MeshKit
1.0
00001 //-----------------------------------C++-------------------------------------// 00002 // File: src/algs/Global.hpp 00003 // Wednesday February 11 10:50 2011 00004 // Brief: HarmonicMap class definition: do the harmonic mapping for the surface 00005 // mesh 00006 //---------------------------------------------------------------------------// 00007 00008 00009 #ifndef GLOBAL1_HPP 00010 #define GLOBAL1_HPP 00011 00012 #include <stdlib.h> 00013 #include <stdio.h> 00014 #include <assert.h> 00015 #include <string> 00016 #include <iostream> 00017 #include <fstream> 00018 #include <string.h> 00019 #include <limits.h> 00020 #include "meshkit/SimpleArray.hpp" 00021 00022 #include <iGeom.h> 00023 #include "meshkit/Matrix.hpp" 00024 #include <vector> 00025 #include <set> 00026 #include <list> 00027 00028 00029 using namespace std; 00030 typedef MeshKit::Vector<3> Vector3D; 00031 typedef MeshKit::Vector<2> Vector2D; 00032 typedef MeshKit::Matrix<3, 3> Matrix3D; 00033 00034 //===========================================================================// 00040 //===========================================================================// 00041 namespace MeshKit 00042 { 00043 static const double dist_tolerance = 1.0e-1; 00044 static const double eps = 1.0e-5; 00045 struct Vertex { 00046 Vertex() 00047 { 00048 onBoundary = 0; 00049 } 00050 int id; 00051 int index; 00052 bool onBoundary; 00053 Vector3D xyz; 00054 Vector2D uv; 00055 bool onCorner; 00056 iBase_EntityHandle gVertexHandle; 00057 }; 00058 struct Edge { 00059 int getNumNodes() const 00060 { 00061 return connect.size(); 00062 } 00063 Vertex* getVertex(int i) const 00064 { 00065 return connect[i]; 00066 } 00067 vector<Vertex*> connect;//could be 1 or 2 00068 iBase_EntityHandle gEdgeHandle; 00069 int id; 00070 int index; 00071 int edge_type;//-1 corner, 0 side, 1 end, -2 reversal 00072 double e; 00073 }; 00074 00075 struct Face { 00076 int getNumNodes() const 00077 { 00078 return connect.size(); 00079 } 00080 Vertex* getVertex(int i) const 00081 { 00082 return connect[i]; 00083 } 00084 int index; 00085 vector<Vertex*> connect; 00086 vector<Edge*> connEdges; 00087 vector<vector<int> > vertexloops; 00088 vector<vector<int> > edgeloops; 00089 iBase_EntityHandle gFaceHandle; 00090 int src_tgt_link;//0--source, 1--target, 2--linking 00091 }; 00092 00093 } 00094 00095 #endif
