MeshKit
1.0
00001 #include "meshkit/QuadCleanUp.hpp" 00002 00003 using namespace Jaal; 00004 00006 00007 void 00008 Jaal::set_doublet_tag(Mesh *mesh, const string &name) 00009 { 00010 int relexist2 = mesh->build_relations(0, 2); 00011 00012 mesh->search_boundary(); 00013 00014 size_t numnodes = mesh->getSize(0); 00015 for (size_t i = 0; i < numnodes; i++) { 00016 Vertex *vertex = mesh->getNodeAt(i); 00017 if( vertex->isActive() ) { 00018 if (QuadCleanUp::isDoublet(vertex)) { 00019 vertex->setAttribute(name, 1); 00020 } else 00021 vertex->setAttribute(name, 0); 00022 } 00023 } 00024 00025 if (!relexist2) 00026 mesh->clear_relations(0, 2); 00027 } 00028 00030 00031 bool 00032 Doublet::isSafe() const 00033 { 00034 assert(vertex); 00035 00036 if (vertex->isRemoved()) return 0; 00037 00038 FaceSequence apexfaces; 00039 vertex->getRelations( apexfaces ); 00040 00041 int nSize = apexfaces.size(); 00042 for (int i = 0; i < nSize; i++) { 00043 Face *face = apexfaces[i]; 00044 if (face->isRemoved()) return 0; 00045 if (face->isVisited()) return 0; 00046 } 00047 return 1; 00048 } 00049 00051 00052 void 00053 Doublet::makeShield() 00054 { 00055 FaceSequence apexfaces; 00056 vertex->getRelations( apexfaces ); 00057 00058 size_t nSize = apexfaces.size(); 00059 for (size_t i = 0; i < nSize; i++) { 00060 Face *face = apexfaces[i]; 00061 face->setVisitMark(1); 00062 } 00063 } 00064 00066 00067 vector<Doublet> 00068 QuadCleanUp::search_interior_doublets() 00069 { 00070 // 00072 // An interior doublet is a vertex, which is shared by two face neighbours. 00073 // They are undesirables in the quadmesh as it would mean the angle is 180 00074 // between some adjacent edges... 00075 // 00077 00078 size_t numnodes = mesh->getSize(0); 00079 00080 mesh->search_boundary(); 00081 00082 assert(mesh->getAdjTable(0, 2)); 00083 00084 size_t numfaces = mesh->getSize(2); 00085 for (size_t i = 0; i < numfaces; i++) { 00086 Face *face = mesh->getFaceAt(i); 00087 face->setVisitMark(0); 00088 } 00089 00090 vDoublets.clear(); 00091 00092 for (size_t i = 0; i < numnodes; i++) { 00093 Vertex *vertex = mesh->getNodeAt(i); 00094 if( !vertex->isRemoved() ) { 00095 if (isDoublet(vertex)) { 00096 Doublet newdoublet(mesh, vertex); 00097 if (newdoublet.isSafe()) { 00098 newdoublet.makeShield(); 00099 vDoublets.push_back(newdoublet); 00100 } 00101 } 00102 } 00103 } 00104 00105 return vDoublets; 00106 } 00107 00109 00110 Vertex* 00111 QuadCleanUp::insert_doublet(Face *face, Vertex *v0, Vertex *v2) 00112 { 00113 //Create new vertex at the center of (v0,v2) 00114 Point3D p3d; 00115 Vertex::mid_point(v0, v2, p3d); 00116 00117 Vertex *doublet = Vertex::newObject(); 00118 doublet->setXYZCoords(p3d); 00119 00120 int pos = face->getPosOf( v0 ); 00121 if( pos < 0) return NULL; 00122 00123 assert( v2 == face->getNodeAt( (pos+2) ) ); 00124 00125 Vertex *o1 = face->getNodeAt( pos+1 ); 00126 Vertex *o2 = face->getNodeAt( pos+3 ); 00127 00128 // Creating a doublet in the mesh changes: 00129 // (1) insert new node 00130 // (2) one old face is removed 00131 // (3) two new faces inserted. 00132 // 00133 00134 NodeSequence connect(4); 00135 00136 mesh->addNode(doublet); 00137 connect[0] = doublet; 00138 connect[1] = v0; 00139 connect[2] = o1; 00140 connect[3] = v2; 00141 00142 Face *newquad1 = Face::newObject(); 00143 newquad1->setNodes(connect); 00144 mesh->addFace(newquad1); 00145 00146 connect[0] = doublet; 00147 connect[1] = v2; 00148 connect[2] = o2; 00149 connect[3] = v0; 00150 00151 Face *newquad2 = Face::newObject(); 00152 newquad2->setNodes(connect); 00153 mesh->addFace(newquad2); 00154 00155 mesh->remove( face ); 00156 00157 return doublet; 00158 } 00159 00161 00162 Vertex* 00163 QuadCleanUp::insert_doublet(Face *face) 00164 { 00165 if (face->getSize(0) != 4) return NULL; 00166 Vertex *v0 = face->getNodeAt(0); 00167 Vertex *v2 = face->getNodeAt(2); 00168 return insert_doublet(face, v0, v2); 00169 } 00170 00172 00173 Vertex* 00174 QuadCleanUp::insert_boundary_doublet(Face *face) 00175 { 00177 // 00178 // X ( Internal Vertex) 00179 // . . 00180 // . . 00181 // . . 00182 // . . 00183 // ********X...........X...........X************************ 00184 // Boundary Singlet Boundary 00185 // 00186 // There is one quad on the boundary with three nodes on the boundary and 00187 // one internal nodes. In order to remove the singlet node, we artifically 00188 // create one doublet between the internal node and the singlet node. 00190 00191 if (!face->isBoundary()) 00192 return NULL; 00193 00194 if (face->getSize(0) != 4) 00195 return NULL; 00196 00197 int ncount = 0; 00198 for (int i = 0; i < 4; i++) { 00199 Vertex *v = face->getNodeAt(i); 00200 ncount += v->isBoundary(); 00201 } 00202 00203 if (ncount != 3) 00204 return NULL; 00205 00206 Vertex *v0 = NULL, *v2 = NULL; 00207 for (int i = 0; i < 4; i++) { 00208 Vertex *v = face->getNodeAt(i); 00209 if (!v->isBoundary()) { 00210 v0 = face->getNodeAt((i + 0) % 4); 00211 v2 = face->getNodeAt((i + 2) % 4); 00212 } 00213 } 00214 00215 return insert_doublet(face, v0, v2); 00216 } 00217 00219 00220 int 00221 Doublet::remove() 00222 { 00223 if (vertex->isRemoved() || vertex->isBoundary()) return 1; 00224 00225 FaceSequence neighs; 00226 vertex->getRelations( neighs ); 00227 assert(neighs.size() > 0); 00228 00229 if (neighs.size() != 2) return 1; 00230 00231 Face *face0 = neighs[0]; 00232 Face *face1 = neighs[1]; 00233 00234 assert(face0 != face1 ); 00235 00236 if (face0->isRemoved() || face1->isRemoved() ) 00237 return 1; 00238 00239 Vertex *d1 = NULL, *d2 = NULL, *o1 = NULL, *o2 = NULL; 00240 00241 NodeSequence connect = face0->getNodes(); 00242 if (connect.size() != 4) 00243 return 2; 00244 00245 int nC = connect.size(); 00246 for (int i = 0; i < nC; i++) { 00247 if (connect[i] == vertex) { 00248 d1 = connect[(i + 1) % 4]; 00249 o1 = connect[(i + 2) % 4]; 00250 d2 = connect[(i + 3) % 4]; 00251 break; 00252 } 00253 } 00254 00255 connect = face1->getNodes(); 00256 if (connect.size() != 4) 00257 return 2; 00258 00259 nC = connect.size(); 00260 for (int i = 0; i < nC; i++) { 00261 if (connect[i] == vertex) { 00262 o2 = connect[(i + 2) % 4]; 00263 break; 00264 } 00265 } 00266 00267 assert(d1); 00268 assert(d2); 00269 assert(o1); 00270 assert(o2); 00271 assert(o1 != o2); 00272 00273 // Change the connectivity of face0 and face1 is removed. 00274 mesh->deactivate( face0 ); 00275 mesh->deactivate( face1 ); 00276 00277 connect[0] = d1; 00278 connect[1] = o1; 00279 connect[2] = d2; 00280 connect[3] = o2; 00281 00282 // Reuse one of the face 00283 face0->setNodes( connect ); 00284 mesh->reactivate( face0 ); 00285 00286 // Other face and doublet die. 00287 mesh->remove( face1 ); 00288 mesh->remove( vertex ); 00289 00290 return 0; 00291 } 00292 00294 00295 int 00296 QuadCleanUp::remove_doublets_once() 00297 { 00298 search_interior_doublets(); 00299 00300 int ncount = 0; 00301 size_t nSize = vDoublets.size(); 00302 00303 for (size_t i = 0; i < nSize; i++) { 00304 int err = vDoublets[i].remove(); 00305 if (!err) ncount++; 00306 } 00307 00308 00309 return ncount; 00310 } 00311 00313 00314 int 00315 QuadCleanUp::remove_interior_doublets() 00316 { 00317 StopWatch swatch; 00318 swatch.start(); 00319 00320 int relexist2 = mesh->build_relations(0, 2); 00321 00322 mesh->search_boundary(); 00323 00324 // It is possible that removal of doublet may create singlets on the boundary 00325 // so, it is better to call doublets first and then call to singlet removal next. 00326 int ncount1 = 0; 00327 while (1) { 00328 int ncount2 = remove_doublets_once(); 00329 if (ncount2 == 0) break; 00330 ncount1 += ncount2; 00331 } 00332 00333 swatch.stop(); 00334 00335 if (!relexist2) 00336 mesh->clear_relations(0, 2); 00337 00338 cout << "Info: #Doublets removed : " << ncount1 << endl; 00339 cout << "Info: Doublet removal execution time : " << swatch.getSeconds() << endl; 00340 00341 return ncount1; 00342 } 00343 00345
