Here is a list of all class members with links to the classes they belong to:
- i -
- icoord
: GridSearchTreeNode
- iCreated
: FacetPoint
- id
: ChollaPoint
, CubitFacet
, OctreeFacetPointData
, FaceterFacetData
, CubitFacetData
, CubitEntity
, ChollaSurface
, CubitFacetEdge
, CubitFacetEdgeData
, ChollaCurve
, ChollaVolume
, CubitPoint
, CubitOctreeCell
, CAEntityId
, CubitOctreeNode
, FacetCurve
- ID_SET
: GeometryEvent
- id_t
: DataCard
- idealize_fillet_geometry()
: GeometryModifyTool
- idealize_hole_slot_geometry()
- ident
: CellCardImpl
, TransformCard
, SurfaceCard
- identity_mtx()
: AnalyticGeometryTool
- idle_wait()
: CubitConcurrent
, CubitQtConcurrent
- IDS_COMPRESSED
: CubitOperationEvent
- if_partition_surf()
: CollapseAngleTool
- ige_attribute_after_imprinting()
: GeometryQueryTool
- ige_export_geom()
: GeometryQueryTool
- ige_import_geom()
: GeometryQueryTool
- ige_is_composite()
: GeometryQueryTool
- ige_is_partition()
: GeometryQueryTool
- ige_push_imprint_attributes_before_modify()
: GeometryQueryTool
- ige_push_named_attributes_to_curves_and_points()
: GeometryQueryTool
- ige_remove_attributes()
: GeometryQueryTool
- ige_remove_attributes_from_unmodifed_virtual()
: GeometryQueryTool
- ige_remove_imprint_attributes_after_modify()
: GeometryQueryTool
- ige_remove_modified()
: GeometryQueryTool
- igeom_init_options
: program_option_struct
- iGeomArrayManager()
: iGeomArrayManager
- IGESet
: GeometryQueryTool
- igeSet
: GeometryQueryTool
- igm
: GeometryContext
- ignore_match()
: ImprintBoundaryTool
- ignore_surface()
: CompositeSurface
- ignoreFlags
: CompSurfFacets
- ImmediateRef()
: ImmediateRef< T >
- import_actuate()
: GeometryQueryTool
- import_facets()
: FacetQueryEngine
- import_geometry()
: IntermediateGeomEngine
, CompositeEngine
, PartitionEngine
- import_solid_model()
: FacetQueryEngine
, OCCQueryEngine
, VirtualQueryEngine
, GeometryQueryEngine
, GeometryQueryTool
, FacetQueryEngine
- import_temp_geom_file()
: OCCQueryEngine
- importanceName()
: GeometryContext
- importances
: CellCardImpl
- importingSolidModel
: GeometryQueryTool
- imprint()
: GeometryModifyEngine
, GeometryModifyTool
, SurfaceOverlapTool
, FacetModifyEngine
, OCCModifyEngine
, ImprintBoundaryTool
, PartitionLumpImprint
- imprint_and_merge_curves()
- imprint_body_curve()
: FBImprint
- imprint_boundaries()
- imprint_boundary_vertices()
- imprint_geom
- imprint_merge_solutions_for_overlapping_surfaces()
: MergeTool
- imprint_projected_edges()
, FacetModifyEngine
, OCCModifyEngine
- imprint_res
: FBImprint
- imprint_segments()
- imprint_singly()
- imprint_surface()
- imprint_toposhapes()
: OCCModifyEngine
- ImprintBoundaryTool()
- ImprintLineSegment()
: ImprintLineSegment
- ImprintMatchData()
: ImprintMatchData
- ImprintPointData()
: ImprintPointData
- imprintResult
: FacetProjectTool
- imprintResults
: SurfaceOverlapTool
- improve_facets()
: FacetModifyEngine
- in_grid()
: PointGridSearch
- inactiveFlag
- inc_query_call_stack()
: ModelQueryEngine
- incorporate_id()
: RefEntityFactory
- IncreasingSort()
: mgcEigen
, mgcEigenD
- increment_list_ptr()
: FBTiler
- index
: ContainmentPoint
, DLIList< X >
, DLList
, DLListIterator
, Hasher< Y, B >::iterator
, IndexedDouble
- index_of()
: CompositeBody
, CompositeCoEdge
, CompositeCurve
, CompositeGeom
, CompositeLump
, CompositeSurface
- IndexedDouble()
: IndexedDouble
- indicesToSerialIndex()
: Fill
- indivStringSize
: CSATagData
- inf_norm()
: CubitMatrix
- infinite_lattice_extra_effort
- infoFlag
: CubitMessage
- init()
: PartitionLumpImprint
- init_bezier_edge()
: FacetEvalTool
- init_bezier_facet()
: FacetEvalTool
- init_bezier_surface()
: FacetEvalTool
- init_boundary_bezier_edge()
: FacetEvalTool
- init_box()
: FacetorTool< SURF, TRI, EDGE, NODE, TRICHILD, NODECHILD, SIZEFUNC >
, TetFacetorTool< TET, SUBTET, NODE >
- init_by_array()
: RandomMersenne
- init_control_points()
: TDFacetBoundaryEdge
- init_csa()
: CADeferredAttrib
- init_edge_control_points()
: FacetEvalTool
- init_edge_control_points_single()
: FacetEvalTool
- init_edge_flags()
: FacetBody
- init_facet_control_points()
: FacetEvalTool
- init_facet_data()
: PartitionSurface
, PartSurfFacetTool
- init_genrand()
: RandomMersenne
- init_gradient()
: FacetEvalTool
- init_hash_curves()
: ChollaEngine
, FacetGeometryCreator
- init_hash_points()
: ChollaEngine
, FacetQueryEngine
- init_hit_flags()
: ChollaSurface
- init_normal()
: TDFacetBoundaryPoint
- init_patch()
: CubitFacet
, CubitQuadFacet
- init_quadrics()
: FacetEvalTool
- initf
: RandomMersenne
- InitialGuess()
- initialize()
: CAEntitySense
, CAGroup
, CAMergePartner
, RefEdge
, RefFace
, RefVertex
, RefVolume
, TDUniqueId
, CurveFacetEvalTool
, FacetEvalTool
, TDFacetBoundaryPoint
, ProcData
, IntersectionTool
- initialize_cgma()
: InitCGMA
- initialize_constructor()
: CubitOctreeNode
- initialize_group_sequence_list()
: TDCAGE
- initialize_imprint_data()
: ImprintPointData
- initialize_octree_generation()
: CubitOctree
- initialize_rand
: CAGroup
- initialize_settings()
: BoundingBoxTool
, CGMApp
, CubitSimpleAttrib
, GeometryQueryTool
, MergeTool
, OldUnmergeCode
, RefEntityName
, SplitSurfaceTool
, FacetModifyEngine
, AppUtil
, CubitMessage
- initilizeTree()
: WeightedOctree< X, C, E >
- InitRead()
: NCubitFile::CFEModel
, NCubitFile::CSimModel
- InitWrite()
- input
: InputDeck::LineExtractor
- input_file
- InputDeck
: CellCardImpl
- insert()
: CompositeGeom
, VGArray< T >
, DLIList< X >
, RStarTreeNode< Y >
, RTreeNode< Y >
, OrderedMap< X, Y >
, OrderedSet< X >
, VolumeCache
- insert_after()
: GroupingEntity
, CompositeLoop
, PartitionLoop
- insert_at_circumcenter()
: FacetorUtil< SURF, TRI, EDGE, NODE, TRICHILD, NODECHILD, SIZEFUNC >
- insert_before()
: GroupingEntity
, CompositeLoop
, PartitionLoop
- insert_coedge()
: CompositeCoEdge
- insert_curve()
: CompositeEngine
, PartitionEngine
- insert_discontinuity_at_point()
: ChollaEngine
- insert_edge()
: PartitionTool
- insert_entity()
: TDCAGE
- insert_facet()
: ChollaCurve
- insert_facets()
: PartitionSurface
- insert_first()
: DLIList< X >
- insert_group()
: TDCAGE
- insert_hard_points()
- insert_in_face()
: FacetProjectTool
, PST_Edge
- insert_item_sorted()
: SDLList
- insert_link()
: DLList
- insert_link_first()
: DLList
, SDLList
- insert_node()
, KDDTree< Z >
- insert_nodes()
- insert_nonmanifold_surfaces()
: CompositeEngine
, PartitionEngine
- insert_one_node()
: TetFacetorTool< TET, SUBTET, NODE >
- insert_point()
: CubitFacet
, CubitFacetData
, CompositeEngine
, FaceterFacetData
, PartitionEngine
- insert_point_curve()
: CompositeEngine
, PartitionEngine
- insert_surface()
: PartitionEngine
- inside()
: GeoTet
- inside_face()
: FacetProjectTool
- inside_of_curve()
: GeometryUtil
- inside_shell()
: CompositeEngine
, PartitionEngine
- inside_undo_group()
: CubitUndo
- instance()
: CGMTagManager
, AnalyticGeometryTool
, CGMApp
, DAG
, DagDrawingTool
, GeometryFeatureTool
, GeometryHealerTool
, GeometryQueryTool
, GeometryUtil
, LocalToleranceTool
, MergeTool
, ModelQueryEngine
, OldUnmergeCode
, RefEntityFactory
, RefEntityName
, FacetModifyEngine
, FacetQueryEngine
, OCCDrawTool
, OCCModifyEngine
, OCCQueryEngine
, ProcData
, CollapseAngleTool
, CollapseCurveTool
, CompositeEngine
, CompositeTool
, PartitionEngine
, PartitionTool
, SplitCompositeSurfaceTool
, AppUtil
, CubitMessage
, SettingHandler
, CubitConcurrent
- instance_
, CGMApp
, DAG
, DagDrawingTool
, GeometryQueryTool
, GeometryUtil
, MergeTool
, ModelQueryEngine
, RefEntityFactory
, RefEntityName
, FacetModifyEngine
, FacetQueryEngine
, OCCDrawTool
, OCCModifyEngine
, OCCQueryEngine
, ProcData
, CollapseAngleTool
, CollapseCurveTool
, CompositeEngine
, CompositeTool
, PartitionEngine
, PartitionTool
, AppUtil
, CubitMessage
, SettingHandler
- instance_no_create()
: AppUtil
- int_array
: CompositeAttrib
- int_attrib_type()
: CATag
, CADeferredAttrib
, CAEntityColor
, CAEntityId
, CAEntityName
, CAEntitySense
, CAEntityTol
, CAGroup
, CAMergePartner
, CAMergeStatus
, CASourceFeature
, CAUniqueId
, CubitAttrib
, CABodies
, CACompositeVG
, CAPartitionVG
, CAVirtualVG
, CAAssemblyData
- int_data_list()
: CubitSimpleAttrib
- int_flag
: ProgOptions
- int_len()
: CubitUtil
- int_ln_ln()
- int_ln_pln()
- int_pln_pln()
- int_pnt_ln()
- int_pnt_pln()
- int_value
: SettingHolder
- intData
: CSATagData
- intDataList
: CubitSimpleAttrib
- intDataSize
: CSATagData
- integerArray
: FacetAttrib
- IntegerHash()
: IntegerHash
- IntegerList
: CompSurfFacets
- interface_group()
: CGMTagManager
- interfaceGroup
: CGMTagManager
- interior_angle()
: GeomMeasureTool
, Faceter
, CubitVector
- interior_edges()
: GeoNode
- interior_facet_points()
: PartitionSurface
- interior_set
: PartSurfFacetTool
- intermediateNodeSets
: ModelQueryEngine
- internal_error()
: CubitMessage
- internal_type
: CastingDLIIterator< ListType, OutType >
, CastingDynamicDLIIterator< ListType, OutType >
- internalSurfaceMergeTest
: GeometryQueryTool
- interp_order()
: FacetEvalTool
, FacetSurface
- interpolate
: CubitVector
- interpolate_along_surface()
: GeometryQueryTool
- interpolate_grey_octreecell_node()
: CubitOctreeCell
- interpOrder
: CurveFacetEvalTool
, FacetEvalTool
- interrupt()
: AppUtil
- intersect()
, OCCModifyEngine
, CubitFacetEdge
, RefGroup
, FacetModifyEngine
, FBIntersect
, CubitBox
, CubitPlane
, DLIList< X >
, DLList
- INTERSECT
: CellCard
- intersect_2D_segments()
: CubitFacetEdge
- intersect_facet()
: FacetDataUtil
- intersect_from_edge()
: BoundaryConstrainTool< SURF, TRI, EDGE, NODE, TRICHILD >
- intersect_from_node()
- intersect_intervals()
: CubitFacetEdge
- intersect_plane_with_boundingbox()
: FBDataUtil
- intersect_point_with_ray()
: IntersectionTool
- intersect_ray()
: FacetEvalTool
- intersect_segment_with_ray()
: IntersectionTool
- intersect_segments()
- intersect_triangle_with_ray()
: IntersectionTool
- intersect_unordered()
: DLIList< X >
- Intersection()
- intersection_edges
: FBPolyhedron
- IntersectionTool()
: IntersectionTool
- intPoint
: OctreeIntersectionData
- intType
: DagType
- inv_mtx_adj()
- inv_trans_mtx()
- invalid_size
: mgcEigen
, mgcEigenD
- invalid_type()
: DagType
- inverse()
: CubitTransformMatrix
, CubitMatrix
- inverse_distance_interpolation()
: CubitOctreeCell
- invert
: Transform
- is_a_collapsed()
: TDSplitSurface
- is_absolute()
: CubitFileUtil
- is_adj_curves()
: TDOctreeRefFace
- is_adjacent()
: ChollaSurface
- is_at_beginning()
: DynamicDLIIteratorImpl< ListType, OutType >
, DLIListIterator< X >
, DLIList< X >
, DLList
, CastingDLIIterator< ListType, OutType >
, DynamicDLIIterator< X >
, DynamicTreeIterator< TreeType, OutType, Which >
- is_at_end()
: DLIListIterator< X >
, DLIList< X >
, DLList
, DynamicDLIIteratorImpl< ListType, OutType >
- is_at_surf()
- is_at_vertex()
: FacetEvalTool
- is_attribute()
: SubEntitySet
- is_b_collapsed()
: TDSplitSurface
- is_backwards()
: CubitFacet
- is_bbox()
- is_c_collapsed()
: TDSplitSurface
- is_cage()
: TDCAGE
- is_cell_index()
: TDCellIndex
- is_chain_two_triangles()
: SplitSurfaceTool
- is_child()
: RefEntity
- is_chordal()
: TDChordal
- is_close()
: FacetQueryEngine
- is_closed_in_U()
: CompositeSurface
, SphereEvaluator
, CubitEvaluator
, CylinderEvaluator
, RefFace
, Surface
, FacetSurface
, OCCSurface
, PartitionSurface
, SubSurface
- is_closed_in_V()
: RefFace
, SphereEvaluator
, Surface
, FacetSurface
, OCCSurface
, CompositeSurface
, PartitionSurface
, SubSurface
, CylinderEvaluator
, CubitEvaluator
- is_collapsed()
: SSSide
- is_compare()
: TDCompare
- is_completed()
: CubitConcurrent
, CubitQtConcurrent
, CubitConcurrent
- is_composite()
, CompositeEngine
, PartitionEngine
, IntermediateGeomEngine
- is_conical()
: FacetSurface
, OCCSurface
- is_contain()
: ChollaCurve
, ChollaSurface
- is_curve_in_outer_loop()
: SplitSurfaceTool
- is_curve_on_side()
: SplitSurfaceTool
- is_cylindrical()
: RefFace
, Surface
- is_d_collapsed()
: TDSplitSurface
- is_data()
: RStarTreeNode< Y >
, RTreeNode< Y >
- is_dead_coedge()
: CompositeSurface
- is_debug_flag_gui_set()
: CubitMessage
- is_debug_flag_set()
: CubitMessage
- is_delaunay()
: TDDelaunay< TRIA, NODE >
- is_directly_related()
: TopologyEntity
- is_directory()
: CubitFileUtil
- is_edge_in_list()
: SplitSurfaceTool
- is_empty()
: CubitString
, HiddenEntitySet
- is_equal()
: GeomMeasureTool
, OCCPoint
, CubitMatrix
- is_executable()
: CubitFileUtil
- is_external()
: FacetLoop
, CompositeLoop
, PartitionLoop
- is_face_blend()
: GeomMeasureTool
- is_facet_boundary_edge()
- is_facet_boundary_point()
- is_facet_point_data_present()
: CubitOctreeCell
- is_facetbool_facet()
: TDFacetboolData
- is_feature()
: CubitPoint
, CubitFacetEdge
- is_feature_engine()
: GeometryFeatureEngine
- is_flat()
: OCCSurface
, CubitFacet
, FacetSurface
, FacetEvalTool
, CubitFacet
- is_flipped()
: CubitFacetEdge
- is_geom_facet()
: TDGeomFacet
- is_healer_engine()
: GeometryHealerEngine
- is_hidden()
: CompositeEngine
- is_identity()
: CubitMatrix
- is_in_curve()
: ChollaPoint
- is_in_list()
: DLIList< X >
, OrderedSet< X >
- is_in_outer_loop()
: SplitSurfaceTool
- is_in_surface()
: ChollaPoint
, PartitionCurve
, ChollaCurve
- is_in_volume()
: ChollaCurve
, ChollaSurface
, ChollaPoint
, TDGeomFacet
- is_initialized()
: GfxDebug
- is_int_number()
: CubitFileUtil
- is_interface()
: TDParallel
- is_intermediate_engine()
: VirtualQueryEngine
- is_intermediate_geometry()
: GeometryQueryTool
- is_internal_edge()
- is_interpnode()
: TDInterpNode
- is_intersection_edge
: FB_Edge
- is_intersection_point_contained_inside_facet()
: CubitOctreeNode
- is_intersects_box()
: CubitOctreeCell
- is_leaf()
: CubitOctreeCell
, RTreeNode< Y >
- is_linear()
: SegmentedCurve
- is_ln_on_pln()
- is_master()
: ProcData
- is_matched()
: ImprintPointData
- is_measure_set()
: GeomDataObserver
- is_mergeable()
: RefEntity
, RefGroup
, RefEntity
, RefGroup
- is_merged()
, RefEntity
- is_modify_enabled()
: FacetModifyEngine
- is_modify_engine()
: FacetModifyEngine
, GeometryModifyEngine
, OCCModifyEngine
- is_narrow_region_at_point()
: GeomMeasureTool
- is_nonmanifold()
: PartitionShell
, BasicTopologyEntity
, PartitionCurve
- is_num_token()
: CellCardImpl
- is_on_boundary
: FB_Coord
- is_on_line_segment()
: Cubit2DPoint
- is_op_token()
: CellCardImpl
- is_outside()
: FacetEvalTool
- is_owner_vertex()
: ImprintPointData
- is_parallel()
: TDParallel
- is_parametric()
: CompositeSurface
, OCCSurface
, CylinderEvaluator
, RefFace
, SphereEvaluator
, FacetSurface
, SubSurface
, PartitionSurface
, Surface
, CubitEvaluator
- is_parent()
: RefEntity
- is_partition()
, PartitionEngine
, CompositeEngine
- is_partner()
: TDGeomFacet
- is_periodic()
: Surface
, SegmentedCurve
, CubitEvaluator
, CylinderEvaluator
, RefEdge
, FacetCurve
, OCCCurve
, SubSurface
, CompositeSurface
, SegmentedCurve
, PartitionSurface
, PartPTCurve
, FacetSurface
, CompositeCurve
, OCCSurface
, RefFace
, SphereEvaluator
, Curve
, RefEdge
, SubCurve
- is_periodic_in_U()
: RefFace
, CylinderEvaluator
, CubitEvaluator
, Surface
, SphereEvaluator
, OCCSurface
, CompositeSurface
, PartitionSurface
, FacetSurface
, SubSurface
- is_periodic_in_V()
: CompositeSurface
, SubSurface
, Surface
, OCCSurface
, FacetSurface
, CubitEvaluator
, CylinderEvaluator
, SphereEvaluator
, RefFace
, PartitionSurface
- is_planar()
: RefFace
- is_plane_valid_
: ParamCubitPlane
- is_pln_on_pln()
- is_pnt_on_ln()
- is_pnt_on_ln_seg()
- is_pnt_on_pln()
- is_point_in_polyhedron()
: FacetDataUtil
- is_point_on_face()
: GeometryUtil
- is_point_on_surface()
: SplitSurfaceTool
- is_position_in_volume()
: GeometryUtil
- is_position_on()
: OCCCurve
, Surface
, PartitionSurface
, OCCSurface
, SegmentedCurve
, SubCurve
, CompositeCurve
, FacetSurface
, FacetCurve
, Curve
, SubSurface
, PartPTCurve
, CompositeSurface
- is_position_within_loop()
: GeometryUtil
- is_position_within_shell()
: GeometryUtil
- is_ptr()
: TDPtr
- is_reversed()
: TDFacetboolData
- is_running()
: CubitConcurrent
, CubitQtConcurrent
- is_same_side()
: CubitOctreeNode
- is_shared_proc()
: TDParallel
- is_sheet()
: RefVolume
, FacetShell
, FacetLump
, OCCShell
, Shell
- is_sheet_body()
: OCCBody
, Body
- is_shell_a_void()
: GeometryUtil
- is_singular_in_U()
: SphereEvaluator
, PartitionSurface
, SubSurface
, CompositeSurface
, RefFace
, CylinderEvaluator
, Surface
, OCCSurface
, CubitEvaluator
, FacetSurface
- is_singular_in_V()
: CubitEvaluator
, FacetSurface
, SphereEvaluator
, CylinderEvaluator
, SubSurface
, RefFace
, PartitionSurface
, Surface
, CompositeSurface
, OCCSurface
- is_solid_modeler_type()
: FacetQueryEngine
, OCCQueryEngine
- is_source_feature()
: TDSourceFeature
- is_spherical()
: FacetSurface
, OCCSurface
- is_split_surface()
: TDSplitSurface
- is_split_surface_extend()
: TDSplitSurfaceExtend
- is_stitched()
: CompositeCurve
- is_success()
- is_surface_narrow()
: GeomMeasureTool
- is_surface_overlap()
: TDSurfaceOverlap
- is_survivor()
: CAMergePartner
- is_td_octree_ref_face()
: TDOctreeRefFace
- is_td_skl_mref_edge()
: TDOctreeRefEdge
- is_td_vector()
: TDVector
- is_tolerant()
: Curve
, RefEdge
- is_tracking()
: CGMHistory
- is_transparent()
: CubitEntity
- is_triangle()
: SplitSurfaceTool
- is_unique_id()
: TDUniqueId
- is_valid()
: DagType
- is_vec_par()
- is_vec_perp()
- is_vecs_same_dir()
- is_vertex_blend()
: GeomMeasureTool
- is_vertex_in_surface()
: SplitSurfaceTool
- is_vertex_on()
: SSSide
- is_vertex_on_side()
: SplitSurfaceTool
- is_vg_facet_owner()
: TDVGFacetOwner
- is_vg_facet_split()
: TDVGFacetSplit
- is_virtual()
- is_visible()
: CubitEntity
- isActive
: CGMTagManager::TagInfo
- isBackwards
: CubitFacet
- isCentered
: CubitViewParam
- isCollapsed
: SSSide
- isComposite()
: CompositeTool
- isEmpty()
: CubitSimpleAttrib
- isequence
: KDTree
- isFeature
: CubitPoint
, CubitFacetEdge
- isFixedSize()
: Lattice
- isFlat
: FacetEvalTool
, CubitFacet
- isFlipped
: CubitFacetEdge
- isInitialized
: ProcData
- isInside
: GeoTet
- isLattice()
: CellCard
, CellCardImpl
- IsLeaf
: WeightedOctree< X, C, E >::Cell
- isLoop
: SplitSurfaceTool
- isMarked
: GeoTet
, GeoNode
- isMatched
: ImprintPointData
- IsModel()
: NCubitFile::CCubitFile
- isParameterized
: FacetEvalTool
- isReversed
: TDFacetboolData
- isSurvivor
: CAMergePartner
- itemCount
: ArrayBasedContainer
- iter
: Hasher< Y, B >::iterator
- iterator
: SimpleArray< T >
, DLIList< X >
, ManagedPtrVector< X >::iterator
, SimpleArray< T >
- iterator_category
: Hasher< Y, B >::BaseIter< T >
- iTotalTBCreated
: OCCQueryEngine
