MeshKit
1.0
00001 #include "meshkit/QuadCleanUp.hpp" 00002 00003 using namespace Jaal; 00004 00006 00007 void 00008 Jaal::set_singlet_tag(Mesh *mesh, const string &aname ) 00009 { 00010 size_t numnodes = mesh->getSize(0); 00011 00012 int relexist = mesh->build_relations(0, 2); 00013 00014 if (!mesh->isBoundaryKnown()) 00015 mesh->search_boundary(); 00016 00017 size_t ncount = 0; 00018 for (size_t i = 0; i < numnodes; i++) { 00019 Vertex *vertex = mesh->getNodeAt(i); 00020 if( vertex->isActive() ) { 00021 if (QuadCleanUp::isSinglet(vertex)) { 00022 vertex->setAttribute(aname, 1); 00023 ncount++; 00024 } else 00025 vertex->setAttribute(aname, 0); 00026 } 00027 } 00028 cout << "#of Singlets detected: " << ncount << endl; 00029 00030 if (!relexist) 00031 mesh->clear_relations(0, 2); 00032 } 00033 00035 00036 vector<Singlet> 00037 QuadCleanUp::search_boundary_singlets() 00038 { 00039 vSinglets.clear(); 00040 // 00041 // A boundary singlet is a vertex which is shared by only one face. 00042 // They are undesirables in the quad mesh as that would mean large 00043 // angle on some of the edges.. 00044 // 00045 // For the flat singlet ( angle closer to 180 degree ). it is easy 00046 // to remove the neighbouring quad from the mesh. 00047 // 00048 00049 int relexist = mesh->build_relations(0, 2); 00050 00051 mesh->search_boundary(); 00052 00053 assert(mesh->getAdjTable(0, 2)); 00054 00055 size_t numfaces = mesh->getSize(2); 00056 for (size_t i = 0; i < numfaces; i++) { 00057 Face *face = mesh->getFaceAt(i); 00058 face->setVisitMark(0); 00059 } 00060 00061 size_t numnodes = mesh->getSize(0); 00062 for (size_t i = 0; i < numnodes; i++) { 00063 Vertex *v = mesh->getNodeAt(i); 00064 if( v->isActive() ) { 00065 if (isSinglet(v)) { 00066 Singlet newsinglet(mesh, v); 00067 vSinglets.push_back(newsinglet); 00068 } 00069 } 00070 00071 } 00072 00073 if (!relexist) 00074 mesh->clear_relations(0, 2); 00075 00076 if (vSinglets.size()) 00077 cout << "Info: Number of Singlets detected " << vSinglets.size() << endl; 00078 00079 return vSinglets; 00080 } 00081 00083 00084 int 00085 QuadCleanUp::remove_boundary_singlets_once() 00086 { 00087 00088 if (vSinglets.empty()) 00089 search_boundary_singlets(); 00090 00091 int ncount = 0; 00092 size_t nSize = vSinglets.size(); 00093 for (size_t i = 0; i < nSize; i++) { 00094 int err = vSinglets[i].remove(); 00095 if (!err) { 00096 ncount++; 00097 } 00098 } 00099 00100 vSinglets.clear(); 00101 00102 return ncount; 00103 } 00105 int Singlet::remove() 00106 { 00107 FaceSequence vfaces; 00108 vertex->getRelations( vfaces ); 00109 if (vfaces.size() > 1) return 1; 00110 00111 return mesh->refine_quad15(vfaces[0]); 00112 } 00113 00115 00116 int 00117 QuadCleanUp::remove_boundary_singlets() 00118 { 00119 int relexist = mesh->build_relations(0, 2); 00120 00121 int ncount = 0; 00122 while (1) { 00123 size_t nremoved = remove_boundary_singlets_once(); 00124 if (nremoved == 0) break; 00125 ncount += nremoved; 00126 } 00127 00128 if (!relexist) mesh->clear_relations(0, 2); 00129 00130 return ncount; 00131 } 00132 00134 00135 void 00136 Singlet::clear() 00137 { 00138 size_t nSize = newNodes.size(); 00139 for (size_t j = 0; j < nSize; j++) 00140 delete newNodes[j]; 00141 newNodes.clear(); 00142 00143 nSize = newFaces.size(); 00144 for (size_t j = 0; j < nSize; j++) 00145 delete newFaces[j]; 00146 00147 newFaces.clear(); 00148 00149 } 00150 00152 00153 int 00154 Singlet::commit() 00155 { 00156 00157 for (size_t i = 0; i < oldFaces.size(); i++) { 00158 if (oldFaces[i]->isRemoved()) { 00159 clear(); 00160 return 1; 00161 } 00162 } 00163 00164 if (!active) return 2; 00165 00166 for (size_t i = 0; i < oldNodes.size(); i++) 00167 mesh->remove( oldNodes[i] ); 00168 oldNodes.clear(); 00169 00170 for (size_t i = 0; i < oldFaces.size(); i++) 00171 mesh->remove(oldFaces[i] ); 00172 oldFaces.clear(); 00173 00174 for (size_t i = 0; i < newNodes.size(); i++) 00175 mesh->addNode(newNodes[i]); 00176 newNodes.clear(); 00177 00178 for (size_t i = 0; i < newFaces.size(); i++) 00179 mesh->addFace(newFaces[i]); 00180 newFaces.clear(); 00181 00182 return 0; 00183 00184 } 00185 00187
