MeshKit
1.0
00001 #ifndef REFINE_H 00002 #define REFINE_H 00003 00004 #include <bitset> 00005 #include "meshkit/Mesh.hpp" 00006 #include "meshkit/SwapEdges.hpp" 00007 00008 #include "meshkit/basic_math.hpp" 00009 00010 using namespace std; 00011 00013 // MeshRefine2D: 00014 // LongestEdgeRefine2D: ConsistencyRefine2D 00015 // ObtuseRefine2D: ConsistencyRefine2D 00016 // GradeRefine2D: ConsistencyRefine2D 00017 // Refine2D14: ConsistencyRefine2D 00018 // CentroidRefine2D 00019 // DelaunayRefine2D 00020 // Square3SubDivision 00022 //Class Refine, refines an existing triangulation. This class works for 2D cases 00023 //or the parametric domain of 3D surface triangulation. The user need to provide 00024 //which cells need to be refined. There could be many criteria for deviding the 00025 //cell, so this is not part of the class. 00026 // 00027 //Input : Connection : Connectivity of the triangulation ( 1D array) 00028 // : ParamCoords: parametric coordinates of the vertices. 00029 // : markFace : Faces which are marked for refinement. 00030 // 00031 //Output: Connection : 00032 // ParamCoords: 00033 // 00034 //If the user is working with 3D triangulated surface, it is assumed that he 00035 //has some representation ( example NURBS ) from which he can calculate the 00036 //physical Coordinates from the paramCoords. Again this is not the responsiblity 00037 //of the class. 00038 // 00039 //------------------------------------------------------------------------------ 00040 //Number of Division : New Vertices : New Faces 00041 //------------------------------------------------------------------------------ 00042 // 2 : 1 : 1 00043 // 3 : 0 : 2 00044 // 4 : 3 : 3 00045 //------------------------------------------------------------------------------ 00046 // Default Number of Subdivisions is 2, which is conservative approach, but 00047 // good at equalizing the aspect ratio with respect to neighbouring triangles. 00048 // 00049 // Programmer : Chaman Singh Verma 00050 // Place : Argonne National Lab. 00051 // Argonne, IL, USA 00052 // 00053 // 00055 // 00062 namespace Jaal 00063 { 00064 enum RefinePolicy { CENTROID_PLACEMENT, CIRCUMCENTER_PLACEMENT, LONGEST_EDGE_BISECTION}; 00065 00066 enum RefineObjective {REFINE_AREA, REFINE_ASPECT_RATIO, REFINE_CURVATURE}; 00067 00069 00071 class MeshRefine2D 00072 { 00073 public: 00074 00075 MeshRefine2D() { 00076 boundary_split_flag = 0; 00077 numIterations = 1; 00078 } 00079 virtual ~MeshRefine2D() {} 00080 00081 void setMesh( Mesh *m ) { mesh = m; } 00082 00083 // void setGeometry( const iGeom_Instance &g ) { geom = g; } 00084 00085 void setBoundarySplitFlag( bool f ) { boundary_split_flag = f; } 00086 00087 const NodeSequence &getNewNodes() const { return insertedNodes; } 00088 const FaceSequence &getNewFaces() const { return insertedFaces; } 00089 00090 size_t getNumFacesRefined() const { return numfacesRefined; } 00091 00092 virtual int execute() = 0; 00093 00094 virtual int initialize(); 00095 00096 void setNumOfIterations( int i ) { numIterations = i; } 00097 00098 // Set Desired Mesh Quality 00099 void setAspectRatio( double a ) { desiredAspectRatio = a; } 00100 void setDesiredArea( double a ) { desiredArea = a; } 00101 void setMinimumAngle( double a ) { desiredMinAngle = a; } 00102 void setMaximumAngle( double a ) { desiredMaxAngle = a; } 00103 void setFeatureAngle( double a ) { featureAngle = a; } 00104 void setMaximumCells( size_t a ) { maxAllowedCells = a; } 00105 00106 protected: 00107 Mesh *mesh; 00108 00109 class RefinedEdgeMap 00110 { 00111 public: 00112 void clear(); 00113 00114 bool hasEdge( Vertex *v1, Vertex *v2) const; 00115 bool allow_edge_refinement( const Edge *edge) const; 00116 00117 Vertex* setVertexOnEdge(Vertex *v1, Vertex *v2); 00118 Vertex* getVertexOnEdge(Vertex *v1, Vertex *v2) const; 00119 bool boundary_split_flag; 00120 00121 // Get All the inserted vertices on the edges.. 00122 NodeSequence getInsertedNodes() const 00123 { 00124 NodeSequence result; 00125 std::map<Vertex*, vector<RefinedEdge> >::const_iterator it; 00126 for( it = refined_edges.begin(); it != refined_edges.end(); ++it) 00127 { 00128 const vector<RefinedEdge> &refedges = it->second; 00129 for( size_t i = 0; i < refedges.size(); i++) 00130 result.push_back( refedges[i].midVertex ); 00131 00132 } 00133 return result; 00134 } 00135 private: 00136 struct RefinedEdge 00137 { 00138 Edge *edge; 00139 Vertex *midVertex; 00140 }; 00141 Edge* create_new_edge( const Vertex *v1, const Vertex *v2 ); 00142 std::map<Vertex*, vector<RefinedEdge> > refined_edges; 00143 }; 00144 00145 RefinedEdgeMap *edgemap; 00146 00147 FaceSequence insertedFaces; 00148 NodeSequence hangingVertex, insertedNodes; 00149 00150 int numIterations; 00151 bool boundary_split_flag; 00152 size_t numfacesRefined; 00153 00154 double desiredAspectRatio, desiredArea; 00155 double desiredMinAngle, desiredMaxAngle; 00156 double featureAngle; 00157 size_t maxAllowedCells; 00158 00159 int finalize(); 00160 00161 void append_new_node( Vertex *v0 ); 00162 Face* append_new_triangle(Vertex *v0, Vertex *v1, Vertex *v2); 00163 Face* append_new_quad(Vertex *v0, Vertex *v1, Vertex *v2, Vertex *v3); 00164 00165 void remove_it(Face *face) { 00166 face->setStatus( MeshEntity::REMOVE); 00167 } 00168 }; 00169 00171 00172 struct Sqrt3Refine2D : public MeshRefine2D 00173 { 00174 Sqrt3Refine2D() {} 00175 Sqrt3Refine2D(Mesh *m) { setMesh(m); } 00176 00177 int execute(); 00178 }; 00179 00181 00182 class CentroidRefine2D : public MeshRefine2D 00183 { 00184 public: 00185 CentroidRefine2D() {} 00186 CentroidRefine2D( Mesh *m ) { setMesh(m); } 00187 00188 void refine( Face *f ) { 00189 atomicOp( f ); 00190 mesh->prune(); 00191 } 00192 00193 void refine( Mesh *m ) { 00194 setMesh( m ); 00195 00196 size_t nSize = mesh->getSize(2); 00197 for( size_t i = 0; i < nSize; i++) 00198 atomicOp( mesh->getFaceAt(i) ); 00199 mesh->prune(); 00200 } 00201 00202 int execute(); 00203 private: 00204 int atomicOp( Face *f); 00205 int refine_tri( Face *f); 00206 int refine_quad( Face *f); 00207 }; 00208 00210 00211 class LongestEdgeRefine2D : public MeshRefine2D 00212 { 00213 public: 00214 LongestEdgeRefine2D() 00215 { 00216 cutOffAspectRatio = 0.50; 00217 } 00218 00219 LongestEdgeRefine2D(Mesh *m) { 00220 setMesh(m); 00221 cutOffAspectRatio = 0.50; 00222 } 00223 00224 ~LongestEdgeRefine2D() {} 00225 00226 void setCutOffAspectRatio(double asp) { cutOffAspectRatio = asp;} 00227 00228 int execute(); 00229 00230 private: 00231 double cutOffAspectRatio; 00232 int atomicOp( const Face *face); 00233 }; 00234 00236 00237 class ConsistencyRefine2D : public MeshRefine2D 00238 { 00239 public: 00240 ConsistencyRefine2D() { } 00241 ConsistencyRefine2D( Mesh *m, RefinedEdgeMap *emap) 00242 { setMesh(m); edgemap = emap;} 00243 00244 ~ConsistencyRefine2D() {} 00245 00246 int execute(); 00247 00248 private: 00249 bitset<3> edge0, edge1, edge2, bitvec; 00250 00251 int atomicOp( Face *f); 00252 void refineEdge0(const Face *f); 00253 void refineEdge1(const Face *f); 00254 void refineEdge2(const Face *f); 00255 00256 void subDivideQuad2Tri( const NodeSequence &qnodes); 00257 void makeConsistent1( Face *f ); 00258 void makeConsistent2( Face *f ); 00259 void makeConsistent3( Face *f ); 00260 void makeConsistent(); 00261 void checkFaceConsistency( Face *f); 00262 }; 00263 00265 00266 class Refine2D14 : public MeshRefine2D 00267 { 00268 public: 00269 00270 ~Refine2D14() {} 00271 00272 int initialize() { return 0; } 00273 int execute(); 00274 00275 private: 00276 int atomicOp( Face *f); 00277 int refine_tri( Face *f); 00278 int refine_quad( Face *f); 00279 }; 00280 00282 00283 struct DelaunayRefinement2D : public MeshRefine2D 00284 { 00285 ~DelaunayRefinement2D() {} 00286 00287 int initialize(); 00288 int finalize(); 00289 int execute() { 00290 00291 return 0; 00292 } 00293 }; 00294 00296 00297 class ObtuseRefine2D : public MeshRefine2D 00298 { 00299 public: 00300 ObtuseRefine2D( ) { cutoffAngle = 90.0;} 00301 00302 void setCutOffAngle( double a ) { cutoffAngle = std::max(90.0, a); } 00303 00304 int initialize(); 00305 int execute(); 00306 00307 private: 00308 double cutoffAngle; 00309 int atomicOp(const Face *f); 00310 }; 00311 00313 00314 class GradeRefine2D : public MeshRefine2D 00315 { 00316 public: 00317 int initialize(); 00318 int finalize(); 00319 int execute(); 00320 00321 private: 00322 int atomicOp( const Vertex *v); 00323 }; 00324 00326 00327 } 00328 00329 #endif 00330
