MeshKit
1.0
00001 #ifndef GFX_STD_INCLUDED // -*- C++ -*- 00002 #define GFX_STD_INCLUDED 00003 00004 /************************************************************************ 00005 00006 Standard base include file for all gfx-based programs. This defines 00007 various common stuff that is used elsewhere. 00008 00009 $Id: std.h,v 1.8 1997/06/25 14:12:31 garland Exp $ 00010 00011 ************************************************************************/ 00012 00013 00014 #include <stdlib.h> 00015 #include <string> 00016 #include <math.h> 00017 #include <iostream> 00018 00019 00020 #ifndef FEQ_EPS 00021 #define FEQ_EPS 1e-6 00022 #define FEQ_EPS2 1e-12 00023 #endif 00024 inline bool FEQ(double a,double b,double eps=FEQ_EPS) { return fabs(a-b)<eps; } 00025 inline bool FEQ(float a,float b,float eps=FEQ_EPS) { return fabsf(a-b)<eps; } 00026 00027 #ifndef GFX_NO_AXIS_NAMES 00028 enum Axis {X=0, Y=1, Z=2, W=3}; 00029 #endif 00030 00031 00032 #define fatal_error(s) report_error(s,__FILE__,__LINE__) 00033 00034 #ifdef assert 00035 # undef assert 00036 #endif 00037 #define assert(i) (i)?((void)NULL):assert_failed(# i,__FILE__,__LINE__) 00038 00039 #ifdef SAFETY 00040 # define AssertBound(t) assert(t) 00041 #else 00042 # define AssertBound(t) 00043 #endif 00044 00045 // 00046 // Define the report_error and assert_failed functions. 00047 // 00048 inline void report_error(const char *msg,const char *file,int line) 00049 { 00050 std::cerr << msg << " ("<<file<<":"<<line<<")"<<std::endl; 00051 exit(1); 00052 } 00053 00054 inline void assert_failed(const char *text,const char *file,int line) 00055 { 00056 std::cerr << "Assertion failed: {" << text <<"} at "; 00057 std::cerr << file << ":" << line << std::endl; 00058 abort(); 00059 } 00060 00061 inline void assertf(int test, const char *msg, 00062 const char *file=__FILE__, int line=__LINE__) 00063 { 00064 if( !test ) 00065 { 00066 std::cerr << "Assertion failed: " << msg << " at "; 00067 std::cerr << file << ":" << line << std::endl; 00068 abort(); 00069 } 00070 } 00071 00072 // GFX_STD_INCLUDED 00073 #endif
