Here is a list of all class members with links to the classes they belong to:
- c -
- C
: Circle3
- c
: AgtLine
, FB_Triangle
, LoopParamTool
- c_str()
: CubitString
- C_STYLE
: Transform
- caActuateFlgs
: CGMApp
- CAActuateSet()
: CAActuateSet
- CAAssemblyData()
: CAAssemblyData
- CABodies()
: CABodies
- cachedPlane
: CubitFacet
- CACompositeVG()
: CACompositeVG
- CADeferredAttrib()
: CADeferredAttrib
- CAEntityColor()
: CAEntityColor
- CAEntityId()
: CAEntityId
- CAEntityName()
: CAEntityName
- CAEntitySense()
: CAEntitySense
- CAEntityTol()
: CAEntityTol
- CAGroup()
: CAGroup
- calc_enlargement()
: RStarTreeNode< Y >
, RTreeNode< Y >
- calc_facet_patch_distance_normal()
: CubitOctreeNode
- calc_overlap()
- calculate_area()
: FacetEvalTool
- calculate_depth_based_on_size()
: CubitOctree
- calculate_id()
: OctreeFacetPointData
- calculate_local_tolerances()
: LocalToleranceTool
- calculate_local_tolerances_automatically()
- calculate_plane()
: PST_Face
- calculate_size_based_on_cell_dimension()
: CubitOctreeNode
- calculate_split_curves()
: SplitSurfaceTool
- calculate_split_points_for_merge()
: GeometryModifyTool
- calculate_tolerances_for_surf_intersection()
: SurfaceOverlapTool
- calculateCellCenter()
: WeightedOctree< X, C, E >
- CAMergePartner
: MergeTool
, CAMergePartner
- CAMergeStatus()
: CAMergeStatus
- can_add()
, RTreeNode< Y >
- can_be_deleted()
: FacetBody
- can_delete_bodies()
: FacetQueryEngine
- can_merge()
: MergeToolAssistant
- can_modify()
: RefEntity
- can_remove()
: PartitionTool
- can_separate()
: MergeTool
- cancel()
: CubitConcurrent
, CubitQtConcurrent
- cancel_opt
: ProgOpt
- capacity()
: SimpleArray< T >
- CAPartitionVG
: CAVirtualVG
, CAPartitionVG
- capsule_distance_to_facet()
: CubitOctree
- Card()
: Card
- CardRef()
: CardRef< T >
- caReadFlgs
: CGMApp
- case_0_2_equal()
: ImprintBoundaryTool
- case_0_3_equal()
- case_1_2_equal()
- case_1_3_equal()
- CaseInsensitive
: CubitString
- CaseSensitive
: CubitString
- CaseSensitivity
: CubitString
- CASourceFeature()
: CASourceFeature
- casting_merge_unique()
: DLIList< X >
- CastingDLIIterator()
: CastingDLIIterator< ListType, OutType >
- CastingDynamicDLIIterator()
: CastingDynamicDLIIterator< ListType, OutType >
- CATag
: CGMTagManager
, CATag
- CATag_att_type
: CGMTagManager
- CATag_creator()
: CGMTagManager
- CATag_NAME
: CGMTagManager
- CATag_NAME_INTERNAL
: CGMTagManager
- catch_interrupt()
: AppUtil
- catching_sigint_
: AppUtil
- CAUniqueId()
: CAUniqueId
- caUpdateFlgs
: CGMApp
- CAVirtualVG()
: CAVirtualVG
- caWriteFlgs
: CGMApp
- CCubitFile()
: NCubitFile::CCubitFile
- CCW
: FBRetriangulate
- Cell()
: GetLongOpt::Cell
, WeightedOctree< X, C, E >::Cell
- cell_card_list
: InputDeck
- cell_from_range()
: PointGridSearch
- cell_index()
: TDCellIndex
- cell_map
: InputDeck
- CellCard()
: CellCard
- CellCardImpl()
: CellCardImpl
- cellDepthDifference
: CubitOctreeNode
- cellIndex
: TDCellIndex
- CELLNUM
: CellCard
- cells
: InputDeck
- Center
: WeightedOctree< X, C, E >::Cell
- center
: OBBox2
, OBBox3
, SphereEvaluatorData
, OctTree< X, E >
, CylinderSurface
, ConeSurface
, TorusSurface
, SphereSurface
, EllipsoidSurface
, GeomMeasureTool
, CubitFacet
, CubitFacetEdge
, CubitBox
- center_offset
: RppVolume
- center_point()
: Curve
, RefEdge
, RefEntity
, RefFace
, RefGroup
, RefVertex
, RefVolume
, OCCSurface
, CubitEntity
, Body
- centroid()
: SurfaceOverlapFacet
- centroid_area()
: CubitPolygon
- CFEModel()
: NCubitFile::CFEModel
- CGMAIterator()
: CGMAIterator
- CGMApp()
: CGMApp
- CGMEngineDynamicLoader()
: CGMEngineDynamicLoader
- cgmEventList
: OCCHistory
- CGMFileOptions()
: CGMFileOptions
- CGMHistory()
: CGMHistory
- CGMMemFile()
: CGMMemFile
- CGMParallelComm()
: CGMParallelComm
- CGMParallelOpts
: CGMReadParallel
- CGMparallelOptsNames
: CGMReadParallel
- CGMpartitionOptsNames
: CGMReadParallel
- CGMProcConfig()
: CGMProcConfig
- CGMReadParallel()
: CGMReadParallel
- CGMTagManager
: CATag
, CGMTagManager
- Chain()
: Chain
- chain_type()
: DagType
- chains()
: TopologyEntity
- change_cell()
: PointGridSearch
- change_item_to()
: DLList
, SDLList
- change_ptr()
: TDUPtr< T >
- change_to()
: DLIList< X >
- change_to_parent_ref_entities()
: RefEntity
- character_type()
: CubitSimpleAttrib
- CharacterizeGroups()
: FBClassify
- check()
: FacetDataUtil
- Check()
: OCCShapeAttributeSet
- check_all_facet_orientations()
: ChollaEngine
- check_boundary_contact()
- check_child_cacvgs()
: CACompositeVG
- check_engine_version()
- check_face_loop()
: SplitSurfaceTool
- check_facet_orientation()
: ChollaEngine
- check_faceting()
: ChollaSurface
, FacetEvalTool
- check_for_loop()
: SplitSurfaceTool
- check_if_arc()
: SplitSurfaceTool
- check_interrupt()
: ProgressTool
, StubProgressTool
, TextProgressTool
, TtyProgressTool
- check_intersection()
: OCCModifyEngine
- check_inverted_facets()
: CubitPoint
- check_mergeable_refentity()
: GeometryQueryTool
- check_operation()
: OCCModifyEngine
- check_overlap()
- check_partition_info()
: CGMReadParallel
- check_points_arc()
: SplitSurfaceTool
- check_points_straight()
: SplitSurfaceTool
- check_saved_id()
: MergeTool
- check_selfintersecting_coincident_edges()
: LoopParamTool
- check_size()
: CGMParallelComm
, CGMMemFile
- check_size_and_swap_surfs()
- check_surf_pairs()
: AutoMidsurfaceTool
- check_surfs_for_imprinting()
- check_through_vertices()
: SplitSurfaceTool
- check_valid_chain()
: GeometryUtil
- check_valid_chain_by_coord()
: GeometryUtil
- check_valid_faces()
: SplitSurfaceTool
- check_valid_facets()
: TDOctreeRefFace
- check_valid_loop()
: GeometryUtil
- check_valid_loop_by_coord()
: GeometryUtil
- checkAcrossBodies
- checkWithinBodies
- child()
: OctTreeCell< X, E >
- childList
: PartitionBody
- children
: CubitOctreeCell
- Children
- children_
- children_mergeable()
: RefEntity
- ChildType
: Curve
, Lump
, RefEdge
, RefFace
, RefVolume
, Surface
- ChollaCurve()
: ChollaCurve
- chollaCurveList
: ChollaEngine
- ChollaCurveList
: TDGeomFacet
- ChollaEngine()
: ChollaEngine
- ChollaEntity()
: ChollaEntity
- ChollaMesh()
: ChollaMesh
- ChollaPoint()
: ChollaPoint
- chollaPointList
: ChollaEngine
- ChollaPointList
: TDGeomFacet
- ChollaSkinTool()
: ChollaSkinTool
- ChollaSurface()
: ChollaSurface
- chollaSurfaceList
: ChollaEngine
- ChollaSurfaceList
: TDGeomFacet
- ChollaVolume()
: ChollaVolume
- chollaVolumeList
: ChollaEngine
- choose_leaf()
: RTreeNode< Y >
- choose_sub_tree()
- chop()
: GeometryModifyEngine
, GeometryModifyTool
, FacetModifyEngine
, OCCModifyEngine
- chordal_axis_transform()
: ChordalAxis
- ChordalAxis()
: ChordalAxis
- CIOWrapper()
: NCubitFile::CIOWrapper
- circumcenter()
: SurfParamTool
, TestParamTool
, FacetorUtil< SURF, TRI, EDGE, NODE, TRICHILD, NODECHILD, SIZEFUNC >
, TDDelaunay< TRIA, NODE >
, CubitOctree
- circumcenter2d()
: TDDelaunay< TRIA, NODE >
- circumsphere()
: GeoTet
, TetFacetorTool< TET, SUBTET, NODE >
- class_identifier()
- class_name()
: BasicTopologyEntity
, Body
, RefEdge
, RefFace
, RefGroup
, RefVertex
, RefVolume
, TopologyEntity
, CubitCoordinateSystem
, CubitEntity
- ClassFunctionTask()
: CubitConcurrent::ClassFunctionTask< X >
- ClassFunctionTaskArg1()
: CubitConcurrent::ClassFunctionTaskArg1< X, Param1 >
- ClassFunctionTaskArg2()
: CubitConcurrent::ClassFunctionTaskArg2< X, Param1, Param2 >
- classify()
: FBClassify
- classify1
: FBIntersect
- classify2
: FBIntersect
- classify_against_plane()
: FBClassify
- classify_children()
: CompositeTool
- classify_edge()
: ChollaEngine
, FacetGeometryCreator
- classify_edges()
: FBRetriangulate
- classify_point()
: ChollaEngine
- classify_tri_by_angle()
: FacetorUtil< SURF, TRI, EDGE, NODE, TRICHILD, NODECHILD, SIZEFUNC >
- classify_triangles()
: FacetorTool< SURF, TRI, EDGE, NODE, TRICHILD, NODECHILD, SIZEFUNC >
- clean()
: RefEntityName
- clean_attributes()
: GeometryHealerEngine
, GeometryHealerTool
- clean_features()
: ChollaSurface
- clean_geometry()
: ChollaEngine
- clean_gpoint_list()
: TDOctreeRefEdge
- clean_loops()
: OCCCurve
- clean_out()
: ArrayBasedContainer
, DLIList< X >
, DLList
, GMem
, OrderedMap< X, Y >
, OrderedSet< X >
- clean_out_deactivated_geometry()
: IntermediateGeomEngine
, CompositeEngine
, PartitionEngine
- clean_out_edges()
: ChollaCurve
- clean_up_attribs()
: CompositeGeom
- clean_up_data()
- clean_up_from_copy_failure()
- clean_up_loop()
: PartitionLumpImprint
- cleanout_deactivated_DAG_nodes()
: DAG
- cleanout_deactivated_geometry()
: GeometryQueryTool
- cleanout_temporary_geometry()
: GeometryQueryTool
- cleanup()
: FacetProjectTool
, CubitDirIterator
, CubitConcurrent::ThreadLocalStorage< T >
- cleanup_cadas()
: CADeferredAttrib
- cleanup_cadas_private()
: CADeferredAttrib
- cleanup_for_extend_op()
: SplitSurfaceTool
- cleanup_unmerge()
: MergeTool
, OldUnmergeCode
- clear()
: CGMHistory
, GfxPreview
, CubitSparseMatrix
, CubitString
, GfxDebug
, ManagedPtrVector< X >
- Clear()
- clear_all()
: TtyProgressTool
- clear_all_simple_attrib()
: CubitAttribUser
- clear_all_simple_attrib_set_to_actuate()
: CubitAttribUser
- clear_copy_map()
: TDUniqueId
- clear_curves()
: OCCPoint
- clear_highlight()
: GfxDebug
- clear_interrupt()
: AppUtil
- clear_out_old_to_new_map()
: CAUniqueId
- clear_simple_attribs()
: CubitAttribUser
- clear_simple_attribs_set_to_actuate()
: CubitAttribUser
- clear_undo_groups()
: CubitUndo
- ClearMetaDataForID()
: NCubitFile::CMetaData
- clearUidMapBeforeImport
: GeometryQueryTool
- clock_secs()
: CpuTimer
- clone()
: DynamicDLIIterator< X >
, DynamicDLIIteratorImpl< ListType, OutType >
, CastingDynamicDLIIterator< ListType, OutType >
, DynamicTreeIterator< TreeType, OutType, Which >
, CubitEquation
, DataRef< T >
, ImmediateRef< T >
, PointerRef< T >
, NullRef< T >
, CardRef< T >
, TransformCard
- Close()
- close()
: CubitFile
- closest_box()
: CompositeGeom
- closest_curve()
: CompositeCurve
- closest_edge()
: FacetProjectTool
- closest_face()
: FacetProjectTool
- closest_face_coedge()
: GeometryUtil
- closest_facet()
: FacetEvalTool
, PartitionSurface
, PartSurfFacetTool
- closest_index()
: CompSurfFacets
- closest_loop_coedge()
: GeometryUtil
- closest_on_edge()
: PST_Edge
- closest_on_line()
: FacetProjectTool
, PST_Edge
- closest_on_lines()
: FacetProjectTool
- closest_point
: CubitFacetData
, FaceterFacetData
, CubitEvaluator
, Curve
, CylinderEvaluator
, RefEdge
, SphereEvaluator
, Surface
, CubitFacet
, CubitFacetEdge
, CurveFacetEvalTool
, FacetEvalTool
, FacetCurve
, FacetProjectTool
, FacetSurface
, OCCCurve
, OCCSurface
, CompositeCurve
, CompositeSurface
, PartitionSurface
, PartPTCurve
, SegmentedCurve
, SubCurve
, SubSurface
, CubitBox
, ParamCubitPlane
- closest_point_along_vector()
: Surface
, FacetSurface
, OCCSurface
, CompositeSurface
, PartitionSurface
, SubSurface
- closest_point_interior_seg()
- closest_point_on_segment()
: SegmentedCurve
- closest_point_seg()
- closest_point_trimmed()
: Curve
, GeometryUtil
, RefEdge
, Surface
, CubitFacet
, FacetEvalTool
, FacetSurface
, OCCSurface
, CompositeCurve
, CompositeSurface
, PartitionSurface
, SegmentedCurve
, SubSurface
- closest_point_uv_guess()
: Surface
, FacetSurface
, OCCSurface
, CompositeSurface
, PartitionSurface
, SubSurface
- closest_points()
: Surface
- closest_points_on_segments()
: IntersectionTool
- closest_points_trimmed()
: Surface
- closest_pt_on_facet()
: PartSurfFacetTool
- closest_seg_seg_dist()
: FBDataUtil
- closest_segment()
: SegmentedCurve
- closest_shell_coface()
: GeometryUtil
- closest_tri_point()
: CompSurfFacets
- closest_trimmed()
: CompositeSurface
- closest_underlying_surface()
: CompositeSurface
- closest_vertex()
: RefEdge
- closestDist
: ImprintMatchData
- closestPoint
: ImprintMatchData
- closestSeg
: ImprintMatchData
- CMetaData()
- co_edge()
: TopologyEntity
- co_edge_loops()
: RefFace
- co_edge_type()
: DagType
- co_edges()
: SSSide
, TopologyEntity
- co_face_type()
: DagType
- co_faces()
: TopologyEntity
- co_vertex_type()
: DagType
- co_vertices()
: TopologyEntity
- co_volume_type()
: DagType
- co_volumes()
: TopologyEntity
- coe_ptr
: CoEdgeDataList
- CoEdge()
: CoEdge
- coedge()
: PST_Edge
- coedge_
: PST_Face
- coEdgeChain
: SSSide
- coEdgeParamList
: SSSide
- coedges()
: OCCLoop
- coedgeSet
: CompositeCoEdge
- CoEdgeSM()
: CoEdgeSM
- coedgesms()
: TopologyBridge
- coef_vector()
: CubitPoint
- coefficient()
: CubitPlane
- coefVector
: CubitPoint
- CoFace()
: CoFace
- cofactor()
: CubitMatrix
- colinear()
: CubitVector
- collapse_angle()
: CollapseAngleTool
- collapse_curve()
: ChollaEngine
, CollapseCurveTool
- COLLAPSE_CURVE_COMPLETED
: CubitOperationEvent
- collapse_curve_only_virtual()
: CollapseCurveTool
- collapse_edge()
: CubitPointData
, PartSurfFacetTool
- collapse_one_angle()
: CollapseAngleTool
- collapse_short_edges()
: FacetDataUtil
- collapse_surface()
: ChollaEngine
- CollapseAngleTool()
: CollapseAngleTool
- CollapseCurveTool()
: CollapseCurveTool
- collect_relevant_pairs()
: OCCHistory
- CollectionEntity()
: CollectionEntity
- collectionEntityPtr
: RefCollection
- color
: CubitOctreeCell
, CubitOctreeNode
, Body
, CAEntityColor
, RefEntity
, CubitEntity
- color_lattice_cell()
: CubitOctreeGenerator
- color_octreecell()
: CubitOctree
- color_octreenode_via_grassfire()
: CubitOctreeGeneratorVolumes
- coloring()
: CubitOctreeCell
- Combine()
: AnalyticGeometryTool
- combine()
: CompositeBody
, CompositeCoEdge
, CompositeCurve
, CompositeEngine
, CompositeLump
, CompositeSurface
, PartitionCurve
, PartitionSurface
, PartPTCurve
, SegmentedCurve
, SubCurve
, SubSurface
- combine_bodies()
: CompositeEngine
- COMMAND_FINISHED
- COMMAND_STARTED
- CommandFeedback()
: CommandFeedback
- common()
: PST_Point
, PST_CoEdge
- common_curve()
: PartitionPoint
- common_face()
: PST_Edge
- common_modify_engine()
- common_point()
: PST_Edge
, CompositeCurve
- common_query_engine()
: GeometryQueryTool
- common_ref_edge()
: RefFace
, RefVertex
- common_ref_edges()
: RefFace
, RefVertex
- common_ref_face()
: RefEdge
- common_ref_faces()
: RefEdge
- common_ref_vertex()
: RefEdge
- common_ref_volume()
: RefFace
- common_vertices()
: RefEdge
- commonGroupingEntities()
: PartitionTool
- compare()
: FileOptions
, CGMFileOptions
, CubitString
, CubitUtil
, KDDTreeNode< Y >
- compare_alignment()
: RefFace
- compare_and_merge()
: MergeTool
- compare_BTE()
: MergeTool
- compare_equal
: SDLList
- compare_function()
: CubitOctreeNode
, OctreeIntersectionData
- compare_GE()
: MergeTool
- compare_notify()
: MergeTool
- compare_order
: SDLList
- compare_order_obj
: SDLList
- compare_SE()
: MergeTool
- compare_tol()
: FacetEvalTool
- compare_with_equality()
: KDDTreeNode< Y >
- compareEntityList
: MergeTool
- CompareFunc
: PriorityQueue< Object >
- comparePartner_
: TDCompare
- compareTol
: FacetEvalTool
- comparison_found()
: RefEntity
- compGeom
: CompositeCurve
, CompositeLump
, CompositeSurface
- COMPLEMENT
: CellCard
- complete_filename()
: CubitFileUtil
- complete_merge()
: MergeTool
- composite()
: CompositeEngine
, CompositeTool
- COMPOSITE_CREATION_COMPLETED
- composite_curves()
: SimplifyTool
- composite_id()
: CACompositeVG
- composite_param()
: CompositeCurve
- composite_surfaces()
: SimplifyTool
- composite_surfaces_test_at_curves()
: SimplifyTool
- CompositeAttrib()
: CompositeAttrib
- CompositeBody
: CompositeLump
, CompositeBody
- CompositeCoEdge()
: CompositeCoEdge
- CompositeCombineEvent()
: CompositeCombineEvent
- CompositeCoSurf()
: CompositeCoSurf
- CompositeCurve
: CompositeCoEdge
, CompositePoint
, CompositeCurve
- CompositeEngine
: CompositeSurface
, CompositeEngine
- CompositeEntry()
: CompositeEntry
- CompositeGeom()
: CompositeGeom
- compositeId
: CACompositeVG
- CompositeLoop
: CompositeCoEdge
, CompositeLoop
- CompositeLump
: CompositeShell
, CompositeLump
- CompositePoint()
: CompositePoint
- CompositeShell()
: CompositeShell
, CompositeCoSurf
- CompositeSurface()
: CompositeSurface
, CompositeCoSurf
, CompositeLoop
, CompositeSurface
- CompositeTool()
: CompositeTool
- compress()
, CGMHistory
, DLList
- compress_all_object_memory()
: MemoryManager
- compress_ids()
: RefEntityFactory
- compress_memory()
: MemoryManager
- compress_object_memory()
: MemoryManager
- compress_ref_ids()
: RefEntityFactory
- CompSurfFacets()
: CompSurfFacets
- compute_angles()
: SplitSurfaceTool
- compute_avg_normal()
: ImprintPointData
, CubitPoint
, CubitPointData
, FaceterPointData
- compute_curve_tangent()
: FacetEvalTool
, TDFacetBoundaryEdge
- compute_next_angle()
: SplitSurfaceTool
- computed
: BoundaryEdgeData
- concurrent_enabled()
: AppUtil
- concurrentSupport
: AppUtil
- condense_tree()
, RTreeNode< Y >
- condition()
: CubitMatrix
- ConeSurface()
: ConeSurface
- connect_edges_at_interface()
: ChollaEngine
- connect_facets_at_interface()
: ChollaEngine
- connect_points_at_interface()
: ChollaEngine
- consolidate_few_points()
: GMem
, CompSurfFacets
- consolidate_many_points()
: CompSurfFacets
, GMem
- consolidate_points()
: GMem
, CompSurfFacets
- const_iterator
: SimpleArray< T >
, DLIList< X >
, Hasher< Y, B >
- const_pointer
: DLIList< X >
- const_reference
: DLIList< X >
- constrain_boundary()
- construct()
: PartitionSurface
, PartPTCurve
, SegmentedCurve
- construct_Body()
: RefEntityFactory
- construct_matrix()
: CubitTransformMatrix
- construct_RefEdge()
: RefEntityFactory
- construct_refentities()
: GeometryQueryTool
- construct_RefFace()
: RefEntityFactory
- construct_RefGroup()
: RefEntityFactory
- construct_RefVertex()
: RefEntityFactory
- construct_RefVolume()
: RefEntityFactory
- contained_volume()
: FacetEvalTool
- container_type
: ManagedPtrVector< X >
- contains()
: GeometryContext::NamedGroup
, CubitFacet
, CubitFacetEdge
, VolumeCache
- contains_bridge()
: CompositeSurface
, CompositeBody
, BridgeManager
, TBOwner
, CompositeCoEdge
, CompositeCurve
, CompositeLump
- contains_char()
: CubitFileUtil
- contains_composites()
- contains_intermediate_geom()
- contains_intermediate_geometry()
: GeometryQueryTool
- contains_merged_children()
: MergeTool
- contains_merged_entities()
: MergeTool
- contains_partitions()
- control_points()
: CubitFacetEdge
, CubitFacet
, CubitFacetEdge
- controlPoints
: CubitFacetEdge
- convert_from_facet()
: ChollaMesh
- convert_from_point()
: ChollaMesh
- convert_string_to_lowercase()
: CubitUtil
- convert_to_facet()
: ChollaMesh
- convert_to_lines()
: GeomMeasureTool
, ImprintBoundaryTool
- convert_to_point()
: ChollaMesh
- coord
: CubitOctreeNode
, FB_Coord
- coord_list_get()
: SSSide
- coord_list_get_a()
: TDSplitSurface
- coord_list_get_and_back()
: SSSide
- coord_list_get_and_back_a()
: TDSplitSurface
- coord_list_get_and_back_b()
: TDSplitSurface
- coord_list_get_and_back_c()
: TDSplitSurface
- coord_list_get_and_back_d()
: TDSplitSurface
- coord_list_get_and_step()
: SSSide
- coord_list_get_and_step_a()
: TDSplitSurface
- coord_list_get_and_step_b()
: TDSplitSurface
- coord_list_get_and_step_c()
: TDSplitSurface
- coord_list_get_and_step_d()
: TDSplitSurface
- coord_list_get_b()
: TDSplitSurface
- coord_list_get_c()
: TDSplitSurface
- coord_list_get_d()
: TDSplitSurface
- coord_list_last()
: SSSide
- coord_list_last_a()
: TDSplitSurface
- coord_list_last_b()
: TDSplitSurface
- coord_list_last_c()
: TDSplitSurface
- coord_list_last_d()
: TDSplitSurface
- coord_list_reset()
: SSSide
- coord_list_reset_a()
: TDSplitSurface
- coord_list_reset_b()
: TDSplitSurface
- coord_list_reset_c()
: TDSplitSurface
- coord_list_reset_d()
: TDSplitSurface
- coord_list_size()
: SSSide
- coord_list_size_a()
: TDSplitSurface
- coord_list_size_b()
: TDSplitSurface
- coord_list_size_c()
: TDSplitSurface
- coord_list_size_d()
: TDSplitSurface
- coord_xform
: SurfaceCard
- COORDINATE_SYSTEM_CREATED
: CubitCoordEvent
- COORDINATE_SYSTEM_DELETED
: CubitCoordEvent
- COORDINATE_SYSTEM_MODIFIED
: CubitCoordEvent
- coordinates()
: GeomPoint
, TBPoint
, RefVertex
, CubitPoint
, CubitPointData
, FacetPoint
, OctreeFacetPointData
, OCCPoint
, FaceterPointData
, ImprintPointData
, PartitionPoint
, PartPTCurve
, CubitVectOctTreeEval
, DefaultPointQuery< X >
, DefaultWeightedNodeQuery< X >
, GPointOctTreeEval
, ImprintPointData
, CompositePoint
, GeoNode
- coordList
: SSSide
- coords
: FaceterPointData
, ImprintPointData
, CubitPointData
- copy()
: FacetBody
, PartitionSurface
, SubSurface
- COPY
: CGMHistory
- copy()
: OCCBody
- copy_attributes()
: OCCQueryEngine
- copy_body()
, FacetModifyEngine
, FacetQueryEngine
, OCCModifyEngine
- copy_body_attributes()
: OCCModifyEngine
- copy_edges_at_interface()
: ChollaEngine
- copy_edges_in_list()
- copy_facet_edges_at_interface()
: ChollaEngine
- copy_facets()
: FacetDataUtil
, FacetSurface
- copy_facets_at_interface()
: ChollaEngine
- copy_from()
: DLIList< X >
- copy_mtx()
- copy_pnt()
- copy_points_at_interface()
: ChollaEngine
- copy_refentity()
- copy_refentity_names()
: RefEntityName
- copy_to()
: DLIList< X >
- copyingEntity
- CopyModel()
- cornerCoEdge
: SplitSurfaceTool
- Cos()
- count()
: Hasher< Y, B >
, HasherVector< Y, S >
- count_curves_in_body()
: SplitSurfaceTool
- count_stream_users()
: CubitMessage
- count_surfaces_in_body()
: SplitSurfaceTool
- count_surfaces_in_owning_body()
: SplitSurfaceTool
- countEdges()
: OCCModifyEngine
- CoVertex()
: CoVertex
- CoVolume()
: CoVolume
- cpu
: CpuTimer
- cpu_secs()
: CpuTimer
- cpuInitial
: CpuTimer
- CpuTimer()
: CpuTimer
- crack_open_point()
: ChollaEngine
- create()
: GeomDataObserver
- create_2dmat
: TDOctreeRefFace
- create_and_schedule()
: CubitConcurrent
- create_and_schedule_group()
: CubitConcurrent
- create_arc()
: FacetModifyEngine
, OCCModifyEngine
, GeometryModifyEngine
- create_arc_center_edge()
, OCCModifyEngine
, FacetModifyEngine
- create_arc_radius()
: OCCModifyEngine
, FacetModifyEngine
- create_arc_three()
: SplitSurfaceTool
, FacetModifyEngine
, OCCModifyEngine
, FacetModifyEngine
, OCCModifyEngine
- create_arc_two()
: SplitSurfaceTool
- create_bbox_tets()
: TetFacetorTool< TET, SUBTET, NODE >
- create_body()
, FacetModifyEngine
, OCCModifyEngine
- create_cgm_history_objects()
: OCCHistory
- create_circle_surface()
, OCCModifyEngine
, OCCModifyEngine
- create_composites()
: CompositeEngine
- create_csa_tag()
: CGMTagManager
- create_cubit_attrib()
: CubitAttribFactory
, CubitAttribManager
, CubitAttribFactory
- create_curve()
: SplitSurfaceTool
, ChollaEngine
- create_curve_boundaries()
: FacetGeometryCreator
, ChollaEngine
- create_curve_combine()
: OCCModifyEngine
, FacetModifyEngine
- create_curve_helix()
- create_directory()
: CubitFileUtil
- create_divide_curves()
: OffsetSplitTool
- create_dummy_undo_object()
: CubitUndo
- create_elements()
: ChollaMesh
- create_ellipse_surface()
, OCCModifyEngine
- create_face()
: PST_Edge
- create_facet_bounding_box()
: FacetQueryEngine
- create_facets()
: FacetModifyEngine
- create_geometry()
: ChollaEngine
- create_local_storage()
: CubitQtConcurrent
, CubitConcurrent
- create_medial_axis()
: MedialTool2D
- create_medial_axis_3d()
: MedialTool3D
- create_midplane()
: MidPlaneTool
- create_mutex()
: CubitConcurrent
- create_net_surface()
, FacetModifyEngine
, OCCModifyEngine
- create_nodes()
: ChollaMesh
- create_offset_body()
, FacetModifyEngine
, OCCModifyEngine
- create_offset_sheet()
, OCCModifyEngine
, FacetModifyEngine
- create_offset_surface()
, FacetModifyEngine
, OCCModifyEngine
- create_old_to_new_ref_ent_map()
- create_parallelogram_surface()
- create_point()
: ChollaEngine
- create_port_event()
: OCCHistory
- create_rectangle_surface()
: OCCModifyEngine
- create_ref_edges()
: SplitSurfaceTool
, OffsetSplitTool
- create_rotation_mtx()
- create_shell_offset()
: FacetModifyEngine
- create_skin_surface()
, FacetModifyEngine
, OCCModifyEngine
- create_solid_bodies_from_surfs()
, OCCModifyEngine
, FacetModifyEngine
- create_super_bounding_box()
: OCCQueryEngine
- create_super_facet_bounding_box()
: FacetQueryEngine
- create_surface()
: OCCModifyEngine
, ChollaEngine
, FacetModifyEngine
, FacetModifyEngine
, OCCModifyEngine
- create_surface_boundaries()
, ChollaEngine
- create_surface_curve()
- create_surface_doubler()
- create_sweep_body()
: OffsetSplitTool
- create_sweep_curve()
: OffsetSplitTool
- create_sweep_section()
: OffsetSplitTool
- create_task1()
: CubitConcurrent
- create_task2()
: CubitConcurrent
- create_taskgroup1()
: CubitConcurrent
- create_taskgroup2()
: CubitConcurrent
- create_triangulation()
: ChordalAxis
- create_virtual_edge()
- create_virtual_vertex()
- create_volume_boundaries()
: ChollaEngine
- create_weld_surface()
: OCCModifyEngine
, FacetModifyEngine
- create_window()
: GfxDebug
- createGeometry()
: GeometryContext
- createGraveyard()
: GeometryContext
- CreateModel()
- createTag()
: CGMTagManager
- cross()
: Vector3d
- Cross()
- cross_vec()
- cross_vec_unit()
- csa()
: CompositeAttrib
- csa_from_dcsa()
: CADeferredAttrib
- csa_list
: OCCBody
- CSATagData()
: CSATagData
- CSimModel()
: NCubitFile::CSimModel
- csTol
- Cubit2DPoint()
: Cubit2DPoint
- cubit_simple_attrib()
: CAEntityTol
, CAMergeStatus
, CAMergePartner
, CAGroup
, CATag
, CAPartitionVG
, CABodies
, CubitAttrib
, CAVirtualVG
, CAAssemblyData
, CAVirtualVG
, CAPartitionVG
, CAMergePartner
, CACompositeVG
, CAUniqueId
, CASourceFeature
, CADeferredAttrib
, CAEntityName
, CAEntityId
, CAEntitySense
, CAEntityColor
- cubit_sleep()
: CubitUtil
- CubitAttrib()
: CubitAttrib
- CubitAttribFactory()
- CubitAttribManager()
: CubitAttribManager
- CubitAttribUser()
: CubitAttribUser
- CubitBox()
: CubitBox
- CubitColor()
: CubitColor
- CubitConcurrent()
: CubitConcurrent
- CubitCoordEvent()
: CubitCoordEvent
- CubitCoordinateSystem()
: CubitCoordinateSystem
- cubitDir
: AppUtil
- CubitDirIterator()
: CubitDirIterator
- cubitedge0index
: FB_Triangle
- cubitedge1index
: FB_Triangle
- cubitedge2index
: FB_Triangle
- cubitedgeindex
: FB_Edge
- CubitEntity()
: CubitEntity
- CubitEquation()
: CubitEquation
- CubitEventDispatcher
: CubitObservable
, CubitEventDispatcher
- CubitFacet()
: CubitFacet
- CubitFacetData()
: CubitFacetData
- CubitFacetEdge()
: CubitFacetEdge
- CubitFacetEdgeData()
: CubitFacetEdgeData
- CubitFile()
: CubitFile
- CubitFileUtil()
: CubitFileUtil
- CubitInputFile()
: CubitInputFile
- CubitMatrix()
: CubitMatrix
- CubitMessage()
: CubitMessage
, MessageFlag
- CubitMessageErrorHandler()
: CubitMessageErrorHandler
- CubitMessageHandler()
: CubitMessageHandler
- CubitObservable()
: CubitObservable
- CubitObserver()
: CubitObserver
, CubitObservable
- cubitOctree
- CubitOctree()
: CubitOctree
- CubitOctreeCell()
: CubitOctreeCell
- cubitOctreeGenerator
: CubitOctree
- CubitOctreeGenerator()
- CubitOctreeGeneratorVolumes()
- cubitOctreeNode
: CubitOctreeCell
- CubitOctreeNode()
: CubitOctreeNode
- CubitOperationEvent()
- CubitPlane()
: CubitPlane
- CubitPoint()
: CubitPoint
- CubitPointData()
: CubitPointData
- CubitPolygon()
: CubitPolygon
- CubitQtConcurrent()
: CubitQtConcurrent
- CubitQuadFacet()
: CubitQuadFacet
- CubitQuadFacetData()
: CubitQuadFacetData
- CubitSilence()
: CubitSilence
- CubitSimpleAttrib()
: CubitSimpleAttrib
- CubitSparseMatrix()
: CubitSparseMatrix
- CubitString()
: CubitString
- cubitsurfaceindex
: FB_Triangle
- CubitTransformMatrix()
- CubitUndo()
: CubitUndo
- CubitUtil()
: CubitUtil
- CubitVector()
: CubitVector
- curr_page_end_
: OctTree< X, E >
- current_allocated_memory()
- current_body_id()
: RefEntityFactory
- current_box
: OctTree< X, E >
- current_edge_id()
: RefEntityFactory
- current_face_id()
: RefEntityFactory
- current_group_id()
: RefEntityFactory
- current_insert_pos
: DLT_IdTable
- current_max
: OctTree< X, E >
- current_min
: OctTree< X, E >
- current_vertex_id()
: RefEntityFactory
- current_volume_id()
: RefEntityFactory
- currentAllocatedMemory
- currentDebugFlag
: CubitMessage
- currentDimension
: CAActuateSet
- currentIndex
: CompositeGeom
- currentList
: CAActuateSet
- currentVal
: TtyProgressTool
- currPercent
: TtyProgressTool
- curve
: CubitLoops< C, V >::CoEdge
- Curve()
: Curve
- curve()
: FacetCoEdge
, OCCCoEdge
- curve_center()
: RefEdge
- curve_in_surface()
- curve_is_on_ignored_surface()
: GeometryQueryEngine
, VirtualQueryEngine
- curve_param()
: CompositeCurve
- curve_ptr
: CoEdgeDataList
- curve_surface_intersection()
, FacetModifyEngine
, OCCModifyEngine
- curveCount
: PartitionPoint
- curveEdgeList
: ChollaCurve
- CurveFacetEvalTool()
: CurveFacetEvalTool
- curveFacetEvalTool
: FacetCurve
- CurveFacets()
: CurveFacets
- curveList
: ChollaPoint
- CurveList
: OCCQueryEngine
- curveList
: ChollaSurface
- curveNext
: PartitionCoEdge
- CurveOverlapFacet()
: CurveOverlapFacet
- curves()
: TopologyBridge
- curves_from_surfaces()
: PartitionEngine
- curves_ignore_virtual()
: TopologyBridge
- curveSliverCleanUpTolerance
: GeometryQueryTool
- CurveSM()
: CurveSM
- curveTopology
: SurfaceFacets
- curVisitFlag
- curvSense
- CUT
: CGMHistory
- cut_link()
: DLList
- cuttingdir
: TreeStack
- CW
: FBRetriangulate
- cylinder()
: OCCModifyEngine
, FacetModifyEngine
- CylinderEvaluator()
: CylinderEvaluator
- CylinderSurface()
: CylinderSurface
- Cylindrical
