MeshKit
1.0
00001 00007 // C++ 00008 #include <iostream> 00009 #include <list> 00010 #include <vector> 00011 00012 // MeshKit 00013 #include "meshkit/AF2Binding.hpp" 00014 #include "meshkit/AF2Point2D.hpp" 00015 #include "meshkit/AF2PntTrnsfrmLnrV.hpp" 00016 #include "meshkit/AF2RuleExistVertex.hpp" 00017 #include "meshkit/Error.hpp" 00018 00019 // MeshKit testing 00020 #include "TestUtil.hpp" 00021 00022 void testListConstructErrorX(); 00023 void testListConstructErrorY(); 00024 void testVectorConstructErrorX(); 00025 void testVectorConstructErrorY(); 00026 void testUnboundError(); 00027 void testSingleVertexJustX(); 00028 void testSingleVertexJustY(); 00029 void testSingleVertexFull(); 00030 void testMultipleVertices(); 00031 00032 int main(int argc, char **argv) 00033 { 00034 int num_fail = 0; 00035 00036 num_fail += RUN_TEST(testListConstructErrorX); 00037 num_fail += RUN_TEST(testListConstructErrorY); 00038 num_fail += RUN_TEST(testVectorConstructErrorX); 00039 num_fail += RUN_TEST(testVectorConstructErrorY); 00040 num_fail += RUN_TEST(testUnboundError); 00041 num_fail += RUN_TEST(testSingleVertexJustX); 00042 num_fail += RUN_TEST(testSingleVertexJustY); 00043 num_fail += RUN_TEST(testSingleVertexFull); 00044 num_fail += RUN_TEST(testMultipleVertices); 00045 00046 return num_fail; 00047 } 00048 00049 void testListConstructErrorX() 00050 { 00051 std::list<const AF2RuleExistVertex*> emptyVertexList; 00052 std::list<double> xCoeff; 00053 std::list<double> yCoeff; 00054 00055 xCoeff.push_back(1.0); 00056 xCoeff.push_back(0.0); 00057 00058 bool exceptionThrown = false; 00059 try 00060 { 00061 AF2PntTrnsfrmLnrV* shouldFail = 00062 new AF2PntTrnsfrmLnrV(emptyVertexList, xCoeff, yCoeff); 00063 delete shouldFail; 00064 } 00065 catch (MeshKit::Error& mkError) 00066 { 00067 CHECK_EQUAL(MeshKit::MK_BAD_INPUT, mkError.error_code()); 00068 std::cout << "Good: The error is a bad input error." << std::endl; 00069 std::cout << "The error message is:\n" << mkError.what() << std::endl; 00070 exceptionThrown = true; 00071 } 00072 00073 CHECK(exceptionThrown); 00074 std::cout << "PASS: A mismatch in the size of the vertex list and the\n" 00075 << " x-coefficient list in the constructor caused an exception." 00076 << std::endl; 00077 } 00078 00079 void testListConstructErrorY() 00080 { 00081 std::list<const AF2RuleExistVertex*> emptyVertexList; 00082 std::list<double> xCoeff; 00083 std::list<double> yCoeff; 00084 00085 yCoeff.push_back(0.0); 00086 yCoeff.push_back(1.0); 00087 00088 bool exceptionThrown = false; 00089 try 00090 { 00091 AF2PntTrnsfrmLnrV* shouldFail = 00092 new AF2PntTrnsfrmLnrV(emptyVertexList, xCoeff, yCoeff); 00093 delete shouldFail; 00094 } 00095 catch (MeshKit::Error& mkError) 00096 { 00097 CHECK_EQUAL(MeshKit::MK_BAD_INPUT, mkError.error_code()); 00098 std::cout << "Good: The error is a bad input error." << std::endl; 00099 std::cout << "The error message is:\n" << mkError.what() << std::endl; 00100 exceptionThrown = true; 00101 } 00102 00103 CHECK(exceptionThrown); 00104 std::cout << "PASS: A mismatch in the size of the vertex list and the\n" 00105 << " y-coefficient list in the constructor caused an exception." 00106 << std::endl; 00107 } 00108 00109 void testVectorConstructErrorX() 00110 { 00111 std::vector<const AF2RuleExistVertex*> emptyVertexVector; 00112 std::vector<double> xCoeff; 00113 std::vector<double> yCoeff; 00114 00115 xCoeff.push_back(1.0); 00116 xCoeff.push_back(0.0); 00117 00118 bool exceptionThrown = false; 00119 try 00120 { 00121 AF2PntTrnsfrmLnrV* shouldFail = 00122 new AF2PntTrnsfrmLnrV(emptyVertexVector, xCoeff, yCoeff); 00123 delete shouldFail; 00124 } 00125 catch (MeshKit::Error& mkError) 00126 { 00127 CHECK_EQUAL(MeshKit::MK_BAD_INPUT, mkError.error_code()); 00128 std::cout << "Good: The error is a bad input error." << std::endl; 00129 std::cout << "The error message is:\n" << mkError.what() << std::endl; 00130 exceptionThrown = true; 00131 } 00132 00133 CHECK(exceptionThrown); 00134 std::cout << "PASS: A mismatch in the size of the vertex vector and the\n" 00135 << " x-coefficient vector in the constructor caused an exception." 00136 << std::endl; 00137 } 00138 00139 void testVectorConstructErrorY() 00140 { 00141 std::vector<const AF2RuleExistVertex*> emptyVertexVector; 00142 std::vector<double> xCoeff; 00143 std::vector<double> yCoeff; 00144 00145 yCoeff.push_back(0.0); 00146 yCoeff.push_back(1.0); 00147 00148 bool exceptionThrown = false; 00149 try 00150 { 00151 AF2PntTrnsfrmLnrV* shouldFail = 00152 new AF2PntTrnsfrmLnrV(emptyVertexVector, xCoeff, yCoeff); 00153 delete shouldFail; 00154 } 00155 catch (MeshKit::Error& mkError) 00156 { 00157 CHECK_EQUAL(MeshKit::MK_BAD_INPUT, mkError.error_code()); 00158 std::cout << "Good: The error is a bad input error." << std::endl; 00159 std::cout << "The error message is:\n" << mkError.what() << std::endl; 00160 exceptionThrown = true; 00161 } 00162 00163 CHECK(exceptionThrown); 00164 std::cout << "PASS: A mismatch in the size of the vertex vector and the\n" 00165 << " y-coefficient vector in the constructor caused an exception." 00166 << std::endl; 00167 } 00168 00169 void testUnboundError() 00170 { 00171 std::vector<const AF2RuleExistVertex*> vertexVector; 00172 AF2RuleExistVertex* existVertex = new AF2RuleExistVertex(0.0, 0.0); 00173 vertexVector.push_back(existVertex); 00174 std::vector<double> xCoeff; 00175 xCoeff.push_back(1.0); 00176 xCoeff.push_back(0.0); 00177 std::vector<double> yCoeff; 00178 yCoeff.push_back(0.0); 00179 yCoeff.push_back(0.0); 00180 00181 AF2PntTrnsfrmLnrV pntTrnsfrm(vertexVector, xCoeff, yCoeff); 00182 AF2Binding emptyBinding; 00183 AF2Point2D aPoint(0.5, 0.5); 00184 00185 bool exceptionThrown = false; 00186 try 00187 { 00188 pntTrnsfrm.transformPoint(aPoint, emptyBinding); 00189 } 00190 catch (MeshKit::Error& mkError) 00191 { 00192 CHECK_EQUAL(MeshKit::MK_BAD_INPUT, mkError.error_code()); 00193 std::cout << "Good: The error is a bad input error." << std::endl; 00194 std::cout << "The error message is:\n" << mkError.what() << std::endl; 00195 exceptionThrown = true; 00196 } 00197 00198 CHECK(exceptionThrown); 00199 std::cout << "PASS: A binding that does not have bound values for all of\n" 00200 << " the vertices that the linear transformation uses causes an error." 00201 << std::endl; 00202 00203 delete existVertex; 00204 } 00205 00206 void testSingleVertexJustX() 00207 { 00208 std::vector<const AF2RuleExistVertex*> vertexVector; 00209 AF2RuleExistVertex* existVertex = new AF2RuleExistVertex(0.0, 0.0); 00210 vertexVector.push_back(existVertex); 00211 std::vector<double> xCoeff; 00212 xCoeff.push_back(1.0); 00213 xCoeff.push_back(0.0); 00214 std::vector<double> yCoeff; 00215 yCoeff.push_back(0.0); 00216 yCoeff.push_back(0.0); 00217 AF2PntTrnsfrmLnrV pntTrnsfrm(vertexVector, xCoeff, yCoeff); 00218 00219 AF2Binding binding; 00220 AF2Point2D boundPnt(0.75, 0.25); 00221 binding.bind(existVertex, &boundPnt); 00222 00223 AF2Point2D pointArg(0.5, 0.5); 00224 AF2Point2D resultPoint = pntTrnsfrm.transformPoint(pointArg, binding); 00225 CHECK_REAL_EQUAL(1.25, resultPoint.getX(), 1e-14); 00226 std::cout << "Good: The resulting point has an x-coordinate of 1.25" 00227 << std::endl; 00228 CHECK_REAL_EQUAL(0.5, resultPoint.getY(), 1e-14); 00229 std::cout << "Good: The resulting point has a y-coordinate of 0.5" 00230 << std::endl; 00231 00232 std::cout << "PASS: A translation in the x direction works." 00233 << std::endl; 00234 00235 delete existVertex; 00236 } 00237 00238 void testSingleVertexJustY() 00239 { 00240 std::vector<const AF2RuleExistVertex*> vertexVector; 00241 AF2RuleExistVertex* existVertex = new AF2RuleExistVertex(1.0, 1.0); 00242 vertexVector.push_back(existVertex); 00243 std::vector<double> xCoeff; 00244 xCoeff.push_back(0.0); 00245 xCoeff.push_back(0.0); 00246 std::vector<double> yCoeff; 00247 yCoeff.push_back(0.0); 00248 yCoeff.push_back(1.0); 00249 AF2PntTrnsfrmLnrV pntTrnsfrm(vertexVector, xCoeff, yCoeff); 00250 00251 AF2Binding binding; 00252 AF2Point2D boundPnt(1.75, 1.25); 00253 binding.bind(existVertex, &boundPnt); 00254 00255 AF2Point2D pointArg(0.5, 0.5); 00256 AF2Point2D resultPoint = pntTrnsfrm.transformPoint(pointArg, binding); 00257 CHECK_REAL_EQUAL(0.5, resultPoint.getX(), 1e-14); 00258 std::cout << "Good: The resulting point has an x-coordinate of 0.5" 00259 << std::endl; 00260 CHECK_REAL_EQUAL(0.75, resultPoint.getY(), 1e-14); 00261 std::cout << "Good: The resulting point has a y-coordinate of 0.75" 00262 << std::endl; 00263 00264 std::cout << "PASS: A translation in the y direction works." 00265 << std::endl; 00266 00267 delete existVertex; 00268 } 00269 00270 void testSingleVertexFull() 00271 { 00272 std::vector<const AF2RuleExistVertex*> vertexVector; 00273 AF2RuleExistVertex* existVertex = new AF2RuleExistVertex(0.0, 0.0); 00274 vertexVector.push_back(existVertex); 00275 std::vector<double> xCoeff; 00276 xCoeff.push_back(1.0); 00277 xCoeff.push_back(-2.0); 00278 std::vector<double> yCoeff; 00279 yCoeff.push_back(-3.0); 00280 yCoeff.push_back(4.0); 00281 AF2PntTrnsfrmLnrV pntTrnsfrm(vertexVector, xCoeff, yCoeff); 00282 00283 AF2Binding binding; 00284 AF2Point2D boundPnt(1.0, 10.0); 00285 binding.bind(existVertex, &boundPnt); 00286 00287 AF2Point2D pointArg(0.0, 0.0); 00288 AF2Point2D resultPoint = pntTrnsfrm.transformPoint(pointArg, binding); 00289 CHECK_REAL_EQUAL(-19.0, resultPoint.getX(), 1e-14); 00290 std::cout << "Good: The resulting point has an x-coordinate of 8.0" 00291 << std::endl; 00292 CHECK_REAL_EQUAL(37.0, resultPoint.getY(), 1e-14); 00293 std::cout << "Good: The resulting point has a y-coordinate of 37.0" 00294 << std::endl; 00295 00296 std::cout << "PASS: A translation involving a single vertex and all\n" 00297 << " four coefficients works." << std::endl; 00298 00299 delete existVertex; 00300 } 00301 00302 void testMultipleVertices() 00303 { 00304 std::vector<const AF2RuleExistVertex*> vertexVector; 00305 AF2RuleExistVertex firstExistVertex(0.0, 0.0); 00306 AF2RuleExistVertex secondExistVertex(1.0, 0.0); 00307 vertexVector.push_back(&firstExistVertex); 00308 vertexVector.push_back(&secondExistVertex); 00309 std::vector<double> xCoeff; 00310 xCoeff.push_back(1.0); 00311 xCoeff.push_back(0.0); 00312 xCoeff.push_back(0.0); 00313 xCoeff.push_back(3.0); 00314 std::vector<double> yCoeff; 00315 yCoeff.push_back(0.0); 00316 yCoeff.push_back(5.0); 00317 yCoeff.push_back(1.0); 00318 yCoeff.push_back(0.0); 00319 AF2PntTrnsfrmLnrV pntTrnsfrm(vertexVector, xCoeff, yCoeff); 00320 00321 AF2Binding binding; 00322 AF2Point2D firstBoundPnt(0.125, 0.25); 00323 AF2Point2D secondBoundPnt(1.5, 0.0625); 00324 binding.bind(&firstExistVertex, &firstBoundPnt); 00325 binding.bind(&secondExistVertex, &secondBoundPnt); 00326 00327 AF2Point2D pointArg(0.0, 0.0); 00328 AF2Point2D resultPoint = pntTrnsfrm.transformPoint(pointArg, binding); 00329 CHECK_REAL_EQUAL(0.3125, resultPoint.getX(), 1e-14); 00330 std::cout << "Good: The resulting point has an x-coordinate of 0.3125" 00331 << std::endl; 00332 CHECK_REAL_EQUAL(1.75, resultPoint.getY(), 1e-14); 00333 std::cout << "Good: The resulting point has a y-coordinate of 1.75" 00334 << std::endl; 00335 00336 std::cout << "PASS: A translation involving multiple vertices works." 00337 << std::endl; 00338 }
