nodes)} " << "\n" << 00466 "#{break} " << "\n" << 00467 "#{endif} " << "\n" << 00468 "#{EndLoop} " << "\n" << std::endl; 00469 00470 // This must be used only for ducts 00471 // if (m_szBLAssmMat(ll) == duct material or it's not pin material') 00472 m_FileOutput << "surf in group " << m_szBLAssmMat(ll) << "_hole_surfaces scheme hole rad_intervals " 00473 << m_nBLMatIntervals(ll) << " bias " << m_dBLMatBias(ll) << " pair node {corner1} with node {_closest_node}" << std::endl; 00474 } 00475 else { // this is regular cylinder 00476 m_FileOutput << "surf in group " << m_szBLAssmMat(ll) << "_hole_surfaces scheme hole rad_intervals " 00477 << m_nBLMatIntervals(ll) << " bias " << m_dBLMatBias(ll) << std::endl; 00478 } 00479 00480 m_FileOutput << "mesh surf in group " << m_szBLAssmMat(ll) << "_hole_surfaces with z_coord = {Zmax}" << std::endl; 00481 if(strcmp(m_szSmooth.c_str(),"on") == 0) 00482 m_FileOutput << "smooth surf in group " << m_szBLAssmMat(ll) << "_hole_surfaces" << std::endl; 00483 } 00484 m_FileOutput << "mesh surf in innerduct with z_coord = {Zmax}" << std::endl; 00485 } 00486 00487 if(m_nPlanar == 0){ // volumes only 00488 if (m_nDuct == 1){ 00489 m_FileOutput << "surf with z_coord > {Z_MID -.1*Z_HEIGHT}" << 00490 " and z_coord < {Z_MID + .1*Z_HEIGHT} size {AXIAL_MESH_SIZE}" << std::endl ; 00491 m_FileOutput << "mesh vol all" << std::endl; 00492 } 00493 else if (m_nDuct > 1){ 00494 m_FileOutput << "### Setting Z intervals on ducts and meshing along Z " << std::endl; 00495 for( int p=m_nDuct; p>= 1; p--){ 00496 if(dMid == 0){ // z - centered 00497 m_FileOutput << "surf with z_coord > " << m_dMZAssm(p, 1) - dHeight/2.0 00498 << " and z_coord < " << m_dMZAssm(p, 2) - dHeight/2.0 << " interval " << "{BLOCK" << p << "_Z_INTERVAL}" << std::endl; 00499 m_FileOutput << "mesh vol with z_coord > " << m_dMZAssm(p, 1) - dHeight/2.0 00500 << " and z_coord < " << m_dMZAssm(p, 2) - dHeight/2.0 << std::endl; 00501 } 00502 else{ 00503 m_FileOutput << "surf with z_coord > " << m_dMZAssm(p, 1) 00504 << " and z_coord < " << m_dMZAssm(p, 2) << " interval " << "{BLOCK" << p << "_Z_INTERVAL}" << std::endl; 00505 m_FileOutput << "mesh vol with z_coord > " << m_dMZAssm(p, 1) 00506 << " and z_coord < " << m_dMZAssm(p, 2) << std::endl; 00507 00508 m_FileOutput << "##" << std::endl; 00509 } 00510 } 00511 } 00512 } 00513 } 00514 00515 else if(m_szMeshType == "tet"){ 00516 m_FileOutput << "##"<< std::endl; 00517 m_FileOutput << "# groupings for creating vertex groups"<< std::endl; 00518 for (int p=1; p<=m_nDuct; p++){ 00519 for(int q=1;q<=m_nSides; q++){ 00520 #ifdef HAVE_RGG16 00521 m_FileOutput << "group 'edge" << (m_nSides*(p-1) + q ) <<"' equals curve with name 'side_edge" 00522 << (m_nSides*(p-1) + q ) << "*'" << std::endl; 00523 #else 00524 m_FileOutput << "group 'edge" << (m_nSides*(p-1) + q ) <<"' equals curve with name 'side_edge" 00525 << (m_nSides*(p-1) + q ) << "@'" << std::endl; 00526 #endif 00527 00528 m_FileOutput << "group 'vt" << (m_nSides*(p-1) + q ) <<"' equals vertex with z_max == z_min in curve in edge" 00529 << (m_nSides*(p-1) + q ) << std::endl; 00530 00531 } 00532 } 00533 00534 // creating groups for vertices on the top surface of the duct 00535 for (int p=1; p<=m_nDuct; p++){ 00536 for(int q=1;q<=m_nSides; q++){ 00537 00538 if(q != m_nSides){ 00539 m_FileOutput << "group 'v" << (m_nSides*(p-1) + q ) <<"' intersect group vt" << (m_nSides*(p-1) + q ) 00540 << " with group vt" << (m_nSides*(p-1) + q + 1 ) << std::endl; 00541 } 00542 else { 00543 m_FileOutput << "group 'v" << (m_nSides*(p-1) + q ) <<"' intersect group vt" << (m_nSides*(p-1) + q ) 00544 << " with group vt" << (m_nSides*(p-1) + 1 ) << std::endl; 00545 } 00546 } 00547 } 00548 00549 // creating temp surfaces groups 00550 for (int p=1; p<=m_nDuct; p++){ 00551 for(int q=1;q<=m_nSides; q++){ 00552 m_FileOutput << "group 'st" << (m_nSides*(p-1) + q ) <<"' equals surface with z_max <> z_min in vert in v" 00553 << (m_nSides*(p-1) + q ) << "'" << std::endl; 00554 } 00555 } 00556 00557 // creating side curve and surface groups 00558 for (int p=1; p<=m_nDuct; p++){ 00559 for(int q=1;q<=m_nSides; q++){ 00560 00561 m_FileOutput << "group 'c" << (m_nSides*(p-1) + q ) <<"' equals curve with z_max <> z_min in vert in v" 00562 << (m_nSides*(p-1) + q ) << std::endl; 00563 00564 if(q != 1){ 00565 m_FileOutput << "group 's" << (m_nSides*(p-1) + q ) <<"' intersect group st" << (m_nSides*(p-1) + q ) 00566 << " with group st" << (m_nSides*(p-1) + q - 1 ) << std::endl; 00567 } 00568 else { 00569 m_FileOutput << "group 's" << (m_nSides*(p-1) + q ) <<"' intersect group st" << (m_nSides*(p-1) + q ) 00570 << " with group st" << (m_nSides*(p-1) + m_nSides ) << std::endl; 00571 } 00572 } 00573 } 00574 00575 // renaming the side surfaces for getting the split surfaces later 00576 for (int p=1; p<=m_nDuct; p++){ 00577 for(int q=1;q<=m_nSides; q++){ 00578 m_FileOutput << "surface in group s" << (m_nSides*(p-1) + q ) << " rename 'side_surface" 00579 << (m_nSides*(p-1) + q ) << "'" << std::endl; 00580 } 00581 } 00582 00583 // splitting the surfaces 00584 for (int p=1; p<=m_nDuct; p++){ 00585 for(int q=1;q<=m_nSides; q++){ 00586 00587 m_FileOutput << "split surface in group s" << (m_nSides*(p-1) + q ) <<" direction curve in group c" 00588 << (m_nSides*(p-1) + q ) << std::endl; 00589 } 00590 } 00591 00592 // get all the split surfaces in individual groups 00593 for (int p=1; p<=m_nDuct; p++){ 00594 for(int q=1;q<=m_nSides; q++){ 00595 #ifdef HAVE_RGG16 00596 m_FileOutput << "group 'sname" << (m_nSides*(p-1) + q ) << "' equals surface with name 'side_surface" 00597 << (m_nSides*(p-1) + q ) << "*'"<< std::endl; 00598 #else 00599 m_FileOutput << "group 'sname" << (m_nSides*(p-1) + q ) << "' equals surface with name 'side_surface" 00600 << (m_nSides*(p-1) + q ) << "'"<< std::endl; 00601 #endif 00602 m_FileOutput << "group 'svert" << (m_nSides*(p-1) + q ) << "' equals surface in vert in v" 00603 << (m_nSides*(p-1) + q ) << std::endl; 00604 m_FileOutput << "group 'ssplit" << (m_nSides*(p-1) + q ) << "' intersect group sname" << (m_nSides*(p-1) + q ) 00605 << " with group svert" << (m_nSides*(p-1) + q ) << std::endl; 00606 } 00607 } 00608 00609 // get all the split surfaces in individual groups 00610 for (int p=1; p<=m_nDuct; p++){ 00611 for(int q=1;q<=m_nSides; q++){ 00612 00613 if(q != 1){ 00614 m_FileOutput << "group 'ssplit_" << (m_nSides*(p-1) + q ) <<"' intersect group sname" << (m_nSides*(p-1) + q ) 00615 << " with group svert" << (m_nSides*(p-1) + q - 1 ) << std::endl; 00616 } 00617 else { 00618 m_FileOutput << "group 'ssplit_" << (m_nSides*(p-1) + q ) <<"' intersect group sname" << (m_nSides*(p-1) + q ) 00619 << " with group svert" << (m_nSides*(p-1) + m_nSides ) << std::endl; 00620 } 00621 } 00622 } 00623 // imprint 00624 m_FileOutput << "#Imprint geometry" << std::endl; 00625 m_FileOutput << "imprint all" << std::endl; 00626 m_FileOutput << "#" << std::endl; 00627 m_FileOutput << "Merge Tolerance " << m_dMergeTol << std::endl; 00628 m_FileOutput << "#" << std::endl; 00629 00630 // merge 00631 m_FileOutput << "#Merge geometry" << std::endl; 00632 m_FileOutput << "merge all" << std::endl; 00633 m_FileOutput << "#" << std::endl; 00634 00635 m_FileOutput << "#Set mesh scheme and size" << std::endl; 00636 m_FileOutput << "volume all scheme {TET} size {TET_MESH_SIZE}" << std::endl; 00637 00638 // mesh one side of each duct, such that one is flipped mesh of the other 00639 for (int p=1; p<=m_nDuct; p++){ 00640 00641 m_FileOutput << "mesh surface in group ssplit" << (m_nSides*(p-1) + 1) << std::endl; 00642 00643 m_FileOutput << "surface in group ssplit_" << (m_nSides*(p-1) + 1) << " scheme copy source surface in group ssplit" 00644 << (m_nSides*(p-1) + 1) 00645 << " source curve in group c" << (m_nSides*(p-1) + 1 ) << " target curve in group c" << (m_nSides*(p-1) + m_nSides ) 00646 << " source vertex in group v" << (m_nSides*(p-1) + 1) << " target vertex in group v" << (m_nSides*(p-1) + m_nSides ) 00647 << " nosmoothing" << std::endl; 00648 00649 m_FileOutput << "mesh surface in group ssplit_" << (m_nSides*(p-1) + 1) << std::endl; 00650 } 00651 00652 // setting the copy mesh commands on the above pair of split surfaces to have all surfaces symmetrical 00653 for (int p=1; p<=m_nDuct; p++){ 00654 for(int q=1;q<=m_nSides; q++){ 00655 if(q != m_nSides){ 00656 #ifdef HAVE_RGG16 00657 m_FileOutput << "copy mesh surface in ssplit" << (m_nSides*(p-1) + 1) 00658 << " onto surface in ssplit" << (m_nSides*(p-1) + q + 1 ) 00659 << " source curve in group c" << (m_nSides*(p-1) + 1) 00660 << " source vertex in group v" << (m_nSides*(p-1) + 1) 00661 << " target curve in group c" << (m_nSides*(p-1) + q + 1) 00662 << " target vertex in group v" << (m_nSides*(p-1) + q + 1) << " " << std::endl; 00663 00664 m_FileOutput << "copy mesh surface in ssplit_" << (m_nSides*(p-1) + 1 ) 00665 << " onto surface in ssplit_" << (m_nSides*(p-1) + q +1 ) 00666 << " source curve in group c" << (m_nSides*p) 00667 << " source vertex in group v" << (m_nSides*p) 00668 << " target curve in group c" << (m_nSides*(p-1) + q) 00669 << " target vertex in group v" << (m_nSides*(p-1) + q) << " " << std::endl; 00670 #else 00671 m_FileOutput << "copy mesh surface in ssplit" << (m_nSides*(p-1) + 1) 00672 << " onto surface in ssplit" << (m_nSides*(p-1) + q + 1 ) 00673 << " source vertex in group v" << (m_nSides*(p-1) + 1) 00674 << " target vertex in group v" << (m_nSides*(p-1) + q + 1) << " nosmoothing" << std::endl; 00675 00676 m_FileOutput << "copy mesh surface in ssplit_" << (m_nSides*(p-1) + 1 ) 00677 << " onto surface in ssplit_" << (m_nSides*(p-1) + q +1 ) 00678 << " source vertex in group v" << (m_nSides*p) 00679 << " target vertex in group v" << (m_nSides*(p-1) + q) << " nosmoothing" << std::endl; 00680 #endif 00681 00682 } 00683 else{ 00684 // do nothing 00685 } 00686 } 00687 } 00688 00689 m_FileOutput << "# Mesh all volumes now" << std::endl; 00690 m_FileOutput << "mesh vol all" << std::endl; 00691 } 00692 00693 // create and sidesets after meshing 00694 m_FileOutput << "#" << std::endl; 00695 // } 00696 if(m_szSideset == "yes"){ 00697 // top surface sidesets 00698 m_FileOutput << "#Creating top surface sidesets" << std::endl; 00699 m_FileOutput << "create group 'surfall'" << std::endl; 00700 for(int p=1;p<=(m_szAssmMatAlias.GetSize() - m_nBLAssemblyMat);p++){ 00701 ++nSideset; 00702 szSurfTop = m_szAssmMat(p)+"_top"; 00703 // Avoid creation if empty sideset 00704 #ifdef HAVE_RGG16 00705 m_FileOutput << "group 'tmpgrp' equals surface with name '" << szSurfTop << "*' in vol in block " << m_nMaterialSetId + p -1 << std::endl; 00706 #else 00707 m_FileOutput << "group 'tmpgrp' equals surface with name '" << szSurfTop << "' in vol in block " << m_nMaterialSetId + p -1 << std::endl; 00708 #endif 00709 m_FileOutput << "sideset " << nSideset << " surface in tmpgrp " << std::endl; 00710 m_FileOutput << "sideset " << nSideset << " name \"" << szSurfTop << "_ss\"" << std::endl; 00711 } 00712 m_FileOutput << "#" << std::endl; 00713 for(int p=1;p<=m_nBLAssemblyMat;p++){ 00714 ++nSideset; 00715 00716 // Avoid creation if empty sideset 00717 #ifdef HAVE_RGG16 00718 m_FileOutput << "group 'tmpgrp' equals surface with name '" << szSurfTop << "*' in vol in block " << m_nMaterialSetId + p -1 << std::endl; 00719 #else 00720 m_FileOutput << "group 'tmpgrp' equals surface with name '" << szSurfTop << "' in vol in block " << m_nMaterialSetId + p -1 << std::endl; 00721 #endif 00722 m_FileOutput << "sideset " << nSideset << " surface in tmpgrp " << std::endl; 00723 m_FileOutput << "sideset " << nSideset << " name \"" << szSurfTop << "_ss\"" << std::endl; 00724 } 00725 m_FileOutput << "#" << std::endl; 00726 } 00727 00728 00729 if(m_nPlanar ==0){ 00730 if(m_szSideset == "yes"){ 00731 // now create bot and side sideset 00732 m_FileOutput << "#Creating bot/side surface sidesets" << std::endl; 00733 for(int p=1;p<=(m_szAssmMatAlias.GetSize() - m_nBLAssemblyMat);p++){ 00734 szSurfTop = m_szAssmMat(p)+"_bot"; 00735 m_FileOutput << "#" << std::endl; 00736 ++nSideset; 00737 #ifdef HAVE_RGG16 00738 m_FileOutput << "group 'tmpgrp' equals surface with name '" << szSurfTop << "*' in vol in block " << m_nMaterialSetId + p -1 << std::endl; 00739 #else 00740 m_FileOutput << "group 'tmpgrp' equals surface with name '" << szSurfTop << "' in vol in block " << m_nMaterialSetId + p -1 << std::endl; 00741 #endif 00742 m_FileOutput << "sideset " << nSideset << " surface in tmpgrp " << std::endl; 00743 m_FileOutput << "sideset " << nSideset << " name \"" << szSurfTop << "_ss\"" << std::endl; 00744 } 00745 for(int p=1;p<=m_nBLAssemblyMat;p++){ 00746 ++nSideset; 00747 szSurfTop = m_szAssmMat(p)+"_bot"; 00748 00749 // Avoid creation if empty sideset 00750 #ifdef HAVE_RGG16 00751 m_FileOutput << "group 'tmpgrp' equals surface with name '" << szSurfTop << "*" << std::endl; 00752 #else 00753 m_FileOutput << "group 'tmpgrp' equals surface with name '" << szSurfTop << std::endl; 00754 #endif 00755 m_FileOutput << "sideset " << nSideset << " surface in tmpgrp " << std::endl; 00756 m_FileOutput << "sideset " << nSideset << " name \"" << szSurfTop << "_ss\"" << std::endl; 00757 } 00758 m_FileOutput << "#" << std::endl; 00759 00760 for(int p=1;p<=(m_szAssmMatAlias.GetSize() - m_nBLAssemblyMat);p++){ 00761 szSurfSide = m_szAssmMat(p)+"_side"; 00762 ++nSideset; 00763 if(m_szGeomType == "hexagonal"){ 00764 for (int u=1; u<=6;u++){ 00765 #ifdef HAVE_RGG16 00766 m_FileOutput << "group 'tmpgrp" << u <<"' equals surf with name '" << szSurfSide << u << "*'" << std::endl; 00767 #else 00768 m_FileOutput << "group 'tmpgrp" << u <<"' equals surf with name '" << szSurfSide << u << "'" << std::endl; 00769 #endif 00770 } 00771 m_FileOutput << "sideset " << nSideset << " surface in tmpgrp1 tmpgrp2 tmpgrp3 tmpgrp4 tmpgrp5 tmpgrp6" << std::endl; 00772 m_FileOutput << "sideset " << nSideset << " name \"" << szSurfSide << "1_ss\"" << std::endl; 00773 ++nSideset; 00774 } 00775 if(m_szGeomType == "hexagonal"){ 00776 for (int u=7; u<=12;u++){ 00777 #ifdef HAVE_RGG16 00778 m_FileOutput << "group 'tmpgrp" << u <<"' equals surf with name '" << szSurfSide << u << "*'" << std::endl; 00779 #else 00780 m_FileOutput << "group 'tmpgrp" << u <<"' equals surf with name '" << szSurfSide << u << "'" << std::endl; 00781 #endif 00782 } 00783 m_FileOutput << "sideset " << nSideset << " surface in tmpgrp7 tmpgrp8 tmpgrp9 tmpgrp10 tmpgrp11 tmpgrp12" << std::endl; 00784 m_FileOutput << "sideset " << nSideset << " name \"" << szSurfSide << "2_ss\"" << std::endl; 00785 } 00786 if(m_szGeomType == "rectangular"){ 00787 for (int u=1; u<=4;u++){ 00788 #ifdef HAVE_RGG16 00789 m_FileOutput << "group 'tmpgrp" << u <<"' equals surf with name '" << szSurfSide << u << "*'" << std::endl; 00790 #else 00791 m_FileOutput << "group 'tmpgrp" << u <<"' equals surf with name '" << szSurfSide << u << "'" << std::endl; 00792 #endif 00793 } 00794 m_FileOutput << "sideset " << nSideset << " surface in tmpgrp1 tmpgrp2 tmpgrp3 tmpgrp4'" << std::endl; 00795 m_FileOutput << "sideset " << nSideset << " name \"" << szSurfSide << "2_ss\"" << std::endl; 00796 ++nSideset; 00797 } 00798 00799 if(m_szGeomType == "rectangular"){ 00800 for (int u=5; u<=8;u++){ 00801 #ifdef HAVE_RGG16 00802 m_FileOutput << "group 'tmpgrp" << u <<"' equals surf with name '" << szSurfSide << u << "*'" << std::endl; 00803 #else 00804 m_FileOutput << "group 'tmpgrp" << u <<"' equals surf with name '" << szSurfSide << u << "'" << std::endl; 00805 #endif 00806 } 00807 m_FileOutput << "sideset " << nSideset << " surface in tmpgrp5 tmpgrp6 tmpgrp7 tmpgrp8'" << std::endl; 00808 m_FileOutput << "sideset " << nSideset << " name \"" << szSurfSide << "2_ss\"" << std::endl; 00809 } 00810 } 00811 00812 00813 m_FileOutput << "#" << std::endl; 00814 00815 m_FileOutput << "#Creating sideset for outer most side surfaces" << std::endl; 00816 ++nSideset; 00817 #ifdef HAVE_RGG16 00818 m_FileOutput << "group 'tmpgrp' equals surf with name 'side_surface*'" << std::endl; 00819 #else 00820 m_FileOutput << "group 'tmpgrp' equals surf with name 'side_surface'" << std::endl; 00821 #endif 00822 m_FileOutput << "sideset " << nSideset << " surface in tmpgrp " << std::endl; 00823 m_FileOutput << "sideset " << nSideset << " name \"" << "outer_side_ss\"" << std::endl; 00824 } 00825 } 00826 if(m_nHblock != -1){ // if more blocks are needed axially, create'em using hexes and the end 00827 // block creation dumps 00828 m_FileOutput << "#Creating blocks, Note: you might need to combine some blocks" << std::endl; 00829 // group creation dumps. each material has a group 00830 m_FileOutput << "#Creating groups" << std::endl; 00831 if(m_szMeshType == "hex"){ 00832 for(int p=1;p<=(m_szAssmMatAlias.GetSize() - m_nBLAssemblyMat);p++){ 00833 szGrp = "g_"+ m_szAssmMat(p); 00834 m_szAssmMat(p); 00835 if(m_nPlanar ==1){ 00836 #ifdef HAVE_RGG16 00837 m_FileOutput << "group \"" << szGrp << "\" add surface with name \"" << m_szAssmMat(p) <<"*\"" << std::endl; 00838 #else 00839 m_FileOutput << "group \"" << szGrp << "\" add surface with name \"" << m_szAssmMat(p) <<"\"" << std::endl; 00840 #endif 00841 } 00842 else{ 00843 #ifdef HAVE_RGG16 00844 m_FileOutput << "group \"" << szGrp << "\" add body with name \"" << m_szAssmMat(p) <<"*\"" << std::endl; 00845 #else 00846 m_FileOutput << "group \"" << szGrp << "\" add body with name \"" << m_szAssmMat(p) <<"\"" << std::endl; 00847 #endif 00848 } 00849 } 00850 for(int p = 1; p <= (m_szAssmMatAlias.GetSize() - m_nBLAssemblyMat);p++){ 00851 szBlock = "b_"+ m_szAssmMat(p); 00852 szGrp = "g_"+ m_szAssmMat(p); 00853 m_FileOutput << "#{nb" << p << " =NumInGrp('" << szGrp << "')}" << std::endl; 00854 m_FileOutput << "#{Ifndef(nb" << p << ")}" << "\n" << "#{else}" << std::endl; 00855 if(m_nPlanar ==1){ 00856 m_FileOutput << "block " << m_nMaterialSetId + p -1 << " surface in " << szGrp << std::endl; 00857 m_FileOutput << "block " << m_nMaterialSetId + p -1 << " name \"" << szBlock <<"\""<< std::endl; 00858 } 00859 else{ 00860 m_FileOutput << "block " << m_nMaterialSetId + p -1 << " hex in body in " << szGrp << std::endl; 00861 m_FileOutput << "block " << m_nMaterialSetId + p -1 << " name \"" << szBlock <<"\""<< std::endl; 00862 } 00863 m_FileOutput << "#{endif}" << std::endl; 00864 } 00865 m_FileOutput << "#" << std::endl; 00866 } 00867 else{ 00868 std::cout << "Error: Terminating journal file writing. \n Hex block (Hblock keyword) is not supported for a tet mesh." << std::endl; 00869 exit(1); 00870 } 00871 } 00872 00873 // create super blocks 00874 if(m_nSuperBlocks > 0){ 00875 for(int o = 1; o <= m_nSuperBlocks; o++){ 00876 m_FileOutput << "block " << sb(o).m_nSuperBlockId << " vol in block "; 00877 for (int p = 1; p <= sb(o).m_nNumSBContents; p++){ 00878 m_FileOutput << m_nMaterialSetId + sb(o).m_nSBContents(p) << " "; 00879 } 00880 m_FileOutput << "\n" << "block " << sb(o).m_nSuperBlockId << " name '" << sb(o).m_szSuperBlockAlias << "'" << std::endl; 00881 m_FileOutput << "delete block " ; 00882 for (int q = 1; q <= sb(o).m_nNumSBContents; q++){ 00883 m_FileOutput << m_nMaterialSetId + sb(o).m_nSBContents(q) << " "; 00884 } 00885 m_FileOutput << "\n" << std::endl; 00886 } 00887 } 00888 00889 00890 00891 if(m_nHblock > 0){ 00892 // now dump the commands for making hex layers as blocks and subtracting from original 00893 double delta = (m_dZend - m_dZstart)/m_nHblock; 00894 for(int i=0; i<(m_szAssmMatAlias.GetSize() - m_nBLAssemblyMat); i++){ 00895 m_FileOutput << "## BLOCK CREATION USING HEXES" << std::endl; 00896 for(int j=0; j<m_nHblock; j++){ 00897 m_FileOutput << "group 'tmpgrp" << j+1 << "' equals hex in block " << m_nMaterialSetId + i 00898 << " with z_coord < " << m_dZstart + (j+1)*delta << " and z_coord > " 00899 << m_dZstart + j*delta << std::endl; 00900 } 00901 for(int j=0; j<m_nHblock; j++){ 00902 m_FileOutput << "block " << m_nMaterialSetId+i << " group tmpgrp" << j+1 << " remove" << std::endl; 00903 } 00904 for(int j=0; j<m_nHblock; j++){ 00905 if((m_szAssmMatAlias.GetSize() - m_nBLAssemblyMat) < 10) 00906 m_FileOutput << "block " << j+1 << m_nMaterialSetId+i << " group tmpgrp" << j+1 << std::endl; 00907 else 00908 m_FileOutput << "block " << (j+1)*10 << m_nMaterialSetId+i << " group tmpgrp" << j+1 << std::endl; 00909 } 00910 } 00911 } 00912 if(m_nMaterialSetId != 1) 00913 m_FileOutput << "renumber hex all start_id " << MAXLINES*1000 << std::endl; 00914 // color now 00915 m_FileOutput << "#Set color for different parts" << std::endl; 00916 if(m_nPlanar == 0){ // volumes only 00917 for(int p=1;p<=(m_szAssmMatAlias.GetSize() - m_nBLAssemblyMat);p++){ 00918 szGrp = "g_"+ m_szAssmMat(p); 00919 if(p>20) 00920 nColor = 1; 00921 else 00922 nColor = p; 00923 m_FileOutput << "color body in " << szGrp << " " << color[nColor] << std::endl; 00924 } 00925 } 00926 else{ //surfaces 00927 // color now 00928 for(int p=1;p<=(m_szAssmMatAlias.GetSize() - m_nBLAssemblyMat);p++){ 00929 szGrp = "g_"+ m_szAssmMat(p); 00930 if(p>20) 00931 nColor = 1; 00932 else 00933 nColor = p; 00934 m_FileOutput << "color surface in " << szGrp << " " << color[nColor] << std::endl; 00935 } 00936 } 00937 00938 m_FileOutput << "delete group all" << std::endl; 00939 // save as .cub file dump 00940 m_FileOutput << "#\n#Save file" << std::endl; 00941 if(save_exodus){ 00942 std::string szSave = m_szFile + ".exo"; 00943 std::transform(szSave.begin(), szSave.end(), szSave.begin(), ::tolower); 00944 m_FileOutput << "export mesh '"<< szSave <<"'" << " overwrite"<<std::endl; 00945 } 00946 else{ 00947 std::string szSave = m_szFile + ".cub"; 00948 std::transform(szSave.begin(), szSave.end(), szSave.begin(), ::tolower); 00949 m_FileOutput << "save as '"<< szSave <<"'" << " overwrite"<<std::endl; 00950 } 00951 00952 std::cout << "Schemes file created: " << m_szSchFile << std::endl; 00953 std::cout << "Cubit journal file created: " << m_szJouFile << std::endl; 00954 if(strcmp(m_szInfo.c_str(),"on") == 0) 00955 std::cout << "Assembly info file created: " << m_szAssmInfo << std::endl; 00956 00957 m_FileOutput << "Timer Stop" << std::endl; 00958 00959 } 00960 }
